jag-lovers-digest Tuesday, 1 October 1996 Volume 02 : Number 392
1987 XJ6 III brake light problem
Re: Substitute throttle potentiometer for V12 EFI
Re: '88 XJ-S V12 (UK) steering rack replacement
My groan is gone! ('59 MK1)
RE: Alternators and Dynamos
RE: nice new jag - need answers
Re: swap name
Re: Restore or replace, SIII XJ-6
Re: 1987 XJ6 III brake light problem
Car Storage - Carcoon
Re: swap name
aluminum polish
aluminum polish
Sir William, noisy AC.
Re: aluminum polish----------------------------------------------------------------------
Date: Mon, 30 Sep 96 09:52:22 PDT
Subject: 1987 XJ6 III brake light problem
Hello everyone,
On the way to work today my wife said that the red brake light (idiot light) came on while she was driving. At the time she said the light came on while she was not braking and stayed on after that. She did not stop driving when this happened. Her discription of this was that there was no difference in braking after the light went on. I have not checked out the car yet and I am hoping I can get some suggestions on what to look for to identify what the problem is. If any one has any suggestion please let me know, because I would like to get the car roadworthy a soon as possible.
Last week I installed new front brake pads and at that time the brake fluid was topped up. There is no evidence of any leaks on my garage floor. Any help would be appriciated. Thanks.
George Mykulowycz
87 XJ6 Vanden Plas
77 XJ6C
69 XKE Roadster
Date: Mon, 30 Sep 1996 13:23:45 -0005
Subject: Re: Substitute throttle potentiometer for V12 EFI
Jeffrey Gram:
A small mirror and and a LED-Laser and pick-up sensors packed around
a perimeter of 180 degrees would do the job together with a
array of gates to electronically switch resistances in / out. To overcome
coarseness a Pentium 200 based or other small microprocessor could time
interpolate and average over the signals from adjacent LASER detectors and
switch
a secondary bank of fine adjustment resistors in and out.
This sounds like a workable plan! And it probably wouldn’t cost any
more than the Jaguar throttle pot!
– Kirbert | If anything is to be accomplished,
| some rules must be broken.
| - Palm’s Postulate
Subject: Re: '88 XJ-S V12 (UK) steering rack replacement
- Anyone have a UK supplier and part number for the aftermarket bushings
WITH WHOM THEY HAD GOOD EXPERIENCES ?
Matthias:
I got mine from Barret’s and they are black. They fit well, but the there
is a little metallic sleeve in the middle. When the rack moves in the fittings
you can feel (barely) the sleeve touching the mounting. I don’t know the
other fittings, but a “full” plastic fitting might be better.
This sounds like the bushings were installed incorrectly! The ‘metal
sleeve’ is essential to the design, and the bolt is supposed to be
tightened down until the brackets on the chassis are against both
ends of it. If yours are merely ‘touching the mounting’,
either you didn’t tighten the mounting bolts enough or you didn’t use
enough fender washers during assembly.
- How difficult is it really ? Any non-obvious caveats ?
Make sure you remove the bold which connects to the tower
to the steering column, otherwise it won’t come off
True, but you can replace the rack bushings without disconnecting the
steering column.
| - Palm’s Postulate
Date: Mon, 30 Sep 1996 10:28:11 -0700
Subject: My groan is gone! ('59 MK1)
Hi Guys-
Back in August, I posted a message to the group asking for some
diagnostic help with a really bad groaning noise my car was making. I
described it then as the same sound a big truck or bus might make just
as it rolls to a stop. It would only happen after about an hours driving,
after everything had gotten warm, and occured when turning left or
driving on a road with lots of crown (right side of car lower than left).
It went away if I applied the brakes, and when it started happening, the
brake pedal also got hard; too hard in my opinion. It began happening
this summer after I completed the conversion to wire wheels.
I’ve let the problem go for a while. I didn’t have any long trips planned
with the car, and during short drives around town, the problem never
happened. I was also kind of depressed about it: the consensus seemed to be
that I might have a bad rear wheel (axle) bearing which would be a major
pain to get to. That, and a new toy in the garage which has been
occupying most of my free time lately, are my excuses for not getting to
work on this sooner…
On Saturday, I finally decided to take a closer look at things
to see if I could find the source of the problem. One theory I had
was that the right rear hub might be loose on the taper, allowing the
rotor to shift slightly between the pads, setting up a vibration. I
was going to pull the cotter pin, and really bear down on the big nut
retaining the hub with an impact wrench. Pulled the wheel and decided
to first check all the nuts/bolts while I was in there.
Call it being in tune with my car; call it mechanics intuition, call
this blind luck whatever you want; but the first bolt I checked was
loose. It was the upper bolt holding the right rear caliper to the axle.
Took almost 3 full turns (I was starting to think it was stripped) to
get it tight. So, I think my theory was close… except that it wasn’t
the rotor that was shifting, it was the caliper.
Took the car for a good long drive on Sunday, and there is no hint of
the noise! No hint of the brake pedal getting hard either!
The groan is gone!
I did replace the pistons on the rear calipers as part of my conversion
to wires (see BestWeb.com - Lease or Buy Domain Names - Best Web Limited if you care
why). I have a faint memory of maybe starting to pull this caliper before
deciding to just swap the pistons in place. Perhaps I started to loosen the
bolt, decided to try and swap in place, and never remembered to re-tighten it.
They weren’t saftey wired (they are now), but rather were held in with red
loc-tite. After losing one of these bolts from a front caliper a couple
of years ago, you’d think I’d have finally learned my lesson…
Happy happy, joy joy-
===== __ ============================================================== |> ===
/_\ Ryan Border o~_ o~_ | *
/ / / Hewlett Packard Company, Inc. >/-.>/’ /o| *
/ / / _______ Software Design Engineer ( )-–(*)-( )’ *
/ / //_____\ email: rborder@cup.hp.com or border@best.com *
/ / __ / / __ / 19111 Pruneridge Ave. mailstop 42LX, Cupertino, CA 95014 *
/ / / / / / // / (408) 447-2496 FAX: (408) 447-0641 *
//// / _____/ WWW: BestWeb.com - Lease or Buy Domain Names - Best Web Limited *
Date: Mon, 30 Sep 96 18:29:00 GMT
Subject: RE: Alternators and Dynamos
A very simple answer is:
That a dynamo produces direct charging current, DC, and an alternator
produces an alternating charging current, AC.
The complicated answer is:
The dynamo has a rather limited output rarely above 30 amps and as such is
unable to produce sufficient output to efficiently run the modern car.
The alternator however is available in several models which can provide an
output from 60 to 100 amps. The 60 amp versions are the most common whereas
the higher output units are usually fitted to heavy usage vehicles like the
emergency services.
The dynamo works by spinning a coil between 2 magnetic fields, this has the
effect of inducing a voltage in the coil which is tapped off at a constant
current rate. The alternator works by spinning a magnet between 2 coils.
The induced voltage from each coil, 1 positive and 1 negative,
alternating, are fed to the rectifier and the positive voltage is tapped off
at a constant voltage rate. Therefore the dynamo is a constant current
charger and the alternator is a constant voltage charger.
eg. Dynamo: increase engine speed = increased voltage - lights get
brighter.
Alternator: increase engine speed = increased current - no effect on
lights.
Both alternators and dynamos require regulators to ensure a constant feed to
the electrical circuit, the regulator prevents over charging. The
alternator requires an additional circuit known as a rectifier, this
converts the AC output to a DC output required for vehicle circuits. The
regulator on the dynamo is usually a separate device with relays preset to
operate at the required voltage. The alternator has a rectifier built in
and sometimes also the regulator. These devices are “solid state” or
transistorised and far more efficient. Both devices are usually set-up to
give a maximum voltage output of approx 14 volts @30amps(dynamo) &
60amps(alternator), for commercial vehicles this would be 24 volts @60 - 100
amps(alternator).
Barrie Dawson
Chatham, Kent England
1985 series III Sovereign
Subject: Alternators and Dynamos
Date: 30 September 1996 23:38
A very simple minded question. What’s the difference between an
alternator and a dynamo? Is one American and the other English for
the same thing, or is there some kind of a distinction?
Makoto Honjo
Phone/Fax +81-3-3473-1848
Date: Mon, 30 Sep 96 18:37:00 GMT
Subject: RE: nice new jag - need answers
Quick check do a compression test for the head gasket, look for oil in water
or water on dipstick. General visual inspection of hoses or leaks from the
heater inside the car, could also be a faulty pressure cap.
I’d be concerned if the temperature gauge went above the mid point, this
would indicate trouble.
Barrie Dawson
Subject: nice new jag - need answers
Date: 30 September 1996 11:37
I have found a 1991 ultra-mint XJS V12 Convertible to replace my 1987 that
was destroyed. One owner, all receipts, flawless, only 35K miles.
Two questions before signing the cheque though:
It was a bit low on coolant and I want to make sure it’s not leaking or
(perish the thought) small head gasket leak into exhaust despite the low
mileage. What’s the best way to figure it out???
The temperature gauge never rose above mid point (N) despite repeated
thrashings in very hot climate. However, when cruising at speed in a more
subdued manner, the temp.gauge dropped a little bit. Is this normal or
should I be concerned???
Please respond quick before I buy it anyway.
Thanks Julian Mullaney
Date: Mon, 30 Sep 1996 14:25:29 -0500 (CDT)
Subject: Re: swap name
On Fri, 27 Sep 1996, Jeffrey Gram wrote:
swap name
I vote for the last more informative name, but something more “cathing” would be appropiate.
what about,Jag-lovers spares corner ?
The Cats Corner ?
etc.
Don’t forget a good motto, say something like one that 103rd Street Auto
Parts in Jacksonville, Florida, once (still?) had:
"All of our parts are road tested."
Larry Lee
Date: Mon, 30 Sep 1996 21:10:14 +0200
Subject: Re: Restore or replace, SIII XJ-6
[ Hunt Dabney hdabney@earthlink.net ]
| I plan to find a local “rent a lift” DIY garage and get the beast up on a
| rack for close inspection. Will survey what it needs and go from there.
Woah there! There can be only one beast, and it is mine.
The series 3 is a female car, no doubt about it, so you’ll
have to find another name for it :-p
The Real Beast ™ is my series 1, manual overdrive, no
girly electric windows, no sun roof, no air-condition,
rough paint-job (British Racing Green, accept no substitute),
no radio antenna, only one wing-mirror and no extra blinky
lights all around. I call it a lightweight, since I keep
having spare bits left over after working on it… It
proven it’s heritage on the racetrack, with me manhandling
the Jag-lovers Nardi steering wheel. It’s made it to the
North Cape and back, with a trailer riding shotgun all the
way. It runs all year round, rain snow or sleet, no problems,
other than an incredibly feeble heater. Thanks to the lack
of soundproofing under the bonnet I can hear every tick,
whine and grunt from the snorting, oil-dripping XK-engine,
pushing it’s waste through the self-installed, very poorly
hung stainless system.
Now, my series 3 is a hairdressers car in comparison. So
my wife gets to drive it
Nick
<<< Nick Johannessen | nick@sn.no | nickj on IRC >>>
<<< Jaguar XJ6 4.2 '70 MOD & '82 Auto >>>
The JagWeb http://www.sn.no/~nick/jaguar.html <<<
This mail was intentionally written to bait Jim Isbell <
From: Jan-Ivar =?iso-8859-1?Q?S=F8rensen?= jan-ivar.sorensen@kf.kommorg.no
Date: Mon, 30 Sep 1996 21:40:25 +0200
Subject: Re: 1987 XJ6 III brake light problem
At 09:52 30.09.96 PDT, you wrote:
Hello everyone,
I suppose you mean the brake-warning light INSIDE the car. There should be a
“brake-circuit-switch” which triggers this. Look in the engine compartment
and follov the brake-pipes from the master-cylinder and you should find the
switch where the brake-pipes are “split” (there would also be two cables
coming down to this “switch”. On some models it can be reset by pressing a
metal-pin located in the bottom of the switch from one side to another. If
you are not familiar with this “brake-circuit-switc” I’ll recomend you to
visit your local garage, because this light should NOT turn itself on unless
there are someting wrong with the brakes.
Date: Mon, 30 Sep 1996 14:17:52 -0400
Subject: Car Storage - Carcoon
So far the product is suitable for indoor storage only and it appears to do a
good job. A recent Carcoon advert indicates that they are working on an
outdoor version.
Date: Mon, 30 Sep 1996 13:24:22 -0700 (PDT)
Oops - sorry Nick! Tez and I are both terrible examples of people who have
no respect for intelectual property, I guess! Note, though, that mine was
“the beast”, not “The Beast ™”, and possibly, I used a different font. In
any case, I’ll have my lawyer contact your laywer so that we can work this
out. I don’t know how to deal with the various international borders,
however. Maybe Tez would like to share legal expenses! The real problem here
is the need for a publicaly acceptable generic name for when it’s bad, vs.
when it runs well. Usually, it’s just “the Jag”, or “the black Jag” (as
opposed to my 'E, which is white). In the states, at least, this could
really get me in trouble! Maybe the more politically correct model
designations would be better…
The last thing I want to do here is restart the naming thread, sorry I said
anything!
Hunt
| rack for close inspection. Will survey what it needs and go from there.Woah there! There can be only one beast, and it is mine.
have to find another name for it :-pThe Real Beast ™ is my series 1, manual overdrive, no
hung stainless system.Now, my series 3 is a hairdressers car in comparison. So
my wife gets to drive itNick
<<< Jaguar XJ6 4.2 '70 MOD & '82 Auto >>>The JagWeb http://www.sn.no/~nick/jaguar.html <<<
Date: Mon, 30 Sep 1996 21:44:16 +0100 (MET)
swap name
what about,
[suggestions deleted]
Jeffrey,
As Kirbert pointed out we need something informative and describing,
that’s why I settled on his suggestion “The Jaguar/Daimler used parts
exchange”. This name also ensures the most correct indexing in all the
different search engines on the Web.
To those of you who haven’t seen it yet, you can find it at:
You can use this service to sell, buy or trade SS, Jaguar and Daimler
cars and parts. The service is free and open for all. No commercial
advertising, please.
Gunnar
Gunnar Helliesen | Bergen IT Consult AS | NetBSD/VAX on a uVAX II
Systems Consultant | Bergen, Norway | '86 Jaguar XJ6 4.2 Sovereign
gunnar@bitcon.no | http://www.bitcon.no/ | Vicki who? What .sig virus?
Date: Mon, 30 Sep 96 13:58:07 PDT
Subject: aluminum polish
The very thought of bringing up the “A” word again has me in a tizzie, but
I got a question. What can I use to clean/polish aluminum? I tried chrome
polish, but it laughed at me.
I’m talking about the aluminum ribs on top of the 4.2 tappet covers.
The aluminum under the hood is the last skuzzie looking thing there, but I’m
stumped as to how to get it clean looking.
LLoyd
Date: Mon, 30 Sep 1996 17:10:05 -0400 (EDT)
George: Two things, one look for loose wire on top of M/C reservoir,
happens all the time, wire breaks and you never see it. 2 Make sure the
handbrake is all the way down, a slight movement up will sometimes cause
the light to come on.
Chad Bolles Jaguar South 306 Valcour Rd Columbia SC 29212 USA 803 798 3044On
Mon, 30 Sep 1996, george mykulowycz wrote:
Hello everyone,
George Mykulowycz
87 XJ6 Vanden Plas
77 XJ6C
69 XKE Roadster
Date: Mon, 30 Sep 1996 17:20:44 -0400 (EDT)
snip
Now, let’s hear it for manly Jaguars!
John
Date: 30 Sep 96 17:20:21 EDT
In answer to Lloyd’s quest:
The best polish I have ever used is a product called Autosol. It is
made in Germany but is available in England and the U.S. It is the
only product I use on aluminum. Discovered it thru a Brit friend whill
polishing motorcycles.
Robert Woodling
'84 XJ-S
Date: Mon, 30 Sep 1996 16:24:55 -0500
Subject: Sir William, noisy AC.
The voice interview I mentioned on the pronounciation of Jaguar was an
interview with Sir William. I consider him the authority on the subject and
he said Jag-u-were.
I have a question about noise from freon flow in an AC system. I just got
my XJ6 back and I can hear the freon flow through the system. I didnt used
to be able to. I had this happen on a Ford Escort once after an AC repair.
Never knew why.
Is this curable? The AC works perfectly, its just that you can hear the
freon “sing” as it goes through the system. Its most noticable after you
shut the car off and the freon goes toward equilibrium.
Jim
“Better an outlaw than not free.”
Nance O’Neil
Date: Mon, 30 Sep 1996 15:30:36 -0700
Subject: Re: aluminum polish
To: Jag Lovers jag-lovers@sn.no
Date: Monday, September 30, 1996 1:58 PMThe very thought of bringing up the “A” word again has me in a tizzie,
but
I’m
stumped as to how to get it clean looking.LLoyd
I use Mother’s Mag Wheel and Aluminum polish. It works IMHO better than
simichrome polish. Put a little on a piece of terry cloth and rub the Al
until it turns black. Move to a clean piece of the cloth and buff off the
black to reveal nice “mirror finish” clean Al. Use a buffing wheel for
faster shining. Lee
End of jag-lovers-digest V2 #392
Return-Path: @owner-jag-lovers-di1
Received: (from majordom@localhost) by ekeberg.sn.no (8.7.5/8.7.3/on4)
id for jag-lovers-digest-out; Tue, 1 Oct 1996 15:55:18 +0200 (MET DST)
Date: Tue, 1 Oct 1996 15:55:18 +0200 (MET DST)
Message-Id: 199610011355.PAA29429@ekeberg.sn.no
X-Authentication-Warning: ekeberg.sn.no: majordom set sender to owner-jag-lovers-digest using -f
To: jag-lovers-digest@sn.no
Subject: jag-lovers-digest V2 #393
Reply-To: jag-lovers@sn.no
Errors-To: @owner-jag-lovers-di1
Precedence: bulk
X-Newsgroups: mail.jag-lovers-digest
jag-lovers-digest Tuesday, 1 October 1996 Volume 02 : Number 393
Re: aluminum polish
XJ40 vs. Series III
XJ40: NO ABS LIGHT
RE: aluminum polish
want to join
Re: nice new jag - need answers
Re: The Beast
XJ6 III fuel filter - effect on idle
Re: XJ40: NO ABS LIGHT
XJ6 III lazy power steering
The big road trip
re: The big road trip
new member
SIII XJ6 Noises
RE: Aluminum Polish
Re: aluminum polish
1994 Vanden Plas
Date: Mon, 30 Sep 1996 16:31:27 +0700
LLoyd,
Tried Mag Wheel polish? It’s made for aluminum
(alumina/aluminium/aluma/…) and shined my cam covers very nicely.
Greg
G. W. Price & Company, Ltd
Santa Fe, New Mexico
Consultants in research, information management
and program evaluation
Probabilistic Record Linkage Services
Date: Mon, 30 Sep 96 16:01:44 PDT
Subject: XJ40 vs. Series III
The debate goes on:
I like the looks of my
XJ6C, but I’d rather DRIVE the XJ40. It’s the only car that’s made me
think of selling the XJ6C in spite of its beautiful looks, engine, and
ride. It’s primitive by comparison - only its looks have saved it so
far…
The XJ40 is the ugliest Jag…
I’ve owned a series II (not III), and I currently drive a `91 XJ40. I can
tell you both of the above statements have merits to them. What we
really want is a series III body style with XJ40 reliability and advancements.
Indeed, the series III is the most beautiful car in the world, but
it’s not all that durable compared to other cars. Especially when it’s
done over 120K miles, the car virtually needs to be restored. You need
a new engine, new transmission, new paint, new interior, new wood,
no bushings, new steering rack, rear suspension work, some rust removal,
A/C work, electrics repair, and perhaps a new gas tank or two. The total cost
can be daunting, and you need to go through a lot of hassles to get
everything done. Once you’re done, if you ever decide to part with your
Jag, you’ll never get your investments back.
Alternatively, a 90 or later XJ40 with low mileage can be readily picked up at Honda prices. These cars are ready to drive; you can use them everyday. The maintenance is simpler, maintenance cost is lower, and you get to experience a car with
90’s advancements.
Trade-offs? Mostly just the styling, and more cramped interior space.
It’s still a Jaguar, doesn’t feel Japanese or German. If you get a Vanden
Plas, I’d say the interior is even nicer than a series III.
Some other thoughts: If you really like your old series III, keep it
as a second car. Drive it on weekends. Alright, if you simply don’t
like the XJ40, I would try to find another series III with lower
mileage. They can be found at good prices if you’re patient.
Roger Peng (408)765-7863
Intel Corporation
Design Technology, Physical CAD
Date: Mon, 30 Sep 1996 16:03:49 -0700
Subject: XJ40: NO ABS LIGHT
Hi all,
Noticed something on my 1989 XJ40 which may actually be a blessing
My ANTI-LOCK FAILURE! lamp has NEVER lighten up. I checked some wiring,
particulary under the dash, and can’t see any visble wire tampering (pulled
apart the harness, and it didn’t light then either!). Some want to disable
this lamp, I guess the PO found out how to! Any suggestions why the lamp
isn’t working? Any idea what to check?
Never noticed this until others complained about the faulty relay in
the boot making “FAILURE” light up.
Thanks a lot for any suggestions!
cobac@ix.netcom.com
Date: Mon, 30 Sep 1996 16:08:52 -0700
Subject: RE: aluminum polish
I used 000 steel wool to clean the aluminum induction manifolds on my
XJ-S with very good results.
Aaron
'85 XJ-S
Sent: Monday, September 30, 1996 1:58 PM
To: Jag Lovers
Subject: aluminum polishThe very thought of bringing up the “A” word again has me in a
tizzie, but
chrome
but I’m
Date: Mon, 30 Sep 1996 20:43:28 -0700
Subject: want to join
Hi:
I would like to get onto your Jag lovers E-Mail list.
We are Bill and Nona Schorse and we own a 1955 XK140
special equipment roadster. We have had this car for
33 years. I do all of the servicing and most of the
repair work. Last winter I rebuilt the engine and
transmission. I was in need of fewer band aids on
this engine change than doing the same work on an
E type. We belong to the Nipissing region of HASC
(Historical Automobile Society of Canada). My interest
is in the Mark 7, XK120, 140, 150. I understand that the
1955 XK 140 Special edition roadster is fairly rare.
Does anyone out there have one? Besides our interest in
the Jag we run our own business which is building and
repairing canoes and selling supplies. Look us up at
www.trillium.net/canoe. Please tell us how to join up
so we can exchange ideas etc. The Jag Lovers and the
Jag Lovers Digest look interesting. What is the difference
between the 2 and what is the subscription charge? Hope to hear
from you soon.
Bill & Nona
canoe@onlink.net
Date: Mon, 30 Sep 1996 21:26:12 -0500
Subject: Re: nice new jag - need answers
Think I can answer your first question. Try a cooling system pressure
tester. A good local shop should have one. Pressurize the system up to the
rated pressure of the cooling system & wait. If you have a leak, the
pressure gauge will register it. If it goes down, you have a leak somewere
in the cooling system! At this point you look for wet, seeping areas.
I don’t know much about V-12s, so I’ll leave them to the experts.
Cleo
52 XK120
56 XK140
62 E-Type
65 3.4S
was destroyed. One owner, all receipts, flawless, only 35K miles.Two questions before signing the cheque though:
mileage. What’s the best way to figure it out???The temperature guage never rose above mid point (N) despite repeated
subdued manner, the temp.guage dropped a little bit. Is this normal or
should I be concerned???Please respond quick before I buy it anyway.
Date: Mon, 30 Sep 96 22:43:52 EDT
From: ** SHANE MANTOSZKO ** IBMA INVENTORY ANALYST **
*** Resending note of 10/01/96 08:26
*** SYDVM1(SHANEM) PH. (02) 354-4918 CUMBERLAND FOREST FE21
*** INTERNET - SHANEM@VNET.IBM.COM *** IBMMAIL - AUIBMSPM ****
brighter.
lights.
Barrie Dawson
Barrie, if what you say above is true, can you help me out with my
current problem. I have a mitsubishi 4 wheel drive, and am having
electrical problems and idling problems. It is idling very low, and
the voltage gauge is slowly dropping down whilst at idle. Revving the
engine starts to make it climb again, and at the same time makes the
headlights get brighter. Both my mechanic and auto electrician say that
the alternator/regulator are fine. I still have doubts.
Is it just the fact that the car is idling at around 400 rpm as opposed
to its usual 800 rpm that may be causing the problem ? Does the
alternator need enough revs to maintain the voltage level ? (If so,
then my problem is probably the computer or the injectors are probably
dirty…car has been tuned up, so plugs/fuel etc is not the problem…)
Are there any other things that may be causing this charging problem ?
Date: Mon, 30 Sep 1996 23:58:38 -0400 (EDT)
Hello everyone,
On the way to work today my wife said that the red brake light (idiot light) came on while she was driving. … Last week I installed new front brake pads and at that time the brake fluid was topped up. There is no evidence of any leaks on my garage floor. Any help would be appriciated. Thanks. George Mykulowycz There are two things that will turn on the light. There a float switch on the master reservoir that trips when the fluid gets low, and a switch on the parking brake handle. Normally it is either low fluid or the parking brake being set. But there is a third fairly common thing, especially considering the resent work. The float switch is in the reservoir cap. Sometimes when you mess with the cap, one of the wires will come adrift, but stay inside the rubber boot so that you don’t notice it. When this happens, the loose wire will eventually migrate over to the other wire, shorting out and turning the light on. Randy K. Wilson randy@taylor.infi.net From: Gunnar Helliesen gunnar@bitcon.no Date: Tue, 1 Oct 1996 05:32:52 +0100 (MET) Subject: Re: The Beast OK, so I’m not Jim but I’ll bite anyway. Nick wrote:
Been there, driven that, got the T-shirt and can vouch for Nick, he’s
telling the truth.
Gunnar
Date: Tue, 1 Oct 1996 15:03:48 +1000
Subject: XJ6 III fuel filter - effect on idle
I’ve been trying for a while to eliminate the cause of rough idling
when my XJ6 III is warm. I’ve always suspected a vacuum leak as the
cause, but have never been able to find it.
This past weekend I finally got around to replacing the fuel filter,
last replaced by the PO (or maybe the PPO…). As I removed the
filter, the horribly cloudy looking fuel that drained back out of it
from the inlet side made it clear that it was way overdue for
replacement.
The surprise: warm idle is now consistently smooth!
I’m delighted, but also puzzled. I would have expected a nearly blocked
filter to affect high power operation, but not idle.
Cheers,
Tim Axelrod
Mt. Stromlo Observatory
Canberra, Australia
Date: Mon, 30 Sep 1996 22:07:40 -0700
Subject: Re: XJ40: NO ABS LIGHT
blessing My ANTI-LOCK FAILURE! lamp has NEVER lighten up.
Count your lucky stars!!! Mine never goes out. Wanna trade?
don farr
Paradise Valley, AZ
(602) 948-7499 - fax
91 Sovereign
d.farr@phx.cox.com - e-mail
http://people.phx.cox.com/dfarr/dfarr.htm - Don’s Homepage
http://people.phx.cox.com/dfarr/jetta1.htm - Jetta Notebook Computers
http://people.phx.cox.com/dfarr/march10.htm - Wireless products
http://people.phx.cox.com/dfarr/ncs1.htm - National Consulting Services
Date: Tue, 1 Oct 1996 15:10:01 +1000
Subject: XJ6 III lazy power steering
The power steering on my 1981 XJ6 III seems inadequate. Whenever it
is called on to work hard, the steering will suddenly revert to unassisted
operation. An example is when entering a roundabout, which requires
fairly rapid movement from straight to left and then to right. If done
at any speed, the steering will feel unassisted about the time the wheel
starts moving right.
The PO fitted wider wheels and tires than standard, so this doubtless
makes the problem worse, but I’m still convinced the power steering
itself has a problem. The fluid level is correct, there are no leaks,
and no bad noises.
I’m suspecting the pump is due for an overhaul. Does anyone know how
likely this is, or how to check further?
Thanks,
Tim Axelrod
Canberra, Australia
From: “Peter Rebbechi (03) 9275 3374” <"REBBECHI PETER"@A1.MEOC02.SNO.mts.dec.com>
Date: Tue, 01 Oct 1996 05:18:00 +0000 (GMT)
Subject: The big road trip
Tomorrow morning, I and a few friends are to venture from
Victoria to Rural NSW for the Bathurst Car races. This is a
1000km event (the race) that is run at sprint speeds for 6
hours. The premier Event for Australia.
By comparison, I will be driving 1,700 km to get there and
back, at decidedly no sprint speeds. The only stop is for
fuel. Because of speed limits, speed will be restricted to
about 120 km/h, as the constabulary also know what happens
to people going to the car races, and use radar,
helicopters, planes etc to spoil our fun. But you never
know!.
I expect the 850km trip to be done in around 8 hrs.
Is anyone else going? If so, call me on my mobile on 018 17
1986.
We will be the unkempt people on ‘hell corner’.
To those who may get this event on TV, we will hold up our
JAG signs.
See ya.
Date: Tue, 1 Oct 96 16:41:59 +60000
Subject: re: The big road trip
Hey Peter,
I know you’re not going at sprint speeds but the race isn’t till Sunday. What
will you do, or for the
benefit of people who haven’t been there, what can you do in Bathurst for
three days?
What was the year the XJS won (I seem to remember it did once).
Have fun and watch out for the pigs in space (police helicopters).
Peter Brown
| a
| to
| know!.
| 17
| 1986.
| JAG signs.
| See ya.
Date: Tue, 1 Oct 1996 20:36:14 +0930
Subject: new member
Hi All,
I am a new member to your group and I have the Jag bug having a
Series 2 since 1984 then a XJS since 1988 and lastly a early model S1, both
S1 and S2 are 4.2 litre cars, due to work commitments I do not get to drive
the as often as I would like as to me they are a real drivers car, I still
get a buzz driving them especially on our freeways.
I look forward to being part of the Jag-lovers group and hope that I can
learn from you and also help others in the group.
John Geovanovich.
Date: 1 Oct 1996 08:00:27 -0400
Subject: SIII XJ6 Noises
I have a 1985 SIII XJ6 VDP…
On colder mornings (50 degrees) after a day or two of sitting, my Jag makes a
strange “clicking” noise upon startup.
It grows progressively weaker as the car warms up, but is still very slightly
discernable even after 5 minutes of running or so…
It is best described as a light clicking or tapping noise, and is noticeable
only from the passenger compartment, with the doors shut. The noise from
opening the engine bay drowns out any chance of hearing the noise from outside
the car.
Seems to be coming from the front of the car, but I could be mistaken.
It does not seem to be related to engine speed, nor position of the
transmission (park is the same as drive). It is again, most discernable when
the car is cold, with a “tic-tic-tic-tic” sound, maybe 150-200 tics per
minute.
It only occurs when the car is running. If ignition is on (key turned) but the
engine is off, it does not occur (seeming to rule out an electric fuel pump,
which is the closest “normal” car noise to this sound that I’ve heard).
I have run out of ideas, and I’m wondering:
- What is it?
- Is this a common, Jag specific problem?
- Is it anything to worry about?
- Has it happened to anyone else?
- What’s the fix?
Any help would be appreciated. If possible, and email response would be
preferred, as I sometimes have precious little time to read the posts. Thanks.
Dan_Golder@sdm.buffalo.edu
Date: Tue, 1 Oct 1996 07:46:02 -0500
Subject: RE: Aluminum Polish
Greetings:
I have been using “Mother’s” brand aluminum polish on my Jag. It works =
great!! Be prepared to use a little elbow grease but the results are =
worth it. I bought it for $3.00US at the local TRAK Auto (a large chain =
of car parts stores).
Jack Fulford
67 E-Type
Dallas, TX
Date: Tue, 1 Oct 1996 08:51:50 -0400 (EDT)
LLoyd: Try a product called Never Dull,(I might have spelled it wrong),I
think I found it a a Pep Boys or Autozone, or sum such store like that.
If you can not find it drop by you local fire station as them what they
use to clean and polish their A with.
803 798 4512 FAXOn
From: Michael Powers/TEIR/Thomson Michael_Powers@teir.com
Date: 1 Oct 96 9:28:01
I, too, have seen my VCM ABS light up on occasion. Could I get more details
about this relay? Where in the boot is it located?
Thanks,
Mike
cobac @ ix.netcom.com
09/30/96 04:03 PM
To: jag-lovers @ sn.no @ Internet
cc:
Hi all,
cobac@ix.netcom.com
Date: Tue, 1 Oct 1996 09:34:00, -0500
Subject: 1994 Vanden Plas
I need instructions on replacing a spent passenger side air bag. It
is not electricaly controled. Is there
a safty? I have the new one in hand but will not try this with out
some instruction. Thanks Paul
End of jag-lovers-digest V2 #393
id for jag-lovers-digest-out; Tue, 1 Oct 1996 18:21:55 +0200 (MET DST)
Date: Tue, 1 Oct 1996 18:21:55 +0200 (MET DST)
Message-Id: 199610011621.SAA05584@ekeberg.sn.no
Subject: jag-lovers-digest V2 #394
Precedence: bulk
jag-lovers-digest Tuesday, 1 October 1996 Volume 02 : Number 394
Jaguar Suppliers (posted monthly)
Re: Alternators and Dynamos
RE: Aluminum Polish
Re: aluminum polish
Local Shops and Dealers
V12 stumbling - answer
I’m new
Date: Tue, 1 Oct 1996 09:00:02 -0500 (CDT)
Subject: Jaguar Suppliers (posted monthly)
Suppliers, North America (mostly).
[This list is automatically sent out on the first of each month.]
Updates:
none
(Corrections, etc, to: jjoy@risc.sps.mot.com)
The majority of this list has come from Rob Reilly reilly@admail.fnal.gov
SUPPLIERS OF JAGUAR PARTS AND SERVICES Rev. 8-1-96
A D Motor Rebuilding, NY 1-516-395-5101
Lucas, Smith’s motors rebuilt
Al Hogan’s Autojumble Mansfield, Ohio 1-419-524-1088
NOS parts supplier
Specializes in buying out old dealer stock. Owner (Al) is knowledgeable
about british car parts.
- -Steve DuChene s0017210@cc.ysu.edu
Dick Ames, 608 Ft. Williams Pkwy, Alexandria, VA 22304 1-703-370-3097
stainless exhaust systems
Best price on stainless steel exhaust systems. I’ve misplaced the
address but can probably look it up if pressed.
- -PKR@SLACVM.SLAC.Stanford.EDU (Patrick Krejcik)
Ancient Car Parts, 64 N Main, Lyndonville, NY 14098 1-716-765-2894
rust repair panels for XJ
Apple Hydraulics, 715 Route 25A, Miller Place, NY 11764 1-800-882-7753
rebuilds Armstrong, Girling shocks, SU carbs 1-516-744-9627
Asom Electric, 1204 McClellan Dr., Los Angeles, CA 90025 1-310-820-3720
email: asomelect@aol.com 1-800-424-2766
Electrical rebuilding shop that deals mostly in Lucas and Bosch and
rebuild starters, alternators, generators, fuel pumps, voltage regulators,
wiper and window motors. They have a large supply of Lucas parts,
including discontinued items. In business for 36 years, have daily UPS,
and accept credit cards.
Atlantic Enterprises, Route 4, Box 394-B, Loris, SC 29569 1-803-756-7565
steering racks, seal kits, polyurethane rack mounts
Auto Interiors of Europe, 1790 E McFadden, Unit 107 1-800-533-2886
interiors Santa Ana, CA 92705
(not sure which addr. is correct)
3023 S. Orange Ave.
Santa Ana, CA 92707
(714) 751-9046
Nice stuff if I remember correctly. Not cheap but nothing for these
beasts is.
- s912!rick@bnf.com (Rick Ezneker)
Kent Bain, 1785 Barnum Ave, Stratford, CT 06497 1-203-377-6745
custom interiors, seat rebuilding and repadding
G.W.Bartlett, Muncie, Ind. 1-800-338-8034
interior and trim parts
Sells original Jaguar Interior kits and components. All to exact Jaguar
specifications. As per original spec. Quite costly but isn’t quality
always a bit more? (eg. Interior kit for Jag 3.8s is about $4200, retail.)
- zrol01@trc.amoco.com (Richard O. Lindsay)
Basset’s, Wyoming, R.I. 1-401-539-3010
restoration parts
Borla Industries, Oxnard, Calif. 1-805-983-7300
stainless exhaust
British Auto Center, 2938 SW Avalon Way, Seattle, WA 98126 206-935-0873
Lots of late model stuff, new and used. Very knowledgeable. Can
sometimes be grumpy. – Greg Meboe (meboe@wsunix.wsu.edu)
British Auto USA, 92 Londonderry Trnpk, 1-603-622-1050
British Auto USA Interiors Manchester, NH 03104 1-800-4-JAGPTS
interior and trim parts 1-800-452-4787
Exc. inventory of interiors and body parts. Limited inventory of
mechanical parts but I always check them out because they’re cheaper!
(I avoid Bartlets for Jag interiors)
British Car Parts, CA 1-818-788-7636
new and used parts
British Marque Auto PO Box 344, Bainbridge, PA 17502 1-717-426-2675
interiors
British Motor Service, 521 W. Katella, Orange, CA 92667 1-714-997-3800
Moss distributor, used XK parts
British Parts Northwest, 4105 SE Lafayette Hwy, 1-503-864-2001
new parts for late models, no sheet metal Dayton, OR 97114
British Restoration Parts, Kansas City, Mo. 1-800-821-3767
new restoration parts
British Spares, 46 Florence, Springfield, MA 01105 1-413-736-0463
fabricates panels for XK, Marks, E
British Vintages, 645-D Tank Farm Rd, 1-800-350-JAGS
San Luis Obispo, CA 93401 1-805-541-5986
Have their catalog but so far never used them.
British Wire Wheel, 1650 Mansfield St, 1-408-479-4495
Santa Cruz, CA 95062
Dayton and Dunlop wire wheels, tires
THE place to go for correct reconditioning of your JagWires. Also to
buy THE correct tires.
Bob Brosen, 7804 Billington Court, Oxen Hill, MD 20744 1-301-248-6327
new repro parts for pre-war, Mark IV, V
Classic Parts & Panels, Ltd. 0296 658938
Fleet Marston Farm, Bicester Rd., Nr Waddesdon
Aylesbury, Bucks, UK HD 18 ODZ XK panels
Classic Restoration Parts, Bellflower, Ca. 1-213-804-2756
XK grilles, gas tanks
Classic Tube 1-716-759-1800
A Division of Classic & Performance Specialists
80 Rotech Drive
Lancaster, NY 14086 USA
They supply steel and stainless steel pre-bent brake and fuel lines for
various makes of cars. I got half the brake lines and clutch lines
from them in stainless, and being the prudish restoration junkie I am,
I was concerned that the reproduction in stainless would not be very
“original”. However, I’m happy to say the final product is almost
identical to the original steel lines, most judges will not notice the
difference. – Mark Roberts (markdr@bnr.ca)
Concourse West, 644 Terminal Way, Costa Mesa CA 92627 714-642-9807
fax 714-645-8388
Have rebuilt diffs.
Cordell R. Newby, 1410 N. Aurora, East Wenatchee, WA 98801 509-884-6823
Specializes in Mark V parts. New and used.
Coshman Ent, PO Box 2685-J, Orcutt, CA 93455 1-805-937-7456
Whitworth tools, taps & dies, gauges, fasteners
Coventry Engineering, 9500 SW Martha St, Tigard, OR 97224 1-503-620-9482
wiring harnesses
Coventry S Ltd, 6406 85th Place, New Carrolton, MD 20784 1-800-537-4146
Joe Curto, 230-22 58th Ave. Bayside, NY 11364 1-718-465-4829
S.U. parts
Wes Czech, HCR 9550, Lucerne Valley, CA 92356 1-619-248-9603
XK parts
Stanley Daniel, 124 Parkview Rd. Cheltenham, PA 19012 1-215-782-1248
used Mark 7-9 parts from 30 cars, call after 9PM EST
Doctor Jaguar, 644 W 17th St, Costa Mesa, CA 92627 1-714-646-2816
parts, engines, trans, susp. parts
East Coast Jag Parts DE 1-302-731-7200
EJAG NEWS, Box J, Carlisle, Mass 01741 magazine, a few accessories
Engel Imports, Kalamazoo, Mich. 1-800-253-4080
new car dealer, will UPS, cheaper than other dealers
European Auto Specialists, 1-313-355-2730
OEM parts for late models
John Farrel, 4315 Murray St., Flushing, NY 11355 1-718-762-9071
NOS XK parts
Foreign Car Center, 1610 S Main, Milpitas, CA 95035 1-408-262-0325
used parts recycler
Grand Turisimo Jaguar 1-216-259-5656
4285 Main Street fax: 1-216-259-5588
Perry Village, OH 44081
engine rebuilder, parts
Specializing in high performance parts and services. They list a
‘level 5’ Jaguar V12 with all of the whistles and bells like porting,
balancing, etc. with 6, count them, 6 two bbl Weber carbs mounted
vertically across the top of the V12! This engine sells for about
$13,500. - zrol01@trc.amoco.com (Richard O. Lindsay)
Gunson Ltd., Pudding Mill Lane, London E15 2PJ
UK source for ColourTune
Tony Handler’s Foreign Parts Connection 1-213-473-7773
2028 Cotner Ave, Westwood, CA 90025
H.D. Rogers & Sons 1-318-742-3651
3418 Barksdale Blvd. fax: 1-318-742-5044
Bossier City, LA 71112
email: hdrsons@iamerican.net
Family-owned business supplying used, NOS, discontinued parts as well as
enhancements for newer cars. For example, they offer aftermarket a/c
hoses for XJ series and a less expensive amplifier. They try to give
special rates to internet users. They also have contracts worldwide
and will try to locate hard to find items, and offer special prices for
prepaid orders from overseas.
Harry CA 1-408-262-0235
used parts
H.P. Co., 1079 Colonial Club Dr, Harahan, LA 70123 1-504-737-4691
burled walnut dashboards
I-35 Imports Oklahoma 1-405-799-2886
used parts, 80 and older
Intermarque Auto Parts Houston 1-800-666-8700
parts and sheet metal
International Spare Parts 1-800-243-0073
J.K.Restorations, 12 Jackson, Oswego, IL 1-708-554-2120
complete restorations, specialist for XK and E, some used parts
Jag Atlanta, 3437 Sexton Woods Dr, Chamblee, GA 30341 1-800-533-8973
new, used parts for E and XJ 1-404-455-0175
Jaggist (Alan Trickel) 1065 Hillview, Ashland, OR 97520 1-503-535-8486
used XK parts
Jaguar Cars Inc, Public Relations, Mahwah NJ 1-201-818-9770
For a fee will authenticate your VIDNs.
Jaguar Denver 1-800-426-4515
Lucas, Girling, Jag parts
Jaguar Heaven, 1433 Tillie Lewis Dr, Stockton, CA 95206-1130
info: 1-209-942-4524, orders: 1-800-969-4524, FAX: 1-209-942-3670
used parts recycler, all models
Jaguar Interiors of England, PO Box 47, Muncie, IN 47308 1-317-289-9901
carpeting and upholstery
Jaguar Motor Works, 3701 Longview Dr, Atlanta, GA 30341 1-800-331-2193
used XJ parts recycler, rebuilt parts Local 404-451-3839
FAX-404-451-7561
Jaguar of North America, Leonia, NJ 1-201-592-5200
factory American distributor
Jaguar South Greenville, SC 1-803-244-1555, 1-803-292-3934
used parts recycler
Jaguar parts SC 1-803-754-5363
Jaguar Warehouse, 6010 Mardale Lane, Burke, VA 22015 1-703-451-4071
NOS parts
Jaguar Warehouse, 5727 Walcott Ave, Fairfax, VA 22030 1-703-968-3983
XK parts
J C Whitney, Chicago, IL 312-431-6102
Also known as Warshawsky/Whitney. Sells car parts cheap for most cars
including LBCs. Massive buying power. Brainless order-takers. You
can call in the middle of the night for good long-distance rates. They
will not tell you brand names. All the swaybars are ADDCO. See also
ADDCO and Werace. - ?
J.C. Whitney offers a few items that are of interest. Things like generic
weatherstrip by the foot, etc. The do offer after market A/C units and
high output quartz halogen 7 inch headlights (110 watts!!!). The ad
carries the label ‘Not legal for street use.’ They look really cool.
John’s Cars, 800 Jaguar Lane, Dallas, TX 75226 1-214-426-4100
fax: 1-214-426-3116
V-8 conversions, other repro parts, claims improvements over stock
Just Jags, 407 Industrial Dr, Carmel, IN 46032 1-317-844-8823
new, used parts, service, restorations
Just Jags, 8720 Big Bend at Elm, St.Louis, MO 63119 1-314-968-2450
service, parts, restoration shop
Keller Associates, PO Box 2833, Saratoga, CA 95070 1-408-370-3705
burl walnut dashboards
Lister of North Am, 1912 Granvill Av, Muncie, IN 47308 1-800-338-8034
high performance accessories
Lovello, Mark SC 1-803-244-1555
used parts
Moss Motors, PO Box MG, 7200 Hollister Av, Goleta, CA 93116 800-235-6954
new and repro parts for XK’s
Moss Motors, Santa Barbara, California 1-805-963-0741
new car dealer
Cordell Newby, 1625 N Western, East Wenatchee, WA 98801 1-509-662-7748
new, used, repro parts for pre-war, Mark IV, V
added: Jul. 29, 1994
Nisonger Instrument Sales & Service 1-914-381-1952
570 Mamaroneck Ave. fax: 1-914-381-1953
Mamaroneck, NY 10543
Repairs capillary based guages.
“I had them repair my water temp gauge 2 months ago. Charge was $100 including
shipping, turnaround time was 2 weeks, and they take plastic.” Rob Reilly
Northwest Modern Classics, 121 Duryea, Raymond, WA 98577
interiors, carpets, upholstery, tops 1-800-854-1751,1-206-942-5532
Northwest Transmission Parts, Ohio 1-513-442-2811 or 1-800-327-1955
auto trans rebuilding kits, torque convertors
Peninsula Imports, 3749 Harlem Rd, Buffalo, NY 14215 1-800-999-1209
XJ, E body and rust repair panels 1-716-833-3000
Fred Petroske, RR1, Box 112, Chaumont, NY 13622 1-315-649-2861
Paul K. Phillips 1-305-846-7976
1124 N. W. 134 Ave. fax: 1-305-846-9450
Sunrise, FL 33323
Specializes in the XJ Coupe market and runs an XJC register.
“I have dealt with him once on an exhaust system (via a referral from
SICP) and got good service. He does require cash C.O.D. (no credit cards)
which is a bit of a bother.” - gladish@suite.com (Brian Gladish)
Phil’s, Inc. Ashland Ave, Evanston, IL 1-708-869-2434
PII Distributing, PO Box 27358, Houston, TX 77227-7358 1-800-231-5836
genuine Jaguar parts, sheet metal 1-713-975-6272
Chuck Pilate, 24996 W Magdalena Dr, Mt Clemens, MI 48045
XK, E parts 1-313-791-0429
Rich’s Import Auto Parts & Serv, 730 N Glebe Rd, Arlington, VA 22203
parts for E, XJ and 62 on sedans 1-800-336-6603, 1-703-522-0440
Rhino Auto Parts, Hanover, MN 1-612-498-8711
used and NOS parts 50’s to 70’s
Rhode Island Wiring Service, Box 3737H, Peace Dale, RI 02883
wiring harnesses 1-401-789-1955
Martin Robey Panels, Pool Rd, Camp Hill 011-44-203-386-903
Industrial Estate, Nuneaton, Warks CV10 9AE England
Rodney, 2035 Cornell St, Sarasota, FL 33577 1-813-955-5960
used parts recycler
SCJ, 3 Elizabeth Ave, Burlington, MA 01803
NOS parts, pre-war to 61
Samplex, 30 Parkview Dr, Succasunna, NJ 07876 201-584-9370
US source for ColourTune
Special Interest Car Parts, 1340 Hartford Ave, Johnston, RI 02919
voice: 1-800-556-7496, 1-800-851-5600, 1-401-831-8850
fax: 1-800-672-SICP(1-800-672-7427), 1-401-831-7760
We have parts for your Jaguar, MG, Healey, TR. Good prices. Superb
catalog. Parts from XK120 through XJ40 including e-types. Will often
meet or beat prices from competitors.
S&S Specialties, 108 Sation St, Cumming, IA 50061 1-515-981-9148
NOS, rebuilt and used parts for XK, Mk and E, sheet metal parts
Stainless Steel Muffler Corp, 3032 Genesee St, Buffalo, NY 14225
stainless exhaust systems 1-716-893-2116
Terry’s Jaguar Parts, 117 E Smith St, Benton, IL 62812 1-800-851-9438
new and used parts for later models 1-618-439-4444
Bill Tracy, Sarasota, Florida 1-813-924-9523
Trans Ocean, Dept PDH, 390 Olive Tree Lane, Sierra Madre, CA 91024
Lucas parts jobber, '30 to '76 British cars
Welsh Jaguar Enterprises, Steubenville, Ohio 1-800-875-5247
new and repro parts for XK’s and newer 1-614-282-8649
fax: 1-614-282-1913
Catalogue available. (free)
The best prices for Jaguar parts that I have found.
Exc. inventory of parts, new and used. Can offer helpful technical advice.
Ed West, 1941H Jan Marie Place, Tustin, CA 92680 1-714-832-2688
new, used, repro parts for earlier Jags
Ed west has lots of intresting stuff at very resonable prices and lots
of advice. – m_skogs@ix.netcom.com (Matthew Skosberg)
White Post Restorations, White Post, VA 22663 1-703-837-1140
restorations, brake and clutch cylinders resleeved
XK’s Unlimited, 850 Fiero Lane, San Luis Obispo, CA 93401 1-805-544-7864
new and repro parts for XK’s 1-800-444-JAGS
In CA: 805-544-7864 FAX: 805-544-1664
catalog available. ($6.00, refundable first order)
“Parts & Service for all model Jaguars from 1948 on” XK’s Unlimited is
a good place to send Girling calipers for for piston bore sleeving. -?
XK’s Unlimited is good, but is a bit higher than Welch Jaguar. They
are also committed to “correct” parts. Additionally, you can call them
without a part number. Just be sure that they tell you what is
included in the replacement part. - zrol01@trc.amoco.com (Richard O.
Lindsay)
Good inventory and advice, but pricey. Nice catalogue. Has a
restoration shop sleeving brake cylinders in stainless.
XKSS Interiors, Thousand Oaks, CA 91359 1-800-922-XKSS, 1-805-482-4682
Vicarage Jaguar 1-305-444-8759
% Gables Cats fax: 1-305-443-6443
220 Granello Avenue
Coral Gables, FL 33146
vicarage@ix.netcom.com (alt. vicarage@paradise.net)
http://paradise.net/vicarage
Vicarage says: If one is in need of specialized or hard to find parts
we will have them. In addition we do offer the unique Vicarage
upgrades and enhancement products for all post war Jaguars.
Zimmer, Bob 2675 Stoney Brook Rd, Orchard Park, NY 14127 1-716-652-7909
XK parts
Date: Tue, 1 Oct 1996 09:45:11 -0500
Subject: Re: Alternators and Dynamos
I’m sure someone else can give a better explanation but just in case they don’t
I’ll give it a try.
No they are not the same thing.
Simple explanation - the alternator is the new technology which is more robust
and generates higher currents (35 amps at least with 50 or 55 not uncommon).
The good dynamo/generators peaked out at about 22 amps.
There are two major differences - which part spins and how the AC is converted
to DC.
A dynamo (AKA generator) has coils of wire (several sets of them I think, say
10 to 15) spinning inside fixed magnets (fixed to the dynamo housing). It uses
the comutator on the end of the spinning shaft to smooth what starts out as an
AC current from the coils. The comutator is the terminals for each end of the
10-15 coils of wire arranged in a cylinder around the spinning shaft. The two
terminals for each coil are on opposite sides of the comutator so that they
contact the two carbon “brushes” at the same time thereby completing a circuit
and allowing the transfer of the current from that coil. This is how the
comutator is used to convert the AC current being created in each coil, as it
spins inside the magnetic field, into a continuous DC output. There is a
regulator involved in the process also but one thing at a time.
The Alternator has the components reversed and spins the magnets inside (1 or 2
I think) coils fixed to the case of the alternator. It is so called because it
produces ALERNATING CURRENT (AC). This AC is converted to the required DC by
a diode rectifier which is usually built in to the alternator. There is also a
regulator involved in this situation which may or may not be incorporated into
the alternator.
Corrections/additions anyone?
Any Questions?
Robert Bradley
82 XJ6, 82 Daimler, 87 XJ-S
Date: Tue, 01 Oct 1996 10:24:25 -0600
At 07:46 AM 10/1/96 -0500, Jack Fulford wrote:
Greetings:
great!! Be prepared to use a little elbow grease but the results are worth
it. I bought it for $3.00US at the local TRAK Auto (a large chain of car
parts stores).Jack Fulford
67 E-Type
Dallas, TX
Yes TRAK does carry it. But if anyone has trouble finding Mothers Aluminum
Polish, let me know. I have both the small and large sizes…about $3 and $6
per can.
Best Regards,
Hal
Hal Rogers
H.D. Rogers & Sons
Import Auto Specialists
Bossier City LA 71112
(318) 742-3651 voice
(318) 742-5044 fax
Serving Auto Enthusiasts since 1959
Date: Tue, 1 Oct 1996 11:20:03 -0400
I like Flitz polish best.
Mark McChesney
Date: Tue, 01 Oct 1996 10:28:58 -0600
about this relay? Where in the boot is it located?Thanks,
Mike
The relay is greyish in color. Jag part number DBC4282. I sell them as
original for a little less than Jaguar pricing at $45.00 should anyone be
interested. I do not get a big margin on them because Hella the manufacturer
can only sell them through Jaguar at this time. So I buy them from England
as directly as possible.
Best Regards,
Hal
Hal Rogers
H.D. Rogers & Sons
(318) 742-5044 fax
Date: Tue, 1 Oct 1996 12:16:28 -0005
Subject: Local Shops and Dealers
So soon after the creation of the Jaguar/Daimler Parts site may not
be a good time to mention this, but I have another idea for a helpful
use of the WWW.
What I think would be helpful would be an online listing of the
various local shops that do Jaguar or Jaguar-related work –
including dealers. Basically, someone with a need to know could
access the site, select the country he’s interested in, then the
state, then the local area, and finally be given a list of the
various shops in that area. Optional: he might also be able to bring
up a collection of comments regarding a selected shop.
I consider this to be a separate idea from the suppliers list or
the list of sources in my XJ-S book. For the most part, I try to
list only sources of interest to XJ-S owners everywhere (mail-order
places, etc.), and avoid listing individual dealers or shops
generally of interest only to locals. Such a site could fill that
void.
Establishment of such a site requires somebody to set it up, but the
input should be easy: each of us can send info on the shops in our
area. Even info copied out of the phone book would suffice, if
nothing else is known. Comments could be added later, if someone has
a pleasant (or otherwise) experience with the shop.
There seem to be a lot of people who post questions to this group
trying to find a decent shop in their area. Also, those who travel
in their Jags might wanna check out the availability of repair sites
along their route – or, if they are connected via a laptop with
cellular modem, they could find the nearest site AFTER they break
down.
| - Palm’s Postulate
Date: Tue, 1 Oct 1996 12:14:13 -0400
Subject: V12 stumbling - answer
Last week I posted a message asking for advice concerning
intermittent loss of power and rough running (as if the engine was running
out of gas or loosing ignition). I received several helpful replies.
The correct answer appears to be one partially suggested by Kirby
Palm …i.e. partial blockage of the fuel pick-up filter inside the gas
tank. In the 74 V12 E-type (but not in the XJ-S wher the filter seems to be
right on the end/inside the fuel pick-up line) the fuel pick-up hose has a
1.5 inch by 0.5 inch tubular fine mesh filter which fits loosely over the
distal 1.25 inches of the fuel pick-up line (see diagram below). This
filter and the distal end of the fuel pick-up line both hang into a small
bowl made by the fuel tank drain plug (see diagram below).
In a perfect world of scrupulously clean gas pumps, this is
obviously a great way to get that last droplet of gas from the tank and
minimize the effects of surges during acceleration/decelaration/cornering.
Equally obvious, in the real world of not so careful gasoline
dealers content to pump the sludge from the bottom of their empty tanks and
sell it to you as “premium”, it’s a very quick way to fill the pick-up bowl
with detritus. This crap then gets sucked onto the filter and blocks it up
during constant high fuel flow rates (~3500 rpm x 1 hr) … causing fuel
starvation and the symptoms I noticed. When you switch the engine off for a
minute, the suction is released, the crap falls off, and the engine then
runs fine again until the cycle repeats itself …etc etc… until you burn
out the electric fuel pump … fortunately I have found the problem in time
(I hope).
Although my Jaguar service manual does not mention periodic
clean-out of the fuel drain plug/fuel pick-up resevoir, it is obvious from
the construction that this is a service/maintenance item (the filter is
loosely fitted over the fuel pick-up line and can be easily removed,
cleaned and replaced through the fuel drain plug apperture).
My recommendation - clean out the fuel tank drain-plug/fuel
resevoir once a year whether it needs it or not…but I’m probably
re-inventing the wheel here.
| | <================== Fuel pick-up pipe and
| | plastic mesh filter INSIDE
\\\| |:: |\\\\ <===== Fuel Tank base \\\\\\\\\ -
|\| |:: |\| OUTSIDE
|\| |:: |\| <===== screw-in fuel tank
|\| ----- |\| drain plug/fuel pick-up
|\| |\| resevoir
Peter
74 XKE-V12 Roadster
Date: 01 Oct 96 17:15:55 GMT
Subject: I’m new
I’ve recently subscribed to the list and have followed the discussions
with much interest. I don’t currently own a Jag, but am looking for a
series 3 XJ6 Sovereign. If anyone knows of an '85/86 for sale, in the
South of England, I’d be interested to hear.
Also, if anyones got any tips on what I should be looking out for, rust
spots, mechanical flaws etc, I’d appreciate any info, before I blow my
entire bank balance on repairs.
Look forward to hearing from you
Dieter Hachenberg
Hopefully soon - XJ6 S111
End of jag-lovers-digest V2 #394
X-UIDL: 117b88a6400122046852ca7525cef64f
id for jag-lovers-digest-out; Wed, 2 Oct 1996 04:38:20 +0200 (MET DST)
Date: Wed, 2 Oct 1996 04:38:20 +0200 (MET DST)
Message-Id: 199610020238.EAA21187@ekeberg.sn.no
Subject: jag-lovers-digest V2 #395
Precedence: bulk
Status: RO
X-Status:
jag-lovers-digest Wednesday, 2 October 1996 Volume 02 : Number 395
Valve cover polishing
XJ40 - Brake accumulator
Re: Local Shops and Dealers
Re: XJ40 vs. Series III
XJ40 - ABS CLUNK!
XK8 seen
Re: V12 stumbling - answer
Re: Valve cover polishing
Re: aluminum polish
Re[2]: Alternators and Dynamos
XJS V12 radiator flush
Re: aluminum polish
Power window conversion
Re: Replace the ECU as preventative maintenance?
Re: Ignition Amplifier
Re: aluminum polish
From: David J Shield David_J_Shield@ccm.fm.intel.com
Date: Tue, 01 Oct 96 09:39:00 PDT
Subject: Valve cover polishing
LLoyd,
Lee has it right - use Mothers Mag wheel polish. If you want to really
sharpen up those Al-You-Min-E-Um valve cover ribs, use the finest grade
emery paper with a very sturdy sanding block (like a block of wood),
finish up with the polish.
Having said this, what’s the best paint to re-paint the black parts of
those valve covers?
'84XJ6 VDP - The Mighty Jag
'70XKE 2+2 - Little Jag
Date: 1 Oct 96 14:37:09
Subject: XJ40 - Brake accumulator
After running several tests from Michael Neil’s excellent post on brake
troubleshooting,
I believe I need to replace the brake accumulator (this was due to the
intermittent “low brake
pressure” light on the VCM). Several replies that I received seemed to
indicate that there had been some good posts on how to do this.
So if anyone has previous posts on:
Where the accumulator is located
How to replace
What else is required
Please post’em!
Many thanks,
Mike
| mpowers@teir.com
| (703) 736-1832
| On my block, a lot of people walk their dogs and I always see them
| walking along with their little poop bags. This, to me, is the lowest
| activity in human life. Following a dog with a little scooper.
| Waiting for him to go so you can walk down the street with
| it in your bag. If aliens are watching this through telescopes,
| they’re going to think the dogs are the leaders of the planet.
| If you see two life forms, one of them’s making a poop, the
| other one’s carrying it for him, who would you assume is in charge?
| -Jerry Seinfeld
Date: Tue, 1 Oct 1996 14:53:37 -0400 (EDT)
Subject: Re: Local Shops and Dealers
Good idea, Kirby.
John
From: David J Shield David_J_Shield�m.fm.intel.com@vm1.cc.nps.navy.mil
David asks;
<Having said this, what’s the best paint to re-paint the black parts of
<those valve covers?
Clean them thouroughly and rough them slightly with some steel wool. Then
smear some vasoline over the parts you don’t want to get paint on. Spray
with some semi-gloss black. When dry, wipe the vasoline off the shiny
all-you-mini-ummmmmm part.
Lloyd - what was it that vasoline used to advertise itself as, "the
family something?? -
Date: Tue, 1 Oct 96 12:41:36 PDT
Subject: Re: XJ40 vs. Series III
| Roger-
| Do you find the road feel to be on par with the SIII? Everything you say
| here rings true for me and I’m less concerned with cost than results and
| effort required (I’m running out of me). What do you believe to be a
| reasonable life expectancy for an XJ-40 vs an SIII?
| Thanks!
| Hunt
You asked some very difficult questions. Here’s how I would put it:
The XJ40 is newer than a SIII, and is more durable, thus it would
ride better than a half-worn SIII. Many SIII’s need new steering rack
bushings, front end rebuild, rear end work, new shocks, and new bushings
throughout by about 80k miles (Jag techs please correct me if I’m wrong).
Why is that? Because usually the old rubber has hardened or worn. Even if
it’s not quite time for repair, the ride would have deteriorated.
If the SIII were new, I’d say it probably rides better due to the
superior rear suspension. I suspect Jag moved the brakes outward on
the XJ40 due to easier service and greater reliability. -
Any car can be made to run forever (well, maybe except for some Italian
stuff…) if you keep replacing worn items. I think a better question is,
what would I have to do to keep up with the car? I would say generally
you would have to do less to a XJ40. I’ve seen many in the local for-sale
ads that have run over 120K miles already, even the least reliable88 models. XJ40's have superior ZF transmissions that last longer than the BW units in SIII's. The AJ6 engine in XJ40's don't blow head gaskets at 100K miles like many SIII's do, and it doesn't need a stake- down kit. Electrics (post
90 models) are more reliable. The paint
doesn’t crack like SIII’s. Even the leather interior is more durable.
Leather and wood, in my opinion, only look good if they’re not in a shabby
state.
Having said all this, if you love the SIII, by all means get it, and
pamper it a bit. Don’t get something you don’t like. I’m just trying
to show you some practical concerns. I think the best “window” to buy
the series III was around 1990, when you could pick them up fairly
new at still reasonable prices. Now you have to be more patient and
look for a good one.
Intel Corporation
Date: Tue, 1 Oct 1996 12:52:45 -0700
Subject: XJ40 - ABS CLUNK!
Hi all,
Also have another brake problem now. Installed new brake rotors and
pads (all dealer), and the ABS system clunks all the time, well, only when
slowing down. Even a gradual slowing down, not attempting a wheel-lock or
anything! My passengers and I have a neck ache from this problem!
Scenario: Low pressure light on for about 9 seconds in morning only.
Rear struts are now non-leveling dealer package
Brakes clunk!
According to the tests it may be the charge solenoid (the low pressure),
because the reservoir may sometimes overflow with green oil (back-flow, not
seating?)
Where is this charge switch/solenoid thing, if it’s still applicable to a
non-leveling car?
Thanks for any insight or experiences!
Eric
cobac@ix.netcom.com
Date: Tue, 01 Oct 96 13:30:05 PDT
Subject: XK8 seen
Last night I attended the Canadian premiere of the XK8 in Victoria,
British Columbia. There were literally hundreds of people in a hotel
ballroom, and the Jags: two xk8 models in red (coupe and convertible, and
an xj6 Vanden Plas (for the first time the Vanden Plas designation in
Canada is for a six cylinder car). All and anything you wanted to drink,
courtesy of Jaguar, and a parking lot and garage FULL of Jaguars and
other high line models. The photos of the XK8 did not prepare me for
the car in the “flesh”. It is far more beautiful and better proportioned
than any photo can show, and IMHO the coupe is the winner. The fit and
finish of these cars is flawless. I have ordered one to be picked up
ten years from now!
Gregory Andrachuk
Date: Tue, 1 Oct 1996 18:03:38 -0400
(I hope).
| | <============== Fuel pick-up pipe and
\\\| |:: |\\ <===== Fuel Tank base \\\\\\\ -
|\| |:: |\| OUTSIDE
|\| |\| resevoir
Peter
74 XKE-V12 Roadster
Date: Tue, 1 Oct 1996 14:48:57 -0700
Subject: Re: V12 stumbling - answer
tank.
- --------------SNIP---------------
from
- -------------SNIP------------------
| | <================== Fuel pick-up pipe and | | plastic mesh filter INSIDE
|\| |:: |\| OUTSIDE
|\| |\| resevoir
On the MARK X’s the filter is brass mesh, and it is attached to the drain plug. It also fits tightly against the fuel pickup tube. If the drain plug has never been removed, the mesh WILL TEAR off of the plug. My brother says a GRACO airless sprayer filter pickup is almost an exact match and much cheaper than the “official” Jaguar part. Lee From: “Lee Walden” lwalden@ebmud.com Date: Tue, 1 Oct 1996 14:51:31 -0700 Subject: Re: Valve cover polishing David wrote:
those valve covers?
Mask off the ribs with masking tape and then spray the cam cover with a
nice semigloss or Crinkle black paint. Remove the masking tape and hit it
with Mother’s again. Lee
Date: Tue, 1 Oct 1996 14:29:16 -0500
I guess I could bottle some of my patented Mexican cheese dip and send
it to you. Every time I make a batch the inside of the pan
(aluminum/aluminium or otherwise) looks like a mirror. My wife says
she won't even try to eat something that can do that to metal.
On a more serious note, try a Brillo pad or a Scotchbrite pad. Both will polish cast alumiwhatever nicely. Far too abrasive for sheet alumimetal, but ok for castings. I have also used felt polishing points in my die grinder (kind of an oversize Dremel Mototool) with various grades of buffing compound. If you want to try a cloth and finger approach, Mother's makes a good alumistuff polish (or at least they did a few years ago.) The real problem is not making it shiny, its keeping it that way! The A-word metal oxidized faster than you can polish it. I've tried various clear coatings in the past. They look good for a while, but soon discolor and sometimes peel from the underhood temperatures. If anyone has a solution to the problem of keeping it shiny in a high temperature environment I'd sure like to hear it. MikeC ______________________________ Reply Separator _________________________________ Subject: aluminum polish Author: LLoyd <3030P@vm1.cc.nps.navy.mil> at Internet Date: 9/30/1996 1:58 PM The very thought of bringing up the "A" word again has me in a tizzie, but I got a question. What can I use to clean/polish aluminum? I tried chrome polish, but it laughed at me. I'm talking about the aluminum ribs on top of the 4.2 tappet covers. The aluminum under the hood is the last skuzzie looking thing there, but I'm stumped as to how to get it clean looking. LLoyd From: M.Cogswell@zds.com (Mike Cogswell) Date: Tue, 1 Oct 1996 15:54:34 -0500 Subject: Re[2]: Alternators and Dynamos While alternators are far superior to generators in automotive applications, especially at maintaining a constant voltage over a fairly wide rpm range, they still will start to fall off at low rpm under load. It's very common for a car with a heavy electrical load (e.g. headlights, climate control, wipers, rear window heater, etc.) to fall below the point where the alternator can keep up with the load at very low engine rpm. This will be aggravated if the engine is idling too slowly. If the alternator cannot maintain voltage at the proper engine idle speed and the electrical load is less than the winter worst case, I would do some diagnostics. If the voltage regulator is maintaining the proper voltage except for low rpm I would start by checking the diodes in the alternator. In your specific case, does the voltage gauge come back up when you raise the rpm to 800? If so, and that is the correct idle, then I'd quit worrying about the alternator and start tracking down the idle problem. MikeC ______________________________ Reply Separator _________________________________ Subject: RE: Alternators and Dynamos Author: shanem@vnet.IBM.COM at Internet Date: 9/30/1996 10:43 PM eg. Dynamo: increase engine speed = increased voltage - lights get brighter. Alternator: increase engine speed = increased current - no effect on lights. Barrie Dawson Chatham, Kent England 1985 series III Sovereign Barrie, if what you say above is true, can you help me out with my current problem. I have a mitsubishi 4 wheel drive, and am having electrical problems and idling problems. It is idling very low, and the voltage gauge is slowly dropping down whilst at idle. Revving the engine starts to make it climb again, and at the same time makes the headlights get brighter. Both my mechanic and auto electrician say that the alternator/regulator are fine. I still have doubts. Is it just the fact that the car is idling at around 400 rpm as opposed to its usual 800 rpm that may be causing the problem ? Does the alternator need enough revs to maintain the voltage level ? (If so, then my problem is probably the computer or the injectors are probably dirty...car has been tuned up, so plugs/fuel etc is not the problem..) Are there any other things that may be causing this charging problem ? From: Patrick Siu <patrick@idacom.hp.com> Date: Tue, 1 Oct 1996 17:01:41 -0600 (MDT) Subject: XJS V12 radiator flush Hi, Winter is approaching in Canada ... I tried to flush the radiator yesterday and discovered that there is no drain plug at the bottom of the radiator. Is this the original design from Jaguar? Any advise on the best way to drain the radiator? Any word of caution or suggestions are greatly appreciated. Thank you in advance for your help. Patrick Siu 89 XJS V12 Conv. From: "Lee Walden" <lwalden@ebmud.com> Date: Tue, 1 Oct 1996 17:27:45 -0700 Subject: Re: aluminum polish Mike wrote:
The
I use a “paint additive” called PENETROL. You wipe on a thin coating, and
it protects the metal from the elements. Don’t know how it holds up to
engine heat though. You could try it. I use it to protect amateur radio
antenna systems. Lee
Date: Tue, 01 Oct 96 21:17:14 EDT
Subject: Power window conversion
Since I didn’t get any replies last time, I’ll try again.
I have a 420G, but I guess this post applies to any jag.
My car has manual wind up windows. I have 4 brand new XJ6 power
window motors and want to find out how difficult it is to add
them to the car. Anyone there who can offer advice ???
I will shop around for a nice neat set of power window switches to
put in the centre console. Anyone recommend a nice set ? I’ve seen
some mark 2’s with a power window conversion that had a nice set of
switches in a panel about 4 inches by 2 inches. Something like this
would be great.
(Hopefully someone out there can help…I’m starting to think that
the discussion on the older cars is now dwindling to zip, and people
are talking about more day to day things and about new models more
often. I’m starting to long for the usenet to get started so that these
discussions can move on to it, and the meatier stuff can get more
priority on this list…) cheers…
1970 420G - Raquel , my voluptuous mistress
1978 XJ6 - My series 2 lumpster (TPI Corvette 350 CI)
REGARDS…Shane
Date: 2 Oct 96 11:18:44
Subject: Re: Replace the ECU as preventative maintenance?
Roger Langley: : On an older car (above 100 000 miles) would it make
sense to forestall
problems by replacing the ECU.
No. The No. 1 cause of injection/ignition trouble is dirty and slack connectors
and broken wires. As a preventive step, clean all tubular connectors with
cotton buds and acetone and check all spade connectors for firmness; tighten
them up (carefully) with a pair of pliers as needed. The connectors behind the
dash are usually OK.
- -Jan
Date: 2 Oct 96 11:33:24
Subject: Re: Ignition Amplifier
I’ve had a bit of a peek at my spare amplifier (date stamped 1987), to check
out this point (possible damage from broken connection to pickup coil). It
appears to be a standard capacitive discharge ignition unit. It’s difficult to
trace the circuit due to a number of unmarked and compound components, but it’s
clear that this is what the three wires to the pickup coil do:
BLACK: common earth
RED: signal from coil to bipolar transistor amplifier stage via DC-blocking
diode.
YELLOW: Small AC excitation current for pickup from oscillator coil. Little or
no DC.
The pickup coil itself is similar to that in a dynamic microphone but much
smaller. Breaking/making any of the three wires cannot cause harmful voltage
spikes.
I can only assume that the requirement to replace pickup and amplifier together
EITHER comes from the person responsible for requiring the use of Bar’s Leaks
in the coolant OR relates to the different connectors and wire colour code in
engine-mounted amplifiers as opposed to front-mounted ones.
- -Jan
Date: 2 Oct 96 13:15:25
Mike Cogswell : I guess I could bottle some of my patented Mexican
cheese dip and send
(aluminum/aluminium or otherwise) looks like a mirror. My wife says she won’t
Hey, can I have the recipe?
It’s the acetic acid in the vinegar that dissolves some of the aluminium; I
remember my granny cooking up some vinegar pickles in a cast aluminium saucepan
- it sprang a leak. And aluminium ions in food are strongly implicated in
Alzheimer’s Disease. I’ve junked all my aluminium cooking utensils (too late,
too late - I forget why) and I’d use a glass bowl if I were you…
My favourite aluminium polish is Solvol Autosol, a German product available
world wide. It’s an abrasive/solvent mix that produces a superb finish (on
chrome, too) and also contains something that appears to leave a protective
film - possibly wax. At least, the polish job seems to last extremely well.
- -Jan
End of jag-lovers-digest V2 #395
id for jag-lovers-digest-out; Wed, 2 Oct 1996 09:28:57 +0200 (MET DST)
Date: Wed, 2 Oct 1996 09:28:57 +0200 (MET DST)
Message-Id: 199610020728.JAA24800@ekeberg.sn.no
Subject: jag-lovers-digest V2 #396
Precedence: bulk
Status: O
X-Status:
jag-lovers-digest Wednesday, 2 October 1996 Volume 02 : Number 396
90 xj6 bulb failure light
[none]
SIII vs. XJ40
Buying a SIII
Re: XJ40 - ABS CLUNK!
Ignition coil testing
XJ6 SIII Speedo Error
Re: XJS V12 radiator flush
Re: aluminum polish
Re: XJ6 SIII Speedo Error
Re: 90 xj6 bulb failure light
Not XJ6 III but serious SI warning - Read it
Jags at Bathurst
Re: SIII vs. XJ40
Re: SIII XJ6 Noises
Re: Ignition coil testing
Date: Tue, 1 Oct 1996 23:09:38 -0400
Subject: 90 xj6 bulb failure light
we have a 90 xj6 that has a bulb failure light that comes on most times when
brakes are applied. installed all new factory bulbs in rear of vehicle and
light still comes on. also light comes on at times when you acceel. any
thoughts???
Date: Wed, 2 Oct 96 09:03:04 +1000 (EST)
Sorry but i couldn’t help it…
One produces alternating current an the other is a feudal japanese lord…!!
:-8
At 09:45 AM 10/1/96 -0500, you wrote:
A very simple minded question. What’s the difference between an
alternator and a dynamo? Is one American and the other English for
the same thing, or is there some kind of a distinction?I’m sure someone else can give a better explanation but just in case they
don’t
I’ll give it a try.No they are not the same thing.
The good dynamo/generators peaked out at about 22 amps.There are two major differences - which part spins and how the AC is converted
to DC.A dynamo (AKA generator) has coils of wire (several sets of them I think, say
uses
regulator involved in the process also but one thing at a time.The Alternator has the components reversed and spins the magnets inside (1
or 2
because it
also a
the alternator.Corrections/additions anyone?
Any Questions?
Robert Bradley
Date: Wed, 2 Oct 96 15:17 NZST
Subject: [none]
Date: Tue, 1 Oct 1996 23:53:45, -0500
Subject: SIII vs. XJ40
The two main reasons we buy Jags are: 1. they are simply beautiful
looking automobiles, and 2. They are a treat to drive. While my first
point is subjective I would have to say that the XJ-40 leaves
something to be desired in the looks department, especially when
compared to the SIII. Since, as we know Jaguars are art forms rather
that appliances maintenance and other mundane considerations must
take a back seat these two reasons, or else I fear we should all be
driving Honda Accords. I might as well add that for my money the new
XJ-6 puts Jaguar sedans back on top in the looks department
Date: Wed, 2 Oct 1996 00:18:00, -0500
Subject: Buying a SIII
Re: Query of Dieter Hachenberg
When looking to buy a SIII Jag one should be aware of many things
such as maintenence history overall condition etc. From my experience
major issues should be: has the car had a stake down kit installed if
not and the car still looks like a deal be prepared to do this as
soon as you buy the car. This kit is not a cheap fix due to labour
costs (the head must be removed) but is absolutely necessary, so
negotiate accordingly. Another key issue is paint, look at it
carefully the laquer on these cars tends to crack and must be
completely sanded off to respray which is very expensive. From what I
have read paint improvements went into effect in mid 1986 so many
'86’s and 87’s have good paint, many earlier cars have been reprayed
but look into this as a cheap respray (without having the old
cracking paint removed) will not last. Good luck on your search.
Date: Wed, 2 Oct 1996 00:32:31 -0400 (EDT)
- The XJ40 is newer than a SIII, and is more durable, thus it would
80K sounds fair for the front end. The rear goes longer. But just for the
record, the common wear items (ball joints, upper arm bushings and shock
mount bushings) are the same pieces for both cars. Well the shock mounts
are different sizes, but the same material. The XJ40 steering rack mount
is better stock. I think road feel is better on a SIII with the aftermarket
bushings.
Nothing is worse than an XJ40 with failed self levelers in the back. To
quote Carrol Smith (talking about something entirely different: “… like
four pogo sticks going down the road in loose formation”.
ads that have run over 120K miles already, even the least reliable `88
As you said, any car (including Italian) can be made to run forever. I have
many SIII customers with over 150K on the clock. Several with over 250K.
models. XJ40’s have superior ZF transmissions that last longer than
the BW units in SIII’s.
True and to this day it amazes me. The 4HP22 unit was used by several Euro
car makers in the 80’s. Volvo, BMW, Peugeot, Renault, Lincoln… and
they all had excessive failure rates. It was common to hear stories from
the dealer mechs about having to push a new car off the transporter and
put another transmission in it. It was so common that Volvo went back to
Borg Warner (well, Asian Warner) around 88.
I’ve yet to see one of these units fail in an XJ40. Typical of Jag to have
the inverse reliability record of a common proven part. :>
The AJ6 engine in XJ40’s don’t blow head gaskets at 100K miles like
many SIII’s do, and it doesn’t need a stake-down kit.
Again, for the record, I am currently doing more AJ6 head gaskets than XK’s.
This is due to oil leaks out the right front corner. Other than that, the
AJ6 is a fantastic engine.
Electrics (post `90 models) are more reliable. The paint
state.
All true.
Randy K. Wilson
Date: Wed, 2 Oct 1996 00:41:29 -0400 (EDT)
Subject: Re: XJ40 - ABS CLUNK!
Hi all,
Brakes clunk!
seating?)Where is this charge switch/solenoid thing, if it’s still applicable to a
non-leveling car?
The charge switch and solenoid are both still very active. They have to
do with the hydraulic brake booster. They have nothing to do with the
rear suspension, the brake hydraulics proper, nor the ABS system. If
they totally failed you would only loose power assist (only? ever try to
stop one of these beasts without any?).
The solenoid is on the valve block, and the switch is on the accumulator
vessel.
Now, what are all of the symptoms? Does the pedal feel normal? Is the clunk
a one time thing, or continuous? rotational? Is the braking force linear or
is it jerky/grabbing? What makes you think it’s the ABS doing the clunking,
and not the brake mechanicals?
My first guess would be a rotor that is severely warped, or not seated
correctly on the hub.
Eric
cobac@ix.netcom.com
Randy K. Wilson
Date: Tue, 1 Oct 1996 22:02:13 -0700
Subject: Ignition coil testing
As a neophyte automotive electrician, I need some assistance in testing
the ignition coils on my '85 XJ-S. Can anyone give me easy to
understand, step by step instructions for this task?
Thanks in advance.
Aaron Burnett
'85 XJ-S
Date: Tue, 1 Oct 1996 22:19:04 -0700 (MST)
Subject: XJ6 SIII Speedo Error
I recently purchased a 1983 XJ6 VP: over 100k miles, but good condition:
some minor undesired features!
One of the ‘features’ is that the speedo appears to read low, e.g. read
40mph but really doing closer to 50 - I think!
Does anyone have data as to what rpm of the engine corresponds to what speed
- in top gear say. A range of speeds would be useful: 30, 40, 50, 60 …
This would allow me to confirm my suspicions and hopefully avoid a speeding
ticket. My car is a standard US model, I believe, with no mods in this area
(wheels, tires, differential, transmission, …).
Assuming that my suspicions prove correct, are there any obvious places to
look other than having the speedo rebuilt? The odometer does appear to be
correct as far as I can tell.
I’m new to this list, and new to owning Jaguar cars, but loved them forever!
I’ve had a Triumph TR6 for twenty years, and its still my daily driver, but
is overdue now for some serious work - hence the justification for the Jag
purchase! Trouble is, my wife has fallen in love with the Jag, so …
BobK
Bob Kerr, Phoenix AZ, USA
'76 Truimph TR6 OD (Carmine);
'83 Jaguar XJ6 Vanden Plas (Gold)
Arsenal Gunners FAN
“Relax…don’t worry…have a homebrew!”
Date: Wed, 2 Oct 1996 07:31:00 +0200 (MET DST)
Any Questions?
I guess one important point is that an alternator deliveres an significant
amount of current at about engine idle speed if I remember well.
- Matthias
Date: Wed, 2 Oct 1996 07:55:17 +0200 (MET DST)
Subject: Re: XJS V12 radiator flush
I removed the lower radiator hose.
- Matthias
Date: Wed, 2 Oct 1996 08:02:51 +0200 (MET DST)
-Jan
Here in France is a company “Belgom” (spelling ?) which amongst others product
have a very nice aluminium cleaner. I bought a bottle recently and it really
gives excellent results. I also saw this product advertized in other
European countries.
- Matthias
Date: Wed, 02 Oct 1996 02:17:10 -0400
Subject: Re: XJ6 SIII Speedo Error
I’m certainly no expert, but when I replaced my
tach generator the techie that rebuilt it tested it
on some kinda flutterometer contraption and, showing
me that it worked properly, told me that they are not
nearly as accurate as people think.
Since I’m having the same suspicions about my own
speedo, I am having a friend drive (following me) checking
my speeds at various increments.
Yeah, I know, and who is going to check his?
Prob. a cop!, it is an E you know.
Charles Daly, Toronto, Canada
'62 E-Type, ots
Date: Tue, 01 Oct 1996 23:18:10 -0700
Subject: Re: 90 xj6 bulb failure light
times when brakes are applied.
I’ve had a similar problem with my 91 Sovereign that reappears like a
ghost from time to
time with never a satisfactory answer. I usually “cure” it by
slamming the driver door (I suggest doing this at stop lights, not
while going around a curve at 90mph).
I’m all ears to what others have to say.
Donald R. Farr
Paradise Valley, AZ 85253
91 Sovereign
Date: Wed, 2 Oct 1996 01:26:01 -0500
Subject: Not XJ6 III but serious SI warning - Read it
I don’t think this is your problem but you reminded me of something which
happened to me several years ago on my Series I XJ12 which scared the daylights
and several other things out of me. I don’t know if it’s common and I believe
it is not just a Jaguar problem, but everone should be aware of the following
in case it ever happens to you - it will possibly save your life.
As far as I am aware there was no warning from the steering system - everthing
was working fine. Then, in a instant I discovered I could no longer turn the
car to the left AT ALL. If I turned the wheel a little to the right that was
easy to do but NO amount of force would turn the wheel back to the left in
the slightest. I shudder ever time I think what I would have done if I had
been traveling at any speed. By the grace of who or whatever, I was reverse
parking at the time! The steering specialist (in Melbourne not Bahrain), who
stripped the rack, said that the the piston on the rack had come loose and shot
to one end of the rack (left end I presume) where it was tilted by the force of
the power steering fluid and formed an extremely effective one way locking
mechanisim on the rack which no amount of force could release.
That’s the warning, here’s the immediate reaction which I hope no-one ever has
to use.
I had time to work this out - it took me about 10-20 seconds, you may not be so
lucky. Cut the engine immediately in order to stop the steering pump. This
removed the pressure from the displaced piston and allowed me to turn the wheel
both ways albeit without any assistance but at least I had full steering
control.
P.S. I think the steering specialist said that the rack design was modified on
later models to attach the piston to the rack in a more secure manner. Can
anyone confirm?
P.P.S. Has any one else had this happen? I don’t want everyone to pannick and
start stripping their racks.
Robert Bradley
82 XJ4.2, 82 Daimler, 87 XJ-S
Date: Wed, 2 Oct 1996 01:42:49 -0500
Subject: Jags at Bathurst
1984 I think but you bring back fond memories. Magnificent race to watch. It
was TWR at their best “I came, I saw, I conquered”. It was a real
demonstration of how a professional team does things. No mucking around, three
car team, fully equiped. All cars were a class above the field. The number
THREE car won easing up at the end due to a broken seat mount. The number two
car retired with a broken headlamp which sent glass into the air intake.
Tom’s (#1) car lost a few laps with an oil leak (how unusual) but Tom got the
last say when the commentary team was focusing on the race for second/third.
Half way up the back straight with second & third neck and neck, side by side
(take your pick); the incar camera in one of the tussling cars is pointed si
deways at the other to highlight the struggle. The commentator is going wild
- meanwhile Tom steams past to make it three abreast (he was a few laps down),
as he draws level he turns to the camera, smiles, flicks a wave and steams
off. Beautiful stuff - anyone got a tape?
Robert Bradley
82 XJ, 82 Daimler, 82 XJ-S
Date: 2 Oct 96 17:54:47
Subject: Re: SIII vs. XJ40
The thing about taste is that, being a species of opinion, one person’s taste
is as valid as any other person’s. I think it’s just a little rude to tell
others that “Your car is ugly next to mine, and doesn’t drive as well, either”.
Personally, I like my XJ12C very much and every drive is a thrill - but if you
prefer the Series 4 XJ6 (aka XJ 40), and get great pleasure out of driving it,
that’s great, and I’m happy for you. Even if you have formed an attachment to a
lump transplant patient, I’m happy for you. It’s your choice, and it’s your
taste that matters, not mine.
Having said that, I think it’s a damn’ shame they didn’t do an XJ12C in series
3…
:3+)
- -Jan
Date: Wed, 2 Oct 1996 02:11:05 -0500
Subject: Re: SIII XJ6 Noises
You are incorrect to rule out the fuel pump. The pump itself does not click on
this model - it whirs (SUs click). Furthermore it does not operate when the
engine is not running or the key is in the cranking position.
One suggestion as follows. The noise you describe, including your diagnosis
notes (notably that the noise is more obvious from inside the car) is very
similiar to the noise I have in one of my SIIIs. After much investigation by
myself and the Jaguar service manager we narrowed it down to a fuel pulsing
noise being transmitted from the fuel line through the body of the car. No
easy fix was obvious. Since the noise is only noticable when ambient noise
levels are low ie. the car is idling and the AC is OFF (only for a few weeks
in winter) and it is not doing any mechanical damage I have not bothered to
pursue it further.
Robert Bradley
Bahrain
82 XJ, 82 Daimler, 87 XJ-S(if it ever comes back from the workshop)
Date: 2 Oct 96 18:22:19
Subject: Re: Ignition coil testing
This is the Gum Tree Garage test for a V12 ignition when it cranks but refuses
to start:
Pull the lead from coil to distributor out of the distributor and jam it
under a fuel pipe so there’s a gap of about 1 mm (.04in) between the brass and
the nearest engine part. -
Crank the engine. Do you get fat, blue sparks in the gap? Then the ignition
is OK and you need to troubleshoot the injection system. If not, continue: -
Pull the spade connector off the coil terminal marked (+). Turn the ignition
on, then test the power with a spare light bulb between the connector and
engine bare metal (this is better than a voltmeter, because it will reveal a
poor contact with insufficient current carrying capacity). Is the lamp bright?
Then continue; if there’s no voltage, check the ignition switch and all its
wiring including the ballast resistor. -
Touch the connector quickly several times to the terminal. Do you get a
spark now? Then the pickup coil in the distributor or its wiring, or (less
likely) the amplifier, may be faulty. If there’s no spark, turn the ignition
off and continue: -
Get a test lead with alligator clips. Clip one end to bare metal on the
engine, pull the tubular connector off the (-) terminal of the coil and clip
the other end to that terminal. -
Repeat test 4. If you get a spark now, the amplifier or its wiring is
faulty. If you get no spark, the coil is dead.
Enjoy!
- -Jan
77 XJ12C
78 XJ12L
End of jag-lovers-digest V2 #396
Return-Path: @owner-jag-lovers-di1
Received: (from majordom@localhost) by ekeberg.sn.no (8.7.5/8.7.3/on4)
id for jag-lovers-digest-out; Wed, 2 Oct 1996 17:03:19 +0200 (MET DST)
Date: Wed, 2 Oct 1996 17:03:19 +0200 (MET DST)
Message-Id: 199610021503.RAA22250@ekeberg.sn.no
X-Authentication-Warning: ekeberg.sn.no: majordom set sender to owner-jag-lovers-digest using -f
To: jag-lovers-digest@sn.no
Subject: jag-lovers-digest V2 #397
Reply-To: jag-lovers@sn.no
Errors-To: @owner-jag-lovers-di1
Precedence: bulk
X-Newsgroups: mail.jag-lovers-digest
jag-lovers-digest Wednesday, 2 October 1996 Volume 02 : Number 397
Re: XJ6 III lazy power steering
Wanted XJ6 SIII, XJ40
Re: SIII XJ6 Noises
Alzheimers/Aluminum
Jaguar Association of New England Rally (X-post SOL)
Bulb Failure Light XJ6/XJS
looking for used tires / XJ-S
RE: Sir William, noisy AC.
Date: 2 Oct 96 19:00:16
Subject: Re: XJ6 III lazy power steering
Does sound like the pump is clapped out, Tim - although they usually get noisy
with age. Have you checked the belt tension? It does need to be fairly tight.
Actually, I just remembered - there’s a small strainer in the relief valve,
which may be blocked; this tends to pop the valve prematurely and reduce the
pressure. To check this, disconnect the delivery line and use a socket (can’t
remember the size - 7/8?) to unscrew the delivery fitting. Behind it, there’s a
spring and a valve spool; at the inner end of the spool (forward as the car
travels), there’s what looks like a self-locking hex nut; the tiny strainer is
in in the mouth of this nut; unscrew it and clean with great care.
For neatness, suck the oil out of the pump before you start - a retired bicycle
pump can easily be converted into a sucker…
The official Repair Operations Manual has a pretty good section on PAS
trouble-shooting, but it calls for gauges and fittings.
- -Jan
Date: Wed, 2 Oct 1996 09:48:20 +0100 (MET)
Roger Peng rpeng@cadev6.intel.com wrote:
Indeed, the series III is the most beautiful car in the world, but
Amen to that! IMHO the Series III XJ is the Cindy Crawford of cars. Or
maybe Cindy is the Jaguar of women? Hmmm…
it’s not all that durable compared to other cars. Especially when it’s
done over 120K miles, the car virtually needs to be restored. You need
a new engine, new transmission, new paint, new interior, new wood,
no bushings, new steering rack, rear suspension work, some rust removal,
A/C work, electrics repair, and perhaps a new gas tank or two. The total
cost can be daunting, and you need to go through a lot of hassles to get
everything done. Once you’re done, if you ever decide to part with your
Jag, you’ll never get your investments back.
Maybe not today, but I think I read somewhere that these cars are rising
stars among the automobile collectors. They are after all getting 10
years old and more and just about everyone agrees that they are
beautiful. I’m afraid that we’re getting to the point soon where they
won’t be driven anymore, they’ll be collected. What a pity.
Ah well, I bought mine to drive it! Now if I could only get Cindy
somehow I’d sure as hell… never mind!
Gunnar
Gunnar Helliesen | Bergen IT Consult AS | NetBSD/VAX on a uVAX II
Systems Consultant | Bergen, Norway | '86 Jaguar XJ6 4.2 Sovereign
gunnar@bitcon.no | http://www.bitcon.no/ | Vicki who? What .sig virus?
Date: Wed, 02 Oct 96 10:57:00 EET
Subject: Wanted XJ6 SIII, XJ40
I`m interested to purchase Jaguar XJ6 SIII (1985 - 1987 only) or XJ40
(1988 - 1993). Important - left placed steering wheel! Colour and
interrior - any, possible. Power windows, doors etc. May be with or
without CD/radio.
Thanks for any response,
Mareks Malnacs.
Date: Wed, 2 Oct 1996 10:02:34 +0100 (MET)
“Dan Golder” dan_golder@sdm.buffalo.edu wrote:
I have a 1985 SIII XJ6 VDP…
On colder mornings (50 degrees) after a day or two of sitting, my Jag makes a strange “clicking” noise upon startup. We have a lot of those mornings around here (and worse to come). My car has the same thing, sounds like it’s coming from under the car, at first I thought it was the passenger seat that was loose or something. The PO (and Oslo Jaguar Service) have told me that it’s the fuel return line. The noise is created by pulses in the line or some such. I’ve checked the tube (yep, it’s running right beneath the passenger seat) and it’s already insulated with rubber by the PO. I’ve been told that it’s perfectly normal and the only way to get rid of it is to install a filter (I think) in line with the tube. I haven’t really investigated further, let me know if you do and find out some more. Gunnar Gunnar Helliesen | Bergen IT Consult AS | NetBSD/VAX on a uVAX II Systems Consultant | Bergen, Norway | '86 Jaguar XJ6 4.2 Sovereign gunnar@bitcon.no | http://www.bitcon.no/ | Vicki who? What .sig virus? From: “Felts, Thomas L.” Thomas.Felts@alcoa.com Date: Wed, 2 Oct 1996 07:27:13 -0400 Subject: Alzheimers/Aluminum Someone recently suggested you throw your AL pans away because use could cause Alzeimers. To my knowledge there has never been any statistically proven link between Al pan use and Alzeimers. Tom From: “Owens, Adam J.” uscuc8hc@ibmmail.com Date: Wed, 02 Oct 1996 09:34:39 EDT Subject: Jaguar Association of New England Rally (X-post SOL) Date: 1996-10-02 09:14 Priority: For any jag-lovers in the Boston,MA area on Sunday October 20,1996. JANE will be holding a Fall Fun Rally. This will be a short non-JCNA sanctioned ‘fun-type’ rally similar to the Spring Rally held in May. Entry is open to anyone and any vehicle. Entry fee will be $15 and trophies will be awarded for 1st, 2nd and 3rd place along with the infamous DLBF prize. Meeting point will the Burger King Restaurant on RTE 128 North in Beverly,MA at 10:00 AM. For further info please call the JANE Rallymasters John & Nancy Capacefalo at (617) 729-2065. Best of luck to all! Cheers, A.J. Owens - Jaguar Association of New England http://users.aol.com/ajowens/jane.htm From: JISBELLJR@mail.utexas.edu (Jim Isbell) Date: Wed, 2 Oct 1996 08:49:01 -0500 Subject: Bulb Failure Light XJ6/XJS I have a bulb failure indication on my XJ6 and cannot find the solution unless it is the detector unit itself that is out. My XJ6 manual (Haynes…?) says that the clearance lights front and back and the tail lights are monitored. Strangely, the Haynes manual for the XJS seems to indicate that only the Brake lights are monitored. Does anyone have the true information? And, is there a way to test the detectors to determine if they are working? JIM I. “Prefiero morir de pie que vivir de rodillas.” Gen. Emiliano Zapata 1879-1919 From: mfl@kheops.cray.com (Matthias FOUQUET-LAPAR) Date: Wed, 2 Oct 1996 15:50:26 +0200 (MET DST) Subject: looking for used tires / XJ-S I’m looking for two used tires for my XJ-S, Pirelli’s P600 235. If anyone something and is going to JEC spare day in October, please let me know Thanks matthias From: M.Cogswell@zds.com (Mike Cogswell) Date: Wed, 2 Oct 1996 10:04:25 -0500 Subject: Re: XJS V12 radiator flush The same question was asked a few weeks ago… The answer is: disconnect the lower radiator hose at the radiator end. (It will drain REAL fast.) ______________________________ Reply Separator _________________________________ Subject: XJS V12 radiator flush Author: Patrick Siu patrick@idacom.hp.com at Internet Date: 10/1/1996 5:01 PM Hi, Winter is approaching in Canada … I tried to flush the radiator yesterday and discovered that there is no drain plug at the bottom of the radiator. Is this the original design from Jaguar? Any advise on the best way to drain the radiator? Any word of caution or suggestions are greatly appreciated. Thank you in advance for your help. Patrick Siu 89 XJS V12 Conv. From: “Dawson, Barrie” dawsonb@btcec3.agw.bt.co.uk Date: Wed, 02 Oct 96 15:22:00 GMT Subject: RE: Sir William, noisy AC. Jim, I have been experiencing the same thing with the AC on my series III . I recently had the AC system rebuilt, compressor/condenser/dryer/various valves & thermostats, everything was fine for about 5 months. I noticed a hissing sound, inside the car, every time the compressor cut in. I checked under the bonnet and noticed an increase in bubbles in the dryer sight glass and a heavy build up of frost on the return pipe to the compressor. I checked this out with my local AC specialist and he said the system was low on refrigerant and needed topping up. Getting system recharged next week, ?40.00 should do it. Barrie Dawson Chatham, Kent England 1985 series III Sovereign From: jag-lovers-owner To: jag-lovers Subject: Sir William, noisy AC. Date: 30 September 1996 16:24 The voice interview I mentioned on the pronounciation of Jaguar was an interview with Sir William. I consider him the authority on the subject and he said Jag-u-were. I have a question about noise from freon flow in an AC system. I just got my XJ6 back and I can hear the freon flow through the system. I didnt used to be able to. I had this happen on a Ford Escort once after an AC repair. Never knew why. Is this curable? The AC works perfectly, its just that you can hear the freon “sing” as it goes through the system. Its most noticable after you shut the car off and the freon goes toward equilibrium. Jim “Better an outlaw than not free.” Nance O’Neil From: jjoy@risc.sps.mot.com Date: Tue, 1 Oct 1996 09:00:02 -0500 (CDT) Subject: Jaguar Suppliers (posted monthly) Suppliers, North America (mostly). [This list is automatically sent out on the first of each month.] Updates: none (Corrections, etc, to: jjoy@risc.sps.mot.com) The majority of this list has come from Rob Reilly reilly@admail.fnal.gov SUPPLIERS OF JAGUAR PARTS AND SERVICES Rev. 8-1-96 A D Motor Rebuilding, NY 1-516-395-5101 Lucas, Smith’s motors rebuilt Al Hogan’s Autojumble Mansfield, Ohio 1-419-524-1088 NOS parts supplier Specializes in buying out old dealer stock. Owner (Al) is knowledgeable about british car parts. Steve DuChene s0017210@cc.ysu.edu Dick Ames, 608 Ft. Williams Pkwy, Alexandria, VA 22304 1-703-370-3097 stainless exhaust systems Best price on stainless steel exhaust systems. I’ve misplaced the address but can probably look it up if pressed. PKR@SLACVM.SLAC.Stanford.EDU (Patrick Krejcik) Ancient Car Parts, 64 N Main, Lyndonville, NY 14098 1-716-765-2894 rust repair panels for XJ Apple Hydraulics, 715 Route 25A, Miller Place, NY 11764 1-800-882-7753 rebuilds Armstrong, Girling shocks, SU carbs 1-516-744-9627 Asom Electric, 1204 McClellan Dr., Los Angeles, CA 90025 1-310-820-3720 email: asomelect@aol.com 1-800-424-2766 Electrical rebuilding shop that deals mostly in Lucas and Bosch and rebuild starters, alternators, generators, fuel pumps, voltage regulators, wiper and window motors. They have a large supply of Lucas parts, including discontinued items. In business for 36 years, have daily UPS, and accept credit cards. Atlantic Enterprises, Route 4, Box 394-B, Loris, SC 29569 1-803-756-7565 steering racks, seal kits, polyurethane rack mounts Auto Interiors of Europe, 1790 E McFadden, Unit 107 1-800-533-2886 interiors Santa Ana, CA 92705 (not sure which addr. is correct) 3023 S. Orange Ave. Santa Ana, CA 92707 (714) 751-9046 Nice stuff if I remember correctly. Not cheap but nothing for these beasts is. s912!rick@bnf.com (Rick Ezneker) Kent Bain, 1785 Barnum Ave, Stratford, CT 06497 1-203-377-6745 custom interiors, seat rebuilding and repadding G.W.Bartlett, Muncie, Ind. 1-800-338-8034 interior and trim parts Sells original Jaguar Interior kits and components. All to exact Jaguar specifications. As per original spec. Quite costly but isn’t quality always a bit more? (eg. Interior kit for Jag 3.8s is about $4200, retail.) zrol01@trc.amoco.com (Richard O. Lindsay) Basset’s, Wyoming, R.I. 1-401-539-3010 restoration parts Borla Industries, Oxnard, Calif. 1-805-983-7300 stainless exhaust British Auto Center, 2938 SW Avalon Way, Seattle, WA 98126 206-935-0873 Lots of late model stuff, new and used. Very knowledgeable. Can sometimes be grumpy. – Greg Meboe (meboe@wsunix.wsu.edu) British Auto USA, 92 Londonderry Trnpk, 1-603-622-1050 British Auto USA Interiors Manchester, NH 03104 1-800-4-JAGPTS interior and trim parts 1-800-452-4787 Exc. inventory of interiors and body parts. Limited inventory of mechanical parts but I always check them out because they’re cheaper! (I avoid Bartlets for Jag interiors) PKR@SLACVM.SLAC.Stanford.EDU (Patrick Krejcik) British Car Parts, CA 1-818-788-7636 new and used parts British Marque Auto PO Box 344, Bainbridge, PA 17502 1-717-426-2675 interiors British Motor Service, 521 W. Katella, Orange, CA 92667 1-714-997-3800 Moss distributor, used XK parts British Parts Northwest, 4105 SE Lafayette Hwy, 1-503-864-2001 new parts for late models, no sheet metal Dayton, OR 97114 British Restoration Parts, Kansas City, Mo. 1-800-821-3767 new restoration parts British Spares, 46 Florence, Springfield, MA 01105 1-413-736-0463 fabricates panels for XK, Marks, E British Vintages, 645-D Tank Farm Rd, 1-800-350-JAGS San Luis Obispo, CA 93401 1-805-541-5986 Have their catalog but so far never used them. PKR@SLACVM.SLAC.Stanford.EDU (Patrick Krejcik) British Wire Wheel, 1650 Mansfield St, 1-408-479-4495 Santa Cruz, CA 95062 Dayton and Dunlop wire wheels, tires THE place to go for correct reconditioning of your JagWires. Also to buy THE correct tires. PKR@SLACVM.SLAC.Stanford.EDU (Patrick Krejcik) Bob Brosen, 7804 Billington Court, Oxen Hill, MD 20744 1-301-248-6327 new repro parts for pre-war, Mark IV, V Classic Parts & Panels, Ltd. 0296 658938 Fleet Marston Farm, Bicester Rd., Nr Waddesdon Aylesbury, Bucks, UK HD 18 ODZ XK panels Classic Restoration Parts, Bellflower, Ca. 1-213-804-2756 XK grilles, gas tanks Classic Tube 1-716-759-1800 A Division of Classic & Performance Specialists 80 Rotech Drive Lancaster, NY 14086 USA They supply steel and stainless steel pre-bent brake and fuel lines for various makes of cars. I got half the brake lines and clutch lines from them in stainless, and being the prudish restoration junkie I am, I was concerned that the reproduction in stainless would not be very “original”. However, I’m happy to say the final product is almost identical to the original steel lines, most judges will not notice the difference. – Mark Roberts (markdr@bnr.ca) Concourse West, 644 Terminal Way, Costa Mesa CA 92627 714-642-9807 fax 714-645-8388 Have rebuilt diffs. PKR@SLACVM.SLAC.Stanford.EDU (Patrick Krejcik) Cordell R. Newby, 1410 N. Aurora, East Wenatchee, WA 98801 509-884-6823 Specializes in Mark V parts. New and used. s912!rick@bnf.com (Rick Ezneker) Coshman Ent, PO Box 2685-J, Orcutt, CA 93455 1-805-937-7456 Whitworth tools, taps & dies, gauges, fasteners Coventry Engineering, 9500 SW Martha St, Tigard, OR 97224 1-503-620-9482 wiring harnesses Coventry S Ltd, 6406 85th Place, New Carrolton, MD 20784 1-800-537-4146 stainless exhaust systems Joe Curto, 230-22 58th Ave. Bayside, NY 11364 1-718-465-4829 S.U. parts Wes Czech, HCR 9550, Lucerne Valley, CA 92356 1-619-248-9603 XK parts Stanley Daniel, 124 Parkview Rd. Cheltenham, PA 19012 1-215-782-1248 used Mark 7-9 parts from 30 cars, call after 9PM EST Doctor Jaguar, 644 W 17th St, Costa Mesa, CA 92627 1-714-646-2816 parts, engines, trans, susp. parts East Coast Jag Parts DE 1-302-731-7200 EJAG NEWS, Box J, Carlisle, Mass 01741 magazine, a few accessories Engel Imports, Kalamazoo, Mich. 1-800-253-4080 new car dealer, will UPS, cheaper than other dealers European Auto Specialists, 1-313-355-2730 OEM parts for late models John Farrel, 4315 Murray St., Flushing, NY 11355 1-718-762-9071 NOS XK parts Foreign Car Center, 1610 S Main, Milpitas, CA 95035 1-408-262-0325 used parts recycler Grand Turisimo Jaguar 1-216-259-5656 4285 Main Street fax: 1-216-259-5588 Perry Village, OH 44081 engine rebuilder, parts Specializing in high performance parts and services. They list a ‘level 5’ Jaguar V12 with all of the whistles and bells like porting, balancing, etc. with 6, count them, 6 two bbl Weber carbs mounted vertically across the top of the V12! This engine sells for about $13,500. - zrol01@trc.amoco.com (Richard O. Lindsay) Gunson Ltd., Pudding Mill Lane, London E15 2PJ UK source for ColourTune Tony Handler’s Foreign Parts Connection 1-213-473-7773 2028 Cotner Ave, Westwood, CA 90025 H.D. Rogers & Sons 1-318-742-3651 3418 Barksdale Blvd. fax: 1-318-742-5044 Bossier City, LA 71112 email: hdrsons@iamerican.net Family-owned business supplying used, NOS, discontinued parts as well as enhancements for newer cars. For example, they offer aftermarket a/c hoses for XJ series and a less expensive amplifier. They try to give special rates to internet users. They also have contracts worldwide and will try to locate hard to find items, and offer special prices for prepaid orders from overseas. Harry CA 1-408-262-0235 used parts H.P. Co., 1079 Colonial Club Dr, Harahan, LA 70123 1-504-737-4691 burled walnut dashboards I-35 Imports Oklahoma 1-405-799-2886 used parts, 80 and older Intermarque Auto Parts Houston 1-800-666-8700 parts and sheet metal International Spare Parts 1-800-243-0073 J.K.Restorations, 12 Jackson, Oswego, IL 1-708-554-2120 complete restorations, specialist for XK and E, some used parts Jag Atlanta, 3437 Sexton Woods Dr, Chamblee, GA 30341 1-800-533-8973 new, used parts for E and XJ 1-404-455-0175 Jaggist (Alan Trickel) 1065 Hillview, Ashland, OR 97520 1-503-535-8486 used XK parts Jaguar Cars Inc, Public Relations, Mahwah NJ 1-201-818-9770 For a fee will authenticate your VIDNs. PKR@SLACVM.SLAC.Stanford.EDU (Patrick Krejcik) Jaguar Denver 1-800-426-4515 Lucas, Girling, Jag parts Jaguar Heaven, 1433 Tillie Lewis Dr, Stockton, CA 95206-1130 info: 1-209-942-4524, orders: 1-800-969-4524, FAX: 1-209-942-3670 used parts recycler, all models Jaguar Interiors of England, PO Box 47, Muncie, IN 47308 1-317-289-9901 carpeting and upholstery Jaguar Motor Works, 3701 Longview Dr, Atlanta, GA 30341 1-800-331-2193 used XJ parts recycler, rebuilt parts Local 404-451-3839 FAX-404-451-7561 Jaguar of North America, Leonia, NJ 1-201-592-5200 factory American distributor Jaguar South Greenville, SC 1-803-244-1555, 1-803-292-3934 used parts recycler Jaguar parts SC 1-803-754-5363 Jaguar Warehouse, 6010 Mardale Lane, Burke, VA 22015 1-703-451-4071 NOS parts Jaguar Warehouse, 5727 Walcott Ave, Fairfax, VA 22030 1-703-968-3983 XK parts J C Whitney, Chicago, IL 312-431-6102 Also known as Warshawsky/Whitney. Sells car parts cheap for most cars including LBCs. Massive buying power. Brainless order-takers. You can call in the middle of the night for good long-distance rates. They will not tell you brand names. All the swaybars are ADDCO. See also ADDCO and Werace. - ? J.C. Whitney offers a few items that are of interest. Things like generic weatherstrip by the foot, etc. The do offer after market A/C units and high output quartz halogen 7 inch headlights (110 watts!!!). The ad carries the label ‘Not legal for street use.’ They look really cool. zrol01@trc.amoco.com (Richard O. Lindsay) John’s Cars, 800 Jaguar Lane, Dallas, TX 75226 1-214-426-4100 fax: 1-214-426-3116 V-8 conversions, other repro parts, claims improvements over stock Just Jags, 407 Industrial Dr, Carmel, IN 46032 1-317-844-8823 new, used parts, service, restorations Just Jags, 8720 Big Bend at Elm, St.Louis, MO 63119 1-314-968-2450 service, parts, restoration shop Keller Associates, PO Box 2833, Saratoga, CA 95070 1-408-370-3705 burl walnut dashboards Lister of North Am, 1912 Granvill Av, Muncie, IN 47308 1-800-338-8034 high performance accessories Lovello, Mark SC 1-803-244-1555 used parts Moss Motors, PO Box MG, 7200 Hollister Av, Goleta, CA 93116 800-235-6954 new and repro parts for XK’s Moss Motors, Santa Barbara, California 1-805-963-0741 new car dealer Cordell Newby, 1625 N Western, East Wenatchee, WA 98801 1-509-662-7748 new, used, repro parts for pre-war, Mark IV, V added: Jul. 29, 1994 Nisonger Instrument Sales & Service 1-914-381-1952 570 Mamaroneck Ave. fax: 1-914-381-1953 Mamaroneck, NY 10543 Repairs capillary based guages. “I had them repair my water temp gauge 2 months ago. Charge was $100 including shipping, turnaround time was 2 weeks, and they take plastic.” Rob Reilly Northwest Modern Classics, 121 Duryea, Raymond, WA 98577 interiors, carpets, upholstery, tops 1-800-854-1751,1-206-942-5532 Northwest Transmission Parts, Ohio 1-513-442-2811 or 1-800-327-1955 auto trans rebuilding kits, torque convertors Peninsula Imports, 3749 Harlem Rd, Buffalo, NY 14215 1-800-999-1209 XJ, E body and rust repair panels 1-716-833-3000 Fred Petroske, RR1, Box 112, Chaumont, NY 13622 1-315-649-2861 used parts recycler, all models Paul K. Phillips 1-305-846-7976 1124 N. W. 134 Ave. fax: 1-305-846-9450 Sunrise, FL 33323 Specializes in the XJ Coupe market and runs an XJC register. “I have dealt with him once on an exhaust system (via a referral from SICP) and got good service. He does require cash C.O.D. (no credit cards) which is a bit of a bother.” - gladish@suite.com (Brian Gladish) Phil’s, Inc. Ashland Ave, Evanston, IL 1-708-869-2434 PII Distributing, PO Box 27358, Houston, TX 77227-7358 1-800-231-5836 genuine Jaguar parts, sheet metal 1-713-975-6272 Chuck Pilate, 24996 W Magdalena Dr, Mt Clemens, MI 48045 XK, E parts 1-313-791-0429 Rich’s Import Auto Parts & Serv, 730 N Glebe Rd, Arlington, VA 22203 parts for E, XJ and 62 on sedans 1-800-336-6603, 1-703-522-0440 Rhino Auto Parts, Hanover, MN 1-612-498-8711 used and NOS parts 50’s to 70’s Rhode Island Wiring Service, Box 3737H, Peace Dale, RI 02883 wiring harnesses 1-401-789-1955 Martin Robey Panels, Pool Rd, Camp Hill 011-44-203-386-903 Industrial Estate, Nuneaton, Warks CV10 9AE England Rodney, 2035 Cornell St, Sarasota, FL 33577 1-813-955-5960 used parts recycler SCJ, 3 Elizabeth Ave, Burlington, MA 01803 NOS parts, pre-war to 61 Samplex, 30 Parkview Dr, Succasunna, NJ 07876 201-584-9370 US source for ColourTune Special Interest Car Parts, 1340 Hartford Ave, Johnston, RI 02919 voice: 1-800-556-7496, 1-800-851-5600, 1-401-831-8850 fax: 1-800-672-SICP(1-800-672-7427), 1-401-831-7760 We have parts for your Jaguar, MG, Healey, TR. Good prices. Superb catalog. Parts from XK120 through XJ40 including e-types. Will often meet or beat prices from competitors. S&S Specialties, 108 Sation St, Cumming, IA 50061 1-515-981-9148 NOS, rebuilt and used parts for XK, Mk and E, sheet metal parts Stainless Steel Muffler Corp, 3032 Genesee St, Buffalo, NY 14225 stainless exhaust systems 1-716-893-2116 Terry’s Jaguar Parts, 117 E Smith St, Benton, IL 62812 1-800-851-9438 new and used parts for later models 1-618-439-4444 Bill Tracy, Sarasota, Florida 1-813-924-9523 new and repro parts for XK’s Trans Ocean, Dept PDH, 390 Olive Tree Lane, Sierra Madre, CA 91024 Lucas parts jobber, '30 to '76 British cars Welsh Jaguar Enterprises, Steubenville, Ohio 1-800-875-5247 new and repro parts for XK’s and newer 1-614-282-8649 fax: 1-614-282-1913 Catalogue available. (free) The best prices for Jaguar parts that I have found. zrol01@trc.amoco.com (Richard O. Lindsay) Exc. inventory of parts, new and used. Can offer helpful technical advice. PKR@SLACVM.SLAC.Stanford.EDU (Patrick Krejcik) Ed West, 1941H Jan Marie Place, Tustin, CA 92680 1-714-832-2688 new, used, repro parts for earlier Jags Ed west has lots of intresting stuff at very resonable prices and lots of advice. – m_skogs@ix.netcom.com (Matthew Skosberg) White Post Restorations, White Post, VA 22663 1-703-837-1140 restorations, brake and clutch cylinders resleeved XK’s Unlimited, 850 Fiero Lane, San Luis Obispo, CA 93401 1-805-544-7864 new and repro parts for XK’s 1-800-444-JAGS In CA: 805-544-7864 FAX: 805-544-1664 catalog available. ($6.00, refundable first order) “Parts & Service for all model Jaguars from 1948 on” XK’s Unlimited is a good place to send Girling calipers for for piston bore sleeving. -? XK’s Unlimited is good, but is a bit higher than Welch Jaguar. They are also committed to “correct” parts. Additionally, you can call them without a part number. Just be sure that they tell you what is included in the replacement part. - zrol01@trc.amoco.com (Richard O. Lindsay) Good inventory and advice, but pricey. Nice catalogue. Has a restoration shop sleeving brake cylinders in stainless. PKR@SLACVM.SLAC.Stanford.EDU (Patrick Krejcik) XKSS Interiors, Thousand Oaks, CA 91359 1-800-922-XKSS, 1-805-482-4682 interior and trim parts Vicarage Jaguar 1-305-444-8759 % Gables Cats fax: 1-305-443-6443 220 Granello Avenue Coral Gables, FL 33146 vicarage@ix.netcom.com (alt. vicarage@paradise.net) http://paradise.net/vicarage Vicarage says: If one is in need of specialized or hard to find parts we will have them. In addition we do offer the unique Vicarage upgrades and enhancement products for all post war Jaguars. Zimmer, Bob 2675 Stoney Brook Rd, Orchard Park, NY 14127 1-716-652-7909 XK parts End of jag-lovers-digest V2 #397 ******************************** Return-Path: @owner-jag-lovers-di1 Received: (from majordom@localhost) by ekeberg.sn.no (8.7.5/8.7.3/on4) id for jag-lovers-digest-out; Wed, 2 Oct 1996 23:36:25 +0200 (MET DST) Date: Wed, 2 Oct 1996 23:36:25 +0200 (MET DST) Message-Id: 199610022136.XAA10798@ekeberg.sn.no X-Authentication-Warning: ekeberg.sn.no: majordom set sender to owner-jag-lovers-digest using -f From: @owner-jag-lovers-di1 To: jag-lovers-digest@sn.no Subject: jag-lovers-digest V2 #398 Reply-To: jag-lovers@sn.no Errors-To: @owner-jag-lovers-di1 Precedence: bulk X-Newsgroups: mail.jag-lovers-digest jag-lovers-digest Wednesday, 2 October 1996 Volume 02 : Number 398 Bulb Failure Light XJ6/XJS Re: XJ6 SIII Speedo Error RE: Sir William, noisy AC. Re[2]: XJ6 SIII Speedo Error XJS cough & Sputter oil pressure Wanted XJ6 SIII, XJ40 RE:XJ40 vs SIII (quite long) Surviving California Smog Check Re: XJS V12 radiator flush Re: Alzheimers/Aluminum (no Jag content whatsoever) RE:XJ40 vs SIII (quite long) Bulb Failure Light XJ6/XJS Vintage Restorations, Kent, UK Re: Alzheimers/Aluminum (no Jag content whatsoever) 1994 vanden plas Re: Alzheimers/Aluminum (no Jag content whatsoever) Re: Vintage Restorations, Kent, UK XJS A/C Servo Connections From: “Tracy A. Ferrell” tracy@brooktree.com Date: Wed, 02 Oct 1996 08:20:32 -0700 Subject: Bulb Failure Light XJ6/XJS Jim Isbell wrote:
unless it is the detector unit itself that is out.My XJ6 manual (Haynes…?) says that the clearance lights front and back and
the tail lights are monitored.Strangely, the Haynes manual for the XJS seems to indicate that only the
Brake lights are monitored.Does anyone have the true information? And, is there a way to test the
I’ve had the bulb failure light come on on my '84 XJ6 for bad side markers
and tail lights. However, I’m sure the license plate lights are also in the
circuit.
