Have him turn one output flange. Does the other turn in the same direction, or the other way. since he 'can not see" the tag, I sense a lack of trust… SAD.
Looks decent. Outboard discs. so inviting.
Open or limited slip differential?
Ratio?
Carl
No PWR-LOK on mine, but the 3.31 is fine, especially if you have a manual +O/D!
Right Pekka,
without doing the maths I’d guess that 3.31 + OD comes pretty close to 3.07 + BW.
Of course, the stick shift makes it a lot more responsive and competent …
Best
Jochen
75 XJ6L auto (UK spec)
Limited slip.
3.somethin’ ratio.
Hi Jochen,
I only have a degree in Arts, but my maths would say:
3.31 x 0.8 = 2.648
So that’s more like 2.65, unless I did something wrong? It drops revs 20% so if I am doing 2.500rpm in top gear at 100km/h engaging O/D drops revs to 2.000rpm.
Sorry for the OP, this is a bit OT.
Absolutely correct, Pekka, from what I can oversee. I wasn’t sure about the 20 % reduction on the OD, but, yes, if it’s 20 %, then 2.65 is correct.
Best
Jochen
75 XJ6L 4.2 auto (UK spec)
THAT low? My automatic will have to behave extremely well over the next years… 2500rpm results in under 90km/h! Not sure if that is 3.54 or 3.31, had no good chance to see the tag yet.
David I would say that is 3.54 diff my 3.8 ‘S’ MoD was sitting at 1800rpm @ 60mph if I recall correctly, this was with an ‘E’ C/w and pinion fitted of 3.07:1
I’m afraid you’re right. I actually think it’s too quick setting off, feels very light and powerful but not as much room for long distances I could do with a 3.0xx some time in the future… or overdrive
That is a really nice clean unit @Eric318 !
So the 15" Kent alloy wheels don’t fit (this was expected). I tried on 16" “Kiwi fruit” rims that fit well.
I guess, I now have an excuse to fit beefier wheels…
Any one in NoCal wants a set of Kent wheels with near unused white line tires (Firestone Tigerpaw: so appropriate… )
Hi …
I have XJC 4.2 automatic.
I need to restore IRS. I have one extra IRS from XJ S3 (3.07 - P.L.) and IRS from XJS 3.6 manual (still on the car, I can’t read marks)…or leave original (A 75 S - 350 ) ?
Can someone explain differences between them in praksis?
3.07 is excellent and PL even better - what do you expect, what do you want from the car - speed or acceleration, race at the lights or go fast?
Acceleration is more important than fast drive…
…and is 5 speed gearbox from XJS 3.6 (1986) compatible with XJC 4.2 (1977) engine? Is very complicated to convert ?
1 . need pedals for the clutch…
2. …
You need a manual from a series XJ. Either the Jaguar box or the LT77. Short of that you want at least a 3.058 or a 3.31 or a 3.54 which is already a bit short in my opinion. But I prefer long legs.
A friend had an XJC 4.2 fitted with the Getrag 'box . I thought it was an S3 box, but I think they were Rover, so maybe from the 3.6 XJS. Apparently was a successful conversion.
They were originally designed for BMW, I believe. I like this gearbox, my 3.6 has it indeed with a 3.54 rear end: 2000 rpm at 100Km/h.
The S3 XJ box was a slightly uprated Rover box that perhaps had some Jaguar history before it ended up in the Rovers.
