Folks:
After removing the factory spec bushings in my steering rack and replacing these with poly, I carefully reinstalled that rack, paying particular attention to the parallelism of the rack main body with respect a line drawn between the lower A-arm pivots. While not done using the factory jig tool, I paid attention to the main reason this tool is specified.
Prior to changing the rack bushings, I knew I had a pre-existing toe out condition, as it identified itself by inordinate wearing of the inner sides of both tires, one much worse than the other.
After replacing those bushes, I brought the car (and with fresh tires all around) to an alignment shop I have used in the past (but all U.S. carsā¦). This was an experience I may write about another time. They almost refused when they discovered a Jag tool was required to align (the rear suspension) the car. I made it clear that I was only after toe, and that they could tell me about caster, camber and even toe, for all four wheels when they finished the front toe. They agreed that they could do the front toe adjustment, but they did not want to touch the rear suspension at all.
Incoming front toe was: left: -0.60 degrees (0 to 0.13 degrees factory), right: -0.98 degrees, for a total toe of -1.58 degrees. Way out- in fact, you could see the outward pointing of each wheel, and also note one was a bit further out than the other.
As adjusted, the front toe was: left: 0.05 degrees, right: 0.06 degrees, total toe: 0.12 degrees.
The short story is that the car now tracks and steers with the impeccable manners and sharpness I recall from earlier days when I had run poly bushes in a different rack. So, so far, so good.
They then presented the situation on the IRS: toe: left side: -0.12 degrees (spec is 0 to 0.03 degrees, I am told), right side: +0.07 degrees, with the total toe at -0.05 degrees.
Hereās the rub, though: I have not seen evidence of abnormal tire wear, let alone wear ascribable to toe misadjustment.
I have understood that the IRS cannot be adjusted for toe, and that toe issues, when they arise, evidently are due to excess needle bearing wear on the lower arms. There may be other reasons, but I am only aware of the bearings matter.
Anybody on this list have any experience with these kinds of IRS toe measurements? About 8 years ago, I changed out the diff, and thereās evidence that the camber on the left side needs to be adjusted (when I swapped the diff in, I simply replaced the same shims I had carefully removed when disassembling the setup to remove the 2.88 diff- never came back to camber measurement, tho, as I probably should have done.). But toe? This must have been pre-existing from the 2.88 days, yet, I could never observe inordinate tire wear patterns on any tires I have run on this car.
I am puzzled, as the measurements ostensibly indicate a rear toe issue, but the tire wear is simply not consistent with those measurements. If anyone out there has had a toe problem on their IRS, and have solved it, I would very much like to hear about it!
Thanks,
Mike