Since the bulb failure circuit is measuring the difference in current
between each side, it’s important that you match wattage between sides.
Tracy A. Ferrell tracy@brooktree.com in Sunny San Diego
Date: Wed, 2 Oct 1996 10:33:13 -0500
I don’t know about your area, but around here (Northern Virginia, USA) you can
take your car to a number of places to get your speedometer checked/calibrated.
My wife took her Honda to a local Jiffy Lube and had hers done. (Jiffy Lube is
a chain of drive-in oil change / lube job places. In and out in minutes. I was
astonished that they did something like speedometer checks.) They gave her a
neat little computer generated sheet showing speedo versus actual speeds.
Author: Bob Kerr bkerr@primenet.com at Internet
Date: 10/1/1996 10:19 PM
BobK
Arsenal Gunners FAN
Date: Wed, 2 Oct 1996 08:11:09 -0700
I had a similar problem, (A heavy build up of frost on the return pipe)
It was the temp sensor on the evaporator which wasn’t working, causing
the compressor to be on all the time. Before you spend any money, you
might just want to check that the compressor clutch is cutting in and
out as it maintains a sensible temperature, rather than trying to freeze
the pipework solid.
Graham
-----Original Message-----
From: Dawson, Barrie [SMTP:dawsonb@btcec3.agw.bt.co.uk]
Sent: Wednesday, October 02, 1996 3:22 PM
To: ‘jag-lovers-owner’
Subject: RE: Sir William, noisy AC.Jim,
it.Barrie Dawson
1985 series III SovereignFrom: jag-lovers-owner
To: jag-lovers
Date: 30 September 1996 16:24The voice interview I mentioned on the pronounciation of Jaguar was an
he said Jag-u-were.I have a question about noise from freon flow in an AC system. I just got
Never knew why.Is this curable? The AC works perfectly, its just that you can hear the
shut the car off and the freon goes toward equilibrium.Jim
Nance O’Neil
Date: Wed, 2 Oct 1996 11:24:21 -0500
Subject: Re[2]: XJ6 SIII Speedo Error
This is a Mime message, which your current mail reader
may not understand. Parts of the message will appear as
text. To process the remainder, you will need to use a Mime
compatible mail reader. Contact your vendor for details.
- –IMA.Boundary.145172448
Content-Type: text/plain; charset=US-ASCII
Content-Transfer-Encoding: 7bit
Content-Description: cc:Mail note part
Easiest way is with a decent highway that has mile/km markers and a
stopwatch. In the US there are many locations that are identified by signs
as “measured miles” specifically so people can check their speedometer and
odometer. There happens to be one a couple of miles from my office. If
you use standard mileposts (kmposts?) you need to go a reasonable distance
for averaging since the highway department isn’t to fussy about exact
location. The measured miles, on the other hand, are accurate.
Call your local bureaucracy, they may have measured distances marked off
for you. Another handy set of markers available in many locations are the
stripes painted across the road used by airborne police to measure your
speed. If you have aerial cops, you should be able to get distances
between stripes and a nearby location from your local police station.
MikeC
Author: charles daly cdaly@passport.ca at Internet
Date: 10/2/1996 2:17 AM
'62 E-Type, ots
- –IMA.Boundary.145172448–
Date: Wed, 02 Oct 1996 09:14:49 -0700
Subject: XJS cough & Sputter
Here I am again. I’m not having good luck with my cat. Heres the
scenario. The engine is warm from driving, the car is parked for 30
minutes, I try to restart it and it ignites but won’t idle. I have to
rabbit foot the accelerator for a minute or two. Along with this problem
my car is prone to overheat slightly from city driving. Any connections
between the two? I’ve had the car one year and already put $2000.00 in
repairs. I’d like to see my mechanic a little less often if possible.
Jana treadwel@ieway.com
Date: Wed, 2 Oct 1996 12:26:55 -0400
Subject: oil pressure
My recently rebuilt 4.2 E type has 45 psi cold, 40-42 hot at 3,000 rpm with
10-40 castrol. Outside temp 50-70 F
The builder predicted 50 - 55 psi.
What pressure should a "new motor " have ? ( Stock, street driven)
The shop manual says 40 psi at 3,000 but doesn’t specify oil weight
The racing prep factory manual says 40 psi with 40w oil
This seems to low
How about a poll of members ? Just hit " reply " and the number of psi you
have
Thanks
Doug
1966 E-Type
Date: Wed, 2 Oct 1996 11:47:19 -0500
without CD/radio.
Mareks Malnacs.
You are going to be very disapointed in your purchase.
You mention color, power windows, and audio accessories. These are not the
things you should be concerned about when buying ANY car, Jaguar or not.
You are not addressing the items that need looking at. I suggest you
purchase a new Japanese car with the color of your choice and make sure it
is dealer maintained.
JIM I.
1879-1919
Date: Wed, 02 Oct 96 18:19:48 -0700
Subject: RE:XJ40 vs SIII (quite long)
The current debate on the merits of the XJ40 & SIII is good to read and for my
money the SIII has it. I can only give a view based on my experiences of SIII
ownership and a friend who owns an XJ40. I have a 1985 SIII Sovereign, my
friend has an XJ40.
My SIII has 76500 miles behind it and a full Jaguar service history. Since I
bought it in 1994 I have done 16500 miles the like of which I have never
experienced before, I tell a lie 250 miles in a Rolls Royce Silver Shadow II.
When I bought the car there were several things wrong that needed attention:
i) Steering & front suspension needed some bushes and minor castor/camber
adjustments.
ii) Rear suspension trunion bearings.
iii) Replacement radiator and pump, originals clogged with BARRS LEAKS.
iv) Exhaust system, 11 years isn’t bad for an exhaust.
v) Recharging of A/C and a new compressor/condenser.
vi) Replacement headlamp wiper motors.
vii) Replacement gearbox reverse gear failed.
The interior has no noticeable wear and apart from mild chips/scratches the
paint work is perfect.
My friends 1990 XJ40 owned for 1 year however has 55000 miles on the clock and
full Jaguar service history. The ride in this car is now also typical of all
Jaguars but my friend is far from happy with it. He has had nothing but trouble:
i) New diff assembly and pair of driveshafts.
ii) New shocks all round.
iii) New front discs and 3 sets of front pads.
iv) 1 complete exhaust and an additional set of rear boxes.
v) 2 new drivers door exterior handles, the others snapped off.
vi) New drivers door mirror, motors packed up.
vii) Complete new A/C system.
viii) New bonnet and boot lid, originals rusted away.
ix) New front and rear screen seals.
x) Complete respray and not that good either.
xi) Replacement radiator, his also clogged with BARRS LEAKS.
xii) Replacement gearbox, front brake band failed.
The interior is also very good but then the car has been off the road for some
time.
I grant you there are many advances in the motor industry that the XJ40 holds
over the SIII but then the SIII is using the lessons of the past to deliver a
better product. I feel that Jaguar learnt a lot during the SI and SII, all of
which they put to good use in the SIII. But when Ford took over they tried to
put into practice a start from fresh approach on a save money basis. There are
a lot of features that are designed to improve service times but these are at the
expense of quality.
The main failing at first glance must be the styling or should I say lack of it
in the XJ40. Where are the curves, gone, given up to sharp corners and square
head lights. Sorry guys but the XJ40 is really ugly. The best thing about the
XJ40 is they kept making the XJS and SIII V12 to take our minds of it. Well what
now, the new XJ6 and the XK8, only time will tell at least the styling is back.
Barrie Dawson
Date: Wed, 2 Oct 1996 10:47:55 -0700
Subject: Surviving California Smog Check
Group:
Brief Background
As most of you here in the US are aware, California is out to get all cars
older than 1990 off the road. This policy is being implemented by tightening
(reducing) the amount of emissions allowable. (Cars are checked every 2
years and also can not be sold without a valid smog certificate. This rule
applies to all cars produced after 1965.) Failure results in you being
unable to renew your vehicle registration, simply put: no registration = no
drive. Lots have been written about this, but that’s a different story.
My Story
I recently purchased a 70 E type and needless to say the DPO thought it
would pass our new smog test-wrong!! The car was identified as a “gross
polluter”, this is very bad and subjects you to all sorts of bs. It took me
4 weeks to get it all straitened out and finally get the car through the
system. Fortunately the PO had to pay the bill.
My suggestion to all of us here is California is to have the car “pretested”
and don’t depend on the fact that “the car passed last time”. Older Jags are
very prone to failing the test, especially if they have been tuned to “run”
rather than “pass” the emissions test. The tightened standards will make it
even harder to pass.
Resolving this problem with the emissions test could not have been done
without the assistance of the folks at European Stables in Redwood City, Ca.
They took the time to work with me and very much went the extra mile (or KM
depending on your location). They really understand Jags and have a
commitment to helping their customers. Prices are also quite fair.( I have
no vested interest in them) It seems like we are always looking for a shop
that does quality work.
I apologize to those of you outside of Norther California, but thought this
experience was worth relating.
There has been some talk of suspending these new smog test regulations, but
whose to say. I hope so, but won’t hold my breath.
Stephen Patchel
Consulting Practice Leader
Radford Associates
voice: 408-321-2540
fax: 408-321-2650
Date: Wed, 2 Oct 1996 13:57:03 -0400 (EDT)
My 82 XJ-S has a radiator drain that you can open from the top. Look for
a metal rod over on the upper right side of the radiator. It might be
partially obscured by other stuff in the area. Twist the rod handle and
that’s it. Of course, often the best way to drain things is by pulling
the lower hose. I do this from the top, taking an extra 3 minutes to pull
the expansion tank, which by the way has no way to drain it to the bottom
(so you might as well pull it anyway). (I also brazed in standard
plumbing fittings to the expansion tank so that I can drain it without
pulling it from the car.)
John
Date: Wed, 2 Oct 1996 14:41:09 -0005
Subject: Re: Alzheimers/Aluminum (no Jag content whatsoever)
It has not been proven, but such “proof” is not what one should be
looking for. By the same token, tobacco has never been proven to
cause lung cancer! A better question might be: has aluminum been
proven to NOT cause Alzeimers. For my money, all my aluminum pots
and pans were donated to Goodwill several years back.
– Kirbert | If anything is to be accomplished,
| some rules must be broken.
| - Palm’s Postulate
Date: Wed, 2 Oct 1996 12:13:27 -0700
At 06:19 PM 10/2/96 -0700, you wrote:
…Sorry guys but the XJ40 is really ugly.
Barrie Dawson
Is it? Well, the ladys still seem to like it! Lexus and Mercedes owners
still give angry looks toward me occasionally (I guess they wanted a Jag,
but didn’t want Jag maintance costs!).
While on the subject, anyone see the CNN news poll about a year or two ago?
They interviewed women and asked what they thought was the sexyist car around.
What did the majority answer? Jaguar, of course! And what car did the news
reports show? That’s right!, a gorgeous late model XJ40 in kingfisher blue
with tan leather, with its owner waving at the camera!
Well, everyone’s entitled to their opinion!
cobac@ix.netcom
1989 XJ40 Vanden Plas (black/biscuit)
Date: Wed, 2 Oct 1996 15:41:43 -0400
Hi Jim,
What are you like! I could have sworn you wrote the definitive XJ6 bumper
book?
Haynes, eh?, who needs 'em.
Date: Wed, 2 Oct 1996 15:41:14 -0400
Subject: Vintage Restorations, Kent, UK
Does anyone have a kind word to say about this bunch?
They are into dashboards and instrument reconditioning.
They are busy - but I don’t know why… They are so damn rude and ‘too busy
to return your call’. Arrogance is no way to keep up a business, so FWIW I
recommend shoving a black mark against them.
Peter Carpenter
1967 420
UK
Date: Wed, 2 Oct 1996 16:29:08 -0400
My understanding was that aluminum was found in the brains of Alzeimers victims
but they did not know if it was cause or effect. I ditched our aluminum pans
too… Not going to wait to find out. But what about all that aluminum dust
from sanding and polishing the dash pots and valve covers on my E-type??? :-/
Maybe one day they’ll find it in my brain…
Mark McChseashedf err McCheaseghfiysdf… what ever
Date: Wed, 02 Oct 1996 15:37:18 -0700
Subject: 1994 vanden plas
I have a 1994 vdp that I have just repaired . It was salvaged but I had
littel trouble and expense restoring it. Now what a beeeeeutifull auto.
My wife has taken it over. She looks so good in it that I’m frightened
to let her out of my sight.(jokeing). I need instruction on replacing
the spent passenger side (right) air bag. I purchased it ($1200 us) and
I would like to install it , there is no electrical connection. Any help?
Also there is a sound (viberating pump type) from right side firewall?
Dealer said ABS (breaks) pump. Is there a cure for this very anoying
loud sound.thanks Paul Martin ,Hoover Alabama USA.
PS: have connection for slightly damaged late model Jags.
sunn46a@prodigy.com
Date: Wed, 02 Oct 1996 17:04:43 -0400
Oh, great! Now I’ll get it!
'62 E-Type, ots
Date: Wed, 02 Oct 1996 16:17:25 -0600
Subject: Re: Vintage Restorations, Kent, UK
recommend shoving a black mark against them.Peter Carpenter
1967 420
UK
I bumped into some of their reconditioned guages in a MG K3 last
year.(literally) Not much room under the dash of one. The guages worked
fine…but I don’t know about their makers!
Hal
Hal Rogers
H.D. Rogers & Sons
Import Auto Specialists
Bossier City LA 71112
(318) 742-3651 voice
(318) 742-5044 fax
Serving Auto Enthusiasts since 1959
Date: Wed, 02 Oct 96 16:34:57 -0500
Subject: XJS A/C Servo Connections
The PO of my '86 XJS had gotten the vacuum hoses
connected with the A/C control goofed up while
trying to repair a problem with the A/C. There
is a black hose and a red hose comming from under
the servo that appear to connect to a green and
a white hose. Does anyone know the correct
connection for these hoses? Also the original
problem is still there. The servo “jogs” back and
forth rather than attaining the desired posistion
and stopping. I replaced the A/C control amplifier
(expensive!) but this had no effect. Any ideas
where I should look next. It appears that if one
of the temp. sensors where bad the servo would run
to one extreme or the other and then stop. Is it
possible that this is caused by a bad servo
feedback pot?
Many thanks to the group for your help.
Phil
End of jag-lovers-digest V2 #398
X-UIDL: 01dc77815515b368cc73219ad74e8342
id for jag-lovers-digest-out; Thu, 3 Oct 1996 04:13:52 +0200 (MET DST)
Date: Thu, 3 Oct 1996 04:13:52 +0200 (MET DST)
Message-Id: 199610030213.EAA28502@ekeberg.sn.no
Subject: jag-lovers-digest V2 #399
Precedence: bulk
Status: RO
X-Status:
jag-lovers-digest Thursday, 3 October 1996 Volume 02 : Number 399
1994 vdp
Re: Jags at Bathurst
Re: Alzheimers/Aluminum (no Jag content whatsoever)(Bad news)
XK8 Screen Saver
XK-8 (I came, I saw, I left) (long)
Re: TWR JAGUAR XJS’s AT BATHURST (1985).
Re: XJ-S help needed
Starting Problem
XJ40 - Brake accumulator
RE: TWR JAGUAR XJS’s AT BATHURST (1985).
Re: XJS cough & Sputter
XJ6 bulb failure light
A caution for Sydney Jag owners (XJ6 in particular)
Date: Wed, 2 Oct 1996 17:04:47, -0500
Subject: 1994 vdp
Sorry I’m new at this . May have sent several times.
had
little trouble and expense restoring it. Now what a beeeeeutifull
auto.
frightened
to let her out of my sight.(joking). I need instruction on replacing
and
help?
Also there is a sound (vibrating pump type) from right side fire wall?
Dealer said ABS (breaks) pump. Is there a cure for this very annoying
snuu46a@prodigy.com
Date: Thu, 3 Oct 1996 08:44:34 +1000
Subject: Re: Jags at Bathurst
Robert,
Our club has two VHS tapes that cover Jags at Bathurst. I haven’t seen them
yet but email me if you are interested and I’ll get more info to you.
Derek Hibbs
Canberra, Australia
77 XJ-S
Date: Thu, 3 Oct 96 8:47:47 +60000
Subject: Re: Alzheimers/Aluminum (no Jag content whatsoever)(Bad news)
Ever wondered what they put in anti-perspirant? Aluminium!
Dilemma: Keep your mind or your friends?
Peter Brown
| aluminum pots
| our aluminum pans
| that aluminum dust
| on my E-type??? :-/
Date: Wed, 02 Oct 1996 15:49:03 -0700
Subject: XK8 Screen Saver
Does anyone have the XK8 screen saver. I couldn’t find it on the main
site.
Thanks
Michael P. Neal ASE Master Technician, Jaguar Certified
'93 Ducati 900SS '83 Porsche 944 '85 Jaguar XJS
Home (707) 829-8464 Work (707) 577-0101
http://www.wco.com/~mneal (always under construction:-)
Date: Wed, 2 Oct 1996 14:00:11 -0500
Subject: XK-8 (I came, I saw, I left) (long)
<if you get bored, at least skip to the bottom and read the last couple of
paragraphs before you give up.>
Well, the long anticipated day finally arrived yesterday. As a long time
Jag Lover who endured the demise of the E-Type and the disappointment of
the introduction of the XJ-S, and who has patiently waited for a couple of
decades for the introduction of a new “sports car”, my invitation to the
premier showing was burning a hole in my pocket.
The local “launch” featured a BRG coupe, a bright blue convertible, lots of
beverages, hors d’oeuvres, guests and one probable big mistake (more on
that later.)
My initial impression (with a little background first so you’ll have an
idea of my bias.) Many years ago I bought a 59 MGA as my first car. I
looked covetously at the big Healys, and could scarcely dream of a
XK-120/140/150. I was in high school when the E-Type was introduced.
While my classmates read Hot Rod, I was busy with Sports Car Graphic.
After '61 my dreams were recalibrated. The E-Type was the only dream.
Life goes on, and six years out of college I bought my dream, a brand new
Series3 OTS. Shortly after, the XJ-S was introduced. My reaction was
significant disappointment in the styling. Reading all the magazine
articles demonstrated I wasn’t alone. Even the most enthusiastic had no
kind words for the style, the flying buttresses being especially damned.
The years move on and the XJ-S steadily improves in many ways, with sales
rising well here in the States. Meanwhile I harbor no desire to own one.
The looks simply don’t appeal to me. Now it’s 1988. I still have my
beloved E-Type. One afternoon I stop by the Jag dealer’s parts department
to pick up a fuel filter and a couple of gaskets for the E (naturally.) On
the way out I walked through the showroom and was stopped dead in my tracks
by a Grenadier Red XJ-S convertible. (The “factory authorized” Hess &
Eisenhardt version.) It looked completely transformed. Once again, an
instant reprogramming of my automotive aspirations. I drove straight home,
held up a gasket, and said “Honey, see this? This is the most expensive
gasket you will ever see!” Yep, the garage definitely is more symmetrical
with a Jag V-12 on both sides.
So now it’s 1996. The XK-8s are beautiful vehicles, the fit and finish is
better than any Jag I’ve ever seen. But they just don’t tug at my heart.
The exterior styling is attractive, but kind of bland. The front fenders
(wings) hint at previous Jags, as does the hood (bonnet). I guess the
grill opening is supposed to hint at the E-Type, with its oval shape and
horizontal bar. But it is significantly marred by two large rectangular
rubber protrusions. Once you get past the A pillar, its basically just
another '90s streamlined bean. No matter where I stood, it never shouted
“I’m a Jag and proud of it.” Virtually every other Jag, except for the
XJ-40 (sorry guys), is readily identified as a Jag from a distance by
people who can’t tell the difference between a Ford and a Chevy.
Strangely, I liked the looks of the coupe better than the convertible (this
from died in the wool folding top person.)
The engine compartment is strangely barren when you open the hood. In the
center is a tangle of black intake runners, surrounded by cosmetic engine
covers/shields that hide all the wiring and plumbing. Nothing really to
look at.
My reaction to the interior is mixed. Like any recent Jag, it is
scrumptious. Beautiful, supple leather, shining veneer, real analog
instruments, shining veneer, a neatly organized radio stack, shining
veneer, a ton of switches and lots of veneer. Did I mention the veneer?
Oh, yes. There’s plenty of it. Enough for several XJ-6s. Way to much of
it, in fact. The center three instruments (clock, oil pressure and
battery) almost look lost in the midst of this huge plank of wood that
extends the width of the car. The main binnacle has a centered
speedometer, with a smaller tach to the left and a tach-sized combo fuel
level and temperature on the right. All the instruments are legible and
traditional white on black. It would be much better if the tach was the
same size as the speedometer. The others are a bit small for their
distance from the driver and would be more legible if they were angled
toward the driver’s seat. The seats are very comfortable, and fully
adjustable thanks to lots of electric motors. The XK-8 also has two
position memory, so the seats, mirrors and tilt/telescope wheel can be
preset for two drivers. The tilt wheel automatically rises out of the way
for entry or exit (there is a switch position on its adjustment knob to
disable this feature.) The wheel is the same basic combo wood and leather
wheel on the high end XJ-6s. I still hate it fiercely. The rear seat in
the coupe is the functional equivalent of the XJ-S coupe’s rear seat. The
rear seat in the convertible is a cruel joke. They could probably be sued
for advertising it as having more than two seats. The boot that covers the
convertible top when it’s down can only be removed by opening the trunk,
something I found a bit odd. One convertible in the lot had its top up.
It fit very nicely and was quite taut. The car was locked, so I couldn’t
get a good look at the inside of the top.
Continuing back, the trunk (boot) is fairly spacious. It looks larger than
my XJ-S trunk. There is a pull-up panel covering a full size spare fitted
in a sunken well under the trunk floor. Also in the trunk is a monstrously
big battery. Looks like it belongs in a large diesel truck. Not likely
you’ll find a replacement anywhere handy. There is also a large box that
contains a lot of relays, fuses and other electrical/electronic goodies.
Close the lid and the rear looks like half the current Fords. Not as oddly
oval as a Taurus, but sort of generic jellybean.
So, the overall is:
Plus: Flawless fit and finish. All the controls are easily reached from
the driver’s seat. Everything you touch seems to have a nice “feel”, it’s
mostly wood or leather. The controls and switchgear seem more harmonized
in feel than my XJ-S. They are both very attractive cars. In many ways,
they look better in the sheet metal than they did in pictures. I’ll go
back tomorrow if I get a chance to drive one and see it outside without the
crowd.
Minus: Generic styling. While it looks attractive, I wonder how it will
“wear.” When I park my eight year old XJ-S it still regularly draws
admirers. When I park my twenty-two year old E-Type it draws a crowd, as
will any XK. I often see people stop to admire XJ-6s (series1-3). Ten or
twenty (or two) years from now will anyone even pause to look at an XK-8?
Or will it be just another bean?
Too much wood. Half the vertical height of wood would be more than enough.
Very large black plastic A/C outlets mounted high in the center don’t help.
What I’d really like: a modest restyling outside to get rid of the rubber
things in the front opening (offer a dealer installed E-Type AAMCO bar for
people who parallel park in the city) and inject some genuine Jag styling
cues. Maybe a touch of gentle upwards rounding of the rear fenders to hint
at the E-Type. Like they hinted at it in the front. Introduce an XK-8S
sports model. Throw away all the electrically adjustable stuff, I never
move my seat anyway. Keep the power windows and exterior mirrors only.
Toss the rear seat from the convertible. A simple carpeted shelf, possibly
with a locking bin like the early XJ-S convertibles would be lighter,
cheaper and much more functional. Put in a 5 or 6 speed manual, a simpler
console (you don’t need a leather covered hydraulic ashtray or cup holders,
if you really want a sports version you don’t smoke while you drive and the
cups would never stay in the holder anyway.) Anyway, you get the idea.
Finally (at last) the big mistake:
Featured with the two XK-8s was a “never-been-titled” '74 E-Type OTS. In
fact, the exact same car that was sitting on the showroom floor 22 years
ago when I purchased my E.
Why a mistake? Because half the crowd spent more time looking at the
E-Type than the XK-8s. I can’t begin to tell you how many times I heard
people say they’d rather buy the E than the -8. Wives were dragging
husbands over, asking why not look at this one? Husbands were dragging
wives over, saying how that’s the Jag they always wanted. It was kind of
funny and sad at the same time. In many ways the E-Type stole the show.
MikeC
Date: Thu, 03 Oct 1996 09:59:56 +1100
The Jags gave Bathurst some international class, it was a memorable race. I
would love to seem them back again.
This Sunday all we will see is Ford Falcon and Holden Commodore V8’s doing
battle on the Mount. A pride of Jaguar V12’s would really add some spice to
the “Great Race”.
Rick Thomas.
Date: Thu, 3 Oct 1996 09:07:31 +1000 (EST)
Subject: Re: TWR JAGUAR XJS’s AT BATHURST (1985).
G’day from Oz,
I am an ex-Bathurst resident and watched the 1985 race live from the
top of Mount Panorama (the best spot IMHO). The A. Hahne / J. Goss Jaguar
XJS won this race. I do have a video of the race - Channel 7, the
Broadcaster also market each year, a video containing the highlights from
each race. As far as I know, these are still available and I could obtain
details of the availability etc. if necessary.
P.S. You can get information (both curent and historical) on the ‘AMP 1000’
(as it is now known - another change of sponsor!) on the Web at :
http://www.ozemail.com.au/~ardc/
cheers,
Jim Ellis.
(1963 Daimler 2.5 v8 .)
Subject: Jags at BathurstWhat was the year the XJS won (I seem to remember it did once).
off. Beautiful stuff - anyone got a tape?Robert Bradley
Jim Ellis
Internal Auditor
University of New England,
N.S.W. 2351.
AUSTRALIA.
'phone: (067) 733497;
[national: +61 67 733497;]
fax: (067) 733314;
e-mail: jellis@metz.une.edu.au
Date: Mon, 30 Sep 1996 12:15:44 GMT
Subject: Re: XJ-S help needed
In message 199609291920.OAA17525@mail.utexas.edu JISBELLJR@mail.utexas.edu (James A. Isbell) writes:
- What is the effect of the air cleaners being mounted backwards in the
housings? When I removed them I noticed that the PO had them installed
backwards (with the “front” arrow pointing to the rear). Maybe he drove in
reverse alot.
There are blanking plates for backfire protection (?) on the back. Two
two different types of air cleaners exist with the blanking plate on the back
in different positions dependent on whether your car has ABS or not. On the
ones with ABS, the filter housings are moved towards the front of the car
because one of them would otherwise foul the vacuum reservoir/pump assembly
for the brakes.
Get air cleaner elements which, when fitted, will have the blanking plate
exactly over the hole of the intake. Perversely enough, this apparently
allows the engine to breathe better - the fuel consumption of mine went
down by about 1l/100km after fitting the correct filters correctly.
Stefan Schulz
jaguar@suaviter.demon.co.uk
Date: Wed, 02 Oct 1996 17:57:54 -0500
book?
The Haynes manual is not much good, but it does have pictures and 70% of the
time they are right. Thats why I wrote the XJ6 Book, to correct some of the
deficiencies of the Haynes Manual. The Jaguar manual is not much better
than the Haynes manual. Both have their failure modes, but they are a start
when nothing else works.
Besides, where do you think I got the RIGHT answers, not from the manual I hope?
Jim
Nance O’Neil
Date: Wed, 02 Oct 1996 20:32:11 -0700
Subject: Starting Problem
I have an intermitent starting problem with my 82 XJ6 SIII 4.2. On
average, in about 1 in 15 starting attempts all I get is a hum (fuel
pump?). After 1 or more retrys, with sometimes wiggling a battery cable
or relay wire, it starts and runs fine. I have cleaned and tightened
the battery connections including the ground to the body, engine to body
ground and also the starter/solenoid connections. I tested the ignition
switch (when it was in a “no start” condition). I tested the inhibitor
switch per the Haynes manual. I replaced the negative battery cable and
replaced the starter with a rebuilt one (2 weeks with no problems after
this; I thought it was solved). The battery was replaced last winter.
This has been going on for about 10 months.
What other part should I replace that doesn’t need to be? Starter
relay?
Any help would be greatly appreciated!
Date: Thu, 3 Oct 1996 00:42:05 GMT
Subject: XJ40 - Brake accumulator
Michael: The accumulator is located under the RHS of the car near the
front. It is in unit with an aluminium block containing two switches - the
low pressure warning switch and the charge switch. Two hydraulic tubes
connect into the aluminium block and the assembly is anchored by a steel
clamp around the accumulator.
First, it is probably a good idea to disconnect the battery earth lead and
the book says to do that. Next, pump the brake pedal about 30 times to
fully discharge the accumulator - the pedal should go hard. Under the
bonnet (hood) in the vicinity of the air conditioner’s drier bottle (that’s
the thing you check to see if the air conditioner needs recharging) you will
find an electrical connector, with 4 leads coming out of it. Double check
that you have found the one with the leads going down to the accumulator
assembly. Cut the plastic ratchet type wire tie that is holding it in place
and disconnect the connector. Feed the lower half of the connector down to
where you can get hold of it from under the car. Now jack up the front of
the car about 6 inches and ensure that it is safe to get under. From under
the car, first thoroughly clean up around the hydraulic tube connections to
the accumulator’s aluminium block (in this job, cleanliness comes before
godliness) disconnect the two tubes (after first noting how far the nuts
screw into the block, for reference in re-assembly) and move them out of the
way, but avoid bending them as that will make the re-assembly more
difficult. Little or no oil will escape. Note that there is a bracket
which one of the tubes goes through in connecting to the aluminium block.
Loosen the accumulator clamp bolt and it will be no problem to remove the
assembly. The rest is the way it looks, with a good filter wrench being as
good as anything to remove the old accumulator from the block and tighten up
the new one, but be very careful to avoid any possibility of damage to the
aluminium block. Because of the way the assembly is held in position on the
car, there is no danger of the accumulator unscrewing while in service.
Before continuing, it is not a bad idea to drop a blunt probe down through
the hole into the old accumulator and see how far it goes. I’m not sure how
far it should go in a new accumulator, but on a blown one it will probably
go right to the end, indicating that the bladder has blown. Reconnecting
the tubes can be a little awkward, with more than a fair chance of cross
threading. The threads are fine and it’s not easy to see what you are
doing. Any sign of resistance early in tightening is almost certainly an
indication of cross threading, so undo and start again. On re-assembly it
is easiest to not fully tighten the clamp bolt holding the accumulator,
until the hydraulic connections are nipped up - you may need to jiggle the
thing a little to get the nuts started in the right direction. Good luck
and I apologise if I have overdone the minor instructions. The job is quite
easy and should not take more than about half an hour if all goes well. Alan.
Date: Thu, 03 Oct 1996 11:02:03 +1000
Subject: RE: TWR JAGUAR XJS’s AT BATHURST (1985).
All,
I was born and bred in Bathurst. Perhaps that’s what started my interest
in cars…
My wife and I went to the big race last year. I was really disappointed
that they only have the V8s in the race now. It found it a lot less
interesting than it used to be.
A few years ago there were cars entered from all over the world, and in
several classes now we only have Australian meat-head V8s. I think they
have ruined the essence of the event.
My suggestion - enter the 2.0L super tourers and allow international
entries such as Jaguars (well, especially Jaguars!).
I wonder if they would allow a Jag with a 307 chevy? - Sarcasm.
Chris Sleeman
c.sleeman@praxa.com.au
PS Jim - thanks for the location of the web site
Date: Wed, 02 Oct 1996 21:52:50 -0500
Subject: Re: XJS cough & Sputter
between the two?
More specifics of the vehicle would help in giving feedback.
It is possible that the overheating is driving the water temp sensor
to shut down the pulse width from the ECU. Pumping the accelerator
allows running on the throttle change pulses untill water circulates
to cool down the temp sensor. Possibly flushing the cooling system,
checking for obstructions to air flow, and assuring the overtemp fan
is functional will elliminate the overheating and the related poor hot
start.
Hope this helps,
Bob Johnson
XJS, XJ12L, XJ50
Date: Wed, 02 Oct 1996 21:57:52 EDT
Subject: XJ6 bulb failure light
If the bulbs are OK check the wiring - if it’s cutting in on acceleration
perhaps there’s a wire that’s loose and losing contact. The bulb failure
also checks ALL your bulbs (or at least it does on my 84 XJ6) so maybe
its the number plate light or a blinker.
John
we have a 90 xj6 that has a bulb failure light that comes on most times
brakes are applied. installed all new factory bulbs in rear of vehicle an
light still comes on. also light comes on at times when you acceel. any
thoughts???
Level 1, 29-57 Christie St.
St Leonards NSW 2065
Ph: +61-2-9937-8063 Fax: +61-2-9937-8100
Mobile +61-419-617-619
Date: Wed, 02 Oct 1996 20:52:09 -0500
Subject: Re: 90 xj6 bulb failure light
IBVILLIN@aol.com wrote:
we have a 90 xj6 that has a bulb failure light that comes on most times when
brakes are applied. installed all new factory bulbs in rear of vehicle and
thoughts???
A similar problem on my '88 XJ40 was due to cracked solder joints in one
of the brake light/signal light control modules, located just in front
of the rear light housings behind the carpet. I resoldered each joint
on the circuit board (took about 10 minutes per module) and this fixed
the problem.
Steve Coleman
1987 XJ6 x2
Date: Wed, 02 Oct 1996 22:13:29 EDT
Subject: A caution for Sydney Jag owners (XJ6 in particular)
As a word of warning for those who are looking for good jag mechanics in
Sydney - Cremorne Prestige in Artarmon,Sydney, shouldn’t be your first
point of call. The quality of work HAS been GOOD, BUT following my last
visit, I’m convinced that they aren’t playing square with me (and
presumably the rest of their customers) I had my XJ6 engine rebuilt by
them (although I’ll probably never know whether it really needed doing).
At the end of the 1000km run in period it took it back to them to have
the head tightened and the oil changed. I mentioned that since the work
was done there was a transmission fluid leak (not previously there). They
told me when I picked up the car that they’d “tightened the transmission
up but that the leak was probably because the power steering pinion seal
was leaking”
I KNOW that can’t be right because the leak was evidencing itself near
the bell housing…a little far back for the power steering seals to be
the cause (unless there’s some really weird physics happening under the
bonnet of Jags).
So I’d suggest if you’re going to use them only do so if you’re really
knowledgeableabout what you want - there prices do appear to be
reasonable but if you can’t trust them…
John
End of jag-lovers-digest V2 #399
id for jag-lovers-digest-out; Thu, 3 Oct 1996 17:10:47 +0200 (MET DST)
Date: Thu, 3 Oct 1996 17:10:47 +0200 (MET DST)
Message-Id: 199610031510.RAA02086@ekeberg.sn.no
Subject: jag-lovers-digest V2 #400
Precedence: bulk
jag-lovers-digest Thursday, 3 October 1996 Volume 02 : Number 400
Re: XK-8 (I came, I saw, I left) (long)
RE:XJ40 vs SIII
Currency Conversion (Very Little Jag Content)
XJ-S Book Size
re: A caution for Sydney Jag owners (XJ6 in particular)
RE: oil pressure
oil pressure
Re: Starting problems
Re: XK8 Screen Saver
Re: Jaguar specialists on the Web
[XK8] - UK only - Top Gear Reminder
RE:XJ40 vs SIII (the reality)
bleeding brakes
[none]
XK-8 versus Aston-Martin
Date: Wed, 2 Oct 1996 22:53:20 -0400 (EDT)
Subject: Re: XK-8 (I came, I saw, I left) (long)
I’ve been informed that I need to clear yet another space in the
collection. My boss went to the debut. He saw. He left. After placing an
order. I’ll post impressions after a through inspection. It will be a
while, though. Supposedly the car is to be built next week. So, Tez,
if you spot a black-coffee-black convertible coming down the line with
a eastern US destination, how about tieing a coke bottle up inside a
fender cavity for me? :>
Randy K. Wilson
randy@taylor.infi.net
Date: Wed, 2 Oct 1996 23:30:37 -0400
Donald R. Farr wrote"
times when brakes are applied.I’ve had a similar problem with my 91 Sovereign that reappears like a
ghost from time to
time with never a satisfactory answer. I usually “cure” it by
slamming the driver door (I suggest doing this at stop lights, not
while going around a curve at 90mph).I’m all ears to what others have to say.
In my four months of ownership that damned bulb failure light has gone on
over half a dozen times – but four of those were burned out bulbs! I also
have an intermittent connection in the courtesy lamp in the trunk (boot)
which the car insists on telling me about.
Never, however, have I had a false alarm. In every case it has been a
genuine bulb failure or its equivalent.
Other than problems stemming directly from the neglect of the PO, it is the
only hassle the car has given me. (“Wait a while,” I hear you all
saying…)
I can tell you from experience that the license plate, fog lamps, and trunk
courtesy lights are monitored, but not all the time… Fog lamps only when
switched on, for instance. Other lamps have a logic I haven’t figured out.
Robert MacLeay
'90 XJ40 vdp Majestic
“So how come we had 50 choices for Miss America, but only two for President
of the United States?” – A.E. Neuman
Date: Wed, 2 Oct 1996 23:30:39 -0400
Barrie Dawson ranted:
to
are
at the
expense of quality.
For the record, the development of the XJ40 preceeded Ford’s aquisition of
Jaguar by several years. Everyone agrees Jaguar’s quality has improved since
the purchase. This is a result of Ford management, perhaps?
I am satisfied with the reliability of my car, and have no desire to live
with the grief which I hear described in so many of these missives. As for
appearance, I honestly don’t get your worship of the SIII. I always thought
the S1 had the purer lines, especially in the greenhouse. My car impresses
the hell out of people – neighbors I’s never spoken with came by to
congratulate me on its purchase. Good enough.
Robert MacLeay
(formerly) numerous Fords and Lincolns
Date: Wed, 02 Oct 1996 22:17:04 -0700
Subject: Currency Conversion (Very Little Jag Content)
From time to time we bandy about costs of various projects here and since
this is a world-wide group, It’s sometimes difficult to relate the cost
in another country to your local exchange rate. Surf on over to
Currency Encyclopedia | Xe and you can convert any currency to your local
currency in real-time. This might come in handy for those using the
Jag/Daimler Used Parts Exchange.
Date: Thu, 3 Oct 1996 03:15:15 -0005
Subject: XJ-S Book Size
I recently have been having some problems printing my XJ-S book.
Then I installed some more RAM, bringing the total up from 16MB to
32MB – and my printing problems went away. I’m sure there’s a
driver problem somewhere, no size of file should cause system
lockups, it should just start caching. However, I do wonder how far
out into untested ground I am getting; the file is about 1.3MB these
days, and showing no signs of slowing growth. Is there a limit to
MS-Word file size?
Is anybody else having trouble with its size? I got a message from
somebody saying their system froze after they scanned to a particular
page, but I dunno why. I also dunno what I’d do about it; since the
document is full of cross-references, I can’t very easily break it
into multiple documents. And since half the cross-references are to
figures, I can’t easily pull the illustrations out and make them
separate files.
While I may claim to know a thing or two about the XJ-S, I still feel
like an amateur on MS-Word.
| - Palm’s Postulate
Date: Thu, 3 Oct 1996 03:15:17 -0005
Stefan Schulz:
There are blanking plates for backfire protection(?) on the back.
Two different types of air cleaners exist with the blanking plate
on the back in different positions dependent on whether your car
has ABS or not.
Reportedly, the K&N filters for the XJ-S do not have the blank-off,
and therefore the same filter fits either ABS or non-ABS cars. The
K&N filter has fabric between aluminum mesh and is certified as a
flame arrestor for boating applications, perhaps that’s why it
doesn’t need the blank-off.
| - Palm’s Postulate
Date: Thu, 3 Oct 96 17:17:48 +60000
Subject: re: A caution for Sydney Jag owners (XJ6 in particular)
begin 600 attach.Z
M’YV0:=R,>7/&31HZ;URTF7,&@,.‘$"-G$BQHL6+&“N"V&@#!@P0#:"B$&# M!DB1)$V&%"F2!HP:,3C*D$'#AHT:-&..E!	$@8&8,*'4JTZ,0Z<^B$D;,1 M
)LW8*P,4KQ:=2I5±JW<JUJ]>O69&D:'D#1HW+!HH:)+F#!HZ(,24
7’G
MC1PZ:$”<4.'3LS(-ZXF?O&#
B;^;,;9-&CAR[<P[`1$&1%I:RB[(7,X
MS)JYE<^></YZ9LU+D`H",&3ADY;L+XM5.&31[-()Q(:1($1,`Y<,J,\2L8
M!`K=O’U’QCOW<1C.BN7823.&L)PS80S.D9VF>$#5>–$AK,4;N’#:.;6E<.&
M3`K<(-4(1)#QL>!==K’!:UW-.>`M"751AENP)6&8YT0F0)DI,&@
M&XF5$=E2<\V!5’##I1:$&:XQU<9M4R@%&(%G!1>&)')4888=:31&@A)]&<@
M7&$,49F=QR4EP))U6&&&65P!L<;=[QFF6NO_659&5±D1H5Z8’@HH:M_0""
M?$34X!$(9MA%&0B#W6&ECIEEQQF%JKF(GQR48;=;W`E"“,=8Z3’U!UHO`%”
MA/1D5H1U_GIQ!-“/$%$%G’5`=>`A[U11YX6@C`B”%‘!J5IV>;1A5QFI)4&’
M@V/"<=!ME1%I)AFDG7’;@'EF1]UR80149Y6BD2:9A2ZH=81(+`QZ1IJ0<&7
MDD(=H<;:C6K@`AEG04"$P?1P<9K(H#`0Q@QBM$&&9X!D8:W;=3A@L#M>$#
M"%<\YIH.:O$!0KQ;7DB779R===2!KD!6)A,(18GGWYB&.QH:S@)<'^ZTJL&
M@Y8AX:L8T06$+U3Y$'&8+>U`,(0+GHVUQ07.G77KY-%L1=2WF5L8;EY$’
M"Y;UF=_&)!%KUP@Y"$I4V8TEA2]1]H:F&%7G0L"E7/%48=4IQY]KQR9(1’$
M%/L1",(13RALQ!54#&O`O*&R<93/?IKZ6ULL$@‘O=/-<1#-29S0!J:“32=0
MD>C)AI[,E+GH1LX@P-%V’D[.X;3!/>(UMKR0HJ`FT5?64:X8MOUMI87F(9A>
M8Y@BA=”`<+Y7X\2<78J%$C8#@FX.HXPXYD$O<W=+WIK-;M%XPMF%/Y8C
MYK<-1AM3:U!H)I]\Z>D;7"YE3F]@Q7)-ZM_I=`KV5O>.A>!^7H^5PP>P;#&
MW7+4,=EWP<G17:"1GO9\7&A&ZCKN]D],V^U5IO?<86UY"X’XIB;-O4%&F)J8
MOXH4JH@5J#N#X0Q>_$8ON>U-<^LA%O?V%1E6#>9O+J(+B\9$!SED9PZ,F8/<
MBF,&8:6A-%##`HHI#/NP<%%TY’4’#+‘’!=I;VGIL1WW$(?2#%O,C4RU8[X
M5@<X:“Y3??->'D[`&1&<3(`1O%^52GC”%Z06=QK8J-NY;<$7<LS(AR/,)`
MO/U$!2ES2="1DL24"C+)?6HSE4&HQBIT(N#P8KA7T1`KQHMX5!7B"FLD,X
MGKG/+3@2#K?B9,88IO%UTR$#@<;@)'H=1#%L,Q@EL_N<@%>#:SX!E<P$H7
M5(8-U;H6F)9"OQV!24QR1)2[%B&)JFMCVQ8CI_D4LI%PM$XZKN6"D%8!E±
MX0V0BM[9;I.DQA@)#7F06\5<-S$X!=?@%&?)@.6GIT)9C"=(PN#YJ`]C/FI
M;M"IPQGVDA3?&,9G=3A!"$7C)(2`X)CX$TSF6&49/QW(=?C49W.@-$UZ)0])
MUR+#7MAX1C%("BY\AL^15@@$'BLAW.Y(74J1=`P>!-=1SB,M`K^@],S:8
M,Z6C[-DS22UR<'57SUQU\J>TBM:8)07O9A0!MJP820TDT$.6E"#&WP,#>Y+
M2AKF4J+MR:M$TRJ#8)9"AL@X80J)M,]-Z`4%-.@`!“NP00Q:((,6Y”`’,[A!
M"W```QO,8"-&“`,>SIK6M;;UK7&=_E@0\FO$$,II+7UM`@Q@L5:UR56L.
MZ46L%CVLIC-K&8WR]G.>O:SH`VM:$=+VM:]K2H3:UJ5\O:UKKVM;”-K6QG
M2]O:VO:VN,VM;G?+V][Z]K?`#:YPATO<XAKWN,A-KG7R]SF.O>YT(VN==+
MW>I:][K8S:YVM\O=[GKWN^`-KWC’2][RFO>\Z$VO>M?+WO:Z][WPC:]\YTO?
&^MKWOD,!
end
Date: Thu, 3 Oct 1996 09:28 +0100
Subject: RE: oil pressure
Hello all,
my rebuilt E-type engine gives 30-40 psi at idle and 55 at 2000 rpm with=20
20W-50 Castrol (hot) at 15 to 20 deg. C outside temp. 55 psi seems to be the=20=
pressure where the overload valve of the pump opens. Of coarse, the gauge=20
must be calibrated against a mechanical gauge, which I did at 40 psi. I=20
built a small test rig for that so I can do that off the car.
Frans.
My recently rebuilt 4.2 E type has 45 psi cold, 40-42 hot at 3,000 rpm=20
with
10-40 castrol. Outside temp 50-70 FThe builder predicted 50 - 55 psi.
This seems to low
How about a poll of members ? Just hit " reply " and the number of psi=20
you
haveThanks
Doug
1966 E-Type
=20
Date: Thu, 03 Oct 96 09:31:33 gmt
Doug,
3.4 S-Type engine, with Duckhams ‘Q’ 20W 50 oil, has 50-55psi on cold start-up,
40-45 psi on normal hot driving, (1000 - 3000rpm) with 30 psi on a hot idle
(500rpm). This engine still running in. Before rebuild the idle pressure was
down to 15psi, with around 25 hot. The gauge and sender unit are the same.
Iwould always use 20-50 oil in an XK type engine, personal preference.
- Alastair Lauener *
- 1964 3.4 S-Type http://www.sn.no/home/nick/alas.html *
Date: Thu, 3 Oct 1996 10:02:20 -0700
Subject: Re: Starting problems
It sounds like the periode it worked fine was just an accident
I assume your car is an automatic, no stick-shift… Ever noticed that if not
in park or neutral, the starter won’t crank the engine? (Am I stupid? 'couse you
do; you americans are breast-fed and raised with automatic transmissions!)
Anyways, I had some shit happening once. It acted like it was in gear; didn’t
crank. After wiggling about for a while with wires and switches, it was suddenly
OK. This was years ago and has never happened since.
Now however, I’m experiencing a problem with the starter (mentioned before some
weeks ago). Half of the times I start it, the following will happen: I turn the
key and it is like the battery is nearly flat, but it ain’t. I turn the key
again to start position and holds it; first a couple of lazy revs, and then
suddenly it “lets go” and cranks the engine properly. Some guy told me the
problem lies with the starter, but what can be done to fix it, that’s what I
wanna know.
Anyone…?
Cheers,
Bard
______ _ ! Baard Th Hesvik, Telesoft AS
/ _ / _ _ _ / / ! Longhammarvn 7, N-5500 Haugesund
/ // / // /_ / / -/- -/- ! T: +47 52735000 F: +47 52717040
/ /_ / /_ / // / /_ ! E-mail: baard@telesoft.no
Date: Thu, 3 Oct 1996 09:56:48 +0100 (MET)
Subject: Re: XK8 Screen Saver
site.
You can download it from my “Sovereign” page at:
Gunnar
Gunnar Helliesen | Bergen IT Consult AS | NetBSD/VAX on a uVAX II
Systems Consultant | Bergen, Norway | '86 Jaguar XJ6 4.2 Sovereign
gunnar@bitcon.no | http://www.bitcon.no/ | Vicki who? What .sig virus?
Date: Thu, 3 Oct 1996 13:47:41 +0200 (MET DST)
wanna know.
I don’t know the XJ6, but the XJS has a starter relay. If you should have this,
ask someone to give it a little smack when you are cranking or check the
voltage accross the relay contacts
- Matthias
Date: Thu, 03 Oct 1996 13:31:23 +0100
Subject: Re: Jaguar specialists on the Web
Recently there was a post on Service Manuals for the XJ40 available
from the JEC? I have stupidly deleted it - could someone forward it
on to me please?
Mark
Mark Stiles
90 Daimler 4.0
Date: Thu, 3 Oct 1996 14:43:28 +0200 (MET DST)
on to me please?
It can be ordered from Bookspeed. Bookspeed accept orders
by email and have a pretty comprehensive web-site. The
web-site is linked to the main page of the JagWeb.
Nick
Date: Thu, 3 Oct 1996 08:10:28 -0500 (CDT)
and pans were donated to Goodwill several years back.My understanding was that aluminum was found in the brains of Alzeimers victims
Maybe one day they’ll find it in my brain…Mark McChseashedf err McCheaseghfiysdf… what ever
I think I did this too…but, for the life of me, I can’t remember.
Seriously, Jaguar owners have enough gremlins to be paranoid about
without this one.
Larry Lee
Date: 03 Oct 96 09:38:18 EDT
Subject: [XK8] - UK only - Top Gear Reminder
UK Jag Lovers, Top Gear has the XK8 road test tonight.
Regards
From: Michael Powers/TEIR/Thomson Michael_Powers@teir.com
Date: 3 Oct 96 9:55:35
Subject: RE:XJ40 vs SIII (the reality)
Whew!!! I was hoping somebody would send a post that took the
“babe factor” into account when comparing an SIII and the XJ40.
Let’s face it, women like the XJ40 better. Period.
Is there really anything more that needs to be said?
Respectfully yours,
Mike
PS - If there are any women on the list, don’t bother sending any nasty
emails saying I’m sexist, or whatever. You know the truth when you hear it…
cobac @ ix.netcom.com
10/02/96 12:13 PM
To: jag-lovers @ sn.no @ Internet
cc:
Barrie Dawson
Chatham, Kent England
cobac@ix.netcom
Date: Thu, 03 Oct 1996 13:55:54 +0000 (GMT)
Subject: bleeding brakes
has anyone ever tried to bleed the rear brakes on a 1967 E-type series 1
without dropping the tranny. it seems as though i can put it up on jack
stands and do it from underneath without going through the incredible
hassle with the rear suspension. i would just like to check with other
peoples experiences before starting. thanks,
robin cooper
1967 E-type series 1 coupe
1974 E-type series 3 convertible
Date: Thu, 3 Oct 1996 11:26:30 -0400
Subject: [none]
Someone recently suggested you throw your AL pans away because use could
cause Alzeimers. To my knowledge there has never been any statistically
proven link between Al pan use and Alzeimers.
Re: Alzheimer’s and dementia:
I won’t pollute the list with arcane technical arguments on Aluminum and
Alzheimer’s Disease and other dementias. There are three world experts on
this: Donald crapper-McLachlan (CRND, Toronto), Daniel Perl (Mt Sinai, New
York) and William Markesbury (Lexington, Kentucky). The former have data in
favour of Aluminum being involved, the latter has data against it. Their
work is easily accessible in any science library, if anyone has a burning
desire to know more they can contact them or me directly. The bottom line
from all three experts however is that you can keep your aluminum pots and
pans, and more importantly your aluminum engines.
However, I think that the medical literature has missed a novel
syndrome that may bear on this discussion. Every Jag-lover’s spouse can
attest to the dementing effects of Jaguar ownership. It is manifest as
mindlessly frittering away dollars and time while polishing, tuning, fixing
Jags, and then spending even more time nattering about it on the internet.
The cause is UNKNOWN but likely culprits are … organic solvents
(cleaning/polishing), Aluminum intoxication (biting the engine during
frustration attacks), and most likely of all, an inate “consitutional
weakness” (i.e. “bad genes” of jag-owners). … got to go now, feel a
dementia attack coming on!
Peter
'74 XKE V12 Roadster
Date: Thu, 3 Oct 1996 10:17:02 -0500
Subject: XK-8 versus Aston-Martin
After I left yesterday's message about the XK-8 launch, I went home to
discover the latest issue of Road & Track in my mailbox.
Right on the cover is the XK-8, with a promise of a full road test
inside. Next to it (both on the cover and sequentially inside) is the
car it could have been and should have been, the exciting new F-Type!
(ooops, I mean Aston-Martin)
The test of the XK-8 oozed praise from every pore. Some of the things
I dislike the most (e.g. more wood on the dash than in a small forest,
that damned ugly steering wheel) they praised the most. Oh well, if
we all liked the same designs, I guess we would all have the same
model car. Worse yet, they'd all be the same color.
R&T did agree that the stylist quit before he finished the back half
of the car.
The handling was highly praised, with a lot of ink spent on the
suspension, etc. Funny thing though, when I went to the road test
summary page. their previous tests showed the XJR sedan equal to the
exciting new XK-8 on the skid pad (at 0.83g) and the XJR was faster
through the slalom!
Next was the new Aston-Martin, which most of you will remember as the
ill-fated F-Type. Remember drooling over the "secret spy photos" in
all the magazines a few years ago? Well, the F-Type is alive and well
in Newport-Pagnell! It neatly answers virtually everything I didn't
like about the XK-8.
The instrument panel and console are tastefully appointed with more
than adequate quantities of wood. The instrument cluster is
symmetrical, with equal sized speedometer and tachometer. If you have
access to Road & Track, just compare the interior photos. The A-M
even has a nice, small diameter, leather wrapped wheel. (I wonder if
it will fit in the XK-8?)
The rear styling of the A-M is also a vast improvement. The rear
fenders have just that small amount of upward rounding or bulging I
thought the XK-8 needed to continue hinting at the E-Type.
And best of all, the A-M has a 5-speed! If A-M (not to mention
Ferrari) can sell expensive 2+2 GTs with a 5-speed, why in the hell
can't Jaguar at least have one on their "sports" car as an option?
Use the one in the A-M. It certainly fits in a shortened XJ-S, which
they both are, and it fits the A-M's destroked AJ-6 engine.
Finally, on the last page, R&T has a side by side photo comparison of
the two cars. Lose the A-M side gills and replace its trademark grill
with an E-Type oval and you basically have long- and short-nosed
versions of the same car from the doors forward. The A-M greenhouse
isn't as much like a pillbox as the XK-8's. Advantage A-M. The rear
end is an absolute slam dunk in favor of the A-M.
<sigh> what could have been!
MikeC
End of jag-lovers-digest V2 #400
id for jag-lovers-digest-out; Thu, 3 Oct 1996 22:48:25 +0200 (MET DST)
Date: Thu, 3 Oct 1996 22:48:25 +0200 (MET DST)
Message-Id: 199610032048.WAA02207@ekeberg.sn.no
Subject: jag-lovers-digest V2 #401
Precedence: bulk
jag-lovers-digest Thursday, 3 October 1996 Volume 02 : Number 401
Re; bulb falure
SIII Unleaded conversion
Chrome,
solinoid question
what your car says about you
XK8 in Wall Street Journal
Re: XK-8 versus Aston-Martin
XJS Electrical problems
Re: XJ-S Book Size
Re: solinoid question
Re: '88 XJ-S V12 (UK) steering rack replacement
XJ40 vs. SIII
Re[2]: XJ40 vs SIII (the reality)
Jaguars and babes
20 - 50 oil
Date: Thu, 3 Oct 1996 11:47:02 -0400
Subject: Re; bulb falure
<we have a 90 xj6 that has a bulb failure light that comes on <most times
when
<brakes are applied. installed all new factory bulbs in rear of <vehicle and
<light still comes on. also light comes on at times when you <acceel. any
thoughts???
We have found that when the bulb failure light comes on it is best to replace
ALL the bulb for the car. If this doest work look the lamp modules.
British Car Specialist 2060 N. Wilson Way Stockton Ca 95205
209-948-8767 (fax# 948-1030) HealeyDoc@aol.com
Norman Nock - Tech, advisor, David Nock - Service
Sheila Huggins - parts research
Technical books by Norman Nock avalilable for the MG and Healey.
If you have any questions give Norman or David Nock a call
Date: Thu, 03 Oct 96 16:40:00 GMT
Subject: SIII Unleaded conversion
I have been concerned about the unleaded issue in Europe since I wish to
have some driving holidays there in the future. The German situation looks
pretty grim so I need some advice.
What do I need to do to convert to unleaded running?
How much would a catalyst conversion set me back?
UK prices only please, thanks.
Barrie Dawson
From: Scott Demaret scott.demaret@ioppublishing.co.uk
Date: Thu, 03 Oct 1996 17:00:58 +0100
Subject: Chrome,
Hi.
Does anybody have any experience, good or bad with removing the chrome
cappings around the top of the door frames (XJ6- S2/3), have tried on a old
scrap door, and it seems almost impossible without damaging the chrome…
The next questions is, if they will come off, how do they go back on.
Thanks
Scott
Date: Thu, 03 Oct 1996 12:45:21 -0400
Subject: solinoid question
I am trying to design a set up that will turn on a 50 amp 12 volt
circuit in the trunk when the key is on. I do a lot of special events
for my company and need to install my voltage inverter to provide 120
volts for areas not giving us power. My initial low cost methode was to
have a small relay turn on a starter solinoid but I know a starter
solinoid is probally designed to only operate for a short time. A 12
volt contacter would be ideal but the only place I can find one is in a
A/C parts house for $80 big ones. I need a solinoid that has a secondary
holding coil that kicks on after the main has activated, This lower
current coil would keep the switch open after the main coil did all the
hard work. Pin ball machines use this concept to keep the coli from
burning up when some body holds the flipper in the active state. Wow
talk about a simple question getting dificult. By the way I’m keeping my
car for now, until my car lot guy gets a volvo in to swap even. Frank
Perrick 1985 XJS
P.S I found a Lancia 2000 in rough shape runs and A/C blows cold are
these things worth anything he wants $500 for it.
Date: Thu, 3 Oct 96 10:19:01 -0700
Subject: what your car says about you
Acura Integra - I have always wanted to own the Buick of sports cars Acura Legend - I'm too bland for German cars Acura NSX - I am impotent Audi 90 - I enjoy putting out engine fires Buick Park Avenue - I am older than 34 of the 50 states Cadillac Eldorado - I am a very good Mary Kay salesman Cadillac Seville - I am a pimp Chevrolet Camaro - I enjoy beating up people Chevrolet Chevette - I like seeing people's reactions when I tell them I have a 'Vette Chevrolet Corvette - I'm in a mid-life crisis Chevrolet El Camino - I am leading a militia to overthrow the government Chrysler Cordoba - I dig the rich Corinthian leather Datsun 280Z - I have a kilo of cocaine in my wheel well Dodge Dart - I teach third grade special education and I voted for Eisenhower Dodge Daytona - I delivered pizza for four years to get this car Ford Fairmont - (See Dodge Dart) Ford Mustang - I slow down to 85 in school zones Ford Crown Victoria - I enjoy having people slow to 55mph and change lanes when I pull up behind them Geo Storm - I will start the 11th grade in the Fall. Geo Tracker - I will start the 12th grade in the Fall. Honda del Sol - I have always said, half a convertible is better than no convertible at all Honda Civic - I have just graduated and have no credit Honda Accord - I lack any originality and am basically a lemming. Infiniti Q45 - I am a physician with 17 malpractice suits pending. Isuzu Impulse - I do not give a rip about J.D. Power or his reports. Jaguar XJ6 - I am so rich I will pay 60K for a car that is in the shop 280 days per year. Kia Sephia - I learned nothing from the failure of Daihatsu Corp. Lincoln Town Car - I live for bingo and covered dish suppers >>> Mercury Grand Marquis - (See above) Mercedes 500SL - I will beat you up if you ask me for an autograph Mercedes 560SEL - I have a daughter named Bitsy and a son named Cole Mazda Miata - I do not fear being decapitated by an eighteen-wheeler MGB - I am dating a mechanic Mitsubishi Diamante - I don't know what it means either Nissan 300ZX - I have yet to complete my divorce proceedings. Oldsmobile Cutlass - I just stole this car and I'm going to make a Peugeot 505 Diesel - I am on the EPA's Ten Most Wanted List Plymouth Neon - I sincerely enjoy doing the Macarena Pontiac Trans AM - I have a switchblade in my sock Porsche 944 - I am dating big haired women that otherwise would be inaccessible to me Rolls Royce Silver Shadow - I think Pat Buchannon is a tad bit too liberal Saturn SC2 - (See Honda Civic) Subaru Legacy - I have always wanted a Japanese car even more Toyota Camry - I am still in the closet Volkswagon Beetle - I still watch Partridge Family reruns Volkswagon Cabriolet - I am out of the closet Volkswagon Microbus - I am tripping right now Volvo 740 Wagon - I am frightened of my wife
Date: Thu, 3 Oct 1996 10:51:13 -0700
Subject: XK8 in Wall Street Journal
My car-loving colleague has just shown me the 8-page pullout from
today's Wall Street Journal. Pretty impressive advert aimed at the
perceived target market!
His estimate of the cost for such a feature is between 8 and 16
MILLION dollars! (Pity it is in B&W only, but apparently the WSJ is
not geared up for any colour work) Nice to see Jaguar, backed no
doubt by those Ford people, are taking this baby very seriously and
pulling out all the stops.
Michael Kenrick
Date: Thu, 3 Oct 1996 11:06:33 -0700
Subject: Re: XK-8 versus Aston-Martin
Sorry to Dissapoint Mike…
- ----------------SNIP------------------------
And best of all, the A-M has a 5-speed! If A-M (not to mention Ferrari) can sell expensive 2+2 GTs with a 5-speed, why in the hell can't Jaguar at least have one on their "sports" car as an option? Use the one in the A-M. It certainly fits in a shortened XJ-S,
which
The F-type (AM) and the XK8 are NOT both built on the same chassis. The F
is based on a shortened XJS, but the KX8 design was started from a clean
sheet of paper. Have to agree on why no 5-speed for a “sports” car. Lee
Date: Thu, 03 Oct 1996 13:40:16 -0700
Subject: XJS Electrical problems
I almost hate to send this email. I was working on the cat two nights ago
and had taken the battery out of the car to clean all of the terminals and
posts. Upon re-entry it was set in place backwards. Without paying any
attention I secured the positive cable and proceeded to secure the negative
cable–BACKWARDS. Dumbfounded that I had done this I quickly pulled the
cables off.
The next day I replaced the alternator that had been shorted out by this
mistake. All seems to be good now. But no. An intermittent problem with
the fuel gage. Every now and then when I press the brake pedal the fuel gage
bottems out. Release the breake and it goes back to reading correctly. This
is all with it sitting in my garage. I am not sure the correct term for this
on but I will explain it as best I can. While driving with the RPM between
1500 and 2000 the engine clatters, I think some people call it dieseling.
Above 2000 and below 1500 every thing seems ok. It will only do this while
the engine is under a load. It will not do it in while the gear is in park.
I noticed today that it does not do this until it gets to normal operating
temp.
My guess at the second problem is that it has something to do with the timing
advance, but I know very little about this sort of thing. Any and all help
is greatly appreciated.
Thanks
Jon Jackson
87 XJS BRG (sick kitty)
Date: Thu, 3 Oct 1996 15:00:39 -0400 (EDT)
Yes, I have the K&N filters and this is exactly how they are designed.
John
Date: Thu, 3 Oct 1996 15:07:52 -0400 (EDT)
Subject: Re: XJ-S Book Size
I have printed your Word document off from machines with only 16 MB of
RAM. No problem. Suspect that your problem lies in your system
configuration and/or printer driver setup. If problem persists e-mail me
privately and I’ll have one of our techies talk you through it.
Yes
MS-Word file size?
This is not that big a document and you should not be having problems.
separate files.
This should not be necessary and would make use of the manual a pain.
You do not seem to have committed any sins in the formatting of the
document. Big documents with graphics are subject to cache/swap space
issues. Machine speed and setup and other concurrent tasks affect it all.
John
Date: Thu, 3 Oct 1996 15:20:25 -0400 (EDT)
Subject: Re: solinoid question
Two easy ways to do this. Relays require more power to pick up than to
stay picked up. Wire a resistance in series with the coil that is shunted
when the coil is deenergized. Second way is to use a ‘toggling’ type of
relay – these only require coil energization for a moment to toggle
between contacts open and closed. Surplus catalogs or stores will have
them for a couple of bucks.
John
Date: Thu, 3 Oct 1996 15:29:20 -0400 (EDT)
Wait – I thought that the XK8 is using some XJ-S floor panels. Tez –
what is the straight story???
John
Date: Mon, 30 Sep 1996 12:26:17 GMT
Subject: Re: '88 XJ-S V12 (UK) steering rack replacement
In message 199609301001.MAA05976@turquoise.cray.com mfl@kheops.cray.com (Matthias FOUQUET-LAPAR) writes:
Check if you have a leak at the tower seal once the
rack is out.
Funny you should say that - that’s why I need a rebuilt rack ! Another
“common failure mode” methinks.
Stefan Schulz
Date: Thu, 03 Oct 96 15:19:18 EST
Subject: XJ40 vs. SIII
Roger Peng snips and writes :
The debate goes on:
I like the looks of my
XJ6C, but I’d rather DRIVE the XJ40. It’s the only car that’s made me
think of selling the XJ6C in spite of its beautiful looks, engine, and
ride. It’s primitive by comparison - only its looks have saved it so
far…
The XJ40 is the ugliest Jag…
Indeed, the series III is the most beautiful car in the world,
Alternatively, a `90 or later XJ40 with low mileage can be readily picked up at
Honda prices.
Trade-offs? Mostly just the styling, and more cramped interior space.
It’s still a Jaguar, doesn’t feel Japanese or German. ------
It’s sort of like choosing a woman. Would you rather have a nice dowdy,
hard-working woman who is a good cook and looks after the house but has
no curves whatsoever - or a Cindy Crawford type who can’t cook, doesn’t
do housework, but is a knockout that you can’t keep away from ?
Hey, I’ll take frozen dinners and housework anyday !!
Jim Legge
'85 SIII
'80 TR7
Date: Thu, 3 Oct 1996 14:34:24 -0500
Subject: Re[2]: XJ40 vs SIII (the reality)
This is a Mime message, which your current mail reader
may not understand. Parts of the message will appear as
text. To process the remainder, you will need to use a Mime
compatible mail reader. Contact your vendor for details.
- –IMA.Boundary.711173448
Content-Type: text/plain; charset=US-ASCII
Content-Transfer-Encoding: 7bit
Content-Description: cc:Mail note part
Yeah, I’d say there are a few things left to say . . .
Grow up. If you think some “babe factor” is the most important factor
in automobile selection (or Jags), call back when your acne clears up. -
Do any of you seriously think the CNN poll was asking women if they
found the XJ-6 series III or the XJ-6 (a.k.a. XJ-40) the most sexy? Do you
even think CNN is aware of the difference? Or ever heard of an “XJ-40”?
Much more likely, people were given a list of brand names (e.g. Jaguar,
Honda, BMW, etc.) and asked to identify the one they thought was the
sexiest. No doubt it was Jag by a landslide, but I’ll bet there was quite
a variety of Jags in mind when they answered the question. Depending on
age and nationality they were thinking of everything from XK-120s and the
older saloons right on up. I’d bet many of the older ones were thinking of
E-Types, and a lot of younger ones had an XJ-S in their thoughts. -
I still have the E-Type I bought new in '74 and the XJ-S convertible I
bought in '88. Over the years I have had a number of notes and cards left
on them by women. So what? Who in their right mind would care about the
opinion of some “babe” who leaves notes on cars belonging to total
strangers? Worse yet, would you even think about responding to one? Would
your medical insurance even cover the risk if you did? -
I’m human, so I certainly bask in the glow when a person in the car
next to me lowers the window and makes a favorable comment. When it’s a
nice day and I’m cruising with the top down the chance of a stoplight
comment from a stranger is probably over 75%. I’m also enough of a sexist
pig that the glow is a bit warmer if the person happens to be a woman.
But, while pleasant comments from strangers certainly add to the overall
enjoyment, I’d love my Jags exactly as much if the comments were absent.
Give me a crisp, clear Fall day like today and a few miles of winding road.
Better yet, up on the Blue Ridge following the curves of Skyline Drive
through all the riot of colors the trees provide this time of year. Top
down, all those wonderful V-12 sounds, that is what owning a Jag is about.
Impressing the neighbors and the babes is why Yuppies buy BMWs. -
The women on this list need not respond to your post, I’ll cheerfully
do it for them. You unnecessarily and unfairly offer them insult and
demean their interest in Jaguars. While they are still a minority on this
list, they certainly provide as much insight and useful input as anyone
else. Have you even noticed that the monthly update to the Jag vendor
list, one of the most useful posts, is contributed by a fellow Jag-Lover
who happens to be a woman? In my on and off-line exchanges I have found
that their messages would be indistinguishable from any other Jag-Lover’s
except for the name on the “from:” line. -
Last, but certainly not least, is the original question. I’ve never
owned a Jag sedan of any type, so I feel no obligation to rationalize my
purchase by favoring one over another. Having said that, I can state
without reservation that the XJ-6/12 Series III is obviously the most
beautiful Jag sedan ever produced. The Series II is a close second. As
for the XJ-40 . . . When it was first introduced as a replacement for the
XJ-6 I hated the looks. To me Jag styling has always been about curves and
tradition. Over the decades, Jag styling had undergone a tremendous
change. Nonetheless, all the styling cues remained so that any Jag, sedan
or otherwise, fairly screamed “I’m a JAG” to anyone who even glanced at it.
So along comes this purported Jag that looks like … Well, like a …
Actually, like the box it shipped in. Yes, it was probably the highest
quality Jag sedan produced up 'til then. Yes, it still had the Jag ride,
handling and glorious interior. (Well, the quality and ride were ok once
you replaced the door handles and rear shocks.) But it just doesn’t look
like a Jag. After I got over hating it for not looking like a Jag, I
realized it is actually a quite attractive car. Much more so than most of
it’s competition. (Obvious exception being the Infinity, which had
apparently adopted as many Jag styling cues as possible. It certainly
wasn’t Jag competition in any other way.) Jaguar certainly came to agree,
since one of the major objectives of the latest XJ-6 redesign was obviously
to restore the curves and traditional Jag styling cues. Just in case
anyone missed the point, they drove it home in all the commercials
featuring nostalgic music and older Jags reflected in the paint of the new
car. I notice the XJ-40 never showed up in the reflections!
So, bottom line: Is the XJ-40 pretty? Sure. Best looking Jag sedan? Get
a grip!
Mike C
______________________________ Reply Separator _________________________________
Author: Michael Powers/TEIR/Thomson
Michael_Powers@teir.com at Internet
Date: 10/3/1996 9:55 AM
Respectfully yours,
Mike
10/02/96 12:13 PM
cc:
Subject: RE:XJ40 vs SIII (quite long)
At 06:19 PM 10/2/96 -0700, you wrote:
…Sorry guys but the XJ40 is really ugly.
Barrie Dawson
1985 series III Sovereign
Is it? Well, the ladys still seem to like it! Lexus and Mercedes owners
still give angry looks toward me occasionally (I guess they wanted a Jag,
but didn’t want Jag maintance costs!).
While on the subject, anyone see the CNN news poll about a year or two ago?
They interviewed women and asked what they thought was the sexyist car around.
What did the majority answer? Jaguar, of course! And what car did the news
reports show? That’s right!, a gorgeous late model XJ40 in kingfisher blue
with tan leather, with its owner waving at the camera!
Well, everyone’s entitled to their opinion!
cobac@ix.netcom
1989 XJ40 Vanden Plas (black/biscuit)
- –IMA.Boundary.711173448–
Date: Thu, 3 Oct 1996 15:56:45 -0400
In a message dated 03/10/96 20:35:57, you write:
what is the straight story???John
The XK8 uses a modified XJS floorpan, only the bulkhead and the seat locators
were altered.
Tez
Date: Thu, 3 Oct 1996 16:13:27 -0400
Subject: Jaguars and babes
Mike
Enjoyed your note, Mike, really. To add -
it…<
Not all feminists are women. The contrary is a common but incorrect
presumption made by many men and women.
There is a notion out there that suggests the attraction of babe to car is
not so much the lure of the car but the driver. Like the old jazz tune says
: “It ain’t whatcha do it’s the way hacha do it.”
Quite seriously, is this forum purely male? I hope not. As a
generalization, how boring !
Date: Thu, 3 Oct 1996 16:45:00 -0400
Subject: 20 - 50 oil
Why do XKE owners use 20 - 50 oil ? Is this recommended by the factory ?
Why should this motor need heavier oil than most other makes ( which use 10
- 30 or 10 -
40 ? )
- 30 or 10 -
Doug
End of jag-lovers-digest V2 #401
X-UIDL: bad4e96d0d9a0bba819032f1fa70cfe0
Return-Path: @owner-jag-lovers-di1
Received: (from majordom@localhost) by ekeberg.sn.no (8.7.5/8.7.3/on4)
id for jag-lovers-digest-out; Fri, 4 Oct 1996 03:54:14 +0200 (MET DST)
Date: Fri, 4 Oct 1996 03:54:14 +0200 (MET DST)
Message-Id: 199610040154.DAA29099@ekeberg.sn.no
X-Authentication-Warning: ekeberg.sn.no: majordom set sender to owner-jag-lovers-digest using -f
To: jag-lovers-digest@sn.no
Subject: jag-lovers-digest V2 #402
Reply-To: jag-lovers@sn.no
Errors-To: @owner-jag-lovers-di1
Precedence: bulk
Status: RO
X-Newsgroups: mail.jag-lovers-digest
jag-lovers-digest Friday, 4 October 1996 Volume 02 : Number 402
Re: Re[2]: Fuel
horsepower list (no Jaguar content)
XJ-S Oil Pressure
Re: XJ40 vs. SIII
Re: Currency Conversion (Very Little Jag Content)
Re: XJ40 vs SIII (the reality)
Re[2]: XK-8 versus Aston-Martin
I saw it too!! XK8
Re: what your car says about you
62-65 Jag XKE roadster
XJ40 v’s SIII
Re: XK8 in Wall Street Journal
XJ-S Help Book Update
Date: 02 Oct 96 03:06:32 EDT
Subject: Re: Re[2]: Fuel
Mike Cogswell replied :
Actually, I think the correct answer is to read your owner’s manual and use
the recommended octane.
Most modern ECUs can compensate for lower octane fuel, but at the expense
of performance and economy.
On the other hand, it is generally worthless to use higher than recommended octane fuel without reprogramming the ECU. MikeC I know of no ECU / EF I /EIS (elec Ignition Systems) system which automatically compensate for the octane rating of fuel. Some systems (SAAB amongst others) can vary the ignition timing advancement until Knock occurs and will then retatd accordingly. I also dont’ know (yet) which adjustment of the ECU is necessary to compensate for for higher octane / or higher compression (which wil require higher octane rating), but I working on it reading my new book from AJ6 engineering. Regards Jeffrey Gram Regards From: DisneyPors@aol.com Date: Thu, 3 Oct 1996 17:31:13 -0400 Subject: horsepower list (no Jaguar content) Hi, I have this from the Porsche list and just thought I would sent it to you guys. Although the stereotype jaguar owner may not be a sports car person, I have owned Jaguars, love Jaguars and they do have one hell of a great racing history. Therefore, I figure some of you may like this list. So, here is a copy of my post to the Porsche list. Ok, no one has added anything to this list for a while now, so here are all the ones I collected. If anyone has anymore to add, please feel free. Otherwise, as Jerry944T@aol.com suggested this should be edited (there are some really unfunny ones in this list) and then maybe make up a Porsche tee shirt with the top ten. anyway, please direct all tee shirt questions and votes to Jerry944T as this his “baby”. I just told him I would keep track of the incoming ideas for a while as he was busy. Enjoy the list: You know you have enough horsepower when� 1. Your horsepower exceeds your weekly salary. 2. You have more than you can safely control, such as any teenager in a 5 liter Mustang. 3. You get a personal thank you note from the Emir of Kuwait for your help in supporting the economy. 4. When you have more horsepower than brain power 5. When your local race shop says “I don’t know how we can spend any more of your money.” 6. Your car goes through rear tires like potato chips. 7. You get a volume discount at both The Tire Rack, and your local traffic court. 8. Your local power company contacts you regarding the use of your car for peak load power generation. 9. Your wife simply says “Warp 7, Mr. Sulu.”, when she wants you take her for a spin. 10. You start scouting the local Army-Navy store for a surplus g-suit. 11. You start running red lights, as they appear green from doppler shift. 12. You plot stealing that big tank of NOX every time you visit the dentist. 13. Your local cops purchase a Vintage CanAm car, just to be able to catch you. 14. Michael Schumacher pays to drive your car. 15. You need FAA clearance to leave your driveway. 16. You leave rubber on the pavement exiting one corner, all the way to the next. 17. Enzo Ferrari (or Dr. Porsche) rolls over in his grave. 18. You have to add a Parachute to slow down 19. You see the Space Shuttle Astronauts waving to you, in your rearview. 20. Your G’Forces exceed your IQ (or weekly salary). 21. A road that was once paved smooth is now full of pot holes from your starts. 22. You rev your engine, and people in LA run for their lives. 23. You’re watching the tape of “In Car 956” on fast-forward mode just to keep from falling asleep. 24. You’re driving East and never see the sun set. 25. You lay two black strips of rubber down the length of your driveway every morning on your way to work. 26. You have to replace your brake pads at the end of each run group. 27. You’ve installed dragster parts to keep your car from wheelying back too far. 28. You don’t lust for Jerry Seinfeld’s mythical 959. 29. You start building a car for your wife (or) you start working on your wife�s car. 30. You give Andial your Visa number and they say, “Sorry, but…”. 31. The emissions test guy starts laughing as soon as you pull onto the rollers. 32. You can’t drive your car in the rain. 33. Your ‘significant other’ is afraid to drive your car. 34. You are afraid to drive your car. 35. You spend more on tires than on food. 36. You spend more on car insurance than on house payments. 37. You look in a state police car and see a picture of your car taped to the dash. 38. You look through the ads in Excellence and don’t see anything you want. 39. You throw your underwear in the garbage rather than the hamper. (Sorry) 40. You have to go to the track to buy gas. 41. Your mechanic names the new wing of his shop after you. 42. You win a PCA race. 43. You win a POC race. 44. You win a F1 race. 45. Norbert Singer (Porsche factory race engineer) calls to ask you a question. 46. You can�t improve your car without Patrick Head & John Barnard�s help. 46.a Patrick Head and John Barnard are so excited by the challenge they agree to do it. 46.b They fail. 46.c Enzo is so excited by the challenge he comes back to help. 47. You can�t find any cars worthy to race against, so you have to start your own series. 47.a Tony George is so threatened by your series that when you don�t let him manage it, he throws a temper tantrum and starts yet another series. 48. Bernie Eclestone show up at your house to see if your car meets regulations. 49. The Bonneville salt flats are to short for you to find out your top speed. 50. Boeing sends engineers to your house for some pointers. 51. Insurance companies create a new category just for you. 52. Your neighbors complain about the sonic boom every morning when you leave for work 53. Tire manufacture�s warrantees exclude your car by name. 54. Enough horsepower, what�s that? 55. Your sideways so often you forget which end is supposed to be in front. 56. You go through transmissions like potato chips. 57. You stop working on your engine and buy a wind tunnel to improve your top end. 58. You can start in 5th and not notice a difference (or - still smoke your tires). 59. Frank Williams and Ron Dennis get into a bidding war over you. 60. You are finally able to prove all those theories about the speed of sound. 61. You take a drive, get out, look back, and watch yourself get there. 62. Marlboro pays you 40 Million to put their logo on your car. 63. You drive faster than your guardian angel can fly 64. You can make the Kessell run in less than 12 parsecs 65. You are crowned King, the undisputed ruler and all knights pledge their undying allegiance to you. From: Steve Draper s_draper@wcsr.com Date: Thu, 3 Oct 1996 17:31:36 -0400 Subject: XJ-S Oil Pressure A few questions: oil pressure is usually around 50psi on highway driving; at times on idle pressure dips to 25psi. Is this necessarily a problem? If so, what could it be? Otherwise, car is fine. From: “Gregory W. Price” gprice@mack.rt66.com Date: Thu, 3 Oct 1996 15:48:33 +0700 Subject: Re: XJ40 vs. SIII It’s sort of like choosing a woman. Would you rather have a nice dowdy, hard-working woman who is a good cook and looks after the house but has no curves whatsoever - or a Cindy Crawford type who can’t cook, doesn’t do housework, but is a knockout that you can’t keep away from ? Hey, I’ll take frozen dinners and housework anyday !! You have Cindy Crawford on tap and you’re taking time to EAT and CLEAN??? Greg. G. W. Price & Company, Ltd Santa Fe, New Mexico Consultants in research, information management and program evaluation Probabilistic Record Linkage Services From: “Kirbert” palmk@gcn.scri.fsu.edu Date: Thu, 3 Oct 1996 17:59:28 -0005 Subject: Re: Currency Conversion (Very Little Jag Content) Surf on over to Currency Encyclopedia | Xe and you can convert any currency to your local currency in real-time. There’s another one at: http://bin.gnn.com/cgi-bin/gnn/currency?United_States Works a little differently, take your pick. Kirbert | If anything is to be accomplished, | some rules must be broken. | - Palm’s Postulate From: Shane Gibson shane_gibson@qsp.co.nz Date: Fri, 04 Oct 1996 10:12:49 -0700 Subject: Re: XJ40 vs SIII (the reality) Mike Cogswell wrote:
Having said that, I can state without reservation that the XJ-6/12 >Series III is obviously the most beautiful Jag sedan ever produced.
I am sorry guys (and gals) but I can remain silent no longer.
The MK II is the most beautiful Jag sedan ever produced.
Shane Gibson
Wellington, New Zealand
1968 Daimler V8 250
Date: Thu, 3 Oct 1996 17:35:13 -0500
Subject: Re[2]: XK-8 versus Aston-Martin
I’m certainly not in a position to argue, since I have no direct connection
to the Jaguar designers. However, I have seen several printed references
to the XK-8 as being based on the XJ-S platform. Of course, I didn’t say
chassis since the XJ-S doesn’t have one. I believe the R&T article not
only repeated the statement about the shortened XJ-S but may have even
given the specific number of different panels. They did say that the front
sub frame and suspension was much different. I think they said the
majority was made of aluminum. The engine is also set farther back to
improve weight distribution.
MikeC
Author: “Lee Walden” lwalden@ebmud.com at Internet
Date: 10/3/1996 11:06 AM
which
Date: Thu, 03 Oct 1996 16:46:54 -0500
I find that a fairly good common currency exists.
In countries that use bread as the “staff of life” you can express prices
in “loaves of bread” This also works good when compairing time periods that
are separated by periods of inflation.
For instance a Model T ford at $500 (yes some were cheaper but some were
more expensive too.) and bread at 5 cents a loaf comes out to 10,000 loaves
of bread. A new Ford Escort is now 12,000 dollars and a loaf of bread is
$1.20 so a new car STILL costs 10,000 loaves of bread.
I suspect that countries that use different things than bread could still
use the cost of a similar product to do the conversion.
Jim
“Better an outlaw than not free.”
Nance O’Neil
Date: Thu, 3 Oct 96 16:05:09 PDT
I have one of each and I would have to say I would give up
the XJ6 to keep the MK2. I can’t say as much over the beauty,
for they both hold there own in that department, but for the unique
character of the MK2 and THE LACK OF SMOG REQUIREMENTS.
Silas
Shane Gibson
1968 Daimler V8 250
Date: Thu, 03 Oct 96 15:45:09 PDT
Subject: I saw it too!! XK8
Got a look at the new XK8 today at lunch. Saw both the coupe and convertable.
X-UIDL: e38b4187385e9659095a805a1db01b9d
id for jag-lovers-digest-out; Fri, 4 Oct 1996 06:45:43 +0200 (MET DST)
Date: Fri, 4 Oct 1996 06:45:43 +0200 (MET DST)
Message-Id: 199610040445.GAA16023@ekeberg.sn.no
Subject: jag-lovers-digest V2 #403
Precedence: bulk
Status: RO
jag-lovers-digest Friday, 4 October 1996 Volume 02 : Number 403
Re[4]: Fuel
Brake Bleeding
Re: Replace the ECU as Pre Maintenance
Re: Local Shops and Dealers
Re: Alzheimers/Aluminum (no Jag content whatsoever)(Good news)
Re: XJ-S Oil Pressure
XJS Oil seals and gaskets.
Re[9998768479]: Fuel
XJ40 Head Gasket
RE: 90 xj6 bulb failure light
Jaguar Screen Savers
XJ40 versus all others
Re: oil pressure
Re: oil pressure
Re: bleeding brakes
Re: bleeding brakes
Date: Thu, 3 Oct 1996 21:49:14 -0500
Subject: Re[4]: Fuel
Jeff:
ECU was probably a poor choice of acronym. However, knock sensors have been
fairly common for quite a while. Cars with knock sensors certainly compensate
for low octane by retarding the timing. However, saying that they “compensate”
without further explanation was an even worse choice. I certainly failed to
make it clear that a) not all have knock sensors and b) running around with your
timing retarded because you have low octane fuel is a fundamentally bad thing.
Thanks for the reply.
The main point however remains, read the manual and use the recommended octane.
MikeC
Author: Jeffrey Gram 101454.2570@CompuServe.COM at Internet
Date: 10/2/1996 3:06 AM
MikeC
Date: 03 Oct 96 22:08:47 EDT
Subject: Brake Bleeding
Robin,
On my '66 series I ‘E’ I removed the rear spring/shock assembles from each side
to reach in and make life a little easier. This can be a little tough though
especially if these bolts haven’t been removed in a awhile. In any case you can
reach up and remove the bolts.
I haven’t tried from just underneath. If you end up doing it that way let me
know. It’ll save a little work next time.
- -Ed-
Date: Thu, 03 Oct 1996 19:14:03 -0500
Subject: Re: Replace the ECU as Pre Maintenance
- – [ From: Tom Graham * EMC.Ver #2.3 ] –
'Morning Chaps-
Just the opening I was waiting for - replace your ignition coil as
preventive maintenance!!! (You old blokes knew I was going to say that,
didn’t you).
I’ve no history of ECU’s going bad. Although I do remember about three
years ago some discussion re XJ-S- ECU’s and how some were prone to the
solder joints on the circuit board becoming “open”, due to vibration or
such. Suppose that is what I’d do with my ECU (84XJ6), I’ll add it to the
list, I’ve been inside the ECU housing before and recall it as being a
board with components. This should be reliable, but one could retouch the
solder joint for each component, wouldn’t hurt anything.
Rather than the ECU going bad it is much more likely that a wiring
connector will go bad. On every car I have, (mostly not Jag’s) if I
suspect an electrical type problem, I head for the connectors. 95% of
electrical problems are at the (bad) connector.
Rather than replacing the ECU, what about the Air Flow Meter??? It is and
electro-mechanical gizmo. Anyone know about how long the AFM, Bosch L-
tronic, is typically good for???
Cherio - Tom
Date: Wed, 02 Oct 1996 00:34:17 GMT
Subject: Re: Local Shops and Dealers
In message 199610011616.AA09695@gcn.scri.fsu.edu “Kirbert” writes:
Optional: he might also be able to bring
up a collection of comments regarding a selected shop.
[snip]
Comments could be added later, if someone has
a pleasant (or otherwise) experience with the shop.
In countries with libel laws like the UK’s, that could be a problem.
Basically, the only defence against a libel charge is “veritas”, i.e.
proving that what one said was indeed true and fair. Point is, the
defendant may have to prove his innocence, in a way.
I’ll be happy to comment on garages I have visited, but only by private
email, as this does not constitute “publication” which is a necessary
prerequisite for establishing libel.
No prizes for guessing what my experiences have been ;-(
Otherwise, great idea.
Stefan Schulz
jaguar@suaviter.demon.co.uk
Date: 4 Oct 96 12:23:47
Subject: Re: Alzheimers/Aluminum (no Jag content whatsoever)(Good news)
Peter Brown :Ever wondered what they put in anti-perspirant? Aluminium!
Dilemma: Keep your mind or your friends?
No problem, just get aluminium-free AP - or pick friends who love you for your
personality, not for your smell…
:3+)
- -Jan
Date: 4 Oct 96 12:12:22
This sounds exactly like my two XJ12s. Heat build-up during parking for half an
hour or so evaporates the fuel in the injection rails, and the fuel in the
filter is hot enough that it, too, mostly evaporates when it hits the rails.
Coughing and spluttering sets in until the vapour is gone. Yes, overheating
makes it worse; I had one period with the LWB before I re-gunned the radiator
when it was so severe that the vapour pushed the fuel back far enough to empty
the filter.
I’ve applied a couple of remedies, starting with getting the cooling system to
work properly. The next step was relocating the filter to the front corner of
the spare wheel well. I then wired an override switch, so as to run the fuel
pump continuously before starting the engine. You can hear the note of the pump
deepen when it gets up to pressure and the pipes are full again.
The Coupe, interestingly enough (possibly because it’s a high-compression
engine) doesn’t get quite as hot under the bonnet and I only turn the ignition
on/off four-five times before starting, to run the pump. This is only needed on
hot days.
- -Jan
XJ12L
XJ12C
Date: 4 Oct 96 13:39:02
Subject: Re: XJ-S Oil Pressure
Steve Draper : oil pressure is usually around 50psi on highway driving;
at times on idle
This is perfectly normal and no worry at all, Steve. In fact, 25 psi on hot
idle is jolly good.
- -Jan
Date: 4 Oct 96 13:43:53
Shane Gibson: The MK II is the most beautiful Jag sedan ever produced.
Prove it.
- -Jan
Date: Thu, 03 Oct 1996 20:43:55 -0500
Subject: XJS Oil seals and gaskets.
I will be putting the XJS back together this week end.
Two questions:
1) I have not yet opened the thermostat housings (I will be replacing
both of them with the 82 degree (summer version). Is the gasket a normal
gasket that I can make from stock gasket material or is it something special?
2) Someone suggested replacing the front oil seal while the radiator
was out. My seal is not leaking now and I wonder if I should just “let
sleeping dogs lie?” I would hate to change it then have a leak develop.
Jim
Nance O’Neil
Date: Thu, 3 Oct 1996 23:22:10 -0400 (EDT)
Subject: Re[9998768479]: Fuel
No offense to anyone involved, but this this whole stupid string started
(again) because someone with an 85 XJS that runs fine on 87 or 89 octane
(been so long I can’t remember) wanted to know if it would make the car
run better if premium gas was used. A reasonable question that has been
answered many times over now. The answer is no as long as the car is not
pinging and timing etc are set to factory specs. Can we stop wasting the
bandwitdth now?
Relatively few cars even today have knock sensors. An 85 XJS certainly does
not.
Thomas
Date: Thu, 3 Oct 1996 20:41:17 -0700
Subject: XJ40 Head Gasket
The AJ6 engine in XJ40’s don’t blow head gaskets at 100K miles like
many SIII’s do, and it doesn’t need a stake-down kit.
Again, for the record, I am currently doing more AJ6 head gaskets than XK’s.
This is due to oil leaks out the right front corner. Other than that, the
AJ6 is a fantastic engine
Is the front right corner leak one that is critical to fix? It appears to leak only where the timing chain runs – not at a cylinder. I’ve heard both versions – “they all do that, don’t worry” and “fix it right away”. What’s the scoop? I can stand a little oil seeping out, but I don’t want to pull the head if there’s no danger of compresssion loss, or head warping.
Mike Everatt
1987 1/2 XJ40 “the experimental version”
Date: Thu, 3 Oct 1996 20:41:35 -0700
Subject: RE: 90 xj6 bulb failure light
You probably have a faulty relay module – there is one in each corner of the car, they control all lights at that corner, and they’re expensive! Not much in them, either, however, they’re not really “user serviceable”. Check the connectors first, and the bulb sockets for corrosion. If they’re ok, it’s probably the one of the relays. (Which one???) Jag techs acknowledge the problem is common with these relays. I was told that they commonly cut two wires to elmininate the VCM display message, but I never did find out which ones.
Mike Everatt
Sent: Tuesday, October 01, 1996 11:18 PM
To: IBVILLIN@aol.com
Cc: jag-lovers@sn.no
ghost from time to
Donald R. Farr
Paradise Valley, AZ 85253
(602) 948-7499 - fax
91 Sovereign
d.farr@phx.cox.com - e-mail
http://people.phx.cox.com/dfarr/dfarr.htm - Don’s Homepage
http://people.phx.cox.com/dfarr/jetta1.htm - Jetta Notebook Computers
http://people.phx.cox.com/dfarr/march10.htm - Wireless products
http://people.phx.cox.com/dfarr/ncs1.htm - National Consulting Services
Date: Thu, 03 Oct 1996 20:46:48 -0700
Subject: Jaguar Screen Savers
Does anyone know if there are any more Jaguar screen savers for Windows
available? I have the XK-8 and the Moss Motoring savers but I would like
to find more, especially of all series of the E-types.
Date: Fri, 4 Oct 1996 03:50:22 GMT
On two occasions, bulb failure warnings in my 89 XJ40 Sovereign have been
due to poor contacts in the tail light assemblies, though all bulbs tested
OK when the car was stationary. I took out all of the bulbs and it was
obvious that arcing had dimpled the contact of one of them - very easily
fixed. I have also been told that the side turn indicator lights are often
the cause of bulb failure warnings - I think that water gets into them, but
am not certain. On the subject of good looking Jags, mine looks great while
it works well and won’t if it lets me down. To me, the same applies to all
cars - and women. Alan
Date: Thu, 3 Oct 1996 20:51:36 -0700
Subject: XJ40 versus all others
IMHO:
The best looking Jag sedan is the Mark II.
The best looking sports car is the XK120, or a Series 1 XKE (depends on the day!). Later XKEs, especially the 2+2, lost their good looks.
Series III’s are nice, but most I see are showing signs of age – body rust, etc. Not pretty anymore.
At first, I wasn’t as keen on the looks of the XJ40 as I was on the Series III, but now I wouldn’t trade at all. XJ40’s have a more modern, less fussy design that really grows on you with time. The interior is far nicer! And, for the record – everyone recognizes it as a Jag! Even Yugo drivers!
Mike Everatt
1987 1/2 XJ40
The experimental Version
Date: Thu, 3 Oct 1996 20:09:17 PST
Subject: Re: oil pressure
50 psi cold and 45psi hot at 2,500 rpm on Castrol20w-50.
Frank Filangeri
62 XKE roadster
On Thu, 3 Oct 1996 09:28 +0100 Frans HOEKEMEIJER
hoekemei@ps.msm.cern.ch writes:
Hello all,
with=20
be the=20=pressure where the overload valve of the pump opens. Of coarse, the
gauge=20
I=20
Frans.My recently rebuilt 4.2 E type has 45 psi cold, 40-42 hot at 3,000
rpm=20
with
What pressure should a "new motor " have ? ( Stock, street driven)
The shop manual says 40 psi at 3,000 but doesn’t specify oil weight
The racing prep factory manual says 40 psi with 40w oil
This seems to low
psi=20
you
haveThanks
Doug
1966 E-Type
=20
Frank Filangeri
62 XKE roadster
Hello all,
with=20
gauge=20
I=20
rpm=20
with
This seems to low
psi=20
you
haveThanks
Doug
1966 E-Type
=20
Date: Thu, 3 Oct 1996 20:05:14 PST
Subject: Re: bleeding brakes
Without dropping the tranny??? Did you mean the rear? In any case the
job can be done from underneath with the car on stands without removing
anything. Acces to the nipples is limited and there is very little
wrench room. However, if you you want to do a real good job the way to
go is put the car on jackstands, take off the wheels and remove the
foward shock/spring aetup on each side. You then have excellent access
to the bleed nipples through the subframe. Taking the shocks off takes
only a few minutes and is well worth NOT getting a face full off brake
fluid when the poorly secured hose pops off the nipple while you are
laying under the car. Good luck.
