Hello all,
so far I had no reason whatsoever to complain about the electrics of my XJ: left unmolested and kept in shape most everything has worked so far.
The one thing that has not worked as it should over my years of ownership is the rear heated window. After I got annoyed somed days ago I made up an electric flow diagram and found out that the RHW has a second control light in the speedo. Last night I checked, found out that the control light didn’t come on and tried to “exercise” the switch. In the course of this repeated switching a mysterious thing occurred.
All of a sudden my windscreen wipers became faster and the instrument lighting much brighter. The dashboard voltmeter maxed out. I reacted by reducing engine speed, switching off the wipers, turning down the rheostat and - finally - switching off the rear heated window.
Some moments later things got better and system voltage returned to a normal state.
It all looks as if the voltage regulator cut out for a certain period of time. Is this a typical failure mode? Do you see any connection with the heated rear window thing - the heated rear window is supplied through the ignition protection relay? Why on earth does the voltage rise to +18 V at engine speeds around 1500 RPM? I would have expected this to happen more at like 4000 RPM. Questions over questions for the holiday seasons …
Thank you all in advance
Best wishes
Jochen
75 XJ6L 4.2 auto (UK spec)