Frank Filangeri
62 XKE roadster
On Thu, 03 Oct 1996 13:55:54 +0000 (GMT) COOPER ROBIN D
COOPER_ROBIN_D@Lilly.com writes:
1
jack
hassle with the rear suspension. i would just like to check with otherpeoples experiences before starting. thanks,
robin cooper
Frank Filangeri
62 XKE roadster
On Thu, 03 Oct 1996 13:55:54 +0000 (GMT) COOPER ROBIN D COOPER_ROBIN_D@Lilly.com writes: has anyone ever tried to bleed the rear brakes on a 1967 E-type series 1 without dropping the tranny. it seems as though i can put it up on jack stands and do it from underneath without going through the incredible hassle with the rear suspension. i would just like to check with other peoples experiences before starting. thanks, robin cooper 1967 E-type series 1 coupe 1974 E-type series 3 convertible From: Randy Wilson randy@taylor.infi.net Date: Fri, 4 Oct 1996 00:36:59 -0400 (EDT) Subject: Re: Replace the ECU as Pre Maintenance Rather than replacing the ECU, what about the Air Flow Meter??? It is and electro-mechanical gizmo. Anyone know about how long the AFM, Bosch L- tronic, is typically good for??? Cherio - Tom You would think that these things would wear out. But my experence has been that they don’t, unless they get murdered. This is done by having a massive backfire through the intake tract. I’ve seen bent flaps and, in extreme conditions, distorted cases. As evidence I’ll offer two of my cars. Many years ago I bought a rusted out injected Fiat sedan, with 180K miles on it, specificly to transplant the injection into my (then carb’d) X1/9. It has since been moved to yet another X1/9. I’m guessing total time on that AFM is around 275K miles, with a large amount of the last 100k being run hard. The other car is a 81 injected Lancia purchased with 61K miles on it. Purchased cheaply because it would hardly run. the car was 11 years old and still had the original spark plugs in it. It also had a destroyed AFM. The case was balloned visibly. This was from backfiring. Jag’s seem to be easier on the AFM than other cars. This is most likely due to the AFM used has a backfire relief valve builtin to the flap, and the plumbing connecting it to the manifold is not as well secured as most. They tend to blow the hose off instead. Randy K. Wilson randy@taylor.infi.net End of jag-lovers-digest V2 #403 ******************************** Return-Path: @owner-jag-lovers-di1 Received: (from majordom@localhost) by ekeberg.sn.no (8.7.5/8.7.3/on4) id for jag-lovers-digest-out; Fri, 4 Oct 1996 15:42:01 +0200 (MET DST) Date: Fri, 4 Oct 1996 15:42:01 +0200 (MET DST) Message-Id: 199610041342.PAA17508@ekeberg.sn.no X-Authentication-Warning: ekeberg.sn.no: majordom set sender to owner-jag-lovers-digest using -f From: @owner-jag-lovers-di1 To: jag-lovers-digest@sn.no Subject: jag-lovers-digest V2 #404 Reply-To: jag-lovers@sn.no Errors-To: @owner-jag-lovers-di1 Precedence: bulk X-Newsgroups: mail.jag-lovers-digest jag-lovers-digest Friday, 4 October 1996 Volume 02 : Number 404 Re: XJS Oil seals and gaskets. XJ40: Bulb Failure Re: XJ40 Head Gasket Re: Local Shops and Dealers Re: jag-lovers-digest V2 #402 Re: XJS Electrical problems XK8 XJS Re: XJ40 vs SIII (the reality) Suspension, XJ3vs40 Re: Series I XJ6 in Auckland [JAGSWAP] Reminder [More WWW] The XK8 vs. DB7 and such Re: XJ40 vs. SIII Re: Local Shops and Dealers XJ40 for sale. ?2300-00 Beautiful cars. Re: Jaguar Screen Savers currency conversion again Re: Re[2]: XJ40 vs SIII (the reality) From: Jan Wikstroem Jan_Wikstroem@acp.com.au Date: 4 Oct 96 16:09:02 Subject: Re: XJS Oil seals and gaskets. Jim Isbell : 1)…thermostat housings… Is the gasket a normal gasket that I can make from stock gasket material…? 2) …replacing the front oil seal while the radiator was out. …not leaking now… 1) Yes - that or silicon. 2) If it ain’t broke, don’t fix it… From: “Rennick, Kim (AS01)” KRennick@p03.as01.honeywell.com.au Date: Fri, 04 Oct 96 12:03:00 EST Subject: XJ40: Bulb Failure I too have had the dreaded ‘Bulb Failure’ warning on the VCM. In the first instance, it proved to be bad connection on one of the front turn indicators. I cleaned the connection and both the fault and the indication went away. The second instance was more interesting. The indication would show for a while (hours or days), then extinguish of its own accord. I checked the bulbs - all working OK. (and who ever hear of self-repairing bulbs, anyway?) I then noticed that the ‘caravan’ icon was showing on the instrument panel whenever the Bulb Failure was indicated. (My car has the towing attachment, complete with ECU, even though I dont actually tow anything!) Because of this, I pulled the electrical connector plugs (at the tow bar) apart. (These are the plugs that you would plug the trailer / caravan wiring connectors to, if you were towing the same.) Sure enough, one of the grub screws holding one of the car wires into one of the sockets had vibrated out (in fact all the screws were loose). The wire was going open circuit with the socket. Reconnecting the loose wire and re-tightening all the screws fixed the fault and extinguished the warning message. Considering that the connector plug is not connected to anything (by virtue of the lack of trailer / caravan), I dont quite understand how the ECU can distinguish that open circuit from the open circuit caused by the missing grub screw! One of the wonders of the modern world, I say. Amazing as it is, the fact remains that in both instances the VCM was reporting a real fault. Fixing the fault reset the VCM indication. What more can you ask for? Kim Rennick __________________________________________________ | | XJ40 3.6L Sovereign - | Citroen BX 19 GTI - | …(English and French rapprochement in my garage!) |__________________________________________________ From: Randy Wilson randy@taylor.infi.net Date: Fri, 4 Oct 1996 00:54:17 -0400 (EDT) Subject: Re: XJ40 Head Gasket Again, for the record, I am currently doing more AJ6 head gaskets than XK’s. This is due to oil leaks out the right front corner. Other than that, the AJ6 is a fantastic engine Is the front right corner leak one that is critical to fix? It appears to leak only where the timing chain runs – not at a cylinder. I’ve heard both versions – “they all do that, don’t worry” and “fix it right away”. What’s the scoop? I can stand a litt>le oil seeping out, but I don’t want to pull the head if there’s no danger of compresssion loss, or head warping. Mike Everatt 1987 1/2 XJ40 “the experimental version” There are three leak areas. the cam cover (usually at the back and into the sparkplug wells) the timing chain tensioner (right behind the distrubtor), and the head gasket proper (right where the head necks down after the timing chain case). The first two get fixed; too simple not to. With the head gasket, I’m of the opinion that as long that it is just seeping (damp), it’s up to the customer. Fix it now, when it gets worse, or when you get tired of it spotting your garage floor. however, if it is leaking; you can see a stream of oil flowing with the engine running; fix it NOW. There are two dangers. One is the oil hydraulicly seperating the head gasket causing further damage. And the other is this oil running out the side is meant to be going to the exhaust cam bearings. Randy K. Wilson randy@taylor.infi.net From: “Kirbert” palmk@gcn.scri.fsu.edu Date: Fri, 4 Oct 1996 01:53:54 -0005 Subject: Re: Local Shops and Dealers Comments could be added later, if someone has a pleasant (or otherwise) experience with the shop. ^^^^^^^^^^^^ Stefan Schulz: In countries with libel laws like the UK’s, that could be a problem. Basically, the only defence against a libel charge is “veritas”, i.e. proving that what one said was indeed true and fair. Point is, the defendant may have to prove his innocence, in a way. I’ll be happy to comment on garages I have visited, but only by private email, as this does not constitute “publication” which is a necessary prerequisite for establishing libel. Good point. I don’t suppose jag-lovers would be too interested in testing the applicability of such laws to Internet “publication”, so perhaps an alternate idea: simply post the e-mail addresses of those who have experience with the shop, so that potential customers can send requests accordingly. Or I suppose we could keep the previous plan, but sterilize it – suggest that posters AVOID making disparaging remarks about the shop, but rather post only verifiable facts: what job was done, what it cost, what the estimate was, etc. Kirbert | If anything is to be accomplished, | some rules must be broken. | - Palm’s Postulate From: Jim Ellis jellis@metz.une.edu.au Date: Fri, 4 Oct 1996 16:59:50 +1000 (EST) Subject: Re: jag-lovers-digest V2 #402 AMEN to that Shane! Jim Ellis. (1963 Daimler 2.5 v8 ) At 03:54 AM 4/10/96 +0200, you wrote:
Shane Gibson
Jim Ellis
Internal Auditor
University of New England,
N.S.W. 2351.
AUSTRALIA.
'phone: (067) 733497;
[national: +61 67 733497;]
fax: (067) 733314;
e-mail: jellis@metz.une.edu.au
Date: Fri, 4 Oct 1996 09:00:04 +0200 (MET DST)
Subject: Re: XJS Electrical problems
temp.
Did you turn on ignition when your battery was inversed ? As far as I remember
the ECU is turned off by the ignition key. On the European kind of cars
is a little mechanism to change ignition advance on warmup. This is controlled
by little box under the passenger dash (LHD), maybe it’s shot ? It activates
when the engine temperature is under 38C for 15 minutes. You could disconnect
it for testing.
- matthias
Date: Fri, 4 Oct 1996 09:49:15 +0200 (MET DST)
Subject: XK8 XJS
I’ve read several times now that the XK8 is finally the first real
sports car after the E-type. Being somewhat biased to the XJS, which in my eyes
is a very beautifull sports car, I am wondering what makes the XK8 a sports car
compared to the XJS. Is it :
racing success (have not seen any XK8 race yet)
performance (the numbers HP and torque seem to better for the V12)
transmission (at least the 3.6/4.0 ltr models had an optinonal manual
option) -
weight (due to “non-sport” extras like A/C etc)
XJ-S not having fancy leather-covered ash trays
- Matthias
1988 XJ-S V12 (and if I had the money, my additinal car would be a XJ-S
cabriolet. V12 of course)
ps
the lowering of the window before closing the doors is a pretty old feature
introduced by BMW first on the 850 and the series 3 coupe.
From: brownd@filon.ml.com (Dave Brown - London Dev X1818)
Date: Fri, 4 Oct 96 08:53:35 BST
Amen to that.
David Brown,
brownd@ml.com
///_/_/_/_/////_///______
/_/_//_/_/_/_/_/____
/_/_/_/_/______/_/_/_/______
/_/_/_/_/_/_/________/_/_____
___/_/_/////_/_/_/_/_/______
/_/___/_/_//_/_/_/____
///_/_/_/____/////_///_________
Date: Fri, 4 Oct 1996 01:32:45 -0700 (PDT)
Subject: Suspension, XJ3vs40
Yes I would say that the SIII sedan does float at high speeds, something
which I would like to correct in our car. Mostly the problem is
noticeable at 100+ mph.
On another note, I understand there is some auto show in Paris right now,
perhaps I’l check it out.
Greg
Greg Meboe meboe@atc.boeing.com
Web site>> http://www.scs.wsu.edu/~meboe
Mechanical Engineer Boeing Payloads Division
'85 XJ-12 H.E. (daily) '67 Spit-6 '74 TR-6
Date: Fri, 4 Oct 1996 10:32:02 -0700
Subject: Re: Series I XJ6 in Auckland
G’day,
I think the program was called Tilt-23. One of the features was about the
annual(?) Garbage Derby in Auckland (NZ). All of a sudden, behind the two racing
garbage trucks, there was a Jaguar XJ6 Series I, red, possibly with black roof,
flashing its headlights and wiggling from side to side. I don’t think it was
trying to overtake the contestants. More likely it was sort of a pace-car.
Was it any of you guys? C’mon, you can tell me. Jaguars have been used as
pace-car before, at Silverstone!
Have a nice week end.
Bard
______ _ ! Baard Th Hesvik, Telesoft AS
/ _ / _ _ _ / / ! Longhammarvn 7, N-5500 Haugesund
/ // / // /_ / / -/- -/- ! T: +47 52735000 F: +47 52717040
/ /_ / /_ / // / /_ ! E-mail: baard@telesoft.no
Date: Fri, 4 Oct 1996 10:05:55 +0100 (MET)
Subject: [JAGSWAP] Reminder
Folks,
I see there are still some postings on the list from people who want to
buy/sell stuff. As one of the reasons to create the “Jaguar/Daimler used
parts exchange” was to relieve the list of some traffic I suggest that I
post an occasional (short!) reminder to the list.
Let me know if you disagree, if not I’ll set up a job to post
automagically every week? fortnight? month?
Please respond to me directly, no point in boring the whole list with
this. Since I’ve already written this much I’ll include my proposed text
of the reminder:
============== start proposed message =======================
This is an automatically posted message to remind/inform the list
members of the existence of the “Jaguar/Daimler used parts exchange”.
This is a free service you can use to buy/sell/trade SS, Jaguar or
Daimler cars and parts. The service is WWW based and you can find it at:
No commercial advertising for companies, please.
============== end proposed message =========================
Apart from all that I’m looking into a two-way gateway between HyperNews
and email so that any Web-challenged members can participate in the
used parts exchange through email.
Gunnar
Gunnar Helliesen | Bergen IT Consult AS | NetBSD/VAX on a uVAX II
Systems Consultant | Bergen, Norway | '86 Jaguar XJ6 4.2 Sovereign
gunnar@bitcon.no | http://www.bitcon.no/ | Vicki who? What .sig virus?
Date: Fri, 4 Oct 1996 10:14:17 +0100 (MET)
Subject: [More WWW] The XK8 vs. DB7 and such
To those who might be interested:
Mike Cogswell has graciously allowed me to use his postings regarding his
impressions of the XK8 and his thoughts about the XK8 vs. the Aston
Martin DB7 on my ‘Virtual Wheels’ WWW based Auto Enthusiasts’ “magazine”.
There’s some other Jaguar stuff there as well. You’ll find ‘Virtual
Wheels’ at:
Gunnar
Date: Fri, 4 Oct 1996 10:53:03 +0100
Hey, I’ll take frozen dinners and housework anyday !!Jim Legge
'85 SIII
'80 TR7
Or maybe you can’t make up your mind!
Ian
Date: Fri, 4 Oct 1996 10:52:54 +0100
Another useful addition would be an events list which anyone on the
list may be attending. That way we could go to an event sure in the
knowledge that at least one person will know the wonders of Jag-loving!
Ian
On Oct 01, 1996 12:16:28, ‘“Kirbert” palmk@gcn.scri.fsu.edu’ wrote:
So soon after the creation of the Jaguar/Daimler Parts site may not
be a good time to mention this, but I have another idea for a helpful
use of the WWW.What I think would be helpful would be an online listing of the
various local shops that do Jaguar or Jaguar-related work –
including dealers. Basically, someone with a need to know could
access the site, select the country he’s interested in, then the
state, then the local area, and finally be given a list of the
various shops in that area. Optional: he might also be able to bring
up a collection of comments regarding a selected shop.I consider this to be a separate idea from the suppliers list or
the list of sources in my XJ-S book. For the most part, I try to
list only sources of interest to XJ-S owners everywhere (mail-order
places, etc.), and avoid listing individual dealers or shops
generally of interest only to locals. Such a site could fill that
void.Establishment of such a site requires somebody to set it up, but the
input should be easy: each of us can send info on the shops in our
area. Even info copied out of the phone book would suffice, if
nothing else is known. Comments could be added later, if someone has
a pleasant (or otherwise) experience with the shop.There seem to be a lot of people who post questions to this group
trying to find a decent shop in their area. Also, those who travel
in their Jags might wanna check out the availability of repair sites
along their route – or, if they are connected via a laptop with
cellular modem, they could find the nearest site AFTER they break
down.– Kirbert | If anything is to be accomplished,
| - Palm’s Postulate
Date: Fri, 04 Oct 1996 12:17:28 +0100
Subject: XJ40 for sale. ?2300-00
XJ40 3.6 Auto on D plate
Gold with Black Leather, Air Con, etc…
Very nice drive.
Needs slight attention… but will sell for ?2300-00 or can swop/part exchange if
anybody is interested.
Bristol Area, but may travel.
E-mail me at scott@hanham.demon.co.uk
Thanks
Scott
Date: Fri, 4 Oct 1996 11:57:10 -0700
Subject: Beautiful cars.
Prove it.
- -Jan
Yeah! Prove it :-@
- -Bard
Jaguar XJ6 Series I (widely known as the most beautiful saloon in the world)
- -Bard
Date: Fri, 04 Oct 96 09:03:58 EST
Subject: Re: Jaguar Screen Savers
Not necessarily just screen savers - but actually any good
digitized images of Jags. There is plenty of shareware
available which will allow you to use any image you want as a
screen saver - where can we get good, high resolution, Jag
pics?
- mclaus ('93 XJ-S)
Author: “George W. Cohn” gwcohn@azstarnet.com at WG-RAL-SMTP
Date: 10/4/96 1:08 AM
Date: Fri, 04 Oct 1996 13:23:26 +0000 (GMT)
Subject: currency conversion again
the magazine ‘the economist’ uses a measure of currency comparison to see
whether a particular currency is over/undervalued in relationship to other
currencies. what they compare is the cost of a big mac and fries at the
local macdonalds-no kidding .i wonder how many big macs the new jag will
cost in the different markets. robin
From: Michael Powers/TEIR/Thomson Michael_Powers@teir.com
Date: 4 Oct 96 9:42:49
Subject: Re: Re[2]: XJ40 vs SIII (the reality)
Geez, mate, the post was merely a somewhat satirical view of the whole
SIII vs XJ40 debate. You shouldn’t take life (or email) so seriously.
After hundreds of posts concerning faulty solenoid questions, brake bleeding
commentary, and all the other bits of minutia, sometimes
we need a whimsical view, just to liven things up.
I hope we’re all still friends!
Cheers,
Mike
89 XJ6 - “The Ultimate Babe-Mobile”*
*Excluding the XK8 and X300
M.Cogswell @ zds.com (Mike Cogswell)
10/03/96 02:34 PM
To: Jag-Lovers @ sn.no @ Internet
cc:
a grip!
Mike C
Subject: RE:XJ40 vs SIII (the reality)
Whew!!! I was hoping somebody would send a post that took the
“babe factor” into account when comparing an SIII and the XJ40.
Let’s face it, women like the XJ40 better. Period.
Is there really anything more that needs to be said?
Respectfully yours,
Mike
PS - If there are any women on the list, don’t bother sending any nasty
emails saying I’m sexist, or whatever. You know the truth when you hear it…
cobac @ ix.netcom.com
10/02/96 12:13 PM
To: jag-lovers @ sn.no @ Internet
cc:
Barrie Dawson
Chatham, Kent England
cobac@ix.netcom
End of jag-lovers-digest V2 #404
id for jag-lovers-digest-out; Fri, 4 Oct 1996 20:25:04 +0200 (MET DST)
Date: Fri, 4 Oct 1996 20:25:04 +0200 (MET DST)
Message-Id: 199610041825.UAA26253@ekeberg.sn.no
Subject: jag-lovers-digest V2 #405
Precedence: bulk
jag-lovers-digest Friday, 4 October 1996 Volume 02 : Number 405
No Jag Content - The source of Standards
Re: Beautiful cars.
XJ-S Shell
Re: Re[2]: 20-50 oil
Re: XJ-S Shell
1990 XJS
Parts for sale list on the web and Dealer comments
Are Jags Sexy?
1994 vanden plas
V12 Chain Tensioner Tools
XK8 vs. Aston-Martin
Re: XJ-S Shell
1990 XJS -Reply
Re: XK8 XJS
XK8 / E-type Musings
Two dead Jags.
Date: Fri, 4 Oct 1996 08:44:26 -0500
Subject: No Jag Content - The source of Standards
I was thinking recently on some of the twisted convoluted regulations =
and taxing systems that affect us and our automobiles. While this does =
not apply directly to automobiles, it does start you thinking… =
BTW…To our friends in the UK, can any of you vouch for the truth of =
this story?
The US Standard railroad gauge (distance between the rails) is 4 feet,
8.5 inches. That’s an exceedingly odd number. Why was that gauge used?
Because that’s the way they built them in England, and the US
railroads were built by English expatriates.Why did the English people build them like that? Because the first
rail lines were built by the same people who built the pre-railroad
tramways, and that’s the gauge they used.Why did “they” use that gauge then? Because the people who built the
tramways used the same jigs and tools that they used for building
wagons, which used that wheel spacing.Okay! Why did the wagons use that odd wheel spacing? Well, if they
tried to use any other spacing the wagons would break on some of the
old, long distance roads, because that’s the spacing of the old wheel
ruts.So who built these old rutted roads? The first long distance roads in
Europe were built by Imperial Rome for the benefit of their legions.
The roads have been used ever since. And the ruts? The initial ruts,
which everyone else had to match for fear of destroying their wagons,
were first made by Roman war chariots. Since the chariots were made
for or by Imperial Rome they were all alike in the matter of wheel
spacing.Thus, we have the answer to the original questions. The United State
standard railroad gauge of 4 feet, 8.5 inches derives from the
original specification (Military Spec) for an Imperial Roman army war
chariot. MilSpecs and Bureaucracies live forever.So, the next time you are handed a specification and wonder what
horse’s ass came up with it, you may be exactly right. Because the
Imperial Roman chariots were made to be just wide enough to
accommodate the back-ends of two war horses.
Date: Fri, 4 Oct 96 14:55:21 BST
Subject: Re: Beautiful cars.
IMHO, The Jaguar C-type was one of the most seductive and beautiful cars ever
produced. Not a regular car, but gorgeous all the same.
David Brown,
brownd@ml.com
Date: Fri, 4 Oct 1996 10:05:30 -0400 (EDT)
Subject: XJ-S Shell
Seems that in a recent Jag magazine I saw a blurb about factory XJ-S
shells being available for something like 500 pounds. Supposed to provide
a solid base for the restoration of an S. A condition of sale was the
destruction of the original shell, I preume because the VIN gets
transferred to the new shell.
This sounds like a real bargain. Is it true? Do shipping costs make this
a problem outside the UK? If all the answers are yes, then maybe a bunch
of us can fill up a container.
John
Date: Fri, 4 Oct 1996 10:10:54 -0400
Subject: Re: Re[2]: 20-50 oil
I have a book on Jags that quotes a 1960’s media test drive : "The usual 50
psi oil pressure dropped to 40 after a spell of top speed running at 5,000
rpm " As usual there is no clue what weight oil was used.
There is no difference in bearing clearances between Jags and any other
motor. the mains and rods are .0015 - .003 .
Performance experts state that 10 psi per 1,000 rpm is desirable. That would
make 50 + psi desirable on a Jag or any other motor at 5,000 rpm. Gran
Turismo Jags state that 100 psi is necessary in their race motors, they have
made a special pump . They run to ~8,000 rpm
I wonder what the Jag Le mans race cars oil psi was. They ran ~6,000 rpm for
hours and I don’t think they had bearing problems.
I am interested in determining the optimal, correct pressure
Doug
Date: Fri, 4 Oct 1996 15:25:39 PDT
Subject: Re: XJ-S Shell
XJ-S
provide
transferred to the new shell.This sounds like a real bargain. Is it true?
It was true. Whether there are any left, I don’t know. The notice was
placed some months ago.
Cheers,
Dave Wood.
Date: Fri, 4 Oct 96 14:31:44 UT
Subject: 1990 XJS
Hi all,
New to the list, I am new owner of an XJS V-12 and it came with the required
two or three minor problems.
The drivers window won’t go all the way up on the first try or it will go up
with a little push. I’ve lubed the track with silicone dilectric compound but
still no luck.
Problem number two is a clicking sound coming from the right front wheel when
going over bumps. Time for a new shock?
Are there zerk fittings on the suspension that I should be greasing? Did they
come with grease fittings or do you have to install them?
The speed control was disconnected when I bought it, the previous owner said
it had never worked for him. After re-connecting it it works fine! Are there
any problems inherent with this system that someone would just disconnect this
system instead of fixing it or should I chalk it up to a previous owner that
just didn’t like speed controls?
I was having a poblem that turned out to be the gas cap. I’d be crusing along
at 65 mph and then no power, nothing till it slowed down to 25mph. It would
limp along till you let it sit for ten or fifteen minutes. The previous owner
suggested vapor lock as the problem, I was a little sceptical but when the gas
cap was loosened and now with it put on just enough to keep it in place, no
more problems!
Kevin Sisterson
El Cajon Ca.
Date: Fri, 4 Oct 1996 09:32:25 -0500
Subject: Parts for sale list on the web and Dealer comments
a reason not to discourage posts to this list of parts to trade/sell is
that some people dont have access to the web. They only have access to E-Mail. -
As to bad comments on service providers. If we just mention those places
with which we are satisfied then it means anyone not on the list is either
not a good place to go, or has never been tried. This will aleviate any
worry about liabel.JIM I.
“Prefiero morir de pie que vivir de rodillas.”
Gen. Emiliano Zapata
1879-1919
Date: Fri, 04 Oct 1996 09:52:32 -0700
Claus, Mike wrote:
Not necessarily just screen savers - but actually any good digitized images of Jags. There is plenty of shareware available which will allow you to use any image you want as a screen saver - where can we get good, high resolution, Jag pics? - mclaus ('93 XJ-S)
Have you tried the Jaguar Cars home page. I think it is at
http://www.jaguarcars.com.
Might be a good place to start
Jon
From: “Makoto & Ann Sado Honjo” fm7m-hnjy@asahi-net.or.jp
Date: Sat, 5 Oct 1996 00:08:15 +0900
Subject: Are Jags Sexy?
My ex secretary (who has since become a forex dealer, been married,
divorced, and remarried) had the ultimate comment on this subject.
“If a guy on a Mercedes tries to pick me up, I’ll think a bit; but if
a guy on a Jag tries to pick me up, I’ll just say ‘Yes, yes, yes.’”
Makoto Honjo
Phone/Fax +81-3-3473-1848
Date: Fri, 04 Oct 1996 10:25:37 -0600
Two questions:
Why would you not want to purchase the correct gasket? They are very CHEAP
even at a Jag Dealer.
Hal
Hal Rogers
H.D. Rogers & Sons
Import Auto Specialists
3418 Barksdale Blvd.
Bossier City LA 71112
(318) 742-3651 voice
(318) 742-5044 fax
Serving Auto Enthusiasts since 1959
Date: Fri, 4 Oct 1996 11:12:57, -0500
Subject: 1994 vanden plas
In regard to my note about Jags slightly damaged at low price.
I have had too many e-mail to return. Their are none on the lot
at this time. Some examples of recent units are as follows.
{1}1995
Xj6 hit left front corner. I estimated which parts to replace &
New
they were about $5000 from dealer (not many Used 95 parts). It
sold as is for $19000 . Insurance pay out was $45000 U S .{2} 94 xjs
convertible. was hit hard on front but was very repairable. $19000.
{3} 90 vanden plas all seats were cut with razor as were plug wires
fuel injection cables. Racial slurs were scratched on top ,hood , &
trunk.
It sold for $5000 US. These were all salvaged by insurance co. and
have
to be repaired & inspected by state to be re titled.
I saw an estimate form a dealer body shop of over $20000 on one Jag
and I know that it only Cost $6500 to repair at none dealer shop.
Dealer
shop told me he did not want that job because the owner would be
impossible to please. And some Ins co most give in to influential
Jag
owners and total some slightly damaged cars as I have seen them. If
no objections I will post any thing (jag) that this dealer list. But
I cant
return all the e-mil. I would like to put another 10k miles on my 94
vdp
wich I love then offer it for about $23K .
paul martin
alabama usa
94 vdp
snuu46a@prodigy.com
Date: Fri, 4 Oct 1996 11:36:14 -0005
Subject: V12 Chain Tensioner Tools
I’m always thinkin’.
The Jaguar manual specifies the use of tool JD.50 for releasing the
tension on the timing chain tensioner. What I would like to know is:
in the place of the small lever that is inserted into the opening to
release the latch, has anybody tried using one of those “brake tools”
that are sold everywhere for working on drum brakes? Y’know, the
little levers you stick through a hole in the backing plate and dial
the little star wheel on the self-adjusting brakes? They look to me
like they might work; I’d like to know if this is a workable
suggestion for the XJ-S help book.
| - Palm’s Postulate
Date: Fri, 4 Oct 1996 10:06:55 -0500
Am I wrong or is anything much greater than 100 dots per inch wasted on a
screen saver. In the interest of saving hard disk space as well as
bandwidth downloading the images I suggest we do not need “high
resolution”.
Dave and Linda Freeman http://www.ipa.net/~dlfreeman
Living the Good Life
Date: Fri, 4 Oct 1996 11:03:23 -0500 (CDT)
rpm " As usual there is no clue what weight oil was used.There is no difference in bearing clearances between Jags and any other
motor. the mains and rods are .0015 - .003 .Performance experts state that 10 psi per 1,000 rpm is desirable. That would
made a special pump . They run to ~8,000 rpmI wonder what the Jag Le mans race cars oil psi was. They ran ~6,000 rpm for
hours and I don’t think they had bearing problems.I am interested in determining the optimal, correct pressure
Here is another opportunity to to venture down the primrose path by
making seemingly “obvious” connections between parameters that are, in
fact, wrong.
Engine bearings are journal bearings, also known as hydrodynamic
bearings. This means that the rotating motion is what produces the
pressure within the oil film that keeps the metal parts apart. I’ll not
go into the mathematical analysis here, but the combination of bearing
load and journal rotation produces localized pressures that are much
greater than any engine’s supply oil pressure. All such a bearing needs
is sufficient oil flow to keep the gap between its journal and bearing
full. Supply oil pressure does not–indeed can not–carry the bearing
load. Supply oil pressure must be adequate to keep all of the engine’s
bearings flooded under all conditions. A loss of oil in the bearing
will result in rapid failure.
Many journal bearings work just fine with oil supplied at almost no
pressure, as in the crankpin bearings of steam engines that were
supplied from a small oil cup mounted on the bearing cap. Yes, I know,
these bearings had oil seals and ran at slower speeds, but that doesn’t
change how they carry loads.
In an engine, oil flow through the bearings serves a couple of other
functions, too. It flushes out wear elements that might be present, and
it serves as the bearings’ coolant.
Don’t confuse hydrodynamic bearings with hydrostatic bearings.
Hydrostatic bearings, machined to very tight tolerances, do require a
high supply (static) pressure to produce the oil film in the bearing.
They are used where bearing runouts in the microinch range are needed,
and they are expensive to buy and operate–not something one would need
to put in an engine.
Racing engines use higher supply pressures to make sure that the bearings
have oil under severe conditions, not just because these engines run at
higher RPMs or stresses. Even 100psi doesn’t compare with the localized
pressures the journal bearing develops from its own motion.
Larry Lee
Date: Fri, 4 Oct 96 9:43:20 PDT
Subject: XK8 vs. Aston-Martin
I remind everyone that the Aston Martin cost almost as much as
an XK8 plus an XJ6!
Roger Peng (408)765-7863
Intel Corporation
Design Technology, Physical CAD
Date: Fri, 04 Oct 96 13:09:32 EST
I guess this is a dumb question, but what is a Shell, and why
might I want one?
- mclaus ('93 XJ-S Convertible)
Subject: XJ-S Shell
Author: John Napoli jgn@li.net at WG-RAL-SMTP
Date: 10/4/96 11:24 AM
John
Date: Fri, 4 Oct 1996 12:57:45 -0400
Subject: 1990 XJS -Reply
Kevin, I’ve got the same issue with my driver’s side window. If you
shine a light into the door (with the window down) toward the front of
the door, you see the motor and gears for driving the window. A good
spray of WD-40 (I attached the little red straw for accuracy) left to sit
for a while may solve the thing. It did for me. Good luck, and if you hear
of a better solution, let me know. Thanks.
Date: Fri, 4 Oct 1996 10:19:27 -0700
Subject: Re: XK8 XJS
Matthias wonders about the good old XJ-S:
Don't let such taxonomic niceties get to you. If you think yours is a
sports car, that's fine I suppose. I know mine is a Grande Tourer,
despite what dubious racing pedigree it may have.
option)The XJ-S V12 transmission is a dog. I have mine upgraded with a
better torque convertor and aggressive change points. It is still a
dog. The longer I own my beautiful Grande Tourer, the more I have to
accept that this piece of old but robust 3-speed American junk they
call a trany can never be considered part of a true sports car. -
The XJ-S is way too heavy to be considered a true sports car. Grande
Tourer, yes. They need it heavy for that wonderful ride. And I’d
personally rather keep the AC, and all other extras that make the XJ-S
such a wwondeful car (tranny notwithstanding!). -
hehehe
Michael Kenrick
Date: Fri, 4 Oct 1996 10:33:32 -0700
Subject: XK8 / E-type Musings
What, in 1961, made the XKE such a great car? Why did it take the world
by storm, and does it continue to have such a great following? Well
in my opinion, it was the result of:
o Race-ready performance, with a (D-type) racing heritage to back
it up. An outstanding power/weight ratio.
o Industry leading technology
- Dual overhead-cam racing engine
- Independant IRS
- 4 wheel disk brakes
- Combined mono-coque / space frame construction
o Breath-taking styling. Looking at what else was being sold in 1961
it’s easy to see how this car made such an impact.
o All at a price an everyday shmuck could (stretch to) afford.
Just imagine if Jaguar took that formula and repeated it today. What would
it be? My take is… a mass produced XJ220 (industry leading technology,
race ready and proven performance, breathtaking styling), at… say $42,000.
No, not the full blown $250K XJ220, but a car for the masses that is to the
XJ220; what the E-type was to the D-type. Who among us wouldn’t be
saving/scrapping/stealing to find a way to put one in the garage? That
is what a “re-birth of the E-type” would have been to me…
Instead, Jaguar has unleashed their “re-birth” of the E-type, the new XK8,
complete with leather cup-holders, a little joy-stick to position the
steering wheel, gazillion way memory seats, etc. And a price tag that’s
just about $70,000. Why a “re-birth” of the E-type? Because it has a hump
running down the middle of the hood, an oval shaped intake, and (arguably)
headlights that sort of look like the old S1 E-type ones.
Don’t get me wrong… after attending the Oct 3 launch in San Jose last
night, I have to say the new XK8 is a nice car. It’s a really nice car.
Good (maybe great) styling, luxuriously appointed interior, good (according
to the rags) performance, very nice fit and finish, etc. I certainly would
like to have one. But there’s no way I’d drop $70K for one. And I really
don’t think it’s going to generate the kind of enthusiasm the E-type did
in 1961.
Instead of a re-birth, maybe what we have is a disinternment. The E-type
was retired with good reason in 1975. It had evolved from a sports car
into a grand touring car, and the original E-type design just wasn’t
very well optimized for this new role. Take a look at the boot space for
instance. The XJ-S (regardless of your opinion about its styling) was
probably a better touring car, and certainly (given it’s success over
some 23 years) proved to be a popular and profitable design. The new
XK8 continues as an even more upscale, luxurious, touring car; but with
some retro E-type styling.
But as I said, it is a really nice car. But to be honest, if I was
looking to spend ~$70K on a GT car, I think I’d buy a Viper coupe before
I’d buy the XK8. Just a thought: if the XK8 had a Diahatsu, Kia, or maybe
even Acura badge on it… what would we all think of it? Conversely would
it have mattered, at all, who built the original E-type?
Just my $0.02 worth.
Ryan.
Date: Fri, 4 Oct 1996 14:23:25 -0400
Subject: Two dead Jags.
Saw two dead Jags the other day.
Local ad stated “two Jags for the price of one”. Curiousity got the
best of me so I called. “A 71 XJ6 and a 76 XJ6, both need TLC but were
running” said the owner, “and they could use a paint job”.
“were” is the operative word.
As I pulled in the driveway, I could see both sitting on the side of the house
tail-to-tail among the weeds. The first casualty I reached was the Series I.
Broken grill, flat tires, spots of bondo. A quick peek inside and I knew what
to expect when I opened the engine bay. Empty places where all the engine
parts should be but are now scattered about the interior, that is what was left
of the interior. So much for the '71. About the only good thing I could say
about it was all the glass was there, and the wheels looked like they
were off an XJ-S.
The '76 looked a little better and the owner said he had been driving it daily
up to last year. Interior was actually pretty good. Complete, musty, but
clean. Headliner hanging way down. Exterior was full of paint bubbles and
passenger side sill was gone. “Does this one run” I asked sheepishly.
“Sure, I just need to clean the carbs then I bet she’ll fire right up” he
said. I didn’t hang around to see if she’d start, I think it would have
been quite the struggle. So much for my “his and hers” XJ6’s.
Sad to say but these will probably end up in the junk yard :~(. Well, I saw
another XJ6 SI over by my parents new neighborhood. Maybe I’ll check it
out this weekend.
If anybody in the Allentown PA area what’s info, e-mail privately.
eric
henning@fp.com
End of jag-lovers-digest V2 #405
id for jag-lovers-digest-out; Sat, 5 Oct 1996 08:10:12 +0200 (MET DST)
Date: Sat, 5 Oct 1996 08:10:12 +0200 (MET DST)
Message-Id: 199610050610.IAA18266@ekeberg.sn.no
Subject: jag-lovers-digest V2 #406
Precedence: bulk
jag-lovers-digest Saturday, 5 October 1996 Volume 02 : Number 406
I saw the XK8!
Re: Bleeding brakes - XKE
Re: XJ-S Shell
Re: 1990 XJS
Re: XJ-S Shell
XK-8
XK-8
Local shops and dealers etc
Jag certificate
Jaguar Accessories
RE: XK8 XJS
S1 XJ6 Interior Trim
Speedomoter Calibration
I rode in an XK8
Jaguar questions
Re: I rode in an XK8
Re: Are Jags Sexy?
XK8 Test Drive
Date: Fri, 4 Oct 96 12:08:50 PDT
Subject: I saw the XK8!
Guys,
I went to the debute of the Jaguar XK8 at San Jose British
Motors last night. There were tons of people there, and Jags
parked everywhere. I must say the car looks better in person
than in the pictures. It won’t knock you out like the XKE or the
series III XJ, but it’s a good effort. I think the front end
looks quite good. The dash also looks better in person. Somehow
in the pictures it looks too “thick”. The “wing” shape is a throwback
to early British sports cars like the Jag XK120 and the old MG’s.
Having said the good things first, now let me turn to the criticisms:
- I don’t like the styling in the rear, and I think Jag will improve
upon it later. - Styling on the side is too blend, kind of looks like a Chrysler
Sebring. Maybe curvier sheetmetal is harder to manufacturer? - I don’t quite like the interior finish. It feels and smells too
much like one of the Ford products. - The engine compartment presentation is very un-Jag like. It’s got
black plastic everywhere. I generally hate the cosmetic engine covers
introduced by the Germans to hide everything. - I noticed that the inside of the headlight lenses already have
condensation!!
I also checked out the `97 XJ sedan line. Here are the changes I
noticed: the XJ6 base model now gets black grill, and is offered
also in LWB. The VDP LWB now has a different looking rear seat.
I don’t particularly like its look (see for yourself), nor do I like
last year’s bench seat. In my opinion, the XJ40 VDP has the best
looking seats. As in the case of the XK8, I think the interior
“finish” is becoming more and more American. You feel it when
you sit inside.
Here’s my ideal Jag: a series III sedan with a XK8 engine/transmission
and XJ40 Majestic seats.
Intel Corporation
Date: Fri, 04 Oct 1996 08:24 -0500 (EST)
Subject: Re: Bleeding brakes - XKE
I remove the telescoping dampers (coiled over shocks) on the cage to
allow access for a wrench to crack the bleed nipples. These are the
two shocks that are on the forward facing side of the cage, not the
rear set. A nut on the top and bottom and the shocks are off. It
makes it worlds easier when bleeding the rear brakes.
Robert Abascal '63 XKE OTS & '66 XKE Coupe
Date: Fri, 4 Oct 1996 16:32:37 -0400 (EDT)
placed some months ago.Cheers,
Dave Wood.
How do you order one? From a dealer? Or direct to the factory?
John
Date: Fri, 4 Oct 1996 16:46:38 -0400 (EDT)
Subject: Re: 1990 XJS
still no luck.
The window channel needs adjustment (procedure outlined in the service
manual) or if adjustment won’t do it replace the window channel lining.
Oh, yes – quite a few. And some can be overlooked if you don’t know
where thay should be. Check the manual.
John
Date: Fri, 4 Oct 1996 16:57:26 -0400 (EDT)
On Fri, 4 Oct 1996, Claus, Mike wrote:
I guess this is a dumb question, but what is a Shell, and why might I want one?
The shell is the whole unibody, but only sheet metal – no ‘stuff’.
You want one because your old one is rusty or bent.
John
Date: Fri, 04 Oct 1996 12:36 -0500 (EST)
Subject: XK-8
I saw the XK-8 last night. Minor negatives first, the rear badges
almost look cartoonish and I can't get excited about a car with a
sterile pedigree. No racing heritage to this car, perhaps with the
latest technology and simulations, race testing is not required
anymore to develop a performance car such as this. No mention in any
literature I have seen has any diagrams of the suspension.
This is all personal opinion of course, but otherwise just about
everything about the car is outstanding. It's a WONDERFUL car. All of
us tech-minded knit-pickers out there need to Kwitcherbitchen!
LONG LIVE JAGUAR!
Robert Abascal '63 XKE OTS & "66 XKE Coupe
Date: Fri, 04 Oct 1996 08:35 -0500 (EST)
Subject: XK-8
LONG LIVE JAGUAR!
Date: Fri, 4 Oct 1996 19:15:58 -0400
Subject: Local shops and dealers etc
Stefan Schulz:
Kirby:
As those in the UK definitely know: Have I got news for you…
“The 420 is THE MOST BEAUTIFUL saloon ever.” Allegedly.
QED
Alternatively, since a certain amount of administration is bound to be
involved (rather than just posting messages), the contributors could grade
a supplier on an A->E type scale, and then Jag-lovers could quote the
number of responses for each grade.
Regards
Peter Carpenter
1967 420
UK
Date: Fri, 4 Oct 1996 19:14:27 -0400
Subject: Jag certificate
Hello all. I am a new member to the world of Jaguar. Over the summer,
I purchased a 1970 Daimler 420 Limo. It was somewhat rough, but I put
quite a bit of work in to it, and now it drives quite nicely.
I have been interested in the history of my particular car since I
purchased it. I have managed to find several owners in the US and the UK.
One owener in New York found a card with the following inscription on it
while oiling the divider window: Personal Card, Her Majesty’s Afternoon
Party, Buckingham Palace, Tuesday, 24th July, 1973. Mr Richard Wheeler.
The really funny thing is that on the back it says the card cannot be replaced
and must be presented at the gate. If it fell between the divider window,
did he ever get to see the Queen? I’m tracking this fellow down with old
newspaper articles.
My real question: The Daimler trust offers a certificate for $40.
Does anyone have one, what does it say on it, and is it worth it?
Is there any other info available for a car like this, e.g. build sheets,
copy of the window sticker, special information.
Any other special info or especially funny stories would also
be appreciated. Bill McDowell
Date: Fri, 04 Oct 1996 19:08:55 -0700
- If it ain’t broke, don’t fix it…
Aren’t you glad the airlines don’t follow that motto?
Date: Fri, 4 Oct 1996 17:20:55 -0700
Subject: Jaguar Accessories
Anyone out there have the Jaguar Accessories Catalog? My dealer has been
out of them, and the shipment hasn’t come in yet, so I haven’t gotten mine.
I was wondering if anyone would be kind enough to tell me about what type
of alarm system they offer (if they offer one) in the catalog and/or what
car phone(s). My '89 only came with the Infra-red unlocking.
Thanks in advance!
cobac@ix.netcom.com
Date: Fri, 4 Oct 1996 20:18:49 ±800
Subject: RE: XK8 XJS
this was actually started with the 61 Lincoln conv. The back windows =
lowered when you pushed the door release. The window dropped abouth an =
inch, then raised when the door was closed…next tinme you go to a car =
show…ask the owner of one to show you…pretty cool
Date: Fri, 4 Oct 1996 21:59:11 -0400
was going to send this to Mike, but thought others might
want same info;
I can send you a couple of gorgeous red E’s, top down, etc.
I took one of these, used photoshop to change it to a white one,
(mine) then took a head shot of myself, from a business CD, and
inserted “me” in the driver’s seat -all this before my E was finished
and ‘on the road’ I use it as my wallpaper (not screen saver)
I will send you these if you like, or just search the web. If you can’t
find any I have some bookmarked I’ll send you.
Fun!
Charles Daly,
'62 E-Type, ots
Date: Fri, 4 Oct 1996 22:31:22 -0400
Subject: S1 XJ6 Interior Trim
Does anyone have a good source for the door moulding trim for the S1 XJ?
This is the furry clip-on moulding trim which goes around the doors.
Also, since I have never actually liked this furry stip, does anyone have an
alternative door trim which works?
Thanks for the advice.
- –David Q.
1971 XJ “Jagalon”
Date: Fri, 4 Oct 1996 22:34:25 -0400
Subject: Speedomoter Calibration
Is it possible to adjust the Smiths’ speedometer for calibration purposes
without taking it to a speedo shop?
This is on a S1 XJ. It appears that the rear of the guage has at least one
thumbscrew and some locking nuts. My guage is off slightly. If it is
possible to adjust, what is the range that is possible?
Thanks for the advice!
- –David Q. “Jagalon”
Date: Fri, 04 Oct 1996 22:49:10 -0400
Subject: I rode in an XK8
Hey folks -
On Thursday I had the good fortune to be invited for a quick ride in a blue XK8 convertible. It was very nice, although the driver was very catious considering the high profile car we were driving. We just ran to get petrol and back. My impressions: Excellent powertrain isolation/refinement. After all, Jaguars have always been about silky smooth power delivery. Veneer is brilliant. I love the huge slab of wood on the fascia, and the centrally positioned minor instruments. Silent operation of convertible top mechanism. Very good underbonnet appearance. One list member mentioned he didn’t see any spark plug wires. That’s because there are none. The XK8 uses coil-on-plug, eliminating spark plug wires as we used to know them. True, there are two wires running to each coil, but they are not spark plug wires in the traditional sense. More to come when I get a “proper” evaluation. B.J. Kroppe - '82 XJ6 From: petrova petrova@loop.com Date: Fri, 04 Oct 1996 22:02:41 +0000 Subject: Jaguar questions I got this e-mail from a young lady and I do not know any of the answers, thought maybe someone on the list might. ______________________________________________________________ Subject: Juguar Car From: LANDY812@gnn.com (Mikan) To: petrova@loop.com Hello! I am a japanese student in Omaha, Nebraska, and doing research about Juguar Auto Inc… My question is how i can find information of Juguar. 1. the number of Juguar’s cars sold in the US before and after Ford’s acquistion of Juguar 2. this acquistion of Juguar was advantage for Ford? 3. if 2 is no, and then why it wasn’t If u know anything about Juguar company’s financial and organization problems, please tell me know. Thank you for your time!! From Ms. Keiko Yokokawa __________________________________________________________ **************************************** Ana Petrova c/o Peter’s Marina Motors 800 Lincoln Blvd. Venice, California 90291 Tel: 310-399-8313 mailto:petrova@loop.com http://EnglishCars.com ******************************************** From: Randy Wilson randy@taylor.infi.net Date: Sat, 5 Oct 1996 00:42:58 -0400 (EDT) Subject: Re: Jaguar Screen Savers Does anyone know if there are any more Jaguar screen savers for Windows available? I have the XK-8 and the Moss Motoring savers but I would like to find more, especially of all series of the E-types. Speaking of… I’ve been looking for some time for pictures/posters of the 78 SCCA Trans-Am champ Group 44 XJS. At one time there was a promotional picture of this car coming out from under the bridge at Road Atlanta, with air under those huge front tires. An awesome shot! If anyone spots any bitmaps of this car, or the Europian equivilent TWR cars, would you kindly point me at them? Randy K. Wilson randy@taylor.infi.net From: “Michael P. Neal” mneal@wco.com Date: Fri, 04 Oct 1996 22:20:21 -0700 Subject: Re: I rode in an XK8 Oh yeah, well I’ve driven three of them so far. This car is the best package Jaguar has ever put together. A little more aggressive power delivery would be good but it is more than adequite. The handling is excellent. Cars are made to be driven so I made sure that the limits were being approached. Of course I wouldn’t recommend this without the years of experience and track time. I’ve considered putting together an in car video for those of you that are XK8 deprived, anyone interested? Kroppe wrote:
Hey folks -
We just ran to get petrol and back.My impressions:
- Excellent powertrain isolation/refinement.
silky smooth power delivery.- Veneer is brilliant. I love the huge slab
positioned minor instruments.- Silent operation of convertible top mechanism.
- Very good underbonnet appearance. One list
spark plug wires in the traditional sense.More to come when I get a “proper” evaluation.
Michael P. Neal ASE Master Technician, Jaguar Certified
'93 Ducati 900SS '83 Porsche 944 '85 Jaguar XJS
Home (707) 829-8464 Work (707) 577-0101
http://www.wco.com/~mneal (always under construction:-)
Date: Sat, 5 Oct 1996 10:22:27 +1000
Subject: Re: Are Jags Sexy?
Obviously the first husband didn’t have a Jaguar!
RKPUTTY@MAIL.EISA.NET.AU
From: Makoto & Ann Sado Honjo fm7m-hnjy@asahi-net.or.jp
Date: Saturday, 5 October 1996 1:08My ex secretary (who has since become a forex dealer, been married,
a guy on a Jag tries to pick me up, I’ll just say ‘Yes, yes, yes.’”Makoto Honjo
Date: Fri, 4 Oct 1996 23:07:12 -0700
Subject: XK8 Test Drive
Unfortunately, I wasn’t able to attend the XK8 “opening” in the San Jose
area Thursday night, but it’s worked out for the best. Instead of being
one of the throng a late-Friday afternoon visit found a quiet dealership
where spending time with the car wasn’t a problem – including being able
to get a test drive of ~20 miles in a coupe.
After reading the earlier reports from list members (thanks!) and
especially the vague sense of “gosh, it’s not an E-type” I was
concerned that I’d be disappointed in the car. I have no saloon
experience with Jaguars, and save for a recent XJR test drive my sole
prior (and ongoing) Jaguar experience is with a 66 Series I E-type.
After driving it – no, it’s not an E-type. But then, nobody would
build an E-type today either. The E-type is beautiful, but the E-type
is also loud (pleasantly to many of us, but loud nonetheless), hot,
relatively spartan. Pushing the acclerator definitely causes something
to happen now. The manual 4-speed is a smoothly machined precision
instrument. Handling, good, but it wants to go fast more than corner.
Conversation? Difficult. Sound system? Forget it. Environmental
control? Good thing the bay area just has a civil temperature range to
begin with.
Don’t get me wrong – I love my E-type, I’ll keep it forever. (Though,
this morning, having discovered it’s losing brake fluid from somewhere
towards the back, the prospects of having to use the various bleeding
tips posted recently is causing some grinding of teeth…)
But back to the XK8. It’s not the E-type that was built in the 60’s.
But, Is it the E-type one would build today? Pretty close – not even
far off pricewise.
Others have noted that the pictures don’t do it justice – I agree. I
thought I’d find the dashboard “overdone” on the wood – but I didn’t,
it all “fits”. Yes, the louvers are plastic. But you know, the little
metal doors underneath the E-type dash were kind of on the crude side too,
and actually, what else would one do? Wood wouldn’t work, metal’d probably
be dangerous in the event one were actually crass enough to cause the
thing to crash. The leather covered ashtray is, admittedly over the top.
The back end is relatively generic – you can see the XJ220 if you try hard.
But overall the lines are very attractive. Others have noted the fit was
excellent – I agree.
Driving. My chief apprehension was that I just wouldn’t be able to bear
the automatic. In a household where our two daily drivers (generic cars)
and the E-type all have manuals, it would just seem too strange. But,
you know (or maybe you don’t, I didn’t), modern automatics are pretty cool
devices, and certainly the one in the XK8 is very very nice.
The circuit I drove included a local freeway, off onto some roads the
twist and turn into the nearby mountain-like hills. I was able to take
curves warned for 30MPH at 45+, without using the brakes, by manually
operating the left part of the J-gate transmission. On the freeway, in
drive, pushing the pedal caused a nice, smooth delivery of power all the
way up to the legal limit. Well, no, by the time I thought I was at
the legal limit I was about 20MPH beyond it. Very nice. Perhaps not
quite the overall rush that the E-type provides, very nice nonetheless.
On the twists and turns the back end felt a trifle light, but not a squeak out of the tires even while accelerating through the curves. All during which my wife and I were holding a speaking-level conversation which involved the salesperson who’d gotten into the back seat for this adventure. (Frankly, barring an emergency, it’s unlikely I’ll ever ask anyone to sit in the back seat of one again, but it did work out better than I thought it would.) Considering we’ve been semi-seriously discussing carrying a portable aircraft intercom and headsets in the E-type (!), this is a big change. The “it’s not your father’s E-type” postings had me concerned I’d be disappointed – but I wasn’t. In fact I’m quite enthused. Having been test driving this or that over the last several months, if you’re really looking for an E-type that was built today you’re probably not going to get any closer without spending a lot more money, and even then I’m not sure. The infusion of technology is quite remarkable, one of the salespeople I conversed with was brimming with enthusiasm over the sense of being able to claim the leading edge. Well, I have go back to shaking out the furniture to see if any more loose change falls out… End of jag-lovers-digest V2 #406 ******************************** Return-Path: @owner-jag-lovers-di1 Received: (from majordom@localhost) by ekeberg.sn.no (8.7.5/8.7.3/on4) id for jag-lovers-digest-out; Sat, 5 Oct 1996 19:58:31 +0200 (MET DST) Date: Sat, 5 Oct 1996 19:58:31 +0200 (MET DST) Message-Id: 199610051758.TAA21759@ekeberg.sn.no X-Authentication-Warning: ekeberg.sn.no: majordom set sender to owner-jag-lovers-digest using -f From: @owner-jag-lovers-di1 To: jag-lovers-digest@sn.no Subject: jag-lovers-digest V2 #407 Reply-To: jag-lovers@sn.no Errors-To: @owner-jag-lovers-di1 Precedence: bulk X-Newsgroups: mail.jag-lovers-digest jag-lovers-digest Saturday, 5 October 1996 Volume 02 : Number 407 Re: Parts for sale list on the web and Dealer comments Re: XJ40 vs. SIII and beer Re: XK8 XJS Photos XK8 Suspension, plus a little of DB7 Re[2]: Jaguar Screen Savers Re: XK8 vs. Aston-Martin XJ6 S1 interior trim Re[2]: XK8 XJS Re: XK-8 versus Aston-Martin Re: XJ40 vs SIII (the reality) Re: XJ6 S1furflex door trim Re: Beautiful cars. XK8 Re: XK8 vs. Aston-Martin Little things not in the book (XJS V-12) Re[2]: XK-8 versus Aston-Martin From: “Kirbert” palmk@gcn.scri.fsu.edu Date: Sat, 5 Oct 1996 03:51:26 -0005 Subject: Re: Parts for sale list on the web and Dealer comments Jim Isbell: 1) a reason not to discourage posts to this list of parts to trade/sell is that some people dont have access to the web. They only have access to E-Mail. There is always a way. Seem to recall there is some scheme whereby you can send an e-mail request, and the contents of a WWW site will be sent to your e-mail address for viewing offline. Perhaps someone recalls the details. In the meantime, I don’t think positive developments should wait for those who cannot seem to get their connections upgraded. We should still discourage – but by no means prohibit – messages about items for sale, and encourage jag-lovers to seek better access. 2) As to bad comments on service providers. If we just mention those places with which we are satisfied then it means anyone not on the list is either not a good place to go, or has never been tried. This will aleviate any worry about liabel. No, no, no, this is not acceptable! A single bad comment on each would probably kill ALL the listings. Also: One way or another, it won’t be long before these businesses are posting THEMSELVES on the list. Who’s gonna tell 'em they can’t be posted because some jag-lovers say they suck? Nah, a better plan is to post all businesses we know exist. If we cannot say anything bad due to liability issues, say nothing at all, but list them anyway. Remember what I originally proposed: the list is the thing, the comments are optional. I still feel that way, believe it is most important to get the list established, whether or not it includes “recommendations” or “ratings” is secondary. Just a Jaguar owner in a particular area knowing that he may have choices OTHER than the dealer will probably go a long way toward improving service! Kirbert | If anything is to be accomplished, | some rules must be broken. | - Palm’s Postulate From: Robert Bradley Robert.Bradley@bh.eyi.com Date: Sat, 5 Oct 1996 04:01:53 -0500 Subject: Re: XJ40 vs. SIII and beer My first and last comment on an esoteric subject. Lets just say that Jaguars are a bit like beers. There is no such thing as a bad beer, just good beer and better beers. Some are nice when fresh, others age well. Only time will tell. Lets get back to slagging the Taurus and Camry brigade. Robert Bradley. From: mfl@kheops.cray.com (Matthias FOUQUET-LAPAR) Date: Sat, 5 Oct 1996 11:16:02 +0200 Subject: Re: XK8 XJS I did not mean to say that the XJ-S is a sports car. I fully agree it’s GT and I like it this way. I’m just wondering which features make the XK8 a sports car compared to the XJ-S Matthuas From: Fred Bramston fcb@nbnet.nb.ca Date: Sat, 05 Oct 1996 09:23:25 -0300 Subject: Photos I have an original Dealer leaflet of the V12 E-type around here somewhere. (I moved into my new house 3 years ago and still some boxes are packed, due to some more interior finish work required) Complete with specs on one side and 8.5 x 11 photo on the other. When I get that into digital form I’ll forward (both sides) to anyone who E-mails me after I notify the list that it’s ready. Should be pretty good wallpaper or screen-saver. Fred. From: Kroppe kroppe@mich.com Date: Sat, 05 Oct 1996 10:51:21 -0400 Subject: XK8 Suspension, plus a little of DB7 Robert_Abascal@ccmail.orl.mmc.com wrote:
No mention in any
The XK8 has the rear suspension from the XJ6 (X300/XJ40)saloon.
The upper lateral link is the halfshaft (driveshaft) and
the rest of it I can’t describe the details on, because
I’m not an XJ40 expert. It has the “pendulum” arrangement
with the differential.
The front suspension is all-new for the XK8 only. It has
an isolated cast aluminum subframe, (vs. XJS stamped and welded
steel) with round radial rubber mountings at front, and
compression style mounts at the back of the subframe.
The suspension itself is a double wishbone with revised
geometry vs. XJS and XJ6.
DB7 has the XJS front and rear suspension lock, stock
and barrel. This means it has 4 rear shock/spring
assemblies, and isolated rear cage and two radius arms.
Stamped/welded front subframe with double wishbones.
I don’t want to tread on any XJS toes, so I’ll let them
speak for the details of XJS suspension, but that’s
what the DB7 has.
Date: Sat, 5 Oct 1996 10:41:33 -0500
Subject: Re[2]: Jaguar Screen Savers
Scan resolution for a full screen image depends on the screen resolution and the
size of the original. For full size 1024x768 wall paper I would need a 10.24" x
7.68" original if I’m scanning at 100 dpi, only 3.41" x 2.56" at 300 dpi. So
the answer is 300 for a small snapshot, 100 for a magazine page. (Magazine
pages generally don’t scan all that well because of the way they’re printed.)
MikeC
______________________________ Reply Separator _________________________________
Author: dlfreeman@ipa.net (Dave & Linda Freeman) at Internet
Date: 10/4/1996 10:06 AM
resolution”.
Date: Sat, 5 Oct 1996 10:49:25 -0500
Subject: Re: XK8 vs. Aston-Martin
Only because A-M is building 200 a year instead of 10,000. If they
were built in equal volumes the A-M wouldn't cost much more than an
XK-8.
MikeC
Author: rpeng@cadev6.intel.com at Internet
Date: 10/4/1996 9:43 AM
an XK8 plus an XJ6!
Intel Corporation
Date: Sat, 5 Oct 96 8:09:14 PDT
Subject: XJ6 S1 interior trim
Hello to you all!
After being in Finland for two months and taking part in my first childs birth
(it is a girl…) I am back in sunny CA. Today is XK Unlimited’s open house,
so my Jag will head towards San Luis Obispo in a few hours.
Anyways, I wanted to comment on David Q’s question about the XJ6 S1 interior:
I think I know what you mean, and I have a strong suspicion that the part
you want is called furflex (at least in XKU’s catalog) and certainly is avai-
lable by the foot. You can call XKU at 1800444jags and ask them, and they
should be able to help you further. You can try talkin to one of their resto-
ration guys in case the sales guys do not seem to know (this is unfortunately
quite often the case there…). I plan to get the same part today, in fact.
Good luck,
Per
Per Stenius (http://www.ece.ucsb.edu/SQO/Per/)
Office: Room 4158C, Engineering I (for mail use addresses below)
Work: Dept. of Elec. Engr., Box 14 Home: 797 Sequoia Walk, Apt. H
University of California Goleta, CA. 93117, USA
Santa Barbara, CA. 93106 Phone: (805) 685 5357
Phone: (805) 893 8664 Fax: Above number, 10pm-8am USWT
Fax: (805) 893 3262 Email: per@quantum.ece.ucsb.edu
Date: Sat, 5 Oct 1996 11:08:45 -0500
Subject: Re[2]: XK8 XJS
This is a Mime message, which your current mail reader
may not understand. Parts of the message will appear as
text. To process the remainder, you will need to use a Mime
compatible mail reader. Contact your vendor for details.
–IMA.Boundary.508825448
Content-Type: text/plain; charset=US-ASCII
Content-Transfer-Encoding: 7bit
Content-Description: cc:Mail note partI would imagine that most E-Type series 1 owners will cheerfully point
out that it was the last sports car Jag built. Series 2 owners will
argue the point, but I think that most Series 3 owners would concede
the point. I’ve owned a Series 3 E-Type for 22 years (and an XJ-S for
over 8), but neither is really a sports car in the classic sense. The
early E-Types could go directly from the showroom floor to the track
and be competitive. With no more preparation than modern “showroom
stock” class car they could win in major events. The Series 3 was
more of a GT. Too heavy, A/C for us pampered Americans, automatic
transmissions. I think the main reason for its existence was as a
rolling test bed for the V-12 intended for the XJ-S and the sedans.
Just like the XJ-SC was the test bed for the AJ-6 for several years
before it went into volume production in the XJ-40. The XJ-S is a
good car that is a luxury touring car. If it didn’t suffer from the
3-speed GM automatic it would be a great car.Yes, both the Series 3 E-Type and XJ-S were successful racers. But
only after considerable reconstruction by very experienced and well
backed teams.MikeC
Author: mkenrick@golder.com (Michael Kenrick) at Internet
Date: 10/4/1996 10:19 AM
hehehe
Michael Kenrick
–IMA.Boundary.508825448–
Date: Sat, 5 Oct 1996 11:32:06 -0400
Subject: Re: XK-8 versus Aston-Martin
On Oct 3, 10:17am, Mike Cogswell wrote:
Subject: XK-8 versus Aston-Martin
And best of all, the A-M has a 5-speed! If A-M (not to mention Ferrari) can sell expensive 2+2 GTs with a 5-speed, why in the hell can't Jaguar
I agree, but A-M is not planning to get many orders (if any!) for the 5-speed,
the Jag has no manual box because their research showed that they would also
sell almost none of them. So why spend the development money? Blame the
customers.
The rear
end is an absolute slam dunk in favor of the A-M.
The designer of the DB-7, Ian Callum, is a friend of mine. I literally dropped
him at Walkinshaws door (near Oxford) in 1990 when he left Ford to work on the
DB-7 (then I drove his Escort Cabriolet lease car back to Dunton to turn in).
He is a great guy and a great designer. I worked for him at Ghia (Italy) in
1988 and again at Dunton, England in '90. I now work for his little brother,
Moray. Moray did the Ghia Vignale. In fact, Moray is standing next to my desk
not knowing that I am writing about him and his brother. But, this said, I
disagree on the rear of the DB-7 being better than the XK8. Over all I’d still
take the DB-7 over the XK8, but I do not like the filler around the DB-7s tail
lights. The XK8 is a nicer work out. I followed a BRG convertible XK8 around
Dearborn a week ago and I think it looked very good. In the studio I did not
like the rear bumper work out, but on the road it really does look good, and I
firmly believe it is every inch a Jaguar. The car really impresses me. Like the
Etype, I do think it looks best in dark colors.
Featured with the two XK-8s was a “never-been-titled” '74 E-Type OTS…
Careful, the S3s are an easy target. The Etype did not grow old gracefully and
the S3 is proof. The list of design indignitys that the Etype suffered in its
final form is too long to enumerate, to say nothing of its regression from
sports car to “boulevard cruiser”. My father has one. Sorry, but I’d take the
XK8.
These are my opinions - not Fords(!).
Mark McChesney
S1 Etype ots
Date: Sat, 5 Oct 1996 11:50:54 -0400
Subject: Re: XJ40 vs SIII (the reality)
Mike Cogswell wrote:Having said that, I can state without reservation that the XJ-6/12 >Series
III is obviously the most beautiful Jag sedan ever produced.I am sorry guys (and gals) but I can remain silent no longer.
The MK II is the most beautiful Jag sedan ever produced.
IMHO you are right. The XJ6/12 (S1,2,or3) comes in a close 2nd!
Mark McChesney
Date: Sat, 05 Oct 1996 11:14:31 -0600
Subject: Re: XJ6 S1furflex door trim
At 08:09 AM 10/5/96 PDT, Per Stenius wrote:
Hello to you all!
Good luck,
Per
Yes, I believe that he is also referring to Furflex…although if you do not
like the fuzzy seal, then an alternative without the fuzz is available
usually by the yard or foot. XKs may offer the alternative too. My company
also sells this type of product too should anyone be interested.
Best Regards,
Hal
Hal Rogers
H.D. Rogers & Sons
(318) 742-5044 fax
Date: Sat, 5 Oct 1996 12:19:01 -0400
produced. Not a regular car, but gorgeous all the same.David Brown,
brownd@ml.com
Bill Borden, who is a former list member (and another Ford stylist), is a very
SERIOUS C-type fanatic. Bill is retiring soon and we (the studio) would like to
buy him a scale C-type, but I can’t find anything larger than 1/43. Anyone know
of anything in say a 1/18th??? Bill owns an aluminum body XK120 - full
Thanks
Mark McChesney
Date: Sat, 05 Oct 1996 10:17:11 -0700
Subject: XK8
Luckily there is a series of racetrack type corners several miles from the
dealer. As I was hustling the car through them I noticed that it felt like
the car was steering from the rear. It seems that the rear suspension
bushings could be a little firmer to prevent the rear geometry changes that
are allowing this to happen. The XJR has the same rear suspension and
tires, the next chance I get I’ll have to test it through the same area.
The 94 XJ12 motor, pre OBDII, has the most power so far. The low end
torque and the raw feel can almost edge out the XK8 V8. I think that the
XK8 has full time traction control because it is very difficult to get the
tires to break loose at low speed. The XJR and the XJ12 have switchable
traction control and you have to be cautious with the throttle when you
have it turned off.
Date: Sat, 05 Oct 1996 10:23:08 -0700
Actually it would probably cost a lot less. The A-M uses a lot of Jag
parts. The problem is that they are not the latest generation, more on par
with a '94 car before the X300 came out. They will still sell ok just for
the collector value. There are several good web sites for the A-M if
anyone is interested at taking a look at them.
At 10:49 AM 10/5/96 -0500, Mike Cogswell wrote:
Only because A-M is building 200 a year instead of 10,000. If they were built in equal volumes the A-M wouldn't cost much more than an XK-8. MikeC
Date: 10/4/1996 9:43 AMI remind everyone that the Aston Martin cost almost as much as
an XK8 plus an XJ6!–
Intel Corporation
Date: Sat, 05 Oct 1996 11:33:04 -0500
Subject: Little things not in the book (XJS V-12)
Here is an example of the types of things that Haynes leaves out of their
manual.
They assume that any work on the timing chain will be with the engine on the
bench and open so they dont even mention the “timming chain tensioner plug”
on the front of the block.
I had the water pump off so decided to replace it while in there. I had no
idea that there were two types of plugs, or so it seems. The replacement I
got from the shop was rubber and soft. The one I am trying to remove is
hard plactic and very brittle. Everytime I touch it another piece falls off
and I cannot seem to remove it.
It appears, if the hard one is shaped like the soft one, that it should
probably be rotated to the left and then pulled straight out. There appears
to be about 160 degrees of rotation possible, but the tabs are broken off so
I am just guessing that the tabs once rotated from vertical at full
counter-clockwise to almost back to vertical at full clockwise.
Which way is out?
I would try to break it up if I was sure I wouldnt drop pieces into the
crank case. But I am not sure of that and in fact am sure some of it would
fall in.
At present the taps are off so it will push in about 1/2" and pull out until
the interior tabs hit, so it isnt stuck, just not oriented to pull out.
It aparently was leaking because the PO had put locktite sealant all around it.
Anyone know how to get this damned thing out? My reassembly is held up
until I find an answer. There goes the week end because no one is watching
on the week end so I wont get an answer till Monday!
Kirby, If I get an answer to this it needs to be in your book!
Jim
“Better an outlaw than not free.”
Nance O’Neil
Date: Sat, 5 Oct 1996 13:45:09 -0500
Subject: Re[2]: XK-8 versus Aston-Martin
- –IMA.Boundary.661835448
If they aren’t planning on building any 5-speeds, and their volumes are
going be be about 2% of the XK-8 volume, then how do you explain A-M
spending the development money for a 5-speed? Any why have the DB-7s I’ve
read about had manual transmissions? The R&T road test makes no mention of
an automatic even being available in the DB-7.
I’m not surprised a Ford designer would prefer the XK-8 rear. Do your
desks also look like jellybeans?
As for the E-Type. I’m not the one who had it on the floor next to the
XK-8s. Nor will I waste my time trying to argue that the Series 3 E-Type
is the pinnacle of automotive styling. It’s a beautiful car in many ways,
but I agree completely that virtually every styling change made from '61 to
'74 was a step away from the purity of the original design. (And I’ve
owned a '74 E-Type since it was new.) My point was clear. A big chunk of
the target audience spent most of their time looking at the E-Type instead
of the XK-8.
MikeC
Author: “Mark McChesney” mmcchesn@ford.com at Internet
Date: 10/5/1996 11:32 AM
customers.
I disagree on the rear of the DB-7 being better than the XK8. Over all I'd still take the DB-7 over the XK8, but I do not like the filler around the DB-7s tail lights. The XK8 is a nicer work out. I followed a BRG convertible XK8 around Dearborn a week ago and I think it looked very good. In the studio I did not like the rear bumper work out, but on the road it really does look good, and I firmly believe it is every inch a Jaguar. The car really impresses me. Like the Etype, I do think it looks best in dark colors.The rear
XK8.
Mark McChesney
S1 Etype ots
- –IMA.Boundary.661835448–
End of jag-lovers-digest V2 #407
id for jag-lovers-digest-out; Sun, 6 Oct 1996 22:10:40 +0200 (MET DST)
Date: Sun, 6 Oct 1996 22:10:40 +0200 (MET DST)
Message-Id: 199610062010.WAA06987@ekeberg.sn.no
Subject: jag-lovers-digest V2 #408
Precedence: bulk
jag-lovers-digest Sunday, 6 October 1996 Volume 02 : Number 408
Beer and Jaguars
XK8
Re: Most Beautiful! XJ40 vs SIII (the reality)
Start&Stop-More Data
oil pressure
Re: Power window conversion
Jag owners are such nice people!
Re: 1990 XJS clicking sound
sir william at 50 rpm
oil pressure
jJaguar Images
XJ6 S1 furflex…
Re: Little things not in the book (XJS V-12)
Re: RF Modulation CD Player units
Re: XK8 XJS
Buying an XJS
XJS timming chain tensioner plug
“Your Bleedin’ Heart (read E-Type brakes)”
Date: Sat, 05 Oct 1996 14:00:40 -0500
would probably kill ALL the listings.Also: One way or another, it won’t be long before these businesses
You were not listening to what I said.
I didnt say a bad comment should remove a listing, I said there should be no
bad comments. In other words if you cant say something good, dont say
anything at all.
This would mean that everyone whould have had a bad comment to keep a name
off the list. Or in other words If one person had a good comment the name
would be on the list, with that good comment. If a name was missing because
no one had anything good to say, it would be telling in its absence.
As to your comments on the people who dont have web access, I find that
rather snobish. Some people, either for reasons of cost or for reasons of
location do not have the access.
I, for one, want to reach the largest audience if I am selling ot trading
something and will therefore continue to post to the list because I dont
want to miss a potential customer!! In the future PERFECT world where
EVERYONE has a web browser I will follow your lead.
The WEB is not the “be all and end all” of the internet. It is a small
percentage of the internet. E Mail is a much larger and more important part
of the internet since it fosters direct interaction between people around
the world. The WEB is the Disnyland of the internet. Dare I say MM?
Jim
Nance O’Neil
Date: Sat, 05 Oct 1996 14:10:25 -0500
Subject: Beer and Jaguars
I personaly think there is no such thing as a Good beer. I have never seen
what one can see in something that tastes like it has already been drunk by
another person.
I find Burbon and good wine to be very tasty, but beer is bitter and salty.
Jim
Nance O’Neil
Date: Sat, 5 Oct 1996 16:27:55 -0400
Subject: XK8
Hiya XK8 fans,
I’m glad that most of you have now either driven one or at least drooled over
one. Anway, I have got around to creating an XK8 website with bits and bobs
on it. I intend to add more information as and when Jag release it. The
current down side was that my scanner decided to play up so the pics are not
the best, but as soon as I get better scanned images I will replace them.
keep drooling
Tez
Superduper V8 fitter
Date: Sun, 6 Oct 1996 07:11:08 +1000 (GMT+1000)
Subject: Re: Most Beautiful! XJ40 vs SIII (the reality)
For a modern car the Mk2 is wonderful but for real beauty the SS100, 3.5
saloon and Mk4 cannot be surpassed.
Or the Daimler low chassis Doulbe Sixes from 1930?
Historic perspective seems lacking.
Now for the worst boot, backend it would have to be the DB18 Daimler or
was it the XJS?
/dlh.
David Hallam http://www.uq.edu.au/`qmdhalla
Senior Scientist
Materials Conservation
Queensland Museum d.hallam@mailbox.uq.edu.au
*** Without Treatment Development our past can only rot ***
____ Daimlers can be fun too! _____
Date: Sat, 5 Oct 1996 20:39:24 -0400
Subject: Start&Stop-More Data
Thanks for the comments on the starting & stopping XJ6. I am
gald to know I am not alone. I had some time this afternoon, to
work on it a bit more. I hope this addiitonal data will strike a
chord in someone’s memory, and I can add to my list of things to
try.
This is a 85, Series III, 4.2 fule injected (and very pretty in
BRG.) The car starts promptly, after a few cranks, and runs at
about 1000RPM. It runs smoothly and then begins to settle down
to 800 and then 700 RPM. When the temp gets just above 50, the
car settles down to its idle, at abount 500RPM. But then it dies.
I drove it around the block and it died going down the hil, as I
took my foot off the accelerator. I got it restarted and got it
home by keeping the gas on. Once in the garageI blocked the
accelerator, so that the engine stayed at 1000RPM. I could not
get the temp up to 90, but when it got to about 75, I took the
block of the accelerator and it idled down just fine. It ran for
about five minutes that way, stumbling a bit – but it always
did. I finally turned it off, wondering what causes the problem
in the warm, not hot, not cool range.
While it ran, I put my head in the trunck to listen to the fule
stuff: There is a steady buzz, and a not-so-steady ca-wish, or
something like that. I assume the buzz it the fuel pump? I
assume the stumbling ca wish, or gurgle, is the return valve,
accepting the overrun gas from the rail? Or is the stumbling
gurgle a sound like a bad fule pump?
My mechanic suggested that i first change the fuel filters, and I
will do that this week. But it is hard to accept the idea that
it might be fule related when it starts every time, even when
warm, and that it seems to run well when hot.
Any suggestions for leads will be greatly appreciated.
Bob Sack
1985 XJ6
1959 XK 150
Robert J. Sack
phone 804 924 4814
fax 804 924 4859
Date: Sat, 05 Oct 1996 21:15:48 -0700
Subject: oil pressure
Oil Pressure on E types
I have rebuilt engines on XK’s and E type prior to 1965.The oil pressure
relief valve is very soft and seems to wear excessively and leaks
pressure. If I can’t replace, I lap the valve head into the seat with
fine valve grinding paste and shim the spring to give 55-60 lbs. pressure
at 3000 RPM. Various grades of oil seem to only change the pressure at
RPMS less than 1500. My XK140 with about 2000 miles on rebuilt engine has
about 30 lbs. At idle and 58-60 at normal highway speeds. Prior to
rebuild I have used 10:40, 20:50 and 30. No difference on highway speed
oil pressure. The Jag oil pump is able to produce more pressure and
volume than the engine will need and if you exceed about 60 lbs. the cam
chambers will fill up with oil and won’t drain back until the RPMs
decrease below about 1500. An accurate test is to install as oil and
temperature gauge. If you have a sudden climb in oil temperature after
reducing the RPMs it will indicate a hot oil gush down from the top end.
I have an increase of about 20 degrees F. and I think this is OK. I have
examined XK engines that have been using #30 and 20:50 oil and have found
excessive wear on the front cam bearings ---- the last to get oil feed. I
have recently changed to Castrol Syntec 5W50. Hoping that the lower
viscosity cold will get the oil to the bearings sooner. I have noticed
that I have increased manifold vacuum, lower oil temperature and an
increase of about 200 RPM.
I have heard recently that Porche has recommended the use of synthetic
oil in their ugly little cars-----but the Germans are good mechanics.
Possibly consider synthetics as a way of getting more mile out of our
cats. My last oil and filter change cost more than my first car (Ford)
but I think it will be worth it in the long run.
There seems to be a lot of strange electrical problems with recent Jags.
Anybody consider an exorcism? I thought about this with a Dodge I once
had.
Bill Schorse Ontario Canada
canoe@onlink.net
Date: 03 Oct 96 06:04:51 EDT
Subject: Re: Power window conversion
Shene,
I dont know how the window wind mechanisms work on a 420 G.
The XJ6 El windows is not consisting only of the motor itself but also of the
gear mechanism, which basivallu lifts the window with a lever arm that
slides in a list at the bottom of the glass.
Additionally there is a wire system with rollers inside another (stationary)
frame lined with felt with guides the sides of the window.
You can maybe cut and paste all this to fit inside the door of the 420G, but I’m
sure thatt is a major task.
I think you would be better off trying to obtain an external motor and gear
assembly
at the size of a large sigarette pack which fits flat and snugly over the manual
handle
shaft. These can be found as general upgrade kits not necessarily associated
with jags.
If you dont like this the next best is to fiddle something inside the door
using
the existing lever system and the XJ6 wind motor.
Have never tryed this, seems you get the chance to pioneer this task.
Regards Jeffrey Gram
Date: Sat, 05 Oct 1996 20:23:56 -0700
Subject: Jag owners are such nice people!
I met a fellow E-Type owner this afternoon. My wife and I had been out
shopping and as we were coming home, she spotted a beautiful Regency Red
70 E-type FHC in a local donut shop parking lot. I made a U-turn and
pulled in next to the car. It had an Arizona personalized license plate
“70 JAG”. It appeared to be in Concours condition. I went into the
donut shop, asked who owned the E and introduced myself. We sat and
chatted for at least 15 minutes.
He has owned the car about two years and didn’t know the first thing
about them when he bought it! He was attracted by the looks and bought it
two days later. He still doesn’t know much about them mechanically and
takes it to a local mechanic to have any repairs done. His biggest
complaint is that no matter how trivial the problem, it always seems to
cost at least $200 and take a month to get the part. Never the less, he
wouldn’t sell the car for any amount.
When was the last time you saw a “lump” in a shopping center and wanted
to meet the owner?
Date: Sun, 6 Oct 1996 00:52:16 -0500
Subject: Re: 1990 XJS clicking sound
Sorry for the shotgun reply but my email gateway has lost the senders address.
However maybe someone else can answer the question on more durable front, top
shock absorber mounts.
Somebody with a recently acquired XJS asked:
This is unlikely to be the shocker, just the top shocker mount. The
underneath pad tends to go first hence making it less obvious. I have now
replaced 7 out of 8 pairs of these on the 4 cars I have (or had). They seem to
go through them faster than nappies in a maternity ward/condoms in a whorehouse
(choose prefered analogue). On that note I don’t know if there is an after
market alternative available which is more durable but doesn’t affect the quiet
factor - try your local Jag parts supplier.
Robert Bradley
82 XJ, 82 Daimler, 87 XJ-S (still in workshop, I’m pining)
Date: Sun, 6 Oct 1996 10:07:50 ±800
Subject: sir william at 50 rpm
yep ole’ sir william must be spinning in his grave…he achieved his =
intended purpose…to design a car that we would lust after, yet still =
afford. Here we are arguing which looks the best…the guy was a =
genius! I know he didn’t do the later stuff, but who ever did had =
his/her finger on the pulse of guess who…John Shuck, Beijing, xk120, =
e-type, others, plus 2 wheel brit stuff…
Date: Sun, 6 Oct 1996 10:46:59 -0400
Why did the oil pressure at cruise on my 66 E type go up 5 psi when I put
more oil in ? : 10 qts instead of 9. ( 8.5 liters - 9 US qts is specified for
oil fill ) 11 qts is necessary to fill to the top dipstick mark . The oil
pump pickup should be covered either way. Motor recently rebuilt.
Doug
Date: Sun, 06 Oct 1996 11:13:01 -0400
Subject: jJaguar Images
There is a very nice downloadable high resolution image on the XKs Unlimited
Net site which I use as wallpaper - it features an SS100, XK-150 DHC and a
Series I ETYPE grouped together in an English manor house courtyard.
Date: Sun, 6 Oct 96 8:33:28 PDT
Subject: XJ6 S1 furflex…
Hi! I commented on David Q’s mail earlier and suggested that the stuff he is
after might be called “furflex” (ie. the molding that goes around the door -
but not the posts - of an XJ6 S1). Well, when I visited XKU yesterday it turned
out that furflex will NOT do the job, and that this part is not really availa-
ble (at least not at XKU or any other source I know) except in black…
Hal Rogers siad he sells this product, but I am not sure whether he meant
furflex (which works fine for earlier models, but apparently not for the XJ6
S1) or something that would work for the XJ6 S1. Any comments Hal?
Date: Sun, 6 Oct 1996 12:44:52 -0400 (EDT)
Subject: Re: Little things not in the book (XJS V-12)
Jim: The plug that you are trying to remove was once soft and made of
rubber, now you see what heat will do over a period of time. Just keep
digging at the thing that is the only way to get it out. Then apply a
thin coat of GM Gasket Sealling Compound part No. 1050026( stuff never
gets hard) and press in the new plug and you are good to go.
Chad Bolles Jaguar South 306 Valcour Rd Columbia SC 29212 USA 803 798 3044On
manual.They assume that any work on the timing chain will be with the engine on the
on the front of the block.I had the water pump off so decided to replace it while in there. I had no
and I cannot seem to remove it.It appears, if the hard one is shaped like the soft one, that it should
counter-clockwise to almost back to vertical at full clockwise.Which way is out?
fall in.At present the taps are off so it will push in about 1/2" and pull out until
the interior tabs hit, so it isnt stuck, just not oriented to pull out.It aparently was leaking because the PO had put locktite sealant all around it.
on the week end so I wont get an answer till Monday!Kirby, If I get an answer to this it needs to be in your book!
Jim“Better an outlaw than not free.”
Nance O’Neil
Date: Sun, 6 Oct 1996 09:58:33 -0700 (PDT)
Subject: Re: RF Modulation CD Player units
At 1:17 PM 9/25/96, Kirbert wrote:
Just a side note: Have you guys noticed that portable CD players are
now available for under $200 that come with 10-second buffers and a
kit to connect to a car stereo? Just plug in, set on the seat,
console, floor or in the glovebox.
Unfortunately, none of them’ll work with the 8 Track player in my XJ6C like
a trunk CD changer would. We got a portable player (Sony) for my wife’s
minivan that works pretty well. Sound from the lousy British Leyland 8
Track wouldn’t suffer much in any event from something coming in over the
FM band. On second thought, reading what I just wrote, the 8 Track’s
coming out & getting wrapped up. That way I’ll have it in the unlikely
event that XJ6C’s with original 8 Tracks become a “hot ticket.” Certainly,
the 8 Track’s not worth more than a buck or two at a garage sale anyway.
-Steve A.
'67 E Type Coupe
'76 XJ6C
'91 XJ40
Date: Sun, 6 Oct 1996 15:19:49 -0400
In a message dated 96-10-04 03:52:24 EDT, mfl@kheops.cray.com (Matthias
FOUQUET-LAPAR) writes:
<< I’ve read several times now that the XK8 is finally the first real
sports car after the E-type. Being somewhat biased to the XJS, which in my
eyes
is a very beautifull sports car, I am wondering what makes the XK8 a sports
car
compared to the XJS. Is it :
racing success (have not seen any XK8 race yet)
performance (the numbers HP and torque seem to better for the V12)
transmission (at least the 3.6/4.0 ltr models had an optinonal manual
option) -
weight (due to “non-sport” extras like A/C etc)
XJ-S not having fancy leather-covered ash trays
Matthias
1988 XJ-S V12 (and if I had the money, my additinal car would be a XJ-S
cabriolet. V12 of course)
I have to add a strong second to this posting. After driving the XK8 for
about an hour I have to say that there are many things about my XJS
convertible which I like better.
On the good side:
I was relatively impressed by the XK8’s finish (though the badge on the front
hood was quite crooked and it seems that no thought went into where the front
license plate would mount (for those places with two plates).
It’s great that you can open and close the convertible top without bringing
the car to a full stop.
The electronics were nice and the sound system more than adequate.
On the down side:
I thought the acceleration was moderate off the line (fairly typical Jag
automatic). My 4.0L XJS feels stronger.
While the car handled nicely in tight highly accelerated turns (over 60mph) I
thought the steering felt a bit unsure as compared with my XJS in similar
situations.
And finally, while the styling is quite striking, it does seem to have that
Ford Taurus look from the rear. The XK8 could be mistaken for other model
vehicles. Nobody seems to ever have a problem recognizing an XJS. It’s
styling remains distinctive and polished.
I believe that the XK8 will certainly be a hit. The dealership I was in had
already sold the seven cars they’d received for a substantial “over list”
markup. On a personal level, I think the car has a ways to go to live before
it lives up to its heritage.
Jonathon Shevelew
'95 XJS 4.0L, Conv.
'93 XJ40 VDP
'96 Explorer (something the kids can get dirty)
Date: Sun, 6 Oct 1996 20:19:55 +0100
Subject: Buying an XJS
I`m about to buy my first Jaguar , an XJS 3.6. Can anyone give me some pointers
as to what to look for when buying one ie rust problem areas, mechanical checks,
oil pressure,etc
I`m looking for one around 1988 (UK model).
thanks alot in advance.
Paul Rance paul@rance.u-net.com
WWW: metro.turnpike.net/P/paulr/index.html
Date: Sun, 06 Oct 1996 13:38:01 -0500
Subject: XJS timming chain tensioner plug
I got it out!
The method is to drill a hole in the center of the plug with a small drill.
Large enough to push a nail through. Then get a long nail (3") and bend the
end (1/3") into almost a hook, about 80 degrees of bend.
Push the end of the nail into the hole and rotate it till it can be used to
pull on the plug. Now pull out pieces of the center of the plug untill
there is a fairly large hole in it. This releases some of the tension that
holds the sides of the plug outwards. As the hole gets bigger you can bend
the nail into a real hook to make sure any pieces fall outside rather than
inside. Now use a flat bladed screwdriver to pry the thing out.
Strangely, it is the outside of the plug that hardens and the interior parts
are realatively soft yet whhich leads me to believe that it is under hood
temps, not engine temps that harden the plug.
I am thinking of removing the plug and cutting the interior tabs off of it
then it would pull out readily. To hold it against any positive crankcase
pressure I will build a small bracket that will press very lightly on the
top of the plug and be held into position by a bolt on the water pump.
Kirby, add this to your book!
Jim
Nance O’Neil
From: rrichardson@eurekanet.com (Robert J. Richardson)
Date: Sun, 6 Oct 1996 16:12:37 -0500
Subject: “Your Bleedin’ Heart (read E-Type brakes)”
Bear with me because this intital paragraph will lead to the essentials of
the removal and refitting of E-Type master cylinders and the “simple” task
of bleeding the front and rear brakes.
I have the Jaguar Shop Manual for my 1964 FHC and long have considered it a
valuable asset in maintaining a 32-year-old machine. Before I moved
back to this small Southeastern Ohio village (to prepare budding
journalists for a life of deadlines and small pay raises), the shop manual
was perused primarily for reading pleasure. In Florida I had mechanics who
restored Deusenbergs and ancient Rolls; they used shop manuals primarily to
check tolerances.
So when recently I discovered a puddle of brake fluid under the Jag, I
opened the good old manual and read that removing the master cylinders (the
bottom one was spirting fluid through a ragged rubber dust extruder) was
the simple task of unfastening the metal brake fluid pipes and then
removing four bolts and a rod secured by a clevis pin. Simple task! Not on
your life! Many sweaty hours later (my left lower arm and hand a bloody
mess due to sharp metal protrusions and my being one of those “Zipper” guys
like Larry King on blood thinner for life) and I finally had the master
cylinders packed for shipment to Imperial Machine in Lincoln, NE, for
resleeving with stainless steel. The bottom one was leaking brake fluid,
but at $60 for resleeving I figured having the top one also resleeved would
be a good investiment. The stone guard beneath the master cylinders and
manifold was now rust free forever with its liberal coating of brake fluid
and water-thin blood.
I concluded that the shop manual author had to have a masochistic bent to
say in words to this effect, “remove the two lower bolts secured by lock
nuts, remove the clevis pin with a suitable device and withdraw the master
cylinder.”
Lesson learned: A skilled mechanic with the proper tools (and no shop
manual) could have done the job in 30 minutes or less. However, in my small
town I couldn’t find a mechanic, skilled or otherwise, willing to work on
my “furin” car.
Then I read the instructions on the bleeding of the rear and front brakes.
Simple. Unscrew the bleed nipple one turn on the brake farthest from the
master cylinder… You guessed it. The writer had observed this being done
by a factory mechanic while the rear suspension was out of the car and
inverted to boot. Nice shiny, new bleed nipple right out there where it
could be turned with a garden-variety open-end wrench.
I now realize I had made two major mistakes: 1) I trusted the bleed
directions in the manual and 2) based on this information, I had purchased
metal ramps instead of a floor jack and jack stands in order to gain crawl
space under the rear of the E-Type. Today, trouble light in hand, I managed
to barely squeeze my head past the exhaust pipes to get a close look at the
bleed nipples. Yes, I could see them, barely, but the front coil springs
and dampers blocked the use of any known wrench. And the car being on ramps
probably means that these units can’t be removed to gain access to the
bleed nipples.
So, take this bleedin’ advice about bleeding brakes: If you aren’t a
skilled restorer type with all the proper tools including jack stands, find
a mechanic who has worked on Jags, is good on working on Jags and likes to
work on Jags. Pay him whatever his going rate and feel blessed that he
exists.
My only recourse now is to install the resleeved master cylinders (I can
wrap my arms and kick the Coumadin for a week) and bleed the front brakes
(served by the lower master cylinder) with a one-man bleed kit. This should
give me enough stopping power to sneak up to Columbus, Ohio, in the
pre-traffic wee hours of the morning where there is a Jag dealer who’ll hit
me with $55 an hour for labor. And while he’s at it, he can adjust the
clutch slave cylinder for 1/16" clearance and rebleed the front brakes as
well. A shop manual may provide a quick fix for the gifted Jag addict with
a well-equipped shop, but it may be a a booby-trap for a novice mechanic
such as I.
End of jag-lovers-digest V2 #408
id for jag-lovers-digest-out; Mon, 7 Oct 1996 15:44:35 +0200 (MET DST)
Date: Mon, 7 Oct 1996 15:44:35 +0200 (MET DST)
Message-Id: 199610071344.PAA28811@ekeberg.sn.no
Subject: jag-lovers-digest V2 #409
Precedence: bulk
jag-lovers-digest Monday, 7 October 1996 Volume 02 : Number 409
Re: Start&Stop-More Data
Parting out Jaguar MkII Saloon
Parts Wanted-Jag MKII saloon
Request for information: SS100
Re: oil pressure
Behind the wheel of the XK-8 cabriolet
Jaguar Sheepskin Covers
XK-8s at Sebring
Re:RF Modulation CD Player units
Speedo Recalibration
scary Jaguar problem
Dealer listing
S type questions
V12 exhaust system
XJ6 Series III Door Disassembly
XK-8 (little jag content)
Wrinkled Wing
Re: XJS timming chain tensioner plug
Date: Sun, 06 Oct 1996 16:23:52 -0500
Subject: Re: Start&Stop-More Data
try.This is a 85, Series III, 4.2 fule injected (and very pretty in
in the warm, not hot, not cool range.While it ran, I put my head in the trunck to listen to the fule
gurgle a sound like a bad fule pump?My mechanic suggested that i first change the fuel filters, and I
warm, and that it seems to run well when hot.Any suggestions for leads will be greatly appreciated.
Bob Sack
1985 XJ6
1959 XK 150Robert J. Sack
phone 804 924 4814
fax 804 924 4859
500 RPM is too slow for the idle speed, assuming you mean this is the
idle speed with air off & gearbox in neurtral. Under these conditions
the idle speed should be right around 800 RPM. With mine set like this,
it idles around 600 RPM with air on and in gear. Try turning the idle
set screw to speed up your idle a bit and see if this helps.
Steve Coleman, Gadsden, AL
1987 XJ6 x2
Date: Sun, 06 Oct 1996 17:21:33 +0000
Subject: Parting out Jaguar MkII Saloon
I am parting out a 1961 Jaguar Mk2, 3.8 engine, 4-speed transmission,
automobile. Many good parts, reasonable. contact me by phone
- -215-572-7626 or by e mail- lseidman@erols.com
Lenny Seidman
Elkins Park, Pennsylvania, USA
email: lseidman@erols.com
Date: Sun, 06 Oct 1996 17:24:27 +0000
Subject: Parts Wanted-Jag MKII saloon
Need the following parts for my 65 Jaguar MkII Saloon:
- Screw top lid assembly w/ rubber flap (and motor?) for large square
glass windshield washer fluid resevoir
Jack handle( it rachets)
Looking to purchase or can trade other parts.
Contact by email below
Lenny Seidman
Date: Sun, 6 Oct 1996 18:37:32 -0400 (EDT)
Subject: Request for information: SS100
A friend of mine who lives in upstate New York has told me about a
potential dream come true. A neighbor (and car collector) of his died
several years ago. His wife is now getting ready to sell off his stuff.
Among his collection is a car which my friend believes is an authentic
SS100, disassembled, in the process of a frame-off rebuild. I hope to get to
see it in the next few weeks. Can anyone help me with specific tips? What
are the strengths and weak points of this car? What is the present market
value? Any info would help.
Michael Frank
1969 E-Type 2+2
Date: Sun, 06 Oct 1996 19:33:01 -0500
Subject: Re: oil pressure
pump pickup should be covered either way. Motor recently rebuilt.Doug
Possibly a small air leak at the upper O-ring of the oil pick up tube.
More oil means less head for the pump, resulting in less entraped air
and higher pressure. What are the pressures, and under what
conditions?
Bob Johnson
Brattleboro, Vt.
S2 E Type, Mk 10
Date: Sun, 06 Oct 1996 23:47:27 GMT
Subject: Behind the wheel of the XK-8 cabriolet
Well, the engine was off…
The XK-8 was shown in Stockholm today.
I sat down briefly behind the wheel of a fine BRG cabriolet.
A very handsome vehicle indeed which I can imagine
would fit me nicely.
The front looked much better in real life than from pictures,
especially the two bumpers in the cat’s mouth looked really Ok now.
They are not made of black rubber.
The Jag people have created something to be proud of, a worthy
successor in style of the XK-E. The Cabriolet is definitely
my favourite with its beautiful roadster body design.
The show car cabriolet had the fine 18" sport wheels.
Minor remark from me is that I find the instruments too
small and recessed, I want XJ6 S1 dials and a Nardi wheel
Too tall owners will not fit into either coupe or cabriolet with
roof on.
It’s time to begin saving up. A reasonably equipped cabriolet
costs 750 000 Skr (Swedish Crowns).
/gunnar XJ6 4.2 S1 '72 (now parked behind garage) Sweden
Date: Sun, 06 Oct 1996 18:16:03 -0500
was it the XJS?
I cant agree. I once owned a 1948 DB18 (about 20 years ago) and I loved the
car. The leather seats were ALL leather, the windshield that opened for
fresh air, that wierd but neat semi-automatic transmission, the jacks built
in at each corner, the automatic chassis oiler, and all those other neat
gadgets that even the newest cars don’t have. I purchased it in Bude for
175 pounds, toured England in it, shipped it to the states for 150 pounds,
and then lost my mind and sold it for a paultry $2500.
It was a beautiful car, the best engineering I have ever seen.
Jim
Nance O’Neil
Date: Sun, 6 Oct 1996 18:13:30 -0700
Subject: Jaguar Sheepskin Covers
Hi all!,
Does anyone out there have the “Jaguar Factory Accessory” Sheepskin
seat covers installed on their car?
I was interested to buy these from the dealer for the approaching cold
weather, and wanted to know how the look in the car (proper fit), and are
they very good quality and soft?
Any idea on a cost for a pair?
I have an 89 VDP, and was wondering how they would look with the rear
lamps and tables, and which color to go with: Sand, or Creme. I have the
light(biscuit?) colour (trim: AEE).
Thanks for any input you can offer!
Eric
cobac@ix.netcom.com
Date: Sun, 6 Oct 1996 21:27:15 -0400
Subject: XK-8s at Sebring
Last Tuesday, October 1st, Jaguar sponsored a publicity event at Sebring
International Race Track with journalists from several different magazines in
attendence. Jaguar also invited some local Jaguar club members and competition
drivers to test drive the XK-8 on the race track.
Jaguar rented Sebring race track and brought five XK-8’s for test driving, three
coupes and two roadsters. They allowed us to run as many individual hot laps as
we wanted with the only requirements that we wear a helmet and seatbelts and
that we make a quick stop in the pits each lap. Were drove the 12 Hour track,
the long track, and there were no restrictions as to how fast we drove or how
hard we pushed the cars.
I was fortunate in that I was able to attend this event with my fellow team
members from Predator Racing, Larry and Debbie Ligas, Ron Evans and Ted Brettner
as well as Tom Palisi the southeast region director of the JCNA, David Hinton of
Twin Cams from Sarasota and Tom Curren of Curren Motorsports from Orlando.
Bob Tullius was Jaguar’s feature guest. He gave rides in his XJR-5. He also has
a hanger at Sebring where he keeps his aircraft colleciton, a P-51 Mustang, T-28
Trojan, PT-19 Stearman, Ryan PT-22 and a Waco by-plane. Mr. Tullis plans to move
his race car collection to his hanger starting with the XJR-5.
Robert E. Berry also made an appearance. He was a Jaguar factory test driver in
the mid 1950’s when the D-Type was in development and he also raced his own
D-Type.
The following race cars were brought to the event:
Larry Ligas and Ron Evans - Predator Performance Racing - Series I
E-Type coupe.
Tom Palisi - XK-120 roadster.
David Hinton - Leaping Cats Racing - XK-120 coupe and Tom Veals XK-120
roadster.
Tom Curren - Curren Motorsports - XK-120 roadster.
Walter Hill - D-Type.
Bob Tullius - XJR-5.
Our day started with a breakfast meeting where the Jaguar representatives
arrived with the journalists in the XK-8’s. We then went staight to the track
and started driving. For the rest of the morning and most of the afternoon we
drove XK-8’s and race cars around the track.
After driving both XK-8 roadsters several laps, Tom Veals XK-120 and Predators
E-Type race car I made the following observations about the XK-8.
The XK-8 has very good acceleration for a luxary road car. When following a race
prepared 120, the 120 was able to pull away very slowly on long straights but
the XK-8’s handeling was far superior to the 120’s in the turns. The XK-8 has
excellent brakes and performed in braking on the track almost as well as a
race prepared XKE weighing over 1000 lbs less. Keep in mind that we were running
individual laps, giving the brakes a little time to cool down…
While on the heavy side, the XK-8 handled very well, it was well balanced and
reacted smoothly and quickly to stearing input, even in a four wheel drift or
snaking turns.The XK-8 transitioned fairly smothly when changing direction in
curves without unmanagable body roll. After most turns, with traction control,
the XK-8 was able to accelerate out of a turn while taking advantage of the
engines power band.
The XK-8 was very confortable and visiability was excellent. I drove the
convertables with the top down and the ride was so smooth and the car so quiet
that it was hard to tell when the engine was peaking out without looking at the
tachometer. All that could be heard on the track was a heavily muffled purr from
the engine, wind blowing past and tires squealing on the turns. Braking was
usually quiet because of the antilock brake system.
The XK-8 was great fun to drive and I would like to purchase a used one in a few
years when the price comes down.
I heard a rumor of a supercharged XK-8 and I have little doubt that an XK-8 will
be modified for racing and in competition in the next year or two.
Doug Bohannon
jaguar@gate.net
Sun Coast Jaguar Club
(941) 967-7899
Date: Sun, 06 Oct 1996 20:08:09 -0700
Subject: Re:RF Modulation CD Player units
Steve Averill mentioned that his XJ6C came with an original British
Leyland 8 track tape player.
While rummaging through some boxes in my shop the other day while looking
for some rubber parts for my E, I came across a box of 8 track tapes and
the player that I originally had in my Datsun 240-Z. My wife asked me
jokingly if I was going to install it in the XK-E.
Hmm…it would be a period accessory. Now lets see, if I can just mount
it beside the Radio Shack CB radio. “Breaker one-nine, this is the big
Cat heading down the superslab, gimme a smokey report, ten four!”
(Last comment void in countries that don’t understand American trucker
slang.)
Date: Mon, 7 Oct 1996 00:32:49, -0500
Subject: Speedo Recalibration
If one is searching for a professional speedo recalibration then I
would have to recommend Nissonger’s in Mamaroneck, NY. When I need
the speedo on my TR-6 recalibrated after I installed an overdrive
unit (with different speedo drive gearing) I sent my speedo to them
via UPS and they did a very nice job, for the cost of a recalibration
they also virtually restored my speedo to “like new” Nissonger’s tell.
is 914/381-1952.
While I am at it I must say that the XK-8 is a stunner, Jaguar pulled
of a styling coup with this one. While true, it is not a S1 E-Type
(and I don’t think that this design will make it to MOMA), it is
still a wonderful achievement for the marque, I hope sales are strong
for many years. My only gripe, and this is a big enough gripe to
keep me from buying one is that this car does not have a manual gear
box. It is screaming for a manual shifter. I don’t care what Ford, or
Jag. research says this car is not a Taurus SHO, or even a XJ-S. If
this automobile claims to be the serious sports or even GT car that
its looks and other equipment suggest then a manual box must be made
available.
Jaguars are enthusiast cars built for and bought buy enthusiasts this
should not be forgotte. Offering this car without a manual box seems
to say to the core of Jaguar’s enthusiast customer base that since we
think you only make up 2% of our target we don’t think that you are
woth it. I am sure that I am not alone when I say that the lack of a
manual gearbox will keep me from purchasing one, and I would consider
myself to be a charter member of this cars target market. If a decent
manual box were available and,as marketing researchers claimed, only
2% of the XK-8’s sales were manual I, for one would be very surprised.
What do other contributors here think?
M.Fatsi
XJ-6
TR-6
a couple of French Cars which shall remain nameless.
Date: Mon, 7 Oct 1996 01:29:50 -0500
Subject: scary Jaguar problem
Hi, today I had a rather unsettling experience with my 1984 XJ-6. After a
lengthy period of inactivity, I got the car running a week ago. A few days
ago I filled both tanks, but did little driving after that.
This afternoon, as I headed down to the grocery store, I noticed a strong
whiff of gasoline after driving a block or so. Then I noticed what appeared
to be a tiny trail of liquid in my wake.
I turned and headed home and after stopping the car. I could see gasoline
brimming out the top of the passenger side gas tank. After releasing the
tank lid, at least two quarts of gasoline came pouring out the top. I
looked underneath the auto to see if there was anything amiss with the tank
itself, but didn’t see anything that looked out of place. Earlier though, I
thought I heard an odd ‘clunk’ coming from what sounded like the trunk. The
only problem is, my trunk is empty.
Has anyone else ever experienced this problem? Could it be that filling
that tank to the brim was a mistake? (not likely, right?). I would
appreciate any suggestions list inhabitants might have. Near as I can tell,
there is no such problem with the left side gas tank…but then again,
it’s only half full.
Finally, this Jag has been sitting for a verry long time: it’s probably
been driven less than 200 miles over the past three years. It has been
sitting in my driveway, unfortunately. I plan on trying to get this machine
in ship shape if it is economically feasible. What problems should I expect
to see in a machine that has been sitting for this long?
Thanks for any and all suggestions,
Joe Average (a true Jaguar dummy)
Date: Mon, 07 Oct 1996 02:34:53 EDT
Subject: Dealer listing
I’ve been watching the debate on the dealer listing web page and so far
no-one has put their hand up to actually do it. I’ll volunteer provided
we can sort out the format and the libel conundrum. I’m in Australia
where I believe our libel laws aren’t quite as vicious as the US but I’ll
need some info on that before we can set it up. Do we have any Australian
lawyers on the list ? If so could you please fill me in (by private email
) on what is OK and what’s not. I also need to know the international
perspective - if I publish something that’s OK here but not OK in Europe
or US can I be sued ?
I don’t mind copping the extra charge of moving to an ISP that will allow
me to publish a web page but I’m not keen on paying several hundred
dollars to get the legal advice.
John
Level 1, 29-57 Christie St.
St Leonards NSW 2065
Ph: +61-2-9937-8063 Fax: +61-2-9937-8100
Mobile +61-419-617-619
From: “Arnold, Dave Dr.” davearno@sandton.senchem.co.za
Date: Mon, 07 Oct 96 09:02:00 PDT
Subject: S type questions
It had to happen. On Friday I looked at a 1967 S type for sale from a
deceased estate. To me, this is the most beautiful car ever made, and
this example is near perfect. Been used very little, 84000 miles
genuine, perfect chrome, no rust, perfect original paintwork, perfect
interior leather, woodwork 99% OK. Runs very well. Even the toolkit is
complete, down to the spare spark plug in its original wrapping. One
problem, looks like the oil pressure guage doesn’t work. Ran the engine
for 30 mins, and drove for 5 miles, with no noises that might indicate
low pressure. Is this likely to be a gauge problem, or likely to be more
serious?
Is the asking price of $ 3000 in the right range?
Dave.
47 Mk IV
80 XJ6 II
67 S type (maybe)
Date: Mon, 7 Oct 1996 14:50:48 +0200 (MET DST)
Subject: V12 exhaust system
I would like to increase the life of my mufflers and I heard one should
drill a little hole into them, so water can drain out avoiding builing up
of rust. Does anyone have experience with this and if so, where should
the hole be loclated
Thanks in advance
- Matthias
Date: Mon, 7 Oct 1996 16:16:22 +0200
Subject: XJ6 Series III Door Disassembly
I am currently working on removing some surface rust on the driver’s door
of my 1985 XJ6 Sovereign.
I have just removed the external chrome strip at the base of the glass.
(This is held on with 5 (rusted) screws inside the door skin, accessible
by removing the weather strip plus the full door trim. There s a sixth scre=
w
at the front - remove the inner and outer triangle shapes and mastic …)
Now to the easy bit - the door mirror …
Unfortunately, the (large, easily accessible, externally rust-free)
screws which hold the mirror on have siezed within their bushes.
The bushes simply turn with the screw.
Anyone got any ideas (eg swap their XK8 for a car
with real character).
Andy Reynolds Andy.Reynolds@lifesciences.com
XJ6 SIII 1985
Engineering Manager
Denley Instruments
UK +44 1403 783441 Ext. 262
Date: Mon, 07 Oct 1996 09:02 -0500 (EST)
Subject: XK-8 (little jag content)
When I went to view the XK-8 I noticed some other marques while
driving through the lot.
The local Jaguar dealer also sells Rolls and Bentley (spelling?).
IMHO, Mother Teresa sitting next to a Bentley would look like Christie
Brinkley. A Checker cab looks more appealing. Talk about ugly cars!
That car was U-G-H-A-L-E-E!!!
I believe it also cost a pretty penny too. ;<) <- turned up nose.
Robert Abascal '63 XKE OTS (almost running) & '66 XKE Coupe
Date: Mon, 7 Oct 1996 09:33:54 -0400
Subject: Wrinkled Wing
Not my day—week–year!
Drove my 3000 to Waynesboro,Va for their British Car Weekend. Great
event!
Left the E-Type at home.
Wife decided to go for a spin.
While backing out of the garage, scraped the right front fender an
adjacent car!!! What the heck, it’s only a car----right?
Tom
Date: Mon, 7 Oct 1996 09:37:55 -0400 (EDT)
Subject: Re: XJS timming chain tensioner plug
Jim: It would be easier to install one of those rubber expandable freeze
plugs that you can get from NAPA, then to go to all the trouable you
would go to .
Sun, 6 Oct 1996, James A. Isbell wrote:
I got it out!
end (1/3") into almost a hook, about 80 degrees of bend.Push the end of the nail into the hole and rotate it till it can be used to
inside. Now use a flat bladed screwdriver to pry the thing out.Strangely, it is the outside of the plug that hardens and the interior parts
temps, not engine temps that harden the plug.I am thinking of removing the plug and cutting the interior tabs off of it
top of the plug and be held into position by a bolt on the water pump.Kirby, add this to your book!
Nance O’Neil
End of jag-lovers-digest V2 #409
id for jag-lovers-digest-out; Mon, 7 Oct 1996 19:41:52 +0200 (MET DST)
Date: Mon, 7 Oct 1996 19:41:52 +0200 (MET DST)
Message-Id: 199610071741.TAA03271@ekeberg.sn.no
Subject: jag-lovers-digest V2 #410
Precedence: bulk
jag-lovers-digest Monday, 7 October 1996 Volume 02 : Number 410
Re: scary Jaguar problem
Re: S type questions
Re: Beer and Jaguars
ain’t broke, don’t, etc.
XJ-S Drivers Window not going all the way up possible answer
Re[2]: Parts for sale list on the web and Dealer comments
I Need a part
Re: XJS V12 radiator flush
Raffle
XK’s Open House (long)
Date: Mon, 7 Oct 1996 09:43:32 -0400 (EDT)
Subject: Re: scary Jaguar problem
Joe: Your return valve is stuck, allowing fuel to return to the worng
tank, it is suppose to return to the tank being used at the time.
it’s only half full.Finally, this Jag has been sitting for a verry long time: it’s probably
to see in a machine that has been sitting for this long?Thanks for any and all suggestions,
Date: Mon, 7 Oct 1996 09:45:51 -0400 (EDT)
Subject: Re: S type questions
Dave: Price real right, replace the oil presssure guage sender, price
around $ 55-65
serious?
Dave.
47 Mk IV
80 XJ6 II
67 S type (maybe)
Date: Mon, 7 Oct 1996 08:43:17 -0600 (MDT)
Subject: Re: Beer and Jaguars
Out of the bleu, Jim whines…
{I personaly think there is no such thing as a Good beer.
I feel very sorry for you. I will nominate you to have your
picture next to the entry for for the word “Deprived” in the
next Websters dictionary. Next time you come thru Boulder, I
will do my best correct this unfortunate delusion of yours.
{I have never seen what one can see in something that tastes like it has
{already been drunk by another person.
I’m afraid I’m unqualified to debate this comparison since I’ve
made it a firm policy of mine not to imbibe any post-processed
fluids.
{I find Burbon and good wine to be very tasty, but beer is bitter and salty.
Two out of three ain’t bad. But, this is not the place for me
to ramble on about the wonders of microbrews.
Ob.jaguar.content
Had a friend make a barn find last week. A 1952 XK120 coupe which
had been sitting in a barn since 1970. $5500 from two old gents
who were straight out of the Muppet Show (“Shut up, you old poop!”)
It’s gonna be alot of work to get perfect, but it’s all there and
hasn’t been mucked with. They’re still out there…
/\ Lawrence Buja http://www.cgd.ucar.edu/cms/southern/
_][ southern@ncar.ucar.edu National Center for Atmospheric Research
________________Boulder,Colorado___80307-3000
Date: Mon, 7 Oct 1996 10:54:42 -0400
Subject: ain’t broke, don’t, etc.
The “…if it ain’t broke, don’t fix it!” quote is from the industrial
age. In the information age the quote is, “…if it works it’s obsolete!”
Never is that so true as in technical/research software. We write
“throw-away” code all the time. Management hates it! “Current”
today means out on the ragged edge. Another phrase I like is
used to refer to technology that has just passed through it’s high
dollar phase heading for the practical phase. That is, “State of the
Shelf”.
Anyway, the XK8 is really incredible. But what is the XJ-S going
to turn in to? I have been out of the loop for a while – laying under
my '66 S-type…
Regards Gang,
Rick
From: “Kirbert” palmk%gcn.scri.fsu.edu@vm1.cc.nps.navy.mil
Date: Sat, 5 Oct 1996 03:51:26 -0005
Subject: Re: Parts for sale list on the web and Dealer comments
Well, I can finally disagree with Kirby;
----------------------------Original message----------------------------
Nah, a better plan is to post all businesses we know exist. If we
cannot say anything bad due to liability issues, say nothing at all,
but list them anyway. Remember what I originally proposed: the list
… deletionws…I see no reason to post businesses if we are not able to warn our
users/netfolks about dealers/businesses that are unethical and/or
dishonest. To me, one of the main reasons is to help find a reasonable,
honest dealer/supplier when I am broken down in HoeDunk Nebraska. (No
offence to HoeDunk residents)LLoyd
Date: Mon, 07 Oct 96 08:55:00 PDT
Subject: XJ-S Drivers Window not going all the way up possible answer
I forgot who asked ( read too many digests this morning ) about possible
fixes to the drivers window not going all the way up without using their
hand. On my 88 XJ-S, the problems was that one of the screws was removed by
a PO, or had fallen out over time that mounts the window motor to the door &
the others had become loose. The motor assy. would move when you raised or
lowered the window, after tightening the screws & new lock washers, ( with
the window all the way up so it would fit correctly )the window now goes all
the way up & I no longer have the fingerprints on the window ( Inside anyway
John Himes
88 XJ-S 98K Miles
( should hit 100K before Christmas )
From: Robert Bradley Robert.Bradley%bh.eyi.com@vm1.cc.nps.navy.mil
Date: Sat, 5 Oct 1996 04:01:53 -0500
Subject: Re: XJ40 vs. SIII and beer
Robert, this is a good point, if I understand what you are saying, BUT you
can never really BUY beer. The most you can do is rent it for a while.
Lets just say that Jaguars are a bit like beers. There is no such thing as a
bad beer, just good beer and better beers. Some are nice when fresh, others
age well. Only time will tell.LLoyd
From: Michael Powers/TEIR/Thomson Michael_Powers@teir.com
Date: 7 Oct 96 10:56:42
Uh oh, I sense a “Beer vs Burbon” thread starting up!!!
- -Mike
“I never met a beer I didn’t like”*
*except Moosehead - It is truly foul…
JISBELLJR @ mail.utexas.edu (James A. Isbell)
10/05/96 02:10 PM
To: jag-lovers @ sn.no @ Internet
cc:
another person.
Jim
Nance O’Neil
Date: Mon, 07 Oct 96 10:31:48 CST
Subject: Re[2]: Parts for sale list on the web and Dealer comments
Author: LLoyd 3030P@vm1.cc.nps.navy.mil at INTERNET
Date: 10/7/96 7:56 AM
Message was resent – Original recipients were:
To:
jag-lovers@sn.no----------------------------------------------------------------
;Hey thar out thar
LLoyd, we’uns out hyar in Nebraskeeee have balin wirr for thos brok’n down
kats. We’uns even know how to string a kat.:))
Be nice to us out hyar u’all mite jus brake down on ure way thru.
Anyway if you do good luck on finding a part. ;-)) (No off-fence taken.)
Kenny Gilson
'64 OTS
LLoyd
Date: Mon, 7 Oct 1996 11:52:07 -0005
console, floor or in the glovebox.Unfortunately, none of them’ll work with the 8 Track player in my XJ6C like
FM band.
I dunno how many others misunderstood this message thanks to my not
altering the subject from a PREVIOUS message, so I will clarify: if
somebody GAVE me a unit that played through an FM radio by
modulating the signal, I would happily throw it as far as I could!
Why would ANYBODY consider such crap? I believe the portable CD
players I mentioned – as an alternative to the expensive wired-in
boot-mounted changers – connect via the preamp-in connections
available on most modern systems.
– Kirbert | If anything is to be accomplished,
| some rules must be broken.
| - Palm’s Postulate
Date: Mon, 7 Oct 1996 11:52:09 -0005
Jim Isbell, regarding removal of the tensioner access cover:
Chad Bolles’ description is correct, and the book has been revised
– look for the next posting.
| - Palm’s Postulate
Date: Mon, 7 Oct 1996 11:20:06 -0500
I disagree! Obviously you never tried BUD LIGHT!
Vlad
Date: Mon, 07 Oct 96 09:18:20 PDT
Subject: I Need a part
Sorry to clutter the list with this, but thought I’ld come here first.
I need a vaccuum advance for the distributer of a '71 4.2 “E” type. Anyone
got one or a lead? I know we got a couple of parts guys on the list.
3030P@VM1.CC.NPS.NAVY.MIL
LLoyd Nolan Monterey, Ca. USA
'71 E-Type OTS, "PrtyKty" It needs some assembly.
'69 black 280sl, “Darth Vader” Just when you think all is lost,
it saves you.
In search of a Mk II or 3.8s
Date: Mon, 7 Oct 1996 10:47:07 -0600 (MDT)
Subject: Re: XJS V12 radiator flush
Hi everyone,
Thanks for the help from Stefan, Jan, Mike, John and Gregory … I did
the radiator flush last weekend.
As many of you suggested, removing the bottom radiator hose from the
radiator ends work the best. Basically, I drained the old anti-freeze,
rinsed it a couple times. Refilled with a can of radiator flush and
fresh water, took the car for a cruise. Drained and rinsed a few times.
Refilled it with 50/50 mix anti-freeze and relaxed.
One point may be useful to add to Kirby’s help book (as Kirby suggested)
is to include when Jaguar remove the “remote control radiator drain plug”.
This plug is definitely not exist in my car. Does anyone know when the
change happened?
Thanks again for everyone’s help.
Patrick Siu
89 XJS V12 Conv
Date: Mon, 7 Oct 1996 13:30:25 -0400 (EDT)
Subject: Raffle
A few weeks ago there was a post about an XK8 raffle.
I’ve lost the specifics and was wondering if anybody could steer me to it.
Jo-Ann Gross
Date: Mon, 7 Oct 1996 10:39:14 -0700
Subject: XK’s Open House (long)
This weekend, was an open house and road rally sponsored by XK’s Unlimited
in San Luis Obispo (about 200mi from my house). Having, just a week ago,
resolved my rear axle groan (loose brake caliper bolt), I decided that my
modified '59 MK1 was ready, and with some very last minute planning my
wife Joan and I arranged to make the trip.
One of the highlights of the whole weekend came early Saturday morning
as we were driving down to Morgan Hill, where the local Jag club was
gathering for a convoy down to the meet. We were cruising sedately along
when to my left I saw the unmistakeable nose of a Britsh racing green S1
E-type. It turned out to be fellow club member George Barry, donning leather
aviators helmet and goggles, in his roadster. Right behind him was another
member Dave Ferguson, in another (white, with helmet to match) S1 roadster.
They asked for directions to the meeting place before speeding ahead. After
hesitating for a short while, I yielded to temptation and gave chase. To
close the gap which had opened, I just opened my car up and watched what
it would do. I backed off as the tach needle swept past 4500rpm- at which
time the car was still pulling like a train. We had closed the gap with the
E’s and spent the next few miles watching the two cars in front of us toy
with eachother, darting around the sparse early mornign traffic; the low
morning sun glistening off the polished fenders. It just formed one of those
mental postcards that will stay with me for a very long time.
At breakfast, Joan scolded me for going too fast- noting that our indicated
speed had reached 155kph (I had been watching the tach, not the speedo),
which translated to almost 100mph. I re-assured her that our speedometer
wasn’t accurate since I had smaller tires on the car than stock and we
probably hadn’t exceeded 90 mph or so. Still, I was quite pleased that my
car was still accellerating with such vigor at that speed…
Despite the early morning excitement, my intention was to take it easy with
the car, and I dropped off the back of the convoy. At engine speeds over
3400rpm or so, my fan belt was slipping and so the easiest fix was just not
to go that fast. We weren’t in any hurry, and just enjoyed the drive.
We arrived shortly before noon, in time for lunch, and seemingly just as
things were really getting started. Saturday was a drive-in car show for
the older cars; with peoples choice balloting. XK’s was also having
a %20 off sale, and I took the opportunity to buy a “flex-fan” conversion
kit, thinking that this should improve my cooling and help solve my slipping
fan-belt problem. Unfortunately, the weather didn’t co-operate, providing
what must have been 100 degree heat. It was especially unbearable on the
black-top where the cars were being shown. Most people spent the day huddled
in the shade. We spent the late afternoon shopping in San Luis Obispo, and
spent the evening in (much cooler, since it’s on the coast) Morro Bay where
I had arranged to stay at a small bed-and-breakfast.
Sunday was a road rally. I had no idea what the format was going to be,
and decided that it might be a good idea to try and get a callibration
for my speedometer (so we could judge both speed and distance). So,
as we drove back into San Luis Obispo, we used the mile markers (over
multiple miles, and over several intervals) to find the conversion factor
between our indicated km, and actual miles. It turned out to be a very
nice, even, 7:5 => 1.4: “1.4?, How can that be right? I’ve got smaller
tires than stock, and the real number is ~1.6”. Then I remembered that I’ve
also replaced my rear axle with one out of an automatic MK1. We checked
again over another interval: 1.4. I was jolted with a smack on the
shoulder when Joan realized what the implication was to the previous
days adventures (110mph).
It turns out that we didn’t really need the speedometer anyway. Rather
than a navigational challenge, the road rally was more of a scavenger
hunt. Over some 100mi of country road we were given ~50 questions
to answer. Things like “what’s salty?” (we drive by the Salty Pelican
Restaurant"), and “Who will be shot on site?” (there’s a sign indicating
that arsonists and vandals will receive this fate, posted at a
junkyard). The route travelled through San Luis Obispo, Morro Bay, Pismo
Beach, and surrounding areas- with some really beautiful back country
roads, taking about 2.5 hours to complete the route. At the conclusion
of the rally, XK’s Unlimited’s owner hosted a very nice lunch, with
champaign, and a small band at his ranch house.
Rally scores were combined with peoples choice voting from the day before-
for a total weekend score. Somehow I took home a 2nd place trophy and a
$50 gift certificate! The deck was somwhat stacked in my favor: there were
a lot more E-types to split the votes up in their category than in my early
sedan class… but I’ll still take it :-). Joan and I only missed 4
questions on the rally- and I still contend that it was a tomato! So,
adding up, that now brings the total number of trophy’s I’ve won with
my car up to… 1!
Of course, no Jaguar adventure would be complete without some mechanical
excitement, and sure enough, we had troubles about 100mi from home. While
accellerating to pass a slower car, I felt the jag loose power… and
then sort of sputter and surge again. At first I thought maybe just a bit
of crud went through one of the carbs, but then there was a severe power
loss. The car would barely maintain ~45mph. We pulled off at the next
exit; where I quickly decided this had to be one of 3 things: fuel, ignition,
or something serious. Temperature was fine, oil pressure was fine, it
wasn’t smoking, and it sounded fine… so I ruled out something serious
pretty quickly. It revved fine, and would pull ok in 3rd gear; sort of
ruling out ignition problems; which left fuel delivery as the culprit.
After a little slow speed driving, it seemed OK… and so we ventured back
onto the highway, where it was fine for a while; but the first time we
went past ~3200rpm in 4th it sputtered, almost died, and we were barely
able to make it to the next exit- where at least there was a service station.
Fuel system fire drill:
- Does it have gas? Yes, gauge indicated about 1/2 a tank.
- Is pickup clogged? ← Actually I’m still guessing this was the problem.
Let car sit for a while, fill up the tank to ‘stir things up’. - Bad gas? If so, new fuel should help. Dumped in a bottle of STP just
for good measure. - Fuel pump working? Sounded OK, fuel filter was full. Turned up the
pressure on my regulator a notch just for good measure. - Blockage in line? There was quite a bit of crud in the filter (rust
particles). Spent about 30mins extracting, cleaning, and re-
installing the filter. - Junk in carb? Maybe… STP might help.
After doing all that, we rolled on without further problems. I took it easy
with the car, focusing on getting it home… A test just a couple of miles
from home showed the car would pull strong, in 4th, well past the point
where the earlier problems occured. So maybe it’s fixed. When this tank
gets close to empty, I’ll probably drain the tank and check the pickup
though.
This little delay cost us ~40mins; and also put us behind a 4 car pile-up
costing us another hour in stop and go traffic. So, it was almost a 5
hour drive home. This after a 2.5 hour rally. Boy were we tired.
But what a great weekend!
===== __ ============================================================== |> ===
/_\ Ryan Border o~_ o~_ | *
/ / / Hewlett Packard Company, Inc. >/-.>/’ /o| *
/ / / _______ Software Design Engineer ( )-–(*)-( )’ *
/ / //_____\ email: rborder@cup.hp.com or border@best.com *
/ / __ / / __ / 19111 Pruneridge Ave. mailstop 42LX, Cupertino, CA 95014 *
/ / / / / / // / (408) 447-2496 FAX: (408) 447-0641 *
//// / _____/ WWW: BestWeb.com - Lease or Buy Domain Names - Best Web Limited *
End of jag-lovers-digest V2 #410
Return-Path: @owner-jag-lovers-di1
Received: (from majordom@localhost) by ekeberg.sn.no (8.7.5/8.7.3/on4)
id for jag-lovers-digest-out; Tue, 8 Oct 1996 01:55:54 +0200 (MET DST)
Date: Tue, 8 Oct 1996 01:55:54 +0200 (MET DST)
Message-Id: 199610072355.BAA10788@ekeberg.sn.no
X-Authentication-Warning: ekeberg.sn.no: majordom set sender to owner-jag-lovers-digest using -f
To: jag-lovers-digest@sn.no
Subject: jag-lovers-digest V2 #411
Reply-To: jag-lovers@sn.no
Errors-To: @owner-jag-lovers-di1
Precedence: bulk
X-Newsgroups: mail.jag-lovers-digest
jag-lovers-digest Tuesday, 8 October 1996 Volume 02 : Number 411
For Texans only…
Re: Beer & Jaguars (some Jag content)
Re: Beer & Jaguars
Re: Re[2]: XK-8 versus Aston-Martin
XJ220 drivetrain details?
Thar She Blows!
Body number? Vehicle Number?
Re: XJ6 Series III Door Disassembly
XJ40 Oil leak
Re: Wrinkled Wing
FW: XJ40 v’s SIII
Fuel leak XJ6
Jag photos
Re: I Need a part
Re: XK8
Date: Mon, 07 Oct 1996 11:20:52 -0700
Ran the engine
serious?
Dave.
47 Mk IV
80 XJ6 II
67 S type (maybe)
sounds like a winner to me. wanna trade it for my '65 Stype? you should take it
somewhere to check the tranny, compression, steering… the usual bits. And budget a
couple grand for fixing things you dont think are problems yet. Also, 84000 miles on an
unrebuilt XK engine is alot. If it really is original, it will need an overhaul soon,
and that will cost more than you are paying for the car.
go for it
Jim
'65 Stype… STILL garage queen
Date: Mon, 7 Oct 1996 14:51:08 -0400 (EDT)
change happened?
Well, 87 has it and your 89 doesn’t. Anyone got an 88?
Thomas E. Alberts
Date: Mon, 7 Oct 1996 19:04:23 GMT
Subject: For Texans only…
I live in Switzerland and occasionally travel in the U.S., mainly in
connection with my business branch in California.
For the last weeks of this month my wife and I plan to travel around in
Texas, probably from Dallas west to San San Antonio and south to the Big
Bend National Park. No firm plans yet.
Any suggestion from friendly and sympathetic locals of what to do and to see
while driving around (unfortunately not in a classic, but in a dull rented
Sedan) is highly appreciated, especially (but not only) if car related.
Glue Man
glueman@collano.ch (former address: gleuma@dial.eunet.ch)
Date: Mon, 7 Oct 1996 14:12:34 -0500
Subject: Re: Beer & Jaguars (some Jag content)
Now, now, Jim. You’ve been pontificating far and wide on a variety of
subjects. But, you’re getting out of your territory with your comments
about beer. You’re beginning to sound snobbish, just like the fellow you
took to task for sounding snobbish about internet access and such.
I am certianly not snobbish, its just that I have never tased a beer that
was NOT bitter.
If you can point me to a beer that is sweet or at least not bitter or salty
I will gladly try it.
When in England I drink Cider but that is as close as I will get to beer.
I have tried Shandy which is lemonade and beer half and half and it is
almost palatable.
Burbon is good BEFORE you start the Jag repairs, it fortifies you for the
job and thickens the blood so you lose less of it through the nuckles. Then
AFTER the repairs, while sitting in the hot tub thinking about the rally you
just won, wine is fine.
DURING the repairs I drink iced tea.
JIM I.
“Prefiero morir de pie que vivir de rodillas.”
Gen. Emiliano Zapata
1879-1919
Date: Mon, 7 Oct 1996 16:06:22 -0400
In a message dated 96-10-07 15:19:24 EDT, JISBELLJR@mail.utexas.edu (Jim
Isbell) writes:
<< If you can point me to a beer that is sweet or at least not bitter or
salty
I will gladly try it…
…I have tried Shandy which is lemonade and beer half and half . >>
I’ve made beer, and as far as I know salt is never an ingredient. And,
Shandy is a ladies drink.
Date: Mon, 7 Oct 1996 16:17:33 -0400
Subject: Re: Re[2]: XK-8 versus Aston-Martin
On Oct 5, 1:45pm, Mike Cogswell wrote:
Subject: Re[2]: XK-8 versus Aston-Martin
If they aren’t planning on building any 5-speeds, and their volumes are
going be be about 2% of the XK-8 volume, then how do you explain A-M
spending the development money for a 5-speed?
I am not A-Ms’ accountant. If volume is only 2% of XK8 than I guess I can’t
explain the DB-7 period - just glad it got built I think you have to give
credit to Ford for that!
… why have the DB-7s I’ve
read about had manual transmissions? The R&T road test makes no mention of
an automatic even being available in the DB-7.
An R&T oversight? Yea, like that never happens. Try another magz.
I’m not surprised a Ford designer would prefer the XK-8 rear. Do your
desks also look like jellybeans?
Yes, I am as easy a target as the S3 E-type Ever see the Lincoln Sentinal
or GT-90 ???
It’s a beautiful car in many ways,
but I agree completely that virtually every styling change made from '61 to
'74 was a step away from the purity of the original design. (And I’ve
owned a '74 E-Type since it was new.) My point was clear. A big chunk of
the target audience spent most of their time looking at the E-Type instead
of the XK-8.
Yes, I admit, the S3 Etype is a beautiful car (am I back-pedaling?). I even
like the 2+2 in a strange sort of way - it has an elegant yet almost arrogant
look about it. The OTS has a windshield that still makes my jaw go slack - so
much plan-view(!) nicer than the S1&2 in that respect. I too would have been
looking at the E-type, but that would not mean that I was any less interested
in the XK8. Never the less, you were there, I was not. You saw the reaction of
the people, I didn’t. Still, I like the XK8 design, and I think (hope) many
others will too.
The boss had one in today, a blue convertible. It has some very nice subtle
surfaces in the rear quarters (fenders) that I never saw before. Many of the
designers in the studio went out to look at it. These guys will pick anything
to death! (Including their own work) But most had the same reaction…
Mark McChesney
'65 S1 Etype ots
'62 Mini Cooper
‘57 BMW Isetta 300 Deluxe
and Dads’ cars…
'72 S3 Etype V12 2+2
'69 S2 Etype Coupe RHD
Date: Mon, 7 Oct 1996 17:24:45 -0005
LLoyd
Anybody know why Lloyd’s reply to my message came through with my
name in the “From” header? I almost deleted it without reading,
assuming it was one of my own messages.
| - Palm’s Postulate
Date: Mon, 7 Oct 1996 23:18:23 +0100 (MET)
Subject: XJ220 drivetrain details?
Anyone know what sort of engine the “production” version of the XJ220
had? Where it came from or what it was developed from? Or was it designed
from scratch?
What about the transmission, eh sorry, transaxle?
Thanks!
Gunnar
Gunnar Helliesen | Bergen IT Consult AS | NetBSD/VAX on a uVAX II
Systems Consultant | Bergen, Norway | '86 Jaguar XJ6 4.2 Sovereign
gunnar@bitcon.no | http://www.bitcon.no/ | Vicki who? What .sig virus?
Date: Mon, 7 Oct 1996 18:31:41 -0005
Subject: Thar She Blows!
For those who aren’t clear on where I live, just look at the weather
report tonight. Tropical Storm Josephine is headin’ right for me.
If it wasn’t such a lame storm, I’d be worried.
| - Palm’s Postulate
Date: Mon, 07 Oct 96 15:39:44 PDT
Subject: Body number? Vehicle Number?
I’m stuck.
I had the sills replaced on my “E”, and they threw away my ID plate. Some
nerve, ehh? No appreciation for originality!
Anyhow, I bought a replacement ID plate, and it has a place for Body number
and a place for Vehicle number. It is a '71 DHC.
The body number is P2R13539, placed in the door sill and on the front box
frame. The window plate says 2R13539 without the “P” in front of it. But I
can’t find a “vehicle” number.
I’ve seen other DHC’s with different numbers in the vehicle number and
body number boxes, but don’t know where to locate the vehicle number.
Anyone have an idea of what I should do next?
BTW, I have tranny and engine numbers.
LLoyd -numbers, numbers. Do they all mean anything…?.. -
Date: Mon, 7 Oct 1996 18:52:57 -0400 (EDT)
Subject: Re: XJ6 Series III Door Disassembly
Andy: A pair of Vise-Grip pliers holding the bush,the only way I can see
to do it, or a new door.
Chad Bolles Jaguar South 306 Valcour Rd Columbia SC USA 29212 803 798 3044
of my 1985 XJ6 Sovereign.I have just removed the external chrome strip at the base of the glass.
by removing the weather strip plus the full door trim. There s a sixth screw
at the front - remove the inner and outer triangle shapes and mastic …)Now to the easy bit - the door mirror …
screws which hold the mirror on have siezed within their bushes.The bushes simply turn with the screw.
XJ6 SIII 1985
Engineering Manager
Denley Instruments
Date: Mon, 7 Oct 1996 16:01:33 -0700
Subject: XJ40 Oil leak
Sorry for wasting bandwidth on this one as I know its been covered many
times. But, I never thought my Jag would ever leak. Its been leak
free til now! Am I a dreamer or what? Just above the distributor at
the base of the head is a fairly good leak. I have the factory books.
However, what is the most economical way to stop it without major
surgery?
Gerald
Date: Mon, 7 Oct 1996 18:58:52 -0400 (EDT)
Patrick: Some where around 85 or 86, as I have seen them both ways.
Mon, 7 Oct 1996, Patrick Siu wrote:
Hi everyone,
the radiator flush last weekend.As many of you suggested, removing the bottom radiator hose from the
Refilled it with 50/50 mix anti-freeze and relaxed.One point may be useful to add to Kirby’s help book (as Kirby suggested)
change happened?Thanks again for everyone’s help.
Patrick Siu
89 XJS V12 Conv
Date: Mon, 7 Oct 1996 19:13:40 -0500
Subject: Re: Wrinkled Wing
event!Left the E-Type at home.
Tom
Had a similar experience,Tom. Clutch won’t engage until pedal is almost all
the way out, thus sort of hairy on an incline. Thought I had it in first
gear when trying to back up to check suspected brake fluid leak. I was
aimed toward right side of garage. You guessed it. I revved my E-Type and
let out the clutch. Bang! That old nose ran into the garage. Nice big dent
and a ruined bumper guard. Have to get that darn clutch adjusted plus an
expensive nose job.
From: “Rennick, Kim (AS01)” KRennick@p03.as01.honeywell.com.au
Date: Tue, 08 Oct 96 08:12:00 EST
Subject: FW: XJ40 v’s SIII
This is a resend due to apparent mail failure - apologies for any
duplication.
To: ‘jag-lovers (post)’
Subject: XJ40 v’s SIII
Date: Friday, 4 October 1996 10:48AM
I thought I might add my 2c worth to this discussion, being as I am a
devoted XJ40 owner, as well as an ardent admirer of the SIII.
Firstly, I cant object to people preferring the styling of the SIII over
that of the XJ40. After all, the SIII is a most sublime piece of artistry,
combining elegance, agility and beautiful dynamic characteristics. It is
perhaps a shame that it took an external design studio to extract the final
touch of excellence out of the original Jaguar design. Then again, the
original SI and SII designs, which are ‘pure’ Jaguar in origin, are also
superb, each in its own way.
But for all that, I rather like the XJ40 styling - it is still elegant, it
‘moves’ well, and could only be a Jaguar. It still speaks of ‘grace, space
& pace’.
I do however object to the vague slurs being thrown at the design of the '40
rear suspension! When you look at Jaguar’s own design / testing data you
see that, in comparison to the SIII, the '40 provides:
improved anti dive / anti squat performance (69% anti-squat compensation,
19% anti-dive) -
improved isolation characteristics, by careful tuning of resonant bounce
frequencies of wheel / axles -
improved response of the body (resonant frequency reduced from 22Hz to
14Hz) to suspension input -
improved bump steer performance (in fact maintaining slight toe out
geometry through bump and rebound, to enhance steering response) -
mildly increased negative camber on bump to increase tyre contact profile
under cornering -
improved lift-off oversteer performance
improved torque steer performance
There was considerable engineering & design effort expended on the XJ40
suspension against both ride & handling criteria. The design team had a
hard act to follow in the SIII, but any objective analysis would indicate
that they achieved their stated design objectives.
If one were to criticise the '40 suspension as a whole, it could be said to
be a touch too taut at suburban speeds, but then at highway speeds it is
quite astonishing in its sophistication. It doesn’t exhibit any of the high
speed float for which the SIII is sometimes criticised.
The '40 is an interesting car. Whereas one could reasonably say that the
SIII ‘evolved’ from its predecessors (which has both positive and negative
results, both in great measure!), the '40 was ‘created’, as a result of a
massive engineering exercise. When you look at any part of the car
(suspension, body structure, engine, brakes, electrics, the use of computers
in various applications, seats, ergonomics, etc) it is obvious that the
design is a real engineering ‘tour de force’. You might be tempted to say
that some of the engineering wasn’t 100% successful (verified by the fact
that later XJ40 , models tended to retreat somewhat from the engineering
‘purity’ of the original model), but anyone who claims to appreciate fine
engineering could only be impressed by the obvious effort and integrity that
went into the design & manufacture of the '40.
And after all, the design and the end result (with all the flaws it
undoubtedly has) are still very much a Jaguar! What else could it be?
I apologise for my excessive use of bandwidth here - I just thought someone
needed to speak up in defence of the somewhat maligned model!
Kim Rennick
| XJ40 3.6L Sovereign -
| Citroen BX 19 GTI -
| …(English and French rapprochement in my garage!)
|__________________________________________________
Date: Mon, 7 Oct 1996 16:14:37 -0700
Subject: Fuel leak XJ6
Joe Average wrote about fuel leaking from the top of his gas tank. I’m
sure he will get lots of replys, but just in case. Check the fuel
return solenoids in the trunk. One or both can be bad. The fuel that
is returned from the engine has to have somewhere to go. A
malfunctioning solenoid(s) allows it to be pumped back to the already
full tank and out the top it goes. Had it happen once on my XJ12
sedan. Nothing in the factory book mentioned such a problem. I
assumed that with the furious fuel consumption rate on the car that
nothing would ever be left to return to the tank! Wrong.
Gerald
Date: Mon, 7 Oct 1996 16:24:19 -0700
Subject: Jag photos
Reference to good Jag photos. I downloaded a few from either
Compuserve or AOL, I don’t remember which. They were listed under a
special auto photo section. I also downloaded a program called Your
own screensaver, which you insert your BMP files and it rotates them as
a screensaver. The Mosiac file viewer on compuserve had a file
conversion utility to convert them from JPG and GIF to BMP. I have not
found a similar source of good car photos on the Web proper. I’m not
on AOL or Compuserve anymore or I would be more specific.
Gerald
Date: Mon, 07 Oct 1996 16:30:26 -0600
Subject: Re: I Need a part
The original Lucas 5442224 is no longer available. I definitely don’t have
any of them. However, this vac advance also fit some TR6s. I do know that
another Lucas part 54400201 will fit TR6. Maybe it will work on the E…I am
not certain. The price of the supercession advance for the TR6 is $29.95. I
can supply these in about 2-4 days…though I will be gone to Hershey PA
(Thurs-Sat)
Hope this helps a bit.
Hal
Hal Rogers
H.D. Rogers & Sons
Import Auto Specialists
3418 Barksdale Blvd.
Bossier City LA 71112
(318) 742-3651 voice
(318) 742-5044 fax
Serving Auto Enthusiasts since 1959
Date: Tue, 8 Oct 1996 09:54:01 +1000
Subject: Re: Most Beautiful! XJ40 vs SIII (the reality)
Jim
I think I bought mine because of the design and enginnering. As a system it
facinates me. They are so much fun to drive too but having said that
Daimler never did have the flair of Lyons for design aethetics. From the
front I love the car, from inside they look great and drive well from the
back? It looks best with a trunk strapped to the rear boot lid to break the
lines that look like a portly maid.
A portly maid she ain’t.
What I would give for a going DB18 at $2500. Have a look at mine on my web
page. It was a mess and is slowly improving. At current rate it is 5 years
from the road.
I was posted to Qld and the car is in Canberra and it will stay for at
least 12 more months.
keep well.
/dlh
At 9:16 AM 7/10/96, James A. Isbell wrote:
Now for the worst boot, backend it would have to be the DB18 Daimler or
was it the XJS?I cant agree. I once owned a 1948 DB18 (about 20 years ago) and I loved the
and then lost my mind and sold it for a paultry $2500.It was a beautiful car, the best engineering I have ever seen.
Jim
“Better an outlaw than not free.”
Nance O’Neil
Without Treatment Development our past can only rot!
David Hallam, Senior Scientist, Materials Conservation,
Queensland Museum, PO Box 3300 South Brisbane 4101 QLD.
Australia -phone 07 34807684 D.Hallam@mailbox.uq.edu.au
Date: Mon, 7 Oct 1996 10:34:49 -0500
Subject: Re: XK8
This is a Mime message, which your current mail reader
may not understand. Parts of the message will appear as
text. To process the remainder, you will need to use a Mime
compatible mail reader. Contact your vendor for details.
- –IMA.Boundary.482237448
Content-Type: text/plain; charset=US-ASCII
Content-Transfer-Encoding: 7bit
Content-Description: cc:Mail note part
In the US, traction control is part of the optional “cold package” which
also included heated seats, block heater and headlamp washers.
I drove a convertible without traction control over the weekend. It had no
inclination to break loose. Judging on “seat of the pants” feel, it might
be a little down on low end torque compared to the XJR /XJ-12. My XJ-S has
more of a tendency to break the rear end loose, and it certainly isn’t any
tire burner.
MikeC
______________________________ Reply Separator _________________________________
Subject: XK8
Author: Michael Neal mneal@wco.com at Internet
Date: 10/5/1996 10:17 AM
Luckily there is a series of racetrack type corners several miles from the
dealer. As I was hustling the car through them I noticed that it felt like
the car was steering from the rear. It seems that the rear suspension
bushings could be a little firmer to prevent the rear geometry changes that
are allowing this to happen. The XJR has the same rear suspension and
tires, the next chance I get I’ll have to test it through the same area.
The 94 XJ12 motor, pre OBDII, has the most power so far. The low end
torque and the raw feel can almost edge out the XK8 V8. I think that the
XK8 has full time traction control because it is very difficult to get the
tires to break loose at low speed. The XJR and the XJ12 have switchable
traction control and you have to be cautious with the throttle when you
have it turned off.
- –IMA.Boundary.482237448–
End of jag-lovers-digest V2 #411
X-UIDL: a273dfd8d19422390a2d6b0f7248cf0c
id for jag-lovers-digest-out; Tue, 8 Oct 1996 07:22:24 +0200 (MET DST)
Date: Tue, 8 Oct 1996 07:22:24 +0200 (MET DST)
Message-Id: 199610080522.HAA17161@ekeberg.sn.no
Subject: jag-lovers-digest V2 #412
Precedence: bulk
Status: RO
X-Status:
jag-lovers-digest Tuesday, 8 October 1996 Volume 02 : Number 412
Re[2]: Most Beautiful! XJ40 vs SIII (the reality)
Re: XJ6 S1 furflex…
‘S’ type grill
Rear window replacement
XJ-S Spark Plug Wires
Re: XJ220 info
Re: Beer & Jaguars
Re: Glueman visiting Texas
XK8 Australian Prices
Re: XJ40 Oil leak
Re: XK8 Australian Prices (Tue Oct 8 09:25:44 1996)
re: Kirby’s last message
(My car
XK’s Unlimited open house
Re: XJ6 S1 furflex…
[XK8] Price
RE: XJ40 Oil leak
[XK engines] Lifespan?
RE: XJ40 Oil leak Re: rear shocks
Date: Mon, 7 Oct 1996 10:45:10 -0500
Subject: Re[2]: Most Beautiful! XJ40 vs SIII (the reality)
–IMA.Boundary.682237448
Content-Description: cc:Mail note partYou need to be more careful with your quoted replies. I DID NOT
write the words below. Notice the double “>>”? They were in a
message I replied to.MikeC
Author: David Hallam D.Hallam@mailbox.uq.oz.au at Internet
Date: 10/6/1996 7:11 AM
For a modern car the Mk2 is wonderful but for real beauty the SS100, 3.5
saloon and Mk4 cannot be surpassed.
Or the Daimler low chassis Doulbe Sixes from 1930?
Historic perspective seems lacking.
was it the XJS?
/dlh.
I am sorry guys (and gals) but I can remain silent no longer.
The MK II is the most beautiful Jag sedan ever produced.
David Hallam http://www.uq.edu.au/`qmdhalla
Senior Scientist
Queensland Museum d.hallam@mailbox.uq.edu.au
*** Without Treatment Development our past can only rot ***
____ Daimlers can be fun too! _____
- –IMA.Boundary.682237448–
Date: Mon, 07 Oct 1996 16:30:21 -0600
Subject: Re: XJ6 S1 furflex…
At 08:33 AM 10/6/96 PDT, Per Stenius wrote:
Hi! I commented on David Q’s mail earlier and suggested that the stuff he is
after might be called “furflex” (ie. the molding that goes around the door -
but not the posts - of an XJ6 S1). Well, when I visited XKU yesterday it turned
out that furflex will NOT do the job, and that this part is not really availa-
ble (at least not at XKU or any other source I know) except in black…
Hal Rogers siad he sells this product, but I am not sure whether he meant
furflex (which works fine for earlier models, but apparently not for the XJ6
S1) or something that would work for the XJ6 S1. Any comments Hal?
The part numbers for the Ser1 are RTC2609, 10, 11, 12…though rears may be
different for SWB and LWB versions. I am fairly sure that the originals are
a preformed seal,not cut to length …I have never tried the furflex or
aftermarket door opening seals to see if they would work. Black is the only
readily available color when you buy “by the yard” furflex or equiv. The
factory fit seals that I have access to are made in England, cannot confirm
if OE or reproductions. They are $46.50 each…retail is $54.95 each. I know
the English seals work fine and fit like originals…maybe they are?
However, black is the only color. Hope this helps.
Hal
Hal Rogers
H.D. Rogers & Sons
(318) 742-5044 fax
Date: Mon, 07 Oct 96 16:20:04 PDT
Subject: ‘S’ type grill
Hi
Having recently visited some car shows it is now obvious that I have a MK II
grill on the front of my ‘S’ type for some unknown reason. The center vain is
correct but the grill is wrong.
Could anybody advise of a source for a replacement/second hand grill.
I believe the vains and the outer piece are 2 parts, I’ve found 1 place that has
the center vains for $75, this seems reasonable because a local scrap yard wants
big bucks for a complete unit.
Does anybody want to swop a MK II for and ‘S’ type.
Regards
Steve
Date: Mon, 07 Oct 96 16:14:12 PDT
Subject: Rear window replacement
Hi
I recently bought a 65 ‘S’ type Jag, but the rear window was out of the car
because the rear rubber had corroded.
I now have the new rubber seal and need to reinstall it. The weather here in
California is starting to cool and we may have some rain soon.
Any advise tips on the installation would be appreciated. I’m experienced with
TR6 front windscreen replacement, same deal with the glass in the rubber then
have a cord in the rubber channel and pull the cord out!
Regards
Steve.
Date: Mon, 7 Oct 1996 17:12:13 -0700
Subject: XJ-S Spark Plug Wires
Kirby,
I was poking around your website today and looked at the picture of your
engine. What sort of spark plug wires are you using? As you may
remember from earlier e-mails, I have had problems with arcing among
wires. I replaced the old set with a new Lucas set about 9 months ago,
but have the problem again.
Thanks in advance
(Also would like to hear recommendations from anyone else encountering
good success with a specific type of plug wire)
Aaron,
'85 XJ-S
Date: Mon, 7 Oct 1996 20:26:19 -0400
Subject: Re: XJ220 info
<< Anyone know what sort of engine the “production” version of the XJ220
from scratch? >>
I dont know a whole lot off the top of my head (and I cant go dig out the old
magazines right now), but if was originally designed to have a 12 cyl based
on their IMSA GTP car’s engine. By production they had shortened the car (a
lot, I think about a foot or so) and changed to a twin turbo 6 cyl. Sorry,
thats all I recall right now. Of course, the change made it fall short of
it’s original design goal of 220MPH and it went 212 only - Doug
Date: Mon, 07 Oct 1996 18:36:14 -0500
You see, thats why I drink Burbon. If it is beer and it doesent taste like
shit its called a “ladies drink”
Jim
Nance O’Neil
Date: Mon, 07 Oct 1996 20:56:14 -0400
Subject: Re: Glueman visiting Texas
Hi all,
Since glueman is not often seen on this list many
may not know him. I’ve had many conversations with
gerry and can tell you he is one interesting dude!
If I lived in Texas I would go a long way to meet him!
(Sorry for leaving his post attached, but my post would
make no sense without it!)
Gerry-if you come to Toronto…!
connection with my business branch in California.For the last weeks of this month my wife and I plan to travel around in
Bend National Park. No firm plans yet.Any suggestion from friendly and sympathetic locals of what to do and to see
Glue Man
Charles Daly, Toronto, Canada
'62 E-Type, ots
From: “Barry Cooper” b.w.cooper@acslink.aone.net.au
Date: Tue, 8 Oct 1996 09:25:44 +1000
Subject: XK8 Australian Prices
Interesting that US Jag Lovers think the XK8 is expensive.
Expected Australian price is from $AUS185,000 which (at an exchange rate of
$US1.00 - $AUS1.26) equates to $US146,825.
The quoted US price of $70,000 would normally equate to $AUS88,200. The
difference is Australian duty and sales tax.
Australian wages are generally lower than US as well so XK8s are not
intended for the average Australian enthusiast.
Barry Cooper
Mackay
Queensland, Australia
Date: Mon, 7 Oct 1996 21:41:22 -0400 (EDT)
Subject: Re: XJ40 Oil leak
surgery?
1> inspect around the cam cover gasket. if dry (oil starts lower) go on.
Now, clean the area well. Start the engine and hold at 2000-2500 rpm while
watching the area for the oil to start flowing.
2> If the oil comes from the oval thing on the side of the head (two nuts
hold it on), then the timing chain tensioner is leaking.
3> If the oil comes out of the head/block interface just in front of the
lead exhaust manifold, then it is the head gasket.
Repair requires replacing the gaskets/seals needed. In the case of #3, you
will also cover #1 and #2 in doing the job.
Gerald
Randy K. Wilson
randy@taylor.infi.net
Date: Tue, 08 Oct 96 15:08:49 GMT
Subject: Re: XK8 Australian Prices (Tue Oct 8 09:25:44 1996)
$US1.00 - $AUS1.26) equates to $US146,825.The quoted US price of $70,000 would normally equate to $AUS88,200. The
difference is Australian duty and sales tax.Australian wages are generally lower than US as well so XK8s are not
intended for the average Australian enthusiast.Barry Cooper
Mackay
Anybody know how much one will be in New Zealand?
I guess even more seeing our dollars worth about 0.84 Australian!!
Dave C
'77 XJ-S
From: David J Shield David_J_Shield@ccm.fm.intel.com
Date: Mon, 07 Oct 96 19:12:00 PDT
Subject: re: Kirby’s last message
Yeah, I looked at it twice, too. At first I thought you were
talking to yourself.
Kirby writes and asks:
>Anybody know why Lloyd's reply to my message came through with my
>name in the "From" header? I almost deleted it without reading,
> -- Kirbert | If anything is to be accomplished,
> | - Palm's Postulate
Date: Mon, 07 Oct 1996 20:39:20 -0700
Subject: (My car
Hi Troops!
would like more info. I own a Jaguar XJS V12 convertible ( Black
on Black cira 1989) would like info regarding said car. An expreience to
drive. Please E-Mail at rccola@ctos.com Look forward to hearing from you!
Happy Trails
Date: Mon, 07 Oct 96 19:46:00 PDT
Subject: XK’s Unlimited open house
I drove to the XK's Unlimited open house this weekend with my two
boys, James and Jonathan. 400 mile drive from Scaramento By the
time we got there I had them convinced that this day was *my* day and they
should be very nice to me, and that tomorrow would be *our* day (i.e.
*their* day - as usual).
We arrived late-ish - about 1:30, but this gave us plenty of time
to look around and meet people. I bought a bunch of miscellaneous
parts for my E, and saved 20% and shipping. At the make_an_offer
table I picked up a new direction indicator (turn signal,
Americans) switch for a '71, but maybe it'll fit. For $5, it'll
fit. I dunno if the turn-signal-stalk horn button is compatible,
if not I'll be following Mike Frank's instructions on how to get
a series II E horn to honk from the center button.
LLoyd Nolan found me and introduced himself. Said I'd just missed
Ryan Border leaving in his MKII.
There were some beautiful cars there. I spoke with one of the XKU
guys who showed me just what they had done to a 74 OTS E and a MKII
to justify the $120K each to the owner (some rich guy in Florida).
Polished down to the last screw.
Jason Len told me that the turnout this year was light compared to last
year. I'll be there next time.
My 7-tear old son came up and said 'Dad, you like beer, don't you?'.
I was busy and replied yes. Next thing he's running back with a
cold one. Seeing it was the last one, he had hidden it way down in the ice
so no one else would get it before he found out if I wanted it or not.
*Now that's* taking care of Dad. (But I'm not so low that I'd send my kid
to fetch me beer!)
Now I see from the jag-lovers mail traffic that others were there, too.
I've got to do a better job of looking for you all.
Best,
Date: Tue, 08 Oct 1996 15:54:11 -0700
S1) or something that would work for the XJ6 S1. Any comments Hal?Hal Rogers Wrote
I have replaced the beige furflex on my Daimler with new furflex brought
by the metre from the NZ Daimler and Lanchester Owners Club.
If you wish I could contact them and see what other colours they have
and if they are applicable to S1’s.
Let me know.
Shane Gibson
Wellington, New Zealand
1968 Daimler V8 250 - either Baldrk or Edmund (I haven’t made my mind up
yet)
Date: Tue, 8 Oct 1996 04:03:27 +0100 (MET)
Subject: [XK8] Price
gunnar@medial.se (Gunnar Forsgren) wrote:
It’s time to begin saving up. A reasonably equipped cabriolet
costs 750 000 Skr (Swedish Crowns).
I just checked today. In Norway the same car costs around 1.5 million
Norwegian Kroner. At 6.5 Kroner to the $ that should work out to a
whopping $230,000! (Around 1.3 million or $200,000 for the coupe).
I could comment further on that, but then again you all know my feelings
about the prices of cars in Norway…
By the way, what are the chances of getting a Green Card in the US these
days?
Gunnar
Date: Mon, 7 Oct 1996 20:12:48 -0700
Subject: RE: XJ40 Oil leak
Randy,
RE: XJ40 Head Gasket leak
Has Jag updated the gasket to prevent this problem recurring? Is the problem due to poor gasket design, head design or possible head warping? Any ideas – I don’t want to be re-doing head gaskets for a relatively minor leak.
Also – any suggestions on aftermarket kits for updating XJ40 rear suspension. The local Jag dealer wants $1100.00 CDN for the OEM conversion kit. (About $800.00 US) Ouch
Finally – anyone know of good quality Stainless Steel exhaust for XJ40? There seems to be lots of aftermarket for SIII, but I guess XJ40’s are just starting to blow catalytics!
Mike Everatt
1987 1/2 XJ40
Sent: Monday, October 07, 1996 2:41 PM
To: jag
surgery?
Gerald
Randy K. Wilson
Date: Tue, 8 Oct 1996 04:54:43 +0100 (MET)
Subject: [XK engines] Lifespan?
Jim Goring jgoring@ccnet.com wrote:
Also, 84000 miles on an unrebuilt XK engine is alot. If it really is
original, it will need an overhaul soon, and that will cost more than
Really? All XK engines?
My '86 Series III 4.2 has so far seen 180,000 kilometers (112,500 miles) of
service and I know for sure it has never been rebuilt. Actually, as I
removed the exhaust side valve cover to fix a tappet guide problem it
looked to me as this had never been off before! All the nuts looked
untouched, there were no signs of previous scraping of gasket material
on neither the head nor the cover and the remains of the gasket were a
real pain to remove. I’m ready to believe that that gasket has been on
there for ten years…
(And now for the part where I knock on wood). The engine runs like a
dream, has good oil pressure and no noises. Like Ryan wrote about his XK
engine, it pulls like a train to 4,500 rpm and beyond.
Thinking about it, I think that’s the part I enjoy most about the car.
That wonderful engine! Well OK, I like the luxury of the interior
too. A Series III XJ6 certainly is no sports car, but when you let
the engine play above 3000 rpm the car really comes to life. The sound
of an XK engine climbing through the revs…
I love that car!
(Yes I worked on the car today and fixed a couple of minor problems that
had been annoying me and then went for a long, spirited and successful test
drive afterwards. How could you tell?
Gunnar
Date: Tue, 08 Oct 1996 14:47:49 -0700
It would have helped if I had put the URL in the sig file!
http://www.uq.edu.au/~qmdhalla/
is my home page but skip the junk and go straight to the mess at
http://www.uq.edu.au/~qmdhalla/redone.htm
/dlh.
*** Without Treatment Development our past can only rot ****
David Hallam Senior Scientist, Materials Conservation
Queensland Museum, PO Box 3300 South Brisbane Qld. 4101 Australia.
************************* Standard Disclaimer;*************************
D.Hallam@mailbox.uq.edu.auhttp://www.uq.edu.au/~qmdhalla/**
Date: Mon, 7 Oct 1996 22:16:36 -0700
Subject: RE: XJ40 Oil leak Re: rear shocks
kit. (About $800.00 US) OuchMike Everatt
1987 1/2 XJ40
Mike,
I don’t know much about your other problems, but I can make a
susggestion on those rear shocks, from my previous experience with my '89
XJ40. I would VERY STRONGLY suggest that you buy the conversion kit
supplied by Jaguar. I have spent over $1000 US , on just trying to get my
car to ride beautifully again, and this was accomplished through the Jaguar
(Bilstein shocks) conversion kit. This kit includes everything: New shims,
spring seats, shocks, and most importantly NEW LONGER SPRINGS!
First, I spent a few hundred dollars on trying to fix the hydraulics, no
luck! Then I spent about $250 on the KYB conversion kit (it’s also offered
through Terry’s Jag parts) and tried to save myself money over the expensive
dealer kit. Little did I know that the KYB aftermarket kit rides HORRIBLY,
and most importantly the whole car sags in the back because the kit doesn’t
offer modified springs. Finally, I just got fed up with the cars horrible
ride, and ugly sagging profile. So, I sprang for the dealer conversion kit!
Now, I’m really happy, the car rides EXCELLENTLY and I can now watch other
XJ40’s bounce and sag, and I know I’ll never have that problem again! It’s
also perfectly level do to the new springs included with the kit.
$800 US for the kit seems pretty high, unless that includes
installation. I purchased my factory JAGUAR kit for around + - $450, and I
installed it myself with no trouble (I was used to it already because of
removing/installing the KYB’s a few times trying to correct the sagging).
The current issue of Hemmings I think has some places offering the kit for
about this price, if not a US dealer could probably ship it to you and save
you a few $$$.
Well, after all this grief of trying to save a few extra dollars, it
turned out I lost more money than I would have, and I also have a box full
of new KYB shocks/springs with about 200 miles on them, that no one wants
either. Save yourself some grief, and find the dealer kit somewhere that is
at a more appealing price. In my opinion the KYB kit is a rip off, and
since that occurance I will only use parts on my car that come straight from
Jaguar and are specifically manufactured by the companys suppliers.
Hope this is of some help!
Eric
cobac@ix.netcom.com
1989 XJ40 Vanden Plas
End of jag-lovers-digest V2 #412
id for jag-lovers-digest-out; Tue, 8 Oct 1996 16:39:34 +0200 (MET DST)
Date: Tue, 8 Oct 1996 16:39:34 +0200 (MET DST)
Message-Id: 199610081439.QAA12544@ekeberg.sn.no
Subject: jag-lovers-digest V2 #413
Precedence: bulk
jag-lovers-digest Tuesday, 8 October 1996 Volume 02 : Number 413
Big Mac index - marginal Jag content
ECU maintenance
Re: XK8
SS-100 information
S-Type Rear window replacement
Re: Beer & Jaguars (clarification)
JAG: Re: XJ220 engine
Re: S-Type Rear window replacement
XJ-S Drain Plug
TO all XJS owners…
Re: XK’s Unlimited open house
Trips to Harlow UK, and San jose
Stolen 1986 XJ12 Vanden Plas
Re[2]: S-Type Rear window replacement
Libel on the Net; XK120
Cat in the Hat
62 E, oil pressure too high
Date: Mon, 07 Oct 96 22:27:00 PDT
Subject: Big Mac index - marginal Jag content
Robin Cooper brings up an interesting tidbit. The purpose of the
Big Mac index is, as Robin says, to evaluate currencies against
each other to determine which are under-/over-valued, and what is
par. This is feasible since the Big Mac is made locally, of local
materials (beef/wheat/and whatever else is in there) with local
labor. All paid for, up and down the food chain, if you will, with
local currency. It actually compares well with other, higher-brow,
indexes.
Now if you could smuggle Big Macs from countries with under-valued
currencies and sell them in countries with over-valued currencies
(there can be a 2:1 spread), you'd purchase that XK8 in no time.
Some of the rest of us will have to wait till the XK8s have a few
10's of thousands of miles/kilometers on them. I may wait till
there's a restorable one - perhaps one of those lucky 'barn finds'
that we hear about.....
The last time I looked at the web site
http://www.economist.com
the Big Mac index wasn't there; maybe after the next annual update
of the index. It's a marvelous magazine, IMHO.
>From: COOPER ROBIN D <COOPER_ROBIN_D@Lilly.com>
>Date: Fri, 04 Oct 1996 13:23:26 +0000 (GMT)
>Subject: currency conversion again
>the magazine 'the economist' uses a measure of currency comparison
>to see whether a particular currency is over/undervalued in
>relationship to other currencies. what they compare is the cost of
>a big mac and fries at the local macdonalds-no kidding .i wonder
>how many big macs the new jag will cost in the different markets.
>robin
Date: Mon, 07 Oct 96 22:41:00 PDT
Subject: ECU maintenance
Hi All. Re: the recent note from Tom G., suggesting retouching
solder joints within the ECU in case any are bad. *If* you are
certain that the ECU is bad, then at least you couldn't make it
worse. *If* you're not so sure, you should consider the external
connectors, as Tom suggests, first. Anyway, if you're committed to
getting inside the ECU, you should understand what ESD
(ElectroStatic Discharge) will do to the CPU inside the ECU box. A
spark too weak for you to notice, will toast the CPU, esp. on the
early '80s CPUs. And then it'll be real dead. The potential is
definitely still there on newer ones. If you retouch solder
joints, use a low-wattage soldering iron. You'll cook the
sensitive parts faster than you can believe.
In my experience, as Tom's, connectors are the place to look first.
Although I did debug my Sony Discman (1984 vintage) a few years ago
and find a bad solder joint in a moving part (the voice-coil lens
positioner). That was rare.
BSEE
'70 XKE2+2 - points, a coil, and a screwdriver.
'84XJ6 VDP
Date: Mon, 7 Oct 1996 22:50:49 -0800
The local salesman said Jaguar brought it into the US about $10,000 under
what their initial thoughts were. This was apparently done under the
influence of a council of 5 big dealers in the US.
Of course, this could also be a line to keep the price close to invoice.
Date: Mon, 7 Oct 1996 22:48:37 -0800
Subject: Re: XK8
tire burner.MikeC
Subject: XK8
Date: 10/5/1996 10:17 AMThe XJR has the same rear suspension and
have it turned off.
I test drove a coupe over the weekend. The base XK8 does not have traction
control. The salesman said that it has some electronically controlled
system that reduces the flow of fuel to the engine if it detects
instability. I forget the name of this system.
My test drive was not tremendously eventful. The XK8 has a very smooth,
steady, and quiet delivery of power. It didn’t have the same kick as my XJR
when I floored it on the freeway. It’s a nice car, but I didn’t get a real
chance to test it. I’m going back to try a convertible when they get one in
for test driving.
Date: 08 Oct 96 02:44:47 EDT
Hi Jim Isbell,
Can’t help it, I must slag you for the remarks on beer. It may be that beer is
bitter
but it is supposed to be so…
…and that comes from a bourbon drinker !. Bourbon is the most disgusting
whisky-wanna-be
which bears no resemblance to the real thing produced in the better areas of
Scotland.
Jim Beam.& Jack Daniels… How can anyone drink this cow-piss? It’s like
Panda’s next to E-types (
(that was the JAG-CONTENT) !!!
Now show me a good Bourbon and I’ll be happy to taste it.
Sweet beer can be bought in Denmark, Belgium, Germany… And I find it
difficult to find really bitter beer…
Could it be that taste is non-discussable ? No never…
Oh, well…wasting bandwidth again…
Jeffrey Gram
Date: Tue, 8 Oct 1996 10:02:44 -0700
Subject: SS-100 information
Mark Frank wrote:
Can anyone help me with specific tips? What
are the strengths and weak points of this car? What is the present market
value? Any info would help.
Don’t ask, buy it!
Bard
Jaguar XJ6 Series I 1973
Date: Tue, 08 Oct 96 09:13:47 gmt
Um, it’s been doing this for some time, confused me before. I think it must be
Lloyd’s mailer a bit weird.
Alastair Lauener
Date: Tue, 08 Oct 96 09:21:12 gmt
Subject: S-Type Rear window replacement
There should be no difficulty, simply put seal in place, rest window on seal,
(second bod handy here) and prise lip over window. I used a blunt awl, which I
ben to a convenient angle, and since used it on another S-Type. Give beer to
second bod. Actually, the window doesn’t sit well , until the central filler/
expander tube bit is in the seal, to hold everything in place. This is much
more difficult to do. You need to expand the centre of the seal, and run the
tube in. Very sore on the thumbs and fingers. Tempting to use implements to
help, and be careful of the paint if one slips. The book says to use the cord
method, but personally, I have never been successful with that.
- Alastair Lauener *
- 1964 3.4 S-Type http://www.sn.no/home/nick/alas.html *
Date: Tue, 8 Oct 1996 03:42:32 -0500
Subject: Re: Beer & Jaguars (clarification)
I bit my tongue for a while but let’s try this once more, since I started it.
My point was supposed to be.
There is no such thing as a bad beer. (refer footnote #1)
There is no such thing as a bad Jaguar (model) (refer footnote #2)
#1 However, some people don’t like beer (for their own, perfectly
valid, reasons)
#2 However some people don’t like Jaguars (for their own reasons which I
don’t (need to) understand)
I am sure Jim is not the only one on this list who falls into category #1.
However, my analogue is still valid.
P.S. I never mentioned whether or not I actually liked beer either.
Date: Tue, 8 Oct 96 10:26:20 BST
Subject: JAG: Re: XJ220 engine
Gunnar Helliesen asked about the production XJ220 engine…
I believe that this is the engine originally designed from scratch by Rover
for the Metro 6R4 group B rally car in the early/mid eighties. It was then
normally aspirated and had the fattest torque curve imaginable. This
engine was used in the Spice sportscar that competed in the WSC at around
the time of the V12 Jags (late eighties). When group B cars were banned
Rover sold the engine. TWR bought the rights either then or later, and did
a great deal of development (i.e. twin turbos etc) for use in the Jags (after
or concurrent with the 48valve V12 development).
(As an aside, the 6R4 development hacks used a V6 which was cut down from the
Rover (ex Buick) V8, but the later engine owes nothing to this)
Hope this is of interest…don’t know about the transaxle.
Cheers,
Ted
Date: Tue, 8 Oct 1996 13:53:40 +0200 (MET DST)
Subject: Re: S-Type Rear window replacement
tube in. Very sore on the thumbs and fingers.The book says to use the cord
Works for me. But before you do anything else, smear the gasket with
suitably “slimy” washing-up detergent along the lip.
The tube should also be lubricated before you insert it. To fit it, I
fabricate a tool from cloth hanger wire and a bit of broomstick that looks
something like this:
__________
!________! <--- Drill a suitable hole for the
|| wire, secure with epoxy glue
|| <--- Optionally wrap a few rounds of fine
/ \ string here, securing with glue
+----------------------> \__/
+-- The size of the loop should be so that the rubber tube will fit
with a slight clearance.
For the less adventurous, similar tools is also available quite
inexpensively from various auto tool suppliers. But ordering such a thing
means that you have to be a person capable of planning a few days ahead
;-). Besides, I really enjoy making useful tools from wire hangers and
pieces of broomstick. Plus you don’t get to make ASCII drawings of them.
Make a similar but J-shaped tool for fitting the chrome surround. Be sure
to round off the tip nicely.
For sealing, never use anything but the forever sticky black 3M window
sealer stuff. Clean off excess with White Spirit.
Egil
Email: egilk@sn.no Voice: +47 22523641, 92022780 Fax: +47 22525899
Snail: Egil Kvaleberg, Husebybakken 14A, 0379 Oslo, Norway
URL: http://home.sn.no/home/egilk/
Date: Tue, 08 Oct 96 07:27:00 PDT
Subject: XJ-S Drain Plug
In reply to the below message, I have an 88 V12 XJ-S ( MFG 3/87 ) & it does
not have the remote drain plug. I would have to un-hook the lower hose
before I had a drain plug added a few months ago when I had the radiator
rodded.
John Himes
88 XJ-S 98K Miles
change happened?
Thomas E. Alberts
Date: Tue, 08 Oct 96 14:31:59 BST
Subject: TO all XJS owners…
Hi folks!
Almost by the minute I’m convincing myself more and more that I want an
XJS. It won’t be particularly new though so I’m still thinking about it.
Can people mail me with what they like about their XJS and what they
dislike?
My main worry is maintenance costs, especially as I’ll be looking at '80s
Jags. Just how reliable are the engines,'boxes, axles, racks etc? Do they
stand up to spirited driving well? I’m no stranger to car mechanics so I’d
hopefully be able to do my own labour. Do things break often, like some
other British cars, or do the Jaguars live up to their ‘precision
engineered’ image? Are there any ‘bad’ years for the XJS? DO they all
come with leather/wood etc?
I’d imagine that UK Jags differ to overseas ones. Would this be correct?
Do the US ones have all the power zapping emissions control equipment on
them?
Steve
Date: Tue, 8 Oct 1996 09:38:57 -0400
Subject: Re: XK’s Unlimited open house
I drove to the XK’s Unlimited open house this weekend…
Did you by chance see the SWB V12 OTS (S1/S3) that they have pictured in their
catalog? I would love to see that car.
Mark
Date: Tue, 8 Oct 1996 09:22:00 -0400
Subject: Trips to Harlow UK, and San jose
I will be travelling to Harlow, UK on business
from Oct 24 to Nov 1. I would be very interested
in meeting any “jag-lovers” who might be in the
area. I also have the weekend off to do whatever,
so I thought I might do a little sight-seeing. Any
info would be greatly appreciated…it will be my first
trip to England. I’ll be staying at the Churchgate
Inn in Harlow.
Also, from Nov. 9 to 15 I will be in the San Jose area
of the US. Again I’d be very interested in meeting
any “jag-lovers” who might be in the area. I plan
on going up to Stockton to Jag Heaven on the 14th,
so if anyone is interested in that, please let me know.
I’ll be staying at the Red Lion Inn in San Jose.
Please contact me off-line.
Regards, Mark Roberts Phone: (613) 763-2924
Ottawa, Ontario, CANADA Fax: (613) 763-3970
1988 VDP - SIII V12 email: markdr@nortel.ca
1963 3.8L E-Type Coupe - 16 years into a 3 year project
Subject: Stolen 1986 XJ12 Vanden Plas
I am sad to report that a 1986 Sage Green XJ12 Vanden Plas
was stolen yesterday in the Ottawa, Canada area.
You may all remember this car, it was the one that Dennis
Rockwood tried to import into the US, but could not
get it to meet his State’s EPA emissions standards.
Dennis’ loss, my friends gain…until yesterday anyway.
Car serial number is SAJBN1047GC455683. Note also that
the C455683 part is etched into all the windows, making
parting of the car less profitable
Could all those members in the Ottawa, Montreal and Toronto area
keep a look out for this car, and pass on the info to
other Jag-o-philes. Thanks.
Date: Tue, 08 Oct 96 15:07:53 gmt
Subject: Re[2]: S-Type Rear window replacement
I used a silicon spray as a lubricant, worked very well, and cleaned off fairly
easily
To fit it, I fabricate a tool from cloth hanger wire and a bit of broomstick >
that looks something like this:__________ ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! !________! <--- Drill a suitable hole for the || wire, secure with epoxy glue || || <--- Optionally wrap a few rounds of fine / \ string here, securing with glue +----------------------> \__/ | +-- The size of the loop should be so that the rubber tube will fit with a slight clearance.
Exactly. Which I had the patience to make something like that. Wish I had the
patience to draw that too
Yup.
Alastair Lauener
Date: 08 Oct 96 10:19:02 EDT
Subject: Libel on the Net; XK120
John Littler: you would be wrong to assume that US libel laws are worse
than Aus. Aus has some of the most restrictive libel laws in the Western world,
different too from state to state. You need to be very careful indeed. There
have certainly been several actionable libels on Jag Lovers in the past. Of
course, one of the biggest problems of being sued is facing up to the stress and
legal costs - even before you consider if the other guy might get damages, or
you might win yourself. Few are prepared to take the risk - why would you?
Lawrence Buja: could you find out and send me the numbers of the XK120
coupe your friend found? I will add it to the worldwide register.
Regards, John Elmgreen
Date: Tue, 8 Oct 1996 10:08:52 -0400
Subject: Cat in the Hat
Just got a 1989 xj6(40) vanden plas. 39k miles, 10G US price. Thought
I’d share the news. Now the semi-spousal unit doesn’t have to drive my
xj-s! Any theories on the “new” car would be appreciated. It’s being
driven in North Carolina, where the rain never stops.
Steve
'88 XJ-S
'89 XJ40 Vanden Plas
Date: Tue, 8 Oct 96 08:38 MDT
Subject: 62 E, oil pressure too high
I have a problem with oil pressure on my 62 E type. Recently, after
replacing the instrument voltage regulator, I noticed the oil pressure gauge
was pegged at over 60 psi. I assumed I had wired the gauge incorrectly, and
drove it to work and back. When I got into it, the wiring looked ok, so a
couple of days ago I replaced the sender unit. No change.
I’m starting to believe that the pressure is real. The gauge reads zero
with the ignitions on, but not running. Within a few seconds of starting
the engine, the gauge is maxed out (over 60 psi). I’ve also noticed that
now I am blowing smoke on acceleration (much more than normal). I assume
this could be a result of the pressure being to high.
This seemed to have all come on very suddenly. I’m afraid to drive the car
until I get this resolved. I’m going to change the oil and filter tonight
in case the filter is clogged.
Could the bypass valve cause this?
Is there a mechanical oil pressure gauge available with the correct thread
that I could put in to verify the pressure?
BTW, I have started to put together a list of links to Jaguar pictures on
the web. So far these are just links to some photos on team.net and some E
types from the jag lovers site.
My home page is at http://rainbow.rmi.net/~jgardner/top.htm
Or, you can go directly to the pictures at
http://rainbow.rmi.net/~jgardner/jags.htm
Thanks!
John Gardner
62 E type OTS
End of jag-lovers-digest V2 #413
id for jag-lovers-digest-out; Tue, 8 Oct 1996 21:12:42 +0200 (MET DST)
Date: Tue, 8 Oct 1996 21:12:42 +0200 (MET DST)
Message-Id: 199610081912.VAA29272@ekeberg.sn.no
Subject: jag-lovers-digest V2 #414
Precedence: bulk
jag-lovers-digest Tuesday, 8 October 1996 Volume 02 : Number 414
Re: Raffle
LLoyd’s strange messages…
XJ40 seat noise
NJCW : beernuts @ pretzels
Re: 89 XJ40 re Xks Open House & Rally Re[2]: XJS V12 radiator flush XJ40 - Inexpensive center cap clean up Re:
89 XJ40
Re: jag-lovers-digest V2 #412
Re: XJ-S Spark Plug Wires
Re: XJ220 info
Window Lift Switches, good sub.
XJ-S front end suspension
Date: Tue, 8 Oct 1996 08:52:55 -0600
Subject: Re: Raffle
You can find information on the XK8 Raffle at:
http://www.ism.net/~globetech/foundation/raffle/rafflehome.html
A few weeks ago there was a post about an XK8 raffle.
I’ve lost the specifics and was wondering if anybody could steer me to it.Jo-Ann Gross
From: David J Shield David_J_Shield�m.fm.intel.com@vm1.cc.nps.navy.mil
Why, yes David. You are right. Kirby is right. I do.
< Yeah, I looked at it twice, too. At first I thought you were
< talking to yourself.
< David
LLoyd
Date: Tue, 08 Oct 96 08:26:43 PDT
Subject: LLoyd’s strange messages…
Well, since my mailer has generated so much comment, guess I’ll send this
out to everyone. The only thing that could be worse would be if we started
argueing over beer, or trying to determine which Jag is the prettiest.
If I respond to a message, the message comes to you looking ‘normal’. But
if I want to send part of the message along with my responce, I use the
foreward command, delete out as much of the incoming message as is needed,
and then add my comments above and or below it. Apparently that message is
the one that is confusing to you. It genertates a much longer header file,
tracking the message back to the original sender, through me, and foreward.
But, to get to the important stuff, beer is good, a yellow car is the
fastest color, the “E” type is the prettiest, and my dad can beat your dad.
LLoyd
Date: Tue, 8 Oct 96 9:06:52 PDT
Subject: XJ40 seat noise
The driver seat of my XJ40 seems to be getting a bit “loose”, so
when it goes over a bump it makes some noise. It’s a minor
problem, but annoying nevertheless. Can anyone offer some suggestions?
Roger Peng (408)765-7863
Intel Corporation
Design Technology, Physical CAD
Date: Tue, 8 Oct 1996 12:37:14 -0400
Subject: NJCW : beernuts @ pretzels
I almost hate beer, always have. I have encountered very large numbers of
ados who will argue with great vigor the various subtlties of one beer
against another. We are talking about 14-17 year old experts on all things
alcoholic; for many it is the core of their lives.
My point : I have always wondered if the attraction to beer would be there if
the stuff had no alcohol. Of those who say yes, I am skeptical. Of those
who say that they hunt because they enjoy the out of doors, I am skeptical.
Of those who say “It’s all relative”, I am skeptical. Of those who say
On the other hand, I am ecstatic over the taste of certain European cheeses.
Most of my fellow Wisconsinites will not get in the same room with them
while I can’t stand Wisconsin cheese.( I suspect that Wisconsin cheese is
much like Bull Frog Beer must be.) Pearls to Swine.
Ok, no pretzel content whatever either.
David “It’s dogged as does it.” - Charles Darwin
Date: Tue, 08 Oct 96 17:08:00 gmt
acouple of days ago I replaced the sender unit. No change.
John, sound like the gauge is earthed. You say that you changed the voltage
regulator, but if you moved the guiage in any way, it is very easy to earth the
gauge to the dash using the locating pegs. How do I know?
Alastair Lauener, 64 3.4 S-Type
Date: Tue, 08 Oct 96 17:02:42 gmt
Information on the XJ220 engine is available at
http://www.jagweb.com/jdht/xk8eng.html,
from the JDHT.
Alastair Lauener
Date: Tue, 8 Oct 96 10:04:15 PDT
Subject: Re: `89 XJ40
Wow, that’s a great price. Those in Australia and Norway must be
extremely envious. How is the cosmetic condition? Any problems so far
with the car?
Sometimes I don’t understand the stunning depreciation on these
cars. Why would someone want to give away a low-mileage, top of the
line Jag for so little money?
Intel Corporation
Date: Tue, 8 Oct 1996 10:13:45 -0700
Subject: re Xks Open House & Rally
After reading Ryan Border and David Shield’s posting re their experiences at
the XKs Unlimited open house and rally last weekend, I am led to wonder how
many more jag-lovers I failed to meet there. Unlike the above I only had to
drive my XK 120 the 5 miles from my house to XKs. (Those bugs on the wings
were only there for show.) Perhaps next year anyone who attends would like
to drop by my place for something a little stronger than the beer and soft
drinks that were served with the barbeque.
Perhaps I should add that after attending these show-rallies for something like
six to eight years, this year I actually won first prize which consisted of
a one hundred credit at XKs and a 3 day, 2 night stay at the San Luis Bay Inn.
Of course I’ll have no trouble finding a use for the former. However, I don’t
know what the heck I’m going to do with the latter.
See you next year.
Earl Huff
53 XK 120
85 XJS
Date: Tue, 8 Oct 1996 13:14:27 -0500
Subject: Re[2]: XJS V12 radiator flush
–IMA.Boundary.673697448
Content-Description: cc:Mail note partMy '88 has no radiator drain, remote or otherwise.
Anyone earlier?MikeC
Subject: Re: XJS V12 radiator flush
Author: Patrick Siu patrick@idacom.hp.com at Internet
Date: 10/7/1996 10:47 AM
is to include when Jaguar remove the “remote control radiator drain plug”.
This plug is definitely not exist in my car. Does anyone know when the
change happened?
Patrick Siu
89 XJS V12 Conv
- –IMA.Boundary.673697448–
From: Michael Powers/TEIR/Thomson Michael_Powers@teir.com
Date: 8 Oct 96 13:54:11
Subject: XJ40 - Inexpensive center cap clean up
Hi all:
My XJ6 has the standard aluminum pepperpot wheels with the plastic chrome-like
center caps.
Two of them had some serious pealing problems, revealing the lovely gray
plastic
base.
Well, up at my local home improvement center, they carry this chrome-like paint
called “Color Works by Krylon”. The stuff went on very cleanly, with no runs
or drips.
I didn’t even have to prime the plastic, and the caps look
brand new. Time will tell how the paint holds up, but right now (after several
weeks) they are looking
as good as new!
Check it out if you want to save some money over replacement.
Rgds,
Mike
| mpowers@teir.com
| On my block, a lot of people walk their dogs and I always see them
| walking along with their little poop bags. This, to me, is the lowest
| activity in human life. Following a dog with a little scooper.
| Waiting for him to go so you can walk down the street with
| it in your bag. If aliens are watching this through telescopes,
| they’re going to think the dogs are the leaders of the planet.
| If you see two life forms, one of them’s making a poop, the
| other one’s carrying it for him, who would you assume is in charge?
| -Jerry Seinfeld
Date: Tue, 8 Oct 1996 19:58:07 +0200 (MET DST)
Forwarded to: SMTP[Jag-LOVERS@SN.NO]
cc:
Comments by: PLacey@Petrol@SwRI08
Comments:
This is about the going rate for an XJ-40 in the U.S. I bought one for a
similar price in perfect condition. The depreciation is due to the
unbelieveable string of minor problems that the average person does not want
to deal with. Nothing that is not easily fixed to those of us that love the
cars, but enough to be a very severe newsence to the non DIY type person who
still wants to keep the car in good shape. So far I have managed to do
everything myself.
As a side issue, it is interesting how the volume of XJ-40 traffic on the
list is increasing so rapidly relative to the volume of other models. Must
be more of us XJ-40’ers joining up as the design gets older?
Paul Lacey, Texas
-------------------------- [Original Message] -------------------------
with the car?
Intel Corporation
Date: Tue, 08 Oct 1996 14:14:13 -0700
Subject: Re: jag-lovers-digest V2 #412
Hello, I am a relatively new subscriber to this list. I have a few (dated) comments about some of the items I
have seen on the mailings. To the person that wanted to buy a car that was no longer the original color: If
you like the color it is in now, buy it. If you don�t, you can paint it again to your preference. If you are
concerned about the value of the car since it is no longer original, you can speak with a professional
appraiser. My guess is that the condition of the car is far more important (from a price perspective) than the
original color. Look at the auction pages on the web. See much of anything that isn�t red? Think they were
all red to begin with? To the person that wanted to know how to troubleshoot a coil. I strongly recommend
that you DO NOT HOLD THE COIL WIRE UP TO A FUEL LINE AND CRANK THE ENGINE. I saw a fellow do this one time (OK
he had also disconnected the fuel line from the carbs) and the resultant fire destroyed the car. Enough
comments from the peanut gallery. I have a question about the proper placement of a US standards plate. I
have a 1968 E type roadster #1E107707. It is just coming off a ground up restoration. I have a small
aluminium plate about 24X76mm (15/16x3in) it is rounded at each end giving it an ovalish shape. The plate says
- –1st line: �THIS VEHICLE COMPLIES� – 2nd line � WITH ALL APPLICABLE U.S.� – 3rd line: �FEDERAL SAFETY STDS.�
- – 4th line: �EFFECTIVE JAN: 1st. 1968.� – 5th line (and in slightly smaller text): �JAGUAR CARS LTD. COVENTRY
ENG.� Know where this plate belongs? Everyone that I have talked to so far about the correct placement of this
plate has quoted a slightly different text. If anyone has a �68 imported into the U.S. ( I think this car came
in via Canada) that has a plate with the exact text, would you please send me details.
J.Dart, 1968 BRG (formerly midnight blue) ots.
Date: Tue, 8 Oct 1996 14:24:57 -0005
Subject: Re: XJ-S Spark Plug Wires
Aaron:
Kirby,
As anyone who has my book will tell you, I don’t put a lot of value
on “original” parts – especially when it’s Lucas we’re talking
about. When I suspected my spark plug wires, I replaced them with
generic wires available at any auto parts store. I simply bought two
sets to get enough wires for a V-12.
You can get anything from a roll of wire and a package of connectors
all the way to completed sets, so I got a “semi-tailored” set – one
end of each wire has the spark plug connector attached, but you cut
the other end to length and attach the distributor cap connector
yourself. The wires on the V-12 are shorter than most, this allowed
me to provide the right length and not have lots of excess wire
laying around.
Another feature to look for is the angle of the spark plug connector.
Some are straight, some are 90 degree. What the V-12 needs is a
slight bend, so I selected a kit with connectors that are straight to
begin with but can be bent to whatever angle is needed. This allowed
me to provide DIFFERENT bends at different cylinders – working on
these plugs, you need all the help you can get!
Of course, silicone is a must.
There is also the choice between 7mm and 8mm wires. At the time, I
would have loved to install 8mm wires, since the Jaguar ignition
system is really hot. However, I couldn’t find an 8mm set that had
the type connectors to fit this distributor cap; the 8mm sets all fit
caps that the connectors look like the top half of a spark plug,
rather than holes. So I ended up with a 7mm set. Another option
would have been to fashion adaptors for the cap, possibly from an old
set of spark plugs. Maybe there are suitable 8mm sets available
today.
All aftermarket kits seem to be bright colors. I didn’t care,
although I do think it looks kinda neat.
The sets I ended up with were made by Auto-Tune and sold by AutoZone
as part number 2300. The two boxes undoubtedly still cost a bunch
less than a single Jaguar set. And since each set has enough wires
for a V-8, I got four plug wires and one coil wire to spare.
Ironically, my problem turned out not to be the wires, apparently the
original set was fine.
– Kirbert | If anything is to be accomplished,
| some rules must be broken.
| - Palm’s Postulate
Date: Tue, 8 Oct 1996 14:24:58 -0005
Doug:
The order of this is backwards. Since the car was to be developed
by the racing group, they insisted that the turbo 6-cyl be used
instead of the normally-aspirated 12. The car shortened as a
result.
it’s original design goal of 220MPH and it went 212 only…
In its first road test, it went 220. No reason to expect it not to,
since the turbo six was as powerful and considerably lighter than the
12.
That doesn’t alter the fact that, IMHO, the decision to go with the
turbo six was one of the worst decisions ever made by Jaguar. The
world is FULL of turbocharged screaming exoticars. The initial
promise of the XJ220 was to come out with an exoticar with a serious
engine, capable of 220 mph WITHOUT the need for turbocharging. After
a whole bunch of people had plunked down their deposit for a car that
hadn’t been developed yet, Jaguar ended up having difficulty getting
rid of them. And more importantly, a V-12 XJ220 would have done
wonders for sales of the XJ-S and XJ12, while the V6 didn’t do
anything for anybody.
| - Palm’s Postulate
Date: Tue, 08 Oct 96 13:40:23 -0500
Subject: Window Lift Switches, good sub.
You may not want to read this if you have never
had any trouble with your window and/or sunroof
switches. I have found a switch which is less
expensive, IMHO looks much better, and I am
positive will last much, much longer. The part is
GC number 35-3565 (green light) or 35-3570 (red
light). This part fits the exsisting hole
perfectly, and has a small, coloured illuminated
strip across it, making it easy to find in the
dark. It is rated at 20 amps @ 12 volts and is
(unlike the jag switch) completely sealed so that
dirt cannot contaminate the contacts. They sell
for US $10.92 each and should be available from
any decent size electronics parts house. I got
mine from Shields Electronic Supply in
Chattanooga. (423) 624-0071. The only modification
necessary to use this part is to cut off the plug
(on the wiring harness) and replace it with push
on lugs on each wire. If you don’t like the light
then just don’t connect it.
Phil
Date: Tue, 08 Oct 1996 11:39:54 -0700
I’m willing to ship the kit parts to you one piece at a time.
1987 1/2 XJ40Mike,
you a few $$$.
Jaguar and are specifically manufactured by the companys suppliers.Hope this is of some help!
Eric
cobac@ix.netcom.com
Date: Tue, 8 Oct 1996 12:14:19 -0700
Subject: XJ-S front end suspension
I plan to replace all the worn rubber parts in the front end of my '85
XJ-S this weekend and am looking for advice regarding replacement
bushings. My assumption is that, as with most Jaguar rubber parts,
original equipment is not the best option. Anyone had good experience
with aftermarket options?
All information is appreciated.
Aaron
'85 XJ-S
End of jag-lovers-digest V2 #414
Return-Path: @owner-jag-lovers-di1
Received: (from majordom@localhost) by ekeberg.sn.no (8.7.5/8.7.3/on4)
id for jag-lovers-digest-out; Wed, 9 Oct 1996 03:40:53 +0200 (MET DST)
Date: Wed, 9 Oct 1996 03:40:53 +0200 (MET DST)
Message-Id: 199610090140.DAA24724@ekeberg.sn.no
X-Authentication-Warning: ekeberg.sn.no: majordom set sender to owner-jag-lovers-digest using -f
To: jag-lovers-digest@sn.no
Subject: jag-lovers-digest V2 #415
Reply-To: jag-lovers@sn.no
Errors-To: @owner-jag-lovers-di1
Precedence: bulk
X-Newsgroups: mail.jag-lovers-digest
jag-lovers-digest Wednesday, 9 October 1996 Volume 02 : Number 415
Re[2]: XK8 Traction Control
Re: 62 E, oil pressure too high
Re: XJ40 - Inexpensive center cap clean up
Most beautiful Jaguar, again
beer and other nonsense
Re: Re[2]: XK8 Traction Control
XJ6/SIII rear knocking advice needed
SS-100 current owner wanted
Aluminum polish research (no beer content)
XJ40 seat noise
Re: XJ6/SIII rear knocking advice needed
Re: XJ-S front end suspension
Re: V12 Chain Tensioner Tools
Re: XK8 / E-type Musings
Re: XJS Oil seals and gaskets.
Re: V12 Radiator drains
Re: Vacuum Advances
Re: E-type serial numbers
Jag Certificate
Date: Tue, 8 Oct 1996 15:39:53 -0500
Subject: Re[2]: XK8 Traction Control
- –IMA.Boundary.135408448
I have to correct myself. The dealer told me what was in the cold package,
but now that I have more written information I notice that the block heater
is not listed as part of the package.
MikeC
Subject: Re: XK8
Author: M.Cogswell@zds.com (Mike Cogswell) at Internet
Date: 10/7/1996 10:34 AM
tire burner.
MikeC
Subject: XK8
have it turned off.
- –IMA.Boundary.135408448–
Date: Tue, 8 Oct 1996 16:07:57 -0400 (EDT)
Subject: Re: 62 E, oil pressure too high
John:
60 PSI is not dangerously high. My 4.2 E-Type fluctuates between 25-35 PSI
at idle, and 50-65 PSI at speed. The only way you would be blowing smoke at
this pressure is if your head gasket had given way. Things to check:
1.What is your RPM at idle? Should be about 600, give or take 100.
Higher speed>higher pressure.
2. Bypass may be stuck or obstructed.
3. Oil filer may be clogged.
4. Bad guage or sensor.
The PO of my car installed a mechanical guage. I will check the make
tonight, and E-mail you.
Mike Frank
1969 E-Type 2+2
l
Date: Tue, 8 Oct 1996 16:21:53 -0005
Subject: Re: XJ40 - Inexpensive center cap clean up
Mike:
center caps.
plastic
base.Well, up at my local home improvement center, they carry this chrome-like paint
or drips.
Here’s an experience: On my wife’s car (non-Jag), the center caps
were also plastic, but were cracking – the plastic itself, not just
the chrome. My solution: I went to an auto supply joint and got
four blank-off covers for 1-1/2" conduit knockouts, which means they
were 2" in diameter. Since these things must meet some electrical
code requirements, they must be metal – not plastic. They have a
ring of fingers on the back which can easily be bent a little to fit
whatever size opening near 2" is necessary.
The caps are made of cheap steel, and if left alone they would
probably turn into brown powder in a matter of days – and don’t look
particularly good while they’re new. However, I found that I could
easily make them look a LOT better by polishing them up with some
fine sandpaper – and then KEEP them looking good with a coating of
clear spray lacquer.
What looks good is of course a matter of taste. Since these wheels
are black painted alloy, the shiny steel center caps look great. If
that appearance is unacceptable, another option is to paint the same
color as the CAR – which, in some applications, looks really good,
giving an appearance of class. The paint doesn’t even have to match
that closely, since it never gets within a few inches of the
bodywork.
Nice thing: if I ever lose or damage a cap, a replacement is as close
as my nearest hardware store.
| - Palm’s Postulate
Date: Tue, 8 Oct 1996 10:41:47 -1000
Subject: Most beautiful Jaguar, again
At the risk of beating a dead thread, the most beautiful Jaguar, I must
say that my personal taste ranks the Mark II first, the Mark IV next, and
my XJ6 S III third. My “personal taste” is mine only and IMHO there is
plenty of room for others. Jaguars of all varieties are rare in the
universe of automobiles in stirring the passion, even love, of their
owners and would be owners. A toast to all Jaguars. Cheers!
Robert Gibson
Honolulu '87 XJ6 VDP
Date: Tue, 8 Oct 1996 16:59:22 -0400
Subject: beer and other nonsense
I reckon the list has gone too far now. Things were fine when I was at a
university address and logged on for unlimited periods for free. Now, I am
at home and have to pay phone calls to download messages. I do not think I
am getting great value any more chaps. A lot of it is - as Jim Isbell would
say - shit.
So thanks for the ride
& thanks for the help Alastair,
Signing off the list
Peter Carpenter
1967 420
UK.
PS Thanks Nick
PPS Jan - Pay for the list? Love to, keep the humour and get the Jag
content denser.
Date: Tue, 8 Oct 1996 15:33:09 -0600 (MDT)
Subject: Re: Re[2]: XK8 Traction Control
This message is in MIME format. The first part should be readable text,
while the remaining parts are likely unreadable without MIME-aware tools.
Send mail to mime@docserver.cac.washington.edu for more info.
Content-Type: TEXT/PLAIN; CHARSET=US-ASCII
Content-ID: Pine.HPP.3.91.961008153204.19038T@jaguar.idacom.hp.com
Hi Mike,
The block heater is included in the cold package for the Canadian version.
Patrick Siu
89 XJ2 V12 Conv
To: jag-lovers@sn.no, mneal@wco.com
Subject: Re[2]: XK8 Traction ControlI have to correct myself. The dealer told me what was in the cold package,
is not listed as part of the package.MikeC
Subject: Re: XK8
Date: 10/7/1996 10:34 AMIn the US, traction control is part of the optional “cold package” which
also included heated seats, block heater and headlamp washers.I drove a convertible without traction control over the weekend. It had no
tire burner.MikeC
Subject: XK8
Date: 10/5/1996 10:17 AMLuckily there is a series of racetrack type corners several miles from the
have it turned off.
Date: Tue, 08 Oct 1996 22:36:57 +0000
Subject: XJ6/SIII rear knocking advice needed
Can anyone give me advice on what the following symptoms might indicate?
Recently I have noticed that if I’m driving over slight bumps in the road that
there is a gentle, knocking, not very loud, from the rear of the car.
I thought maybe some of the bushes might be worn in the rear suspension, so I
tried holding onto one of the rear wheels at the top of the wheel, and rocking
it (into and out of the car, as opposed to along the direction of the car). If I
did this quite hard there was a considerable movement and knocking sound. If I
looked under the car along the driveshaft into the differential I could see that
the movement seemed to occur where the shaft goes into the diff. The same occurs
with either back wheel.
Does this indicate the diff has had it, or is it the bearings where the
driveshafts come out of the diff? If I am driving and put my foot onto ond off
the gas I’ll get a clunking from the diff, but there is no noise while driving
along steadily.
Do I need a new diff?
Thanks
Pete Hamel
Date: Tue, 08 Oct 1996 17:20:03 -0600
Subject: SS-100 current owner wanted
The recent discussion of SS100 has reminded me that my grandfather owned an
SS100 many years ago when he lived in England. I would like to locate the
current owner of the car if possible. If anyone can recommend a starting
point that would be helpful.
My grandfathers name is Harold Denny Rogers. Not sure of the years he owned
it but probably it was during the 40s or early 50s. He sold it to a friend
of his before moving to Africa from England. He was living near Liverpool in
a town called Widnes. I am hoping to find a picture with a license plate
number but haven’t yet.
Thanks in Advance,
Hal Rogers
Hal Rogers
H.D. Rogers & Sons
(318) 742-5044 fax
Date: Tue, 08 Oct 96 15:54:50 PDT
Subject: Aluminum polish research (no beer content)
Thanks to several members who graciously furnished me with a magnitude of
ideas to polish my aluminum manifolds. I tried several things in ‘layers’
to get through the oxidation quickly, and these are my results.
First I used a wire brush on an electric drill to get through the thick oxida
tion. Although this works well, I got a bit too deep in a couple places and
left scratches. But works well if you are carefull.
Next, Chrome polish and a toothbrush, scrub it on and let it set a while.
Although it will not polish, it is a good tarnish remover and the toothbrush
gets into all the little corners.
For places still tarnished, use a piece of fine (00 or 000) steel wool and
a screwdriver. Now you are getting close.
Finally, Mothers mag and aluminum polish is recommended by the majority of
those who responded to my inquiery. Put it on with the toothbrush, scrubbing
it in good. Let it set a couple minutes. Polish it off with a clean cloth,
and you will have a nice shine.
Brought to you through the elboe greese of -LLoyd-
From: “Rennick, Kim (AS01)” KRennick@p03.as01.honeywell.com.au
Date: Wed, 09 Oct 96 08:06:00 EST
No solution to offer, other than to mention that the seat cushion can be
easily removed by undoing the single PH screw at the lower front of the
unit. The cushion can then be slipped out after disconnecting the seat belt
detector at the connector. You will then have a full view of and access to
the front seat mechanism - hopefully you will then be able to see where the
looseness is and correct it.
Kim Rennick
'88 Sovereign
Date: Tue, 08 Oct 1996 19:51:07 -0500
Subject: Re: XJ6/SIII rear knocking advice needed
with either back wheel.Does this indicate the diff has had it, or is it the bearings where the
along steadily.Do I need a new diff?
Thanks
Pete Hamel
I believe more likely than the diff bearing, it would be the hub
bearing. Check to see if there is movement between the hub carrier and
wheel. This would indicate a failed bearing. Hub bearing sets are
reasonably priced and quite strait forward to install, unless the
spline has frozen to the axle.
Hope this helps.
Bob Johnson
Brattleboro, Vt.
Mk 1, XJ12L
Date: Tue, 08 Oct 1996 20:29:46 -0500
Subject: Re: XJ-S front end suspension
with aftermarket options?All information is appreciated.
Aaron
'85 XJ-S
I have had no problems with OEM rubber parts. You should expect to
find some rusted sleeves between the bush bolts and bushings. The best
solution is big tools and some heat. The satisfaction resulting from
the quieter and smoother ride is worth while.
Bob Johnson,
Brattleboro, Vt.
XJ12L, XJS
Date: 9 Oct 96 11:40:45
Subject: Re: V12 Chain Tensioner Tools
I use a medium fine screwdriver myself, Kirby. I’ve also made up a suitable
hook for pulling the tensioner straight, out of some 1/4in steel rod. It’s
permanently linked to an old ring spanner (poor quality but good enough for
this) for leverage.
- Jan
Date: 9 Oct 96 11:56:03
Subject: Re: XK8 / E-type Musings
Ryan Border :
My take is… a mass produced XJ220 (industry leading technology,
race ready and proven performance, breathtaking styling), at… say $42,000.
No, not the full blown $250K XJ220, but a car for the masses that is to the
XJ220; what the E-type was to the D-type.
Just a thought: if the XK8 had a Diahatsu, Kia, or maybe
even Acura badge on it… what would we all think of it? Conversely would
it have mattered, at all, who built the original E-type?
Excellent points, and let’s have the V12 (Jaguar’s last racing engine!) in the
XJ220, even if it costs an extra $10k. Would you believe that when the XJ220
was launched, it was priced at AUD 2,000,000
(two million, USD 1,600,000) for the Australian market? I think they sold one.
Is there anything dumber than greed?
- -Jan
Date: 9 Oct 96 12:04:17
Subject: Re: XJS Oil seals and gaskets.
viadata @ interramp.com (David Hurlston)
05/10/96 10:08
To: jag-lovers @ sn.no @ internet
cc:
Date: 4 Oct 96 16:09:02
- If it ain’t broke, don’t fix it…
Aren’t you glad the airlines don’t follow that motto?
Do you? :3+)
- -Jan
Date: Tue, 8 Oct 1996 17:39:00 -0400
Subject: Re: V12 Radiator drains
change happened?
Well, 87 has it and your 89 doesn’t. Anyone got an 88?
Our 1988 V12 VDP has no drain. Stewart’s (just stolen) 1986 V12 VDP
had no drain. Stewart’s 1985 XJ-S has the drain.
As a side note, the radiators with the drain have the slip-on and clamp
transmission oil cooler lines, while the no-drain ones have the threaded
connectors for the transmission cooler.
Date: Tue, 8 Oct 1996 18:11:00 -0400
Subject: Re: Vacuum Advances
Lloyd wrote:
Sorry to clutter the list with this, but thought I’ld come here first.
I need a vaccuum advance for the distributer of a '71 4.2 “E” type. Anyone
got one or a lead? I know we got a couple of parts guys on the list.
Hal wrote:
The original Lucas 5442224 is no longer available. I definitely don’t have
any of them. However, this vac advance also fit some TR6s. I do know that
another Lucas part 54400201 will fit TR6. Maybe it will work on the E…
I write:
I got a new/rebuilt vacuum advance for my 3.8l E-type distributor, type
DMBZ6, from British Auto. They also had new/rebuilt ones for the 4.2l
distributor, 22D. I was about to get one of these for my spare 4.2l
engine’s distributor, until I actually checked it out, and it was
functioning fine. I think Welsh also has these new/rebuilt advances.
Subject: Re: E-type serial numbers
Lloyd:
The “2R13539” should be your vehicle number, ie serial number.
Why the sill plate and picture frame have a “P” in front of it
is beyond my knowledge…3.8 E-Type mainly. The body number
will be located elsewhere on the car, like above the fuel
bowl in the engine compartment, or (as in my car) on the
left inner fender above the gas tank and under the mohair
interior fender covering…your covering will be vinyle (sp).
The body number should be on a small aluminum tag.
Mark D. Roberts Mail-Stop CRK-047
Northern Telecom Phone ESN 393-2924
Dept. 5S85 Fax: ESN 393-3970
Custom Technology Access email:markdr@nortel.ca
Date: Tue, 8 Oct 1996 21:41:37 -0400
Subject: Jag Certificate
I would again like to ask if anyone has purchased a certificate from
Jaguar. They offer it through North America or Brown’s Lane. It’s about
$40. I was curious as to what it said or if it was worth the money. Feel
free to respond to me privately. TIA, Bill
End of jag-lovers-digest V2 #415
id for jag-lovers-digest-out; Wed, 9 Oct 1996 09:19:48 +0200 (MET DST)
Date: Wed, 9 Oct 1996 09:19:48 +0200 (MET DST)
Message-Id: 199610090719.JAA05364@ekeberg.sn.no
Subject: jag-lovers-digest V2 #416
Precedence: bulk
Status: O
X-Status:
jag-lovers-digest Wednesday, 9 October 1996 Volume 02 : Number 416
Re: XJ40 Oil leak
Front end alignment
XJ6 series III headlight loss
Re: Beer and Jaguars
Re: Little things not in the book (XJS V-12)
Re: XJ40 Oil leak
Fuel Tank Sealers
S-Type front end rebuild
Jack Stands for an E-Type
Re: Front end alignment
Re: Fuel Tank Sealers
xj220
XK8/E-Type
Missed opportunities at XKU open house (jag-lovers content)
re: XKU open house and SI/III E htbrid
XK8 in Japan
Re: Front end alignment - solution
Date: Tue, 08 Oct 1996 21:43:02 -0500
Gerald M Foster wrote:
Sorry for wasting bandwidth on this one as I know its been covered many
times. But, I never thought my Jag would ever leak. Its been leak
free til now! Am I a dreamer or what? Just above the distributor at
the base of the head is a fairly good leak. I have the factory books.
However, what is the most economical way to stop it without major
surgery?Gerald
I believe this is the cam cover gasket. I have had a break on this
corner result in large volumn leakage. Fortunately, it is a quick fix.
Bob Johnson,
Brattleboro, Vt.
XJ40, XJ50
Date: Tue, 08 Oct 1996 20:56:27 -0500
Subject: Front end alignment
Today I decided to arrange to have my front end aligned (1987 XJ6) as
the car has developed a tendency to veer slightly to the right. I
figured this ought to be a “Mr Goodwrench” level task, but I ran into a
brick wall of resistance at the two local shops I tried, the nearest
Jaguar shop being sixty miles away. The first just refused to consider
it and gave no explanation. At the second, I was told that the
alignment had to be done with both gas tanks full and the passenger
compartment loaded with sandbags. They referred me to a mechanic in
town who had the “special equipment” needed to do the job, but I was
pretty bewildered by this point and did not pursue it further. I guess
I’ll need to take it to the Jag shop, but is this really that
complicated a job? Or are these guys just FOS?
Steve Coleman, Gadsden, AL
1987 XJ6 x2
Date: Tue, 8 Oct 1996 22:11:23 -0400
Subject: XJ6 series III headlight loss
This evening on the way home from work I tried to switch on the high beams.
However, all I managed to do was turn off all the head lights. By keeping
pressure on the switch the high beams work. But let go and only the
parking lights remain. Any ideas of where to start? Thanks for any help
you can provide.
Date: 9 Oct 96 13:16:18
Subject: Re: Beer and Jaguars
Jim Isbell :
I find Burbon and good wine to be very tasty, but beer is bitter and salty.
Try Australian beer, mate…
- -Jan
Date: 9 Oct 96 13:12:38
Subject: Re: Little things not in the book (XJS V-12)
AFAIK, Jim, there’s just the rubber bung - and yours has gone hard and brittle
with age. When I pulled my last two ones out, they were half-hard, and the
current one in the coupe is getting there.
You might be able to slip a sheet of aluminium or something in behind the plug
(yes, after pulling the cam cover) to stop rubbish falling in.
On the other hand, whatever does fall in won’t do any harm - it’s too soft to damage any steel parts, there’s no narrow oil drain passage to block and the strainer on the oil pump suction will make sure the fragments stay in the sump until the next oil change. They won’t be thrown around by the crankshaft either, because it’s fully baffled. Jan From: Randy Wilson randy@taylor.infi.net Date: Tue, 8 Oct 1996 21:57:53 -0400 (EDT) Subject: Re: XJ40 Oil leak Randy, RE: XJ40 Head Gasket leak Has Jag updated the gasket to prevent this problem recurring? Is the problem due to poor gasket design, head design or possible head warping? Any ideas – I don’t want to be re-doing head gaskets for a relatively minor leak. This sort of problem is not limited to the AJ6 engine. Many makers went through the same sort of thing in the 80’s, especially those using aluminum head and iron block. Gasket technology has progressed. The new gaskets are improved. However, I have no conrete proof that the problem is fully cured, as I have not yet had anyone put 100K+ miles on a new gasket. Also – any suggestions on aftermarket kits for updating XJ40 rear suspension. The local Jag dealer wants $1100.00 CDN for the OEM conversion kit. (About $800.00 US) Ouch A proper kit comes with new shocks, shims, hardware, and springs. Beware the cheapy kits. I have experence with the KYB conversion. It rides poorly, sits low (requiring several attempts at shimming), and the flimsy plastic filler piece they include fails quickly. The kit I stock comes with Boge shocks, factory springs, perches, shims, and hardware. It’s in the $600 US range. Mike Everatt 1987 1/2 XJ40 Randy K. Wilson randy@taylor.infi.net From: MDavid1566@aol.com Date: Tue, 8 Oct 1996 22:27:12 -0400 Subject: Fuel Tank Sealers I have seen a few postings about using fuel tank sealants to solve pinhole leaks. My question is, can this be done with the tank still in the car? How does one achieve sloshing the sealant fluid around the inside of the tank? And there seemed to be a split in the general consensus on whether this type of product really works…any feedback from satisfied users? Thanks for the info…sorry I have no opinions on the beer vs. burbon debate:-} David Q. 1971 XJ S1 From: ROLindsay@aol.com Date: Tue, 8 Oct 1996 23:22:51 -0400 Subject: S-Type front end rebuild Hi Gang. I have decided to complete the rebuild of the “S” Type front end that I started a few months ago. I did the easy bits like new tie rods and sway bar rubber bushings as well as a general clean-up and degreasing of the entire mess. It made such a difference in the handling, even if the steering is a little vague, that I must continue. As for the steering, I discovered that the lower steering column bushing is MISSING allowing quite a bit movement that is no doubt adding to the vagueness. As I have to pull the steering shaft to replace the bushing, why not do it all. I plan to do the work in steps. That is, scrub down and degrease everything first. I just hate working on grimey things when it is avoidable. I will remover the dampers and springs with the assembly still on the car. After that I will decide if the entire unit needs to come out to replace the rubber shims at the fulcrums of the A arms. Any experienced advice here is appreciated. The E-type was completely different… Having gone this far I may as well replace the brake pads. The rotors, hoses, pistons and seals are fine. Anyway, its nice to be working on the Jag again. As many of you know, two pulls on the spanner and all of the work-day’s problems melt away… Regards, Rick Lindsay '66 Jaguar 3.8 “S” Type '89 Mercedes 420 SEL '79 Dino 308 GT/4 (in the spring, maybe…) From: Jan Wikstroem Jan_Wikstroem@acp.com.au Date: 9 Oct 96 14:52:58 Subject: Re: XJ6/SIII rear knocking advice needed Peter Hamel : If I looked under the car along the driveshaft into the differential I could see that the movement seemed to occur where the shaft goes into the diff. That’s your diff output shaft bearings, all right. They’re subject to much more stress than the rest of the diff, and it’s very likely that all you need to do is replace the bearings and seals. This is not difficult, but you’ll need to take the rear subframe off your car. You can do it from underneath, but that probably takes longer because of the difficulty in getting the brake calipers off and back on. Besides, taking out and dismantling the complete rear suspension gives you a great opportunity to check everything. You need two good stands and a small garage jack, as well as a friend to stabilise the subframe as you move it down and up (and help you lift it to the workbench; that sucker is heavy). To make the job a lot easier, take the spring/shock units out first and refit them last. You’ll need to shift the subframe in two lifts, as the stroke of the jack won’t be long enough. I use a 5" thick wooden block on the jack and rest the unit on two cement blocks halfway up. Jan From: rrichardson@eurekanet.com (Robert J. Richardson) Date: Wed, 9 Oct 1996 00:23:06 -0500 Subject: Jack Stands for an E-Type Robert Abascal in his 10/7 posting advised me to consider purchasing jack stands and a floor jack for use now to access the rear brake bleed nipples by removing the forward coil springs and shocks. I have metal ramps, but he was correct in saying that the suspension must be unsprung re weight or the springs and shocks can’t be removed. It’s no small investment, I agree, but he said the units would more than pay for themselves in the event major brake work is required and for regular maintenance of under-body units and parts. He also said to get the tallest jack stands I could find. Imparts, primarily a BMW parts house, has a pair of 6-ton jack stands that have a maximum lifting height of 25 inches. My questions are 1) will 25 inches maximum height give me elbow room under my E-Type and 2) is the price of $48 per pair a competitive price? Should I invest in two pair to have a level car platform? Also, what can I be expected to pay for a floor jack and does anyone on the list have this information plus the source for such a jack? I’m on hold now waiting the return of my newly resleeved master cylinders and am hoping to get the bleed job, etc. completed before freezing weather sets in (unheated and small built-on garage). From: rrichardson@eurekanet.com (Robert J. Richardson) Date: Wed, 9 Oct 1996 00:30:33 -0500 Subject: Re: Front end alignment Today I decided to arrange to have my front end aligned (1987 XJ6) as the car has developed a tendency to veer slightly to the right. I figured this ought to be a “Mr Goodwrench” level task, but I ran into a brick wall of resistance at the two local shops I tried, the nearest Jaguar shop being sixty miles away. The first just refused to consider it and gave no explanation. At the second, I was told that the alignment had to be done with both gas tanks full and the passenger compartment loaded with sandbags. They referred me to a mechanic in town who had the “special equipment” needed to do the job, but I was pretty bewildered by this point and did not pursue it further. I guess I’ll need to take it to the Jag shop, but is this really that complicated a job? Or are these guys just FOS? Steve Coleman, Gadsden, AL 1987 XJ6 x2 Join my club! I’ve been getting the same resistance here in Athens, Ohio. No one wants to work on Jags. Even the mechanic I just located who worked on my E-Type in the 1960s failed to follow through on my request for brake work. So I’ve ended up doing the brake work myself. Alignment is another question. You do need special tools and experience to obtain a proper allignment. Good luck. From: Frank Perrick frankp@mscnet.net Date: Wed, 09 Oct 1996 00:51:10 -0400 Subject: Re: Fuel Tank Sealers MDavid1566@aol.com wrote:
does one achieve sloshing the sealant fluid around the inside of the tank?And there seemed to be a split in the general consensus on whether this type
of product really works…any feedback from satisfied users?Thanks for the info…sorry I have no opinions on the beer vs. burbon
debate:-}–David Q.
1971 XJ S1
I think I started this string by askong about the availabilty of this
product. I did not use the liquid sealer for two reasons 1) lack of
availabilty ( I needed it on my day off) 2) I didn’t want to risk
messing up my sending unit or chance breaking it trying to pull it out.
So I spent the majority of the day sanding to bare metal spraying on
Extend (A rust converter) and epoxying the area with a thin layer of
marine tex ( a marine epoxy $20.00 for 2 oz’s, Dad had some, I would
never pay that much for epoxy) I forced it into the pepper holes with a
spork ( a plastic spoon/fork available at Kentucky fried chicken cost:
$2.99 comes with nice carring case and two pieces of chicken) After that
set up I primered it,then sprayed it with under coating gucky stuff,
looks like tar but hides any uneveness and IMHO provides more padding
between the tank and floor. Oh by the way the tank has to come out
completely, much easier the third time around. When reinstalling shop
vac and wipe the tank and floor with a wet rag to remove any sand that
could vibrate its way into another hole. O.k. a simple thing made long
but it doesnt leak and if you have a source for marine tex it don’t cost
much. Frank P. 1985 XJS (IMHO tm Kirby Palm)
P.S. That fuel tank repair epoxy that twists off and you knead in your
hand is a waste of $2.00. You might as well rub a bar of soap on the
leak !!( Bar of soap was suggested by my Dad to stop minor fuel leaks,
Still havent Tried it.)
Date: Wed, 9 Oct 1996 12:30:26 ±800
Subject: xj220
someone was going to do a story in Jaguar World about the warehouse full =
of XJ220’s. Has it been done yet?? I’m in china and don’t get Jag =
World on a regular basis. Also, I can buy the large (probably 1/15 =
scale) models of the xj220 here for about $135 USD. Is that too much? =
John Shuck, Beijing…
Date: Tue, 8 Oct 1996 22:32:52 -0700 (PDT)
Subject: XK8/E-Type
Had occasion to be driving the E-Type roadster around and ran accross an
open XK8 parked on the street in Carmel Valley, CA. so it was interesting
to pull along side and give a visual comparison. The most striking thing is
how much lower one is in the E, although the length seemed about the same.
We were positively looking up to the top of the door of the 8 (although it
was probably only a few inches). When I first caught sight of an 8 driving
around the day before at an intermediate distance I thought it was a Miata,
but on second take it seems slightly bigger and a little more robust, so I
gave chase for a while to get a visual impression but lost it.
One is tempted in the abstract to compare the two, but in the flesh it is
obvious that there is no real way to compare the cars as they are so
different. Manufacturing techniques, background, personnel, history,
market, and so on are all radically changed. The 8 is a thoroughly modern
car while the E has in the last ten years or so slipped into the antique
category. It’s spartan nature, spindly wire wheels and skinny tires, lack
of amenities (like head lights that work) and other idiosyncracies would
just not be acceptable today and few 8 customers would choose to by an E.
(However, it might be a question whether for the same money one could buy
either an XK8 OR an E-type, a XK150 AND a XK120, and maybe throw in a tatty
XJ-6 for good measure!) By the same token the 8 is a modern car and
seems to suffer from, je ne se quoi; a lack of soul for want of a better
term. From a quartering frontal angle the car looks it’s best, but
otherwise it looks sort or undifferentiated from a number of other similar
cars. It remains to be seen what will make this a Jaguar and not just an
other appliance or transportation unit. Certainly it does not come off as
the Ferrari for the common man that the XK series did, so, it will have to
make it’s reputation on the road. And good luck to it too. Bill Spear
Bill Spear
227 7th Street
Juneau, Alaska 99801
907/586-2209 v
907/586-6858 f
bill@wmspear.com
The world’s most wonderful pins…
http://www.carmelnet.com/spearpins
Play the accordian, go to jail. That’s the law.
From: David J Shield David_J_Shield@ccm.fm.intel.com
Date: Tue, 08 Oct 96 22:42:00 PDT
Subject: Missed opportunities at XKU open house (jag-lovers content)
Earl,
I'll gladly visit you next year. Keep the room at the San Luis Bay
Inn in case I shouldn't drive home after visiting you <g>.
Honestly, I nearly went and had jag-lovers T-shirts made up for my
kids and myself so as to identify us to the computer-savvy amongst
the group. Wish I had.
Earl sayeth:
>After reading Ryan Border and David Shield's posting re their
>experiences at the XKs Unlimited open house and rally last
>weekend, I am led to wonder how many more jag-lovers I failed to
>meet there. ...snip... Perhaps next year anyone who attends
>would like to drop by my place for something a little stronger
>than the beer and soft drinks that were served with the barbeque.
>...snip... this year I actually won first prize which consisted of
>Luis Bay Inn. Of course I'll have no trouble finding a use for the
>former. However, I don't know what the heck I'm going to do with
>the latter. See you next year.
>Earl Huff
>53 XK 120
>85 XJS
Date: Wed, 9 Oct 1996 16:15:31 +1000 (EST)
I had more luck with the epoxy that you knead. However, first I cleaned the
area to metal, then used a self tapping screw (short) and screwed it into
the tank through the pin hole before I used the epoxy (yes it makes a bigger
hole and this was not on a Jag tank so I experimented). I did not think
that it would work but it has held for over two years. Looked at it the
other day, it looks strong and very hard to touch: don’t think that it will
leak again. I fixed two holes on the same tank with success.
Ned
'61 Mk2
Ned Blagojevic
Environmental Science Division
Australian Nuclear Science Organisation
PMB 1 Menai, NSW 2234
Australia
email: nbx@ansto.gov.au
phone (w)int 61-2-717-3660
fax int 61-2-717-9260
Date: Tue, 08 Oct 96 23:13:00 PDT
Subject: re: XKU open house and SI/III E htbrid
The last mention I saw in XKU's Coventry Quarterly, they had taken
the asking price down to $65K (~2 years ago). I seriously thought
(for about a femtosecond) of dumping enough assets to buy it. I
guess they've sold it. Anyone here own it?
>> I drove to the XK's Unlimited open house this weekend...
>pictured in their catalog? I would love to see that car.
>Mark
Date: 9 Oct 96 15:36:54 JST
Subject: XK8 in Japan
For what it’s worth. The XK8 will be offered in Japan from November 1.
The low end model (which will have 18" tires, wood interiors and the
5 speed automatic transmission) will be put on the market at
Yen 8,880,000, which at today’s exchange rate translates to about US$80,000.
If you consider the extent of homologation that the car went through to beat
our environment hurdle, and other such “non tariff barriers,” they’ve priced
it pretty competitively.
Regards
Makoto Honjo
Date: 9 Oct 96 18:17:29
Subject: Re: Front end alignment - solution
The Repair Operations Manual specifies using (simple) tools to lock the
suspension at half height for wheel alignment or, in the absence of such tools,
loading the car to “average” condition. However, this assumes that the
suspension has totally correct springs and sits at the specified height - a
condition I’ve never come across in any Jag older than 10 years (I haven’t
worked on any newer ones…).
The reality is that every car sits at its own height, depending on how “tired”
the springs are. The reality is also that the ride height changes all but
imperceptibly if you take on a passenger; I have decided that the best
condition for checking and adjusting wheel alignment is with nearly full tanks
and the driver on board. I take the car to the local tyre sales place and pay
them $A 30 to measure (not adjust) the wheel alignment (front and rear) in that
condition.
The reason for telling them not to adjust the alignment is a) they won’t be
tempted to fudge if it’s “near enough” and b) their settings catalogue has
wildly incorrect values. Once you know the measured angles, adjustment is very
simple. Camber (front and rear) and caster is adjusted by adding/removing or
moving shims, and the manual specifies how much difference each shim makes.
The simple method up front involves jackling up the car and taking the front
wheel off, then either taking the spring load with a garage jack under the
outer ball joint or spring, or lowering the same part on to a stack of bricks.
This takes the transverse load off the upper ball joint and wishbone, so you
can move the shims as you please.
The rear is a little more work, as you need to jack up the whole rear end and
put it on stands, then crawl under and remove/add shims between each inner
U-joint and the brake disk.
Once your camber and caster are correct as specified in the manual for your
model, adjust the toe-in by turning the tie rods (I use a ViseGrip, and an
open-ender for the lock nut), and equalise the adjustment nicely so the
steering wheel sits straight. Again, check your manual for the correct toe in.
On the series 2 V12 with fuel injection (which is what I’ve got) it’s easy as can be; the toe-in should be zero plus minus a whisker. Since I have the same wheel size front and rear and the track is the same, I simply aim along the wheels at hub height and adjust until front and rear lines up perfectly on both sides. I’ve found by experience that error on the IN side is better than on the OUT side (harder cornering without tyre squeal). Jan “Gum Tree Garage” 77 XJ12C 78 XJ12L End of jag-lovers-digest V2 #416 ******************************** Return-Path: @owner-jag-lovers-di1 Received: (from majordom@localhost) by ekeberg.sn.no (8.7.5/8.7.3/on4) id for jag-lovers-digest-out; Wed, 9 Oct 1996 15:57:12 +0200 (MET DST) Date: Wed, 9 Oct 1996 15:57:12 +0200 (MET DST) Message-Id: 199610091357.PAA21734@ekeberg.sn.no X-Authentication-Warning: ekeberg.sn.no: majordom set sender to owner-jag-lovers-digest using -f From: @owner-jag-lovers-di1 To: jag-lovers-digest@sn.no Subject: jag-lovers-digest V2 #417 Reply-To: jag-lovers@sn.no Errors-To: @owner-jag-lovers-di1 Precedence: bulk X-Newsgroups: mail.jag-lovers-digest jag-lovers-digest Wednesday, 9 October 1996 Volume 02 : Number 417 Re: Front end alignment - check RE: 62 E, oil pressure too high SIII-85 DVP Scratching sound from the rear brakes Newbie Bushings (Was XJS Front end suspension) MK II restoration update re: S-Type front end rebuild re: SI/III E htbrid Re: TO all XJS owners… Re: XJ6/SIII rear knocking advice needed Re: V12 Radiator drains Re: XJ6 series III headlight loss Re: Fuel Tank Sealers Re: Front end alignment Re: SIII-85 DVP Scratching sound from the rear brakes Re: XJ40 - Inexpensive center cap clean up Most beautiful Jaguar Re: XJ-S Spark Plug Wires Re: XJ6/SIII rear knocking advice needed From: Jan Wikstroem Jan_Wikstroem@acp.com.au Date: 9 Oct 96 18:29:11 Subject: Re: Front end alignment - check Steve Coleman : …as the car has developed a tendency to veer slightly to the right. I’ve just finished a post on doing your own wheel alignment, but I forgot to mention that your symptom may have two other causes. A malfunction in the power steering can force it off the centre position; this tends to be fairly strong. A binding brake caliper can also cause pulling to the side; this is simply dirt that prevents the puck from retracting properly. One way to identify this is to brake moderately; if the car then goes straight, your brake calipers need a cleanup. Another way is to drive a few miles at speed without braking, then roll to a stop. If one brake disk is warm and the other cold, that’s it. This fault also tends to go away by itself after a week or two, especially if you do some really hard braking. If the pulling is indeed due to wheel alignment having gone off, you have to find out why it’s gone off - most likely, a bushing has given up or a wheel bearing has given notice. The Jag front suspension is immensely strong and is not likely to be thrown out of kilter by a pothole. I’ve gone across the corner of a kerb at about 50 km/h (30 mph), which had absolutely no effect apart from some rather nasty bruising of the tyre and raising my blood pressure to about 400/300. Jan From: Frans HOEKEMEIJER hoekemei@ps.msm.cern.ch Date: Wed, 9 Oct 1996 09:38 +0100 Subject: RE: 62 E, oil pressure too high Hello, yes, I reckon that your bypass valve is stuck. The oil pressure gauge is not=20= fed through the voltage stabalizer as the system is self regulating. If the=20= oil filter is clogged the pressure indication should be lower as it is=20 measured after the filter. I once had a short in the oil sender when there=20 was pressure, but you have already changed it. If the pressure is too high=20 you risk busting seals in the oilways, the smoke may come from too much oil=20= spray on the valve gear. Frans. I have a problem with oil pressure on my 62 E type. Recently, after replacing the instrument voltage regulator, I noticed the oil pressure=20 gauge was pegged at over 60 psi. I assumed I had wired the gauge incorrectly,=20 and drove it to work and back. When I got into it, the wiring looked ok, so a couple of days ago I replaced the sender unit. No change. I’m starting to believe that the pressure is real. The gauge reads zero with the ignitions on, but not running. Within a few seconds of starting the engine, the gauge is maxed out (over 60 psi). I’ve also noticed that now I am blowing smoke on acceleration (much more than normal). I assume this could be a result of the pressure being to high. This seemed to have all come on very suddenly. I’m afraid to drive the=20 car until I get this resolved. I’m going to change the oil and filter tonight in case the filter is clogged. Could the bypass valve cause this? John Gardner 62 E type OTS =20 From: Roger Hartonen etohart@eto.ericsson.se Date: Wed, 09 Oct 1996 08:57:39 +0000 Subject: SIII-85 DVP Scratching sound from the rear brakes Hi, I have some strange noises comming from the area around the rear brakes. It’s a scratching sound, like if the brake pads were still on the disc from time to time. Return-Path: @owner-jag-lovers-di1 Received: (from majordom@localhost) by ekeberg.sn.no (8.7.5/8.7.3/on4) id for jag-lovers-digest-out; Wed, 9 Oct 1996 22:39:46 +0200 (MET DST) Date: Wed, 9 Oct 1996 22:39:46 +0200 (MET DST) Message-Id: 199610092039.WAA10980@ekeberg.sn.no X-Authentication-Warning: ekeberg.sn.no: majordom set sender to owner-jag-lovers-digest using -f From: @owner-jag-lovers-di1 To: jag-lovers-digest@sn.no Subject: jag-lovers-digest V2 #418 Reply-To: jag-lovers@sn.no Errors-To: @owner-jag-lovers-di1 Precedence: bulk X-Newsgroups: mail.jag-lovers-digest jag-lovers-digest Wednesday, 9 October 1996 Volume 02 : Number 418 Re: XJS V12 radiator flush - elimination of drain tap Re: xj220 US Floor Jack Price & Question about 1 person brake bleeding Leather Interior Re: Beer and Jaguars Jaguar certification Re: S-Type front end rebuild re: S-Type front end rebuild re: 1 person brake bleeding Re: Leather Interior H&E Convertible Fuel System [Fwd: Returned mail: User unknown] XJ40 - Oil Change XJ40 rear shock conversion Re[2]: 1 person brake bleeding (ride height: long) From: Stefan Schulz jaguar@suaviter.demon.co.uk Date: Wed, 09 Oct 1996 12:41:32 GMT Subject: Re: XJS V12 radiator flush - elimination of drain tap In message 199610071851.OAA02641@gemini.aero.odu.edu Thomas Alberts writes: Does anyone know when the change happened? Well, 87 has it and your 89 doesn’t. Anyone got an 88? I do. Haven’t got a drain tap. Regards, Stefan Schulz jaguar@suaviter.demon.co.uk From: “Lee Walden” lwalden@ebmud.com Date: Wed, 9 Oct 1996 08:40:27 -0700 Subject: Re: xj220 John wrote:
Also, I can buy the large (probably 1/15 scale) models of the xj220 here
for >about $135 USD. Is that too much? John Shuck, Beijing…
I’m not sure of the scale, but I just bought the Majisto (?) metal model of
the XJ-220 in a very nice metallic BRG for $9.00 USD at the local warehouse
store. The car comes on a plastic base which is about 10" long by 6" wide.
The hood (bonnett) and engine deck lids open. The doors open. The seat
backs “recline” the steering wheel turns the front wheels, the wheels roll,
and the wheel can move up and down too. The engine is the V-12. Car is
RHD. They have other models available including the XKE. Lee
Date: Wed, 09 Oct 96 10:01:00 PDT
Subject: US Floor Jack Price & Question about 1 person brake bleeding
My local Sams Club ( Denver, Co, USA ) has a 3 ton floor jack for $60. ( I
am happy with this one ) They currently do not have jack stands. If I
remember when I go to some chain auto parts stores tonight I will look at
jack stand prices.
Other then the one person with the “EZ Bleed” kit in the UK that attaches to
the spare tire for pressure & a large resivoir of fluid ( can’t seem to find
one like that ), has anyone used the one person type that fits a hose over
the bleed nipple into a jar of fluid with any success ?
I am hoping that this is all I need to do. Yesterday the brakes were a
little mushy, but then came back. This morning the petal went all the way
to the floor. There was enough breaking power to hold the car in place with
the car in gear, but that is about it. Just glad I have a 2nd car. ( but
its brakes need some work too. )
John Himes
88 XJ-S 98K Miles
Date: Wed, 9 Oct 1996 12:01:04 -0005
Subject: Leather Interior
Chad Bolles:
Yes the entire interior should be leather.
Actually, I’m not sure ANY of them are entirely leather. On mine,
many of the parts of the seat that don’t touch occupants are vinyl.
It’s my understanding that most – if not all – of the cars are this
way.
| - Palm’s Postulate
Date: Wed, 9 Oct 1996 12:10:19 -0400 (EDT)
Date: Mon, 7 Oct 1996 14:12:34 -0500
Subject: Re: Beer & Jaguars (some Jag content)
If you can point me to a beer that is sweet or at least not bitter or salty
I will gladly try it.
When in England I drink Cider but that is as close as I will get to beer.
I have tried Shandy which is lemonade and beer half and half and it is
almost palatable.
If you’re visiting the Jaguar plant, there is an extremely nice little
pub called the Rainbow in Allesley Village within a couple of miles of
Brown’s Lane. It is very rare in actually brewing its own beer
and I would highly recommend a try.
- -Phil Andrews
Date: Wed, 9 Oct 1996 12:12:21 -0400
Subject: Jaguar certification
I recently sent for a certificate for my '84 XJ-S from JCNA, trying to
confirm
that several pieces of optional equipment were factory or TWR options.
1. You have to send them all the eng/trans/body/VIN numbers- they will
“verify” them (?)
2. Took six weeks to receive reply
3. Certificate does not say anything about optional equipment.
Doesn’t even say
what dealer initially sold the car.
Unless you have a collector’s class early car (XK,etc.), save your money for
parts.
Brian “a fool and his money are soon parted” Sherwood
'85 XJ-6
'84 XJ-S
Date: Wed, 9 Oct 96 17:21:00 BST
Subject: Re: S-Type front end rebuild
Alastair Lauener replied to Rick Lindsay:
The lower steering column bush is not the same as the upper one. Watch, as alot
of places sell a pair of bushes (which were the same as the upper), I got a
pair, and ended up using the old ones again.
On my 1966 Mk2 I also retained the old “worn” bushes as they fitted better than the new ones. There is a locating piece at the bottom of the column, which if worn, can allow up and down movement of the inner column in relation to the outer. A bitch to find a replacement. Easily obtainable from SC Jaguar in the UK. There are two thicknesses available, differing by .002" and one is about twice the price of the other. Since the old one had worn by something like .050" without causing any problems, I just fitted the cheaper one . Note that this locating piece is only fitted on later columns (on Mk2s anyway) - dunno the date off hand, but there was a change! Cheers, Ted (currently replacing connectors and refitting the fascia!) ejt@wg.icl.co.uk From: Ryan Border rborder@hpspls16.cup.hp.com Date: Wed, 9 Oct 1996 09:51:43 -0700 Subject: re: S-Type front end rebuild I will remover the dampers and springs with the assembly still on the car. After that I will decide if the entire unit needs to come out to replace the rubber shims at the fulcrums of the A arms. Any experienced advice here is appreciated. My suggestion is to just pull it. It’s much easier to work on the spring retaining plate bolts with the unit flipped upside down in front of you than laying on your back under the car. It’s only… 13 bolts: 4 at front suspension mounts 2 long carriage bolts at rear mounts (if somebody put these in backwards while the engine was out, you may have to undo the 4 nuts holding the mounts to the cross-member instead) 2 brake hose fittings (take the hoses out with the cross-member) 4 bolts where the sway-bar is mounted to the chassis 1 bolt connecting lower steering column to steering box… make sure you remove this bolt, don’t just loosen it. For a spring compressor, I just used a long threaded rod, a couple of nuts, and a progressive set of washers. The final washer going against the spring retaining plate turned out to be a 2.5lb weight that I bought at the local fitness store. I needed to make the hole at the top of the tower larger (I used a grinder) so that the metal rod could pass through it. Use a coarse thread rod (otherwise it will take forever to unload the spring), and be liberal with the wd40 on it as you compress. Be SURE the rod is long enough to release all the spring energy before you run out of threads. If you really are intent on doing this in the car, then you’ll have to jack the front end up really high to slip a long-enough-rod into the tower. I’ve pulled springs by supporting the plate with a jack, undoing the bolts, and then lowering the plate and spring out… Your chance of re-installing the spring this way (getting the plate to line up perfectly on the A-arm) is about zero. Actually, if you care about the car, I wouldn’t even pull them this way, it’s easy for things to slip and bind as the plate starts to come loose under load, making getting the last bolt or 2 out very hard. Here’s another tip from experience… old long water-pump bolts make excellent spring plate guides when it comes time to re-install the spring. They have the same thread at the ends as the actual plate bolts, and smooth sides so the plate will slide along them without catching. Get them started as early as possible, the more spring load you’re fighting, the harder it will be to get them started. Pulling/inserting A-arm bushings is probably best done with a big bench vice and an assortement of big sockets. I found armor-all to be about the best lubricant I tried to get the rubber to slip into the metal sleeves. Good luck- If you need to make any ride height adjustments let me know, I’ve got a bunch more tips I can pass along there… Ryan. From: Ryan Border rborder@hpspls16.cup.hp.com Date: Wed, 9 Oct 1996 10:04:50 -0700 Subject: re: 1 person brake bleeding jwh@mime.dw.lucent.com writes: has anyone used the one person type that fits a hose over the bleed nipple into a jar of fluid with any success ? I have one of these, and have had only marginal success with it. The probelem I encounter is air slipping by the threads on the bleeder nipple. So, I can never tell if the air in the tube is actually coming from the caliper, or slipping into the system from outside. The kit came with a little package of sealant to put on the bleeder for just this reason, but it doesn’t seem to work all that well. My method is to use the kit to to the first %80 of the bleeding, where it is very convenient. But for the last bit of bleeding on each caliper I use the old friend pumping the pedal method. Ryan. From: Michael Frank mfrank@westnet.com Date: Wed, 9 Oct 1996 13:49:15 -0400 (EDT) Subject: Re: Leather Interior Kirbert: Every car brochure I have seen in recent years describes leather upholstery as ‘leather seating surfaces’. I have always assumed that this means a combination of cowhide and naugahide. The practice must go back a long way: the seat backs on my '69 E-Type appear to be synthetic. Mike Frank At 12:01 PM 10/9/96 -0005, you wrote:
Chad Bolles:
way.– Kirbert | If anything is to be accomplished,
| - Palm’s Postulate
Date: Wed, 9 Oct 1996 14:23:31 -0005
Subject: H&E Convertible Fuel System
Since my XJ-S help book is finally getting around, I occasionally get
phone calls from people wanting help getting their car fixed. Given
how much I have learned about the cars over the years, it is simply
amazing how rarely I can actually help them!
I got a call a while ago from Marv Schindler in Marathon, Florida,
which is half way down the keys. Marv owns a Hess & Eisenhart
convertible, and is having trouble with the fuel system – and I know
nothing about the H&E fuel system.
He can only put about 12 gallons in it, even though it’s supposed to
take 24. He says the car has two tanks, one just forward of the
spare tire and under where the convertible top stores, and another
under the shelf behind the front seats. Each tank has its own fuel
pump; there’s one in the trunk that looks like the standard Lucas
pump, but the forward tank has a pump inside it. There are also two
fuel gauge sending units, one per tank, but only one gauge on the
dash.
While I pointed out that dual tanks are nothing new for Jaguar
(although it is different for an XJ-S), this system has no changeover
switch. Apparently it does whatever changeover it does
automatically. No clue as to how it works. Supposedly it was an H&E
invention.
He also reported that H&E convertibles have apparently had some fuel
tank explosions followed by lawsuits against H&E. If you call H&E,
which is apparently some sort of chassis manufacturer, you can’t
find anyone who claims to know anything about the Jaguar
convertible. Only makes finding info harder.
If anyone can provide some factual info on this system, I’d be happy
to include it in my book – or maybe just a reference to the source,
so that H&E owners can find it for themselves.
| - Palm’s Postulate
Date: Wed, 09 Oct 1996 14:40:36 -0700
Subject: [Fwd: Returned mail: User unknown]
Return-Path: MAILER-DAEMON
Received: from localhost (localhost) by westnet.com (8.7.6/8.7.3) with internal id NAA26952; Wed, 9 Oct 1996 13:49:21 -0400 (EDT)
Date: Wed, 9 Oct 1996 13:49:21 -0400 (EDT)
Subject: Returned mail: User unknown
Message-Id: 199610091749.NAA26952@westnet.com
To: mfrank@westnet.com
MIME-Version: 1.0
Content-Type: multipart/report; report-type=delivery-status;
boundary=“NAA26952.844883361/westnet.com”
Auto-Submitted: auto-generated (failure)
This is a MIME-encapsulated message
- –NAA26952.844883361/westnet.com
The original message was received at Wed, 9 Oct 1996 13:49:13 -0400 (EDT)
from port12.ts1.westnet.com [206.24.7.233]
----- The following addresses have delivery notifications -----
jag-lvoers@sn.no (unrecoverable error)
----- Transcript of session follows -----
… while talking to ekeberg.sn.no.:
RCPT To:jag-lvoers@sn.no
<<< 550 jag-lvoers@sn.no… User unknown
Content-Type: message/delivery-status
Reporting-MTA: dns; westnet.com
Received-From-MTA: DNS; port12.ts1.westnet.com
Arrival-Date: Wed, 9 Oct 1996 13:49:13 -0400 (EDT)
Final-Recipient: RFC822; jag-lvoers@sn.no
Action: failed
Status: 5.2.0
Remote-MTA: DNS; ekeberg.sn.no
Diagnostic-Code: SMTP; 550 jag-lvoers@sn.no… User unknown
Last-Attempt-Date: Wed, 9 Oct 1996 13:49:20 -0400 (EDT)
Content-Type: message/rfc822
Return-Path: mfrank@westnet.com
Received: from LOCALNAME (port12.ts1.westnet.com [206.24.7.233]) by westnet.com (8.7.6/8.7.3) with SMTP id NAA26948; Wed, 9 Oct 1996 13:49:13 -0400 (EDT)
Message-Id: 199610091749.NAA26948@westnet.com
X-Sender: mfrank@westnet.com
X-Mailer: Windows Eudora Light Version 1.5.2
Mime-Version: 1.0
Content-Type: text/plain; charset=“us-ascii”
To: “Himes,John W.” jwh@mime.dw.lucent.com
Subject: Re: US Floor Jack Price & Question about 1 person brake
bleeding
Cc: jag-lvoers@sn.no
John:
I use a home-made one man bleed kit. I use a piece of rubber tubing
which fits snuggly over the bleed nipple. I run this into a glass bottle
which is 1/4 filled with brake fluid. You just open the bleeder and pump the
brake until clean fluid starts to come out. As long as the end of the hose
remains below the level of the fluid in the jar, no air will get back into
the works.
I have used this method for many years, on many cars
Mike Frank
1969 E-Type 2+2
- –NAA26952.844883361/westnet.com–
Date: Wed, 9 Oct 1996 08:11:17 +0100
Subject: XJ40 - Oil Change
Hi Folks
I have been reading the list for a few days now and think it’s great.
Having recently purchased a '90 XJ40 Sovereign (6th September),
I am really interested in your comment’s, technical queries and
opinion’s on Jag ownership.
Problems with the Sov. so far have been a front offside wheel bearing
and stub axle replacement and a leaking cap on the power steering
bottle. Apart from this the car runs like a dream.
It is my intention to replace the engine oil and filter this weekend,
my question is should I use a synthetic oil (Mobil One @ �24.99 a can)
or a normal one such as Castrol GTX/Duckhams etc. and change this on
a more frequent basis.
Thanks.
Brian Kelly - Durham, England
Date: Wed, 09 Oct 1996 14:34:56 -0700
Subject: XJ40 rear shock conversion
I just put in the Jaguar kit. A couple of thoughts:
- The kit came with absolutely no instructions for the strut assembly,
removal of old or installation of new.
- If feasible, ask the supplier to assemble the struts for you. The puny
spring compressors I tried to use were not up to the job and I ended up
taking them to a shop for assembly. It might save you some frustration and
even a finger or two. However, there may be some problems shipping the
struts assembled since there is plenty of stored energy in them.
Dave
Date: Wed, 09 Oct 96 14:32:00 CST
Subject: Re[2]: 1 person brake bleeding
I've only had success with using one person and a vacuum pump. The jar
worked great only with my motorcycles.
Steve
______________________________ Reply Separator _________________________________
Author: Ryan Border rborder@hpspls16.cup.hp.com at smtplink-tellabs
Date: 10/9/96 2:00 PM
Ryan.
Date: Wed, 09 Oct 1996 13:43:55 PDT
Subject: (ride height: long)
Hi Rick-
I’ll take you up on the advice offered-
I guess that means you want my tips on ride-height…
Here goes:
If it’s not too late, measure the ride height on the front end of
your car. How and where you do this really isn’t important, so long
as you’re consistent about it. I measure from the ground to the outside
edge of the hightest point on the fender-lip. Getting a base-line before
you take things apart could save you one installation/removal cycle
on the front springs: which is not a trivial job.
Obviously, if everything looks good, then just don’t mix things up
and put them together the way you found them.
On a Mk1/Mk2 (would guess, but can’t be certain that it’s the same on an S-type) the easiest way to tell if you’ve got a sagging front spring is to park the car on a level surface, and check the rear (yes rear) bumper for level. If you have a bad front spring, it’s like having a table with one leg too short. The table will either sit perfectly level, or will teeter over onto the short leg- depending on the weight distribution. With a bad front spring, because of all the weight up front in the car, it will definitely fall onto the short (bad) front corner- raising the opposite rear corner. The result is that it makes the rear spring(s) on the same side as the bad front spring look bad. If you’ve got a ‘sagging’ right rear corner, suspect the right front spring. If you suspect this might be the case, there is a test to verify. Support the car with a big floor jack centered under the front crossmember. Take off both front wheels and lower the front end to about where it normally rides. Now, re-measure the rear; if it’s level (and wasn’t before) then you’ve got front spring problems. If it’s still crooked, then you get to play with your rear springs… This is expensive experience talking: I put brand new rear springs in my car, and the rear still sagged to one side. Swapped them side to side, and the same rear corner sagged. It was the front springs all along. Any adjustments you make to a front spring length will have approximately double the effect on ride height. This is because the A-arms form a lever, with the spring mid-way between the wheel (ball-joints) and the fulcrum. After a lot of experimenting, I can say with some confidence that the multiplication factor is a little less than 2; say 1.8 or 1.9. I learned this (2X) lesson the very expensive way the first time I cut a set of coil springs. If your aim is to raise a front corner, then all you do is add shims under the ends of the spring. There are washer-type shims that go at the top of the spring (your car almost certainly has these in it) and flexible C-shaped shims which go under the pig-tail end. In addition to the 1.9 rule, expect that the opposite side will follow the one your adjusting a little bit. If you raise the left side an inch, by adding a 1/2" shim to it, expect the right side to come up… maybe 1/8" The real challenge comes when you need to lower a front corner. If the required adjustment is small (less than 1/2" or so) then there’s a trick you can use to save you much potential grief: simply shim between the spring retaining plate and the lower A-arm. My final 1/4" adjustment on one side (1/8" shims) was done this way. For shims, I simply used washers. To play it safe, longer bolts are also reccomended. Actually the stock bolts have non-threaded points on them; I’m using bolts the same length but with threads running all the way to the end and feel perfectly safe with them. If you over-lower a car with this method, you can simply take the shims out… you can’t undo a spring cut. With some patience, you can actually do this without pulling the springs: install compressor for safety, remove outer bolts, loosen middle bolts, slip in outer shims and re-install bolts. Loosen inner bolts, remove middle bolts, install shims and sort of tighten. Remove inner bolts and install shims, tighten everything. You have to finesse it, but it can be done. Which brings us to cutting springs. The actual cutting is a piece of cake, I’ve used a hack-saw, a sawzall, and a rotary air-powered cutting wheel; all with success. The challenge is determining where to cut them. What you need to do is cut the desired adjustment (divided by 1.9) from the compressed (loaded) coil; not from the free coil. So, what you do is: with the car on its wheels, measure the distance between adjascent coils on the spring. Measure along the axis of the spring; not perpendicular to the coils. This number, and your desired adjustment is about all you need. Example: Say your measured distance between coils is 1.625" ← it will vary a lot from one car to another, depending on springs used. Don’t worry if your number is a lot different. And, suppose you want to lower that corner 0.75". 0.75" / (1 compressed coils / 1.625") / 1.9 => 0.641 compressed coils. You want to cut 0.641 coils off the spring. The point of this is to find a unit (coils) that is constant in or out of the car. But there’s more. If you look at your spring, and it hasn’t been cut before, you’ll probably see a flattened end on the pig-tail. (it is the pig-tail end that you need to cut). So, get out the calipers again, and measure the distance (in the middle of the spring, along the axis) between 2 uncompressed coils. It’s easiest to just not adjust the calipers; and now find the point on the spring which is that same distance down from the end of the flattened pig-tail. It will probably be about 1.25 coils down. It’s a bit of an eye-baller… so mark both springs at the same time and be consistent about it. Mark that point (felt tip); which will be the reference point for any cuts: 1 “coil” from the end. Back to our example: What we want to cut is 0.641 coils, or 0.359 coils short of the mark we just made. Start at the “1 coil” mark, and go 129 (0.359*360) degrees towards the tip and that’s your cutting mark. My car (with S-type/420) uprights has got cut down springs from a MKX in it. I had to install them “as is” to get a reference, and then: using the above method, lowered the car to the perfect height in one shot. I cut over 2 coils on one side, about 1.5 coils on the other. (my towers have quite uneven heights for some reason). Well, not perfect, I did make the aforementioned 1/4" adjustment on one side. The other advice I have, is to never trust a single measurement. Take the shocks and sway bar out (they just add friction for this exercise). Go drive the car for a short distance, stopping everywhere you see that looks level and repeat your measurements. Throw out any that are way off the others, and use an average of the rest. You’ll be surprised how much they vary, and will be glad you didn’t do anything drastic based on a bad measurement. DRIVE THE CAR: everytime you lower it onto the front wheels, the tires will get pinched in, artificially raising the front end. Just around the block will be fine to alleviate this. If you get the sides within 1/8" of eachother, you’ve done a great job. In the US, if anything, you might want the right side to be a hair higher than the left to help compensate for road crown. If you want to be very accurate, then be sure to load the car as it will be when driven (you might toss 150lbs of sand-bags into the drivers seat for instance). Whew- Ryan. End of jag-lovers-digest V2 #418 ******************************** Return-Path: @owner-jag-lovers-di1 Received: (from majordom@localhost) by ekeberg.sn.no (8.7.5/8.7.3/on4) id for jag-lovers-digest-out; Thu, 10 Oct 1996 02:08:22 +0200 (MET DST) Date: Thu, 10 Oct 1996 02:08:22 +0200 (MET DST) Message-Id: 199610100008.CAA28720@ekeberg.sn.no X-Authentication-Warning: ekeberg.sn.no: majordom set sender to owner-jag-lovers-digest using -f From: @owner-jag-lovers-di1 To: jag-lovers-digest@sn.no Subject: jag-lovers-digest V2 #419 Reply-To: jag-lovers@sn.no Errors-To: @owner-jag-lovers-di1 Precedence: bulk X-Newsgroups: mail.jag-lovers-digest jag-lovers-digest Thursday, 10 October 1996 Volume 02 : Number 419 Front end alignment AC Compressors Re[2]: Leather Interior Re: [XK8] Price Polished E-Type [was: Re: XK’s Unlimited open house] Re: XJ-S Drain Plug Putting in the crossover pipe (XJS) Doh! Big mistake in previous message Re[2]: `89 XJ40 Re: V12 Radiator drains Re: Leather Interior Re: H&E Convertible Fuel System Re: Jack Stands for an E-Type Re[2]: V12 Radiator drains Re: 62 E, oil pressure too high Re: Fuel tank sealant Re[2]: Front end alignment From: Tony Watts amw@maths.uq.oz.au Date: Thu, 10 Oct 1996 07:51:24 +1000 Subject: Front end alignment There is a web page on do-it-yourself wheel alignment that I found out about somewhere, perhaps even from the jag lovers list: http://www.vtr.org/maintain/diy-alignment.html It looks a little over complicated to me but I am sure that people could adapt it to their own tastes. I have never tried it so cannot vouch for it. Tony Watts From: gprice@Rt66.com (Gregory W. Price) Date: Wed, 09 Oct 1996 14:13:58 -0600 Subject: AC Compressors My '85VdP needs an A/C compressor. I have the type with the superheat switch, which is about 100 bucks more than the compressor without the superheat switch. What is a superheat switch, and can I either supplant the one I have, or use the other compressor and ignore the superheat switch? TIA Greg. ******************************************************************* Gregory W. Price & Company, Ltd Business research and information management for those who need it most. 1-800-670-5491 ******************************************************************* From: Steve_Kemp_at_NBD@pcmail.tellabs.com Date: Wed, 09 Oct 96 16:51:17 CST Subject: Re[2]: Leather Interior The seat backs and sides on all of my Fords have been vinyl, while the surfaces were/are leather. Vinyl (or ICI(?) vinylide or something with a wierd name) is used on the door panels and sills on early E-Types, while leather is used on the seats and shift boot. I think the actual console is vinyl too. I’m fairly certain that BAS or British Auto could offer a definitive solution. Since it’s a Ford now, I suppose only the seating surfaces will be leather Steve ______________________________ Reply Separator _________________________________ Subject: Re: Leather Interior Author: Michael Frank mfrank@westnet.com at smtplink-tellabs Date: 10/9/96 3:02 PM Kirbert: Every car brochure I have seen in recent years describes leather upholstery as ‘leather seating surfaces’. I have always assumed that this means a combination of cowhide and naugahide. The practice must go back a long way: the seat backs on my '69 E-Type appear to be synthetic. Mike Frank At 12:01 PM 10/9/96 -0005, you wrote:
Chad Bolles:
| some rules must be broken.
| - Palm’s Postulate
Date: Wed, 9 Oct 1996 18:03:39 -0500
Subject: Re: [XK8] Price
Geez, don’t you guys get to vote? Is this a byproduct of a plan to
massively discourage the use of luxury cars? What is the price of
something a bit more basic, like a Honda Accord for example. When I
visited Austrailia recently I saw a TV ad for an Accord at something like
AU$ 36,000. It appeared to be the equivavlent of my wife’s new accord,
which cost just under US$ 20,000.
Or is there a bigger picture that makes such a comparison invalid. For
example, here we have a variety of National, State and sometimes local
income taxes. For cars over US$ 30,000 we have a luxury tax on the cost in
excess of $ 30,000. In addition, at least in this state, we have a sales
tax on the purchase price, miscellaneous title and registration fees and an
annual property tax. I’ll have to do a bit of research and then I can put
up a number that represents earnings before any taxes required to buy an
XK-8. (And then I can translate that into Big Macs )
MikeC
Subject: [XK8] Price
Author: Gunnar Helliesen gunnar@bitcon.no at Internet
Date: 10/8/1996 4:03 AM
gunnar@medial.se (Gunnar Forsgren) wrote:
It’s time to begin saving up. A reasonably equipped cabriolet
costs 750 000 Skr (Swedish Crowns).
I just checked today. In Norway the same car costs around 1.5 million
Norwegian Kroner. At 6.5 Kroner to the $ that should work out to a
whopping $230,000! (Around 1.3 million or $200,000 for the coupe).
I could comment further on that, but then again you all know my feelings
about the prices of cars in Norway…
By the way, what are the chances of getting a Green Card in the US these
days?
Gunnar
Gunnar Helliesen | Bergen IT Consult AS | NetBSD/VAX on a uVAX II
Systems Consultant | Bergen, Norway | '86 Jaguar XJ6 4.2 Sovereign
gunnar@bitcon.no | http://www.bitcon.no/ | Vicki who? What .sig virus?
Date: Wed, 9 Oct 1996 18:21:54 -0500
Subject: Polished E-Type [was: Re: XK’s Unlimited open house]
Sounds like a couple of E-Types I've seen at concours events (after
they rolled out of an enclosed trailer.)
I don't look down at people who try to maintain a car in perfect
"like-new" condition, but I have to admit I don't understand how cars
that are chromed and polished way beyond the way they were originally
can be judged so highly.
Any of you judges? If so, how about a discussion of how things are
judged for originality, especially for appearance?
MikeC
Subject: XK’s Unlimited open house
Author: David J Shield David_J_Shield@ccm.fm.intel.com at Internet
Date: 10/7/1996 7:46 PM
<snip>
There were some beautiful cars there. I spoke with one of the XKU
guys who showed me just what they had done to a 74 OTS E and a MKII
to justify the $120K each to the owner (some rich guy in Florida).
Polished down to the last screw.
<snip>
Best,
Date: Wed, 9 Oct 1996 18:40:01 -0500
Subject: Re: XJ-S Drain Plug
Is one of those dates a typo? 3/87 seems way too early be an '87. My
'88 was built 12/87 (without a drain of any kind.)
MikeC
Subject: XJ-S Drain Plug
Author: “Himes;John W.” jwh@mime.dw.lucent.com at Internet
Date: 10/8/1996 7:27 AM
I have an 88 V12 XJ-S ( MFG 3/87 )
John Himes
88 XJ-S 98K Miles
Date: Wed, 09 Oct 1996 16:56:15 -0500
Subject: Putting in the crossover pipe (XJS)
I have just replaced the crossover pipe in my '85 XJS. After much trial and
error I have found a way that works. If you ever have to do it, this is the
only way if the water pump is installed already. I think it might be easier
to install if it went on with the water pump attached except for one thing.
When removing the water pump the Haynes manual says remove the crankshaft
pully. I have several problems with that aside from the fact that its not
needed, its not easy and means you have to remove the starter which adds
more work. “The starter you say?”, yes, the starter so that you can jamb
the flywheel to remove/replace the crank nut which is at 150 ft pounds.
I feel that if the crank nut and the pully bolts (4) are tight, don’t mess
with them. Let sleeping dogs lie. (check them, of course) The water pump
will come out and go back in without removing the crank pully. But the pump
will not go back on with the crossover pipe connected if the pully is still
on as you have to snake it in over the pully and the crossover pipe would be
a big impediment.
So having said that and realising that you are now going to replace the
crossover pipe with the water pump already installed, there is only one way:
Lubricate all three of the pipe connections (on the two thermostat housings
and the water pump) liberaly with 3M water hose sealer. Then lubricate the
three matching pipe ends on the crossover pipe with the 3M stuff. Now slip
the new, cut to the proper length, hoses onto the crossover pipe. Put two
clamps onto each of the three hoses, not tight, just enough so they don’t
slide off. The two clamps on the right side should be placed so the screw
is on top when installed and slightly back. The clamp on the thermostat
housing on the left side should be so that it is on the bottom and slightly
back so there is enough room for a screwdriver angled down below the header
tank. The two clamps on the water pump hose should be on the left side of
the hose slightly back so the screwdriver is angled to the left side of the
car. If you set the clamps up this way you will save alot of greif later on.
Now push the hoses up onto the crossover pipe as far as they will go. Next
place the center (water pump), hose onto the water pump tilting it and the
crossover into position. It will take a little pushing and prying with a
screwdriver, but its not too bad and the hardest part is done.
Now, pull all the three hoses into approximately the correct position and
lightly tighten the clamps. Now make sure the small pipe on the top of the
crossover is clear of the big bolt on the block so that the hose to the
overflow tank can be put on without being in a position to rub a hole in it.
Tighten all six clamps and you are done.
I hope this helps someone.
Jim
“Better an outlaw than not free.”
Nance O’Neil
Date: Wed, 09 Oct 1996 16:38:51 PDT
Subject: Doh! Big mistake in previous message
Doh!
Basic math skills fail me…
And, suppose you want to lower that corner 0.75".0.75" / (1 compressed coils / 1.625") / 1.9 => 0.641 compressed coils.
Of course this should have read
0.75" * (1 compressed coil / 1.625") / 1.9 => 0.243 compressed coils.
and
should have been:
What we want to cut is 0.243 coils, or 0.757 coils short of the mark we
just made. Start at the “1 coil” mark, and go 272 (0.757*360) degrees
Is it Friday yet?
Ryan.
Date: Wed, 9 Oct 1996 18:48:36 -0500
Subject: Re[2]: `89 XJ40
'Cause it’s an XJ-40 and they’re so ugly no one wants them???
<sorry, I couldn’t resist swinging at such a slow pitch>
<no, no, no! before all you XJ-40 owners sic your dogs on me, it’s a joke,
only a joke!>
Subject: Re: `89 XJ40
Author: rpeng@cadev6.intel.com at Internet
Date: 10/8/1996 10:04 AM
Just got a 1989 xj6(40) vanden plas. 39k miles, 10G US price.
<snip>
Sometimes I don’t understand the stunning depreciation on these
cars. Why would someone want to give away a low-mileage, top of the
line Jag for so little money?
Roger Peng
Date: Wed, 9 Oct 1996 15:07:40 -0500
Subject: Re: V12 Radiator drains
My 1985 XJS has the clamp in transmission hoses and does have a drain.
However the drain is virtualy worthless since it drains out horizontaly and
onto the front suspension and is virtualy impossible to catch in anything
smaller than a bath tub.
I asket the radiator shop that rodded it to solder a small elbo ont ot to
make it drain down but they would not do it for fear that the heat would
dammage the seals in the drain cock.
Does anyone have a suggestion to solve the drain mess?
Oh, by the way ( boy, am I going to sneak this one in on them! ). I prefer
the discussion of Beer and Burbon or the Beauty of the SIII/Mark II to the
discussion of the XJ8 since I dont think there is one XJ8 owner on the list
yet and very few with the wherewithall to become XJ8 owners. At least I can
own a can of beer, a bottle of burbon, a series III or a Mark II (I actualy
own 3 out of four). The XJ8 discussion takes up 50% of the more recent
digests while the beer/burbon/series III/MarkII discussion takes up less than 5%
JIM I.
“Prefiero morir de pie que vivir de rodillas.”
Gen. Emiliano Zapata
1879-1919
Date: Wed, 9 Oct 1996 19:45:38 -0400 (EDT)
Kirby: I think that you are right, the side of the front seats are
something else, but unlike the XJ-6 the door panels and other pieces are
leather.
Chad Bolles Jaguar South 306 Valcour Rd Columbia SC 29212 USA 803 798 3044On
Wed, 9 Oct 1996, Kirbert wrote:
Chad Bolles:
| - Palm’s Postulate
Date: Wed, 9 Oct 1996 19:50:57 -0400 (EDT)
Subject: Re: H&E Convertible Fuel System
Kirby: I have a friend with an H&E he has all the parts books and such.
And yes the fuel system is one of the main reasons Jaguar quit selling
the H&E car. I will see what my friend has to say as he has fixed his
fuel system. Will TRY tomorrow, as I have a rather full day planed
already.
amazing how rarely I can actually help them!I got a call a while ago from Marv Schindler in Marathon, Florida,
nothing about the H&E fuel system.He can only put about 12 gallons in it, even though it’s supposed to
dash.While I pointed out that dual tanks are nothing new for Jaguar
invention.He also reported that H&E convertibles have apparently had some fuel
convertible. Only makes finding info harder.If anyone can provide some factual info on this system, I’d be happy
so that H&E owners can find it for themselves.– Kirbert | If anything is to be accomplished,
| - Palm’s Postulate
Date: Wed, 9 Oct 1996 19:29:07 -0500
Subject: Re: Jack Stands for an E-Type
This is a Mime message, which your current mail reader
may not understand. Parts of the message will appear as
text. To process the remainder, you will need to use a Mime
compatible mail reader. Contact your vendor for details.
- –IMA.Boundary.143509448
Content-Type: text/plain; charset=US-ASCII
Content-Transfer-Encoding: 7bit
Content-Description: cc:Mail note part
I have had jackstands for many, many years. I can’t imagine working on a
car in the garage without them. (Unless I could have a real lift!!) For a
variety of reasons, I now have eight stands instead of four. I certainly
consider four the minimum. My stands extend to about 24" maximum. I’m
pretty big (i.e. fat), but find the height sufficient for working on my '74
E-Type. $48 a pair seems very high. Try shopping at K-Mart, Walmart, or
your local discount auto parts chain. (e.g. Trak Auto, Hi-Gear, etc.) You
should be able to buy them for less than half that price. A six ton stand
is overkill for one corner of a less than two-ton car.
A good hydraulic floor jack is also a great investment if you plan on doing
much DIY work. A couple of pumps and the entire end of the car is off the
ground. Never work with the car on the jack, support it with stands!!
Personally, I think it’s a better investment to get a good quality jack
(e.g. Walker) instead of a K-Mart special. It’ll last a long time, and if
you have a minor problem you can get new seals, etc. easily. The el-cheapo
jacks tend to be throw-away items.
The three things I use constantly in auto maintenance are my floor jack, my
stands and my compressor.
MikeC
Author: rrichardson@eurekanet.com (Robert J. Richardson) at Internet
Date: 10/9/1996 12:23 AM
a jack?
- –IMA.Boundary.143509448–
Date: Wed, 9 Oct 1996 19:52:51 -0500
Subject: Re[2]: V12 Radiator drains
–IMA.Boundary.085509448
Content-Description: cc:Mail note partWhat year XJ-S had the drain? Any chance is was added?
MikeC
Author: Chad Bolles aa100519@dasher.csd.sc.edu at Internet
Date: 10/9/1996 8:35 AM
Mark: Hate to disagree with you, but the other day while working on an S
with the screw on trans cooler lines, I noticed that it had a drain codk
on it… Had to look twice to believe it, for I as you believed the drain
cock to be a thing of the past, but there it was.
Chad Bolles
- –IMA.Boundary.085509448–
Date: Wed, 9 Oct 1996 20:03:18 -0400 (EDT)
Subject: Re: 62 E, oil pressure too high
All:
To those who asked, the PO of my car installed a mechanical oil pressure
guage in the space normally occupied by the electrical guage. The face of
the meter reads ‘Autometer 2421’ that is as much as I know about who made
it. It is exactly the same size as the original, but has a red pointer, so
it is a minor eysore. There is a simple fitting in place of the normal
sending unit, which allows attachment of a capilary tube. The tube enters
the dash thru the same grommet as the choke cable. By the way, a small
amount of oil seeps from this capilary into the interior of the car, making
the Jag experience that much more complete.
Mike Frank
1969 E-Type
At 06:19 PM 10/8/96 -0700, you wrote:
Hi Michael,
I’m curious too about a mechanical oil pressure gauge for
a 62 e-type. Could you email me the details as well?Thanks in advance,
Ken
John:
60 PSI is not dangerously high. My 4.2 E-Type fluctuates between 25-35 PSI
at idle, and 50-65 PSI at speed. The only way you would be blowing smoke at
this pressure is if your head gasket had given way. Things to check:1.What is your RPM at idle? Should be about 600, give or take 100.
Higher speed>higher pressure.
Bypass may be stuck or obstructed.
Oil filer may be clogged.
Bad guage or sensor.
The PO of my car installed a mechanical guage. I will check the make
tonight, and E-mail you.Mike Frank
l
Is there a mechanical oil pressure gauge available with the correct thread
that I could put in to verify the pressure?
Date: Thu, 10 Oct 96 13:03 NZST
Subject: Re: Fuel tank sealant
The only purpose fuel tank sealant is good for is sealing up the seams in a
fuel tank. In my experience it is no good for sealing up holes. Yes you do
have to slosh it around the tank.
If you want the ultimate in beer, wine and jaguars, then you better come to
New Zealand.
Alex.
Date: Wed, 9 Oct 1996 20:01:22 -0500
Subject: Re[2]: Front end alignment
- –IMA.Boundary.160609448
I agree with Chad. Any competent shop can easily do my XJ-S. I had mine
done by the local Goodyear dealer when I had new tires installed. Only
caveat is to make sure they have the right settings. Thanks to my fellow
Jag-lovers, who have pointed this out many times, I took the correct
settings with me. Sure enough, their book was wrong. They cheerfully used
my settings. No pulling, no handling degradation and no visible uneven
tire wear. They just charged their standard price for a conventional rear
wheel drive car.
MikeC
Date: 10/9/1996 8:48 AM
The front end of the Jag is just a straight forward front end, no big
deal, it has caster and camber and toe end settings just like a Ford or a
Chev.
I get all my front alignment work done by a local shop here in Columbia SC
and even Tyre America said they would do it. Cost around $25.
Chad Bolles
- –IMA.Boundary.160609448–
End of jag-lovers-digest V2 #419
id for jag-lovers-digest-out; Thu, 10 Oct 1996 15:31:26 +0200 (MET DST)
Date: Thu, 10 Oct 1996 15:31:26 +0200 (MET DST)
Message-Id: 199610101331.PAA22999@ekeberg.sn.no
Subject: jag-lovers-digest V2 #420
Precedence: bulk
jag-lovers-digest Thursday, 10 October 1996 Volume 02 : Number 420
XK8 on Speed Vision
XK8 Prices and Aust. car costs (little jag content)
Two Birds – One Stone?
(Fwd) I spit PATOO!
Seat Mounting Bolts & Nuts - XJ-S
XJ-S Seat Mount Bolts
Re: Putting in the crossover pipe (XJS)
Re: Polished E-Type [was: Re: XK’s Unlimited open house]
Re[3]: Leather Interior
A question of paint color for restoration
Front end alignment
Re: Re[2]: V12 Radiator drains
Date: Wed, 09 Oct 1996 20:36:57 -0400
Subject: XK8 on Speed Vision
Jaguar bought a lengthy spot on speedvision net work,I scrambled for a
tape and caught about %70 of it . It’s a very well done comercial
showing all aspects of the production and driving of the XK8. It’s in a
lexus style format lots of sureal type shots extremly well done with
interviews from factory employees that build the XK8. About 10 mins in
length?? Hope this airs on more common networkss for all to enjoy.
Frank P.
Date: Wed, 9 Oct 1996 20:26:32 -0500
- –IMA.Boundary.147709448
I don’t think there is a simple answer. It seems to vary from year to year
and market to market. Judging from all the photos and descriptions I’ve
seen, the XJ-S generally gained increasing amounts of leather and wood as
the years passed. My '88 brochure describes both the seats and doors as
leather covered. The later 6-cyl XJ-S in the US market probably has less
leather than the V-12, just as it lacks the trip computer and several other
features. On my XJ-S, the instrument panel is black, while on newer XJ-Ss
I’ve seen wood ones (at least on ones with round gauges.)
On my '74 E-Type the only leather is the actual seating surfaces, all the rest of the seats and the entire rest of the interior is one of two types of vinyl. I also have brochures where different models of the XJ-6 are clearly described as having different amounts of leather. For example, the '93 XJ-6 (XJ-40) is described as having leather faced seats while the VDP version is described as having full leather seat trim, handbrake grip, sun visors, console, armrests and map pockets. MikeC ______________________________ Reply Separator _________________________________ Subject: Re: Leather Interior Author: Michael Frank mfrank@westnet.com at Internet Date: 10/9/1996 1:49 PM Kirbert: Every car brochure I have seen in recent years describes leather upholstery as ‘leather seating surfaces’. I have always assumed that this means a combination of cowhide and naugahide. The practice must go back a long way: the seat backs on my '69 E-Type appear to be synthetic. Mike Frank At 12:01 PM 10/9/96 -0005, you wrote:
Chad Bolles:
| - Palm’s Postulate
- –IMA.Boundary.147709448–
Date: Wed, 9 Oct 1996 20:43:50 -0500
I can, and will, write you a description of the H&E fuel system. That
particular Rube Goldberg system is one of the biggest differences between an H&E
and a “normal” XJ-S.
I pretty much figured out for myself how it all worked, but thanks to Julian
Mullaney (whose beloved H&E was flattened by a tree during Hurricane Fran) I now
have an H&E manual to refer to.
I’ll send you a detailed write-up in a few days.
MikeC
Author: palmk@gcn.scri.fsu.edu at Internet
Date: 10/9/1996 2:23 PM
dash.
invention.
| - Palm’s Postulate
Date: Wed, 09 Oct 1996 22:04:18 EDT
Subject: XK8 Prices and Aust. car costs (little jag content)
Mike cogswell said, with regard to a thread on Aussie car prices
Yeah, we get to vote, but the only people (? thats probably being generou
calling them people) we get to vote for are politicians…
Yes it is an indirect attempt to discourage the use of luxury cars -
high income earners are taxed (both directly and indirectly) quite
punitively. Any vehicle costing more than $50000 AUD ($40,000 USD)
attracts a luxury car tax, and considering we have a tariff on all
incomingcars (I think it’s 20%) plus shipping costs from Europe whence
most luxury cars come are a fair bit to here, it doesn’t take much of a
car to have a landed cost greater than $40,000 US.
OK lets compare apples with apples, $36000 AUD is roughly $29000 USD.
Take $20000 USD add 20% tariff ($4000) add shipping costs - your Honda is
made in the US isn’t it? - don’t know what it costs but say a $1000, the
difference is about $4000 US - that difference is probably a combination
of less economies of scale of purchase and dealership in Australia, the
population is a 10th of the US- therefore less cars sold. A less heavily
taxed business environment - dealer gross margins don’t have to be as
high to get the same net margin, POSSIBLY more ridiculous design
regulations (not sure on this one) - anything that our design rules
specify has to be in a car that no other country does will cost more per
unit to implement. (and prob half a doz. other things I haven’t thought
of)
Good idea - then you could do a realistic “real world” comparison. The
concepts underpinning purchasing power parity have caused arguments in
economics for years, the basic principle’s OK but there’s so many if’s
and’s and but’s associated with actually making a valid comparison. The
big mac comparison for example is really only rule of thumb stuff because
there’s factors which mean that unless you’re using the big mac index to
compare the burger king prices (idea identical good) it’s not valid. For
example of one reason it’s often not very useful - in Japan due to heavy
protectionism of their agricultural sector mean the price of a “bigmaku”
is about 3 times what it would be if it was a sushi burger, i.e non-beef.
John
Level 1, 29-57 Christie St.
St Leonards NSW 2065
Ph: +61-2-9937-8063 Fax: +61-2-9937-8100
Mobile +61-419-617-619
Date: Wed, 09 Oct 1996 22:06:02 -0500
Subject: Re: XJ6 series III headlight loss
Bruce Sawyer wrote:
This evening on the way home from work I tried to switch on the high beams.
However, all I managed to do was turn off all the head lights. By keeping
pressure on the switch the high beams work. But let go and only the
parking lights remain. Any ideas of where to start? Thanks for any help
you can provide.
This problem can be caused by the headlamp relay or the headlamp
switch. The relay can be serviced, although best to replace. Opening
the relay cover and lubricating the ratchet mechanism has worked well
for me. The headlamp switch is usually a dirty contact; again, best
solution is to replace.
Hope this helps,
Bob Johnson
Brattleboro, Vt.
XJ50, XJS, XJ12L
Date: Wed, 9 Oct 1996 22:24:07 -0500
Subject: Two Birds – One Stone?
Bird 1: Like David Shield I have considered having a t-shirt made saying =
jag-lovers@sn.no to wear for those events when I might meet in person =
someone I have met here. Or maybe a pin or clasp or cap?=20
Bird 2: Beyond the tremendous sharing of talent and time, there are =
monetary expenses associated with jag-lovers that have been borne by =
some of our friends. (Being relatively new to the list I hope I’m right =
about all this?)
Stone: Perhaps some of our more talented friends could create a product =
that would carry the name and be sold at a reasonable profit to help =
support jag-lovers?
As I have said, I am relatively new but I have benefited much and I =
certainly want to contribute to the fiscal health of this activity. If =
cash is a better solution, that’s OK by me. Just thought I would throw =
out this idea.
Date: Wed, 9 Oct 1996 15:40:07 -0005
Subject: (Fwd) I spit PATOO!
The following is the opinion of a non-jag-lover when discussing
Jaguar’s decision not to offer a manual transmission. I think it is
illuminating. BTW, the car he refers to is an early 70’s Dodge
Charger 440 Magnum with the infamous Mopar automatic transmission –
special ordered from the factory, purple with white top and white
interior.
- ------- Forwarded Message Follows -------
To: slowness@bcfreenet.seflin.lib.fl.us
Date: 9 Oct 1996 11:34:58 CST
Subject: I spit PATOO!
K>From the guy who removed the GM400 from his Jaguar to bolt in the
5-speed, I must say minds are closed here! I hate automatics, but
even I am willing to keep an open mind until I drive the new XK8; all
reports are that the tranny is truly excellent, totally unlike the
crap the GM400 is. And since it can be shifted manually when desired,
what more could you want? The Jaguar engineers point out that it will
shift FASTER than anyone can possibly move a shifter, so couldn’t it
actually be a good thing?
From one who also owns a car with a “state-of-the-art” automatic when
it was built 25 years ago, which was touted as able to be shifted
manually when desired, and which was demonstrably superior to stick
shifts at the time in speed of shifts and getting power to the ground
(all drag cars had the auto, considerably quicker than the 4-speed), I
would say “blaaaaaugh!” to all the above. If the car is to be used as
a dragster, perhaps a good auto as an option would be nice. As a
sports car, speed of shifting is secondary to positive control, which
necessitates a CLUTCH. Many manufacturers have made all those same
claims, IOW, I’ll believe it when I see it. Meanwhile, not even having
an option of a stick in a “sports car” is unforgivable.
MW
| - Palm’s Postulate
Date: Thu, 10 Oct 1996 01:20:08 -0005
Subject: Seat Mounting Bolts & Nuts - XJ-S
We had just recently been talking about the pleasure of working with
the seat mounting bolts and nuts on the XJ-S – notably, how much
enjoyment is derived trying to hold those rectangular nuts in place
while you get the bolts started. I suggested perhaps some clip nuts
might be found to replace the rectangular nuts that would hold
themselves in place.
So, tonight, while working on something else in the interior, I
happened to notice that my passenger’s seat needed some attention –
and that it would have to come out.
Since there’s no hurry, I decided I would try to find some suitable
clip nuts myself and have them on hand when I worked on the seat. Of
course, to do that I really need to know such pesky details as the
size of the bolt, some dimensional stuff about where the clip nut
would clip, etc. So I decided to go ahead and pull one of the front
corner bolts temporarily so I could get some measurements.
With the bolt in hand, I went to my collection of bolts to compare
the size. It is a 5/16" fine thread, so as I mentioned before I
doubt if I’ll find any clip nuts in fine thread, and plan to look for
coarse thread clip nuts and some new bolts to fit them.
Anyhow, while looking through my junk, I found a clip nut – it
looked right, too. I also picked up a 1" long 5/16" NC Allen head
bolt, and went back to the car to trial fit the combo. I expected
the clip nut would be close, but since the Allen head is considerably
taller than the original bolt head, I figured it would foul the
sliding seat rail. At least I could see how badly it fouled the seat
rail, and purchase new bolts accordingly, hopefully without having to
grind any heads for clearance.
So I slide the clip nut into place, and it fits PERFECTLY. I then
install the Allen head bolt (requires a 1/4" Allen wrench) and it
fits perfectly too! I looked down the rail, and there is plenty of
clearance for the taller head, even with the original lock washer
under it. In fact, the whole thing went together so
perfectly that I REALLY didn’t wanna take it back out, even though I
knew I would need the parts in hand to buy another 7 of each.
For those who don’t know clip nuts, I will describe as best I can;
an ASCII pic would never work here. This clip nut is made entirely
of sheet steel – how they form the threads I have NO idea, but it
ends up with about twice as much threading as that crappy rectangular
nut had. One end of the sheet metal is folded over to form a clip;
sometimes it’s just a short clip, but this one goes all the way back
over the threaded hole, with another hole for the bolt to pass
through. The distance from the threaded hole to the fold is
important; if it’s too short, the clip won’t go on far enough for the
holes to line up, and too long and it leaves the fold sticking out
the front of the seat mount and grabbing ladies’ stockings. Like I
said, this clip nut was perfect, and the distance from the center of
the threaded hole to the fold is 5/8".
Some clip nuts are designed to clip onto thin sheet metal and some
are designed to clip to thicker stuff. This one could probably
handle up to 1/8", so it clips onto the seat mount easily.
Also note that since the clip part of the clip nut ends up on top of
the seat mount, the bottom seat rail will actually be sitting on it
- – or at least the washer under the seat rail will be sitting on it.
This is no problem, and is the way clip nuts are supposed to work.
Anybody planning to pull their seats out, I highly suggest you get a
set of these clip nuts and Allen head bolts before starting. It’ll
make reinstallation SO much easier.
Meanwhile, if I get a part number or other better description while
I’m at the hardware store getting 7 more, I’ll post it.
| - Palm’s Postulate
Date: Wed, 9 Oct 1996 15:40:08 -0005
Subject: XJ-S Seat Mount Bolts
difficult to get the Phillips screwdriver directly on the screws at
the back of the seat.
Stefan Schulz:
They’re TORX in mine.
That is, IMHO, a significant improvement. In fact, I’ve been
thinking about getting some TORX or Allen screws to replace the
Phillips with, probably will the next time I’ve gotta fiddle with the
seat.
D’ya suppose finding just the right type of clip nut would help?
Pass. The only clip nuts I know are ones that fit into 19" electronics
racks, and they need a square cutout to fit.
No no no – drop into a Lowe’s or any good auto parts or hardware
store and you can find dozens of clip nuts, the type that fit around
the edge of a piece of sheet metal. Most of the smaller ones just
have a stamped hole to thread a sheet metal screw into, but nowadays
there are larger ones that actually have serious formed threads in
them. Seems to me that perhaps a suitable shaped one might be found
that would clip onto the floor mounts from the end, leaving the
threaded part inside where that obnoxious square nut presently sits,
and the clip part would be up on top so the seat would sit on it.
I suspect that most available clip nuts are coarse thread, so the
bolts themselves will need to be replaced. Suitable replacements
should be available at the same store. Gotta be careful about the
shape of the head, so that it doesn’t interfere with the travel of
the seat rail.
| - Palm’s Postulate
Date: Thu, 10 Oct 1996 08:02:02 +0200 (MET DST)
Subject: Re: Putting in the crossover pipe (XJS)
You don’t need to remove the starter to jam the flywheel. Once you have removed
the upper part of the pully (the one which drives 3 belts), you can easily
use it’s 2 screws to attach a home-made bar on the damper.
- Matthias
Date: Thu, 10 Oct 96 02:54:33 EDT
From: ** SHANE MANTOSZKO ** IBMA INVENTORY ANALYST **
*** Resending note of 10/10/96 16:34
*** SYDVM1(SHANEM) PH. (02) 354-4918 CUMBERLAND FOREST FE21
*** INTERNET - SHANEM@VNET.IBM.COM *** IBMMAIL - AUIBMSPM ****
- Matthias
Or even use a good long handled socket/torsion wrench, put it on the
front crank nut, brace it on a strong part of the engine bay, disconnect
the coil, and then turn your ignition key for a few quick bursts, and
voila, the crank nut will be loose…hard part is then re-tightening it,
but a ratchet gun worked for me.
Date: Thu, 10 Oct 1996 09:58:48 +0100
Subject: Re: Polished E-Type [was: Re: XK’s Unlimited open house]
Mike Cogswell wrote:
I don't look down at people who try to maintain a car in perfect "like-new" condition, but I have to admit I don't understand how cars that are chromed and polished way beyond the way they were originally can be judged so highly. Any of you judges? If so, how about a discussion of how things are judged for originality, especially for appearance?
I’m not a judge but I do think it a little absurd the lengths to
which concours owners (oops almost said drivers) go to keep their
cars in “like-new” condition. This was proved to me a while ago
when a motoring program discovered an XK120 (or maybe 140) that
had practicaly never been used with something like less than 300
miles on the clock and stored since being purchased.
It was entirely as-new but would never had won a bean at a concours
event. Jaguar build quality ensured that the shut lines were uneven,
the underseal was patchy, interior didn’t fit etc. A far cry from
the people who paint the inside of their exhaust pipes to make it
appear “newer”. Poor saps.
Cosmo
83 XJ6 4.2
65 Mustang 289
Date: Thu, 10 Oct 96 08:07:20 EST
Subject: Re[3]: Leather Interior
Here is a data point. I have a late model ('93) XJ-S 6-cyl. It is pretty much
ALL leather - seat sides and backs are definitely the same as the seating
surfaces. Door lining is leather too. The dash certainly feels like leather.
Also plenty of wood. Only a few places where they might have put wood but
didn’t - Instrument panel is not wood - but a black material - with round
gauges. The transmission shift knob is metal/plastic combo - a little ugly.
(anybody know where to buy a nice wooden replacement handle?)
In later years I am pretty sure that Jaguar has listened to it’s customers in
the luxury car market in the US - they want all the pampering stuff - and they
won’t buy without it.
Went to see the XK-8 yesterday. Looks like all leather there too - so the trend
continues. Definitely too much wood.
- mclaus ('93 XJ-S Convertible)
Date: Thu, 10 Oct 1996 9:12:20 -0400 (EDT)
Subject: A question of paint color for restoration
Date: 10/Oct/1996
Subj: A quesion of paint color for restoration
Dear Jag Lovers,
Mine is a fairly sinple question. I have begun, at long last, a
more serious effort to restore my 59 XK 150-S. Jaguar Cars confirmed
my suspicion that the original color was Mist Gray with a red interior.
It is now Imperial Maroon over BRG, over Old English White over the
original Mist Gray. The dash and door panels are black dye over red.
The seats are black snd not original. The question is: How important
is it to put back the original color? I don’t want to insult anyone,
but Mist Gray/Red is not what I would have picked if I had been
walking around the new car lot. Several years ago at a JANE show I
saw an XK 140 in Old English White with a Fawn interior which was
so lovely even my wife liked it (this is not an insignificant
consideration). What do you think? Should we try to hold true to
the original or create what we would have liked it to be?
Is there a source for paint codes somewhere on the Net? If
not does someone have a file that they could e-mail me?
George Dodson
Dodson@Bates.MIT.Edu
Date: Thu, 10 Oct 1996 09:13:32 PST
All this discussion of alignment comes at a very opportune time as our 79
XJ6 is in dire need of adjustment after the replacement of the front
bushings. I was very interested to read that most shops have incorrect
specs for this
work. Could someone please relate the proper settings so I can assure
they do it right.
The car is a 79 1/2 SIII XJ6.
Thanks all.
Kory Krofft
64 XKE Cpe.
79 XJ6
Date: Thu, 10 Oct 1996 09:25:00 -0400 (EDT)
Subject: Re: Re[2]: V12 Radiator drains
Mike: No,cause you could tell if it was, by the teltale marks of the
solder. As I said it was a surprise to me.
Wed, 9 Oct 1996, Mike Cogswell wrote:
What year XJ-S had the drain? Any chance is was added? MikeC
Date: 10/9/1996 8:35 AMMark: Hate to disagree with you, but the other day while working on an S
cock to be a thing of the past, but there it was.Chad Bolles
End of jag-lovers-digest V2 #420
id for jag-lovers-digest-out; Thu, 10 Oct 1996 18:24:28 +0200 (MET DST)
Date: Thu, 10 Oct 1996 18:24:28 +0200 (MET DST)
Message-Id: 199610101624.SAA02023@ekeberg.sn.no
Subject: jag-lovers-digest V2 #421
Precedence: bulk
jag-lovers-digest Thursday, 10 October 1996 Volume 02 : Number 421
Re: AC Compressors
Re: Front end alignment
Re: Doh! Big mistake in previous message
Re[2]: 62 E, oil pressure too high
Re[2]: Art vs. Cars [was: Polished E-type]
Jack Stand Prices in Denver Colorado USA
Re: AC Compressors
Re: A question of paint color for restoration
Floor Jacks
JACK STAND WARNING!!!
Re: Seat Mounting Bolts & Nuts - XJ-S
Re[2]: A question of paint color for restoration
Date: Thu, 10 Oct 1996 09:32:03 -0400 (EDT)
Subject: Re: AC Compressors
Greg: Where do you live??? You should have an Autozone, Advance Auto,Pep
Boys or Western Auto in your town. Compressor fits a Chev, you just need
one with the metric bolts in it and superheat. Switch is located in the
rear of the comp, held in with a snap ring. The rebuilt comp that you
will get from one of the stores for around $69-109 with clutch, will have
a plug in the place the superheat switch fits. Most of the cars that I
work on have had the switch bypassed anyway, so I usually leave the plug
in place, but that is up to you.
one I have, or use the other compressor and ignore the superheat switch?TIA
Greg.
Date: Thu, 10 Oct 1996 09:39:28 -0400 (EDT)
Jim: Why or Why remove the starter, when you can remove the dust shield
for the trans and do the same thing, and the dust shield comes of with no
problem.
Besides if the car has 50,000 plus miles on it the front seal is most
likley leaking or seeping at the very least, and it sure is much easier
to replace it at the same time.
Date: Thu, 10 Oct 1996 08:43:27 -0500 (CDT)
Subject: Re: Front end alignment
On Wed, 9 Oct 1996, Robert J. Richardson wrote:
Today I decided to arrange to have my front end aligned (1987 XJ6) as
pretty bewildered by this point and did not pursue it further. I guess
I’ll need to take it to the Jag shop, but is this really that
complicated a job? Or are these guys just FOS?Steve Coleman, Gadsden, AL
1987 XJ6 x2
Join my club! I’ve been getting the same resistance here in Athens, Ohio.
These guys are FOS. I wouldn’t trust alignment of a lump to them. If you
want to drive down to Auburn, I’ll introduce you to the guy who–when the
need arises–keeps my SII heading true. He’s not a Jag dealer, and he’s
not limited to foreign cars. He just knows how to align cars.
There is no magic to aligning automobiles, but, to do it right–the only
way an alignment is at all useful–the guy doing it HAS to know the
things that are common and those that are unique to various cars, like
Jaguars’ shims. (Having, and being able and willing to read, some
manuals helps, too.) He also HAS to appreciate careful and accurate work.
Larry Lee
Auburn, Alabama
1979 XJ4.2, SII
Date: Thu, 10 Oct 1996 09:43:31 -0400 (EDT)
Subject: Re: Doh! Big mistake in previous message
Ryan: Scuse me for sticking my nose in here, but if you are working on
the front end of the car why not use the packing spacers that are under
the bottom of the spring to adjust the front end. This is so much easier
than cutting a spring.
Wed, 9 Oct 1996, Ryan Border wrote:
Doh!
andWhat we want to cut is 0.641 coils, or 0.359 coils short of the mark we
towards the tip and that’s your cutting mark.should have been:
towards the tip and that’s your cutting mark.Is it Friday yet?
Ryan.
Date: Thu, 10 Oct 96 08:23:51 CST
Subject: Re[2]: 62 E, oil pressure too high
As I told John, but failed to send to the group, I had done basically the same
on a previous E-type, but was able to obtain a Smiths gauge that appeared
identical to the electrical variety. The oil leak is caused by not having the
proper Smiths fittings (I also had the same experience when trying to use
standard US fittings). These gauges are much more reliable (although
non-authentic) than the originals, as they will give an immediate reading.
Steve Kemp
Date: 10/9/96 8:43 PM
All:
Mike Frank
1969 E-Type
Hi Michael,
Ken
John:
I have a problem with oil pressure on my 62 E type. Recently, after
l
Date: Thu, 10 Oct 96 08:39:37 CST
Subject: Re[2]: Art vs. Cars [was: Polished E-type]
I think owners (or drivers, for that matter) can be separated into those who
collect them for the pleasure of driving them or the pleasure of looking at
them, or both. If it is being viewed as art, you probably would want it to look
at its best. If it is for driving, that’s a different story. And, of course,
there is some middle ground.
The problem I’ve personally had in restoring is trying to decide which of
Jaguars’ manufacturing flaws should be removed and which shouldn’t. Certainly
poor fitting doors are something that can detract from the overall package in
any event. However, you’re right in that they came that way. Conversely, I find
an occasional lead dribble, sloppy weld or stamping flaw perfectly normal.
Like anything, I suppose it’s personal taste and most of us being individuals,
there’s going to be lots of variation.
There’s been talk in concours circles of initializing another class for those
cars, like the XK mentioned below, that restoration would do more damage than
good but can’t compete at the Pebble Beach level. Save the Pebble Beach
restorations for cars that were too shot to be driven or shown in the first
place. Unfortunately, this describes most of the E-types I’ve owned.
Any thoughts?
Steve Kemp
Author: Cosmo simond@inflon.informix.com at smtplink-tellabs
Date: 10/10/96 5:43 AM
the underseal was patchy, interior didn’t fit etc. A far cry from the
people who paint the inside of their exhaust pipes to make it appear
“newer”. Poor saps.
Cosmo
83 XJ6 4.2
65 Mustang 289
Date: Thu, 10 Oct 1996 09:52:56 -0400 (EDT)
Jim: Why not slip a piece of rubber hose over the drain cock long enough
to drop down past the sub frame.
By the way the General is dead.
"Variety is the Spice of Life, Satisfaction is Death"
Chad Bolles 1958
smaller than a bath tub.I asket the radiator shop that rodded it to solder a small elbo ont ot to
dammage the seals in the drain cock.Does anyone have a suggestion to solve the drain mess?
digests while the beer/burbon/series III/MarkII discussion takes up less than 5%JIM I.
Gen. Emiliano Zapata 1879-1919
Date: Thu, 10 Oct 96 08:04:00 PDT
Subject: Jack Stand Prices in Denver Colorado USA
I did remember to look at the jack stand prices yesterday while I was at
Checker Auto Parts getting some brake fluid. They had a 2 ton capacity
stand for $10, or a box of 2 4 ton capacity for $20.
They had an El cheapo floor jack (small one ) for about $20 or $30 and some
better ones starting at about $40+ but were out of stock at the store I was
at so I really did not get to look and see how they looked.
Myself I have 4 - 2 ton stands & works great for my 4000+ lbs XJ-S. ( also
have 4 more stands, but they are not a nice )
The 3 ton capacity floor jack I have was about $60.
( all prices quoted are in approximate US dollars )
John Himes
88 XJ-S 98K Miles
Date: Thu, 10 Oct 96 15:26:26 gmt
George Dodson asked re XK150
consideration).
George, it is your car, you and yor wife know what you like, make it as you
would like and enjoy it.
Alastair Lauener
64 3.4 S-Type
Date: Thu, 10 Oct 1996 09:32:22 -0500 (CDT)
Greg,
Jaguar uses a stock Harrison (GM) A/C compressor that you can find almost
anywhere. The superheat, or “hot gas” switch is a device to protect the
compressor from overheating in certain situations. Many systems either
do not have one, or have had them disabled. While I am not a fan of
disabling devices that protect equipment, this one seldom comes into play
in a properly maintained and charged system (note the last phrase).
In many of the Harrison compressors, the hot gas switch plugs into the
back of the unit, so you may be able to re-use your existing switch if
you wish.
Larry Lee
Date: Thu, 10 Oct 1996 10:46:27 -0400 (EDT)
Subject: Re: A question of paint color for restoration
George:
Ahhh…a philosophical question! It comes down to this: what do you
intend to do with the car? If your intention is show, then originality is
absolutely required, right down to the last nut or bolt.
But given that the car has had four full paint jobs already, it probably
isn’t the best candidate for show, anyhow. If your intention is to use it as
an an occasional car, then I say do your thing, but try to keep it in good
taste. A major consideration is your wife’s approval. Having been thru this
myself, I can tell you that your life will be much happier if you can draw
her into the hobby: a color change is a small price to pay, especially if
you agree on color. Remember that this is YOUR car, not OURS. Even if every
jag-lover on the planet was deeply offended by you plan, so what? But to be
fair to the next owner, keep the best records you can, and be honest about
any changes.
There has been quite a bit of discussion about paint colors on the list. I
don’t think anyone has come up with a good source for this info.
Michael Frank
1969 E-Type 2+2 (Signal Red courtesy of PO, formerly Regency Red)
At 09:12 AM 10/10/96 -0400, you wrote:
Date: 10/Oct/1996
Subj: A quesion of paint color for restorationDear Jag Lovers,
not does someone have a file that they could e-mail me?George Dodson Dodson@Bates.MIT.Edu
Date: Thu, 10 Oct 1996 09:07:02 +0700
Subject: Floor Jacks
Sears has (at least my Sears in Santa Fe, NM) a large, shop-style
3-ton floor jack on sale for $79.00. Naturally, it went on sale
after I bought my “home mechanic” style 3-ton floor jack at Checker
Auto. I would of course preferred the larger, sturdier Sears jack,
but poor timing being the perpetual curse to my life…
Greg Price
Date: Thu, 10 Oct 96 08:15:55 PDT
Subject: JACK STAND WARNING!!!
Having grown up working after school and weekends in a garqage, I have not
mentioned this before because I just assumed…
NEVER support a car on 4 jack stands. It isn’t safe. They are for supporting
either the front OR the back, if you are lifting up only one end of the vehicle
. If you are lifting the entire vehicle use jack stands on one end only. Put
the other end on blocks or ramps.
Personally, when I’m under a car with jack stands, I also have my hydrolic
jack supporting a bit of weight between them, just in case. I may be a sissy,
but I’ve spent some time trapped under a car when it fell on me.
But that’s another story…
LLoyd - I prefer Coors -
Date: Thu, 10 Oct 1996 11:40:14 -0400 (EDT)
You should have told them your Jag had a Chevy motor in it. They’d have
done the alignment straight away.
John
From: mfl%kheops.cray.com@vm1.cc.nps.navy.mil (Matthias FOUQUET-LAPAR)
But easiest of all;
<You don’t need to remove the starter to jam the flywheel. Once you have remove
<the upper part of the pully (the one which drives 3 belts), you can easily
<use it’s 2 screws to attach a home-made bar on the damper.
I just put her in 4th, and set the emergency brake.
Date: Thu, 10 Oct 1996 12:01:57 -0400 (EDT)
Subject: Re: Seat Mounting Bolts & Nuts - XJ-S
Your description sounds like the thingies (are they called Tinnermans
orsomething like that?) that are used to secure electronic equipment in
racks. Some of these have a captive nut attached and some are one piece.
John
Date: Thu, 10 Oct 96 11:09:01 CST
Subject: Re[2]: A question of paint color for restoration
GEORGE,
As Michael said it is YOUR jaguar do as you please. I painted my '64 a
carmen red with a black interior, the original color was a light
metallic blue. I did stay with a jag color for that year.
Visit your friendly auto paint store and most often they will have a
book on the color samples plus the formula’s. The smallest mix I can get
is a pint container which can be used to see if you like the color. I
removed EVERY inch of the blue before I started my quest. Good luck .
Date: Thu, 10 Oct 1996 12:24:01 -0005
Isbell:
Sure. Take a piece of thin-wall rubber hose and fasten it to the end
of the valve. The valve, a paragon of British design, doesn’t even
provide a suitable place to attach a hose, but it does have a little
lip to it. Once you get a piece of hose over it, you can wrap some
steel wire around it and twist it tight. The wire will pull the
flexible hose down behind that lip so it won’t fall off. Then, with
about 6" of hose, you can aim that drain in any direction you want.
| - Palm’s Postulate
End of jag-lovers-digest V2 #421
id for jag-lovers-digest-out; Thu, 10 Oct 1996 19:17:51 +0200 (MET DST)
Date: Thu, 10 Oct 1996 19:17:51 +0200 (MET DST)
Message-Id: 199610101717.TAA14337@ekeberg.sn.no
Subject: jag-lovers-digest V2 #422
Precedence: bulk
jag-lovers-digest Thursday, 10 October 1996 Volume 02 : Number 422
Re: AC Compressors
Serial Number strangeness
[none]
Re[2]: Putting in the crossover pipe (XJS)
Leather and Wood
Re[2]: Polished E-Type [was: Re: XK’s Unlimited open house]
Chad Bolles:
You don’t need the metric bolts. SAE bolts will work fine, unless
you’re anal enough that you need to use the original bolts!
Actually, it’s not up to you; the superheat switch will not fit in a
compressor that was not made to have one, and most are made for a
pressure switch these days. Best bet: just plan on abandoning the
superheat switch and the 3-way fuse.
By the way, one fundamental difference: the pressure switch is
closed when all is OK and opens when pressure is low, so the clutch
is generally grounded through it. The superheat switch that comes
on the Jag, however, is open when everything is OK and closes to
cause a short and blow the 3-way fuse when temp is too high. So,
the wiring to the clutch goes through the fuse, and a third wire
goes to the superheat switch which must NOT be grounded in order for
the system to work.
| - Palm’s Postulate
Date: Thu, 10 Oct 96 09:17:06 PDT
Subject: Serial Number strangeness
With the help of several Jag Lovers, much head scratching, searching, ques-
tioning, and an appropriate amount of nose picking, I have come up with the
following ‘strangities’ associated with the serial numbers on my Jag. For
anyone wondering about their numbers, this may be of help, or at least, in-
terest. My car was made in 8-1970, one of the last series II “E” types to
roll off the assembly line, and a US import.
My original question had to do with distinguishing between the body number
and the vehicle ID number. Fortunately, I kept a copy of the previous title, an
d when I got my Calif. title, they mistakenly used my body number instead of
the vehicle ID number on the title. I also have an original listing of
serial numbers that came with the car when it was new.
The vehicle ID number is stamped on a piece of aluminum on the left side ‘A’
post. Body numbers are on the box frame, left door sill and under the trunk lid
on the body.
Date Of Manufacture 8-1970 (last one made in 10-1970)
Vehicle ID 2R13939
Body Number P2R13939 (same-same with leading P)
Engine NO. 7Rnnnnn-9 (n is a number, -9 is 9:1 compression, -8 would be 8:1)
Tranny No. KEnnnnn
The body number vs. ID number had me confused for a while, but thanks to one
of the list members (can’t remember who right now) I verified this.
LLoyd -no beer content, no prettiest content -
Date: Thu, 10 Oct 1996 19:04:57 +0200
Subject: [none]
From jag-lovers-digest-owner@sn.no Thu Oct 10 11:03:17 1996
Received: from ekeberg.sn.no (126@ekeberg.sn.no [194.143.8.8]) by smtp.internetdesign.com (8.6.10) id LAA08027; Thu, 10 Oct 1996 11:03:14 -0600
Reply-To: @owner-jag-lovers-di1
Precedence: bulk
XK8 on Speed Vision
(Fwd) I spit PATOO!
Front end alignment
Frank P.
Chad Bolles:
Yes the entire interior should be leather.
Actually, I’m not sure ANY of them are entirely leather. On mine,
many of the parts of the seat that don’t touch occupants are vinyl.
It’s my understanding that most – if not all – of the cars are this
way.– Kirbert | If anything is to be accomplished,
| - Palm’s Postulate
MikeC
Subject: H&E Convertible Fuel System
Since my XJ-S help book is finally getting around, I occasionally get
phone calls from people wanting help getting their car fixed. Given
how much I have learned about the cars over the years, it is simply
which is half way down the keys. Marv owns a Hess & Eisenhart
convertible, and is having trouble with the fuel system – and I know
take 24. He says the car has two tanks, one just forward of the
spare tire and under where the convertible top stores, and another
under the shelf behind the front seats. Each tank has its own fuel
pump; there’s one in the trunk that looks like the standard Lucas
pump, but the forward tank has a pump inside it. There are also two
fuel gauge sending units, one per tank, but only one gauge on the
dash.
(although it is different for an XJ-S), this system has no changeover
switch. Apparently it does whatever changeover it does
automatically. No clue as to how it works. Supposedly it was an H&E
invention.
tank explosions followed by lawsuits against H&E. If you call H&E,
which is apparently some sort of chassis manufacturer, you can’t
find anyone who claims to know anything about the Jaguar
to include it in my book – or maybe just a reference to the source,
| - Palm’s Postulate
of)
John
you can provide.
Hope this helps,
Bob Johnson
Brattleboro, Vt.
XJ50, XJS, XJ12L
about all this?)
support jag-lovers?
out this idea.
interior.
MW
| - Palm’s Postulate
| - Palm’s Postulate
Stefan Schulz:
seat.
the seat rail.
| - Palm’s Postulate
- Matthias
- Matthias
Cosmo
83 XJ6 4.2
65 Mustang 289
Date: 10/Oct/1996
Dear Jag Lovers,
George Dodson
specs for this
they do it right.
Thanks all.
Kory Krofft
64 XKE Cpe.
79 XJ6
Date: Thu, 10 Oct 1996 13:00:41 -0500
Subject: Re[2]: Putting in the crossover pipe (XJS)
Another good use for a clutch, right Kirby? Just put it in gear, apply the
parking brake and/or chock the wheels. Now the engine is locked.
On a more serious note, you can weld a short length of rod to the end of an old
spark plug. Use it to replace a plug, hand rotate the engine (breaker bar on
that bolt you’re trying to remove) until the piston is up against the rod. Now
it’s locked for sure. Just make sure you disable the starter and hang a red tag
so it can’t get turned over with the rod in it.
MikeC
Author: mfl@kheops.cray.com (Matthias FOUQUET-LAPAR) at Internet
Date: 10/10/1996 8:02 AM
- Matthias
Date: Thu, 10 Oct 96 10:15:45 PDT
Subject: Leather and Wood
I think leather and wood is nice, but personally, I don’t really
mind if the sun-visor or the parking brake handle surround is not
made of leather.
An aside: I can’t help but giggle inside when someone proudly
tells me he bought the latest Honda Accord or Toyota Camry with
full lether interior.
Roger Peng (408)765-7863
Intel Corporation
Design Technology, Physical CAD
Date: Thu, 10 Oct 1996 13:08:38 -0500
Subject: Re[2]: Polished E-Type [was: Re: XK’s Unlimited open house]
–IMA.Boundary.817769448
Content-Description: cc:Mail note partExactly the kind of thing that caused me to raise the issue. I’m
pretty well convinced that if you had a time machine and could go bake
to the '60s or '70s and grab a brand new E-Type at the factory you
wouldn’t stand a chance in a concours today. I’m genuinely puzzled by
this. How did this come to be? I’d still like to hear from people in
the concours business as judges and/or competitors.MikeC
Author: Cosmo simond@inflon.informix.com at Internet
Date: 10/10/1996 9:58 AM
<snip>
“newer”. Poor saps.
Cosmo
83 XJ6 4.2
65 Mustang 289
- –IMA.Boundary.817769448–
End of jag-lovers-digest V2 #422
id for jag-lovers-digest-out; Fri, 11 Oct 1996 02:08:29 +0200 (MET DST)
Date: Fri, 11 Oct 1996 02:08:29 +0200 (MET DST)
Message-Id: 199610110008.CAA17979@ekeberg.sn.no
Subject: jag-lovers-digest V2 #423
Precedence: bulk
jag-lovers-digest Friday, 11 October 1996 Volume 02 : Number 423
XJ-S front end rebuild
Serial Number strangeness/4.2 Compression Ratio
Re: JACK STAND WARNING!!!
RE: xj220
Re: Two Birds – One Stone?
Re: Tone of voice and bashing fellow jag-lovers
Re: Re[2]: Putting in the crossover pipe (XJS)
Re: XK150 colour
Leather Interiors
Re: Re[2]: Polished E-Type [was: Re: XK’s Unlimited open house]
re: Re[2]: Putting in the crossover…
[No Jag content, but some Ford, sorta] Breaking loose
Question
Date: Thu, 10 Oct 1996 13:31:21 -0005
nut had. One end of the sheet metal is folded over to form a clip;Your description sounds like the thingies (are they called Tinnermans
That sounds correct. The one I have here does not have the captive
nut, although there’s no reason why one of those wouldn’t work as
well. This one has a 1/4" long set of threads formed directly from
the parent sheet metal.
| - Palm’s Postulate
Date: Thu, 10 Oct 1996 11:04:22 -0700
Subject: XJ-S front end rebuild
This weekend I will replace the upper A-arm bushings, anti-roll bar
frame mount and end link bushings and shock absorber mounts on my '85
XJ-S. I have two questions:
1.) Is this most easily accomplished with the sub-assembly in the car
or out.
2.) Is there anything else I should do while I’m at it
3.) I plan to use a large C-clamp and socket to press the old bushings
out – sound reasonable? I’ve done this type of repair on a '62 Impala,
but had a great deal of trouble removing the old bushings.
Any help is appreciated
Aaron
'85 XJ-S
Date: Thu, 10 Oct 1996 14:01:56 -0400 (EDT)
Subject: Serial Number strangeness/4.2 Compression Ratio
Group:
The PO of my car obliterated the last digit of the Engine # on the ID
plate. What’s more, the engine itself has been totally stripped of
identifying marks. I was told that he had installed high compression pistons
in a low compression engine. Is there any easy way to tell the compression
of the engine, without disassembly?
Mike Frank
1969 E-Type 2+2
Date: Thu, 10 Oct 1996 13:37:54 -0500
Subject: Re: JACK STAND WARNING!!!
Why isn’t it safe?
MikeC
Author: LLoyd 3030P@vm1.cc.nps.navy.mil at Internet
Date: 10/10/1996 8:15 AM
Date: Thu, 10 Oct 1996 13:26:46 -0500
Why are you fixing it up? To be a contest winner or to drive it and enjoy
it? If you want a contest winner, go with the original color. If you want
to enjoy your car, paint it any damned color that strikes your fancy. If
you want to turn it into a contest winner later, you can always buy more
paint. If you use an original color combination that you like, who’ll be
able to tell without knowing the original codes for your car?
I redid my E-Type in the original Azure Blue with Cinnamon interior. I
like it in '74 when I bought it new and I still like it. On the other
hand, I’m thinking about changing the color of my XJ-S interior.
Bottom line: Do what pleases you. After all, it’s your car. (Unless, of
course, you are contemplating a lump conversion. )
MikeC
Author: DODSON@AESIR.MIT.EDU at Internet
Date: 10/10/1996 9:12 AM
Date: 10/Oct/1996
Dear Jag Lovers,
The seats are black snd not original. The question is: How important is
it to put back the original color? I don’t want to insult anyone, but
George Dodson
Date: Thu, 10 Oct 1996 11:38:31 -0700
Subject: RE: xj220
Lee,
It’s 1/18th scale, but the engine on mine has 3 plug wires on each side – making it a V6. I agree that the detail is fantastic! Cost me $14.00 CDN at Costco.
Mike Everatt
1987 1/2 XJ40 Full Size
1/18 scale XJ220
Sent: Wednesday, October 09, 1996 8:40 AM
To: Licensed; ‘jag-lovers@sn.no’
Subject: Re: xj220
John wrote:
Also, I can buy the large (probably 1/15 scale) models of the xj220 here
for >about $135 USD. Is that too much? John Shuck, Beijing…
I’m not sure of the scale, but I just bought the Majisto (?) metal model of
the XJ-220 in a very nice metallic BRG for $9.00 USD at the local warehouse
store. The car comes on a plastic base which is about 10" long by 6" wide.
The hood (bonnett) and engine deck lids open. The doors open. The seat
backs “recline” the steering wheel turns the front wheels, the wheels roll,
and the wheel can move up and down too. The engine is the V-12. Car is
RHD. They have other models available including the XKE. Lee
Date: Thu, 10 Oct 1996 12:09:35 -0700
visors, console, armrests and map pockets.MikeC
As for the XJ40, I know of that in 1989 the XJ6 had those fully fluted
seats. They were only covered on the top, were you sit with real leather.
The sides and back were all a nice vinyl. The console was also covered in
leather, as was the shift knob and steering wheel.
In my 1989 VDP, Seats are completely leather, sides and all. However,
the back of the seat has a removable trim piece with the picnic tables.
This removable piece is vinyl stitched, but the pockets in the back of the
seat is all full leather. The console, armrests, map pockets, mini console
in the back, handbrake boot and grip, sun visors, shift knob, steering pad &
wheel and front & rear centre armrests are also full leather. The middle of
the door panels, dash, knee bolsters, and rear quarter window surrounds are
made of the top quality vinyl.
The VDP with much more leather, does have a stronger aroma in the car,
but the XJ6 that had a little more vinyl, was also nice because the vinyl is
able to endure much more abuse, and doesn’t need all the pampering and
conditioning that the leather needs so much of, to keep it looking good.
The vinyl always seems to stay in a like new condition, even if it hasn’t
been cared for in a long time.
Cheers,
cobac@ix.netcom.com
Date: Thu, 10 Oct 96 16:39:48 CST
Subject: Re: Two Birds – One Stone?
Also new to the group, I think it is a very good idea and timely, considering
the world is starting to get educated on the meaning of anygroup@yourserver.com
naming conventions. I’m not sure too many would have got it a year ago.
Unfortunately, standard quality t-shirts in a small run can cost $15-20 a piece.
This leads one to wonder how big of a run should one run, and who would want to
bear the cost of inventory until the run is depleted. Lots of logistics,
unfortunately.
Steve
Author: Kyle Chatman kchatman@mail.coin.missouri.edu at smtplink-tellabs
Date: 10/10/96 12:54 AM
about all this?)
support jag-lovers?
out this idea.
Date: 10 Oct 96 18:06:14 EDT
Subject: Re: Tone of voice and bashing fellow jag-lovers
Hi Guys and Girls,
It may be me in a slightly intolerant mode (mood ?), but the slagging of the
concours boyz I find intolerant and unjustified. This list is big (too… well
never mind),
nevertheless there is room for all of us, hopefully also the extremists, and
hopefully
also the lumpy bit.
I too find a well meant practical joke allright and some camp fires are fine
when the
anti-lumps fires a series of grenades in the lump campand vice versa or
whatever, but hanging
anyone out as poor suckers because they have a different way of expressing their
love, vision or ultimate
reflection of nirvana, is over the line.
There need not be a common understanding on this list of what is “right” or
what is “Wrong”
to do with our Jags. The diversity is the interesting part.
I find discussions on glamorous or heartfelt experiences,
or technical matters, or meeting people on this list interesting and fine to
read
when conducted in a civil and polite, humourous, obviously joking or otherwise
well meant manner
but a discussion about the mental deficiencies of “the Other Freaks” or
allegations towards
such is inpolite , intolerable, and as such belongs under heading “listtrash”.
As we saw today one listmember
has already given in to the high level of (polite) trash, sad indeed.
It is possible to express exactly what is meant without offending anyone, a fine
balance indeed, but
lets try and keep the tone above waistline.
If I over-reacted I apologise, but with the amount of traffic which could be
much less and potentially of higher quality
I blew a fuse…
“ever since you found out you contain less fluid than Jeff Beck you’ve been
trying to out-do him” - courtesy of FZ
Jeff
Date: 10 Oct 96 18:06:17 EDT
Subject: Re: Re[2]: Putting in the crossover pipe (XJS)
Hi Mike C and list
tag
What ??!!. You must be joking. This may work on a 1000 HP
ship engine with cast iron pistons
but on any other car that is a potential suicide, at least a sure way to leave
big time
score marks, and might even break the rod or the plug or rip the plug straight
out out the head.
I’m speechless (almost). Octobers first prize for the most outrageous advice.
To fill a cylinder with concrete works well also, but oil is better…
Jeff
Date: Fri, 11 Oct 96 11:12 NZST
Subject: Re: XK150 colour
The best colour for an XK150 is British Racing Green with Biscuit interior,
no questions asked. If you want to increase the sex appeal of you and the
car then this the the best option.
I am open for arguments on this colour combination.
Your Mate from New Zealand
Alex Beacham
Date: Thu, 10 Oct 1996 18:34:51 -0400
Hey Lloyd and All Good Jaggers:
I remember reading somewhere that a small quantity of the series 2 =
E-Types were manufactured in 1971 just before they starting fitting it =
with the V12 and various body changes and hence the series 3.
I have (I think) a 1971 series 2 E-Type that was originally imported to =
Canada (I think). It was sold and I bought it as a 1971 and I’ve always =
understood it to be a 1971. It’s a 4.2 litre and has the series 2 body =
style. I have the car number, body number, gearbox number, and the =
engine number but the name plate indicating the date of manufacture is =
missing.
The car (vehicle) number is 1R12449 and the body number is 4R6986.
So Lloyd, and others, what exactly do I have? Aside from a year’s worth =
of restoration ahead of me. ;>)
Of all the world beers, Canadian beers are best (Brick Amber Dry, =
Niagara Gritstone and Olde Jack, Upper Canada Dark Ale). So there. Case =
closed!
Date: Thu, 10 Oct 1996 18:47:46 -0400
Subject: Leather Interiors
The amount of leather used in the interior seams to increase as the years
go by. My S III XKE has leather seats and backs. The console arm rest is
also leather. The rest is vinyl.
On the 90 VDP everthing except the dash is leather. The same is true with
the 95 XJS V12. You can really smell the hides in these cars.
Jack Bednarski
71 XKE V12
90 XJ6 VDP
95 XJS V12 Conv
Date: Thu, 10 Oct 1996 15:51:44 -0700
Subject: Re: Re[2]: Polished E-Type [was: Re: XK’s Unlimited open house]
Mike Cogswell writes:
miles on the clock and stored since being purchased.It was entirely as-new but would never had won a bean at a concours
“newer”. Poor saps.
In addition to driving a Jaguar, I am also restoring a 1931 Ford Model
A Town Sedan. The judging rules for the Model A explicitly deduct points
for “over-restoration”. If the car is in better than showroom stock condition,
you lose points (aside from a few special exceptions, such as putting sealer
on originally bare metal parts to prevent rust). They have not, however,
as yet required that cars be driven much, although all cars must be driven
during the judging. There are two classes of judging, one essentially for
cars arriving on trailers and another for cars arriving under their own power.
I personally would prefer that the judging include a rally of some minimum
distance, perhaps 50 or 100 miles, before other judging, to ensure that the
car is an automobile, not just an automotive sculpture.
It is unfortunate that judging for most other makes allows for
over-restoration.
From: Tommy tommy%peterboro.net@vm1.cc.nps.navy.mil
Tommy asks, and says;
<I remember reading somewhere that a small quantity of the series 2 =
<E-Types were manufactured in 1971 just before they starting fitting it =
<with the V12 and various body changes and hence the series 3.
What I have read indicates 10-1970 was the last production date for the
series II. Mine (roadster) was bought in 11/70 and registered as a '71.
<style. I have the car number, body number, gearbox number, and the =
<engine number but the name plate indicating the date of manufacture is =
<missing.
Should be on the left door jamb.
<The car (vehicle) number is 1R12449 and the body number is 4R6986.
Mine is 2R13939, maybe yours is the coupe?
…but, most importantly… !
<So Lloyd, and others, what exactly do I have? Aside from a year’s worth =
<of restoration ahead of me. ;>)
If you can do it in a year, you are a better man than I.
LLoyd
Date: Thu, 10 Oct 1996 16:40:54 -0700
Subject: re: Re[2]: Putting in the crossover…
Jeffrey Gram writes:
of an old spark plug. Use it to replace a plug, hand rotate the engine
(breaker bar on that bolt you’re trying to remove)…
I always thought the trick for this was to fill the cylinder with nylon
rope through the spark-plug hole. Soft enough not to damage anything,
but “rigid” enough (when it’s all bunched up by the piston) to work
some serious force against.
Ryan.
Date: Fri, 11 Oct 1996 00:53:07 +0100 (MET)
Subject: [No Jag content, but some Ford, sorta] Breaking loose
All this talk about rear tires breaking loose prompts me to relay an
experience I had a few days ago.
A friend has a DeTomaso Pantera GTS (they came originally with a Ford 351
lump engine). I have no idea how many horsepower that engine yields (not
quite stock, impossibly large valves, a slightly warmed cam, Holley
750cfm etc.) but that thing really moves! That is, when it’s not in the
garage (engine, transaxle, you name it).
As Nick once said: Total sensory overload. A large lump V8 with just the
minimum in regards to induction and exhaust restrictions screaming at
over 6,000 rpm less than one foot behind your head while the car leaps
ahead at speeds well in excess of the comprehensible sort of gives you a
new perspective on the terms “performance” and “speed”. The shove in my
back as the car accellerated was unbelievable.
Another friend has a Lamborghini Countach sitting right next to another
DeTomaso (also his). He has promised me a spin in the Lambo as soon as he
gets the V12 back together. It’s an '87 but still hasn’t seen more than
approx. 30,000 kilometers (18,750 miles) of service. The upper cam chains
needed replacing after bits and pieces of them were found in the oil sump.
Also the clutch has already been replaced once. In his words the
whole drivetrain is a piece of crap, simply not built to withstand the
kind of use the rest of the car invites to (and he’s really a careful
driver, honest!)
I’m helping both guys in the garage so maybe I get to drive these
machines one day…
Maybe Jaguars aren’t so bad after all.
Gunnar
Gunnar Helliesen | Bergen IT Consult AS | NetBSD/VAX on a uVAX II
Systems Consultant | Bergen, Norway | '86 Jaguar XJ6 4.2 Sovereign
gunnar@bitcon.no | http://www.bitcon.no/ | Vicki who? What .sig virus?
Date: Thu, 10 Oct 1996 19:57:51 -0400 (EDT)
Kory: Up to Vin No. 360146
Toe in 1/16 to 1/8
Castor 2 1/4 positive plus or minus 1/4 positive
Camber 1/2 plus or minus 1/4 positive
after Vin No. 360146
Toe in 0 to 1/8
I think that the rest is the same
Chad Bolles Jaguar South 306 Valcour Rd Columbia SC 29212 USA 803 798
specs for this
they do it right.
Thanks all.Kory Krofft
64 XKE Cpe.
79 XJ6
Date: Thu, 10 Oct 1996 20:05:29 -0700
Subject: Question
I replaced my brake power booster last week. Am I supposed to replace
the vacuum check valve too? Can anyone tell me where it is located? Is
this the same thing as the non-return valve? There are no valves in my
vacuum line running from the booster. Thanks again!
1982 XJ6 SIII - Nothing like a prozac with a beer chaser.
End of jag-lovers-digest V2 #423
X-UIDL: 5221649b0caa2b82e566e69638b06ce2
Return-Path: @owner-jag-lovers-di1
Received: (from majordom@localhost) by ekeberg.sn.no (8.7.5/8.7.3/on4)
id for jag-lovers-digest-out; Fri, 11 Oct 1996 04:48:09 +0200 (MET DST)
Date: Fri, 11 Oct 1996 04:48:09 +0200 (MET DST)
Message-Id: 199610110248.EAA06124@ekeberg.sn.no
X-Authentication-Warning: ekeberg.sn.no: majordom set sender to owner-jag-lovers-digest using -f
To: jag-lovers-digest@sn.no
Subject: jag-lovers-digest V2 #424
Reply-To: jag-lovers@sn.no
Errors-To: @owner-jag-lovers-di1
Precedence: bulk
Status: RO
X-Status:
X-Newsgroups: mail.jag-lovers-digest
jag-lovers-digest Friday, 11 October 1996 Volume 02 : Number 424
Antennae
Re: XJ-S front end rebuild
[SIII XJ6] Oil and oil pressure. Today’s entertainment
Re: Serial Number strangeness/4.2 Compression Ratio
Cogswell’s Messages
Still need some wire information (XJS)
Re: AC Compressors
Jaguar Special
XJS stalling
Re: Originality or Lump?
Temporarily unsubscribed + XJ S1 pic !
Re[2]: Seat Mounting Bolts & Nuts - XJ-S
Re: Re[2]: Polished E-Type/Beer
Date: Thu, 10 Oct 1996 20:38:47 -0005
Subject: Antennae
I know there are some radio experts here.
I recall learning years ago that the ideal length for an antenna on
an FM radio is around 31 inches, and that either longer or shorter
is not as good. Is this true? If so, how come some antennas are
not that length?
If true, how does the antenna being mounted at some angle other than
vertical affect it? Should it still be 31 inches long, regardless of
mounting angle?
| some rules must be broken.
| - Palm’s Postulate
Date: Thu, 10 Oct 1996 16:44:19 -0005
Subject: Re: XJ-S front end rebuild
Aaron Burnett aaron.burnett@attws.com:
Why don’t you use two sockets and a piece of threaded rod instead?
One socket needs to be big enough to fit AROUND a bushing while the
other needs an OD just slightly smaller than the OD of the bushing
itself, and the threaded rod should fit through both sockets and the
bushing itself. Couple nuts and washers, and you should be able to
apply a LOT more force than any C-clamp.
| - Palm’s Postulate
Date: Fri, 11 Oct 1996 01:54:59 +0100 (MET)
Subject: [SIII XJ6] Oil and oil pressure. Today’s entertainment
Today I decided to change the oil in preparation for the oncoming winter.
I went to my friendly local auto parts store and innocently asked for an
oil filter for an '86 Jaguar XJ6 4.2 (I already knew what was coming next).
- “Sorry, we don’t have that”
Many of you might know the look on a typical auto store parts man’s face
when you mention the word “Jaguar”. Sort of like “These are exotic cars, no
way we have parts for them. Why do you even bother to ask? Besides, I only
own a Toyota so I’m envious of you. Go away.”
So I asked him if he was sure and if he could please check. After a
lengthy consultation with his books he looks up and asks:
- “Do you have a series one, a series eleven or a series one hundred and
eleven?”
- “Say what? Let me look at that book!”
Sure enough, the book listed XJ6 Series 1, Series 11 and Series 111. I
couldn’t help laughing. Why he bothered to ask I do not know because the
filter listed was the same for all XK engines and even the later AJ6.
Anyway, he checked his stock and of course had several. In an astonishing
break with Jaguar tradition it wasn’t even expensive.
Next stop was a local gas station to buy some of that Mobil 1 oil you’ve
all been talking so favourably of. I checked my owner’s maintenance
manual first and felt my wallet cringe as I read that my engine requires
8.8 liters of this precious fluid. This was going to be expensive! What I
didn’t realize was that I was in for some more entertainment. I had
parked right in front of the door to the station, this meant the attendant
could see my car. I walked up to the appropriate shelf and took two four
liter cans and one one liter can with me to the counter. The attendant then
calmly started to explain to me that I wouldn’t need that much oil, I
should only fill to the marker on the dipstick, not drown the engine.
- “Thank you, but I’m quite sure that I need 8.8 liters.”
- “No, no. 4 liters will do it, maybe 5 if you replace the oil filter as
well.”
- “But my owner’s manual clearly states 8.8 liters.”
- “That must be a mistake. No cars use that much oil, not even Jaguars.”
- “But… but… nevermind! This is not a Toyota or Volvo, OK? I’m
absolutely certain that I need 8.8 liters!”
- (Offended and hurt) “OK, if you say so.”
I did. My wallet did hurt though, the 9 liters cost me NOK 796 (US
$122.50). Later the same day I discovered something new about Mobil 1
oil. An auto discount store here (Biltema) sells Mobil 1 oil at much
lower prices than the gas stations. No surprise so far, the thing is
that it is not the same oil! The stuff sold at Biltema is imported from
the US (the cans clearly state that the oil is manufactured in the US)
and only holds CCMC G4 quality. The stuff sold at the gas stations and
elsewhere is manufactured in Sweden and holds CCMC G5 quality (and is
thus superior to the US variant as I understand it). The Swedish made oil
has a 5W-50 viscosity range while I believe the US version “only” has
5W-40. I saw the US type cans ('cause a friend had bought some) and was
able to do a direct comparison.
Strange, isn’t it? Why would they make the same oil but have different
qualities for different markets? Or is it just a case of Biltema buying a
large stock of leftover oil from the US cheaply because it has been
replaced by a newer, better oil?
While I’m on the subject of Mobil 1 oil: Mobil has been advertising all
over the place lately for the new Mobil 1 oil with a viscosity range of
0W-40! Problem was I couldn’t find any. None of the places I visited had
got it in stock yet and I was determined to do the oil change today.
5W-50 should be adequate even for Norwegian winters though.
As for erratic oil pressure readings on the dash instrument I discovered
the same thing as many others have been reporting on this list. It was
simply a loose connection between the oil pressure sender and the wire. I
tightened the clamp connector and hey presto! High and stable readings
from the instrument.
Now if someone could explain to me how Kpa (Kilo Pascal) relates to the
real world I would actually know exactly how good my oil pressure is!
(The instrument is a scale from 0 to 7 and the text on the instrument
face says “Kpa x 100”). So I know I have 300Kpa at idle and 600Kpa at
3000rpm (both hot), but what is that in psi or Kg/cm2? Help!
Gunnar
Date: Thu, 10 Oct 96 12:53:50 PDT
Subject: Re: Serial Number strangeness/4.2 Compression Ratio
Mike,
You should be able to tell by running a comnpression check. 8:1 at sea level
should be around 128 PSI and 9:1 around 144.
LLoyd - my mercedes is 195PSI, stock-
Subject: Cogswell’s Messages
Is it just me, or are Mike Cogswell’s messages coming through
differently than everyone else’s? My Pegasus software treats them as
multi-part messages with only one part.
| - Palm’s Postulate
Date: Thu, 10 Oct 1996 18:57:38 -0500
Subject: Still need some wire information (XJS)
I am just about back together with my “new” '82 XJS but I still have two
sets of wires to hook up.
The Green and the Green/Red wire to the temperature sensor on the water
pump. Does it make any difference which connector they go on? Are they
interchangable, I hope? -
The Black and White wires in a sheath that come from the right side of
the engine, across the front of the engine and over to the vicinity of the
left hand thermostat. Where do they go? I dont seem to have anything to
push them onto. They each come from a three way connector just under the
intake manifold above and slightly behind the air pump. (EPA mandated in
the US) I havent traced where they go from here.
Help!! I need this info before I can finish the job.
Jim
“Better an outlaw than not free.”
Nance O’Neil
Date: Thu, 10 Oct 1996 21:05:54 -0005
On a more serious note, you can weld a short length of rod to the end of an old spark plug. Use it to replace a plug, hand rotate the engine (breaker bar on that bolt you’re trying to remove) until the piston is up against the rod. Now it’s locked for sure. Jeffrey Gram: What ??!!. You must be joking. This may work on a 1000 HP ship engine with cast iron pistons but on any other car that is a potential suicide, at least a sure way to leave big time score marks, and might even break the rod or the plug or rip the plug straight out out the head. I’m speechless (almost). Octobers first prize for the most outrageous advice. That’s funny, I thought it was a pretty good idea. I don’t understand where score marks would result at all. Obviously, the rod would have to be fairly substantial, but that’s not difficult. If you’ve used all the threads on the spark plug hole, there’s no chance in hell you’re gonna rip it out. The only risk I can see is punching a hole in the top of a piston, but I suspect you’d have to be applying a whole bunch of torque to that nut to do that. Personally, I’ve never been all that thrilled of jamming the flywheel. Only too easy to bugger up those teeth. Why can’t these car companies provide a place to put a pin? Kirbert | If anything is to be accomplished, | some rules must be broken. | - Palm’s Postulate From: “Kirbert” palmk@gcn.scri.fsu.edu Date: Thu, 10 Oct 1996 21:05:55 -0005 Subject: Re: JACK STAND WARNING!!! Author: LLoyd 3030P@vm1.cc.nps.navy.mil at Internet NEVER support a car on 4 jack stands. It isn’t safe. There are all sorts of unsafe ways to support a car. One of the most common is to use cinderblocks, which crumble without warning. However, I would tend to disagree that supporting a car on 4 stands is all that dangerous. As long as the stands are decent quality and they are positioned under the car in such a way that the car cannot slide around on top of the stands, it should be OK. My rule of thumb: regardless of what is supporting the car, before crawling under I always give the car a good shaking – good enough to convince me that it won’t fall down while I’m under there. If I manage to shake it off its supports, I may damage some sheet metal, but I’ll still be around to fix it. Way back before my Jag ownership days, in fact when I was still in grade school, my father became enamored of a professor he studied under while getting a graduate degree. This man changed my father’s outlook on life in general, and I can still remember the day it happened. Some time later, this professor was killed by having a Jaguar fall on him. To this day, it appears to concern my father that I not only own one of these evil cars but that I actually crawl under it from time to time. Kirbert | If anything is to be accomplished, | some rules must be broken. | - Palm’s Postulate Kirbert | If anything is to be accomplished, | some rules must be broken. | - Palm’s Postulate From: Stefan Schulz jaguar@suaviter.demon.co.uk Date: Thu, 10 Oct 1996 22:02:22 GMT Subject: Re: AC Compressors In message 199610101623.AA31124@gcn.scri.fsu.edu “Kirbert” writes: By the way, one fundamental difference: the pressure switch is closed when all is OK and opens when pressure is low, so the clutch is generally grounded through it. The superheat switch that comes on the Jag, however, is open when everything is OK and closes to cause a short and blow the 3-way fuse when temp is too high. Until sometime pre-1988 when the fuse was eliminated and Jaguar started to use a pressure switch as you first describe it. Regards, Stefan Schulz jaguar@suaviter.demon.co.uk From: rpeng@cadev6.intel.com Date: Thu, 10 Oct 96 12:22:01 PDT Subject: Jaguar Special Guys, Check out the latest issue of the British magazine: Thoroughbred and classic Cars. This month they are having a Jaguar special. There’s one article titled “Jaguar” that is very interesting; it takes a rather cynical view of various models as well as the company itself. There’s truth to what it’s saying though. Definitely check it out yourself! Roger Peng (408)765-7863 Intel Corporation Design Technology, Physical CAD From: David Hallam d.hallam@mailbox.uq.edu.au Date: Fri, 11 Oct 1996 11:44:32 -0700 Subject: Re: A question of paint color for restoration Giday All Before we all wax to lucid. Remember an original is an original. Un touched and passed to us through time with minimal degridation. A restored car is just a restored car, nothing more, it is not an original. It may be restored to your interpritation of the orginal specification. But… Original cars are rare… Very rare… But having said that I’d much rather have a car that has been rebuilt to my interpritation of original so I can thrash the pants of it then rebuild it again. /dlh. *** Without Treatment Development our past can only rot **** David Hallam Senior Scientist, Materials Conservation Queensland Museum, PO Box 3300 South Brisbane Qld. 4101 Australia. ************************* Standard Disclaimer;************************* D.Hallam@mailbox.uq.edu.auhttp://www.uq.edu.au/~qmdhalla/** From: rrichardson@eurekanet.com (Robert J. Richardson) Date: Thu, 10 Oct 1996 17:47:01 -0500 Subject: Re: JACK STAND WARNING!!! Having grown up working after school and weekends in a garqage, I have not mentioned this before because I just assumed… NEVER support a car on 4 jack stands. It isn’t safe. They are for supporting either the front OR the back, if you are lifting up only one end of the vehicle . If you are lifting the entire vehicle use jack stands on one end only. Put the other end on blocks or ramps. Personally, when I’m under a car with jack stands, I also have my hydrolic jack supporting a bit of weight between them, just in case. I may be a sissy, but I’ve spent some time trapped under a car when it fell on me. But that’s another story… LLoyd - I prefer Coors - I tend to agree with you. A car on four jack stands, with their narrow basis, would seem to be unstable. A slight shift in weight, say you have someone in the driver’s seat to help you with brake bleeding, could be disastrous. I have the metal ramps and you convinced me to buy just a pair of jack stands. I’m still looking for stands with a max height of 24 inches so I don’t have to wedge my 232 pounds under the rear suspension, etc. From: “Kevin Sisterson” stablemates@msn.com Date: Fri, 11 Oct 96 02:12:44 UT Subject: XJS stalling Well I thought it was vapor lock, so I drove it around for a week with the gas cap loose, ran fine. All of a sudden, still with the gas cap loose, I’m driving along at 65 mph and no power untill I slow down to about 30. I pull off the road, let it sit for a few minutes then it’s fine again. It never happens in the morning, only in the afternoon, who knows maybe just coinsedance. Anybody out there got a clue what the problem is? Kevin From: charles daly cdaly@passport.ca Date: Thu, 10 Oct 1996 22:23:10 -0400 Subject: Re: Serial Number strangeness Hi Tommy, According to the Originality Guide (Haddock) "…from model numbers… 1R.12955 About April 1970, the fan control thermostat was changed. I read this as saying that your car was made before April '70??? Hope I’m right (or wrong!- whichever works 4 u!) Do you have the engine or transmission number? Hope this helps, I have (I think) a 1971 series 2 E-Type that was originally imported to Canada (I think). It was sold and I bought it as a 1971 and I’ve always understood it to be a 1971. It’s a 4.2 litre and has the series 2 body style. I have the car number, body number, gearbox number, and the engine number but the name plate indicating the date of manufacture is missing. The car (vehicle) number is 1R12449 and the body number is 4R6986. Charles Daly, Toronto, Canada '62 E-Type, ots From: “Gregory W. Price” gprice@mack.rt66.com Date: Thu, 10 Oct 1996 20:17:08 +0700 Subject: Re: XJ-S front end rebuild Aaron Burnett aaron.burnett@attws.com: 3.) I plan to use a large C-clamp and socket to press the old bushings out – sound reasonable? I’ve done this type of repair on a '62 Impala, but had a great deal of trouble removing the old bushings. Kirby wrote:
Ditto.
Tried the C-Clamp-and-socket routine on my steering rack bushings and
ruined a good 8" C-Clamp. Finally used the bolt-and-socket gizmo to
get them all out.
Greg.
Date: Thu, 10 Oct 1996 22:34:54 -0400
Subject: Re: Originality or Lump?
Since acquiring my car I’ve been an avid reader;
sometimes contributor to the list.
Now I need help.
For many months we’ve been throwing red, over ripe
tomatoes (originality stickers properly affixed) at the mention
of lump conversions.
I have restored my car to virtually original condition, even to the
absurd (but pretty) glass windshield bottle, original spare tire,
etc. and I drive the car almost every day, often at 100mph+,
because that’s my interpretation of why it was built in the
first place (June 1962).
Now it seems, I’m a sap to do that.
So please explain where, between an orange lump and a glass
windshield bottle I should be.
Tomorrow I shall paint it purple, with orange/red flames on the
bonnet, and a raccoon tail (pink, no doubt) flying from the antenna.
'62 E-Type, ots
Date: Thu, 10 Oct 1996 22:50:56 +0100
Subject: Temporarily unsubscribed + XJ S1 pic !
In case anybody cares I am temporarily unsubscribed
for next week, I have the privilege to visit New York.
In case anybody know of any Jag events there, feel free
to email hints to ‘gunnar@medial.se’.
BTW, I just uploaded a 1982 image of my XJ S1.
http://www.medial.se/xj6.jpg (78 Kbytes)
The car looked terrific at the time after my previous restoration of it,
had new paint and all.=20
My goal is to return it to that shape again before the end of 1997…
It has not been on the road since 1989.
I got inspiration from looking at the XK-8’s last weekend and realized
that ‘Hey, I have one of these animals at home, just a matter of
fixin’ a few things…’
Gunnar Forsgren gunnar@medial.se=20
MEDIAL Maskin & Data http://www.medial.se
=C4ngsvik 2 24 hour phone/fax +46 8 570 25056
S-139 50 V=E4rmd=F6, Sweden XJ6 4.2 S1 '72
Date: Thu, 10 Oct 96 15:01:37 CST
Subject: Re[2]: Seat Mounting Bolts & Nuts - XJ-S
I think you are referring to "speednuts." Typically, they are clips or
just a rectangular piece of stamped sheet metal that accept machine or
sheet metal screws. The clips I've seen in datacom cabinets have a
more meaty nut/thread portion to them and I don't know if these are
also called speednuts.
I would grab hold of a MacMaster-Carr (sp?) catalog. Certainly, they
would have a picture of what's available, if anyone. Not that you've
got my curiosity up, I'll have to look tonite.
Steve K.
______________________________ Reply Separator _________________________________
Author: palmk@gcn.scri.fsu.edu at smtplink-tellabs
Date: 10/10/96 2:39 PM
For those who don’t know clip nuts, I will describe as best I can;
an ASCII pic would never work here. This clip nut is made entirely
of sheet steel – how they form the threads I have NO idea, but it
ends up with about twice as much threading as that crappy rectangular
| - Palm’s Postulate
Date: Thu, 10 Oct 1996 15:49:03 -0400
Subject: Re: Re[2]: Polished E-Type/Beer
Exactly the kind of thing that caused me to raise the issue. I'm pretty well convinced that if you had a time machine and could go bake to the '60s or '70s and grab a brand new E-Type at the factory you wouldn't stand a chance in a concours today. I'm genuinely puzzled by this. How did this come to be? I'd still like to hear from people in the concours business as judges and/or competitors. MikeC
I have seen a few clean original E-types (vs original but well worn) with
original paint interior etc. They were pretty nice. I have yet to see a bad
door gap on an original E, though the doors on XK-120-150s never seem to fit at
the bottom. I think that the factory would do some engine bay polishing at
extra cost, so polished immaculate engines are probably legit. Also, I doubt
that the cars were covered with road dust and tar when they left the factory,
and I’ll bet the cotton wiring harnesses were not covered with greasy finger
smears (like mine are).
It is easy to say that my car is more like original condition because it is
not “perfect”, but really that is a lame excuse for a maingy car, sort of a
automotive sour grapes syndrome - stems from the fact that these ‘perfect’ cars
seem to take away the impact of our ‘driven’ cars.
When I look at new cars on showroom floors, and look under the cars, under
the hoods etc. it makes me think that the “over restored” cars at the concours
may not be so over restored. :-(.
When I can suppress my envy I do like to see perfect Jags. If these people
didn’t do this to their cars it would be hard to imagine how old Jags looked
when they were new. The practicality of maintaining them is another matter, but
hey, it is their car…
A nice patina of age on an unmolested original car is also a gratifying
sight, but one that seems to be getting more rare. Patina usually = rust.
Mark McChesney
Beer? - I've not had a drink since I was 17 - probably a good thing...
End of jag-lovers-digest V2 #424
X-UIDL: 7bdf2486a5c5fcae812e99be95b23ad9
id for jag-lovers-digest-out; Fri, 11 Oct 1996 05:18:32 +0200 (MET DST)
Date: Fri, 11 Oct 1996 05:18:32 +0200 (MET DST)
Message-Id: 199610110318.FAA09001@ekeberg.sn.no
Subject: jag-lovers-digest V2 #425
Precedence: bulk
Status: RO
X-Status:
jag-lovers-digest Friday, 11 October 1996 Volume 02 : Number 425
May I introduce myself and ask a question?
Newbee intro & wannabe S-Type owner
[none]
RE: Re[2]: Leather Interior
Re: Polished E-Type
Date: Thu, 10 Oct 96 12:49:21 PDT
Subject: May I introduce myself and ask a question?
I’m new to Jag-lovers and am just about to become a Jaguar owner. I
just haven’t quite decided exactly what I intend to buy yet but will
almost certainly get something within the next week or so since a
vehicle change is immanent and it will be a Jaguar - if I can find a
suitable vehicle.
By the way, I’m Welsh, living in the Bay Area of California and my
only actual Jaguar experience has been with other folks’ cars - a
friend owned a 1972 XJ6 that I drove a bit and watched him work on and
I rode in a 1975 XJS for a while. I have a deep suspicion of any cars
built under the Leyland auspices, so you can guess what models I’m
not looking for :-).
My original target was an 88, 89 or 90 XJ6 with a slight preference
for a late series III, although the possibility of better reliability
with an XJ40 has been tempting and I wouldn’t turn one down if I came
across a good example.
During my wanderings, I was distracted by a 90 XJS that claimed to be
(I think) a classic (or possibly collectors) edition. It differed
slightly from the usual XJS in that it had a pair of twin headlamps as
opposed to the usual ovoid shape. I’ve never heard of such a model and
haven’t been able to find mention of it anywhere. Can anyone tell me
what this model is? It was attractive enough that car-lust is
threatening to overcome my intention to buy a more reasonable XJ6, so
any comments either for or against such a beast would be helpful.
Finally, given that I’m a novice, would anyone like to influence my
choice of vehicle in a more general way? I’m always happy to listen
to expert advice but I do have my own prejudices :-). I suppose I
should mention that I love looking at Jaguars, delight in driving them
and am never going to work on one - that’s what specialist autoshops
are for - in case that makes a difference to anyone’s recommendations.
I hope such a banal set of questions doesn’t contravene any
conventions on this list. I’d normally lurk for a while before posting
anything but since it seems this is necessary to see if there’s any
information to be gathered before I buy, I’m taking the chance. Any
input gratefully received …
Many thanks,
| Kevin D. Jones |
| Rambus Inc. | Tel: 415 903 4730 |
| 2465 Latham Street | Fax: 415 965 1528 |
| Mountain View CA 94040 | Email: kdj@rambus.com |
Date: Thu, 10 Oct 1996 20:54:10 +0100
Subject: Newbee intro & wannabe S-Type owner
Hi, folks
I’m new to the jag-lovers list and according to the info on the JagWeb
WWW I should introduce myself.
I’m a 1960-model Homo Sapiens, living in Oslo, Norway. Although I start
to feel the age, I’m fairly well maintained I’d say. At least no rust,
guaranteed. Heard that before ? :-).
I have never owned a Jaguar, but I’m quite sure that some day I will.
My first encounter with a Jag that I can recall, was when a friend of
mine had a toy car for Christmas, when I was around 10 years old. The
day
after Christwas eve we used to compare our presents and play with them.
I was very facintated by its very special lines. It had a very long hood
and a small coupe at the very rear. I had never seen a car like that
before, toy or real. There was a rear door that could be opened almost
vertically, and the colour was dark blue.
Thats all I can remeber, and I don’t recall if I was aware at that time
what make it was. Later I learned that it must have been a Jaguar E-type
FHC, probabely series I.
Although I never have forgotten that toy car, I can’t say that since
that day I’ve wanted one. I don’t think my special interest in Jags
started before I was well over 25. It’s hard to tell when, though. It
has sort of sneaked up on me. About 10 years ago I bought a book on
E-types.
Now I’ve got 5 Jag books, plus some books on other cars that I find
interesting, such as the Merceds 300SL, Ferrari 250 GTO, Fiat Dino,
among others.
Jaguars are special to me because of the Lyons design, and they have a
wide range of cars that I find appealing. It probabely also helps that,
contrary to the mentioned Mercedes and Ferrari, they seem to be within
financial range. Someday, somehow.
I would definetly like to own a E-Type or a MkII, but find them quite
expensive, at least here in Norway. I’m quite sceptical about bying a
car from abroad or an imported one. Bying abroad is hard because you
don’t know what you get unless you spend a lot of time and money finding
one and ensuring it’s what it pretends to be. Imported cars have often
undergone bad “restoration”. You know, a lot of filler and then new
paint and leather, and the price is up.
So, lately I’ve been looking at the S-type as a cheaper alternative to
the MkII. I’ve read about the two Alastair’s (do I have to change my
name to own an S-type and their restoration projects. Also, I know
that there’s Egil Kvaleberg, who’s S-Type I’ve seen around Oslo a few
times. I also know that the picture on his WWW-page is the pretty side
of his car :-).
More specifically, last week I looked at a 64 3.8 S-Type Automatic that
looked interesting. Just had time for a quick look. Think I’m going back
too see it again this weekend, for a closer look and take it for a test
drive. With the SOL check-list in my hand, of course.
The car has had �14,000 spent on it in 1992, in England. That’s also the
asking price now. Although a lot has been done to the car, I’m concerned
about the quality of the work. New paint, leather interior and stainless
steel exhaust looked fine, but I haven’t looked closely at the engine or
underneath yet which of course is the importent things. Noticed that the
door fitting was very poor, though.
I would of course be very happy to hear what one should specifically
look for on an S-type. Haven’t read any books on it (is there any ?). I
would guess that much of what applies to the MkII goes for the S-type,
since their quite comparable, exept for the IRS.
That’s it. Nice to be here. Look forward to a lot of interesting info.
Mostly reading for a start, I guess, but maybe someday I know enough
about one particualar Jag (preferably residing in my garage) to answer
some questions.
I’ll hang around.
- -Ragnar
Date: Fri, 11 Oct 1996 05:05:42 +0200
Subject: [none]
From jag-lovers-digest-owner@sn.no Thu Oct 10 21:04:08 1996
Received: from ekeberg.sn.no (126@ekeberg.sn.no [194.143.8.8]) by smtp.internetdesign.com (8.6.10) id VAA12003; Thu, 10 Oct 1996 21:04:06 -0600
Precedence: bulk
RE: xj220
Re: Leather Interior
Re: XK150 colour
Leather Interiors
Re: Front end alignment
Question
| - Palm’s Postulate
or out.
Aaron
'85 XJ-S
Group:
Mike Frank
1969 E-Type 2+2
Why isn’t it safe?
MikeC
MikeC
Subject: A question of paint color for restoration
Date: 10/Oct/1996
Dear Jag Lovers,
Mine is a fairly sinple question. I have begun, at long last, a
more serious effort to restore my 59 XK 150-S. Jaguar Cars confirmed
my suspicion that the original color was Mist Gray with a red interior.
It is now Imperial Maroon over BRG, over Old English White over the
original Mist Gray. The dash and door panels are black dye over red.
Mist Gray/Red is not what I would have picked if I had been
walking around the new car lot. Several years ago at a JANE show I
saw an XK 140 in Old English White with a Fawn interior which was
so lovely even my wife liked it (this is not an insignificant
consideration). What do you think? Should we try to hold true to
the original or create what we would have liked it to be?
Is there a source for paint codes somewhere on the Net? If
George Dodson
Subject: RE: xj220
Lee,
Mike Everatt
1/18 scale XJ220
Subject: Re: xj220
Subject: Re: Leather Interior
I also have brochures where different models of the XJ-6 are clearly
described as having different amounts of leather. For example, the '93
XJ-6 (XJ-40) is described as having leather faced seats while the VDP
version is described as having full leather seat trim, handbrake grip, sun
Cheers,
cobac@ix.netcom.com
unfortunately.
Steve
Subject: Two Birds – One Stone?
Bird 1: Like David Shield I have considered having a t-shirt made saying =
jag-lovers@sn.no to wear for those events when I might meet in person =
someone I have met here. Or maybe a pin or clasp or cap?=20
Bird 2: Beyond the tremendous sharing of talent and time, there are =
monetary expenses associated with jag-lovers that have been borne by =
some of our friends. (Being relatively new to the list I hope I’m right =
about all this?)
Stone: Perhaps some of our more talented friends could create a product =
that would carry the name and be sold at a reasonable profit to help =
support jag-lovers?
As I have said, I am relatively new but I have benefited much and I =
certainly want to contribute to the fiscal health of this activity. If =
cash is a better solution, that’s OK by me. Just thought I would throw =
out this idea.
Hi Guys and Girls,
never mind),
hopefully
also the lumpy bit.
when the
what is “Wrong”
read
well meant manner
allegations towards
balance indeed, but
I blew a fuse…
Jeff
Hi Mike C and list
tag
big time
out out the head.
Jeff
Alex Beacham
missing.
closed!
Jack Bednarski
71 XKE V12
90 XJ6 VDP
95 XJS V12 Conv
I’m not a judge but I do think it a little absurd the lengths to
which concours owners (oops almost said drivers) go to keep their
cars in “like-new” condition. This was proved to me a while ago
when a motoring program discovered an XK120 (or maybe 140) that
had practicaly never been used with something like less than 300
event. Jaguar build quality ensured that the shut lines were uneven,
the underseal was patchy, interior didn’t fit etc. A far cry from the
people who paint the inside of their exhaust pipes to make it appear
“newer”. Poor saps.
over-restoration.
<missing.
LLoyd
Ryan.
driver, honest!)
machines one day…
Gunnar
Subject: Re: Front end alignment
Toe in 1/16 to 1/8
Toe in 0 to 1/8
All this discussion of alignment comes at a very opportune time as our 79
XJ6 is in dire need of adjustment after the replacement of the front
bushings. I was very interested to read that most shops have incorrect
specs for this
work. Could someone please relate the proper settings so I can assure
they do it right.
The car is a 79 1/2 SIII XJ6.
64 XKE Cpe.
79 XJ6
Subject: Question
Date: Thu, 10 Oct 1996 11:47:35 -0700
Subject: RE: Re[2]: Leather Interior
I agree with Mike C. The brochures describe the lower end models of XJ6 as having Leather Seating Surfaces, and the Vanden Plas as having all leather. I know my 1987 Sovereign has vinyl seat sides and backs, and the console trim is vinyl too.
Mike Everatt
1987 1/2 XJ40
Sent: Wednesday, October 09, 1996 6:26 PM
To: palmk@gcn.scri.fsu.edu; Michael Frank
Cc: jag-lovers@sn.no
Subject: Re[2]: Leather Interior
I don’t think there is a simple answer. It seems to vary from year to year
and market to market. Judging from all the photos and descriptions I’ve
seen, the XJ-S generally gained increasing amounts of leather and wood as
the years passed. My '88 brochure describes both the seats and doors as
leather covered. The later 6-cyl XJ-S in the US market probably has less
leather than the V-12, just as it lacks the trip computer and several other
features. On my XJ-S, the instrument panel is black, while on newer XJ-Ss
I’ve seen wood ones (at least on ones with round gauges.)
On my '74 E-Type the only leather is the actual seating surfaces, all the rest of the seats and the entire rest of the interior is one of two types of vinyl. I also have brochures where different models of the XJ-6 are clearly described as having different amounts of leather. For example, the '93 XJ-6 (XJ-40) is described as having leather faced seats while the VDP version is described as having full leather seat trim, handbrake grip, sun visors, console, armrests and map pockets. MikeC ______________________________ Reply Separator _________________________________ Subject: Re: Leather Interior Author: Michael Frank mfrank@westnet.com at Internet Date: 10/9/1996 1:49 PM Kirbert: Every car brochure I have seen in recent years describes leather upholstery as ‘leather seating surfaces’. I have always assumed that this means a combination of cowhide and naugahide. The practice must go back a long way: the seat backs on my '69 E-Type appear to be synthetic. Mike Frank At 12:01 PM 10/9/96 -0005, you wrote:
Chad Bolles:
| - Palm’s Postulate
Date: Thu, 10 Oct 1996 17:33:30 -0500
Subject: Re: Polished E-Type
I don't look down at people who try to maintain a car in perfect "like-new" condition, but I have to admit I don't understand how cars that are chromed and polished way beyond the way they were originally can be judged so highly. Any of you judges? If so, how about a discussion of how things are judged for originality, especially for appearance?
I got certified as a JCNA judge this Summer. First off, JCNA changed the
wording in the judges manual some time back to specify authenticity
rather than originality. This means that parts which are period
authentic are OK, even if not orginal (for example, there were no
outside mirrors on the S1 E-type as shipped to the US, but any mirror
that was typically mounted by dealers at that time is OK, and it can
be in any reasonable location). Chroming something that wasn’t
delivered that way will result in a deduction. Polishing something
that wasn’t polished by the factory, however, is quite acceptable –
it was often done for photo-cars and as dealer preparation, and
is just considered cleaning.
It is true that a car right off the line from Jaguar probably would
not win a concours. Even with their improved quality control, the
cars show up with dirt, excess grease, and imperfections. One judge
tells of somebody who drove a car to an event that was brand new,
and when they opened the spare wheel compartment, they found some
trash that had been left in at some point either at the factory or
at the dealer.
The goal of concours is to encourage the highest quality of care and
preservation of the marque. Cleanliness is the highest priority –
dirt and corrosion anywhere that is judged will get you a deduction.
However, judges are not supposed to look under a car – if you can’t
see something without getting on your knees, you aren’t supposed to judge
it. This means that there have been high-scoring concours cars with
rotted floors, but at the same time it means that you aren’t expected to
polish the muffler. The best E-type in our club’s concours this year
was driven to the event and is driven regularly – it isn’t a trailer
queen, and the current rules make this quite possible, as long as you
spend the time keeping it up (which is precisely the goal). So polishing
the aluminum cam covers is really just a part of cleaning corrosion.
If somebody goes to special lengths to get them to a mirror finish
vs. just nicely polished, it won’t really affect the scoring because
I won’t see the nicely polished ones as requiring a deduction.
After cleanliness comes maintenance. Pretty much everything has to work
(we check lights, wipers, horn). If you can fix it while it is being
judged, we let it go (one guy blew a fuse while we were judging
him, and we let him replace it). That brings up the aspect of judging
that judges can’t touch the car – they can ask the owner to do things
like open and close the doors, boot, etc., and open the spare wheel
compartment,
or unroll the tool kit, as needed to check the car, but nothing that
involves disassembly (such as lifting the carpet). Softops on roadsters
are supposed to be erect, and the judge can ask the owner to put it
up if it’s not already. The other aspects of maintenance are looking for
rust, dents, paint defects, pitting in the chrome, worn plating, cracked
rubber, frayed/torn cloth, cracked/torn/unstitched leather, etc.
Athenticity comes last, but can cost some big points (usually for
repeated minor errors, like having 20 nonauthentic hose clamps). There
are a few biggies like having tires that are the wrong size and type
(i.e. oversize radials when smaller bias-ply were specified). If somebody
has made a lot of improvements to the original design there is a
class for modified cars – e.g. a S1 E with an alternator, S2 brakes,
and Webers would be welcome there. One thing that I would personally
like to see excepted from the authenticity requirement is safety
devices – I think it is a shame to take points off because somebody
put 3-point seatbelts in a car that wasn’t built with them as an option.
Regarding the polished cam covers: Keep in mind that there are two
classes in JCNA concours – Concours and Driven. In driven class,
the bonnet stays closed – it doesn’t matter if you have an engine
bay so clogged with dirt that you can’t find the engine. If you were
able to drive it onto the field and I can’t see dirt pouring out of
the radiator grille, you won’t lose points for it. But the idea of
concours class is that people also want to show off their beautiful
Jaguar power plant, and they are expected to clean every nook and
cranny and polish everything capable of shining – the idea is to
show off how gorgeous the car can look under the bonnet in addition
to the exterior and passenger compartment. Frankly, I think that all
of the covers on the XK-8 are going to make for some really boring
concours judging in a few years. As an aside about the E-type, most
people don’t realise that the majority of the hardware associated
with the triple SU carbs was flash-plated with nickle – it rubs off
with even fairly light polishing – in reality, all that polished
brass is incorrect, but I don’t know anybody who deducts for it.
How does one become a judge? For those who compete in concours, it
should not come as a surprise that JCNA doesn’t technically require
a judge to know anything about the cars, in order to be certified.
The judge’s test is an open-book exam that asks you to cite the
manual with regard to a number of situations. All JCNA really
requires is that judges have read and understand the concours
rules. Having said that however, in order to serve as a judge,
you have to be approved by the judging chair for each concours,
and it is up to that person (and their club) as to how much
knowledge you should have. In our club, we had a series of tech
sessions where the chair went over a bunch of E-types and XKs
pointing out the things we needed to know. As a first time judge,
I was paired with somebody experienced and closely supervised
by the chair. For most judges, becoming knowledgable about the
cars is a point of pride anyway, so it isn’t usually a problem.
I applaud people who are so dedicated that they keep their driven
cars in better than new shape. I wish I had the time to do it too.
But I also applaud people who just take good care of their cars
and bring them to the concours in driven class for the fun of
showing them off. One of our club’s unwritten rules is to not
judge cars too harshly that aren’t highly prepared. If your car
is in decent shape and you clean it up well the day before you show it,
you’ll probably still score in the 90’s – we want concours showing
to be fun for everyone. The more cars on the field, the better the
event.
Chip
End of jag-lovers-digest V2 #425
X-UIDL: b9942c3507917a2e26f23badf838dfa6
id for jag-lovers-digest-out; Fri, 11 Oct 1996 05:37:14 +0200 (MET DST)
Date: Fri, 11 Oct 1996 05:37:14 +0200 (MET DST)
Message-Id: 199610110337.FAA10915@ekeberg.sn.no
Subject: jag-lovers-digest V2 #426
Precedence: bulk
Status: RO
X-Status:
jag-lovers-digest Friday, 11 October 1996 Volume 02 : Number 426
[none]
Re: Re[2]: Seat Mounting Bolts & Nuts - XJ-S
JCNA Judging
Re: jag-lovers-digest V2 #421
Date: Thu, 10 Oct 1996 21:43:11 +0200
Subject: [none]
From jag-lovers-digest-owner@sn.no Thu Oct 10 13:42:19 1996
Received: from ekeberg.sn.no (126@ekeberg.sn.no [194.143.8.8]) by smtp.internetdesign.com (8.6.10) id NAA25924; Thu, 10 Oct 1996 13:42:16 -0600
id for jag-lovers-digest-out; Thu, 10 Oct 1996 18:24:28 +0200 (MET DST)
Date: Thu, 10 Oct 1996 18:24:28 +0200 (MET DST)
Message-Id: 199610101624.SAA02023@ekeberg.sn.no
Reply-To: @owner-jag-lovers-di1
Subject: jag-lovers-digest V2 #421
Precedence: bulk
jag-lovers-digest Thursday, 10 October 1996 Volume 02 : Number 421
Re: AC Compressors
Re: Putting in the crossover pipe (XJS)
Re: Doh! Big mistake in previous message
Re[2]: 62 E, oil pressure too high
Re[2]: Art vs. Cars [was: Polished E-type]
Re: V12 Radiator drains
Jack Stand Prices in Denver Colorado USA
Re: AC Compressors
Floor Jacks
Re: Seat Mounting Bolts & Nuts - XJ-S
Re[2]: A question of paint color for restoration
Date: Thu, 10 Oct 1996 09:32:03 -0400 (EDT)
Greg: Where do you live??? You should have an Autozone, Advance Auto,Pep
Boys or Western Auto in your town. Compressor fits a Chev, you just need
one with the metric bolts in it and superheat. Switch is located in the
rear of the comp, held in with a snap ring. The rebuilt comp that you
will get from one of the stores for around $69-109 with clutch, will have
a plug in the place the superheat switch fits. Most of the cars that I
work on have had the switch bypassed anyway, so I usually leave the plug
in place, but that is up to you.
Chad Bolles Jaguar South 306 Valcour Rd Columbia SC 29212 USA 803 798 3044On
Wed, 9 Oct 1996, Gregory W. Price wrote:
My '85VdP needs an A/C compressor. I have the type with the superheat
switch, which is about 100 bucks more than the compressor without the
superheat switch. What is a superheat switch, and can I either supplant the
one I have, or use the other compressor and ignore the superheat switch?TIA
Greg.
Gregory W. Price & Company, Ltd Business research and information management for those who need it most. 1-800-670-5491
Date: Thu, 10 Oct 1996 09:39:28 -0400 (EDT)
Subject: Re: Putting in the crossover pipe (XJS)
Jim: Why or Why remove the starter, when you can remove the dust shield
for the trans and do the same thing, and the dust shield comes of with no
problem.
Besides if the car has 50,000 plus miles on it the front seal is most
likley leaking or seeping at the very least, and it sure is much easier
to replace it at the same time.
Date: Thu, 10 Oct 1996 08:43:27 -0500 (CDT)
On Wed, 9 Oct 1996, Robert J. Richardson wrote:
Today I decided to arrange to have my front end aligned (1987 XJ6) as
pretty bewildered by this point and did not pursue it further. I guess
I’ll need to take it to the Jag shop, but is this really that
complicated a job? Or are these guys just FOS?Steve Coleman, Gadsden, AL
1987 XJ6 x2
Join my club! I’ve been getting the same resistance here in Athens, Ohio.
These guys are FOS. I wouldn’t trust alignment of a lump to them. If you
want to drive down to Auburn, I’ll introduce you to the guy who–when the
need arises–keeps my SII heading true. He’s not a Jag dealer, and he’s
not limited to foreign cars. He just knows how to align cars.
There is no magic to aligning automobiles, but, to do it right–the only
way an alignment is at all useful–the guy doing it HAS to know the
things that are common and those that are unique to various cars, like
Jaguars’ shims. (Having, and being able and willing to read, some
manuals helps, too.) He also HAS to appreciate careful and accurate work.
Larry Lee
Auburn, Alabama
1979 XJ4.2, SII
Date: Thu, 10 Oct 1996 09:43:31 -0400 (EDT)
Subject: Re: Doh! Big mistake in previous message
Ryan: Scuse me for sticking my nose in here, but if you are working on
the front end of the car why not use the packing spacers that are under
the bottom of the spring to adjust the front end. This is so much easier
than cutting a spring.
Wed, 9 Oct 1996, Ryan Border wrote:
Doh!
Basic math skills fail me…
I wrote:
Say your measured distance between coils is 1.625"
And, suppose you want to lower that corner 0.75".0.75" / (1 compressed coils / 1.625") / 1.9 => 0.641 compressed coils.
Of course this should have read
0.75" * (1 compressed coil / 1.625") / 1.9 => 0.243 compressed coils.
andWhat we want to cut is 0.641 coils, or 0.359 coils short of the mark we
just made. Start at the “1 coil” mark, and go 129 (0.359*360) degrees
towards the tip and that’s your cutting mark.should have been:
What we want to cut is 0.243 coils, or 0.757 coils short of the mark we
just made. Start at the “1 coil” mark, and go 272 (0.757*360) degrees
towards the tip and that’s your cutting mark.Is it Friday yet?
Ryan.
Date: Thu, 10 Oct 96 08:23:51 CST
Subject: Re[2]: 62 E, oil pressure too high
As I told John, but failed to send to the group, I had done basically the same
on a previous E-type, but was able to obtain a Smiths gauge that appeared
identical to the electrical variety. The oil leak is caused by not having the
proper Smiths fittings (I also had the same experience when trying to use
standard US fittings). These gauges are much more reliable (although
non-authentic) than the originals, as they will give an immediate reading.
Steve Kemp
Subject: Re: 62 E, oil pressure too high
Author: Michael Frank mfrank@westnet.com at smtplink-tellabs
Date: 10/9/96 8:43 PM
All:
To those who asked, the PO of my car installed a mechanical oil pressure
guage in the space normally occupied by the electrical guage. The face of
the meter reads ‘Autometer 2421’ that is as much as I know about who made
it. It is exactly the same size as the original, but has a red pointer, so
it is a minor eysore. There is a simple fitting in place of the normal
sending unit, which allows attachment of a capilary tube. The tube enters
the dash thru the same grommet as the choke cable. By the way, a small
amount of oil seeps from this capilary into the interior of the car, making
the Jag experience that much more complete.
Mike Frank
1969 E-Type
At 06:19 PM 10/8/96 -0700, you wrote:
Hi Michael,
I’m curious too about a mechanical oil pressure gauge for
a 62 e-type. Could you email me the details as well?Thanks in advance,
Ken
John:
60 PSI is not dangerously high. My 4.2 E-Type fluctuates between 25-35 PSI
at idle, and 50-65 PSI at speed. The only way you would be blowing smoke at
this pressure is if your head gasket had given way. Things to check:1.What is your RPM at idle? Should be about 600, give or take 100.
Higher speed>higher pressure.
Bypass may be stuck or obstructed.
Oil filer may be clogged.
Bad guage or sensor.
The PO of my car installed a mechanical guage. I will check the make
tonight, and E-mail you.Mike Frank
1969 E-Type 2+2At 08:38 AM 10/8/96 MDT, you wrote:
I have a problem with oil pressure on my 62 E type. Recently, after
l
Is there a mechanical oil pressure gauge available with the correct thread
that I could put in to verify the pressure?
Date: Thu, 10 Oct 96 08:39:37 CST
Subject: Re[2]: Art vs. Cars [was: Polished E-type]
I think owners (or drivers, for that matter) can be separated into those who
collect them for the pleasure of driving them or the pleasure of looking at
them, or both. If it is being viewed as art, you probably would want it to look
at its best. If it is for driving, that’s a different story. And, of course,
there is some middle ground.
The problem I’ve personally had in restoring is trying to decide which of
Jaguars’ manufacturing flaws should be removed and which shouldn’t. Certainly
poor fitting doors are something that can detract from the overall package in
any event. However, you’re right in that they came that way. Conversely, I find
an occasional lead dribble, sloppy weld or stamping flaw perfectly normal.
Like anything, I suppose it’s personal taste and most of us being individuals,
there’s going to be lots of variation.
There’s been talk in concours circles of initializing another class for those
cars, like the XK mentioned below, that restoration would do more damage than
good but can’t compete at the Pebble Beach level. Save the Pebble Beach
restorations for cars that were too shot to be driven or shown in the first
place. Unfortunately, this describes most of the E-types I’ve owned.
Any thoughts?
Steve Kemp
Subject: Re: Polished E-Type [was: Re: XK’s Unlimited open house]
Author: Cosmo simond@inflon.informix.com at smtplink-tellabs
Date: 10/10/96 5:43 AM
“newer”. Poor saps.
Cosmo
83 XJ6 4.2
65 Mustang 289
Date: Thu, 10 Oct 1996 09:52:56 -0400 (EDT)
Subject: Re: V12 Radiator drains
Jim: Why not slip a piece of rubber hose over the drain cock long enough
to drop down past the sub frame.
By the way the General is dead.
"Variety is the Spice of Life, Satisfaction is Death"
Chad Bolles 1958
On Wed, 9 Oct 1996, Jim Isbell wrote:
My 1985 XJS has the clamp in transmission hoses and does have a drain.
However the drain is virtualy worthless since it drains out horizontaly and
onto the front suspension and is virtualy impossible to catch in anything
smaller than a bath tub.I asket the radiator shop that rodded it to solder a small elbo ont ot to
make it drain down but they would not do it for fear that the heat would
dammage the seals in the drain cock.Does anyone have a suggestion to solve the drain mess?
Oh, by the way ( boy, am I going to sneak this one in on them! ). I prefer
the discussion of Beer and Burbon or the Beauty of the SIII/Mark II to the
discussion of the XJ8 since I dont think there is one XJ8 owner on the list
yet and very few with the wherewithall to become XJ8 owners. At least I can
own a can of beer, a bottle of burbon, a series III or a Mark II (I actualy
own 3 out of four). The XJ8 discussion takes up 50% of the more recent
digests while the beer/burbon/series III/MarkII discussion takes up less than 5%JIM I.
“Prefiero morir de pie que vivir de rodillas.”
Gen. Emiliano Zapata 1879-1919
Date: Thu, 10 Oct 96 08:04:00 PDT
Subject: Jack Stand Prices in Denver Colorado USA
I did remember to look at the jack stand prices yesterday while I was at
Checker Auto Parts getting some brake fluid. They had a 2 ton capacity
stand for $10, or a box of 2 4 ton capacity for $20.
They had an El cheapo floor jack (small one ) for about $20 or $30 and some
better ones starting at about $40+ but were out of stock at the store I was
at so I really did not get to look and see how they looked.
Myself I have 4 - 2 ton stands & works great for my 4000+ lbs XJ-S. ( also
have 4 more stands, but they are not a nice )
The 3 ton capacity floor jack I have was about $60.
( all prices quoted are in approximate US dollars )
John Himes
88 XJ-S 98K Miles
Date: Thu, 10 Oct 96 15:26:26 gmt
George Dodson asked re XK150
The question is: How important
is it to put back the original color? I don’t want to insult anyone,
but Mist Gray/Red is not what I would have picked if I had been
consideration).
George, it is your car, you and yor wife know what you like, make it as you
would like and enjoy it.
Alastair Lauener
64 3.4 S-Type
Date: Thu, 10 Oct 1996 09:32:22 -0500 (CDT)
Greg,
Jaguar uses a stock Harrison (GM) A/C compressor that you can find almost
anywhere. The superheat, or “hot gas” switch is a device to protect the
compressor from overheating in certain situations. Many systems either
do not have one, or have had them disabled. While I am not a fan of
disabling devices that protect equipment, this one seldom comes into play
in a properly maintained and charged system (note the last phrase).
In many of the Harrison compressors, the hot gas switch plugs into the
back of the unit, so you may be able to re-use your existing switch if
you wish.
Larry Lee
Date: Thu, 10 Oct 1996 10:46:27 -0400 (EDT)
George:
Ahhh…a philosophical question! It comes down to this: what do you
intend to do with the car? If your intention is show, then originality is
absolutely required, right down to the last nut or bolt.
But given that the car has had four full paint jobs already, it probably
isn’t the best candidate for show, anyhow. If your intention is to use it as
an an occasional car, then I say do your thing, but try to keep it in good
taste. A major consideration is your wife’s approval. Having been thru this
myself, I can tell you that your life will be much happier if you can draw
her into the hobby: a color change is a small price to pay, especially if
you agree on color. Remember that this is YOUR car, not OURS. Even if every
jag-lover on the planet was deeply offended by you plan, so what? But to be
fair to the next owner, keep the best records you can, and be honest about
any changes.
There has been quite a bit of discussion about paint colors on the list. I
don’t think anyone has come up with a good source for this info.
Michael Frank
1969 E-Type 2+2 (Signal Red courtesy of PO, formerly Regency Red)
At 09:12 AM 10/10/96 -0400, you wrote:
Date: 10/Oct/1996
Subj: A quesion of paint color for restorationDear Jag Lovers,
The seats are black snd not original. The question is: How important
not does someone have a file that they could e-mail me?George Dodson Dodson@Bates.MIT.Edu
Date: Thu, 10 Oct 1996 09:07:02 +0700
Subject: Floor Jacks
Sears has (at least my Sears in Santa Fe, NM) a large, shop-style
3-ton floor jack on sale for $79.00. Naturally, it went on sale
after I bought my “home mechanic” style 3-ton floor jack at Checker
Auto. I would of course preferred the larger, sturdier Sears jack,
but poor timing being the perpetual curse to my life…
Greg Price
Date: Thu, 10 Oct 96 08:15:55 PDT
Subject: JACK STAND WARNING!!!
Date: Thu, 10 Oct 1996 11:40:14 -0400 (EDT)
You should have told them your Jag had a Chevy motor in it. They’d have
done the alignment straight away.
John
From: mfl%kheops.cray.com@vm1.cc.nps.navy.mil (Matthias FOUQUET-LAPAR)
Date: Thu, 10 Oct 1996 08:02:02 +0200 (MET DST)
But easiest of all;
needed, its not easy and means you have to remove the starter which adds
more work. “The starter you say?”, yes, the starter so that you can jamb
the flywheel to remove/replace the crank nut which is at 150 ft pounds.
<You don’t need to remove the starter to jam the flywheel. Once you have remove
<the upper part of the pully (the one which drives 3 belts), you can easily
<use it’s 2 screws to attach a home-made bar on the damper.
I just put her in 4th, and set the emergency brake.
Date: Thu, 10 Oct 1996 12:01:57 -0400 (EDT)
Subject: Re: Seat Mounting Bolts & Nuts - XJ-S
nut had. One end of the sheet metal is folded over to form a clip;
Your description sounds like the thingies (are they called Tinnermans
orsomething like that?) that are used to secure electronic equipment in
racks. Some of these have a captive nut attached and some are one piece.
John
Date: Thu, 10 Oct 96 11:09:01 CST
Subject: Re[2]: A question of paint color for restoration
GEORGE,
As Michael said it is YOUR jaguar do as you please. I painted my '64 a
carmen red with a black interior, the original color was a light
metallic blue. I did stay with a jag color for that year.
Visit your friendly auto paint store and most often they will have a
book on the color samples plus the formula’s. The smallest mix I can get
is a pint container which can be used to see if you like the color. I
removed EVERY inch of the blue before I started my quest. Good luck .
Date: Thu, 10 Oct 1996 12:24:01 -0005
Isbell:
Sure. Take a piece of thin-wall rubber hose and fasten it to the end
of the valve. The valve, a paragon of British design, doesn’t even
provide a suitable place to attach a hose, but it does have a little
lip to it. Once you get a piece of hose over it, you can wrap some
steel wire around it and twist it tight. The wire will pull the
flexible hose down behind that lip so it won’t fall off. Then, with
about 6" of hose, you can aim that drain in any direction you want.
– Kirbert | If anything is to be accomplished,
| - Palm’s Postulate
End of jag-lovers-digest V2 #421
Date: Thu, 10 Oct 1996 20:26:12 -0700
Subject: Re: Re[2]: Seat Mounting Bolts & Nuts - XJ-S
Whatever nuts you end up using to replace the oem stuff just make sure that
they are as strong as the originals. If the seat breaks loose when some
idiot rear-ends you the odds are slamming yourself up against the rear
window are pretty great. VW bugs are famous for this because of their weak
seat tracks. People have been ejected out the rear window and run over by
the car that rear-ended them.
At 03:01 PM 10/10/96 CST, Steve_Kemp_at_NBD@pcmail.tellabs.com wrote:
I think you are referring to "speednuts." Typically, they are clips or just a rectangular piece of stamped sheet metal that accept machine or sheet metal screws. The clips I've seen in datacom cabinets have a more meaty nut/thread portion to them and I don't know if these are also called speednuts. I would grab hold of a MacMaster-Carr (sp?) catalog. Certainly, they would have a picture of what's available, if anyone. Not that you've got my curiosity up, I'll have to look tonite.
Date: Thu, 10 Oct 1996 18:05:00 -0400
Subject: JCNA Judging
Mike said:
Exactly the kind of thing that caused me to raise the issue. I’m
wouldn’t stand a chance in a concours today. I’m genuinely puzzled by
this. How did this come to be? I’d still like to hear from people in
the concours business as judges and/or competitors.MikeC
Okay, I’ll bite :-). I’m the Chief Judge for our local JCNA Jag club…
having said that I too struggle with the original vs over-restored car.
I like to think that I instill in the other judges that we are looking
for “authenticity” not perfection. A 100.00 pt. car should be one that
is as it should have left the factory, with no defects that would have
been noticed by the those on the factory floor…if they had had the
time to actually go over every car inch-by-inch (cm-by-cm). A car that
has the heater box so shiny you can see yourself in it is, IMHO, a bit
too far in the perfection direction, but it should not score anymore
points than one which is original and has no signs of rust or wear.
If you know the car is essentially “original”, then you are only
judging the wear and cleanliness of items in the car.
Remember, the intent of the Concours was/is to have very good examples of
these cars, that we so love, around so that others can enjoy them, and
we can use them as references in “restoring” other cars. If we do not
keep track of what “authentic” is for a particular car, then we loose
all sight of what it is we are really trying to achieve.
Each car is an individual, and as such is unique. No one can know for
sure what it is suppose to have, or not have, but we do have a pretty
good idea what the “average” car had. These “rules” for authenticity
then are better used a guidelines, not hard and fast rules…sort
of like Kirby’s signature. “Lofty” England often stated that if
a non-important part was out of stock when a car was built, then that car
did not get that part, or got a substitute part. Does that mean the
car is now non-original according to the JCNA rules? Yes, unless the owner
can prove the difference. Does it mean the car is non-original according
to how it left the factory, absolutely not! It is the second condition
which I think is the more important of the two. That makes the judging more
subjective, and also forces the judges to find out more about each individual
car, and the owners, to find out the history, and/or if they are trying to
get one by you. It is this interaction and history which attracts me
to judging, not telling someone that they missed a spot, or have the wrong
type of hose clamp on the gas line under the vacuum reservior, although I
do check that as well :-).
These cars were made to be driven, not trailered, although I have to admit
that some examples are truely very nice to look at, and keeping them in that
condition while driving them would be a lot of work. Some people are able to
do this, others are not. Some people are in the show for the trophies, others
are there to show off what wonderful works of art they have, and others are
there to help keep these cars from disappearing. Actually, I guess all are
there because they want to keep these car from disappearing, but in their own way.
I just hope that I can help keep the “authentic” cars around, and let others
know which cars these are. That is not to say I cannot appreciate a “non-original”
car. Far from it. That Series I/III E-type that Jay Leno bought from XKU is
a stunning car…just not factory original. I am also looking forward to
meeting Ryan Border and his modified Mk I. It is also not original, and
would not score well in a JCNA Concours, but it is still a beautiful car,
with that certain “Jaguarness” we all appreciate and understand.
Well, I’ve rambled on too much now. Better get that flame suit dusted off
Regards, Mark Roberts Phone: (613) 763-2924
Ottawa, Ontario, CANADA Fax: (613) 763-3970
1988 VDP - SIII V12 email: markdr@nortel.ca
1963 3.8L E-Type Coupe - 16 years into a 3 year project
Date: Thu, 10 Oct 1996 15:06:13 -0500
Subject: Re: jag-lovers-digest V2 #421
Please delete my name from your list-Thank you-Robert.Mann@imsday.com
To: jag-lovers-digest@sn.no
Date: Thursday, October 10, 1996 11:24 AMjag-lovers-digest Thursday, 10 October 1996 Volume 02 : Number
421Re: AC Compressors
Re: AC Compressors
Floor Jacks
Subject: Re: AC CompressorsGreg: Where do you live??? You should have an Autozone, Advance Auto,Pep
3044On
Wed, 9 Oct 1996, Gregory W. Price wrote:My '85VdP needs an A/C compressor. I have the type with the superheat
supplant the
switch?TIA
Greg.
Subject: Re: Putting in the crossover pipe (XJS)Jim: Why or Why remove the starter, when you can remove the dust shield
problem.
3044
Subject: Re: Front end alignmentOn Wed, 9 Oct 1996, Robert J. Richardson wrote:
guess
1987 XJ6 x2Join my club! I’ve been getting the same resistance here in Athens,
Ohio.These guys are FOS. I wouldn’t trust alignment of a lump to them. If
you
not limited to foreign cars. He just knows how to align cars.There is no magic to aligning automobiles, but, to do it right–the only
work.Larry Lee
Auburn, Alabama
1979 XJ4.2, SII
Subject: Re: Doh! Big mistake in previous messageRyan: Scuse me for sticking my nose in here, but if you are working on
3044On
Wed, 9 Oct 1996, Ryan Border wrote:Doh!
coils.Of course this should have read
coils.
we
degrees
we
degrees
Ryan.
Subject: Re[2]: 62 E, oil pressure too highAs I told John, but failed to send to the group, I had done basically the
same
the
reading.Steve Kemp
Date: 10/9/96 8:43 PMAll:
so
making
the Jag experience that much more complete.Mike Frank
1969 E-TypeAt 06:19 PM 10/8/96 -0700, you wrote:
Hi Michael,
Ken
John:
25-35 PSI
smoke at
l
thread
Subject: Re[2]: Art vs. Cars [was: Polished E-type]I think owners (or drivers, for that matter) can be separated into those
who
at
to look
course,
there is some middle ground.The problem I’ve personally had in restoring is trying to decide which of
Certainly
package in
I find
normal.Like anything, I suppose it’s personal taste and most of us being
individuals,
there’s going to be lots of variation.There’s been talk in concours circles of initializing another class for
those
than
first
place. Unfortunately, this describes most of the E-types I’ve owned.Any thoughts?
Steve Kemp
cars
originally
are
miles on the clock and stored since being purchased.It was entirely as-new but would never had won a bean at a concours
“newer”. Poor saps.Cosmo
83 XJ6 4.2
65 Mustang 289
Subject: Re: V12 Radiator drainsJim: Why not slip a piece of rubber hose over the drain cock long enough
3044"Variety is the Spice of Life, Satisfaction is Death" Chad Bolles 1958
and
anything
to
would
prefer
the
list
I can
actualy
less than 5%
JIM I.
Gen. Emiliano
Zapata
1879-1919
Subject: Jack Stand Prices in Denver Colorado USAI did remember to look at the jack stand prices yesterday while I was at
stand for $10, or a box of 2 4 ton capacity for $20.They had an El cheapo floor jack (small one ) for about $20 or $30 and
some
was
at so I really did not get to look and see how they looked.Myself I have 4 - 2 ton stands & works great for my 4000+ lbs XJ-S. (
also
have 4 more stands, but they are not a nice )The 3 ton capacity floor jack I have was about $60.
( all prices quoted are in approximate US dollars )John Himes
88 XJ-S 98K Miles
Subject: A question of paint color for restorationGeorge Dodson asked re XK150
consideration).George, it is your car, you and yor wife know what you like, make it as
you
would like and enjoy it.Alastair Lauener
64 3.4 S-Type
supplant the
switch?Greg,
you wish.Larry Lee
Subject: Re: A question of paint color for restorationGeorge:
absolutely required, right down to the last nut or bolt.But given that the car has had four full paint jobs already, it probably
as
good
this
draw
every
be
about
any changes.There has been quite a bit of discussion about paint colors on the list.
I
don’t think anyone has come up with a good source for this info.Michael Frank
1969 E-Type 2+2 (Signal Red courtesy of PO, formerly Regency Red)At 09:12 AM 10/10/96 -0400, you wrote:
Date: 10/Oct/1996
Subject: Floor JacksSears has (at least my Sears in Santa Fe, NM) a large, shop-style
but poor timing being the perpetual curse to my life…Greg Price
Subject: JACK STAND WARNING!!!Having grown up working after school and weekends in a garqage, I have
not
supporting
vehicle
Put
hydrolic
sissy,
complicated a job? Or are these guys just FOS?You should have told them your Jag had a Chevy motor in it. They’d have
done the alignment straight away.John
Subject: Re: Putting in the crossover pipe (XJS)But easiest of all;
adds
jamb
remove
easily
<use it’s 2 screws to attach a home-made bar on the damper.I just put her in 4th, and set the emergency brake.
Subject: Re: Seat Mounting Bolts & Nuts - XJ-SOn Thu, 10 Oct 1996, Kirbert wrote:
nut had. One end of the sheet metal is folded over to form a clip;Your description sounds like the thingies (are they called Tinnermans
racks. Some of these have a captive nut attached and some are one piece.John
Subject: Re[2]: A question of paint color for restorationsaw an XK 140 in Old English White with a Fawn interior which was
GEORGE,
get
Subject: Re: V12 Radiator drainsIsbell:
and
anything
to
would
about 6" of hose, you can aim that drain in any direction you want.– Kirbert | If anything is to be accomplished,
| - Palm’s Postulate
End of jag-lovers-digest V2 #426
X-UIDL: 3a3a6df3554665c41e1eeb6b1071549d
Return-Path: @owner-jag-lovers-di1
Received: (from majordom@localhost) by ekeberg.sn.no (8.7.5/8.7.3/on4)
id for jag-lovers-digest-out; Fri, 11 Oct 1996 06:02:48 +0200 (MET DST)
Date: Fri, 11 Oct 1996 06:02:48 +0200 (MET DST)
Message-Id: 199610110402.GAA13415@ekeberg.sn.no
X-Authentication-Warning: ekeberg.sn.no: majordom set sender to owner-jag-lovers-digest using -f
Subject: jag-lovers-digest V2 #427
Reply-To: jag-lovers@sn.no
Errors-To: @owner-jag-lovers-di1
Precedence: bulk
Status: RO
X-Status:
X-Newsgroups: mail.jag-lovers-digest
jag-lovers-digest Friday, 11 October 1996 Volume 02 : Number 427
XJ40 - Oil Change
[none]
Date: Thu, 10 Oct 1996 23:50:38 -0400
Subject: XJ40 - Oil Change
Brian,
Problems with the Sov. so far have been a front offside wheel bearing
and stub axle replacement and a leaking cap on the power steering
bottle. Apart from this the car runs like a dream.
When I got my '93 a year ago and laid out the maintenance requirements, I
found that Jaguar calls for no front wheel bearing repacking. I did it
anyway, and found that, at 41,000 they were “ready.” I later mentioned this
to a Jag mechanic and he replied: “You should see the pile of spindles and
bearings I’ve replaced.” My personal schedule is 30,000 miles.
It is my intention to replace the engine oil and filter this weekend,
my question is should I use a synthetic oil (Mobil One @ �24.99 a can)
or a normal one such as Castrol GTX/Duckhams etc. and change this on
a more frequent basis.
Depends on how much you love the car. I have Mobil #1 (15W/50) in mine. My
quandry is that this car uses about a quart per 1,200 miles, making it more
costly than I’d like. My record with synthetics is extensive, and I have
been collecting technical data on it for years. Three stories. First,
Porsche recommends it with a 15,000 mile change. One of the local
enthusiasts called the factory because he thought the drain interval too
long. The factory said: “Perhaps your oils are not as good as our’s!”
Second, the car the Jag replaced was a 1981 Oldsmobile. I changed oil
annually. When I gave it to a neice last year (14 years old) it had never
needed a drop of oil between changes. Third, I switched to synthetic in my
1985 Chevy Suburban upon completion of the break-in. At 140,000 miles, I
replaced the engine with a 350 HP engine in order to outrun the 18 wheelers
when pulling our Airstream trailer. We pulled the heads to examine the
internal condition and found NO cylinder wear. Convinced?
Ron Miller - Seattle, WA, US
1993 XJ-40
Date: Thu, 10 Oct 1996 23:43:39 +0200
Subject: [none]
From jag-lovers-digest-owner@sn.no Thu Oct 10 15:41:55 1996
Received: from ekeberg.sn.no (126@ekeberg.sn.no [194.143.8.8]) by smtp.internetdesign.com (8.6.10) id PAA03778; Thu, 10 Oct 1996 15:41:52 -0600
id for jag-lovers-digest-out; Thu, 10 Oct 1996 19:17:51 +0200 (MET DST)
Date: Thu, 10 Oct 1996 19:17:51 +0200 (MET DST)
Message-Id: 199610101717.TAA14337@ekeberg.sn.no
Subject: jag-lovers-digest V2 #422
Precedence: bulk
jag-lovers-digest Thursday, 10 October 1996 Volume 02 : Number 422
Re: AC Compressors
[none]
Re[2]: Putting in the crossover pipe (XJS)
Leather and Wood
Re[2]: Polished E-Type [was: Re: XK’s Unlimited open house]
Chad Bolles:
You don’t need the metric bolts. SAE bolts will work fine, unless
you’re anal enough that you need to use the original bolts!
Actually, it’s not up to you; the superheat switch will not fit in a
compressor that was not made to have one, and most are made for a
pressure switch these days. Best bet: just plan on abandoning the
superheat switch and the 3-way fuse.
By the way, one fundamental difference: the pressure switch is
closed when all is OK and opens when pressure is low, so the clutch
is generally grounded through it. The superheat switch that comes
on the Jag, however, is open when everything is OK and closes to
cause a short and blow the 3-way fuse when temp is too high. So,
the wiring to the clutch goes through the fuse, and a third wire
goes to the superheat switch which must NOT be grounded in order for
the system to work.
| some rules must be broken.
| - Palm’s Postulate
Date: Thu, 10 Oct 96 09:17:06 PDT
Subject: Serial Number strangeness
With the help of several Jag Lovers, much head scratching, searching, ques-
tioning, and an appropriate amount of nose picking, I have come up with the
following ‘strangities’ associated with the serial numbers on my Jag. For
anyone wondering about their numbers, this may be of help, or at least, in-
terest. My car was made in 8-1970, one of the last series II “E” types to
roll off the assembly line, and a US import.
My original question had to do with distinguishing between the body number
and the vehicle ID number. Fortunately, I kept a copy of the previous title, an
d when I got my Calif. title, they mistakenly used my body number instead of
the vehicle ID number on the title. I also have an original listing of
serial numbers that came with the car when it was new.
The vehicle ID number is stamped on a piece of aluminum on the left side ‘A’
post. Body numbers are on the box frame, left door sill and under the trunk lid
on the body.
Date Of Manufacture 8-1970 (last one made in 10-1970)
Vehicle ID 2R13939
Body Number P2R13939 (same-same with leading P)
Engine NO. 7Rnnnnn-9 (n is a number, -9 is 9:1 compression, -8 would be 8:1)
Tranny No. KEnnnnn
The body number vs. ID number had me confused for a while, but thanks to one
of the list members (can’t remember who right now) I verified this.
LLoyd -no beer content, no prettiest content -
Date: Thu, 10 Oct 1996 19:04:57 +0200
Subject: [none]
From jag-lovers-digest-owner@sn.no Thu Oct 10 11:03:17 1996
Received: from ekeberg.sn.no (126@ekeberg.sn.no [194.143.8.8]) by smtp.internetdesign.com (8.6.10) id LAA08027; Thu, 10 Oct 1996 11:03:14 -0600
id for jag-lovers-digest-out; Thu, 10 Oct 1996 15:31:26 +0200 (MET DST)
Date: Thu, 10 Oct 1996 15:31:26 +0200 (MET DST)
Message-Id: 199610101331.PAA22999@ekeberg.sn.no
Subject: jag-lovers-digest V2 #420
Precedence: bulk
jag-lovers-digest Thursday, 10 October 1996 Volume 02 : Number 420
XK8 on Speed Vision
Re: H&E Convertible Fuel System
XK8 Prices and Aust. car costs (little jag content)
Re: XJ6 series III headlight loss
(Fwd) I spit PATOO!
XJ-S Seat Mount Bolts
Re[3]: Leather Interior
Front end alignment
Re: Re[2]: V12 Radiator drains
Date: Wed, 09 Oct 1996 20:36:57 -0400
Subject: XK8 on Speed Vision
Jaguar bought a lengthy spot on speedvision net work,I scrambled for a
tape and caught about %70 of it . It’s a very well done comercial
showing all aspects of the production and driving of the XK8. It’s in a
lexus style format lots of sureal type shots extremly well done with
interviews from factory employees that build the XK8. About 10 mins in
length?? Hope this airs on more common networkss for all to enjoy.
Frank P.
Date: Wed, 9 Oct 1996 20:26:32 -0500
This is a Mime message, which your current mail reader
may not understand. Parts of the message will appear as
text. To process the remainder, you will need to use a Mime
compatible mail reader. Contact your vendor for details.
- –IMA.Boundary.147709448
Content-Type: text/plain; charset=US-ASCII
Content-Transfer-Encoding: 7bit
Content-Description: cc:Mail note part
Chad Bolles:
Yes the entire interior should be leather.
Actually, I’m not sure ANY of them are entirely leather. On mine,
many of the parts of the seat that don’t touch occupants are vinyl.
It’s my understanding that most – if not all – of the cars are this
way.– Kirbert | If anything is to be accomplished,
| - Palm’s Postulate
- –IMA.Boundary.147709448–
Date: Wed, 9 Oct 1996 20:43:50 -0500
Subject: Re: H&E Convertible Fuel System
I can, and will, write you a description of the H&E fuel system. That
particular Rube Goldberg system is one of the biggest differences between an H&E
and a “normal” XJ-S.
I pretty much figured out for myself how it all worked, but thanks to Julian
Mullaney (whose beloved H&E was flattened by a tree during Hurricane Fran) I now
have an H&E manual to refer to.
I’ll send you a detailed write-up in a few days.
MikeC
Subject: H&E Convertible Fuel System
Author: palmk@gcn.scri.fsu.edu at Internet
Date: 10/9/1996 2:23 PM
Since my XJ-S help book is finally getting around, I occasionally get
phone calls from people wanting help getting their car fixed. Given
how much I have learned about the cars over the years, it is simply
amazing how rarely I can actually help them!
I got a call a while ago from Marv Schindler in Marathon, Florida,
which is half way down the keys. Marv owns a Hess & Eisenhart
convertible, and is having trouble with the fuel system – and I know
nothing about the H&E fuel system.
He can only put about 12 gallons in it, even though it’s supposed to
take 24. He says the car has two tanks, one just forward of the
spare tire and under where the convertible top stores, and another
under the shelf behind the front seats. Each tank has its own fuel
pump; there’s one in the trunk that looks like the standard Lucas
pump, but the forward tank has a pump inside it. There are also two
fuel gauge sending units, one per tank, but only one gauge on the
dash.
While I pointed out that dual tanks are nothing new for Jaguar
(although it is different for an XJ-S), this system has no changeover
switch. Apparently it does whatever changeover it does
automatically. No clue as to how it works. Supposedly it was an H&E
invention.
He also reported that H&E convertibles have apparently had some fuel
tank explosions followed by lawsuits against H&E. If you call H&E,
which is apparently some sort of chassis manufacturer, you can’t
find anyone who claims to know anything about the Jaguar
convertible. Only makes finding info harder.
If anyone can provide some factual info on this system, I’d be happy
to include it in my book – or maybe just a reference to the source,
so that H&E owners can find it for themselves.
| - Palm’s Postulate
Date: Wed, 09 Oct 1996 22:04:18 EDT
Subject: XK8 Prices and Aust. car costs (little jag content)
Mike cogswell said, with regard to a thread on Aussie car prices
Geez, don’t you guys get to vote? Is this a byproduct of a plan to
massively discourage the use of luxury cars?
Yeah, we get to vote, but the only people (? thats probably being generou
calling them people) we get to vote for are politicians…
Yes it is an indirect attempt to discourage the use of luxury cars -
high income earners are taxed (both directly and indirectly) quite
punitively. Any vehicle costing more than $50000 AUD ($40,000 USD)
attracts a luxury car tax, and considering we have a tariff on all
incomingcars (I think it’s 20%) plus shipping costs from Europe whence
most luxury cars come are a fair bit to here, it doesn’t take much of a
car to have a landed cost greater than $40,000 US.
What is the price of
something a bit more basic, like a Honda Accord for example. When I
visited Austrailia recently I saw a TV ad for an Accord at something lik
AU$ 36,000. It appeared to be the equivavlent of my wife’s new accord,
which cost just under US$ 20,000.
OK lets compare apples with apples, $36000 AUD is roughly $29000 USD.
Take $20000 USD add 20% tariff ($4000) add shipping costs - your Honda is
made in the US isn’t it? - don’t know what it costs but say a $1000, the
difference is about $4000 US - that difference is probably a combination
of less economies of scale of purchase and dealership in Australia, the
population is a 10th of the US- therefore less cars sold. A less heavily
taxed business environment - dealer gross margins don’t have to be as
high to get the same net margin, POSSIBLY more ridiculous design
regulations (not sure on this one) - anything that our design rules
specify has to be in a car that no other country does will cost more per
unit to implement. (and prob half a doz. other things I haven’t thought
of)
I’ll have to do a bit of research and then I can put
up a number that represents earnings before any taxes required to buy an
XK-8. (And then I can translate that into Big Macs )
Good idea - then you could do a realistic “real world” comparison. The
concepts underpinning purchasing power parity have caused arguments in
economics for years, the basic principle’s OK but there’s so many if’s
and’s and but’s associated with actually making a valid comparison. The
big mac comparison for example is really only rule of thumb stuff because
there’s factors which mean that unless you’re using the big mac index to
compare the burger king prices (idea identical good) it’s not valid. For
example of one reason it’s often not very useful - in Japan due to heavy
protectionism of their agricultural sector mean the price of a “bigmaku”
is about 3 times what it would be if it was a sushi burger, i.e non-beef.
John
Level 1, 29-57 Christie St.
St Leonards NSW 2065
Ph: +61-2-9937-8063 Fax: +61-2-9937-8100
Mobile +61-419-617-619
Date: Wed, 09 Oct 1996 22:06:02 -0500
Subject: Re: XJ6 series III headlight loss
Bruce Sawyer wrote:
This evening on the way home from work I tried to switch on the high beams.
However, all I managed to do was turn off all the head lights. By keeping
pressure on the switch the high beams work. But let go and only the
parking lights remain. Any ideas of where to start? Thanks for any help
you can provide.
This problem can be caused by the headlamp relay or the headlamp
switch. The relay can be serviced, although best to replace. Opening
the relay cover and lubricating the ratchet mechanism has worked well
for me. The headlamp switch is usually a dirty contact; again, best
solution is to replace.
Hope this helps,
Bob Johnson
Brattleboro, Vt.
XJ50, XJS, XJ12L
Date: Wed, 9 Oct 1996 22:24:07 -0500
about all this?)
support jag-lovers?
out this idea.
Date: Wed, 9 Oct 1996 15:40:07 -0005
Subject: (Fwd) I spit PATOO!
The following is the opinion of a non-jag-lover when discussing
Jaguar’s decision not to offer a manual transmission. I think it is
illuminating. BTW, the car he refers to is an early 70’s Dodge
Charger 440 Magnum with the infamous Mopar automatic transmission –
special ordered from the factory, purple with white top and white
interior.
- ------- Forwarded Message Follows -------
To: slowness@bcfreenet.seflin.lib.fl.us
Date: 9 Oct 1996 11:34:58 CST
Subject: I spit PATOO!
K>From the guy who removed the GM400 from his Jaguar to bolt in the
5-speed, I must say minds are closed here! I hate automatics, but
even I am willing to keep an open mind until I drive the new XK8; all
reports are that the tranny is truly excellent, totally unlike the
crap the GM400 is. And since it can be shifted manually when desired,
what more could you want? The Jaguar engineers point out that it will
shift FASTER than anyone can possibly move a shifter, so couldn’t it
actually be a good thing?
From one who also owns a car with a “state-of-the-art” automatic when
it was built 25 years ago, which was touted as able to be shifted
manually when desired, and which was demonstrably superior to stick
shifts at the time in speed of shifts and getting power to the ground
(all drag cars had the auto, considerably quicker than the 4-speed), I
would say “blaaaaaugh!” to all the above. If the car is to be used as
a dragster, perhaps a good auto as an option would be nice. As a
sports car, speed of shifting is secondary to positive control, which
necessitates a CLUTCH. Many manufacturers have made all those same
claims, IOW, I’ll believe it when I see it. Meanwhile, not even having
an option of a stick in a “sports car” is unforgivable.
MW
| - Palm’s Postulate
Date: Thu, 10 Oct 1996 01:20:08 -0005
Subject: Seat Mounting Bolts & Nuts - XJ-S
We had just recently been talking about the pleasure of working with
the seat mounting bolts and nuts on the XJ-S – notably, how much
enjoyment is derived trying to hold those rectangular nuts in place
while you get the bolts started. I suggested perhaps some clip nuts
might be found to replace the rectangular nuts that would hold
themselves in place.
So, tonight, while working on something else in the interior, I
happened to notice that my passenger’s seat needed some attention –
and that it would have to come out.
Since there’s no hurry, I decided I would try to find some suitable
clip nuts myself and have them on hand when I worked on the seat. Of
course, to do that I really need to know such pesky details as the
size of the bolt, some dimensional stuff about where the clip nut
would clip, etc. So I decided to go ahead and pull one of the front
corner bolts temporarily so I could get some measurements.
With the bolt in hand, I went to my collection of bolts to compare
the size. It is a 5/16" fine thread, so as I mentioned before I
doubt if I’ll find any clip nuts in fine thread, and plan to look for
coarse thread clip nuts and some new bolts to fit them.
Anyhow, while looking through my junk, I found a clip nut – it
looked right, too. I also picked up a 1" long 5/16" NC Allen head
bolt, and went back to the car to trial fit the combo. I expected
the clip nut would be close, but since the Allen head is considerably
taller than the original bolt head, I figured it would foul the
sliding seat rail. At least I could see how badly it fouled the seat
rail, and purchase new bolts accordingly, hopefully without having to
grind any heads for clearance.
So I slide the clip nut into place, and it fits PERFECTLY. I then
install the Allen head bolt (requires a 1/4" Allen wrench) and it
fits perfectly too! I looked down the rail, and there is plenty of
clearance for the taller head, even with the original lock washer
under it. In fact, the whole thing went together so
perfectly that I REALLY didn’t wanna take it back out, even though I
knew I would need the parts in hand to buy another 7 of each.
For those who don’t know clip nuts, I will describe as best I can;
an ASCII pic would never work here. This clip nut is made entirely
of sheet steel – how they form the threads I have NO idea, but it
ends up with about twice as much threading as that crappy rectangular
sometimes it’s just a short clip, but this one goes all the way back
over the threaded hole, with another hole for the bolt to pass
through. The distance from the threaded hole to the fold is
important; if it’s too short, the clip won’t go on far enough for the
holes to line up, and too long and it leaves the fold sticking out
the front of the seat mount and grabbing ladies’ stockings. Like I
said, this clip nut was perfect, and the distance from the center of
the threaded hole to the fold is 5/8".
Some clip nuts are designed to clip onto thin sheet metal and some
are designed to clip to thicker stuff. This one could probably
handle up to 1/8", so it clips onto the seat mount easily.
Also note that since the clip part of the clip nut ends up on top of
the seat mount, the bottom seat rail will actually be sitting on it
- – or at least the washer under the seat rail will be sitting on it.
This is no problem, and is the way clip nuts are supposed to work.
Anybody planning to pull their seats out, I highly suggest you get a
set of these clip nuts and Allen head bolts before starting. It’ll
make reinstallation SO much easier.
Meanwhile, if I get a part number or other better description while
I’m at the hardware store getting 7 more, I’ll post it.
| - Palm’s Postulate
Date: Wed, 9 Oct 1996 15:40:08 -0005
Subject: XJ-S Seat Mount Bolts
difficult to get the Phillips screwdriver directly on the screws at
the back of the seat.
Stefan Schulz:
They’re TORX in mine.
That is, IMHO, a significant improvement. In fact, I’ve been
thinking about getting some TORX or Allen screws to replace the
Phillips with, probably will the next time I’ve gotta fiddle with the
seat.
D’ya suppose finding just the right type of clip nut would help?
Pass. The only clip nuts I know are ones that fit into 19" electronics
racks, and they need a square cutout to fit.
No no no – drop into a Lowe’s or any good auto parts or hardware
store and you can find dozens of clip nuts, the type that fit around
the edge of a piece of sheet metal. Most of the smaller ones just
have a stamped hole to thread a sheet metal screw into, but nowadays
there are larger ones that actually have serious formed threads in
them. Seems to me that perhaps a suitable shaped one might be found
that would clip onto the floor mounts from the end, leaving the
threaded part inside where that obnoxious square nut presently sits,
and the clip part would be up on top so the seat would sit on it.
I suspect that most available clip nuts are coarse thread, so the
bolts themselves will need to be replaced. Suitable replacements
should be available at the same store. Gotta be careful about the
shape of the head, so that it doesn’t interfere with the travel of
the seat rail.
| - Palm’s Postulate
When removing the water pump the Haynes manual says remove the crankshaft
pully. I have several problems with that aside from the fact that its not
You don’t need to remove the starter to jam the flywheel. Once you have removed
- Matthias
Date: Thu, 10 Oct 96 02:54:33 EDT
From: ** SHANE MANTOSZKO ** IBMA INVENTORY ANALYST **
*** Resending note of 10/10/96 16:34
*** SYDVM1(SHANEM) PH. (02) 354-4918 CUMBERLAND FOREST FE21
*** INTERNET - SHANEM@VNET.IBM.COM *** IBMMAIL - AUIBMSPM ****
- Matthias
Or even use a good long handled socket/torsion wrench, put it on the
front crank nut, brace it on a strong part of the engine bay, disconnect
the coil, and then turn your ignition key for a few quick bursts, and
voila, the crank nut will be loose…hard part is then re-tightening it,
but a ratchet gun worked for me.
Date: Thu, 10 Oct 1996 09:58:48 +0100
the people who paint the inside of their exhaust pipes to make it
appear “newer”. Poor saps.
Cosmo
83 XJ6 4.2
65 Mustang 289
Date: Thu, 10 Oct 96 08:07:20 EST
Subject: Re[3]: Leather Interior
Here is a data point. I have a late model ('93) XJ-S 6-cyl. It is pretty much
ALL leather - seat sides and backs are definitely the same as the seating
surfaces. Door lining is leather too. The dash certainly feels like leather.
Also plenty of wood. Only a few places where they might have put wood but
didn’t - Instrument panel is not wood - but a black material - with round
gauges. The transmission shift knob is metal/plastic combo - a little ugly.
(anybody know where to buy a nice wooden replacement handle?)
In later years I am pretty sure that Jaguar has listened to it’s customers in
the luxury car market in the US - they want all the pampering stuff - and they
won’t buy without it.
Went to see the XK-8 yesterday. Looks like all leather there too - so the trend
continues. Definitely too much wood.
- mclaus ('93 XJ-S Convertible)
Date: Thu, 10 Oct 1996 9:12:20 -0400 (EDT)
Date: 10/Oct/1996
Dear Jag Lovers,
Mine is a fairly sinple question. I have begun, at long last, a
more serious effort to restore my 59 XK 150-S. Jaguar Cars confirmed
my suspicion that the original color was Mist Gray with a red interior.
It is now Imperial Maroon over BRG, over Old English White over the
original Mist Gray. The dash and door panels are black dye over red.
walking around the new car lot. Several years ago at a JANE show I
so lovely even my wife liked it (this is not an insignificant
consideration). What do you think? Should we try to hold true to
the original or create what we would have liked it to be?
Is there a source for paint codes somewhere on the Net? If
George Dodson
Date: Thu, 10 Oct 1996 09:13:32 PST
Subject: Front end alignment
specs for this
they do it right.
Thanks all.
Kory Krofft
64 XKE Cpe.
79 XJ6
Date: Thu, 10 Oct 1996 09:25:00 -0400 (EDT)
Subject: Re: Re[2]: V12 Radiator drains
Mike: No,cause you could tell if it was, by the teltale marks of the
solder. As I said it was a surprise to me.
Wed, 9 Oct 1996, Mike Cogswell wrote:
What year XJ-S had the drain? Any chance is was added? MikeC
Author: Chad Bolles aa100519@dasher.csd.sc.edu at Internet
Date: 10/9/1996 8:35 AMMark: Hate to disagree with you, but the other day while working on an S
with the screw on trans cooler lines, I noticed that it had a drain codk
on it… Had to look twice to believe it, for I as you believed the drain
cock to be a thing of the past, but there it was.Chad Bolles
End of jag-lovers-digest V2 #420
Date: Thu, 10 Oct 1996 13:00:41 -0500
Subject: Re[2]: Putting in the crossover pipe (XJS)
Another good use for a clutch, right Kirby? Just put it in gear, apply the
parking brake and/or chock the wheels. Now the engine is locked.
On a more serious note, you can weld a short length of rod to the end of an old
spark plug. Use it to replace a plug, hand rotate the engine (breaker bar on
that bolt you’re trying to remove) until the piston is up against the rod. Now
it’s locked for sure. Just make sure you disable the starter and hang a red tag
so it can’t get turned over with the rod in it.
MikeC
Author: mfl@kheops.cray.com (Matthias FOUQUET-LAPAR) at Internet
Date: 10/10/1996 8:02 AM
- Matthias
Date: Thu, 10 Oct 96 10:15:45 PDT
Subject: Leather and Wood
I think leather and wood is nice, but personally, I don’t really
mind if the sun-visor or the parking brake handle surround is not
made of leather.
An aside: I can’t help but giggle inside when someone proudly
tells me he bought the latest Honda Accord or Toyota Camry with
full lether interior.
Roger Peng (408)765-7863
Intel Corporation
Design Technology, Physical CAD
Date: Thu, 10 Oct 1996 13:08:38 -0500
Subject: Re[2]: Polished E-Type [was: Re: XK’s Unlimited open house]
–IMA.Boundary.817769448
Content-Description: cc:Mail note partExactly the kind of thing that caused me to raise the issue. I’m
pretty well convinced that if you had a time machine and could go bake
to the '60s or '70s and grab a brand new E-Type at the factory you
______________________________ Reply Separator _________________________________
Author: Cosmo simond@inflon.informix.com at Internet
Date: 10/10/1996 9:58 AM
<snip>
I’m not a judge but I do think it a little absurd the lengths to
which concours owners (oops almost said drivers) go to keep their
cars in “like-new” condition. This was proved to me a while ago
when a motoring program discovered an XK120 (or maybe 140) that
had practicaly never been used with something like less than 300
event. Jaguar build quality ensured that the shut lines were uneven,
the underseal was patchy, interior didn’t fit etc. A far cry from the
people who paint the inside of their exhaust pipes to make it appear
“newer”. Poor saps.
Cosmo
83 XJ6 4.2
65 Mustang 289
- –IMA.Boundary.817769448–
End of jag-lovers-digest V2 #422
End of jag-lovers-digest V2 #427
id for jag-lovers-digest-out; Fri, 11 Oct 1996 10:39:54 +0200 (MET DST)
Date: Fri, 11 Oct 1996 10:39:54 +0200 (MET DST)
Message-Id: 199610110839.KAA18212@ekeberg.sn.no
Subject: jag-lovers-digest V2 #428
Precedence: bulk
Status: RO
X-Status:
jag-lovers-digest Friday, 11 October 1996 Volume 02 : Number 428
Re: Antennae
[none]
[none]
Chrome paint on dashboard trim (SII Etype)
Re: Front end alignment - solution
Re: beer and other nonsense
Antennae lengths
Date: Fri, 11 Oct 1996 00:47:11 -0005
Subject: Re: Antennae
doug heinen:
You are correct, Kirbert. 31 inches is nominal, but there is a
compromise for AM frequencies thrown into the equation.
Since I don’t give a RA for AM, I guess that means I need 31".
Also, vertical
is the best for reception of all frequencies but asthetics and style
come into that equation…a raked antenna mast that matches the wind
screen or body lines is more pleasing to the eye. (for some)
Ooooh. Please make a feeble attempt to explain how important this
is. Some of us prefer the looks of the swept antenna, would like to
know just how much we sacrifice in FM reception. Is it a whole
bunch? I note that both of the stock antennas on my Hondas are
swept, and swept a lot more than the (non-stock) one on my Jag –
but they’re on the roof, which probably also makes a difference.
| - Palm’s Postulate
From: rrichardson@eurekanet.com (Robert J. Richardson)
Date: Fri, 11 Oct 1996 01:27:52 -0500
Subject: [none]
I’m in the market for an interior kit for a Series I 1964 E-Type FHC. In
Barlett’s ad in Hemmings, they list a standard kit and a deluxe kit. What
comes with the deluxe kit that is not included in the standard kit? The
price with rebate for a standard kit is about $1,600. Is this a competitive
price and will I get all the leather to replace the original leather? Also
do kits include the headliner material? My old headliner is drooping and
sagging all over the place.
Bartlett’s at one time did interiors and quoted 90 manhours to do a FHC.
This seems a little bit much. Has any of you E owners replaced the complete
interior of a coupe? I’d appreciate some advice that will help me in this
project.
Date: Fri, 11 Oct 1996 09:32:27 +0200
Subject: [none]
From jag-lovers-digest-owner@sn.no Fri Oct 11 00:55:42 1996
Received: from ekeberg.sn.no (126@ekeberg.sn.no [194.143.8.8]) by smtp.internetdesign.com (8.6.10) id AAA24537; Fri, 11 Oct 1996 00:55:40 -0600
id for jag-lovers-digest-out; Fri, 11 Oct 1996 04:48:09 +0200 (MET DST)
Date: Fri, 11 Oct 1996 04:48:09 +0200 (MET DST)
Message-Id: 199610110248.EAA06124@ekeberg.sn.no
Subject: jag-lovers-digest V2 #424
Precedence: bulk
jag-lovers-digest Friday, 11 October 1996 Volume 02 : Number 424
Antennae
Re: XJ-S front end rebuild
[SIII XJ6] Oil and oil pressure. Today’s entertainment
Re: Serial Number strangeness/4.2 Compression Ratio
Cogswell’s Messages
Still need some wire information (XJS)
Re: Re[2]: Putting in the crossover pipe (XJS)
Re: JACK STAND WARNING!!!
Re: AC Compressors
Jaguar Special
XJS stalling
Re: Originality or Lump?
Temporarily unsubscribed + XJ S1 pic !
Re: Re[2]: Polished E-Type/Beer
Date: Thu, 10 Oct 1996 20:38:47 -0005
Subject: Antennae
I know there are some radio experts here.
I recall learning years ago that the ideal length for an antenna on
an FM radio is around 31 inches, and that either longer or shorter
is not as good. Is this true? If so, how come some antennas are
not that length?
If true, how does the antenna being mounted at some angle other than
vertical affect it? Should it still be 31 inches long, regardless of
mounting angle?
| - Palm’s Postulate
Date: Thu, 10 Oct 1996 16:44:19 -0005
Subject: Re: XJ-S front end rebuild
Aaron Burnett aaron.burnett@attws.com:
3.) I plan to use a large C-clamp and socket to press the old bushings
out – sound reasonable? I’ve done this type of repair on a '62 Impala,
but had a great deal of trouble removing the old bushings.
Why don’t you use two sockets and a piece of threaded rod instead?
One socket needs to be big enough to fit AROUND a bushing while the
other needs an OD just slightly smaller than the OD of the bushing
itself, and the threaded rod should fit through both sockets and the
bushing itself. Couple nuts and washers, and you should be able to
apply a LOT more force than any C-clamp.
| - Palm’s Postulate
Date: Fri, 11 Oct 1996 01:54:59 +0100 (MET)
Subject: [SIII XJ6] Oil and oil pressure. Today’s entertainment
Today I decided to change the oil in preparation for the oncoming winter.
I went to my friendly local auto parts store and innocently asked for an
oil filter for an '86 Jaguar XJ6 4.2 (I already knew what was coming next).
- “Sorry, we don’t have that”
Many of you might know the look on a typical auto store parts man’s face
when you mention the word “Jaguar”. Sort of like “These are exotic cars, no
way we have parts for them. Why do you even bother to ask? Besides, I only
own a Toyota so I’m envious of you. Go away.”
So I asked him if he was sure and if he could please check. After a
lengthy consultation with his books he looks up and asks:
- “Do you have a series one, a series eleven or a series one hundred and
eleven?”
- “Say what? Let me look at that book!”
Sure enough, the book listed XJ6 Series 1, Series 11 and Series 111. I
couldn’t help laughing. Why he bothered to ask I do not know because the
filter listed was the same for all XK engines and even the later AJ6.
Anyway, he checked his stock and of course had several. In an astonishing
break with Jaguar tradition it wasn’t even expensive.
Next stop was a local gas station to buy some of that Mobil 1 oil you’ve
all been talking so favourably of. I checked my owner’s maintenance
manual first and felt my wallet cringe as I read that my engine requires
8.8 liters of this precious fluid. This was going to be expensive! What I
didn’t realize was that I was in for some more entertainment. I had
parked right in front of the door to the station, this meant the attendant
could see my car. I walked up to the appropriate shelf and took two four
liter cans and one one liter can with me to the counter. The attendant then
calmly started to explain to me that I wouldn’t need that much oil, I
should only fill to the marker on the dipstick, not drown the engine.
- “Thank you, but I’m quite sure that I need 8.8 liters.”
- “No, no. 4 liters will do it, maybe 5 if you replace the oil filter as
well.”
- “But my owner’s manual clearly states 8.8 liters.”
- “That must be a mistake. No cars use that much oil, not even Jaguars.”
- “But… but… nevermind! This is not a Toyota or Volvo, OK? I’m
absolutely certain that I need 8.8 liters!”
- (Offended and hurt) “OK, if you say so.”
I did. My wallet did hurt though, the 9 liters cost me NOK 796 (US
$122.50). Later the same day I discovered something new about Mobil 1
oil. An auto discount store here (Biltema) sells Mobil 1 oil at much
lower prices than the gas stations. No surprise so far, the thing is
that it is not the same oil! The stuff sold at Biltema is imported from
the US (the cans clearly state that the oil is manufactured in the US)
and only holds CCMC G4 quality. The stuff sold at the gas stations and
elsewhere is manufactured in Sweden and holds CCMC G5 quality (and is
thus superior to the US variant as I understand it). The Swedish made oil
has a 5W-50 viscosity range while I believe the US version “only” has
5W-40. I saw the US type cans ('cause a friend had bought some) and was
able to do a direct comparison.
Strange, isn’t it? Why would they make the same oil but have different
qualities for different markets? Or is it just a case of Biltema buying a
large stock of leftover oil from the US cheaply because it has been
replaced by a newer, better oil?
While I’m on the subject of Mobil 1 oil: Mobil has been advertising all
over the place lately for the new Mobil 1 oil with a viscosity range of
0W-40! Problem was I couldn’t find any. None of the places I visited had
got it in stock yet and I was determined to do the oil change today.
5W-50 should be adequate even for Norwegian winters though.
As for erratic oil pressure readings on the dash instrument I discovered
the same thing as many others have been reporting on this list. It was
simply a loose connection between the oil pressure sender and the wire. I
tightened the clamp connector and hey presto! High and stable readings
from the instrument.
Now if someone could explain to me how Kpa (Kilo Pascal) relates to the
real world I would actually know exactly how good my oil pressure is!
(The instrument is a scale from 0 to 7 and the text on the instrument
face says “Kpa x 100”). So I know I have 300Kpa at idle and 600Kpa at
3000rpm (both hot), but what is that in psi or Kg/cm2? Help!
Gunnar
Gunnar Helliesen | Bergen IT Consult AS | NetBSD/VAX on a uVAX II
Systems Consultant | Bergen, Norway | '86 Jaguar XJ6 4.2 Sovereign
gunnar@bitcon.no | http://www.bitcon.no/ | Vicki who? What .sig virus?
Date: Thu, 10 Oct 96 12:53:50 PDT
Subject: Re: Serial Number strangeness/4.2 Compression Ratio
Mike,
You should be able to tell by running a comnpression check. 8:1 at sea level
should be around 128 PSI and 9:1 around 144.
LLoyd - my mercedes is 195PSI, stock-
Subject: Cogswell’s Messages
Is it just me, or are Mike Cogswell’s messages coming through
differently than everyone else’s? My Pegasus software treats them as
multi-part messages with only one part.
| - Palm’s Postulate
Date: Thu, 10 Oct 1996 18:57:38 -0500
Subject: Still need some wire information (XJS)
I am just about back together with my “new” '82 XJS but I still have two
sets of wires to hook up.
The Green and the Green/Red wire to the temperature sensor on the water
pump. Does it make any difference which connector they go on? Are they
interchangable, I hope? -
The Black and White wires in a sheath that come from the right side of
the engine, across the front of the engine and over to the vicinity of the
left hand thermostat. Where do they go? I dont seem to have anything to
push them onto. They each come from a three way connector just under the
intake manifold above and slightly behind the air pump. (EPA mandated in
the US) I havent traced where they go from here.
Help!! I need this info before I can finish the job.
Jim
“Better an outlaw than not free.”
Nance O’Neil
Date: Thu, 10 Oct 1996 21:05:54 -0005
Subject: Re: Re[2]: Putting in the crossover pipe (XJS)
On a more serious note, you can weld a short length of rod to the end of an old spark plug. Use it to replace a plug, hand rotate the engine (breaker bar on that bolt you’re trying to remove) until the piston is up against the rod. Now it’s locked for sure. Jeffrey Gram: What ??!!. You must be joking. This may work on a 1000 HP ship engine with cast iron pistons but on any other car that is a potential suicide, at least a sure way to leave big time score marks, and might even break the rod or the plug or rip the plug straight out out the head. I’m speechless (almost). Octobers first prize for the most outrageous advice. That’s funny, I thought it was a pretty good idea. I don’t understand where score marks would result at all. Obviously, the rod would have to be fairly substantial, but that’s not difficult. If you’ve used all the threads on the spark plug hole, there’s no chance in hell you’re gonna rip it out. The only risk I can see is punching a hole in the top of a piston, but I suspect you’d have to be applying a whole bunch of torque to that nut to do that. Personally, I’ve never been all that thrilled of jamming the flywheel. Only too easy to bugger up those teeth. Why can’t these car companies provide a place to put a pin? Kirbert | If anything is to be accomplished, | some rules must be broken. | - Palm’s Postulate From: “Kirbert” palmk@gcn.scri.fsu.edu Date: Thu, 10 Oct 1996 21:05:55 -0005 Subject: Re: JACK STAND WARNING!!! Author: LLoyd 3030P@vm1.cc.nps.navy.mil at Internet NEVER support a car on 4 jack stands. It isn’t safe. There are all sorts of unsafe ways to support a car. One of the most common is to use cinderblocks, which crumble without warning. However, I would tend to disagree that supporting a car on 4 stands is all that dangerous. As long as the stands are decent quality and they are positioned under the car in such a way that the car cannot slide around on top of the stands, it should be OK. My rule of thumb: regardless of what is supporting the car, before crawling under I always give the car a good shaking – good enough to convince me that it won’t fall down while I’m under there. If I manage to shake it off its supports, I may damage some sheet metal, but I’ll still be around to fix it. Way back before my Jag ownership days, in fact when I was still in grade school, my father became enamored of a professor he studied under while getting a graduate degree. This man changed my father’s outlook on life in general, and I can still remember the day it happened. Some time later, this professor was killed by having a Jaguar fall on him. To this day, it appears to concern my father that I not only own one of these evil cars but that I actually crawl under it from time to time. Kirbert | If anything is to be accomplished, | some rules must be broken. | - Palm’s Postulate Kirbert | If anything is to be accomplished, | some rules must be broken. | - Palm’s Postulate From: Stefan Schulz jaguar@suaviter.demon.co.uk Date: Thu, 10 Oct 1996 22:02:22 GMT Subject: Re: AC Compressors In message 199610101623.AA31124@gcn.scri.fsu.edu “Kirbert” writes: By the way, one fundamental difference: the pressure switch is closed when all is OK and opens when pressure is low, so the clutch is generally grounded through it. The superheat switch that comes on the Jag, however, is open when everything is OK and closes to cause a short and blow the 3-way fuse when temp is too high. Until sometime pre-1988 when the fuse was eliminated and Jaguar started to use a pressure switch as you first describe it. Regards, Stefan Schulz jaguar@suaviter.demon.co.uk From: rpeng@cadev6.intel.com Date: Thu, 10 Oct 96 12:22:01 PDT Subject: Jaguar Special Guys, Check out the latest issue of the British magazine: Thoroughbred and classic Cars. This month they are having a Jaguar special. There’s one article titled “Jaguar” that is very interesting; it takes a rather cynical view of various models as well as the company itself. There’s truth to what it’s saying though. Definitely check it out yourself! Roger Peng (408)765-7863 Intel Corporation Design Technology, Physical CAD From: David Hallam d.hallam@mailbox.uq.edu.au Date: Fri, 11 Oct 1996 11:44:32 -0700 Subject: Re: A question of paint color for restoration Giday All Before we all wax to lucid. Remember an original is an original. Un touched and passed to us through time with minimal degridation. A restored car is just a restored car, nothing more, it is not an original. It may be restored to your interpritation of the orginal specification. But… Original cars are rare… Very rare… But having said that I’d much rather have a car that has been rebuilt to my interpritation of original so I can thrash the pants of it then rebuild it again. /dlh. *** Without Treatment Development our past can only rot **** David Hallam Senior Scientist, Materials Conservation Queensland Museum, PO Box 3300 South Brisbane Qld. 4101 Australia. ************************* Standard Disclaimer;************************* D.Hallam@mailbox.uq.edu.auhttp://www.uq.edu.au/~qmdhalla/** From: rrichardson@eurekanet.com (Robert J. Richardson) Date: Thu, 10 Oct 1996 17:47:01 -0500 Subject: Re: JACK STAND WARNING!!! Having grown up working after school and weekends in a garqage, I have not mentioned this before because I just assumed… NEVER support a car on 4 jack stands. It isn’t safe. They are for supporting either the front OR the back, if you are lifting up only one end of the vehicle . If you are lifting the entire vehicle use jack stands on one end only. Put the other end on blocks or ramps. Personally, when I’m under a car with jack stands, I also have my hydrolic jack supporting a bit of weight between them, just in case. I may be a sissy, but I’ve spent some time trapped under a car when it fell on me. But that’s another story… LLoyd - I prefer Coors - I tend to agree with you. A car on four jack stands, with their narrow basis, would seem to be unstable. A slight shift in weight, say you have someone in the driver’s seat to help you with brake bleeding, could be disastrous. I have the metal ramps and you convinced me to buy just a pair of jack stands. I’m still looking for stands with a max height of 24 inches so I don’t have to wedge my 232 pounds under the rear suspension, etc. From: “Kevin Sisterson” stablemates@msn.com Date: Fri, 11 Oct 96 02:12:44 UT Subject: XJS stalling Well I thought it was vapor lock, so I drove it around for a week with the gas cap loose, ran fine. All of a sudden, still with the gas cap loose, I’m driving along at 65 mph and no power untill I slow down to about 30. I pull off the road, let it sit for a few minutes then it’s fine again. It never happens in the morning, only in the afternoon, who knows maybe just coinsedance. Anybody out there got a clue what the problem is? Kevin From: charles daly cdaly@passport.ca Date: Thu, 10 Oct 1996 22:23:10 -0400 Subject: Re: Serial Number strangeness Hi Tommy, According to the Originality Guide (Haddock) "…from model numbers… 1R.12955 About April 1970, the fan control thermostat was changed. I read this as saying that your car was made before April '70??? Hope I’m right (or wrong!- whichever works 4 u!) Do you have the engine or transmission number? Hope this helps, I have (I think) a 1971 series 2 E-Type that was originally imported to Canada (I think). It was sold and I bought it as a 1971 and I’ve always understood it to be a 1971. It’s a 4.2 litre and has the series 2 body style. I have the car number, body number, gearbox number, and the engine number but the name plate indicating the date of manufacture is missing. The car (vehicle) number is 1R12449 and the body number is 4R6986. Charles Daly, Toronto, Canada '62 E-Type, ots From: “Gregory W. Price” gprice@mack.rt66.com Date: Thu, 10 Oct 1996 20:17:08 +0700 Subject: Re: XJ-S front end rebuild Aaron Burnett aaron.burnett@attws.com: 3.) I plan to use a large C-clamp and socket to press the old bushings out – sound reasonable? I’ve done this type of repair on a '62 Impala, but had a great deal of trouble removing the old bushings. Kirby wrote:
Ditto.
Tried the C-Clamp-and-socket routine on my steering rack bushings and
ruined a good 8" C-Clamp. Finally used the bolt-and-socket gizmo to
get them all out.
Greg.
Date: Thu, 10 Oct 1996 22:34:54 -0400
Subject: Re: Originality or Lump?
Since acquiring my car I’ve been an avid reader;
sometimes contributor to the list.
Now I need help.
For many months we’ve been throwing red, over ripe
tomatoes (originality stickers properly affixed) at the mention
of lump conversions.
I have restored my car to virtually original condition, even to the
absurd (but pretty) glass windshield bottle, original spare tire,
etc. and I drive the car almost every day, often at 100mph+,
because that’s my interpretation of why it was built in the
first place (June 1962).
Now it seems, I’m a sap to do that.
So please explain where, between an orange lump and a glass
windshield bottle I should be.
Tomorrow I shall paint it purple, with orange/red flames on the
bonnet, and a raccoon tail (pink, no doubt) flying from the antenna.
'62 E-Type, ots
Date: Thu, 10 Oct 1996 22:50:56 +0100
Subject: Temporarily unsubscribed + XJ S1 pic !
In case anybody cares I am temporarily unsubscribed
for next week, I have the privilege to visit New York.
In case anybody know of any Jag events there, feel free
to email hints to ‘gunnar@medial.se’.
BTW, I just uploaded a 1982 image of my XJ S1.
http://www.medial.se/xj6.jpg (78 Kbytes)
The car looked terrific at the time after my previous restoration of it,
had new paint and all.=20
My goal is to return it to that shape again before the end of 1997…
It has not been on the road since 1989.
I got inspiration from looking at the XK-8’s last weekend and realized
that ‘Hey, I have one of these animals at home, just a matter of
fixin’ a few things…’
Gunnar Forsgren gunnar@medial.se=20
MEDIAL Maskin & Data http://www.medial.se
=C4ngsvik 2 24 hour phone/fax +46 8 570 25056
S-139 50 V=E4rmd=F6, Sweden XJ6 4.2 S1 '72
Date: Thu, 10 Oct 96 15:01:37 CST
Subject: Re[2]: Seat Mounting Bolts & Nuts - XJ-S
Steve K.
Author: palmk@gcn.scri.fsu.edu at smtplink-tellabs
Date: 10/10/96 2:39 PM
That sounds correct. The one I have here does not have the captive
nut, although there’s no reason why one of those wouldn’t work as
well. This one has a 1/4" long set of threads formed directly from
the parent sheet metal.
| - Palm’s Postulate
Date: Thu, 10 Oct 1996 15:49:03 -0400
Subject: Re: Re[2]: Polished E-Type/Beer
Exactly the kind of thing that caused me to raise the issue. I'm pretty well convinced that if you had a time machine and could go bake to the '60s or '70s and grab a brand new E-Type at the factory you wouldn't stand a chance in a concours today. I'm genuinely puzzled by this. How did this come to be? I'd still like to hear from people in the concours business as judges and/or competitors. MikeC
I have seen a few clean original E-types (vs original but well worn) with
original paint interior etc. They were pretty nice. I have yet to see a bad
door gap on an original E, though the doors on XK-120-150s never seem to fit at
the bottom. I think that the factory would do some engine bay polishing at
extra cost, so polished immaculate engines are probably legit. Also, I doubt
that the cars were covered with road dust and tar when they left the factory,
and I’ll bet the cotton wiring harnesses were not covered with greasy finger
smears (like mine are).
It is easy to say that my car is more like original condition because it is
not “perfect”, but really that is a lame excuse for a maingy car, sort of a
automotive sour grapes syndrome - stems from the fact that these ‘perfect’ cars
seem to take away the impact of our ‘driven’ cars.
When I look at new cars on showroom floors, and look under the cars, under
the hoods etc. it makes me think that the “over restored” cars at the concours
may not be so over restored. :-(.
When I can suppress my envy I do like to see perfect Jags. If these people
didn’t do this to their cars it would be hard to imagine how old Jags looked
when they were new. The practicality of maintaining them is another matter, but
hey, it is their car…
A nice patina of age on an unmolested original car is also a gratifying
sight, but one that seems to be getting more rare. Patina usually = rust.
Mark McChesney
Beer? - I've not had a drink since I was 17 - probably a good thing...
End of jag-lovers-digest V2 #424
Date: Fri, 11 Oct 1996 03:32:19 -0005
Michael Neal:
Whatever nuts you end up using to replace the oem stuff just make sure that
they are as strong as the originals. If the seat breaks loose when some
idiot rear-ends you the odds are slamming yourself up against the rear
window are pretty great.
I agree with this completely. However, I have never been overly
impressed with the strength of rectangular nuts like those used to
mount the seats – Grade 8 they’re not! OTOH, this clip nut appears
to be VERY strong – twice the thread as the rectangular nut, and
made from a very hard spring steel instead of the soft putty the
rectangular nut is. And the configuration of the clip nut appears to
put the threaded part in compression when the bolt is under tension.
All in all, I expect using these parts would make the mount much
stronger than it was.
| - Palm’s Postulate
From: David J Shield David_J_Shield@ccm.fm.intel.com
Date: Thu, 10 Oct 96 23:48:00 PDT
Subject: Chrome paint on dashboard trim (SII Etype)
The switches on the SII E-type are arranged in a row on the dash.
Each switch position has a raised surround, plated with chrome or
chrome paint. Well, most of this is worn off, but otherwise things
are OK. Can I repaint this? Is there a chrome paint, or chrome
leaf that can be applied? And, if you recommend a product, have
you tried it?
Thanks.
David - just one more $50 part to avoid buying
Date: Fri, 11 Oct 1996 09:27:59 +0100
Subject: Re: Front end alignment - solution
On Oct 09, 1996 18:17:29, ‘Jan Wikstroem Jan_Wikstroem@acp.com.au’ wrote:
The Repair Operations Manual specifies using (simple) tools to lock the
suspension at half height for wheel alignment or, in the absence of such
tools,loading the car to “average” condition. However, this assumes that the
suspension has totally correct springs and sits at the specified height -
a
condition I’ve never come across in any Jag older than 10 years (I haven’t
worked on any newer ones…).
Early MKII manuals show adjustment with the wheels off the ground. A later
supplement suggests using the “half way” method. Just FYI.
The simple method up front involves jackling up the car and taking the
front
wheel off, then either taking the spring load with a garage jack under the
outer ball joint or spring, or lowering the same part on to a stack of
bricks.
PLEASE DON’T DO THIS. Bricks can explode under pressure, and HURT YOU.
Use an axle stand, or even a bottle jack. Don’t use breeze blocks either.
Be careful out there!
- Jan
“Gum Tree Garage”
77 XJ12C
78 XJ12L
Ian
Date: Fri, 11 Oct 1996 09:27:57 +0100
Subject: Re: beer and other nonsense
So things were fine when taxpayers like me supported your hobby?
Sad.
Ian
On Oct 08, 1996 16:59:22, ‘Peter Carpenter 106257.3334@CompuServe.COM’ wrote:
I reckon the list has gone too far now. Things were fine when I was at a
university address and logged on for unlimited periods for free. Now, I am
at home and have to pay phone calls to download messages. I do not think
I
am getting great value any more chaps. A lot of it is - as Jim Isbell
would
say - shit.So thanks for the ride
& thanks for the help Alastair,Signing off the list
Peter Carpenter
1967 420
UK.PS Thanks Nick
PPS Jan - Pay for the list? Love to, keep the humour and get the Jag
content denser.
Date: Fri, 11 Oct 96 00:53:00 PDT
Subject: Antennae lengths
Kirby,
The general formula for a quarter wavelength antenna is:
Length in feet = 234/frequency in MHz
So, your 31" antenna seems to be optimal for 90.9 MHz.
Notice, though, that this formula is not related by a factor of 4
to the general formula for wavelength which is:
Wavelength (full wave) in feet = 984/freq. in MHz.
I forget why this is so.
As for the optimal mounting position on the car, the manufacturer
installs it wherever it fits. Note that the car body makes a
pretty good ground plane. If the antenna is mounted on a corner,
the sensitivity plot will be pretty uneven (strong in some
directions, weak in others). Body contours mess up the reception
as well. Amateur radio operators know these things and mount their
antennae directly in the center of the roof, which I personally
find un-appealing, visually.
Angle? It matters. Straight up is best for mobile. FM radio
stations have a vertically-polarized component of the signal. This
helps serve the mobile audience. But there are so many factors
involved, that the exact length of the antenna and angle are not
the primary determinants of overall sound quality. The shape of
your car, what is around you, how many pennies the radio
manufacturer put into the tuner, probably have more influence on
the sound quality.
Clarion makes (used to make?) a radio with 'Diversity Tuning'. The
car has two antennae, each feeding a separate tuner (but set to the
same frequency). Whichever antenna/tuner had the cleanest signal
would be used. This will change several times/second as you drive.
The car I rode in had a very clear signal no matter what.
David - it's been a while since I thought about this stuff
Kirby writes:
>on an FM radio is around 31 inches, and that either longer or
>shorter is not as good. Is this true? If so, how come some
>antennas are not that length?
>than vertical affect it? Should it still be 31 inches long,
>regardless of mounting angle?
End of jag-lovers-digest V2 #428
id for jag-lovers-digest-out; Fri, 11 Oct 1996 21:03:40 +0200 (MET DST)
Date: Fri, 11 Oct 1996 21:03:40 +0200 (MET DST)
Message-Id: 199610111903.VAA19385@ekeberg.sn.no
To: jag-lovers-digest@sn.no
Subject: jag-lovers-digest V2 #429
Precedence: bulk
jag-lovers-digest Friday, 11 October 1996 Volume 02 : Number 429
T-shirts with jag-lovers@sn.no on 'em
JEC Spares Day 1996
A small FAQ
Sorry about the digest-problems
Re: Polished E-Type
Re: JEC Spares Day 1996
brake parts
Re: Antennae
Mobile 1 Oil
Hess fuel system
Re: Cogswell’s Messages
XJ 40 oil change
Re: XJS stalling
Re[4]: Seat Mounting Bolts & Nuts - XJ-S
Re: A small FAQ
Jack Stands
Wanted: XJ-S dealer repair manual
Re: Antennae lengths
Wanted: UK supplier of Mk2 Front suspension parts
Re: A small FAQ
XK 8 (long-ish)
Date: Fri, 11 Oct 96 01:03:00 PDT
Subject: T-shirts with jag-lovers@sn.no on 'em
A couple of people seconded this idea: I think I'll start wearing
some kind of identifier such as jag-lovers@sn.no on a T-shirt when
I attend things like rallies or XKU open house, etc. And, unless
someone *really* wants to be in the T-shirt business, I'll just go
get my own, in BRG. Lands End has nice t-shirts etc., but they
only monogram up to 10 characters. Every shopping mall has a
custom t-shirt store, it should be easy to get one made up.
'70 XKE 2+2
'84 XJ6 VDP
Date: Fri, 11 Oct 1996 11:09:45 +0200
Subject: JEC Spares Day 1996
The Jaguar Enthusiasts Club in the UK are arranging their Autumn
Spares Day on the 27th of October at Stoneleigh. I will be going
over for the weekend and will be there in the company of Roly
Alcock. Would be pleased to meet other Jag-lovers I’ll be
there promoting www.jagweb.com, but should have time for a good
chat.
Contact me or Roly to arrange things.
Nick
Date: Fri, 11 Oct 1996 11:13:46 +0200
Subject: A small FAQ
This is just a short posting to remind members of pertinent information.
How do I get off the list?
Send a message to majordomo@sn.no containing the line: unsubscribe jag-lovers or unsubscribe jag-lovers-digest If this doesn't work you may have changed your email-address since you subscribed. In this case mail the list-admin at nick@sn.no and ask for help.
Where are the archives?
The archives are periodically uploaded to the JagWeb in batches of 30. I try to keep the archives current. The archives go nearly 3 years back in time now.
Where is this JagWeb and are there other sites of interest?
The JagWeb: http://home.sn.no/home/nick/jaguar.html I would also like to point people to http://www.jagweb.com a new site promoting Jaguar specialists. Worth a visit, since many of the companies offer free catalogues. All the companies can accept email, but you must include snail-mail or a fax # to receive a reply. Please send enquiries ;-) There is a list of links at the JagWeb to other sites of interest, amongst them a fair few companies and a lot of Jag-lovers homepages.
Where can I get books and manuals?
Try Bookspeed, a British company that have their own web-site and export all over the world. It is linked to the front page of the JagWeb.
Where can I find Kirby’s XJS-book and Jim’s XJ-book?
Again, the JagWeb has them. There are also US-versions of these linked in, including a list of suppliers.
Can’t think of anything more for now.
Nick (admin of all things good)
Date: Fri, 11 Oct 1996 11:28:41 +0200
Subject: Sorry about the digest-problems
Due to an unfortunately configured mailserver in Holland the digest
has been plagued with duplicates today. I am very sorry about this,
but it was out of my control. The problem should be fixed now.
Nick (admin)
Date: Fri, 11 Oct 1996 23:32:49 +1300
Subject: Re: Polished E-Type
Chip Weems wrote:
I got certified as a JCNA judge this Summer. First off, snip
Chip’s home page was the second thing I found on the Net (Pamela Anderson was the first
but I havn’t been back). If you look at the restoration being performed you’ll wonder
how he got the time to get certified.
Stewart
PS Steinlager = beer of choice.
PPS Once again looking for Series 1 Roadster - don’t ask
PPS Never buy a Jag sight unseen.
Date: Fri, 11 Oct 1996 12:50:15 +0200 (MET DST)
Subject: Re: JEC Spares Day 1996
chat.
Marie-Anne and myself are also going. Maybe we all could get Saturday
night ? Who else is coming ?
- Matthias
Date: Fri, 11 Oct 1996 11:00:04 +0000 (GMT)
Subject: brake parts
i am presently on a quick visit to the u.k. and as always have a list of bits
and pieces that i need. i stopped by barrett’s in bridgenorth, they have some
brake piston/cylinders in stainless and are they gorgeous. so i bought a set
for the front end of my ser. 1 e-type. god knows what the security machines
will do at heathrow. interestingly they also recommended that i do NOT replace
the fluid with silicone as the original jag specs were not close enough to
accomodate this and urged me to use the dot 4 fluid. any thoughts, robin
Date: Fri, 11 Oct 1996 06:53:22 -0500
If 40 years makes me an expert, here I am.
This is true, but not very critical considering the signal strength that is
needed by the radio and the signal strength that is generaly available.
not that length?
If you live in a fringe area then a 31" antenna could help but most of the
time you have an overkill of signal available and a 5" antenna will work.
mounting angle?
This makes no difference at all since generaly speaking you are getting a
reflected signal so its polarity can be almost anything. If you are getting
a pure line of sight signal you are close enough to the station that it
doesnt matter.
In a perfect world you would want a vertical antenna since the antenna at
the station is vertical. But in this world your signal has bounced off
several buildings before you got it and the polarity is all screwed up.
Jim
Nance O’Neil
Date: Fri, 11 Oct 1996 07:02:27 -0500
Subject: Mobile 1 Oil
I dont know what you guys pay for your regular oil, but the price you are
paying for Mobile 1 (24 pounds, sorry, I dont have the correct symbol on the
keyboard) seems excessive.
Here in the states a quart (little less than a litre) of normal oil is
around a dollar. and a quart of Mobile 1 is around $4. At that spread the
difference in length of time you can leave it in makes up for the difference
in price.
BUT…I have had some trouble with Mobile 1 in my car in that the oil
leaks increased.
Castoroil synthetic, I have heard, is not much better than regular oil.
I use Quaker State Synthetic which is only about $3 a quart and the leaks
stoped!
Jim
Nance O’Neil
Date: Fri, 11 Oct 1996 09:13:22 -0400
Subject: Hess fuel system
Someone asked about the dual fuel tank system on the Hess & Eisenhardt XJS
Convertible.
I have no further need for my original Hess manual anymore so I’m willing to
donate it to the list.
Over half the book (filled 2 inch binder) is devoted to the fuel system. Due
to it’s size it does not lend itself to frequent copying. As I understand it
this manual is very hard to find and is no longer in print.
I can ship it to Kirby (or someone else) if they would like to be the keeper.
Julian Mullaney
Date: Fri, 11 Oct 1996 06:32:45 8
Subject: Re: Cogswell’s Messages
as multi-part messages with only one part.
Ditto. In PegasusMail, they’re treated differently so that it takes
about 4 button clicks to read them, then 4 more clicks to exit (or
delete). They usually get trashed, 'cause of the extra effort
involved…
Peter Morris
Date: Fri, 11 Oct 1996 08:39:01 -0700
Subject: XJ 40 oil change
Don’t forget the rear bearings! Same deal.
Dave
When I got my '93 a year ago and laid out the maintenance requirements, I
found that Jaguar calls for no front wheel bearing repacking. I did it
anyway, and found that, at 41,000 they were “ready.” I later mentioned this
to a Jag mechanic and he replied: “You should see the pile of spindles and
bearings I’ve replaced.” My personal schedule is 30,000 miles.
Date: Fri, 11 Oct 96 08:27:11 CST
Subject: Re: XJS stalling
Sounds like a weak fuel pump.
SK
Author: “Kevin Sisterson” stablemates@msn.com at smtplink-tellabs
Date: 10/11/96 2:12 AM
Kevin
Date: Fri, 11 Oct 96 08:20:19 CST
Subject: Re[4]: Seat Mounting Bolts & Nuts - XJ-S
Already did it.
J-Type Cage nuts are "a nut clip plus the security & holding power of
a multiple thread fastner." Spring steel U-Nuts are speed nuts (the
recangtular part) in a clip on configuration. They come in both sheet
metal and machine screw threads.
My apologies to Mr. McMaster for mispelling his name.
SK
Subject: Re: Re[2]: Seat Mounting Bolts & Nuts - XJ-S
Date: 10/11/96 1:51 AM
I think you are referring to "speednuts."
Speednuts is the term generally applied to sheet metal nuts that have
no clip. They also generally only have a formed hole the bolt screws
into, so there is something less than 1 thread.
I would grab hold of a MacMaster-Carr (sp?) catalog.
Good plan! I have a Grainger catalog around here somewhere, very
similar, will give a look! Thanks!
| - Palm’s Postulate
Date: Fri, 11 Oct 1996 16:10:25 +0100
Subject: Re: A small FAQ
Nick - one to add to the FAQ :
I send in details to the Jag-Lovers database - how do I access this
database?
Mark
Mark Stiles - Academic Development Manager
IT Services
Staffordshire University
01785 353410
Date: 11 Oct 96 10:31:02 EDT
Subject: Jack Stands
I use four 6000lb jackstands to support my '84 XJ-S while I am working
under it. I place a stand under each of the support units welded to
the car. I have bled the brakes many times while my wife crawls in and
out of the car. The car is as stable as can be. Before I first
crawled under the car I pushed and shoved from every angle and
satisfied myself that this is a very solid arrangement. It is
important to use high quality heavy duty stands and not the discount
store specials! I also only due this on a level concrete floor. I do
not recommend jack stands on any other surface.
Robert Woodling
Date: Fri, 11 Oct 1996 08:51:17 -0700
Subject: Wanted: XJ-S dealer repair manual
I am looking for a dealer repair manual for a 1985 XJ-S.
All assistance is appreciated
Aaron Burnett
(206) 515-8023
Date: Fri, 11 Oct 1996 09:10:51 -0700
Subject: Re: Antennae lengths
David, Kirby et al…
From Amateur Radio antenna books…
A 1/4 wavelength antenna for the US commercial broadcast bands should be
3.00 X 10 ^8 M/S (C)
WAVELENGTH in Mtrs= frequency in Hz
Taking the the middle of the broadcast band to be 98 MHZ (108-88)
therefore length = 300/98=3.06Mtrs Multiply that by .25 for a quarter
wavelength= .765mtrs. Convert that to inches and the answer is:30.6.
Now that’s for “perfect” conditions. By inserting a coil into the antenna,
you can shorten the overall length. For more gain moving to a 5/8 wave
antenna is better. Of course it will be a longer antenna. Most
manufacturers will compromise on the length vs looks. Remember the GM in
the windshield dipole antennas?
Most radios have a set of trimmer coils/capacitors near where the antenna
plugs into the radio. You adjust them to get the best signal for the
particular antenna. The antenna doesn’t have to be near vertical as FM
radio stations know that both cars (vertical) and homes (horizontal)
antennas are used for reception.
Look at older Honda’s and tha antenna comes out of the driver side
windshield piller resulting in a 45 degree angle ±. On my Mark X the
antenna is on the front fender. On the newer Jags it’s in a rear quarter
panel. Ideal placement would be in the middle of the roof, but it then
tends to hit low hanging branches, parking garages, lights in drive
throughs, etc.
The quarter wavelength antenna is used because it offers a good compromise
on operating characteristics. The best antenna is a multiple wavelength
antenna. Adding a wideband pre-amp can also “make-up” for a less than
optimal installation.
Lee (N0DHS - Amateur Radio Call Sign, not an acronym)
Kirby, The general formula for a quarter wavelength antenna is: Length in feet = 234/frequency in MHz So, your 31" antenna seems to be optimal for 90.9 MHz. Notice, though, that this formula is not related by a factor of 4 to the general formula for wavelength which is: Wavelength (full wave) in feet = 984/freq. in MHz. I forget why this is so. As for the optimal mounting position on the car, the manufacturer installs it wherever it fits. Note that the car body makes a pretty good ground plane. If the antenna is mounted on a corner, the sensitivity plot will be pretty uneven (strong in some directions, weak in others). Body contours mess up the reception as well. Amateur radio operators know these things and mount their antennae directly in the center of the roof, which I personally find un-appealing, visually. Angle? It matters. Straight up is best for mobile. FM radio stations have a vertically-polarized component of the signal. This helps serve the mobile audience. But there are so many factors involved, that the exact length of the antenna and angle are not the primary determinants of overall sound quality. The shape of your car, what is around you, how many pennies the radio manufacturer put into the tuner, probably have more influence on the sound quality. Clarion makes (used to make?) a radio with 'Diversity Tuning'. The car has two antennae, each feeding a separate tuner (but set to the same frequency). Whichever antenna/tuner had the cleanest signal would be used. This will change several times/second as you drive. The car I rode in had a very clear signal no matter what. David - it's been a while since I thought about this stuff Kirby writes: >I recall learning years ago that the ideal length for an antenna >on an FM radio is around 31 inches, and that either longer or >shorter is not as good. Is this true? If so, how come some >antennas are not that length? >If true, how does the antenna being mounted at some angle other >than vertical affect it? Should it still be 31 inches long, >regardless of mounting angle?
From: “Patrick O’Neill” patrick.oneill@premierusa.com
Date: Fri, 11 Oct 1996 10:23:41 -0700
Subject: Wanted: UK supplier of Mk2 Front suspension parts
I am looking for a UK supplier of Mk2 Front suspension parts. I need to do
a complete rebuild including springs.
Does anyone have a list of what should be replaced in a Mk2 power steering
car?
Cheers,
Patrick D. O’Neill
1963 Mk2 3.8L MOD
PS I will also be looking for a complete interior for the Mk2 soon also.
Date: Fri, 11 Oct 1996 18:23:37 +0200
[ Mark Stiles ittmjs@staffs.ac.uk ]
| database?
This is Alastair Laueners project. I don’t think he has
regenerated the database for a while now, but I’m sure he
will reply to this query himself.
Nick
Nick Johannessen // nick@sn.no // http://www.sn.no/home/nick/
Date: Fri, 11 Oct 1996 14:58:21 -0400
Subject: XK 8 (long-ish)
I looked at, and drove the XK 8 last night.
I’ve been fantasizing about replacing my crushed '87 XJS Convertible with an
XK8 (not likely!!!).
I went by the dealer on a whim after work just to take a quick peek. The
coupe looked fairly unremarkable to me at first sight. Although I liked the
car, it smacks of Lexus etc. in the overall smoothness and roundness and
general flawlessness somewhat. I was not overwhelmed by the sight of it in
the flesh vs. pictures as some others have been.
Inside, I liked the car a lot. The big wood dash, guages, and everything
else are very Jaguar IMHO. Although, I’ll agree with Mike Cogswell that the
wood/leather hybrid steering wheel is quite silly. It does not seem to have
quite the legroom of my XJS, and there is a very misfortunately placed ridge
under the dash which will hit tall people’s left knee on entry/egress.
No sooner than I had sat in the car and popped the hood, the salesman ran off
to get the keys. He obviously wanted to go for a ride as much as I did. To
me, the engine looks like an engine. I don’t think it should necessarily
have to look like a “Jaguar” engine. I’m not sure which looks worse, the
plastic molded Jaguar logo on the XK8 intake, or the peeling Jaguar sticker
on my old V12 cam cover.
Now for the driving: (BTW I’m not a racing expert, I just drive normally)
The saleman had to drive the car off the lot (some insurance requirement),
and right from the get-go he was flooring it. I had to put my seat belt on.
This guy obviously was not going to be upset no matter how I thrashed the
car on the test drive. The engine is not as smooth as the V12. When it
idles it vibrates the car just a bit, and while driving it makes more noise.
It’s not bad noise, just not the silence of the V12. Perhaps for the
overall charachter of the XK8 a bit more noise is well suited. Generally the
car felt much lighter, much tighter, and MUCH faster than the XJS. It goes
round corners feeling like it’s on rails, and I could not get the tires to
spin. I used to consider myself a dyed-in-the-wool manual trans. type, but
the auto in the XK 8 is different. I have no idea how it works, but you
really can make it behave like a manual. I was surprised. The more I think
about it the more I think I might actually prefer the automatic (remember,
I’m not a race car driver).
Having said all that, I returned, got out of the car, looked at it, looked at
the '95 XJS V12 Convertible sitting next to it and thought: This new car
just doesn’t have that slight excessiveness, the ever so slightly ballsy body
style, the aristocratically accepted flaws of the other Jaguars. It reminded
me of excercises in market segmentation, and computerised attribute selection
to please the largest amount of the people the largest amount of the time,
and to offend nobody. It reminded me of the recent thread about Series III
vs. XJ40.
THEN that’s when he said they had a newly arrived convertible in the back and
I could look at it.
I must say that EVERY mediocracy of styling in the coupe vanished in the
convertible. The tail end of the convertible looks fabulous with top up or
down. With the top down, looking fromt the side the whole car is perfect.
It’s amazing how different the whole car looks in convertible form. That
was when I realized that the XK8 continues another Jaguar trend: as in the
Etype, and especially the XJS; the convertibles look infinitely better than
the coupes. I think the Convertible XK8 is fabulous.
Julian Mullaney
End of jag-lovers-digest V2 #429
Return-Path: @owner-jag-lovers-di1
Received: (from majordom@localhost) by ekeberg.sn.no (8.7.5/8.7.3/on4)
id for jag-lovers-digest-out; Sat, 12 Oct 1996 02:42:48 +0200 (MET DST)
Date: Sat, 12 Oct 1996 02:42:48 +0200 (MET DST)
Message-Id: 199610120042.CAA16422@ekeberg.sn.no
X-Authentication-Warning: ekeberg.sn.no: majordom set sender to owner-jag-lovers-digest using -f
Subject: jag-lovers-digest V2 #430
Reply-To: jag-lovers@sn.no
Errors-To: @owner-jag-lovers-di1
Precedence: bulk
X-Newsgroups: mail.jag-lovers-digest
jag-lovers-digest Saturday, 12 October 1996 Volume 02 : Number 430
Jack Stands
XJ6 brakes
XJS wheels
Concours VS Driven
Footnote on the XJ40
Re: [SIII XJ6] Oil and oil pressure. Today’s entertainment
71 E-Type
Concours Judging
Re: Concours VS Driven
XJ-S Repair Manual
Re: Concours Judging
E-Type resleeved master cylinders
Re: XJS wheels
Re: T-shirts with jag-lovers@sn.no on 'em
Found an ‘S’ type grill
Carb rebuild
Re[3]: H&E Convertible Fuel System
Date: Fri, 11 Oct 1996 12:27:35 -0500
I personaly would not want to be under a car on 24" jack stands, thats to
high and spindly. Mine are at most 18". And like someone else said, after
putting the car on stands I place the floor jack under the car and take just
a bit off the tension on the jack stands for insurance.
BTW, NEVER go under a car held up by a hydraulic jack alone.
One failure mode on a hydraulic jack is instantaneous collapse where as a
jack stand may bend slowly (note I said MAY) and further, since you have two
of them, maybe the other one will protect you (note I said MAYBE).
A simple rule of thumb, never trust anything above you that weighs more than
you do.
Even with both I dont like being under the car. At my age it takes me
longer to get out from under a falling car so I am cautious. I once had a
car fall on my hand and one of my fingers has not been the same since.
JIM I.
“Prefiero morir de pie que vivir de rodillas.”
Gen. Emiliano Zapata
1879-1919
Date: Fri, 11 Oct 1996 15:09:00 -0400
Subject: XJ6 brakes
Some time ago there was discussion about failure of the reaction valve
| on the vacuum booster. When this sticks the brake pedal goes to the
| floor. this has happened recently to me. I have ordered the rebuild
| kit, but was wondering if there was any tricks to installing it. I
| wish I had kept all the previous correspondance about this topic.
| Any advice would be welcome.
| Gene johnston '72 XJ6 '53 MK7
Date: Fri, 11 Oct 1996 12:44:38 -0500
Subject: XJS wheels
My '82 XJS has the “starfish” wheels. I also have a set of the “Fau Spoke”
wheels. I think it came orriginaly with the Starfish wheels but am
wondering if the fake spokes were also available in that year or are they a
later thing.
JIM I.
1879-1919
Date: Fri, 11 Oct 1996 12:12:09 -0500
Subject: Concours VS Driven
I dont have a problem here in Austin. There is a driven class. In fact I
am putting my '85 XJ6 in the driven class on Sunday to see how good a job we
did in the resurection of “Old #25”. I have never done this before and it
is not the start of a concours mind set, just a quiriosity since the car
came out so well after the “total”.
If any of you are judges or have experience in JCNA events, I am wondering
how many points I will be sacrificing by having a small leaper on the hood,
XJS wheels and straight exhaust tips.
There was once talk of a “Modified” class where it was net required that
everything be as sold, but could be improved, if it realy was an
improvement. I think it would have been very hevy on points loss for a
lump. Has anyone heard anything about that prpposal?
Our local club has three classes, the regular concours which includes
“trailer queens”, the Driven class which requires that the car actualy be
driven to the concours grounds, and the Wash and Show class for those who
dont feel like doing alot of work on their car. This later class is not
JCNA sanctioned, only a local thing.
JIM I.
1879-1919
Date: Fri, 11 Oct 1996 15:41:54 -0400
Subject: Footnote on the XJ40
As many of you know, I just bought an 89 XJ40 VDP. One feature on
the car, however, (which I understand is a standard feature) I could live
without. I’m talking about the automatic shoe cleaning device that self
activates when cornering to shower the driver’s shoes with an
(in)appropriate amount of water. I plan on investigationg/maybe fixing
this “feature” this weekend. Any pointers would be appreciated.
(Please, no suggestions to put an umbrella on my toe).
Date: Fri, 11 Oct 1996 12:48:24 -0700
Subject: Re: [SIII XJ6] Oil and oil pressure. Today’s entertainment
3000rpm (both hot), but what is that in psi or Kg/cm2? Help!Gunnar,
300Kpa =43.5 PSI=3.06 KG/cm2
600Kpa =87 PSI=6.12 KG/cm2
At least thats what I get from my conversion tables. I guess selling
flowmeters comes in handy occasionally. BTW, thanks for all of your
help on the Jag parts page. It is phenomonal.
Dan Buringrud
68 XKE ots
95 Ford Mustang GT Convertible
Date: Fri, 11 Oct 1996 16:34:55 -0400 (EDT)
Today I decided to arrange to have my front end aligned (1987 XJ6) as
the car has developed a tendency to veer slightly to the right. I
figured this ought to be a “Mr Goodwrench” level task, but I ran into a
brick wall of resistance at the two local shops I tried, the nearest
Jaguar shop being sixty miles away. The first just refused to consider
it and gave no explanation.
I had a really bad power steering leak in my 89xjs and it was not
driveable for any great distance (for fear of damaging the pump), so I
took it to one the local garages.
One of the mechanics told his supervisor, “I aint working on no F*ing Jag”
An older guy raised it and took a look underneath. Ironically, after a
couple minutes, every guy in the establishment (6-8 men) was underneath,
checking the machine out. The dual exhaust, the V12, and everything else.
They started it up, turned the wheel a bit, and 4 of them were sprayed
good with Dexron-III.
That incident aside, I found a shop about 40 minutes away where they are a
bit more experienced with my car. I’d lost a couple quarts of antifreeze,
so I had him check it out. He pressure tested it and he didnt charge me. I
will take it there next time I need some work done.
- -Jason
Date: Fri, 11 Oct 1996 22:52:51 +0200 (MET DST)
Forwarded to: SMTP[Jag-LOVERS@SN.NO]
cc:
Comments by: PLacey@Petrol@SwRI08
Comments:
In response to Steve Draper
This water “leak” is a common problem with my XJ-40. It is due to the drain
pipe from the heater system blocking. The drain pipe is located at the
drivers side (U.S.) in the inside corner of the footwell beside the
accellerator pedal. Just pull off the tube and push a piece of wire up in
the plastic connector and a rush of water will normally follow as you
dislodge the blockage.
On a separate issue. Recently, the heater fan on my 1988 XJ-40 has taken on a mind of its own. In the low and medium settings it cuts in and out (even in manual mode), but in the high setting appears to be OK. Any thoughts? How do I even start to diagnose this computerized system? Paul Lacey, Texas [Original Message] ------------------------- As many of you know, I just bought an 89 XJ40 VDP. One feature on the car, however, (which I understand is a standard feature) I could live without. I’m talking about the automatic shoe cleaning device that self activates when cornering to shower the driver’s shoes with an (in)appropriate amount of water. I plan on investigationg/maybe fixing this “feature” this weekend. Any pointers would be appreciated. (Please, no suggestions to put an umbrella on my toe). From: “Robert A. Bagramian” robtbagr@umich.edu Date: Fri, 11 Oct 96 17:04:44 -0400 Subject: 71 E-Type To Lloyd and others about the 6 cylinder 71 E-types… Not sure about serial numbers but the 71 (6 cylinder) cars had a chrome bead around the mouth of the air intake on the hood and a black plastic jaguar emblem on each side of the hood at about the level of the battery. Bob Bagramian… 70 XKE, 71 XKE, 72 XJ6, 88 XJ40 From: Ryan Border rborder@hpspls16.cup.hp.com Date: Fri, 11 Oct 1996 14:27:34 -0700 Subject: Concours Judging Chip Weems writes: I got certified as a JCNA judge this Summer. Athenticity comes last, but can cost some big points… There are a few biggies like having tires that are the wrong size and type One thing that I would personally like to see excepted from the authenticity requirement is safety devices – I think it is a shame to take points off because somebody put 3-point seatbelts in a car that wasn’t built with them as an option. I agree with your idea that the addition of safety devices should be allowed. And, since this exception isn’t allowed now anyway, this is really a moot point… but wouldn’t (shouldn’t) modern radials be considered a saftety item when compared to the bias ply tires of days gone by? It’s hard enough for the driven cars to compete with the trailer queens; but, to me, it just adds insult to injury that the judges demand that owners must suffer with archaic tire technology if they want to participate. Poor performance doesn’t just take away from the enjoyment of driving a car- stopping sooner, cornering harder, maintaining traction in the wet are all things which can help a driver in an emergency situation. For JCNA to (through their judging rules) coerce their members to use old tire technology seems… well… irresponsible. Then again, my car’s not a concourse contender anyway- so what do I care… Ryan. 205 65VR15 Bridgestone Turanza’s (on my '59 MK1) And, an A&W Root Beer for me. From: Chip Weems weems@cs.umass.edu Date: Fri, 11 Oct 1996 17:12:09 -0500 Subject: Re: Concours VS Driven At 12:12 PM -0500 10/11/96, Jim Isbell wrote:
Not sure about the authenticity of the leaper and wheels – if the car
could be ordered with these as options, then there shouldn’t be a deduction.
If not, then (and I’d have to check the judging guide to know the exact
number) you could lose about half a point per wheel (actually, the
judges work on a sheet of a thousand points, which gets divided by 10
for concours, and I think it was 5 of these points per wheel as a maximum).
But many judges will take less than the maximum for incorrect Jaguar
wheels vs. non-Jaguar. The exhaust tips would likely cost you another few
tenths.
Yes, the modified class exists. I could look it up if you want the
details. It is, however, for cars that have been significantly modified,
rather than just as a way for people to avoid deductions for minor
non-authenticity. Heavily performance-modded engines are often shown
there, as are the occasional custom body.
Chip
Date: Fri, 11 Oct 1996 17:52:55 -0400
Subject: XJ-S Repair Manual
There has been much talk about repair manuals, and one route to go is
to order the full repair manual. Hal Rogers offers these at a good price.
What I got was the “Repair Operation Manual” for the XJ-S, which
incorporates “HE & 5.3 Supplements” and is printed by Jaguar Cars Ltd.
This book cost 74.95US from British Car Magazine. The book includes
supplement A (1979-1984) and supplement B (1984-19881/2). It is a
single softbound volume and seems fairly comprehensive. The book
includes repair procedures and illustrations, wiring diagrams, and
maintenance schedules. The book, I think, is VERY useful.
I haven’t seen the set Hal sells and I believe it is more comprehensive
than what I have, but the single volume I’ve got more than suffices for
what I’m capable of doing. I’d say if you need to cover every base,
order the full factory set; if you can get buy with a single volume, maybe
the one I’ve got will do. British Car Magazine is at 1-415-949-9680, and it
is their book # B-J85WH.
If anybody has any questions about what specifically is in this book,
feel free to e-mail.
Date: Fri, 11 Oct 1996 17:58:24 -0500
Subject: Re: Concours Judging
gone by?It’s hard enough for the driven cars to compete with the trailer queens;
owners must suffer with archaic tire technology if they want to participate.Poor performance doesn’t just take away from the enjoyment of driving
I have been told that on the XK’s and earlier cars, radials are actually
less safe because they put stresses on the suspension that it was not
designed for, and that it can cause failures that would result
in accidents. Certainly for the XK’s and earlier, bias ply tires are adequate
for most driving they will see.
The S1 E-type presents an interesting transition period. Later E-types
were definitely designed to take radials. The S1 wasn’t but people
seem undecided as to whether the front end is harmed by their use.
I should also note that a common trick in driven class is to have
a set of concours wheels that one substitutes for the drivers –
it is a matter of how much effort it is to swap wheels as opposed
to cleaning every spoke and all the rubber after driving to the
event (and how much the owner feels like paying for extra wheels
vs. using elbow grease). Obviously, if the owner believes radials
are OK on their S1 E, then they can keep a set of bias tires on
the show wheels.
Also, just being radial wouldn’t result in a full deduction – the
size of the tire and the authenticity of the wheel are part
of the equation. So, for example, to get a full deduction, I would
have to see oversize radial tires on painted wire wheels with the
wrong number of spokes on that S1 E. Even then, we’re talking about
something like 2.5 points total deduction (i.e. 97.5 point score if
everything else is OK).
Some people go to the golf course to WIN. Others go to have a good
time. The same is true of the concours. I wouldn’t ever go there expecting
to win, but I do have a good time, enjoy having people ooh and ahh
over my car and ask me about it, learn a bit more about caring for
it, and it’s a great excuse to do a thorough cleaning of it each
year (which is really good for it). I also enjoy looking at other
people’s cars and talking with Jag lovers and browsing the swap
and vendor tables.
As a judge, I much prefer to deal with people who are there for a
good time than the person who can only think of winning.
Chip
Date: Fri, 11 Oct 1996 19:27:57 -0500
Subject: E-Type resleeved master cylinders
It “do pay” to ask questions. I assumed that the resleeved master cylinders
I got back from Imperial Machine would be rebuilt and ready to bolt on. Not
so. The master cylinders had been properly resleeved in stainless steel,
but all the greasy innards were returned in a zipper bag. The $60 price for
each was right (I’ve seen prices as high as $120); I’ll now have to get two
refitting kits to complete the job. The Service Manual on Page L.12 shows a
master cylinder piston with a rubber sealing ring about midway. Both of my
pistons (for a 1964 E-Type) don’t have this feature. They do have rubber
cup seals and the seals at the end of the valves.
The master cylinder for the rear brakes was not leaking fluid, but it had
to be removed to get at the leaking bottom unit (for front brakes) and
would eventually need servicing, so it probably was wise to have both units
resleeved.
Question: Do the rubber cup seals slip over the pistons or does one have to
dismantle the valve unit, and remove the springs, in order to fit the cup
seals?
As to bleeding the brakes…I found that you just can’t gain access to the
inboard rear brake bleed nipples with an open-end wrench and go about the
bleed operation in a matter of minutes. Oh, no. The springs and shocks are
a real obstacle. What to do? One must remove the rear suspensions forward
spring-shock unit. Can’t do this with the car raised on metal ramps. This
means an investment in jack stands and jack stands require a rolling floor
jack. I hit a bunch of those discount auto parts stores plus Odd Lots and
found only 17" jack stands and rinky-dink Made in Timbuktu floor jacks.
They all were as cheap as sin, but I wouldn’t trust my torso to such junk.
Then I went to Sears. Eureka! They have 24" sturdy jack stands of pro
quality for $40 a pair. They have el cheapo rolling floor jacks for about
$50, but the max height is 19 inches. The next higher price is $99 for a
jack with 21" maximum lift and a six-ton rating. It’s close to being of
professional quality and is backed by the Sears no-nonsense quarantee. So
I’ve decided to get the $99 unit.
I’m not going to take chances with elevating the Jag with four jack stands
and possibly ending up at the bottom of a Jag sandwich. I thought I had
wasted my money on metal ramps, but they can be used to stablize and
elevate one end of the car as it is perched on the two jack stands. I
intend to keep the floor jack in place (if there is room to work) as
insurance should we have a Level 6 earthquake here in the hills of
southeastern Ohio. We actually had a slight tremor in Athens in 1986 and I
have a crack in my office wall to prove it.
Date: Fri, 11 Oct 1996 19:25:50 -0005
Subject: Re: XJS wheels
later thing.
Faux spokes came later. In the mid-80’s, you could buy an XJ-S
right off the showroom floor with BIS wheels (not made by Jaguar)
faux spoke wheels. Dunno if they were an official option or a
dealer-installed addition. Later, possibly along with the
introduction of ABS brakes, the XJ-S came fitted with Jaguar faux
spoke wheels of their own manufacture.
– Kirbert | If anything is to be accomplished,
| - Palm’s Postulate
Date: Fri, 11 Oct 1996 19:49:36 -0500
Subject: Re: T-shirts with jag-lovers@sn.no on 'em
A couple of people seconded this idea: I think I'll start wearing some kind of identifier such as jag-lovers@sn.no on a T-shirt when I attend things like rallies or XKU open house, etc. And, unless someone *really* wants to be in the T-shirt business, I'll just go get my own, in BRG. Lands End has nice t-shirts etc., but they only monogram up to 10 characters. Every shopping mall has a custom t-shirt store, it should be easy to get one made up. David '70 XKE 2+2 '84 XJ6 VDP
Consider this: Line art of E-Type (or whatever you "love") surprinted
on a red heart. Text under this art element could read: @sn.no. Those of us
on the list would identify the T-shirt wearer as a list member. Others
would be very much confused. And that would be good.
Date: Fri, 11 Oct 96 16:00:55 PDT
Subject: Found an ‘S’ type grill
Hi
Earlier this week I asked if anybody knew where I could find a grill for my ‘S’
type. Well I found one, unfortunately it’s still attached to the car.
I now own 2 1965 ‘S’ type jags. The new one is in overall better condition than
the first, the wire wheels are perfect, it has original tool kit, the wood has
been restored, the only down side - all purist sit down it has a ford V8 in it.
The engine blew last weekend so the price was right. Problem do I keep the ford
or put all the best bits on one car with the jag engine!
Best regards
Steve.
And I’m still married!!
1974 TR6
1971 Jensen Interceptor
1965 ‘S’ Type Jag X 2
1992 Explorer
1993 Ninja
1986 Cobra (RV)
Date: Fri, 11 Oct 96 16:05:06 PDT
Subject: Carb rebuild
Hi
I need to rebuild the SUs on my 65 ‘S’ type in the very near future.
Can anybody advise me of the best rebuild kit to use. I’ve noticed a few
different suppliers that supply them. Are these kit complete i.e. do they
include bushes for the spindles etc.
Burlen in the UK have 2 kits one is quite expensive by comparison to some of the
others but is supposed to have everything in it.
Any advise greatly appreciated.
Best regards
Steve
Date: Fri, 11 Oct 1996 20:38:20 -0500
Subject: Re[3]: H&E Convertible Fuel System
All: I sent this last night, but jag-lovers bounced it.
Kirby: Is this the only message you received from me that looked
strange?
MikeC
______________________________ Reply Separator _________________________________
Subject: Re[2]: H&E Convertible Fuel System
Author: Mike Cogswell at ZDS_FEDS
Date: 10/10/1996 2:36 PM
Kirby: I'm posting this reply to the whole list, since others may
find the information useful until I can write an H&E supplement for
your book.
<Kirby asked me for suggestions regarding an H&E convertible where the
gauge doesn't work properly and the owner reports he can only add 12
gallons to a 24 gallon tank>
It doesn't switch between tanks. That would be entirely too simple.
The short story is:
In order to make room for the folding top and it's mechanism H&E had
to take the standard tank and cut part of it off. It would appear
they literally cut the tank and welded in a sloped section. To regain
fuel capacity, they added a second tank under the parcel area,
basically where the rear seat would have been in a coupe. The upper
tank is about 14 US gal. and the lower is about 11.
As you know, the standard tank has a sump from which the high pressure
fuel injection pump draws its fuel. Since the second tank is lower
than the first H&E added two concentric hoses. The larger outer hose
allow fuel to gravity drain into the lower tank from the upper (which
is where the filler neck is located.) Consequently, the lower tank is
always full until the upper tank goes dry. Meanwhile, a small
submerged pump constantly pumps fuel from the bottom tank to the top
tank via a small tube that is located in the center of the large drain
hose. The fuel is dumped into the upper tank's sump, where it is
available to the main fuel pump. The submerged pump can pump fuel
faster than the engine consumes it, but any in excess of the sump
capacity will drain right back into the lower tank. Both pumps only
run when the ignition is on and the standard pump circuit is
energized, so all the regular safety interlocks still work.
None of the above has any relationship to how the fuel level gauge
works (if at all.)
Each tank has its own fuel level sending unit. The upper unit is
apparently the standard XJ-S tank unit. The lower one is similar,
except the mounting plate is horizontal instead of vertical. The two
gauges are wired in series. There is a small circuit board in the H&E
harness that theoretically turns on the low fuel level light.
My gauge is wildly inaccurate. Because they are in series I'm
guessing that my top one basically hits bottom well before the bottom
one starts to drop. As a result, my gauge is very non-linear. I has
also developed a dead spot, where it reads zero for a gallon or so.
Obviously a bad spot in the winding on a sender. It is low enough on
the gauge that it is after the top sender has reached zero naturally.
I can't imagine why he can't put more fuel in, unless the gravity feed
to the bottom is blocked. The hose is only about 1.5" in dia. and has
a vent tube and the feed tube running down the middle. It seems much
more likely to me that his gauges are simply way off. He probably
can't put more in because that's all he has used. Suggest he drive by
the computer (reset when full and use the fuel used part) until he
approaches 20 gallons used. Then see how much he can put in. He
might also want to drive around until he actually runs out (carrying a
can with him!) Then he can see how much it really holds and how far
he can go on a tank. I did that on my E-Type and just reset the
odometer to zero whenever I fill up. My odometer works a lot better
than my gas gauge!
On the other hand, if he runs out of fuel while driving and then can
only add 12 gallons I'd say the lower fuel lift pump is dead. That
way almost half his capacity is trapped in the lower tank with no way
to get to the main pump.
On my list of things to do is to build a small A/D and D/A card with a
microprocessor. Then I can take any car, run it dry and program it to
equate a specific analog input to every whole gallon of capacity.
Then program the output to create the correct outputs for empty,
quarter, half, three-quarters and full on the gauge. The processor
can then interpolate what output to use for each gallon point from
zero to full. As long as you can bend the float wire so the sender
can read something over the entire range you can then have a very
accurate gauge.
MikeC
Hope all this helps. Let me know if anything helps this guy.
End of jag-lovers-digest V2 #430
id for jag-lovers-digest-out; Sat, 12 Oct 1996 11:14:16 +0200 (MET DST)
Date: Sat, 12 Oct 1996 11:14:16 +0200 (MET DST)
Message-Id: 199610120914.LAA23895@ekeberg.sn.no
Subject: jag-lovers-digest V2 #431
Precedence: bulk
jag-lovers-digest Saturday, 12 October 1996 Volume 02 : Number 431
List
XJ6 series 3 carpets, which are orriginal?
Oil Change
XK8 Price
Southern Arizona Jaguar Concourse
auto (Jaguar) event in New York
XJ40 Oil Change
Re[4]: Polished E-Type/Beer
Engine stop [was: Re[4]: …crossover pipe (XJS)]
Re: Leather Interiors
Re: Oil Change
RE: Footnote on the XJ40
Date: Fri, 11 Oct 1996 20:53:30 -0400
Subject: List
Firstname Chris Margiotti
Surname ****
Address 4637B Ocean Pines
City/Town Berlin
State/County MD
Zip/Postcode 21811
Country USA
Phone Nos etc
Home (410)208-2516, (610)660-2235
Office ****
Fax available
Email cm082350@sju.edu
http:// ****
Car 1 Jaguar
Model1 XJ12C
Colour Silver (some day)
Interior Black
Year 1974
Mileage says 64,000 shows 100,000 +
Condition in restoration
Likes/Dislikes limited room in engine compartment
Remarks **** (eg other cars, kids, anything you like)
Date: Fri, 11 Oct 1996 19:12:36 -0500
Subject: XJ6 series 3 carpets, which are orriginal?
My '82 XJ6 has two sets of carpets. The lower set which is on the metal
floor have a rubber square (drivers heal) with the word Jaguar on it. On
top of these carpets are two (one on each side) rugs that cover the lower
rugs. The second set had an embroidered square at the place of the rubber
square below. In the lower right side of the square is a black Jaguar leaper.
Which of these was orriginal equipment? Or were they both orriginal? I
will be showing the car on Sunday and would like it to be as near to correct
as possible.
Jim
“Better an outlaw than not free.”
Nance O’Neil
Date: Sat, 12 Oct 1996 10:27:32 +0900
Subject: Oil Change
How do you dispose the old oil in your place. Does the retailer
take it back?
Regards
Makoto Honjo
Phone/Fax +81-3-3473-1848
Subject: XK8 Price
For what it’s worth, my son tells me that his favorite, the Big Mac
Set, which includes a Big Mac, bag of chips , and a large “pop,” costs
about US$5.00. I’d think that by the Big Mac indicator, prices are
becoming pretty competitive in Japan.
Regards
Makoto Honjo
Date: Fri, 11 Oct 1996 20:38:16 -0500
Chip,
I will have to differ with you on radial tires on XKs. I have had them on
both my cars since I have owned them for over 12 years. No ill effects have
been noticed. The general ride and handling improvement is well worth the
change and the point deductions. I will never have bias ply tires on any of
my cars! Some American cars of that vintage did have problems with radial
tires.
I also have friends who have been driving XKs since the 1950s and they have
not had any problems either. And they drive their cars much harder than I do!
I agree with your other comments. I have found Concours to be a good way to
meet other people with the same interests. I find it sad that people won’t
go to a Concours because of the preconceived notion that Concours consists
only of “trailer queens”.
Cleo Bay
52 XK120
56 XK140
62 E-Type
65 3.4S
members to use old tire technology seems… well… irresponsible.I have been told that on the XK’s and earlier cars, radials are actually
for most driving they will see.The S1 E-type presents an interesting transition period. Later E-types
seem undecided as to whether the front end is harmed by their use.I should also note that a common trick in driven class is to have
the show wheels.Also, just being radial wouldn’t result in a full deduction – the
everything else is OK).Some people go to the golf course to WIN. Others go to have a good
and vendor tables.As a judge, I much prefer to deal with people who are there for a
good time than the person who can only think of winning.Chip
Date: Fri, 11 Oct 1996 18:30:02 -0700
Subject: Southern Arizona Jaguar Concourse
The local chapter of the JCNA, Jaguar Club of Southern Arizona, is
sponsoring a Concourse next Saturday, October 19th at the St. Phillips
Plaza in Tucson, AZ. Cars will be lining up at 8AM and judging will be
at 10AM.
I’m going just to take pictures of the cars. Maybe, if any of them turn
out, I’ll post them on my web site.
Date: Fri, 11 Oct 1996 21:20:49 EDT
Subject: auto (Jaguar) event in New York
Hi Gunnar,
If you are going to be in the New York City area next weekend on Saturday
October 19 you might want to try to get out to Bridgehampton, Long
Island, about a 2 hour drive from NYC. The Bridgehampton Historical
Society is running its third road rally for cars built 1954 and earlier.
This is meant to be a recreation of the early road races through the
streets of Bridgehampton prior to the construction of the race track. I
will be competing as navigator in a 1953XK120 drophead (there were
several XK’s last year) and there is at least one original C-type
registered (there will probably be two the other being Tony Wangs car
which ran last year). We even had an SS100 last year. Don’t know if
they are entered again. Judging by last year there should be around 40
entries total ranging from the 1900s on up.
Jaguar Cars is a major sponsor for this event and they had several new
cars on display last year as well as other classic jags. I will have my
62 E roadster on display with the new Jags again (one women tried to get
in the car and demanded to know when she could have her new one
delivered!!! She was devastated to learn they had not made one in over
20 years). I’m sure they will bring an XK-8 and no doubt it will be the
main attraction this year. Can’t wait as I have not seen one “in person”
yet.
First car is off a 10 am Saturday and last car should be in by 4 pm. If
you want to see all the cars best to be there by 9:30 am and see them all
off (around one every 3 minutes). This is a real fun event and beats a
static concours display hands down.
If you think you might attend and need any additional info let me know.
Frank Filangeri
Date: Sat, 12 Oct 1996 12:41:43 +1000 (EST)
Subject: XJ40 Oil Change
Reply to Brian Kelly. I sent this to your email address, but it bounced.
Brian: My car is a 1989 Sovereign, but I believe that in important respects
it is similar to yours. My very strong advice is to have front and rear
wheel bearings repacked with grease, which involves dissembly and will take
a few hours. The XJ40 has no means, other than dissembly, of repacking the
bearings and there have been some catastrophic failures. Normally you would
expect a bearing failure to damage only the bearing and possibly the axle,
but the rear end of XJ40s have been known to lock solid and destroy the
bearing housings - a very expensive repair job. I understand that at first
Jaguar would not believe that this could happen, but there were finally too
many failures for them to ignore so they now recommend the repacking at
about 50000 km intervals, which is probably more often than necessary as I
don’t think any failures occurred under 1000000 km. Use a high temperature
lithium base bearing grease. Also, the front bearings rotate on the axles
and wear the axles. The use of Loctite helps overcome this problem. Other
than the brake system, in which the accumulator doesn’t last as long as I
think it should, the car has few other real faults and if properly serviced
should be very reliable. I used Castrol GTX3 for the first year or so and
have now changed to Castrol TXT, which is a semi-synthetic 10W-40. I can’t
give any long term assessment, but the change was to have an oil which was
lighter when cold to reduce the start up wear. I expected to notice an
increase in oil consumption, but haven’t so far. Good luck. Alan
Date: Fri, 11 Oct 1996 22:38:24 -0500
Subject: Re[4]: Polished E-Type/Beer
This is a Mime message, which your current mail reader
may not understand. Parts of the message will appear as
text. To process the remainder, you will need to use a Mime
compatible mail reader. Contact your vendor for details.
- –IMA.Boundary.154880548
Content-Type: text/plain; charset=US-ASCII
Content-Transfer-Encoding: 7bit
Content-Description: cc:Mail note part
I think you misunderstand my basic question completely. I have absolutely
no problem with anyone who has managed to achieve a genuine showroom “like
new” condition on their car. I would expect nothing less in cars that
aren’t entered in a “driven” class. Even if I had the time and patience to
achieve such a high degree of cleanliness, and the money to replace
everything that would have to be replaced (nothing in the world looks like
a brand new radiator hose except a brand new hose), I’d just hop in it and
go blasting down the road. Every new car I’ve every owned has been turned
into a concours loser because I can’t resist driving it, rain, mud and
construction sites notwithstanding. But I don’t envy a person who does
maintain a showroom condition car, I admire him and his car.
My basic question remains. It seems to me that I have seen entirely too
many winning E-Types that are well beyond new condition. I’d like to see
the factory invoice where the engine compartment of a Series 3 E-Type was
buffed, polished and waxed to a perfect mirror finish before all the bits
and pieces were installed. Or one where some of the bits were polished
instead of leaving the factory as a simple clean machined surface. I
stress that I have no issue at all with fixing things like door gaps or
sloppy welds when restoring a particular car. E-Type were basically hand
welded from a lot of pieces. Body panels were made, largely by hand, by
two different companies. Inevitably fit and finish varies. When I redid
the paint on my E-Type I had the trailing edge of the bonnet and the body
cowl area recontoured so they were a much better match. I regard that sort
of thing as akin to blueprinting an engine or even just doing a great front
end alignment. The tolerances (or production practices) allow for
variance. There’s certainly nothing wrong with trying to achieve the
specified ideal instead of settling for the outer edge of the allowable.
But when I see a car that has its throttle linkage so polished it looks
like chrome, I don’t understand why that’s better than one that has a nice
shiny new steel appearance like it originally did. (Mine, of course, has
that nice patina of age you refer to, otherwise known as iron oxide.)
MikeC
- –IMA.Boundary.154880548–
Date: Sat, 12 Oct 1996 13:01:03 +1000 (EST)
Subject: [SIII XJ6] Oil and oil pressure. Today’s entertainment
Now if someone could explain to me how Kpa (Kilo Pascal) relates to the
real world I would actually know exactly how good my oil pressure is!
Gunnar. Divide Kpa by 7 for an approximate conversion to psi.
I think that a more accurate figure is 6.89. Alan
Date: Fri, 11 Oct 1996 23:05:53 -0400
I think that this is a really good point!
I’ve only been to one concours, that hosted by Ontario Jaguar Assoc. this
past summer.
My car was new (to me) and I was new to Jags. I was made most welcome and
met a ton
of very nice, interesting people and saw more jags probably than I had seen
in my life!
I live about 8 miles from the location and had a wonderful intro to E-Types
as I flew from a
ramp onto an expressway. I was accelerating “at speed” and quickly checked
my rear-view
for any jags with red lights on their roofs when I saw behind me a very
nice red E-Type!
We traveled together for the entire distance to the park and met, once
inside the park.
It’s the only way I know of to meet so many like-minded people and
see/touch/smell/hear
so many great cars. If it takes the need for originality to get such a fine
group together…
then here’s to originality!
to
won’t
consists
Date: Fri, 11 Oct 1996 23:02:29 -0500
Subject: Engine stop [was: Re[4]: …crossover pipe (XJS)]
And this is from the guy who just left a message about politeness on the list?
Do you seriously think you can break a rod or rip a plug out of the head by
trying to turn the crank with a hand wrench? There are a tools sold to do
essentially the same thing, often a plate you bolt to the block with a bolt
threaded through the plate. Just run the bolt down to contact the piston and it
holds things in place quite nicely. This is just a do it yourself version that
works with the engine together.
You don’t slam the piston into the rod, you brace it against it. If it’ll make
you feel better, put a rubber foot on the rod.
You overlooked the one great danger and the important caveat I failed to
mention… You do need to be VERY careful about valves. Obviously if the rod
interferes with the valves you could easily damage a valve and create a lot of
work for yourself.
MikeC
Subject: Re: Re[2]: Putting in the crossover pipe (XJS)
Author: Jeffrey Gram 101454.2570@CompuServe.COM at Internet
Date: 10/10/1996 6:06 PM
Hi Mike C and list
On a more serious note, you can weld a short length of rod to the end of an old
spark plug. Use it to replace a plug, hand rotate the engine (breaker bar on
that bolt you’re trying to remove) until the piston is up against the rod. Now
it’s locked for sure. Just make sure you disable the starter and hang a red
tag
so it can’t get turned over with the rod in it.
What ??!!. You must be joking. This may work on a 1000 HP
ship engine with cast iron pistons
but on any other car that is a potential suicide, at least a sure way to leave
big time
score marks, and might even break the rod or the plug or rip the plug straight
out out the head.
I’m speechless (almost). Octobers first prize for the most outrageous advice.
To fill a cylinder with concrete works well also, but oil is better…
Jeff
Date: Fri, 11 Oct 1996 23:14:47 -0500
Subject: Re: Leather Interiors
- –IMA.Boundary.016090548
I certainly agree that the Jags have generally gotten more luxurious (if by
that we mean more wood and leather) over the years. I was reading about
the original XJ-S last night. It was introduced with no wood at all and
the only leather being the seat facings and steering wheel. My '88 XJ-S
has much more leather and a considerable amount of wood.
By the way, the seats in a Series 3 E-Type (at least in my '74 US market
OTS) are only leather faced. The strip around the seat cushion that forms
the sides, front and back is vinyl. The edges (sides) and back on the
backrest are also vinyl. Only the pieces your butt and back actually touch
are leather. I was pretty sure that the armrest cushion was also vinyl,
but I’ll have to look at it again to be sure.
MikeC
Subject: Leather Interiors
Author: “John P Bednarski” jackb@epix.net at Internet
Date: 10/10/1996 6:47 PM
The amount of leather used in the interior seams to increase as the years
go by. My S III XKE has leather seats and backs. The console arm rest is
also leather. The rest is vinyl.
On the 90 VDP everthing except the dash is leather. The same is true with
the 95 XJS V12. You can really smell the hides in these cars.
Jack Bednarski
71 XKE V12
90 XJ6 VDP
95 XJS V12 Conv
- –IMA.Boundary.016090548–
Date: Fri, 11 Oct 1996 23:32:22 -0500
Subject: Re: Serial Number strangeness
- –IMA.Boundary.250290548
These are some great questions. When I was trying to get some information
to answer one of Lloyd’s questions, I ran into an interesting anomaly. In
the most complete E-Type reference I’m aware of the end of production was
given (if I remember right) as 10/71. The anomaly is that in the appendix
where he lists many changes to the cars, along with the month and body (or
engine) numbers where they went into production, he lists changes and
affected body numbers at least through 12/71. I’ll try to bring the book
in and leave a message with some examples.
Your other issue, regarding the cars year is a bit more complicated. In
the US, Jaguar Cars seems to have tried to match the US concept of model
year and tried to stick with the Fall to Fall cycle. I wonder if this was
the case in England or other countries. It also seems apparent that in
many places the cars get registered by the year they are shipped from the
factory or by the year they are sold. Since I understand that Jag didn’t
ship the last of the E-Types from the factory to dealers until sometime in
'75 (long after the last one was made) I guess I’m not surprised anymore by
the occasional ad for a '75 E-Type, although I think most of us would tend
to say there is no such thing.
MikeC
Subject: Serial Number strangeness
Author: Tommy tommy@peterboro.net at Internet
Date: 10/10/1996 6:34 PM
Hey Lloyd and All Good Jaggers:
I remember reading somewhere that a small quantity of the series 2 E-Types were
m anufactured in 1971 just before they starting fitting it with the V12 and
various body changes and hence the series 3.
I have (I think) a 1971 series 2 E-Type that was originally imported to Canada
(I think). It was sold and I bought it as a 1971 and I’ve always understood it
to be a 1971. It’s a 4.2 litre and has the series 2 body style. I have the car
number, body number, gearbox number, and the engine number but the name plate
indicating the date of manufacture is missing.
The car (vehicle) number is 1R12449 and the body number is 4R6986.
So Lloyd, and others, what exactly do I have? Aside from a year’s worth of
restor ation ahead of me. ;>)
Of all the world beers, Canadian beers are best (Brick Amber Dry, Niagara
Gritsto ne and Olde Jack, Upper Canada Dark Ale). So there. Case closed!
- –IMA.Boundary.250290548–
Date: Sat, 12 Oct 1996 04:47:13 +0100 (MET)
Subject: Re: Oil Change
take it back?
Yes they do, they are required to by law. Here in Norway we have
“special/toxic waste return stations” that will take oil, used car
batteries and stuff like that. Companies have to pay a small fee to
deliver waste, for private persons it’s free.
Gunnar
Gunnar Helliesen | Bergen IT Consult AS | NetBSD/VAX on a uVAX II
Systems Consultant | Bergen, Norway | '86 Jaguar XJ6 4.2 Sovereign
gunnar@bitcon.no | http://www.bitcon.no/ | Vicki who? What .sig virus?
Date: Fri, 11 Oct 1996 21:31:39 -0700
Subject: RE: Footnote on the XJ40
Steve,
I had the same problem on my 87. It seems that Jag designed a rubber drain “bulb” that sits at the bottom of the plastic air intake duct (open the bonnet and look at the firewall, just behind the engine on the intake side). This bulb has a slit in the bottom, I suppose to let water run out. The problem was that the PO had probably parked underneath pine trees most of the time, and the bulb was jammed solid with pine needles. Ergo, every time it rained, the water built up in the fresh air intake and ran into the fan ducts on either side, and onto our feet.
The bulb is held on with a single hose clamp; it’s easily removed and checked. I assume the purpose of the bulb is to act as a simple one-way valve – water can flow through, but engine oil, coolant and smoke from under the hood would not go up through the bulb. Make sure it’s free of obstructions, and that the slit opens easily.
Mike Everatt
1987 1/2 XJ40
Learning more every day
Sent: Friday, October 11, 1996 12:41 PM
Date: Sat, 12 Oct 1996 02:29:21 -0500
Subject: Re[2]: Polished E-Type
- –IMA.Boundary.005111548
Great! Thanks for the complete reply. I guess you basically confirmed my
suspicion that overdoing the polishing is rewarded more than striving for a
pure factory new appearance. I appreciate all the detail and information
you included. You also answered another question that puzzled me. I’ve
seen a couple of non-driven Series 3 E-Types that have dual outside remote
mirrors. Since I have the same setup on mine, I know it’s not authentic or
original. I wanted to have a second mirror when I first bought it new.
The dealer told me Jag only had driver’s side mirrors. I pointed out that
in the Jag’s home town that was the driver’s door. He said “oh” and then
ordered me a RHD driver’s mirror. I was really surprised when the first
E-Type I’d ever seen with the same arrangement was a prize winning
non-driven class car.
MikeC
Author: Chip Weems weems@cs.umass.edu at Internet
Date: 10/10/1996 5:33 PM
Mike Cogswell wrote:
I don't look down at people who try to maintain a car in perfect "like-new" condition, but I have to admit I don't understand how cars that are chromed and polished way beyond the way they were originally can be judged so highly. Any of you judges? If so, how about a discussion of how things are judged for originality, especially for appearance?
I got certified as a JCNA judge this Summer. First off, JCNA changed the
wording in the judges manual some time back to specify authenticity
rather than originality. This means that parts which are period
authentic are OK, even if not orginal (for example, there were no
outside mirrors on the S1 E-type as shipped to the US, but any mirror
that was typically mounted by dealers at that time is OK, and it can
be in any reasonable location). Chroming something that wasn’t delivered
that way will result in a deduction. Polishing something that wasn’t
polished by the factory, however, is quite acceptable –
If somebody goes to special lengths to get them to a mirror finish
vs. just nicely polished, it won’t really affect the scoring because
I won’t see the nicely polished ones as requiring a deduction.
Athenticity comes last, but can cost some big points (usually for
repeated minor errors, like having 20 nonauthentic hose clamps).
Chip
- –IMA.Boundary.005111548–
End of jag-lovers-digest V2 #431
id for jag-lovers-digest-out; Sun, 13 Oct 1996 14:13:21 +0200 (MET DST)
Date: Sun, 13 Oct 1996 14:13:21 +0200 (MET DST)
Message-Id: 199610131213.OAA08322@ekeberg.sn.no
To: jag-lovers-digest@sn.no
Subject: jag-lovers-digest V2 #432
Precedence: bulk
jag-lovers-digest Sunday, 13 October 1996 Volume 02 : Number 432
Early XJ-S vacuum advance unit
Re: Oil Change
Re: Originality or Lump?
Re: 71 E-Type
E-Type master cyl. kits
Re: Footnote on the XJ40
XJ40 Wheel Bearings
Genesis of The Jaguar V-12
Removing Fuel Tank from an E-OTS
Sometimes you just have to laugh…
Re: Genesis of The Jaguar V-12
Re: Re[2]: JACK STAND WARNING!!!
Re: Serial Number strangeness/4.2 Compression Ratio
XJ40: Trans
XJS Fuel Starvation
Re: Re[2]: XK-8 versus Aston-Martin
Re: Oil Change
Date: Sat, 12 Oct 1996 10:22:10 -0700
Subject: Early XJ-S vacuum advance unit
I would appreciate advice on the following.
My 77 and 79 XJ-S cars have vacuum advance units (VAU)which are
identical, and I think both have failed. Part number is Lucas 54429459
with the extra notation 6-10 8. I think this means that the advance
starts at 6in of mercury and reaches a maximum of 8 crankshaft degrees at
10in Hg.
The official service manual (88 edition) states that it should be 6-10 4.
Kirby’s book suggests that the VAU may be replaced by one for an MGB.
Obsolete Automotive specializes in MGs and has a Web page. They have a
VAU for an MG on sale for about two thirds of the local Jag dealer price.
It looks from the photo as though this unit would fit in my cars. A
junior employee of Obsolete informs me that the specs of the MG unit are
5-13 10. He informs me that they also have a unit for a Triumph with
specs 3-10 7 that might fit, similar price.
Questions
What are the correct Jag specs?
Is there an MG unit with the correct specs?
If not, are the available cheaper units adequate?
John Nuttall
1977 XJ-S beginning restoration
1979 XJ-S parts car
Date: Sat, 12 Oct 1996 11:16:48 -0400 (EDT)
Makoto:
In the US, or at least here in New York, auto repair shops are required by
law to take recieve used motor oil for recycling, at no charge. I save my
old oil in bottles, and take it down to the local service station a couple
of times a year.
Now a question for the jag-lovers. In Chris Harvey’s ‘E-Type End of an Era’,
hes suggests drilling a small hole in the top of the door sills, plugging
the drainage holes, and filling them with your waste oil. This has the
beneficial effect of rustproofing the sills from the inside. After a
vigorous drive to distribute the oil, you are supposed to open the drains
and remove the oil. Has anyone actually tried this? Does it work? Is it messy?
Mike Frank
1969 E-Type 2+2
take it back?Regards
Makoto Honjo
Date: Sat, 12 Oct 1996 11:51:34 -0400
Subject: Re: Originality or Lump?
I drive the car almost every day, often at 100mph+,
because that’s my interpretation of why it was built in the
first place (June 1962).
Cool,I was built in June 1962 too! (on the 17th)
Only 100mph? I think it should be good for 150mph.
If I ever get mine done I hope to do the same, you are no sap Charles!
Mark McChesney
'65 Etype ots
Date: Sat, 12 Oct 1996 12:11:20 -0400
Subject: Re: 71 E-Type
On Oct 11, 5:04pm, Robert A. Bagramian wrote:
Subject: 71 E-Type
– End of excerpt from Robert A. Bagramian
A fellow stylist here at Ford has a 6 cyl. '71 S2 E-type fhc that has an S3
grill and chrome bead around the “mouth”. He thinks it is original (he is 3rd
owner).
Could the factory have been throwing the S3 grill on the last of the S2 cars???
It still has the S2 bonnet. I will try to get the serial numbers from him.
Mark McChesney
'65 ots
From: rrichardson@eurekanet.com (Robert J. Richardson)
Date: Sat, 12 Oct 1996 12:31:13 -0500
Subject: E-Type master cyl. kits
Would you believe that the brake master cylinder rebuild kit for a Series I
E-Type costs $37.50! You get only the rubber dust exluder, piston rubber
seal and valve set rubber seal. One would expect at least a fitting tube at
this price. I still need to know if the unit has to be dismantled to fit
the piston cup seal. The Service Manual just says to replace both seals,
but doesn’t describe how to remove the valve gear from the piston. I also
did a dumb thing. I swilled the piston, valve assembly in petrol. The
rubbers on this unit were almost new. I had intended to only replace the
seals on the m.c. for the rear brakes as those rubbers had disintegrated.
Did the petrol swill destroy the effectiveness of the rubber seals? Should
I buy another kit because of my unknowing cleaning method?
Date: Sat, 12 Oct 1996 12:37:35 -0400
I know of NO changes in suspension from S1 to S2 E-types (yes,brakes were
changed). Does anyone else know of any? There was an anti-dive geometry and
track width change (ok and power steering) w/ the S3 but they still had the
same type bushes. Oddly, Gran Turismo says that the S3 had an inferior camber
curve to the S1/S2.
Mark McChesney
'65 Etype ots
Date: Sat, 12 Oct 1996 13:02:52 -0400 (EDT)
Subject: Re: Footnote on the XJ40
Steve: Just clean out the drain line for the AC. This will allow the
water to drain properly.
Chad Bolles Jaguar South 306 Valcour Rd Columbia SC 29212 USA 803 798 3044On
Date: Sat, 12 Oct 96 10:08:06 PDT
Subject: XJ40 Wheel Bearings
Does anyone know if this is also applies to my `91 XJ40? Is re-packing
the wheel-bearings included in the dealer major service?
Roger Peng (408)765-7863
Intel Corporation
Design Technology, Physical CAD
Date: Sat, 12 Oct 1996 13:23:09 -0400 (EDT)
Subject: Genesis of The Jaguar V-12
I have come across several copies of this publication. It comes with the
French, German and Italian insert. My understanding is that this is an
extremely rare item. If anyone is interested.
Date: Sat, 12 Oct 1996 12:19:03 -0700
Subject: Removing Fuel Tank from an E-OTS
I’m getting ready to have my E painted in the next couple of weeks and I
noticed a ding under the rear where the PO had apparently backed into a
high curb. Naturally the ding is under the fuel tank! Because I want a
first-class paint job, I decided to remove the tank to make it easier
(and cheaper) for the body man to fix the dent. Here’s my experience in
case someone else is contemplating doing this.
First remove the small plug in the pick-up sump and drain out all of the
old (six year) fuel, phew! Then remove the sump with a larger socket,
being careful not to lose or damage the screen which just sits over the
end of the pickup tube.
Next, remove the wood floor and possibly the deck lid to prevent damaging
it. You will see 3 bolts in the corners of the tank. Remove these and
the fuel pickup fitting. The hose will probably break so plan on
replacing it. Remove the pickup tube assembly from the tank or you will
not be able to slide the tank to the right.
Now, remove the two Cheney clamps from the fuel filler neck and slide the
hose up on the filler neck. Some WD-40 sprayed on the filler neck will
help it slide.
Next, unbolt the black saddle shaped mount at the right front of the
tank. This is held on by four welded bolts with nuts behind the IRS.
You cannot get the tank out without removing this!
Slide the tank to the right a few inches and cut the vent hoses off. If
you try to remove these without cutting them, you will probably damage
the brazed in tank fittings.
Finally, work the tank to the right some more and eventually you will get
enough clearance to lift it out. It’s such a tight fit that I understand
that Vicarraige has to match the tanks to the cars for their projects as
they are not always interchangeable.
The tank sits on a jute pad about 8 inches square and a round doughnut
around the sump. You may find as I did that these pads hold moisture and
there may be a little rust on the tank. Now would be a good time to
clean it up and put on a few coats of a good epoxy paint.
Sorry for the long post but this procedure is not as obvious as it looks.
It actually looks quite intimidating before you start.
Note to Larry Buja: You may want to include this in the E-type section on
the Jag-Web. GWC
Date: Sat, 12 Oct 1996 21:13:17 +0200
Subject: Sometimes you just have to laugh…
Just reading the delightfull new issue of Thoroughbred &
Classic Cars when I come upon a full-page advert from the
Symbolic Motor Car Company (now whats that supposed to mean?)
where they advertise a:
“1956 Jaguar D-type #XKD552 $850.000. Totally correct
and restored to Pebble Beach standard. Some racing
history.”
In light of recent discussions concerning concourse judgin,
can anyone spot the obvious error?
Symbolic also have an XKSS and an XJR-15 for sale sigh
Nick
Date: Sat, 12 Oct 1996 17:39:12 -0400
Subject: Re: Genesis of The Jaguar V-12
In a message dated 12/10/96 17:27:19, you write:
Is that the one with the acetate insert of the V12? If so I have one. Whats
it worth then?
Tez
Date: Sat, 12 Oct 1996 19:23:19 -0005
Subject: Re: Re[2]: JACK STAND WARNING!!!
MikeC:
I looked at my stands at home…Interestingly, the newer set has
a prominent warning and usage label.
Many years ago, Consumer Reports (whose reports, as a whole, I do
NOT endorse) did a comparison test on jack stands. Something like
half of the stands tested had a warning label instructing the user
not to get under the car when supported by the stands! CR was in
the process of consulting legal sources on whether stipulated
instructions not to use an item for its intended purpose was a valid
defense against liability suits; I dunno what the results were.
| some rules must be broken.
| - Palm’s Postulate
Date: Sat, 12 Oct 1996 20:00:57 -0400 (EDT)
Subject: Re: Serial Number strangeness/4.2 Compression Ratio
LLoyd:
The correct pressures are:
180 PSI - 9:1
155 PSI - 8:1
Turns out that my engine has a 9:1 ratio
Thanks,
Mike
At 12:53 PM 10/10/96 PDT, you wrote:
Mike,
You should be able to tell by running a comnpression check. 8:1 at sea level
should be around 128 PSI and 9:1 around 144.LLoyd - my mercedes is 195PSI, stock-
Date: Sat, 12 Oct 1996 17:20:14 -0700
Subject: XJ40: Trans
I’ve been having a problem that some jag-lovers where kind enough to
help me out with, I was wondering if anyone else knows of a possible remedy.
My 1989 XJ40 has a light clunk from the transmission when I slow down for a
stop light (around 12-15 mph it clunks). Unusually, it seems to happen more
when the car is warmed up, and doesn’t usually occur when cold. Another
footnote that may help, is at around the same temp, when full throttle
(really to the floor) out of a toll-booth, the car will tach close to 6000
rpm then shift into the second gear with a slight roughness, not that rough,
just not as silky shifting as when driving slower. The two seem like they
might be related (?)
Randy Wilson was nice enough to suggest that the trans throttle cable on
the throttle bell may have been incorrectly adjusted and need an adjustment
(it adjustes the shift time between gears). There is a little metal ferrel
next to the threaded portion of the cable, I’m not sure but I believe that
the ferrel should basically be touching the threaded part of the cable.
Mine is almost touching the threaded part, hard to measure. Anyone know of
the guage measurement that this ferrel should be when compared to the
threaded part? I’m not sure, but it may need the shifts to be closer, maybe
this will stop that clunking (it’ll downshift to first before I slow down as
much to feel it).
I’m not used to all this trans stuff, but maybe it may just need a new
filter and oil treatment (70,000 miles).
Anyone have the same problem with their XJ40?
I’m open to any thoughts anyone has on this problem,
Thanks for any help!
Eric
cobac@ix.netcom.com
Date: Sun, 13 Oct 1996 02:06:32 +0100 (MET)
was the case in England or other countries. It also seems apparent
that in many places the cars get registered by the year they are
shipped from the factory or by the year they are sold. Since I
understand that Jag didn’t ship the last of the E-Types from the
factory to dealers until sometime in '75 (long after the last one was
made) I guess I’m not surprised anymore by the occasional ad for a '75
E-Type, although I think most of us would tend to say there is no such
thing.
My XJ6 was sold new in Norway in 11/85. To the Norwegian Biltilsynet (our
version of the DOT) it is thus an '85. Nevertheless, the dealer insists
that it is an '86 model year car.
Gunnar
Date: Sat, 12 Oct 1996 22:52:09 -0500
MikeC:
a prominent warning and usage label.Many years ago, Consumer Reports (whose reports, as a whole, I do
defense against liability suits; I dunno what the results were.– Kirbert | If anything is to be accomplished,
| - Palm’s Postulate
Most of the people who have replied to my jack stand queries do use them to
gain access under their cars. I can appreciate the inherent danger in doing
so and I am only going to use two jack stands with the other end of the Jag
supported on metal ramps. And I also am going to keep the floor jack
positioned under the differential house just in case. Sears has a pair of
six-ton stands for $40 and they extend to the 24-inch height I think I’ll
need to remove the forward shock and spring assembly so I can get a wrench
on the rear brake bleed nipples.
From: “Barry Cooper” b.w.cooper@acslink.aone.net.au
Date: Sun, 13 Oct 1996 16:46:36 +1000
Subject: XJS Fuel Starvation
I haven’t noticed any definitive reply on this subject and I don’t have an
XJS but I understand that there is a known problem with blocking of the
internal fine gauze filter located in the surge tank which is located below
the main fuel tank. My source of information is the May 1996 Queensland
Jaguar Driver magazine which also has a brief procedure for resolution. If
required I could type out the procedure. John Smith was the author.
Barry Cooper
Mackay Qld
Australia
68 E Type FHC
Date: Sun, 13 Oct 1996 02:45:58 -0500
Gunnar wrote, among other things>>>- “Sorry, we don’t have that”
Nice story, it’s the same the world over. I try to buy a radiator cap in
several parts stores in Bahrain and the follwoing ensues.
“Do you have radiator caps”
“What car sir?”
“Just a radiator cap”
“What car sir?”
“Just a plain radiator cap, you know 15 lbs”
“What car sir?”
“Jaguar”
“Sorry sir”
“What, don’t you have one like this?” (produce sample)
“Oh yes sir - you want 13, 15 or 16 lb?”
Then you get the other extreme.
“No sir we don’t have that one, but we can make this one fit. (Blow torch in
hand, angle grinder under arm) You take seat, we have a look”.
"Thank you, Thank you (back towards car) I’ll come back later. (large cloud
of dust and small pebbles)
True story - exhaust system.
Footnote: The local garage guy (Bahraini) I get to do simple things still
doesn’t understand why I go down in the pit with his “mechanic”
Then there was Australia, different problem though. The local Repco autoparts
chain - fairly good, usually knowledgable staff but foiled but the bean
counters in head office.
“I need some spark plugs”
“What sort”
“Champion N12Y” (or something like that)
“No probelm, how many, 4 or 6?”
“12”
“Sorry we only have 10”
“10? why 10?”
“That’s how many are in a box and we only hold one box in shop stock”
Foiled by metrication
Robert Bradley “Some days are diamond, some days are stone”
Date: Sun, 13 Oct 1996 13:13:12 GMT
Subject: Re: Re[2]: XK-8 versus Aston-Martin
On Mon, 7 Oct 1996 16:17:33 -0400, you wrote:
Anybody noticed that if you take a image of a
E-type rear end and use an image editing tool
to unsharpen it, it will remind much of the XK-8
rear end, especially the rear lights.
Gunnar Forsgren gunnar@medial.se
MEDIAL Maskin & Data http://www.medial.se
�ngsvik 2, S-139 50 V�rmd� Phone/fax +46 8 57025056
Sweden
Date: Sun, 13 Oct 1996 22:19:30 +1000
and remove the oil. Has anyone actually tried this? Does it work? Is it messy?Mike Frank
1969 E-Type 2+2
Mike I havent actually tried old oil, but I started to get some rust at the
bottom sills, so untill I save the money to get a full respray a friend
suggested the following.
strip the inside of the door, make sure that all holes are clear of
muck/grime/debris, drill some more holes if needed and give a good liberal
spray of FISH OIL available at all good car centres which sell
parts/cleaners etc.
It smells for a few weeks (approx 4) butt works very well…
Mik:-)
End of jag-lovers-digest V2 #432
Return-Path: @owner-jag-lovers-di1
Received: (from majordom@localhost) by ekeberg.sn.no (8.7.5/8.7.3/on4)
id for jag-lovers-digest-out; Mon, 14 Oct 1996 01:14:01 +0200 (MET DST)
Date: Mon, 14 Oct 1996 01:14:01 +0200 (MET DST)
Message-Id: 199610132314.BAA21548@ekeberg.sn.no
X-Authentication-Warning: ekeberg.sn.no: majordom set sender to owner-jag-lovers-digest using -f
Subject: jag-lovers-digest V2 #433
Reply-To: jag-lovers@sn.no
Errors-To: @owner-jag-lovers-di1
Precedence: bulk
X-Newsgroups: mail.jag-lovers-digest
jag-lovers-digest Monday, 14 October 1996 Volume 02 : Number 433
Re: Oil Change
Re: Antennae
Suspension Improvements
No jag content: Navspeak explained (long message, rally driver content!)
Interstate vs Jaguar batteries
Alternate speedometer transducer gear for 1983 XJ6 5-speed?
Re: XJ40: Trans
Rust Proofing 92, XJ40
Concours Rules
Re: Jack Stands
Re: Engine stop [was: Re[4]: …crossover pipe (XJS)]
Re: Re[2]: `89 XJ40
S3 E-Type rear camber [was: Re[2]: Concours Judging]
Re: Interstate vs Jaguar batteries
Date: Sun, 13 Oct 1996 09:27:51 -0400
Gunar,
No, but I understand that if you drive the XK-8 in
reverse, over 80MPH, the exhaust sound says,
“I look like an E,
buy me!”
Charles Daly, Toronto, Canada
'62 E-Type, ots
Date: Sun, 13 Oct 1996 09:34:25 -0400 (EDT)
Mik:
I have used the technique of oil-engine-oil-ina-a garden-sprayer to treat
the inside of wheelwells on my old Chryslers, so I know that this can slow
corrosion. The real point of my question is whether the technique of
filling-the-box-sections can be used without filling the interior with oil,
creating an anti-social oil slick on the interstate, etc.
It would seem that you have found the only thing on the planet more fragrant
than old engine oil. I don’t think I can find that stuff here,anyhow.
Mike
parts/cleaners etc.It smells for a few weeks (approx 4) butt works very well…
Mik:-)
Date: Sun, 13 Oct 1996 11:14:08 -0400
In a message dated 96-10-12 22:50:44 EDT, rrichardson@eurekanet.com (Robert
J. Richardson) writes:
<< I can appreciate the inherent danger in doing
supported on metal ramps. >>
OK I have to make a comment here.
I see no reason why having the front or rear end on ramps is any safer than 4
simple jackstands, in fact I think it is MORE dangerous.
Why?
Because when using 4 stands the front and rear can be progressively raised in
a manner that the car remains relatively level throughout the process. When
using ramps, the front is driven up the ramp first, then the floorjack raises
the rear. If you are getting it way up there, there is risk of the whole car
rolling off the ramps when the rear wheels first lift off the ground (nose
pointing skyward like an ICBM). To me, this is much more dangerous.
Lastly, the floor jack should be positioned under the car for safety but
should bear NO weight. Floorjacks become more stable against side loads with
increased weight load (within their rated limit).
Do be careful where the jacks are positioned. I put a small hole in the
floorpan of my XJS once where the metal was thin.
Julian Mullaney
Date: Sun, 13 Oct 1996 16:12:35 GMT
Subject: Re: Antennae
On Thu, 10 Oct 1996 20:38:47 -0005, Kirby Palm wrote:
I know there are some radio experts here.
I recall learning years ago that the ideal length for an antenna on
an FM radio is around 31 inches, and that either longer or shorter
is not as good. Is this true? If so, how come some antennas are
not that length?
That is true. Older antennas were longer because they were used to
receive signals on the AM broadcast band, which is a considerably
longer wavelength. Since most folks these days are interested
primarily in FM reception, newer antennas are a single length which is
optimized for the middle of the FM band.
If true, how does the antenna being mounted at some angle other than=20
vertical affect it? Should it still be 31 inches long, regardless of=20
mounting angle?
The receiving antenna should be polarized the same as the transmitting
antenna for best reception. If the transmitting antenna is vertically
polarized, so should be the antenna on the other end. Received signal
strength theoretically will decrease as a function of the difference
in polarity between the two antennas. In actual practice, however,
the effect is so small as not to be noticed. The position of the
antenna should have little effect on its optimum length.
| - Palm’s Postulate
-- Vince -- If we are to accomplish anything with
electromagnetic waves and their propagation, we must break no rules.
- – =20
Vince Chrzanowski radiowsh@mindport.net=20
“There is not a moment to be lost” - Jack Aubrey
- -------------------------------------------------- =20
Date: Sun, 13 Oct 1996 12:17:34 -0005
Subject: Suspension Improvements
Mark McChesney:
curve to the S1/S2.
One must understand where GTJ is coming from. Their feeling is that
the suspension should be designed for optimum cornering under racing
conditions, and therefore offer parts to CHANGE the suspension to
hold the wheels perpendicular to the ground when cornering. However,
this is not what the suspension was designed for.
The original intention of the unequal A-arm type suspension is to
cause the contact point on the bottom of the tire to move vertically
up and down with suspension travel with a minimum of sideways
motion. This is accomplished by the shorter upper arm pulling the
top of the tire inward – and thereby pushing the bottom of the tire
outward – when the suspension is at either the far up or far down
position, where the lower arm is pulling the tire inward. IOW, the
suspension deliberately tilts the wheel to keep the contact patch
moving vertically.
The advantages of such a design include optimized tire wear, since
the contact patch moving sideways tends to scrub rubber. It also
tends to make the suspension work better towards a smooth ride,
since the suspension trying to push the contact patch side to side
has the reverse effect of restricting suspension motion. And, of
course, the contact patch moving side to side results in the CAR
moving side to side over one-wheel bumps, not conducive to the
legendary Jaguar ride.
The benefits of such designs are only fully realized when tires of
the correct diameter are mounted on wheels of the proper offset.
I’d be interested in knowing if the recommended tire size changed
between the models discussed; that might explain the suspension
dimension differences.
If you wanna go racing, the GTJ suspension mods make sense. However,
for normal road use where ride, tire wear, and all-around use are
important, the stock design is excellent.
| - Palm’s Postulate
Date: Sun, 13 Oct 1996 16:22:57 GMT
Subject: No jag content: Navspeak explained (long message, rally driver content!)
As a rally driver I very much enjoyed John Brown’s list of technical terms
and what they really mean (John Brown is an ex-rally driver and a very
experienced rally organizer). Here are the ones that really rang a bell:
What the navigator says…Our start time is 11:37 = Real meaning…Our
start time is 10:37
Go like the clappers - the organisers have pruned this section = We should
have turned left a mile back.
You can go a bit slower - this is an easier section = Your kamikaze driving
has already given me brown underpants.
Wait at the yellow board - we’ve got a couple of minutes in hand at this
control = We’ve missed the previous two.
The marshal’s your side - ask him for 23:17 = We should have been here at
23:15, but it’s now 23:19 and we’re trying it on.
Do you mind if I open the window? = I’m abut to deposit my dinner on your lap.
Gosh, there’s number 25 in front of us again - he must be cutting a lot = He
missed out our last three wrong slots.
There is a very tricky slot in the next half mile = There was a very tricky
slot in the last half mile.
This crest looks flat on the map = This crest is immediately followed by a
fresh air hairpin left.
We’re going over a fold in the map = We’re about to go steep downhill on wet
cow manure into a tight 90 right over a narrow stone bridge.
I’m just changing maps = For the next five miles, I will be reading you the
wrong road.
Sorry, it’s not as map = Not as the bit of map I was looking at, anyway.
We’re taking a short cut along a farm road = It has six gates to open, the
last of which is padlocked and guarded by a crazed Rottweiler.
The crafty blighters have sent us on to Map 135 without specifying it = The
Public Library’s copy of Map 135 was out, and I hoped that there wouldn’t be
too much of the route on it.
The cunning sods have put the code board facing the wrong way = We have just
wrong-approached a passage control.
This road is a bit rough and wet = It’s blue on the map.
Have you farted? = I have farted.
I know where we are now = We’ve been lost for the last 20 minutes.
I made our stage time there a few seconds quicker than the organisers = I
forgot to start the watch.
I agree with the finish time the marshal gave us = I forgot to stop the watch.
Fast left - 200 - ABSOLUTELY flat crest - 200 = Oops - I turned over two
pages at once.
Yes, we’ve plenty of time for a gearbox change = We’ve six minutes and 22
seconds, but I’m off to get a meat pie and have a dump, and you won’t see me
for the next quarter of an hour.
Well driven! = My grandmother could have gone quicker.
Oh bugger = Oh bugger.
Glue Man
glueman@collano.ch (former address: gleuma@dial.eunet.ch)
Date: Sun, 13 Oct 1996 12:39:57 -0500
Subject: Interstate vs Jaguar batteries
Hi everyone,
There I was in a hurry as usual, turned the key and click click click. I
changed to another car and a couple of days later called the local auto
club for a start jump. I then ran the car over to the local Jag dealer
who called and told me I needed a new battery. O.K. When I picked up my
car after hours I opened the hood and found a new Interstate battery
resting in there. The battey was both smaller and shorter than the
original. The dealer had “jury rigged” foam pieces around the sides and
under the top cross piece restraint to hold the battery in place. It’s
not very pretty but functional.
Should I be concerned ?
- with an Interstate battery ? How well do they hold up ?
- with the “jury rig” installation ?
Thanks,
Lou 92 XJ40
Date: Sun, 13 Oct 1996 10:48:12 -0700
Subject: Alternate speedometer transducer gear for 1983 XJ6 5-speed?
I have a 1983 XJ6. It is a US model, with the automatic
transmission replaced a European model 5-speed manual transmission.
As far as I know, the parts are all stock, but the final drive appears
to be the one shipped with the car. The speedometer and the trip
computer, which use the same electronic speed transducer at the back
end of the transmission, both indicate 8% low. That is, at 65 MPH,
they read 60 MPH. I notice in the Jaguar Series III Service Manual
that the stnadard final driver ratio was 3.31:1 (43/13), with 3.07/1
(43/14) being an optional alternative (if I am interpreting the
wording correctly). This difference corresponds to the 8% difference
I am seeing.
I suppose that I have a 3.31:1 final drive, but a transducer
drive pinion geared to match a 3.07:1 final drive. Is this a
reasonable conclusion? Are the drive pinions common to all three
tranmissions (manual, BW66, GM400)? If so, what is the easiest way to
acquire the appropriate transducer drive pinion? Since the manual
transmission was not shipped on any US vehicles for this vintage, I
suspect that it may take a long time to order the pinion through the
dealer.
Date: Sun, 13 Oct 1996 12:58:27 -0500
How about a hat. Tee shirts are great for those who fit in them. While
at one of the local fairs here in Wisconsin I had a hat made with the
leaper and Jaguar on it for $10.00 (US). I wore it that day and was
stopped three different times by people who wanted to talk Jaguars with
me. Can we do the leaper ? (copyright issue ? ) with sn.no below it ?
Lou
Date: Sun, 13 Oct 1996 13:04:04 -0500
Subject: Re: XJ40: Trans
cobac@ix.netcom.com wrote:
My 1989 XJ40 has a light clunk from the transmission when I slow down for a stop light (around 12-15 mph it clunks).
(text deleted)
Eric
cobac@ix.netcom.com
Hi Eric,
I have a 92 XJ40 which thunks at 50MPH, it thunks when I reach 50 and
when I slow down to 50. I asked the dealer about this and was told that
this is normal. I sure hope so. I also would be interested in hearing
about this.
Thanks
Lou
Date: Sun, 13 Oct 1996 13:12:08 -0500
Subject: Rust Proofing 92, XJ40
Hello,
I was wondering does the XJ40 come from the factory with rust proofing ?
I discovered rust as an issue when I moved from California to Wisconsin
a couple of years ago. My 84 Audi shows no signs of rust but the Ford is
broken out in many areas. I discovered that the Audi is rust proofed at
the factory.
If rust proofing is not done at the Jaguar factory can it be added later
to the car ?
What is the groups experience with different sources and types of rust
proofing ?
Thanks,
Lou
Date: Sun, 13 Oct 1996 14:22:15 -0005
In
Question: Are the first examples of the XK8 referred to as '96 or
'97?
| - Palm’s Postulate
Date: Sun, 13 Oct 1996 12:31:25 -0700
'97. Jaguar has tried for fall model changes but many times they have
missed the September manufacture date and also had many mid year model
changes.
In
year and tried to stick with the Fall to Fall cycle.Question: Are the first examples of the XK8 referred to as '96 or
'97?– Kirbert | If anything is to be accomplished,
| - Palm’s Postulate
Date: 13 Oct 96 16:02:52 EDT
Subject: Concours Rules
Perhaps Chip or anyone else knowledgable about Concours could tell me if, in
Concours, you lose points if you have an item which was not offered on your car
in the year it was sold, but WAS offered in subsequent years? For example, if
you have 1986 tread plates on a 1985 car, and the design of the tread plates was
changed at the end of the 1985 model year, are you penalized for that?
Daniel Kagan
1985 Jaguar Sovereign HE
Date: Sun, 13 Oct 1996 16:20:59 -0400 (EDT)
Subject: Re: Jack Stands
Don’t forget that there are jack stands and then there are jack stands. I
have some sheet-steel stands that are real skinny, very lightweight, and
cost somethink like $10 each. Even though they would probably test beyond
their rated capacity in the lab, there is no way I would trust them for
any job that could experience a side thrust. They work great for go-karts
and boat trailers, though. I also have four Snap-On stands with a
very large base. Ultra stable. No problem – can put my truck two feet
in the air all around and it won’t fall off (I know because the first time
I jacked it up this way I pushed the truck around every which way before
I’d crawl under it). Then of course I have this pair of SOLID cast iron
jack stands that date from something like 1920. Super large base.
Incredibly strong. So it all depends on what you are working with.
John
On Fri, 11 Oct 1996, Jim Isbell wrote:
I personaly would not want to be under a car on 24" jack stands, thats to
high and spindly. Mine are at most 18".
Date: Sun, 13 Oct 1996 16:34:34 -0400 (EDT)
Subject: Re: Engine stop [was: Re[4]: …crossover pipe (XJS)]
Well, here’s my two cents worth:
I once took an old aluminum piston and tried to drive a 1/4" blunt punch
through it. Why? Because my car (non-Jag) had just swallowed a piston,
and I wanted to get a feel for the forces involved. It took very little
force to begin to deform and then crack the piston. On another, not much
more to punch right through. There is a big diffrence between the force
of combustion evenly distributed and concentrated force in one spot.
So I would not do it this way because you can’t guarantee how much force
will be applied and how smoothly. And I bet it gets more complicated
if the rod contacts the piston at an angle. Since you would have to
build this tool anyway, why not just go with the rope idea? Sounds
easiest and for sure safest.
John
Date: Sun, 13 Oct 1996 16:37:35 -0400
Subject: Re: Re[2]: `89 XJ40
Mike;
/re: Ugly XJ40’s, You are hereby directed to report to headquarters at sunup
to be shot. Or at least since I don’t have a dog tormented for seven days and
nights by a demented dwarf. Hmm, maybe sentenced to drive a Dihatsu in
public for 1 year.
Rick Castonguay
90 Sovereign
Date: Sun, 13 Oct 1996 16:41:43 -0500
Subject: S3 E-Type rear camber [was: Re[2]: Concours Judging]
- –IMA.Boundary.666932548
The S3 E-Type has a longer half-shaft than the 6-cyl E-Types. I recall reading
once that Group 44 fixed the rear camber problem as a byproduct of improving the
rear brakes. As you probably know, there white number 44 was one of the two
S3’s that routinely trounced the Corvettes and Cobras in SCCA B-Production
racing circa 73-75. The other was a silver west coast car, #11 I think, run by
Huffaker (spelling?) I believe he Group 44 car is in the Jag museum.
Anyway, the rules allowed the use of front brakes in the rear. Group 44 used
the front vented disks in the rear, which required shorter half-shafts to
compensate for the extra width of the large vented discs. They discovered that
the 6-cyl E-Type half-shaft was virtually a perfect fit. Spacers and shims to
center the rotor in the caliper were also used to correct the half-shaft length.
The only other major change they made to the rear was replacing the trailing arm
with one that had its front mount directly in line with the lower control arm
pivots. That triangulated the lower arm for additional strength and eliminated
the rear steering effect of the toe-in changes caused by the trailing arm.
MikeC
Subject: Re: Concours Judging
Author: “Mark McChesney” mmcchesn@ford.com at Internet
Date: 10/12/1996 12:37 PM
Oddly, Gran Turismo says that the S3 had an inferior camber curve to the
S1/S2.
Mark McChesney
'65 Etype ots
- –IMA.Boundary.666932548–
Date: Sun, 13 Oct 1996 21:09:19 GMT
In message 3260eadb.904045@mail.algonet.se gunnar@medial.se (Gunnar Forsgren) writes:
If you take an image of a Mazda Miata and enlarge it, it will look like
an XK-8. (Saw one in the flesh two days ago. It’s TINY !)
Regards
Stefan Schulz
jaguar@suaviter.demon.co.uk
'88 XJ-S V12 and sticking with it
Date: Sun, 13 Oct 1996 19:13:10 -0400 (EDT)
Subject: Re: Interstate vs Jaguar batteries
Lou:
For some strange reason, repair shops in the US drop that little Interstate
battery into everything that comes along. If you aren’t too concerned about
how it looks, it will hold up: the one in my E held up for 3 1/2 years of
very intermittent use. As to the adequacy of the hold-down rigging, you are
the best judge. The PO of my car had done something similar, and it was no
problem.
I ended up using an (Exide International Series) when I replaced my battery.
It is close enough in size to allow the original hold-downs to be used.
Mike Frank
1969 E-Type 2+2
At 12:39 PM 10/13/96 -0500, you wrote:
Hi everyone,
Thanks,
Lou 92 XJ40
End of jag-lovers-digest V2 #433
X-UIDL: 00a4bef1a792af38d6be85d2884c772b
id for jag-lovers-digest-out; Mon, 14 Oct 1996 05:30:21 +0200 (MET DST)
Date: Mon, 14 Oct 1996 05:30:21 +0200 (MET DST)
Message-Id: 199610140330.FAA13402@ekeberg.sn.no
Subject: jag-lovers-digest V2 #434
Precedence: bulk
Status: RO
X-Status:
jag-lovers-digest Monday, 14 October 1996 Volume 02 : Number 434
Re: Oil Change
Cute line
Re: Jack stand warning
concours confusion:
Re: May I introduce myself and ask a question?
Re: XJ40: Trans
Big Road Trip - recap.
E-Type master cylinders
Re: JACK STANDS, whats all the fuss about
Hoisting the old Jag
Re: concours confusion:
ticking noise
The resurection of old #25 ('85 XJ6)
XJ40: Transmission
XJ-40 TRANSMISSION
Clicking fuel lines
Date: Sun, 13 Oct 1996 19:13:14 -0400 (EDT)
Kirbert:
Just got back from the XK8 intro at Bergen Jaguar. 1997.
Mike
In
| - Palm’s Postulate
Date: Sun, 13 Oct 1996 19:55:48 -0400
OK,
So I did that!
Now what the hell do I do about these damn flys???
parts/cleaners etc.
Charles Daly,
'62 E-Type, ots
white, with fly specks
Date: Sun, 13 Oct 1996 20:10:10 -0400
Subject: Cute line
Just thought I’d share this great line from a print
ad in the Toronto papers for the Japan Grand Prix,
“Objects in mirror may be more aggressive than
they appear!”
Unfortunately, Jacques didn’t finish!
'62 E-Type, ots
Date: Mon, 14 Oct 1996 10:42:07 +1000
Subject: Re: Jack stand warning
I got out my jack stands at the weekend. The difference in height between
when they are flat on the ground and when the top is at the maximum height
directly over the outside line of the feet is 30 mm, a little over an inch.
Supporting a car on four stands alone, or on one or two stands without the
other wheels being securely chocked or locked is like using a one inch
thick piece of wood to chock the wheels.
A backup support seems to be highly advisable.
Tony Watts
Date: Sun, 13 Oct 1996 20:47:58 -0400
Subject: concours confusion:
- I don’t have many details :
I am aware of an XK120 that when shown is a great public hit and a formally
judged prize winner. The facia is not one offered - as far as I know ? -
in a roadster. It had the wooden fascia as offered in other models, the
coupe for example. It did look good by the way.
Here’s another : I inquired of a major Jaguar restoration parts supplier
about the availability of “white” steering wheels for an XK120. I was told
that there never was such a thing as a white jqaguar steering wheel.
Nevertheless, I have a photograph of a 120 at a car show with a white
steering wheel. It looked good by the way. -
Another : Duetto sales brochure : Interior has red carpeting. Never
happened in production Duettos as far as I know. (?)
What does anyone make of this?
Date: 14 Oct 96 10:58:36
Subject: Re: May I introduce myself and ask a question?
Kevin Jones : I have a deep suspicion of any cars built under the Leyland
auspices, so you can guess what models I’m not looking for :-).
Welcome, Kevin, and I hope you’ll find a Jag that gives you what you’re looking
for. Just a small comment on the tragic Leyland years: yes, Jags of that era
suffered miserable build quality - but any survivors around today have been
sorted long since, and will be as reliable as any other 20-year-old car. I have
two of them, and use them as daily drivers with no major hassles (after
rectifying PO’s neglect, that is…).
- -Jan
1977 XJ12C
1978 XJ12L
Date: Sun, 13 Oct 1996 21:35:11 -0500
(text deleted)
Eric
cobac@ix.netcom.com
Hi Eric,
about this.
Thanks
Lou
The “clunk” at 50 MPH is the lock up of the torque converter. It
should not be a loud sound.
Bob Johnson
Brattleboro, Vt.
XJ40, XJ50
From: “Peter Rebbechi (03) 9275 3374” <"REBBECHI PETER"@a1.meoc02.sno.mts.dec.com>
Date: Mon, 14 Oct 1996 01:48:00 +0000 (GMT)
Subject: Big Road Trip - recap.
Well, Bathurst has been and gone.
I will describe the Jag content only.
The trip up was uneventful, except for the HUGE cross
country capacity of an XJ40.
The trip up was 890km, which was accomplished in less than 8
hrs, including the trek to get out of the city, which from
my residence is the first 1.5 hrs, and 80 kms. The big cat
loves cruising.
Some figures for the stat people.
At 120 km/h, the car sits at 2500 rpm. redline is 5500. No
Virginia, that does not mean that you can do 270km/h.
We did do some testing, and 200 km/h is easy. 230 takes some
time, and we were too busy looking for cops to go higher.
It also coincided with roadworks, and dirt sections of the
road. over 200 km/h on dirt meant that I was doing
everything slowly, in measured doses. We actually spent very
little time over the speed limit, as we were making good
time, and the penalty for getting caught exceeding the speed
limit by more than 30 km/h is automatic loss of licence for
3 months, followed by the court case, and any oher penalty
they may care to throw at you.
The temp never exceeded normal, oil pressure remained
constant, and it was a real pleasure. car used no
discernable oil or water.
We did take the cat up to the camping area at the top of the
mountain, but were deterred by the looks we were getting.
As a matter of ritual, all cars going up the top of Bathurst
during race time are obligated to do burnouts, and crowd
displeasure is indicated by trashing your car!
We went up on Thursday BEFORE the crowds arrived, out of
consideration for insurance. Fear played a part. By friday,
two cars had been set alight and the crowd would not let the
fire brigade get near the cars before they burnt out. The
security people had their car trashed before the police
arrived to calm things down.
We contented ourselves with watching the racing, and the
donut competitions in the paddock area (tame). Suffice to
say that we had B&B accomodation. Much better for old
blokes like us.
I won’t document the racing, as there is no Jag content
there, but all you European people keep an eye for a
promising young driver called Craig Lowndes, who is driving
Formula 3 in Europe for TWR next year. He has a ten year
‘grooming’ contract with TWR that should see him in Formula
1 within 5 years if he continues showing the talent.
After the racing (4 am start to get a decent viewing
position on race day), we drove to Windsor (NSW) which is
about 250 km away, along a great stretch of road called the
Old Bell Line. Magnificent scenery, and great corners.
recommended for all NSW jag lovers.
After a team meeting on Tuesday and Wednesday (paintball
competitions) I drove home to Melbourne, which is a journey
of 970km. I only made one stop, for fuel, and made the
return trip in 8.5 hours. No speed limits were broken,
(maybe bent a little) due to the fact that I left Windsor at
4 pm, and the Hume is such a good road for interstate
travel.
I arrived reasonable fresh at home at 12:30 am, and with no
stress at all.
This is the first drive of more than 5-6 hrs duration that I
have done with my XJ40 after 3 yrs of ownership. Normally
we have 4 kids as well, so we take the van. Cruising was so
effortless in the Jag.
All in All, 2,308 km was done, with the total ave speed at
93 km/h, and ave fuel consumption of 26.7 mpg. Considering
a lot was idling in parking lots, and some city driving,
quite good.
Date: Sun, 13 Oct 1996 22:23:22 -0500
Subject: E-Type master cylinders
Thanks to Mark Roberts I was able to dismantle one of the master cylinders
on my 1964 Series I E-Type. I thought I’d pass this information on to
owners of the 3.8 E-Types who need to resleeve master cylinders and may
have to install new rubber seals. This was my first attempt. And I am
taking it seriously because brake failure can have truly deadly
consequences.
There are two makes of brake master cylinders on the 1961-64 Series I
E-Types. The service manual on page L.12 shows a sectional view of the
Girling unit. This master cylinder has three rubber seals. One is a sealing
ring on the piston and behind it, between the piston and the spring support
is a cup seal. On the end of the valve is the third seal. The Dunlop unit
has just the cup seal and the valve seal. Terry’s Jaguar, as do other
parts houses, identify the master cylinder rebuild kit as SP9016 but do not
identify the kit as being for either the Girling m.c. or the Dunlop m.c. I
have a kit on order, $37.50 for the rubber seals and the dust excluder
(Wow! Talk about profit!) and am hoping the seals will work on my Dunlop
master.
The manual suggests that the Girling unit consists of the piston and the
valve-spring device. But if you have the Dunlop unit, the piston and valve
have to be separated in order to affix the cup seal. Pressing on the valve
seal is a simple matter. Now, about separating the piston from the valve’s
spring support. It had me completely stymied until Mark answered my query
posted to the list.
To separate the piston from the valve assembly, you need access to
watchmaker’s screwdrivers. On the side of the metal spring support (that
appears to be solidly attached to the piston, is a U-shaped clip cut into
the support. This is a spring clip that needs to be pried up. In doing this
the units will separate quite suddenly with the spring tossing valve pieces
hither and yon.
Only now can you slip on the cup seal with the higher rim pointed toward
the piston itself. The manual suggests lubricating these rubbers and the
inner bore of the master cylinder with brake fluid. And of course during
this operation, you should keep the work area and parts scrupulously clean.
One of my resleeved master cylinders (stainless steel) came back with the
piston and valve unit full of gunk from seals that literally had been
disolved in the brake fluid. So I swilled the gunky parts in gasoline.
This, I learned, is a no-no. The directions for refitting the clutch master
cylinder with new seals plainly states not to swill the rubber seals in
gasoline or paraffin. The writer neglected to insert this advice in the
section on brake master cylinders. The seals in this unit, for the rear
brakes were almost new. At this point, with my new jack stands and floor
jack at the ready, I don’t know whether I should use this super-clean seals
or order another kit.
It’s an oddity that the manual suggests that the middle reservoir is for
the rear brake master cylinder. This is not so! The rear reservoir serves
the rear brakes and the middle one the front brakes.
But the top master cylinder is for the rear brakes, the most difficult to
bleed with the removal of the forward spring-shock assembly almost a
necessity. If I use the new rubber seals for the top master cylinder then
I’m apt to not need to bleed the rear brakes for quite some time. This
means putting the piston-valve assembly with the “gassed” rubber seals in
the bottom master cylinder, which, if it goes bad, means removing the top
master cylinder and the need to bleed both the front and rear brakes. Why
didn’t they just mount them side by side? I take it that the 4.2 E has just
a single master cylinder. I do know it is a completely different unit from
the Girling and Dulop masters with different part numbers for rebuild kits
and servo kits.
Date: Mon, 14 Oct 96 15:20 NZST
Subject: Re: JACK STANDS, whats all the fuss about
What is the big problem about Jack Stands. I can’t believe what the big
fuss is about. You simply just jack your car up and plus four stands on the
jacking points or similar. The car is then accesable from underneath, with
very liitle risk. The wait of the car is enough to prevent the car for
going to far.
We use jack stands for stripping MK 2’s. This means climbing around the in
the cabin the boot and the like, and we have never had a car fall, or even
wobble.
I am telling you now, a hurricane could hit the car and it would still be
as solid as a rock on the Jack Stands, even cheap ones.
Please put your minds to rest.
Alex
alex@lindisfarne.hb.school.nz
Date: Sun, 13 Oct 1996 22:33:08 -0500
Subject: Hoisting the old Jag
Incredibly strong. So it all depends on what you are working with.John
It was suggested by several list people to get the 24" stands. I bought a
pair at Sears today for $34.50. They are really rugged and I only have to
extend them high enough for me to get at the rear brake bleeders. I’ll keep
the floor jack nugged to the differential housing as insurance. The Sears
were listed as pro-parts in the catalog. Believe me, I’m not about to take
any chances. And I’m going to use metal ramps on the front end (with tires
secured so the car can’t roll). If this works out for what I want to do
maintenance wise, O.K. If not, I’ll add another pair of jack stands to my
garage litter.
Date: Sun, 13 Oct 1996 22:09:51 -0500
Subject: Re: concours confusion:
David,
The white steering wheel was on some of the XK120s. Very rare item-like the
bucket seats for XK120 racers. Probably won’t find one at any parts houses
and then only at a swap-meet if you are very lucky. I’ve never seen one, but
have read about them.
None of the XK roadsters (OTS-Open Two Seater) had a veneer dash. Only a
leather covered dash. A couple of vendors are now selling veneer dashes for
the OTS, however.
Cleo Bay
52 XK120
56 XK140
62 E-Type
65 3.4S
steering wheel. It looked good by the way.Another : Duetto sales brochure : Interior has red carpeting. Never
happened in production Duettos as far as I know. (?)What does anyone make of this?
Date: Sun, 13 Oct 1996 20:55:47 -0600
Subject: ticking noise
Hi Troops
Recently I aquired my Jag. I sometimes think I should leave the radio
up louder because I hear many things I probably shouldn’t hear.I have have a
slight ticking noise in the front drivers side. Other passengers in the car
can’t hear it but I know this car. My problem is that I live 100 miles from
my nearest service dept. and I would like to troubleshoot this problem. Any
guesses!!!
Date: Sun, 13 Oct 1996 21:03:48 -0500
Subject: The resurection of old #25 ('85 XJ6)
It must have been a success. I recieved 9.994 points in the Driven class
and took First place against stiff competition.
Second place was 9.993
Third place was 9.992
I think I will take the cup to Michael tomorrrow to show him how good his
work is.
When I arrived I was very down as I looked over the competition. I just
knew I couldnt beat them, they looked like new cars. Those were the best
looking XJ6s I had ever seen, even better than the ones I saw new.
When they started anouncing the awards with third and it wasn’t my name I
thought, "Well maybe I got second. But when my name was not second I
thought, “Well it was fun anyway.” But then when I was anounced as First
place I just could not believe it.
A very successful resurection I would say.
This was my first, and probably last journey into the Concours field. It
was fun but its not my cup of tea.
Jim
“Better an outlaw than not free.”
Nance O’Neil
From: “Rennick, Kim (AS01)” KRennick@p03.as01.honeywell.com.au
Date: Mon, 14 Oct 96 12:41:00 EST
Subject: XJ40: Transmission
about this.
This sounds like the transmission going into and out of ‘lock-up’ mode,
which is programmed to occur at (I think) 54mph. Just why they chose 54mph
rather than 58, I’m not really sure.
In my car ('88 3.6L) one is aware of the transition into lock-up, but I
wouldn’t say that there is any ‘thunk’. If there is a thunk, it is very
gentle and well isolated.
Kim Rennick
'88 3.6L Sovereign
Date: Sun, 13 Oct 1996 23:12:15 -0400
Subject: XJ-40 TRANSMISSION
about this.
The “Thunk” (good description) is your torque converter clutch engaging, or
disengaging, depending on whether you are accelerating or slowing. Watch
your tach when this happens and you’ll see it change. Mine activates at
exactly 52 MPH. I frequently switch to “Sport” until up to 55, or so, then
ease off the accelerator as I hit the button again to give a soft lock. When
a “non Jaguar person” is in the car it avoids having to give an explanation
to “What was that?”.
Ron Miller, Seattle, '93 XJ-40
Date: Sun, 13 Oct 1996 20:23:12 -0700
Subject: Clicking fuel lines
I am sure I saw something ion this once before, but I don’t remember the answer. I discovered that there is a distinct rapid clicking sound, audible from in the car, which comes from the fuel system. It seems too loud to be a normal occurence – very noticable from inside with the windows closed. I can feel the vibration in the fuel lines, both the supply and the return. Vibration is also felt on the fuel rail – quite noticaeble. Is this the sign of a failing pump, a bad valve, or normal. Car is an 1987 1/2 XJ40, and I have been expereincing surging and stumbling problems at idle and cruising, but no loss under full throttle.
One other problem – I suspected that the PO had tampered with the VCM. Today I disconnected the Crank Position Indicator, and turned the engine over. Of course, it did not start, but NO VCM message appeared. I should have expected to see a “check engine” or “Fueling failure” warning, but didn’t. I followed the manual’s procedure for double checking – turned the ignition off for half a minute, and re-checked. Still nothing. Does anyone know how these error codes would be prevented from being shown? I’m sure it was done intentionally to hide a problem. Perhaps a wire snip at the VCM or ECU?
Mike Everatt
1987 1/2 XJ40
Still learning…
Date: Sun, 13 Oct 1996 23:30:55 -0005
Tony Watts:
Except for one fundamental difference: jack stands don’t roll. If
you’re gonna use this kind of faulty logic, I’ll have to point out
that supporting one end of a car with 2 stands permits the same
analysis for the car to fall over SIDEWAYS.
Look at it another way: With the car supported on four stands, the
above analysis means that to get the car to fall off, you have to
lift it one inch! It weighs four thousand pounds, folks – you’d
have to be jerkin’ that car pretty hard.
The real concern with four stands is that the car may SLIDE off of
them. If the top of the stand is largely flat (as most are – the
little bends at the ends of the top are usually flattened early on)
and the stand is placed under something that might slide around on
the stands – such as the little posts intended to fit the jack on
the XJ’s – then even a relatively minor amount of shaking may cause
the car to slide on top of the stands, followed by either sliding
completely off of them or repositioning themselves enough to cause
the jack to tip over.
| - Palm’s Postulate
End of jag-lovers-digest V2 #434
id for jag-lovers-digest-out; Mon, 14 Oct 1996 16:46:00 +0200 (MET DST)
Date: Mon, 14 Oct 1996 16:46:00 +0200 (MET DST)
Message-Id: 199610141446.QAA06864@ekeberg.sn.no
Subject: jag-lovers-digest V2 #435
Precedence: bulk
jag-lovers-digest Monday, 14 October 1996 Volume 02 : Number 435
RE: Serial Number strangeness
BMW owns Jaguar!!!
Silly question
Battery
Re: Carb rebuild
Re:Jack stand warning
Re: BMW owns Jaguar!!! (NO jag content)
[WWW] update 14th October
Please read, list info
S-Types
Jag-lovers database
Re: Genesis of the Jag V12
timing chain noise
Drivers’ Eye of LeMans circuit from D-Type
'88 XJ-S with No Flow h2o
Re: jag-lovers-digest V2 #365
RE:Silly question
Date: Sun, 13 Oct 1996 20:38:34 -0700
Subject: RE: Serial Number strangeness
1997, according to the brochures handed out at the party.
I guess that’s why my 1987 1/2 XJ40, built in May of 87, is referred to as a “late” 87!
Mike Everatt
1987 1/2 XJ40
Sent: Sunday, October 13, 1996 7:22 AM
In
the US, Jaguar Cars seems to have tried to match the US concept of model
'97?
| - Palm’s Postulate
Date: Mon, 14 Oct 96 14:13:00 EST
Subject: BMW owns Jaguar!!!
I thought that you folks might like to learn of the latest development in
motor market ownership…
The Sydney Motor Show is currently in progress - this is quite an impressive
show, certainly the premier motor market event in Australia.
So I went along on Friday to take a look.
More out of politeness than anything else, I called by the BMW stand to see
what they had to offer. And, in order to start the conversation, (and
keeping my Jaguar keys well out of sight) I asked the able and qualified
sales assistants (who will happily take one’s order for one of their cars)
how the BMW 12 cylinder engine compared to the Jaguar V12. (I like a good
argument.)
Well, they proceeded to inform me that they were both pretty good, and that
the Jaguar engine uses a lot of ‘BMW technology’. “Oh really?”, I say,
somewhat bemused by this revelation.
Oh yes, they say. “After all, BMW owns Jaguar, and they have a major input
into all Jaguar designs” they offer, as further validation of their earlier
statement. “Oh really?” I say, by now gasping for breath.
I try to explain in monosyllabic words that, while BMW certainly does own
Rover, I think Jaguar is pretty definitely owned by ‘others’.
“Well, BMW certainly does own a large part of Jaguar…” - a certain loss
of confidence is now becoming evident. “…and they do have a major input
into their designs, and… and… the V12’s are very similar…”. They
then went of to lure someone else in from the adjacent Daewoo stand.
Would you buy a new car from this man??
Kim Rennick
'88 3.6L Sovereign
Date: Sun, 13 Oct 1996 23:48:07, -0500
Subject: Silly question
I realize this is a silly question but I hope someone will help me
anyway. Does the dash board illumination light on a S111 XJ-6, you
know the one that is mounted under the overhange above the center
vents, have a lens or cover plate. I just discovered that my 1986
model does not have a lens over the bulb, there is just a small
exposed bulb. It works fine but now that I have noticed that the
bulb is exposed I am wondering… Thanks
Date: Sun, 13 Oct 1996 23:40:56, -0500
Subject: Battery
I wouldn’t be worried about having an Interstate Battery in your car
it should work just fine. For the most part a battery is a battery,
and FYI Jaguar does not make its own battery. Yet it sounds to me
that the dealer did not have the proper size battery in stock so he
simply put one in. I would be very annoyed by this especially
considering you probably paid the Jag dealer top dollar for a job
that could have been better performed at your local gas station. I
would go back to the dealer and have him put the correct size battery
in your car, and if they still don’t have it go get the proper sized
battery from Sears or K-Mart or a gas station and return the small
one to the dealer.
Date: Mon, 14 Oct 1996 06:27:37 -0200 (GMT)
Subject: Re: Carb rebuild
Date: Sat, 12 Oct 1996 15:53:35
To: “MarrioSD”
I need to rebuild the SUs on my 65 ‘S’ type in the very near future.Can anybody advise me of the best rebuild kit to use.
Steve
I rebuilt a pair of 2" SUs for my '64 Mk II last year. I replaced the
standard 1.75" with a pair from a 420. I used a complete Burlen kit and
everything worked well. If I remember correctly you need the bigger (or
repair) kit if you have any problems with the carburettor body such as
bushing wear on the throttle spindles. The repair kit includes everything in
the service kit plus replacement bushes, spindles and throttle discs. The
service or cheaper kit has gaskets and a new choke tube etc. According to my
catalog from Burlen you need a CSK37 service kit or a CSK217 repair kit.
Burlen do an excellent manual/catalog for SUs which will give you some good
hints on rebuilding the carbs. I have no experience of any other kits, I
would stick to Burlen as they are now remanufacturing SUs and seem to be
world experts.Regards Brian
'64 Mk II
'86 XJSC
Date: Mon, 14 Oct 1996 15:01:04 +1000
Subject: Re:Jack stand warning
Subject: Re: Jack stand warningTony Watts:
thick piece of wood to chock the wheels.Except for one fundamental difference: jack stands don’t roll.
Yes they do. Unless you put them on a slippery surface.
If `you’re gonna use this kind of faulty logic, I’ll have to point out
The logic is not faulty. You didn’t read what I said. You are right about
the two stands.
If you only use two stands and the other wheels can move, you only have to
lift half the car. Mine weighs 1750 kg, half of that is say 900 kg
I weigh 90 kg. If I fall 10 inches I have enough energy to get half the car
up one inch. Admittedly this then means the car is being jerked harder than
is likely to happen, but the safety factor for a timid person like me is
not enough. As you say, if one of more of the stands slide relative to the
ground or to the car, there is even less of a safety factor.
Sorry to labour a point that is past its use by date, but I could not let
this criticism go without response.
Tony Watts
Date: Mon, 14 Oct 1996 01:26:03 -0400
Subject: Re: BMW owns Jaguar!!! (NO jag content)
In a message dated 96-10-14 00:14:43 EDT, you write:
<< Would you buy a new car from this man?? >>
What a fool!!! there are a lot of car salesmen who are fools. I will tell you
a couple of my experiences.
I was at an auto show several years ago, and went by the Lamborgini stand.
Well, I went to the salesman (who was free, I wouldnt take him from a real
customer if he was with one) and asked him to tell me a little about the
difference in the engine between the Countach and the LM002 (in case you are
not aware they were the same engine, but it was 50 HP more in the LM002 —
turns out it was mainly do to exaust/emmision laws that were easier for
trucks than cars), anyway, he said “it is a 12 in the countach.” I said, I
know that, and stated my question again. The reply (with a smile and
adjustment on his silk tie and fancy suit) they BOTH have 12 cylendar
engines". -
I was test driving cars, trying to find a good one to recomend to my
grandparents as a second car (nothing fancy). Well, when driving one (I
forget which, but I was looking in the Galant, Altima class of cars). the guy
said “this is the most powerful 4 cyl on the market”. I said, I sure, dont
you mean, the most powerful in its class?" he retourted with a bit of anger
in his voice “no, it is the most powerful!”. my reply “well, for turbo
models, isnt it the lotus esprit, and in normally aspirated, doesnt the
Porsche 968 put out 236 HP stock?” his reply “well, I dont count those kind
of cars”. -
last one. My convertable blew a fuse with the top half way up. I was in a
bit of a panic (due to where and when it happened) and was not thinking
clearly enough to just pull a fuse from something else to get my top the rest
of the way up (for those of you starting to sweat, it was a Porsche, not a
Jaguar, I have only owned XJ6 jags). Anyway, I called my Dealership (facotry
authorized) all the mechanics had gone home and the couldnt/wouldnt call one.
My manual was not in the car (I know, I know) and so they put me on with a
salesman. he said, call back in 5 minutes and I will tell you how to manually
override it, I will find a manual (he had 3 of my model cars on the lot). I
call back and the receptionist answers “He is with a customer, but told me to
tell you that it will go if you just force it.” I reply “are you sure i
really dont think that is a good idea. There must be a release or something”
she goes " no, just force it" well, it was about to start raining, and I
couldnt have the car towed, so like an A**&%^$%$^ that I was that night I
listened. SNAP. the top broke! well, I was able to get it home at least now,
since I could drive it. Well, I was able to get it fixed without paying the
$1700 that the repair ended up costing…in this story I was as dumb as the
salesman. But he sould have either said " I have no idea" or looked in the
glove box of one of the other cars. when I got to the dealership I checked,
all three had manuals, and it is clear in manual. you remove a panel and the
crank the top up or down.
well, that is it. I have learned. to take everything a salesman says with a
bucket of salt. at least until he proves he knows his stuff (some do). oh
yea, I once had a salesman take me for a test drive in a 944 and he couldnt
show me where the trip odometer reset button was. - Doug
Date: Mon, 14 Oct 1996 08:55:13 +0200
Subject: [WWW] update 14th October
Nothing major in this update, really. The arcives are current
again, up to about a week ago. With the level of traffic on
the list at the moment we average about 2 digests a day, a
far cry from the old days.
Yes, I will get round to updating the guestbook. I currently
have around 500 entries I have to go through and html’ize. I
have decided to start editing the guestbook more heavily now,
deleting entries that really don’t say much, unless they have
other redeeming aspects, maybe. It really is quite fun looking
at the access-logs from the web-pages, people are coming in
from virtually every contry in the world. We are truly seeing
global usage.
If you have submitted something for the web and can’t see it
yet, please remind me. Mail does get lost in the stacks I
receive every day and I don’t intentionally ignore anyone.
Just give me a subtle reminder and I will get right on the case.
The commercial sister site at www.jagweb.com is coming along
nicely. Currently representing the JDHT and 20 companies, including
Jaguar World (check out the nice list of back issues, plenty
of interesting material) and mainly UK specialists. Some of the
companies offer free catalogues that you can order by email,
sounds like a good deal to me. The site is still in its infancy
though, and many of the companies are on trial time to see if
there is any point to advertising on the web. Please have a look
and request some information from them, by email at no charge to
yourself. Give me a hand in dragging the olde worlde Jaguar
specialists into the age of the Internet
Thats all, for now.
Nick, your friendly admin
Date: Mon, 14 Oct 1996 09:53:19 +0200
Subject: Please read, list info
Just as a point of interest, we are now 812 members on the list.
368 on the regular list and 444 on the digestified list.
If you feel overwhelmed by the amount of messages on the regular
list, please consider changing from the regular list to the
digestified version. The digest is currently send out roughly twice
daily under normal conditions. Abnormal conditions occur occasionally
when someone screws up and posts a complete digest to the list, but
this doesn’t occur too often.
Digest-readers:
When responding to a topic from a digest, please make sure you
change the subject-field to something appropritate.
All readers:
Please quote carefully. When responding to a message it is courteous
to include the name of the person you are following up. It is also
courteous to only include the pertinent bits necessary for the thread
from the previous message. Please do not include more information
than is necessary. It is in everyones interest to keep the messages
to a maximum of new information and a minimum of repeated info.
My policy for unsubscribing people:
If mail to you bounces back over a period of time I will unsubscribe
you without further warning. There are several list-members where
this frequently occurs. If I know you and know that you often have
problems I will do noting. If the mail is returned with “user unknown”
I will remove you immediately. AOL-users that frequently have full
mailboxes will be removed after a few days, the same goes for Netcom-users.
If you find that mail from the list suddenly dries up, try to get
your problems sorted out and re-subscribe. If you are going away and
think your mailbox might fill up, please unsubscribe and catch up from
the archives. If you are abandoning a mail-account, please be courteous
and unsubscribe from the list.
Please understand that with over 800 subscribers to the list it is
impossible for me to provide personal service to everyone.
Final note:
When posting to the list make sure you send your message to
jag-lovers@sn.no
This is the only address that relays the message to the list. All
other combinations like jag-lovers-owner@sn.no only ends up in my
admin-mailbox. Several people every day manage to address their mail
incorrectly, and it does make work for me informing everyone.
Thats all, for now.
Nick, admin
Date: Mon, 14 Oct 96 12:10:37 gmt
Subject: S-Types
Ragnar Westad said about looking at an S-Type
The car has had �14,000 spent on it in 1992, in England
Can’t say much here, excpet for that money it must be one of the best!, and for
that price, I would expect perfect door fittings. Note, actually, the door
fittings were never that good around the rear door/rear wing line, that is where
most cars (including mine) give themselves away.
Door fit on these cars is probably one of the most time consuming items, and has
to be done before painting, but with door-seals fitted, and I ask how many do
that?
Most bodywork is much the same as the Mk2, as are engine problems.
The S-Type can suffer from rust to the inner rear wheelarches, and the rear
bumper valence in addition.
Also, the usual IRS problems, nothing particular to the S-Type
Alastair Lauener
64 3.4 S-Type
Date: Mon, 14 Oct 96 12:05:49 gmt
Subject: Jag-lovers database
Mark, you asked
[ Mark Stiles ittmjs@staffs.ac.uk ]
| I send in details to the Jag-Lovers database - how do I access this
| database?
The database is at http://home.sn.no/home/nick/database/main.html
It is a little out of date, but I am religiously collecting all the information
I get. Just trying to figure out the best way to automate the whole process
Regards, Alastair Lauener
Date: Mon, 14 Oct 96 12:27:50 gmt
Subject: Re: Genesis of the Jag V12
I have come across several copies of this publication. It comes with the
French, German and Italian insert. My understanding is that this is an
extremely rare item. If anyone is interested.
Not a rare item it seems.
Available from the Jaguar Daimler HEritage Trust at 6 UK Pounds + P&P
http://www.jagweb.com/jdht/jdhtpack.html
Jaguar Daimler Heritage Trust, contact,
Ann Harris, Archivist,
Fax +44(0)1203 405581
Date: Mon, 14 Oct 1996 14:17:09 +0200
Subject: timing chain noise
This is a question on a SIII XJ6:
On my car I can hear a strange sound coming from the motor. The car is '84 with 127.000 km. I can’t feel a stake down kit when feeling around the exhaust valve guide no.1. Following a hint from Robert Bradley, I used a screwdriver as a stethoscope and tried to localize it. The sound is more pronounced with the car at operating temperatur (80 degC) at comes from the exhaust side of the engine (i.e. left hand side). With the screw driver I can hear the valve tappets ticking, but this is not related to this sound. It comes from the front of the cylinder head from the place I would suspect the timing chains to be. The sound is intermittent, not regular (but far too often). Sometimes it stops for a second or decreases its amplitude. Sounds like a solid bolt ratteling against a solid wall - xylophone-like, not like a ratteling metal sheet. How urgently is this noise to be fixed? If it is the timing chain, how do I know how much tension I have to apply by adjusting the excentric idler? Thanks for any hints Bert Bert Willing '84 XJ6 Laboratoire de Ceramique - Departement des Materiaux Swiss Federal Institute of Technology (EPFL), MX-Ecublens, CH-1015 Lausanne Fone : (+41 21) 693 29 44 Phax : 58 10 email: Bert.Willing@lc.dmx.epfl.ch Eudora 2.1.1 ------------------------------ From: Gunnar Helliesen gunnar@bitcon.no Date: Mon, 14 Oct 1996 13:29:50 +0100 (MET) Subject: Re: Serial Number strangeness “Kirbert” palmk@gcn.scri.fsu.edu wrote:
'97?
Quote from http://www.jaguarvehicles.com/xk8.html (Jaguar US’ Web pages):
“Introducing the new 1997 Jaguar XK8 Convertible and Coupe”
Gunnar
Gunnar Helliesen | Bergen IT Consult AS | NetBSD/VAX on a uVAX II
Systems Consultant | Bergen, Norway | '86 Jaguar XJ6 4.2 Sovereign
gunnar@bitcon.no | http://www.bitcon.no/ | Vicki who? What .sig virus?
Date: Mon, 14 Oct 96 14:25:31 gmt
Subject: Drivers’ Eye of LeMans circuit from D-Type
From Tony O’Keeffe, there is a rather nice photograph, taken from the Drivers’
viewpoint at Lemans.
http://www.jagweb.com/jdht/lemans.jpg
This was from the trip to Lemans of the collection of D-Types this summer.
I hope more pictures from this will become available.
Further Jaguar Daimler Heritage Trust info available at
http://www.jagweb.com/jdht/index.html,
including Tony’s latest story for us about the years work so far at
http://www.jagweb.com/jdht/jdhtton2.html
Other Info here,
The XK8 engine and transmission
Interested in a tour of the factory
Jaguar Daimler Heritage Trust Vehicles
Material Available from J.D.H.T. * Lots of info here *
How to obtain your Heritage certificate, available from J.D.H.T.
Photographs from thr 1996 Season
The oldest Daimler, and an X300 Daimler
Daimlers in the Browns Lane Museum, Picture1, Picture 2
75 Earls Court XJS, Last Cabriolet, Last Convertible
End of the XJS
Drivers' Eye of LeMans circuit from D-Type
XJS and XK8
XK8 Press Pictures, Front quarter, XK8 and fhc E-Type, XK8 Side.
P40 XJS and P60 XJS for the JDHT collection
Ronnie Adams, Winner, Monte Carlo 1956 in a MkVII
A modern Daimler Century
The Daimler Corsica concept car, (Front quarter, Side Shot, Interior)
- Alastair Lauener Work Phone +44 131 455 2458 *
- Chief Technician Fax +44 131 455 2267 *
- Department of Building & Surveying *
- Napier University, Edinburgh EH10 5DT a.lauener@napier.ac.uk *
- 1964 3.4 S-Type story at http://www.sn.no/home/nick/alas.html *
Date: Mon, 14 Oct 1996 10:04:11 -0400
Subject: '88 XJ-S with No Flow h2o
Having just unclogged the XJ40 with advice from fellow jag-lovers, I’m
turning my attention to the XJ-S. Symptoms are foggy windshield and
water on the driver’s side (U.S.) front footwell only. I looked under the
car (with two ramps only!) and found one drain tube on the passenger
side. None on the other side. Shouldn’t there be one there too? I
inserted a wire into the one tube, but it didn’t seem clogged, plus some
water was dripping out of it. Does anyone have an idea of where the
clog might be, other than my cerebral passages? Thanks.
From: “Dr. Martin Dudziak, Virginia Commonwealth Univ.” MDUDZIAK@Gems.VCU.EDU
Date: Mon, 14 Oct 1996 10:26:51 -0400 (EDT)
Subject: Re: jag-lovers-digest V2 #365
Please change all my email to go to:
silicond@erols.com from now on.
Thanks, and sorry if this got inadvertently broadcast to all members.
Martin Dudziak
Date: Mon, 14 Oct 1996 15:32:20 -0700
Subject: RE:Silly question
This is the map reading light you’re refering and no it doesn’t, well
not on any I’ve seen.
Barrie Dawson
Chatham, Kent England
1985 SIII Jaguar Sovereign
Date: Mon, 14 Oct 1996 16:45:41 +0200 (MET DST)
Martin Dudziak
Thank you, Martin, you just made my day. Please observe the following:
When replying to a digest: Change the subject-field to reflect
the content of your message. -
Don’t use the reply-function to start a new topic, and especially
not when replying to a digest. -
Never, ever send unsubscribe-messages to the list. Send them to
majordomo@sn.no. In case of problems send a note to the admin
at nick@sn.no -
Unless you have tried yourself and failed, don’t ask the admin
to perform menial tasks such as changing your mail-address. If
you do, at least have the decency not to have done points 1-3. -
To do the task you are asking me to do all you have to do is
send a message to majordomo@sn.no with the lines:
unsubscribe jag-lovers-digest
(from your old address of course)
And then send a new message to majordomo@sn.no, this time from
your AOL-account, with the line:
subscribe jag-lovers-digest -
It really isn’t that tricky.
Dr. Nick, ticking time-bomb of tension
End of jag-lovers-digest V2 #435
id for jag-lovers-digest-out; Tue, 15 Oct 1996 00:24:09 +0200 (MET DST)
Date: Tue, 15 Oct 1996 00:24:09 +0200 (MET DST)
Message-Id: 199610142224.AAA21048@ekeberg.sn.no
To: jag-lovers-digest@sn.no
Subject: jag-lovers-digest V2 #436
Precedence: bulk
jag-lovers-digest Tuesday, 15 October 1996 Volume 02 : Number 436
Water and Air
Carb/engine tuning- help needed
XJ40 - Mystery Button
Daimler SP 250 “B” spec.
Salesmen (Zero Jag content)
Robert C Moreau - Introduction
Re: Carb/engine tuning- help needed
Dead cat
XK120 dream comes true
Re: Frank’s Dead cat
Re: Dead cat
Re: timing chain noise
Re: Alternate speedometer transducer gear for 1983 XJ6 5-speed?
RE: XJ40: Transmission
Toe-in and Camber for 84 XJ6
Date: Mon, 14 Oct 1996 09:45:42 -0700
Subject: Water and Air
Hey guys,
Been having good luck with my Jaguar lately so I haven't been that
active in posting to the list. Through a revelation in my brakes..I
am back posting.
I have been noticing when I come to a stop that it sounds like my
brakes are dragging or grinding metal to metal (not a good sound).
Especially when I am going slow and barely have the brakes on. Well,
I decided to jump under there and find out what is going on. Come to
find out, my pads are great!
Hmmm....Well, I decide to clean the brakes up pretty good and bleed
the brake lines. WHOA!!!!! There is water in the front right brake
line and LOTS of air in the left.
Anyone have a similar experience...if so..did you find out how the air
and water got into the lines? My guess is that it is the hose that
connects the brake cylinder to the frame of the body.
Also...I can't purchase low moisture brake fluid anywhere so I used
regular...did I make a HUGE mistake?
Justin
Date: Mon, 14 Oct 1996 17:09:30 +0100
Subject: Carb/engine tuning- help needed
Hi list,
As some may have followed my rebuilt 4.2 liter engine
received a set of Rallye cams (308 degree) with 10.75 mm lift
from VSE in UK. Th car is a XJ6 Coupe from 1978 in
European (Dutch ) trim that is equipped with 2 HIF7 carbs.
The car drove resonably after reassembly, but now that the
run in period
is over I’ve tried to open up for the 200 odd slumbering horses,
but only about half of them are awake.
Afte some unsuccesful adjustments of the carbies I gave in
and let a garage have a go at them. We got all new seals new
needles (BDY) for the things, checked float and damper
specs, and checked the ignition (old contact breakers which
works apart from insufficient centrifugal advance),
however the problem remains :
At idle and moderate acceleration up to about 100km/h is
pulls fine, but floor it and the power collapses. The garageman
said that if he pulls the manual choke full blast at the same
time as the flooring of the pedal, the car pulls very fine, which
makes him arrive at the conclusion : Fuel starvation (NOT the
pump) at high volumes of air. Further he concludes that the
carbs don’t fit that engine (with changed cams).
The only explanation I can think of is that the Cams have
somehow upset the air/fuel ratio, in that the breathing ability
is enhanced so much that the carb needle / jet can’t deliver
enough.
I could of course put the old cams in to prove a point, but
does someone have hands-on experience with such a
“problem”, or know how to “update” a SU carb to deliver the
expected ?
Have I really broken the fence and run into a no-mans land -
a white map area or where no Jaguar has ever before stepped
on - I just cant believe that. I have also troubles in
understanding that a small change in Cam timing could cause
such a dramatic effect.
My deceased father just whispered : What did I say ! - Don’t
change the engine…". Can he still be right ?
Again I am at wits end - just several hundred Dollars poorer,
as someone warned earlier.
And this car is supposed to be going to the Jag Sapres Day
in the UK in 10 days.
If you have any ideas or hints please respond with copy to my
home account also : 101454.2570@compuserve.com.
Regards Jeffrey Gram
From: Michael Powers/TEIR/Thomson Michael_Powers@teir.com
Date: 14 Oct 96 11:51:42
Subject: XJ40 - Mystery Button
Hell all:
On my 89 XJ6, I have found a strange rocker switch that is not mentioned in the manual. It is on the driver seat(US), on the side of the seat that faces the door. If you were seated and you dropped you left hand between the door panel and the seat, you could hit it. It is pretty large, and when I hit it, nothing noticeable happens. Any ideas? Thanks, Mike /-----------------------------------------------------------------\ | mpowers@teir.com | | “A man without hand is not a man. I’ve got so much hand | I’m coming out of my gloves.” | - George Costanza, in Seinfeld episode “The Pez Dispenser” *-------------------------------------------------------------------*/ From: Robert C Moreau RCMOREAU@istar.ca Date: Sun, 13 Oct 1996 10:35:52 -0700 Subject: Daimler SP 250 “B” spec. Hello everyone, I am presently looking at at Daimler SP 250 “B” spec. that a private seller is willing to part with. I am totally unfamiliar with this model. Very little (if any at all!) info is available. This car is in need of some restoration. It has more than 100,000 miles but the mechanics look ok. The outside needs some attention (it needs a paint job and a hood) but the inside (passenger area, dash, boot…) needs new upholstery, carpets… The vendor is asking about $10,000CAN (about 5,000 pounds or $7,500US) but he can probably be brought down somewhat. I like this car. It is powerfull, seems to be sturdy, has character and is somewhat rare) Could anyone enlighten me regarding its’ value, the availability of parts in general (and those I need in particular), the drawbacks of this model, published road tests and other comments. Thank you for your help! Robert C Moreau rcmoreau@istar.ca From: Ryan Border rborder@hpspls16.cup.hp.com Date: Mon, 14 Oct 1996 09:49:06 -0700 Subject: Salesmen (Zero Jag content) These car salesman stories reminded me of my favorite experience… The setup: My wife and I are shopping for a mini-van; to be used mostly to haul our bicycles (including a tandem) around inside of. We’ve pretty much decided on a Previa, but decide to go look at the Lumina’s to compare. Necessary Background: A couple of years earlier, I had gone on an interview trip to Edwards Airforce base. I sent my resume to all the local aerospace companies, told them I’d be in town, and would like to talk (needed a job). One of the companies that invited me in was Rockwell; who at the time were assembling one of the space shuttles… I think it was Endeavor. They gave me a tour, including a walk through of the assembly floor; and a (brief) look into the partially assembled cock-pit. To set the tone for the salesman, my opening statement to the guy was: “We’re probably going to buy a Previa. Why should we buy one of these instead, especially since my wife thinks it’s so ugly?”. He gave us a walk around on the car, pointed out the (pretty significant) price difference, and then offered a test drive. So a few minutes later we’re cruising down a country road (this is in rural Illinois), he’s pointing out all the cup holders and vanity mirrors to Joan, and then proudly says to me: “And the interior is designed after, and very much like the interior of the space shuttle”. I managed to suppress my laughter, and simply replied “No it’s not”. Rather snidely, the salesman then asked me: “Have you ever been inside the shuttle?”. Me: “Well… actually… Yes.” Him: “Really?”. I then explained how I had… and how the very last thing you’d want to do is design an automobile after the shuttle; mostly because of the poor visibility. Hmmm, then again, one of my complaints about the Lumina was the bad obstruction caused by the A-pillar… Anyway, I don’t think that salesman ever used the shuttle comparison on the Lumina again. Ryan. PS: We ended up buying the Previa. Eventually got tired of the payments, so now I haul those bikes around in my hearse. From: Robert C Moreau RCMOREAU@istar.ca Date: Sun, 13 Oct 1996 11:26:18 -0700 Subject: Robert C Moreau - Introduction Hello everyone, I just joined the list and I would like to introduce myself. I am 40 years of age, living in Montreal, Canada. My spouse(she’s a physiotherapist) and I have no children yet, but we’re starting to make plans about having 2. After practicing law for 10 years, I joined Nesbitt Burns, the largest stock brokers in Canada as an Investment Advisor. I have been with them for 5 years and things are going very well. I currently drive an Acura Vigor and Nathalie drives a Toyota Paseo. Many years ago (1979-1982) I owned a TR-6. I loved it!! Although it was in not too great shape I had a great time driving it. I loved the feel of driving this little but powerfull car down the winding roads to the state of Maine for vacations by the sea (I only drove it between May-Nov.) or around the city. I sold it to my then girlfriend’s brother for about the price I paid for it. 15 years later (with the picture of my Triumph still on my desk) I am looking forward to getting another one of these roadsters. This time I would like to put my hands on a first of hopefully 2-3 classics. My first project (to find out wether or not I still have the passion) would be to find a not too difficult project to renovate and bring up to an excellent condition. I am presently looking at a 1963 Daimler SP 250 “B” spec.as this potential first project. It appeals to me because it is a powerfull car (8 cylinder with semis) it looks and feels rugged, the shape has character and it’s not as common as many other ones (I was originally looking at an Austin-Healy 3000, but was told I wouldn’t fit in it - I am 6’4" tall) Its’ fiberglass construction would require only minimal body renovation while I could concentrate on the renovation of the interior and some mechanical adjustments with the help of a much more knowledgeable person. I am still trying to find out more about this model (history, road tests, availability of parts…if you have any, please let me know!) Later on, if things turn out well, I would like to undertake a more complex (and more rewarding project) like a Jaguar XK. But that will be for a few years down the road. Looking forward to reading your mail and sharing my own experiences and thoughts. Yours truly. Robert C Moreau From: Michael Frank mfrank@westnet.com Date: Mon, 14 Oct 1996 13:07:33 -0400 (EDT) Subject: Re: Carb/engine tuning- help needed Jeffrey: This is exactly correct. The cam lift and timing changes the fuel delivery requirements. The problem can probably be fixed with a new set of carb needles. Only hitch is, there are about 1,000 different SU needles. The first thing I would do is to go back to the cam manufacturer…they are in the best position to recommend a needle. (The high lift cam for my E-Type came with new needles, PO warned me never to change them for standard.) Barring that, try contacting Burlen’s, they may have a recommendation. SU’s fuel delivery is controlled by the action of the piston and the needle. As the engine is stressed, the piston is drawn up into the chamber, exposing narrower and narrower cross-sections of the tapered needle. This has the effect of allowing more fuel to pass thru the jet under heavy load. Different needles have different tapers, therefore change the characteristics of the carb. The proper way to select a needle is with a dynamometer. By running the engine at load, the rpm at which fuel starvation occurs can be identified. Measuring the carburetor piston lift at this point will allow the correct needle taper to be selected. If you have lots of patience, you can also select needles by trial and error, but you will have lots of trials and lots of errors (and you will need lots of needles). Mike Frank 1969 E-Type 2+2 At 05:09 PM 10/14/96 +0100, you wrote:
enough.
Date: Mon, 14 Oct 1996 13:23:49 -0400
Subject: Dead cat
After all the trouble I have been through with my Jaguar I thought I
could finally take the time to enjoy it. However the car had other
plans. For the first time ever the car left me walking. 5 miles to be
exact. Passed by two FHP troppers ( thanks guys ) I had the car towed
back to the house and proceeded to try to start it. When it did start I
was greeted by a loud rattle, like valve tapping only ten times worse.
Then after placing the car in gear to try to move it,it wouldn’t even
budge the rpm bogged to 500 and stalled. The under cariage is painted
with oil and theres no water in the car. A long story short, the car
will be at samsula auto salvage in new smyerna beach after 1pm today if
anyone wants it. He’s going to run it to auction and I will be
responsible for rest of bill. Thanks for all the help this list has
given me BYE. Frank Perrick X Xjs Owner
Date: Mon, 14 Oct 1996 19:48:52 -0200 (GMT)
Dear Jeffrey
Hi list,
from VSE in UK.If you have any ideas or hints please respond
Four areas to think on, maybe
- Fax VSE and get their set up specs for the cams
- Fix the advance problem with the distributor
- Try the mixture setting on the carbs, although I expect you’ve done this.
40 Vary the cam timing, my “tame” Jag expert has tuned 2 different 3.8
enginesboth with higher lift cams (Iskenderian profile) and has moved the
max power band from 3500 - 4500 rpm (my road car) to 4500 - 5500 rpm (his
occasional race car).
Hope this helps Regards Brian
Date: Mon, 14 Oct 1996 13:29:22 -0500
Jeffrey,
A few things to try:
- Check your dash-pots for fluild. Try differing weights of oil in the
dash-pots. A higher number makes the carbs richer during acceleration. Start
with a 20 weight and work up to a 50 weight. - Try a higher volume fuel pump with a regulator. I’ve seen cases where the
orginial pump can’t keep up without help. - Check the fuel lines for kinks. Replace any old lines.
- Replace old ignition wires. I had a car which ran great until I would
floor it. They were breaking down under load. - Try some richer needles. If you can’t find ones that work, get a pair
that are lean and start turning them down on a lathe until you get the right
setting. - Check your tank screen and filters for blockage.
Hope some of these suggestions help.
Cleo Bay
52 XK120
56 XK140
62 E-Type
65 3.4S
Hi list,
European (Dutch ) trim that is equipped with 2 HIF7 carbs.The car drove resonably after reassembly, but now that the
run in period
but only about half of them are awake.Afte some unsuccesful adjustments of the carbies I gave in
however the problem remains :At idle and moderate acceleration up to about 100km/h is
carbs don’t fit that engine (with changed cams).The only explanation I can think of is that the Cams have
enough.I could of course put the old cams in to prove a point, but
expected ?Have I really broken the fence and run into a no-mans land -
such a dramatic effect.My deceased father just whispered : What did I say ! - Don’t
change the engine…". Can he still be right ?Again I am at wits end - just several hundred Dollars poorer,
as someone warned earlier.And this car is supposed to be going to the Jag Sapres Day
in the UK in 10 days.If you have any ideas or hints please respond with copy to my
home account also : 101454.2570@compuserve.com.Regards Jeffrey Gram
Date: 14 Oct 96 14:30:51 EDT
Subject: XK120 dream comes true
Dear friends
Finally I have made one of my dreams come true! On my last trip to Florida I
have baught a XK120 DHC 1953!!!
I’m happy and I really can’t wait untill it is shipped to me to Switzerland!
It is in the moment an ugly duck but I hope to make a beautiful swan out of it!
I certainly will be asking many silly questions when it arrives. I already have
a bunch of them, but I don’t want to start to early with the questions.
Is there any sub-group of this group handling only XK Jaguars?
Best regards Zoran MItrovic
85 XJ6 SIII
53 XK 120 dhc
Date: Mon, 14 Oct 1996 14:40:30 -0400
Subject: Re: Frank’s Dead cat
Yes, that’s the problem with those darn cats.
They seem to need oil and water as well as gas.
Darn cats!
Charles Daly, Toronto, Canada
'62 E-Type, ots
Date: Mon, 14 Oct 1996 14:57:28 -0400 (EDT)
Subject: Re: Dead cat
Sorry for your trouble with the car. I’m sure it took some out of your
hide. Hope you make it up.
John
plans. For the first time ever the car left me walking…
Date: Mon, 14 Oct 1996 14:55:05 -0400 (EDT)
Subject: Re: timing chain noise
Bert:: Just tighten the upper chain, you cannot over tighten it. If the
noise is still there on the exhaust side then I would remove the cam
cover,check to see if the cam has been hitting the guides. If it has just
drive the guide back into the head, and install a hold down kit.
Chad Bolles Jaguar South 306 Valcour Rd Columbia SC 29212 USA 803 798 3044On
bolt ratteling against a solid wall - xylophone-like, not like a ratteling metal sheet.How urgently is this noise to be fixed? If it is the timing chain, how do I know how
much tension I have to apply by adjusting the excentric idler?Thanks for any hints
Bert
Phax : 58 10
------------------------- Eudora 2.1.1 ------------------------------
Date: Mon, 14 Oct 1996 14:58:27 -0400 (EDT)
Subject: Re: Alternate speedometer transducer gear for 1983 XJ6 5-speed?
William::: No the GM Turbo 400 shares no parts with any other trans in
the Jag. Also the Turbo 400 never came in the XJ-6. Order your part from
Jag, have fun.
On Sun, 13 Oct 1996, William J. Earl wrote:
I have a 1983 XJ6. It is a US model, with the automatic
transmission replaced a European model 5-speed manual transmission.
As far as I know, the parts are all stock, but the final drive appears
to be the one shipped with the car. The speedometer and the trip
computer, which use the same electronic speed transducer at the back
end of the transmission, both indicate 8% low. That is, at 65 MPH,
they read 60 MPH. I notice in the Jaguar Series III Service Manual
that the stnadard final driver ratio was 3.31:1 (43/13), with 3.07/1
(43/14) being an optional alternative (if I am interpreting the
wording correctly). This difference corresponds to the 8% difference
I am seeing.I suppose that I have a 3.31:1 final drive, but a transducer
drive pinion geared to match a 3.07:1 final drive. Is this a
reasonable conclusion? Are the drive pinions common to all three
tranmissions (manual, BW66, GM400)? If so, what is the easiest way to
acquire the appropriate transducer drive pinion? Since the manual
transmission was not shipped on any US vehicles for this vintage, I
suspect that it may take a long time to order the pinion through the
dealer.
Date: Mon, 14 Oct 1996 15:16:35 -0700
Subject: RE: XJ40: Transmission
Why 54mph? Probably had to do with US speed limit of 55mph.
Mike Everatt
1987 1/2 XJ40
From: Rennick, Kim (AS01)[SMTP:KRennick@p03.as01.honeywell.com.au]
Sent: Monday, October 14, 1996 10:41 AM
To: ‘jag-lovers (post)’
Lou wrote:
I have a 92 XJ40 which thunks at 50MPH, it thunks when I reach 50 and
when I slow down to 50. I asked the dealer about this and was told that
this is normal. I sure hope so. I also would be interested in hearing
about this.
Kim Rennick
'88 3.6L Sovereign
Date: Mon, 14 Oct 1996 14:07:00 -0700
Subject: Toe-in and Camber for 84 XJ6
My car is in need of a front alignment but I need to know what the =
specs are for this. I know my Haynes manual is wrong and have been =
unsucessful in finding them in the XJ6 help book.
Can anyone give me these specs and any others I might need for a front =
end alignment?
Thanks=20
Julio.
PS. Maybe we should include these specs in an appendix to the XJ6 =
book.
End of jag-lovers-digest V2 #436
X-UIDL: 4b13bec0431065e04e433b031f866df9
Return-Path: @owner-jag-lovers-di1
Received: (from majordom@localhost) by ekeberg.sn.no (8.7.5/8.7.3/on4)
id for jag-lovers-digest-out; Tue, 15 Oct 1996 04:54:09 +0200 (MET DST)
Date: Tue, 15 Oct 1996 04:54:09 +0200 (MET DST)
Message-Id: 199610150254.EAA29194@ekeberg.sn.no
X-Authentication-Warning: ekeberg.sn.no: majordom set sender to owner-jag-lovers-digest using -f
Subject: jag-lovers-digest V2 #437
Reply-To: jag-lovers@sn.no
Errors-To: @owner-jag-lovers-di1
Precedence: bulk
Status: RO
X-Status:
X-Newsgroups: mail.jag-lovers-digest
jag-lovers-digest Tuesday, 15 October 1996 Volume 02 : Number 437
Adjusting Fuel/Air Mixture and Idle RPM of 84 XJ6
Euro Head lights
Jag articles on the WWW
Re: Carb/engine tuning- status
Re: XJ40 - Mystery Button
Rebuilding E-Type master cylinders
[NON-JAG, but funny] The Chicken Gun
An XK8 in a small town
[SIII XJ6] Butterfly valve and microswitch adjustment
Re: 71 E-Types
Thrown rod ??
Re: ticking noise
Re; BMW owns Jaguar
XJ40 Oil Change - The Answer?
[Little or no Jag content again] Countach
[www] update
Date: Mon, 14 Oct 1996 14:00:44 -0700
Subject: Adjusting Fuel/Air Mixture and Idle RPM of 84 XJ6
I've been trying to smoothen out the idling of the engine and need to =
check/adjust the fuel to air mixture and set the Idle RPM. I know where =
both of the adjusting screws are but don’t know how many turns out they =
should be set to. Sometimes while idling at a stop, but on drive, the =
engine rpm fluctuates about 100 rpm accompanied by a little engine =
shaking. So I am in the process of eliminating components. Compression =
readings are good and even in all six and the spark plugs are new. I =
will be putting a scope on the car next to see if an injector is at =
fault.
According to the manual, the fuel/air mixture should be adjusted while =
measuring the emissions. Since I don’t have an emissions analyzer, I =
need to know what the factory setting is (United States). I think =
someone mentioned that it was 6 turns out from the bottom. Is this =
true. I have turned this screw while the engine is idling and have not =
noticed any significant difference in the idling. Should the adjustments =
be done with the oxygen sensor disconnected? I will be cleaning the air =
flow meter with brake cleaner while I at it. Is there a way to know if =
the air flow meter is not giving intermitent readings. =20
As for the idle speed adjusting screw, how many turns out should it be =
if everything else was working Ok. I have been able to adjust the idle =
RPMs with this screw but I just want to know what the factory set it to =
when the car was new.
Thanks
=09
Julio.
Date: Mon, 14 Oct 1996 18:07:56 EDT
Subject: Euro Head lights
I would like to know if anyone might have the parts I need to put the 7"
out side headlights on my 1985 XJ6.
I use to have a euro model 1985 XJ6 that was set up like this and like
the look.
Thank You
Bill Kroeger
Bill Kroeger
St Paul MN
1985 XJ6
E-Mail ( blkcat@juno.com )
Date: Mon, 14 Oct 1996 15:58:48 -0700
Subject: Jag articles on the WWW
Bumped across these today:
XK8: http://www.motortrend.com/november/9611jag/jag_f.html
X200: http://www.motortrend.com/november/9611int/int_1f.html
Ryan.
Date: 14 Oct 96 18:52:28 EDT
Subject: Re: Carb/engine tuning- status
Thanks very much to those who responded so far
I phoned VSE in UK where I have bought the rallye Cams and asked. Prompt answer
HIF7 carbs were used primarily for emissions reasons and VSE had only
ever had success with these with stock engines. No “fiddle” would make them work
with a modified Cam engine. I should use the HS8 carbs or HD8’s - and be
prepared to fiddle -
with needles - suddenly EFI with closed loop lambda control seems like a
brilliant idea - bolt on and
let the EFI sort itself out - yeah that’s the way we like it - keep on
dreaming…
The stupid thing is I have just sold my two HS8’s to a fellow jag-lower… Had
them in the cellar
and sold them just before I needed them. Again my old man was right , also in
another respect :
don’t ever throw things out - they will become indespensable shortly after yoy
dispose off them -
A variant of Murphy’s first law.
I’ll feel really stupid paying the bill for the mechanic to try and solve an
unsolveable problem -
this should not have happened - selfesteem dropped two notches.
A triple HD8 carb set seem’s appropiate - just only 10 days to get 'em on before
the UK spares
day on the 27th Oct.
To reply to some suggestions :
Tried the fat mixture settings and oil in dash-pots : no difference
Higher volume fuel pump : not tried but almost surely not the problem -
pump will deliver oozes of petrol.
Replace ignition wires : not tried but true - these are old and have been
troublemakers before, new are in stock
Try richer needles : For the HIF7 carb there are no richer needles - VSE have
tried already
more than what I am prepared to go through - experience taken at face value :
Jim Isbell : update the XJ6 book !
Check tank filters and screens for dirt : Done - Tanks and filters are just
replaced / repaired 3000 km ago.
Check ignition : Done . Advance not sufficient, however will not cause collapse
of power
- at most a loss of the last “10 %”.
Vary cam timing : not done, however the cam adjustment timing (when done real
professionally) is
a bloody time comsuming task involving several micrometer devices and a power
test stand -
I’m not even going to try that. But I’ll check the timing next time cam covers
are off - Ryan Border
and I know now how to do this after our long discussion last feb-march…
Jim C. tell the changed cam profile changes the volumetric efficiency of the
engine requiring
a change in fuelling. This sounds correct and fits with the observed
performance (or lack of it rather).
I speculate if part of the problem may lie in that the greater and easier
breathing causes a
lowering of the vacumm in the carb therebu causing alower than perfect raise of
the piston
which in turn causes less fuel to be available since the needle is also
controlled by this raise in the
piston. I havent had a carbon monoxide tester on while driving, but I think
I’ll get a GUNSON
CO measurement equipment from UK (about 50 pounds) which could be broought along
during test
driving.
Raising the needles / raising the fuel level in the float would maybe help but
since VSE have tried
already without success this is hardly worth it. Michael frank suggested similar
trial and error method,
but again - chance of succes is small.
Ryan also report problems in carb adjustment with changed cam timing - there is
more to know
about the engine than just throwing other cams in.
Ok that was the status so far. Stuff for thought !
r
Date: Mon, 14 Oct 96 16:31:25 PDT
Subject: Re: XJ40 - Mystery Button
On my 89 XJ6, I have found a strange rocker switch that is not mentioned in the manual. It is on the driver seat(US), on the side of the seat that faces the door. If you were seated and you dropped you left hand between the door panel and the seat, you could hit it. It is pretty large, and when I hit it, nothing noticeable happens. Any ideas? That buttons is supposed to move to seat back to faciliate exit from the car. I guess yours is not working. Roger Peng (408)765-7863 Intel Corporation Design Technology, Physical CAD From: rrichardson@eurekanet.com (Robert J. Richardson) Date: Mon, 14 Oct 1996 19:44:59 -0500 Subject: Rebuilding E-Type master cylinders I had posted tips on disassembling a brakemaster cylinder on a 3.8 E-Type. Apparently, it didn’t connect with the list. If you have a leaking master cylinder and need to replace the rubber seals, you must identify the make of the master. It’s either a Girlind unit or a Dunlop unit. The Girling sectional is shown on page L.12 of the service manual. It has an additional seal midway on the piston. The Dunlop unit has a rubber cup seal at the base of the piston and the rubber seal that caps the valve unit. Mark Roberts gave me a tip on separating the piston from the valve assembly. Should you need help on this, send me an E-Mail and I’ll explain the procedure in detail. From: Gunnar Helliesen gunnar@bitcon.no Date: Tue, 15 Oct 1996 01:04:22 +0100 (MET) Subject: [NON-JAG, but funny] The Chicken Gun I’m sorry for the waste of bandwidth, but I thought maybe some of you might appreciate this one which I received from a friend of mine: The Chicken Gun In a recent issue of “Meat & Poultry” magazine, editors quoted from “Feathers,” the publication of the California Poultry Industry Federation, telling the following story: It seems the US Federal Aviation Administration has a unique device for testing the strength of windshields on airplanes. The device is a gun that launches a dead chicken at a plane’s windshield at approximately the speed the plane flies. The theory is that if the windshield doesn’t crack from the carcass impact, it’ll survive a real collision with a bird during flight. It seems the British were very interested in this and wanted to test a windshield on a brand new, speedy locomotive they’re developing. They borrowed the FAA’s chicken launcher, loaded the chicken and fired. The ballistic chicken shattered the windshield, went through the engineer’s chair, broke an instrument panel and embedded itself in the back wall of the engine cab. The British were stunned and asked the FAA to recheck the test to see if everything was done correctly. The FAA reviewed the test thoroughly and had one recommendation: “Use a thawed chicken.” If not Jag related it’s at least sort of vehicle related… (I’ll make up for it in my next post, promise!) Gunnar Gunnar Helliesen | Bergen IT Consult AS | NetBSD/VAX on a uVAX II Systems Consultant | Bergen, Norway | '86 Jaguar XJ6 4.2 Sovereign gunnar@bitcon.no | http://www.bitcon.no/ | Vicki who? What .sig virus? From: rrichardson@eurekanet.com (Robert J. Richardson) Date: Mon, 14 Oct 1996 20:08:24 -0500 Subject: An XK8 in a small town This is hard to believe, but I had an experience this morning that shook me up a little. I had just read several writeups on the new XK8 last evening. When I left my home on my dead-end street (just 16 houses in all), I was greeted by a red XK8 driven by an elderly gentlemen with an equally elderly classy lady in the passenger seat. It was warm enough for him to have the top down. Of course, he took no notice of my silver BMW, but did I oggle him and the new classy Jag. Why was I so startled. Athens, Ohio, is a small city of 10,000 in the summer that swells to 30,000 when Ohio University is in full session. We are nestled in the hills of Southeastern Ohio where poverty is at its greatest in the state. Abandoned coal mines and overgrown farmlands greet the visitor. Rusty pickups haul mostly windblown children with spouse and driver protected from the elements. Food stamps are a viable currency in at Kroger’s. Leash laws are ignored and deer plunder our flower gardens. An occasional juvenile male black bear swims the Ohio and tries to make our wildnerness his denning place. And there it was, cruising down my street-that beautiful red XK8. And where was my E-Type FHC? Up on jack stands in my closed garage. What irony. I would have given anything to have been in my gunmetal gray E when I met up with the old gent driving the XK8. Would he have been the startled one? I’d like to believe that he would. From: Gunnar Helliesen gunnar@bitcon.no Date: Tue, 15 Oct 1996 02:20:40 +0100 (MET) Subject: [SIII XJ6] Butterfly valve and microswitch adjustment Folks, Here is the promised posting with Jag content to make up for the previous non-Jag posting I made today Jim, I hope you can use this in your book. I’ve long had a problem with my '86 Series III XJ6 4.2 stumbling when I applied the throttle from idle. This could be a real problem when trying to make haste when crossing an intersection for example. A friend familiar with the Bosch L-Jetronic EFI system told me I should have a look at the small microswitch on the butterfly valve (the main throttle body on the EFI system). This switch is normally closed (on) at idle and should open the instant you press the accellerator to tell the ECU that the engine is no longer idling. If this switch is set to open too late or too soon the ECU will think the engine is still idling when in fact you are trying to increase the revs or vice versa. The ECU will compensate and thus “fight” what you are trying to achieve. Before you try to adjust this microswitch it could be a good idea to adjust the main throttle valve itself (the butterfly valve). The procedure is well documented in the Jaguar shop manual except for one thing: The manual doesn’t say how important it is that you adjust the butterfly valve/valve housing clearance to be as small as possible. When they tell you to use a 0.05 mm (0.002 inch) feeler gauge they really mean it. If this clearance is set too big it could cause problems in adjusting your idle speed low enough (to around 800 rpm). How do I know? The procedure is simple: Remove the elbow hose going from the airflow sensor to the butterly valve housing. Release the lock nut on the butterfly valve stop bolt and turn the bolt so far in that it will no longer support the valve arm and thus let the valve close completely. Insert a 0.05 mm feeler gauge between valve and housing. Turn the stop bolt out again until it barely touches the arm on the valve’s axle. Secure the lock nut. Remove the feeler gauge and test the operation of the valve making sure it doesn’t stick at all when you try to open it. If it does you will have to increase the clearance slightly. Next for the microswitch. The shop manual is actually incorrect here, it tells you to adjust the switch so that it opens when the outer (big) arm on the butterfly valve axle touches the inner arm (the arm that is directly connected to the valve). This is in fact too soon. There is a small clearance between the two arms allowing the outer arm (the one the throttle cable is attached to) to move a millimeter or so before touching the inner arm and thus opening the butterfly valve. You need to adjust the switch so that it opens the instant the inner arm starts to move. This is fairly logical when you think about it, but strangely enough not what the manual tells you to do. I know from experience that this adjustment is a bit tricky to get just right, but if you don’t you won’t get rid of the stumbling. The procedure: Remove the two wires going to the switch and attach an Ohm-meter so you can see when the switch is open or closed. Loosen the two screws that hold the switch body to its mounting plate just enough to allow you to move the switch with some effort. Pull on the outer arm (mimicking the pull of the throttle cable) and adjust the switch to open the instant the inner arm starts to move (but not before). Fasten the two screws holding the switch body and re-attach the wires. Replace the elbow hose and go for a test drive. Hope this helps somebody, I’ve been struggling with this problem for some time (in fact I’ve been struggling with both problems since I got the car. Don’t know if I should blame the PO or Oslo Jaguar Service though… Gunnar Gunnar Helliesen | Bergen IT Consult AS | NetBSD/VAX on a uVAX II Systems Consultant | Bergen, Norway | '86 Jaguar XJ6 4.2 Sovereign gunnar@bitcon.no | http://www.bitcon.no/ | Vicki who? What .sig virus? From: “Robert A. Bagramian” robtbagr@umich.edu Date: Mon, 14 Oct 96 21:27:14 -0600 Subject: Re: 71 E-Types To Lloyd and Tommy and the rest… A fair number of series two 71 E types were manufactured. These cars are not series three and have the identical bodies as all the rest of the series II… with two additions that I know of… Again, a small chrome bead that completey circles the mouth of the air intake on the front of the hood… (Not a series three grill) and small square plastic black jaguar emblems on each side of the hood… Other than that the 69,70 and 71 E types are identical… By the way the vehicle number for my 71 is 2R14423… quite late in production compared to the numbers for Lloyd and Tommy… Do not have the date of manufacture or chassis number at hand but will try to get it… Bob Bagramian… 70 E, 71 E, 72 XJ-6, 88 XJ 40 From: Frank Perrick frankp@mscnet.net Date: Mon, 14 Oct 1996 16:20:24 -0400 Subject: Thrown rod ?? I had my XJS towed out to a junk yard today and they said the motor threw a rod and are refusing to take the car unitil I pay off the balance of $2,100 that I owe them ,or fix the motor they say the car is worthless as is. What is a thrown rod ?? Has any one done this repair? Why are they recomending a chevy motor being cheaper than repair the V-12 ?? All I want to do is get rid of the thing and I can’t even do that ! Frank Perrick From: Gunnar Helliesen gunnar@bitcon.no Date: Tue, 15 Oct 1996 02:53:41 +0100 (MET) Subject: Re: ticking noise Veronica Coats rccola@ctos.com wrote:
Hi Troops
Recently I aquired my Jag. I sometimes think I should leave the radio
up louder because I hear many things I probably shouldn’t hear.I have
have a slight ticking noise in the front drivers side. Other passengers
in the car can’t hear it but I know this car. My problem is that I live
100 miles from my nearest service dept. and I would like to
troubleshoot this problem. Any guesses!!!
Veronica,
I was going to reply to your message suggesting a problem with a loose
tappet guide when it dawned on me that you didn’t tell us what kind of
Jaguar you have. I think you should try reposting your message to Jag
Lovers but his time remember to include some more information about your
car:
- Which Jaguar model (XJ6, XJ12, XJ40 (post 1987 XJ6), XKE, XJS…
- What model year your car is
- Which engine you have (2.8, 2.9, 3.2, 3.4, 3.6, 3.8, 4.0 or 4.2 for six
cylinder engines or 5.3 or 6.0 for twelve cylinder engines) (Did I miss
any?
Maybe also some more info on the noise:
- Is it there when the engine is cold or just when it is hot?
- Is it intermittent or steady?
- Does it go away if you rev the engine with the transmission in Park or
Neutral or is it there all the time?
Open the hood/bonnet and try to check whether:
- It comes from the engine itself or one of the (on later models many)
engine accessories? - It comes from the front or back of the engine?
- It really comes from the drivers side (what is your drivers side by the
way? Left Hand Drive or RHD?) or not?
As you can see there are many variables when dealing with a Jaguar…
IF you have a Series III XJ6 (1979-1987) with a 4.2 liter six cylinder
engine and the noise comes from the left hand side of the engine at the
top (and maybe only when the engine has reached operating temperature),
chances are you have a loose tappet guide. This is a serious problem and
should be attended to immediately by someone who knows Jaguar engines.
There are two solutions to this problem, one is installing a so called
“tappet guide stakedown kit” (available from several Jaguar specialists
in the US and elsewhere(?)) and the other is installing a small screw to
hold each tappet guide in place. Both require dismantling of the cam
covers and drilling in the engine’s cylinder head (and should be done
by a professional).
Gunnar
Date: Mon, 14 Oct 1996 21:20:20 +0100
Mike,
Your mystery button is a ‘Drivers’s Seat Entry/ExitSwitch’
According to the manual (UK), this facility will operate when the driver’s
door is open or when the ignition switch is in position ’ II '.
Press the switch to move the seat rearward.
To move the seat forward, press the seat adjustment switch on the centre
console.
Never used mine!
Brian
in the manual It is on the driver seat(US), on the side of the seat
that faces the
panel
nothing >noticeable happens.
Date: Mon, 14 Oct 1996 15:24:33 -0500
Subject: Re; BMW owns Jaguar
I have over the years heard some very insulting things about my cars.
Once years ago when I drove into a service station in a brand new Citroen ID
19 the pump operator (that tells you how long ago it was) asked me how much
it cost me to have that body put onto a Volkswagen.
Then three days ago a neighbor asked me what kind of kit car my “new” XJS was.
Its all I can do to keep from committing mahem when someone says something
like that. But I am usualy very civil and explain to them so that they know.
JIM I.
“Prefiero morir de pie que vivir de rodillas.”
Gen. Emiliano Zapata
1879-1919
Date: Mon, 14 Oct 1996 20:38:57 +0100
Subject: XJ40 Oil Change - The Answer?
With reference to my request a few day’s ago concerning my question
on a suitable lubricant for my XJ40, I thought the member’s may be
interested in a web site I found at :-
http://skylands.ibmwr.org/tomk/sbr/tom/tech/oil_facts.html
This page explains in considerable detail the slippy stuff and has
certainly increased my knowledge of engine oil.
Hope it is of interest.
Brian
Date: Tue, 15 Oct 1996 03:49:07 +0100 (MET)
Subject: [Little or no Jag content again] Countach
Some of you might remember that I told you about a friend who’s been
fixing his Lamborghini Countach’s V12 engine.
I said it was an '87 that had seen 30,000 kms of service. It turns out I
was a bit off, it’s an '86 that has only seen 20,000 kms of service.
After finally finishing replacing the cam chains and adjusting all 48
valves (it’s a Countach 5000 Quatrovalvole) we tried to adjust the timing
and discovered that the distributor is shot! Worn out after only 20,000
kms! Give me a Jaguar V12 any day… All you XKE owners who complain
about needing small fingers to work on your cars, ever tried adjusting
the ignition timing or the cam chain tensioners of a Lamborghini V12?
We put the distributor back in as a new distributor for a Lamborghini is
a bit hard to find in Bergen, Norway at 11 pm on a Monday night.
We took the car for a test drive and I have to tell you, the sound of
that V12 sure makes up for its lousy build quality!
I want a V12 some day!!! (Jaguar, of course) Soon!!! Arrrrggghhhh!!!
I’ll never forgive Jaguar for dropping the V12 for '97. “XJ12 Sedan
discontinued” they calmly state on their Web pages. The XJS is already
history to that’s the sad end of an era… a lousy V8 is supposed to
replace the glorious twelve we’re told. Bollocks, I say! I don’t care how
advanced it is or how much Jaguar has spent on developing the AJ-V8. It’s
still a lump to me no matter what. Jaguars are supposed to have n6
cylinders! 1.336 cylinders? Nah, all wrong.
Anywho, you should have seen the reaction of people we met along the road.
Instant whiplash! (There are only three Countachs in all of Norway, the
other two are in Oslo). We parked in front of snackbar to grab a bite
to eat and suddenly heard truck brakes whining. A truck driver stopped
his rig in the middle of the road, turned on his “hazard” lights and
jumped out to look at the car. Fun! I’m sure he would have done the same
if I had parked an XJS convertible (or an XKE!) there instead.
Moral of story: Never let a car sit for a long time without being used
(the Lambo has sat still for three years for tax reasons). And nothing
beats the sound of a V12!
Gunnar
Date: Sun, 13 Oct 1996 21:52:27 +0200
Subject: [www] update
JagWeb: new digest in place
JagWeb.com: total of 21 companies now represented. Newcomers
are Zwakman Jaguar, AJ6 Engineering, Paramount Performance
and G.W. Bartlett. Some of the companies offer free catalogues
that you can order by email, sounds like a deal to me.
Nick
<<< Nick Johannessen | nick@sn.no | nickj on IRC >>>
<<< Jaguar XJ6 4.2 '70 MOD & '82 Auto >>>
The JagWeb http://www.sn.no/~nick/jaguar.html <<<
End of jag-lovers-digest V2 #437
id for jag-lovers-digest-out; Tue, 15 Oct 1996 10:07:09 +0200 (MET DST)
Date: Tue, 15 Oct 1996 10:07:09 +0200 (MET DST)
Message-Id: 199610150807.KAA07379@ekeberg.sn.no
Subject: jag-lovers-digest V2 #438
Precedence: bulk
Status: O
X-Status:
jag-lovers-digest Tuesday, 15 October 1996 Volume 02 : Number 438
Re: Silly question
Re: Thrown rod ??
Re: [NON-JAG, but funny] The Chicken Gun
Re: S3 E-Type rear camber [was: Re[2]: Concours Judging]
Re: ‘88 XJ-S with No Flow h2o
Re: Thrown rod ??and Hook,Line and Sinker??
Jack Stands & Ramps
Re: Silly question
Daimler SP 250.
Re: Jag Certificate
tick noise in 90 xj6
I’'m Back/ Concours
Re: Silly question
Introduce myself and ask a question
Re: auto (Jaguar) event in New York
Date: Mon, 14 Oct 1996 14:47:48 -0400 (EDT)
Subject: Re: Silly question
Michael: Not a silly question at all, the answer is NO.
Sun, 13 Oct 1996, MR MICHAEL D FATSI wrote:
I realize this is a silly question but I hope someone will help me
anyway. Does the dash board illumination light on a S111 XJ-6, you
know the one that is mounted under the overhange above the center
vents, have a lens or cover plate. I just discovered that my 1986
model does not have a lens over the bulb, there is just a small
exposed bulb. It works fine but now that I have noticed that the
bulb is exposed I am wondering… Thanks
Date: Mon, 14 Oct 1996 20:26:34 -0700
Subject: Re: Thrown rod ??
Frank, what the gearheads are referring to is a broken connecting rod.
Depending on how long you ran the motor, and also where the break occurred,
you could be looking at a replacement of the connecting rod and a possible
cylinder honing, to a “holed” block, seized piston, bent
valves…Translation BIG BUCKS! Been there done that, but it was with a
“disposable block Chevy Vega”.
Date: Mon, 14 Oct 1996 20:31:43 -0700
Subject: Re: [NON-JAG, but funny] The Chicken Gun
Gunnar sent in a story about “testing windshields”
The testing involves both “fresh” and “frozen” birds. They also “launch”
them into the engines during development. PBS ran a six-part show on
building the Boeing 777 and they showed the engine testing. Time-Life
books also describes the windshield testing in their book on flight.
There is also a DEPT of Energy “gun” which launches telephone poles into
building walls. Has something to due with nuclear power plant designs.
Lee
It seems the US Federal Aviation Administration has a unique device for testing the strength of windshields on airplanes. The device is a gun that launches a dead chicken at a plane's windshield at approximately the speed the plane flies.
From: Ken_Sadowski@stkamer.stortek.com (Ken Sadowski)
Date: 14 Oct 1996 20:01:33 GMT
I have the same switch on my 89 XJ40. It is
used to move the driver’s seat back. It does not
move it forward, just back. It was designed to move the
seat back before you try and squeeze yourself in after a
shorter person drives your beautiful machine.
Ken Sadowski
1989 XJ40
StorageTek Corporation
2270 South 88th Street
Louisville, Colorado 80028
Date: Mon, 14 Oct 1996 11:37:45 -0400
Subject: Re: S3 E-Type rear camber [was: Re[2]: Concours Judging]
On Oct 13, 4:41pm, Mike Cogswell wrote:
Subject: S3 E-Type rear camber [was: Re[2]: Concours Judging]
I recall reading
once that Group 44 fixed the rear camber problem as a byproduct of improving
the
rear brakes.
I did not know that there was an issue with the rear camber, I was referring to
the front camber.
The vented brakes makes sense as this would reduce heat transfer from the rear
brakes to the diff.
Mark
Date: Mon, 14 Oct 1996 15:06:17 -0400 (EDT)
Subject: Re: '88 XJ-S with No Flow h2o
Steve:: Get ready to replace your heater core. If your car has the MK III
heating system the job will not take you two days, you chould be able to
do it in 3 or 4 hours. I cannot remember when the MK III system was
installed in the XJ-S, but you better hope that you have a MK III. At
test to find out if it is the heater core, put your finger in the water
if it is oiley and has a sweet smell, or taste, it is anti freeze from
the heater core. If you wish call me after you call Jag for the price on
the core and have had your socks knocked off, maybe I can get a better
price.
Date: Tue, 15 Oct 1996 00:43:07 -0300
Subject: Re: Thrown rod ??and Hook,Line and Sinker??
Hi! A thrown rod can be expensive but they may be feeding you a line.In
any case you may be better off attempting to get rid of your Jag and pay
your bill by selling it through this list first. Take some time and give
as much relevent info. as possible. After all we are Jag-Lovers!!!
- -Fred
Date: Tue, 15 Oct 1996 00:00:28 -0400
Michael Powers wrote:
<On my 89 XJ6, I have found a strange rocker switch that is not mentioned in
the
<manual. It is on the driver seat(US), on the side of the seat that faces
the door.
On mine the switch is used to move the driver’s seat back when the ignition
switch is off, thereby making it easier to enter the car. It is described in
my owner’s manual.
Ron Miller '93 XJ-40
Date: Mon, 14 Oct 96 12:06:00 PDT
Subject: Jack Stands & Ramps
Other things you need to watch when using jack stands & ramps. If you are
raising your car to bleed to brakes & your current braking action is not
very good, you can over run the ramps as you can not stop the car quick
enough when you reach the top of the ramps. On the XJ-S, you may have
problems with the front air-dam & undertray pushing the ramps when you try
and drive on them, or problems backing up on them if you have the mud flaps.
Also, make sure the ramps are sitting square with weight on all points that
sit on the ground. ( if you drove a little too far and the ramp sides of the
ramps are off the ground. Big trouble can happen )
When using jack stands, Like Kirby & others said, find a good, solid point (
frame ) to lower the car onto ( not the middle of the floor pan ). If your
car has “pins” that the stock jack connects to ( on the XJ-S ) and are using
a jack stand that has a flat surface, the car can slip off one or more
stands, regardless of the weight of the car. Also when lowering the car
onto stands using a floor jack on wheels, the car can move a little and the
stands then may not sit square on all 4 sided. That is a disaster waiting to
happen. This can be oven more pronounced on a driveway with a slight grade,
you just place one end on 2 stands, start jacking up the other end and the
car starts to move on the first 2 stands. Just make sure the stands are
still sitting flat after lowering. Oil on the frame or where you are
sitting the car on the stand can also pose a problem. Cement cinder blocks
can crumble with out any notice.
I disagree that the stands should bear no load. If the jack holding the car
goes, the shear force of the car dropping on the stands could cause failure
of the stands, or they could tilt and fall over. Either way I would not
want to be under the car when that happens, or that happen to my car.
Its your life, but I do not want to go with some fat cat falling on me and
squishing out all my innards.
John Himes
88 XJ-S 98K Miles
Date: Mon, 14 Oct 1996 16:04:30 +0100
There is NOT one listed in the parts manual either.
Roly
vents, have a lens or cover plate.This is the map reading light you’re refering and no it doesn’t, well
not on any I’ve seen.Barrie Dawson
Roly Alcock, (Postmaster) Principal Systems Engineer
Redac Systems Ltd, Tel: 01684 294161 ext. 211
Zuken-Redac Group, Fax: 01684 298902
Green Lane,
Tewkesbury, E-mail: roly@redac.co.uk
Gloucestershire, GL20 8HE, UK Web: http://www.redac.co.uk
Date: Mon, 14 Oct 1996 13:12:10 -0600 (MDT)
Subject: Daimler SP 250.
Robert C Moreau writes…
{I just joined the list and I would like to introduce myself.
Welcome aboard.
{I owned a TR-6. I loved it!!
{I am presently looking at a 1963 Daimler SP 250 “B” spec.
My first Jag was a Daimler 2.5L V8 which is a Jag MkII sedan body
powered by the same little Daimler V8 as is in SP 250.
There’s a reason that the SP 250’s weren’t very popular. Even if you
can get past it’s odd carplike looks, the SP 250 body lacked stiffness
and the 2.5L hemi V8 simply isn’t that powerful. The 0-60mph time for
my Daimler Saloon were roughly equivalent to that of the same car with
the smallest of the Jag XK engines (2.4L). Parts are going to be hard
to find, much harder than for a TR-6 or an XK. If you are doing engine
work, you will need some special tools.
There is alot to be said for the moral support which comes from people
coming up to you and saying what a beautiful car your XK is. They won’t
do this with a SP 250; the best you’ll get is some odd looks and a few
“How very interesting…”'s. You may end up sinking a big chunk of
your life into a mediocre car that no one else wants.
Life’s too short and, with babies on the way, your time will soon be
oversubscribed to a degree you never thought possible.
Unless you really love this car, I’d advise you to save your precious
time, money and focus for the XK or TR project which you really want.
/\ Lawrence Buja http://www.cgd.ucar.edu/cms/southern/
_][ southern@ncar.ucar.edu National Center for Atmospheric Research
________________Boulder,Colorado___80307-3000
Date: Tue, 15 Oct 1996 00:24:21 -0005
in the dash-pots. A higher number makes the carbs richer during
acceleration.
Even I know this ain’t right. A thicker oil makes the carbs richer
during throttle openings – which is a lot briefer than acceleration.
The purpose is to avoid stumbles when stomping. Once you have
established throttle position and are on your way, the thickness of
this oil will have little effect.
Yeah, but you would expect this problem to happen whenever the
throttle was wide open, not merely above a certain RPM.
– Kirbert | If anything is to be accomplished,
| some rules must be broken.
| - Palm’s Postulate
Date: Tue, 15 Oct 1996 00:24:25 -0400
Subject: Re: Jag Certificate
I got a certificate for my 1967 420. After my first letter to Brown’s Lane, I
received a reply that all U.S. inquires must go through Jaguar Cars USA in
Mahwah, New Jersey. After writing to them with all the information I had on
the car, I received a letter with the particulars of my car including: Model,
body style, specification, VIN number, Engine #, gearbox #, interior and
exterior colour, date built, main distributor, and first owner’s name and
address. After writing back to confirm that all the information was
consistent with my own records, I was sent a certificate from England. It is
very nice, about 12" x 14" in shades of green and white on heavy parchment
stock with Jaguar Heritage Trust logos and royal warrants. It includes all
the information noted above, typed in with a typewriter along with your name
and address and a certificate number. It is very suitable for framing. It
would certainly look impressive on the wall or to anyone who was buying your
car. Is it worth $40? It is to me.
Jim Scannell
'67 420 Valentine Beige
'89 XJ-40 BRG
P.S. When writing, be sure to include proof of ownership (pink slip in CA).
Jaguar is somewhat sticky on this point before they release information.
Date: Tue, 15 Oct 1996 00:27:48 -0400
Subject: tick noise in 90 xj6
our 90 xj6 has about 70,000 miles and lately has been making ticking noise at
engine. noise is noted at start up and at highway speeds. noise sounds as if
possible lifter. noise as of late has started to get louder. noise is noted
both cold and hot. whats a lifter stake doown guide? took vehicle to
retailing jag dealer and was advised noise is normal for vehicle’s milage. do
4.0 engine valves need adjusting as mantinance? also one other worry/concern
with vehicle is the bulb failure light. all bulbs are new factory bulbs. also
cleaned all contacts at marker and front park lamps. light also comes on at
times after car has been washed and restarted and brakes have not been
applied. any thoughts???
Date: Mon, 14 Oct 1996 23:38:41 -0700
Well waddya know - a question I can actually answer!
The button is to move the seat back before you get in the car. My wife is
small and I can’t get in the car with the seat forward after she has driven
it, so the button really helps out. It doesn’t work once you are in the
car, but then the button on the side of the tunnel does the trick.
Dave
Michael Powers
Hello all:On my 89 XJ6, I have found a strange rocker switch that is not mentioned in the manual. From: Dphdcpe@aol.com Date: Mon, 14 Oct 1996 11:36:43 -0400 Subject: I’'m Back/ Concours I have been off the line for a while due to computor and chenges in my job. I have been reading the concours articles which interest due to my participating in JCNA events . I own a 1960 XK150 drophead which does not have a ground up restoration. It has the original seats, boot mat, and coil which is sitting on top of a detailed engine compartment . The paint is about 15-20 years old and has been compounded two times now due to a thick paint job. The braze marks are popping out on top of the fender . The bumbers have been rechromed, but the rest of the brightwork is original with very little pit marks. The top has been replaced using the original wood. I drive this car about 2,000+ miles during the warm months. I entered it in JCNA event at Coatsville, Pa. last year and was going to enter it in a driven class until I was talked into entering it in concours. The judges loved the car for it’s originality and gave it a 99.48. The same year, it also took best of show at an all British car show in Hellertown, Pa. I feel that if you drive your car a reasonable amount of miles and carefully clean it up when done, putting a lot of sweat equity into it, the car will stay in good shape and show presentable. I do not mean that a daily driver will garner these type of points in a concours class, but that is what the driven class is all about. I have seen cars capable of getting high 90’s in the concours class entered in the driven class so I guess it all evens out in the end. Currently, I am building a 1961 OTS Ser. # 875091 which has some vintage race history. I am attempting to make it a 100 Pt. car and therefore going to have it a “Trailer Queen” for the first year of it’s new life. The reason why I’m doing it is due to the equity of the car going up if it scores 99+ or higher in several events. This is my choice from a financial standpoint. I plan to untrailer it after the first year and drive it or sell it if a ridiculous offer comes around. I do have jags to drive and this OTS project is my hobby and what I do with it is my own business. Terry K. Wagner 2483 Leiscz’s Bridge Rd. Reading, Pa. 19605 610-374-7445 From: Hunt Dabney hdabney@earthlink.net Date: Mon, 14 Oct 1996 22:33:09 -0700 (PDT) Subject: Re: Silly question Mine doesn’t – just the bulb. Hunt At 11:48 PM 10/13/96 -0500, MR MICHAEL D FATSI wrote:
Date: Tue, 15 Oct 1996 02:20:21 -0005
Jeffrey Gram:
tried already
Hmmmm. Does all of this imply that taking the stock needles out and
machining them thinner won’t help?
| - Palm’s Postulate
Date: Tue, 15 Oct 96 08:22 EET
Subject: Introduce myself and ask a question
Hi there,
I’m an aspirant Jag owner and I’d like to ask advice of the car I want to buy.
It’s a 1990 XJRS 6litre and is priced at R200000. That converts to about
28570 British pounds or 45000 dollars.
Is this a realistic price for a six year old car imported to South Africa?
Thanks
John McKeag
Publications & Training Manager
North West Communication Service
Date: Mon, 14 Oct 1996 23:46:01 EDT
Hi Jeff,
Don’t be discouraged. The effort will be wothwhile. When I received the
hi-lift cam kit for my 3.8 xke it came with Isky springs and richer
needles for the SU’s. I was warned that it would not run properly with
the stock needles. With the proper needles the car will still idle at
650 rpm with only a very slight lope that disappears as soon as the gas
is touched. Pulls like a freight train too! Getting in touch with the
cam vendor is a good place to start. If they cannot suggest anything
find an SU specialist and pick their brains for a starting place. Good
Luck!!
Frank
62 E Roadster
Subject: Re: auto (Jaguar) event in New York
Hi John,
Don’t know the details on the winery trip fro sure. There should be a
newsletter or mailing coming out this week with those details. The
Pelligrini winery is in Cutchogue on the north fork and last I heard we
were supposed to be out there around noon. If you do not receive
anything snail mail by Friday I suggest you contact Brian O’Keefe.
The Bridgehampton event is at the Historical Society which is right on
Main St (Montauk Hgwy) on the north side right in the middle of town. I
think the cross street is Corwith Ave. I would suggest you arrive by 9
or 9:30 am Saturday to get a good chance to see the cars before they take
off and then hang out for lunch, sponsored by Jag last year.
See you this weekend.
Frank
62E Roadster
End of jag-lovers-digest V2 #438
id for jag-lovers-digest-out; Tue, 15 Oct 1996 19:48:39 +0200 (MET DST)
Date: Tue, 15 Oct 1996 19:48:39 +0200 (MET DST)
Message-Id: 199610151748.TAA07445@ekeberg.sn.no
To: jag-lovers-digest@sn.no
Subject: jag-lovers-digest V2 #439
Precedence: bulk
jag-lovers-digest Tuesday, 15 October 1996 Volume 02 : Number 439
Battery size vs. capasity
Re: Thrown rod ??
FW: '88 XJ-S with No Flow h2o
Maintaining the Woodwork
Re: Thrown rod ??
The Cat now has night vision
FW: timing chain noise
Heated rear window XJ6 Series III
Fuel change over switch
XJS Location and phone #'s
Cold starting '85 XJ-S
Driver’s Window slow down XJ6 Series III
Cylinder head off (Series III XJ6) …long
Tires and Battery for Jag MkII
Date: Tue, 15 Oct 96 11:53:15 gmt
Somebody said re the XK engine:
Oh yes you can, with disastrous consequences. Rather have a too loose noise,
than a too tight one.
Alastair Lauener
Date: Tue, 15 Oct 1996 8:21:35 -0400 (EDT)
Subject: Battery size vs. capasity
I remember in the 70’s they’d measure the battery dimentions to replace a
battery. Now batteries are smaller with the same capasity. So if you replace
a battery say from a 60’s car with the same capasity, it will be too small for
the hold down arrangement. I’ve used blocks of wood to make up the difference.
I’ve also given the shop the dimentions of the holder, and ended up with a more
“powerfull” battery.
Russ Lehman
“nothing worthwhile is ever easy”
“pessimists are accurate; optimists live longer”
Internet: rlehman@npr.org
Date: Tue, 15 Oct 1996 08:47:25 -0400 (EDT)
Frank: To bad you are not in my area, cause build and sell V-12 engines
for $4900. Will install it in your car for a total price of $6500. You
cannot convert the car to a Chev V-8 for that price. Well I guess you
could if you use used parts, and do all the labor yourself.
Date: Tue, 15 Oct 96 09:26:44 PDT
Subject: FW: '88 XJ-S with No Flow h2o
- ---------------Original Message---------------
Symptoms are foggy windshield and
water on the driver’s side (U.S.) front footwell only.
Does anyone have an idea of where the
clog might be, other than my cerebral passages? Thanks.
- ----------End of Original Message----------
I had a water leake in my 86 XJ-S. I had the front
windshield sealed for $45. It solved my problem.
Tom Murray
appraise@i2020.net
Date: Tue, 15 Oct 1996 22:55:30 +0900
Subject: Maintaining the Woodwork
Okay folks, this isn’t a mechanical question, but as Jag owners it’s
every bit as important (if not more) for the classic Jag owners, and
I’d like some opinion on the following issue from the cognoscenti
amongst our fold.
In Larry Martz’s excellent piece on these web pages, “Refinishing
Early Jaguar Woodwork,” he recommends the use of Watco Satin Wax Dark
for finishing up the rejuvenation work on a veneer piece, and using
Minwax Paste Finishing Wax for additional luster. Now the latest
(October) issue of Jaguar Enthusiast recommends,
“beeswax polish and NOT household furniture polish. The reason is
that beeswax is perfectly natural, whereas some brands of household
polish contain chemicals which . . . would act as a barrier and
prevent any future re-lacquering from taking place (p.70).”
Now I posed this question on woodwork maintenance to Tony at
Vicarage, and his opinion was (Tony I apologize for quoting your e-mail
without prior permission),
Once you have a good clear coat on it… then any standard polish is
fine…
I now realize there are quite a lot of theories around this issue.
May I invite some discussion amongst my learned Jag-lover fellow members on
the woodwork maintenance issue?
Also, I’d appreciate information from the cognoscenti about a
recommended mail order place to get all these nice “finishers.”
Makoto Honjo
Phone/Fax +81-3-3473-1848
Date: Tue, 15 Oct 1996 10:00:47 -0400 (EDT)
You will undoubtedly receive many replies regarding the options for fixing
your motor, so I’ll address something else you should consider.
If it gets to the point where you really want the car to go away, keep in
mind that the components of the car are worth far more than $2100. Your
junk yard knows this and is playing both sides of the street.
Your rear is worth $1000 retail, front clip $3500, interior $1200, rear
clip $1500 – you get the idea. So if you must place an ad in Hemmings
and start unbolting.
Fellow jag-lovers – this poor guy has a kid on the way and doesn’t need
the stress this car is causing him. Maybe there are enough of us on
the list who need major parts to help him out.
For sure, you should place an ‘ad’ on the Jaguar/Daimler Used Parts
Exchange.
You have been experiencing nothing but trouble but hang in there a bit
more and you may yet find a bit of a pony under the pile.
John
Date: Tue, 15 Oct 1996 10:12:13 -0400 (EDT)
Thanks for the info. I’m bringing some photographs I took of clubmembers
cars in Stony Brook last spring. I’ve got some good shots of your car
that you can have.
John
On Mon, 14 Oct 1996, Frank A Filangeri wrote:
Hi John,
Frank
62E Roadster
Date: Tue, 15 Oct 1996 08:52:51 -0600 (MDT)
{Somebody said re the XK engine:
{>Bert:: Just tighten the upper chain, you cannot over tighten it.
{Oh yes you can, with disastrous consequences. Rather have a too loose noise,
{than a too tight one.
For a saga of what can happen when you hear XK engine timing chain
clicking noises and attempt to solve the problem by simply tightening up
the timing chain, see http://home.sn.no/home/nick/golden/timing.html
I got lucky and had access to a full Jag racing shop when my clicking
timing chain grenaded a few weeks later and it only cost me a couple
hundred bucks to repair the engine damage because I did almost all the
rebuild work myself.
I strongly recommend that you pull off one of the valve covers and
inspect your timing chain. Examine on the underneath of the valve cover
which encloses the timing chain. The broken link on my chain gouged a
visible track in the aluminum valve cover. Slowly rotate the engine and
examine the entire length of the upper chain for broken links. Think of
it as a chance to get to know your engine better.
Date: Tue, 15 Oct 1996 10:55:04 -0400
Subject: The Cat now has night vision
Thanks to all that responded to my question of headlight loss on my XJ6
series III. This past weekend armed with the replies in order of amount of
work needed to complete, I found that the bullet connector (large blue wire
near headlight fuse box) for power to the relay had past its last electron.
Simply cleaning the bullets and replacing the connector with one left over
from an MGA restoration did the trick! I have filed all the other
possible solutions away as I know these will be needed in the future
(having had a lot of practice with Lucas electrics).
If I had had internet access and there was service like jag-lovers I would
not have traded my last MGB for a Miata. Thanks again
Date: Tue, 15 Oct 1996 08:03:47 -0700
Subject: FW: timing chain noise
Can you also tighten the timing chain on an XJ-S?
If so, how?
thanks,
Aaron
'85 XJ-S
From: Alastair Lauener[SMTP:a.lauener@napier.ac.uk]
Sent: Tuesday, October 15, 1996 4:53 AM
Subject: Re: timing chain noiseSomebody said re the XK engine:
than a too tight one.Alastair Lauener
Date: Tue, 15 Oct 1996 11:00:24 -0400
Subject: Heated rear window XJ6 Series III
My Jag’s rear window defroster isn’t working and the weather in Maine is
starting to get cold. The switch appears to work and the light in the tac
lights so there is power that far. The fuse is ok as well. Any one have
any ideas as to where to start the solving process? Thanks for your help.
Date: Tue, 15 Oct 1996 08:14:05 -0700
I too have a leak on the driver’s side of my XJ-S. I have sealed the
windshield, and still the leak persists. I live in Seattle, Washington,
and during the winter months, rain can be almost constant. Every time
it rains, my foot gets soaked. The water is spilling from the piece of
under-dash trim that also covers the fuse panel.
I think I have exhausted all uses for “flowable” silicone, and yet, have
not found success. I understand this is a common XJ-S problem.
Any suggestions for solution?
Thanks in advance.
Aaron
'85 XJ-S
Sent: Tuesday, October 15, 1996 9:26 AM
To: Jag-lovers@sn.no
Subject: FW: '88 XJ-S with No Flow h2o---------------Original Message---------------
water on the driver’s side (U.S.) front footwell only.Does anyone have an idea of where the
----------End of Original Message----------I had a water leake in my 86 XJ-S. I had the front
windshield sealed for $45. It solved my problem.Tom Murray
appraise@i2020.net
Date: Tue, 15 Oct 1996 14:19:41 -0100
Subject: Fuel change over switch
Anyone know the life span of an XJ6 Series III fuel change over
switch? After coming back from the MOT mine has mysteriously
taken to sticking in. I’ve done 108,000 miles and just want to
know if that is expected and I should get a new one (30 quid),
or if it should last longer and I can get one from the breakers.
The MOT station swore they did nothing, but the electric mirrors
had been moved (those switches are partialy broken too but at 60+
quid each they can stay broken) and the trip counter reset. Won’t
be going back there.
Cheers,
Cosmo
83 XJ6 4.2
65 Mustang 289
Date: Tue, 15 Oct 1996 11:38:58 -0400
Subject: XJS Location and phone #'s
Thank for all the well wishing. At many request the following
information is being posted:
1985 XJS with 80k miles. Rusted in normal spots body estimates $1500 to
$2,000 including repaint. Car is green. Motor has loud tapping overheats
quickly. Can run, drive, but not recomended until problem is found. I
orginally suspected the water pump. Car was never run past midway
between n and top of temp gauge. Interior is not much to talk about,
VYNL! front seats, rear leather has shrunk and stressing the seams
baddly. Wood is in poor shape. leather door panel have some nicks. Front
end headlight buckets and top of bumper were new 6 months ago, also has
4 new pirrelli p5 cinturato ( or something ) on star type wheels, new
a/c compressor (generic) Whole car for $2,100. With owners manual haynes
and Mr. Palms book. Alpine CD Stereo ( if it’s still there) Suposidly
has thrown rod in motor. Sorry for posting here instead of other list.
Junk yard at 904-428-0244 ask for angello
Call me first at 1-800-484-8293 enter 6758 as code I’ll give details and
directions. Car is in new smyerna beach Florida 20 miles south of
daytona.
Please Please Please call me!! I’ve got to get out of this car I have
about $10,000 lost in this thing and I have to get the pay off only i’m
not looking for a profit. $2,100 takes it. Frank Perrick
Date: Tue, 15 Oct 1996 08:56:13 -0700
Subject: Cold starting '85 XJ-S
Now that I have my car back I have noticed a couple of new things:
1.) I have to feather the gas to get it started in the morning
2.) When it starts, it starts slowly and “winds up”
3.) It lacks power when cold (first 10 minutes of operation/ 2 miles of
driving)
4.) Engine RPM seems too low (about 1050) on cold start.
I know it doesn’t have a choke, but if it did I would say something is
wrong with it.
I really don’t know what to check for this one. Anyone have ideas?
Aaron
'85 XJ-S
Date: Tue, 15 Oct 1996 12:40:45 -0400
Subject: Driver’s Window slow down XJ6 Series III
Have noticed that the driver’s power window is slowing down. Thought I
would need to take the door apart and clean the track rails. However, my
dealer suggested that I lower the window and spray WD-40 in the tracks.
WOW! Could this be a problem or a cure? Anyone else ever tried this? If so
how often should I spray the stuff?
Date: Tue, 15 Oct 96 18:00:44 BST
Subject: Cylinder head off (Series III XJ6) …long
Well, I took the cylinder head of my 1985 (Series III) 4.2 XJ6 Sovereign.
Actually, that was about four weeks ago but I’ve only just got around to writing
it up!
THE REASON: At 105000 miles I have shaving-foam in the breather system (despite the
fact that the oil looks fine - My usual trip is 30 miles to work so the
engine has plenty of time to get nice and hot).
I also had low compression on number three and need of a good de-coke
plus valve bucket-guide stakedown measures.
Oil pressure is fine:- 30psi at idle (hot) 60psi at 3000 on (15W-50)
THE DESIGN: The Aluminium XK engine cylinder head is clamped down onto the cast iron
block by studs which are anchored right at the bottom of the block in
the crankcase. This means that the studs are “wet” with coolant all
the way up to the cylinder head nuts and consequently the studs get glued
into their holes with all the clag that inevitably builds up.
So unlike many engines where the head comes off easily once you’ve managed
to get the head/block face split, the jag 6-cyl head has to be fought
all the way!
THE APPROACH: I decided to pull the head off using home-made lifting beams straddling
the engine compartment bearing on the inner-wing gutters using threaded
rods and nuts (two on either end of each beam - eight in all).
I left all three manifolds on (two exhaust and one inlet/fuel-injection)
which gives you more mass to lift but means that you’ve got something
to get hold of - I used four heavy-duty woven nylon staps going underneath
the manifolds and over the beams. The beams themselves were 3" x 3" timber
(you could use a bit of steel RSJ instead but I didn’t have any).
Actually I tried slightly smaller timbers first but broke them! - that
gives you some idea of the force needed even with nice clean coolant
an no noticable corrosion evident!
I weighed the head after I got it off and it is about 25kg. With all three
manifolds on that goes up to 50kg - (1 cwt). You need to be reasonably
strong to lift that at arm’s length so plan carefully and don’t hurt
your back. However, I assure you it CAN be done single-handed!
(I didn’t bother taking the bonnet off and lifted the head out sideways).
-The alternative approach I could have used is to unscrew the head studs
first (see Jim Isbell’s excellent XJ6 bumper-to-bumper book). If you do
that then the head will come off easily once the joint is split - it’s
a cunning idea. It also has the advantage that you don’t need to lift the
so high because there are no studs to clear. Mind you;- if you snap off a
stud INSIDE the block then you’re in deep shit and are going to need specialist
help of Micheal Neal calibre, (see his technical help section on the web
page). You choose :~)
THE ACTUAL JOB: Having drained the coolant, the first thing you need to do is to disconnect
evrything. This includes exhaust, fuel injection hoses, vacuuum hoses,
throttle cable, kickdown cable, wiring harness, air intake ducting &
air-flow meter, coolant hoses etc etc etc. There are lots of connections so
label everything up carefully. I used lots of cable ties to temporarily
hold everything out of the way to ensure a clean lift.
You may also have emissions control plumbing to disconnect as well if
you’re unlucky
You also need to disconnect the camshaft drives - after taking the cam-covers
and breather housing off you can slacken the upper cam-chain and then un-bolt
the cam sprockets from the camshafts (careful not to drop the screws or lock
tabs down the timimg case into the sump!). Jaguar have thoughfully provided
a beautiful cast aluminium bracket for you to strap the sprockects to.
Late 4.2s like mine have four screws per camshaft and a plain shaft (+ circlip
groove) sticking through the bracket whereas earlier ones (judging by the
pictures in the manual) have two screws and a threaded shaft.
The manual implies that you can lift the head without removing the camshafts
but I found it impossible to do so because the little shaft sticking out
of each sprocket (through the support bracket) fouls the front of the cylinder
head as you lift… easier to remove the shafts.
(Maybe the earlier threaded shafts are a bit shorter???)
Also, if you DID manage to leave the shafts on the you must take care not
to bend the valves when you put the head down, as they protrude below the
block/head joint - although if you have left both manifolds on then they will
hold the head clear.
Mark the crank and cam positions before removing - if you get it wrong on
reassembly then the intake and exhaust valves will hit each other and bend
when you rotate the engine.
Note also that there are six small studs at the front round the timing case
as well as the fourteen main ones sticking up through the block. Don’t
forget these as the job is difficult enough as it is!
To rotate the crankshaft into a convenient position beforehand (and for
subsequent piston-top cleaning) I found it convenient to remove the water-pump/
power-steering belt and put a chain wrench on the pulley - it makes it easy
to edge the crank round degree by degree.
(N.B. once the timing chain is disconnected never rotate one camshaft without
removing the other one first - othewise the inlets will hit the exhausts and
they’ll bend).
OK. Once everything is disconnected ALL you have to is lift the head off:~)
Ha! Ha! Ha! Ha Ha! Ha! Ha! Ha!
How anyone manages to do this by hand (even with two strong men) I can't
imagine. My engine has lovely clean coolant and I soaked the head studs/holes
with penetrating oil for A WEEK before attempting it. Even then I had to
exert a considerable force to get the head off.
At least the dual lifting-beam arrangement allows a nice straight steady lift.
I kept going around tightening the threaded rods a turn at time, tapping down
the studs with a rubber mallet (and steel rod in the later stages) and
giving the head a wiggle (thermostat housing makes a good handhold!).
Eventually it came free.
I kept spraying penetrating oil down the stud holes from time to time.
Due to the studs-glued-into-the-holes sydrome it's a hard pull all the way until
the studs are cleared. I used a little wooden measuring stick to make sure
that I wasn't lifting the head too high at one end at a time and making it bind.
DON'T be tempted to stick a lever into the joint face and pry it 'cause you'll
gouge a groove and most likely make the new gasket leak on reassembly.
Incidentally, I draped old pieces of carpet soft side down over the wings
throughout to prevent scratching (Don't you just HATE overalls with brass zips
on the pockets? - should be velcro -...... I digress..)
Once the head is clear of the studs and hanging from the beams you can lift it
off. Actually I inserted another couple of wooden poles under it first, then
undid the straps, then slid it towards the side of the engine bay so that it was
nearer my body for an easier lift. 50kg (my estimate was 70kg!) may not sound
that much but it feels heavier stretched out in front of you like that!
(and you don't want to drop it on that lovely curvey Jaguar wing do you? :~)
...no, I thought not!)
If you're working in covered garage and/or have a engine crane then you can
put them to good use (I haven't).
POSTSCRIPT: Hoorah! the cylinder head is off.
The exhaust manifolds came off easily. The inlet/fuel-injection manifold required
a little bit of welly. I’ll write what I actually DID to the head in another message
when I get round to it - it was fun.
I am amazed at the condition of the cylinder bores;- you can see the brown laquer
mark where the top piston ring sits but there is practically no discernable ridge in
the bore, you can’t even feel it with a thumbnail. Looks like re-boring these engines
at 100000 miles is a waste of time. More like re-bore at 300000 miles with a de-coke
and fresh head gasket every 100000 or so.
…anyway, more waffle on my cyl-head rebuild in a week or two.
…kind regards,
…enjoy your Jaguars,
Dan.
Date: Tue, 15 Oct 1996 12:53:32 +0000
Subject: Tires and Battery for Jag MkII
I need to get tires and a battery for my Daimler 2.5 V8 (Jag MkII). I
will be using the stock steel wheels. Can anyone recommend what modern
tire sizes /ratings/brands I can use on this car? Also need info on
correct size battery for same vehicle.
Thanks
Lenny Seidman
Elkins Park, Pennsylvania, USA
email: lseidman@erols.com
End of jag-lovers-digest V2 #439
Return-Path: @owner-jag-lovers-di1
Received: (from majordom@localhost) by ekeberg.sn.no (8.7.5/8.7.3/on4)
id for jag-lovers-digest-out; Wed, 16 Oct 1996 05:57:53 +0200 (MET DST)
Date: Wed, 16 Oct 1996 05:57:53 +0200 (MET DST)
Message-Id: 199610160357.FAA16643@ekeberg.sn.no
Subject: jag-lovers-digest V2 #440
Reply-To: jag-lovers@sn.no
Errors-To: @owner-jag-lovers-di1
Precedence: bulk
X-Newsgroups: mail.jag-lovers-digest
jag-lovers-digest Wednesday, 16 October 1996 Volume 02 : Number 440
XJ40: ‘Entry/Exit Switch’ in VDP’s?
Starter and flywheel for 1983 Series III XJ6?
new message
Re: Salesmen (Zero Jag content)
Re: Toe-in and Camber for 84 XJ6
those last few concours points
thrown rod in Fla.
Re: Jack Stands & Ramps
Jaguar Factory Sheepskin Covers
[rpeng: XJ40 Wheel Bearings]
Re: Engine stop [was: Re[4]: …crossover pipe (XJS)]
Re: thrown rod
Re: Cold starting '85 XJ-S
Vacation down under. (No jag content)
Re: Heated rear window XJ6 Series III
Re: FW: timing chain noise
Part needed and Introduction
Ventilated rear brake disks
Series III beauty
Funny car story (no Jaguar content)
Date: Tue, 15 Oct 1996 11:50:37 -0700
Subject: XJ40: ‘Entry/Exit Switch’ in VDP’s?
Hi all!,
I was just reading all the replys on the “mystery button” for the 1989
XJ40-XJ6. I was curious as to know why some models have that “Access”
switch and others do not. I don’t have it on my 1989 Vanden Plas, and
wished I did, it would help when short people drive my car and I can’t reach
to those power seat switches because the stearing wheel, seat, and passive
belt are in the way.
What, only the XJ6’s got that “option”? Or was it something that real
late model 89’s / early 90’s got in their car.
My VDP has the heated seats (their two wires are plugged in), and
under the seat their is a “open plug” under both seats like something is
supposed to plug in their but no switch is installed on the side of the seat.
Where exactly is this switch supposedly located in relation to the
“lap belt”? Is it carved into the side of the seat cushion (thus, the VDP’s
different seats didn’t have that switch there)? I wonder if VDP owners out
there have this switch!
Thanks a lot for any replys!
Eric
cobac@ix.netcom.com
Date: Tue, 15 Oct 1996 17:32:35 -0700
Subject: Starter and flywheel for 1983 Series III XJ6?
I took my 1983 Series III XJ6 into a shop for a loose starter wire.
While they were looking at that, they investigated and found that the
starter and flywheel were mismatched, in terms of the angle of the pinion
and ring gear teeth, and that the latter were much worn. My car a US model,
originally a BW66 automatic, retrofitted by the PO with a European 5-speed
manual transmission. Apparently, the shop which did the conversion replaced
the flywheel, but not the starter, or else the starter was later replaced
with the wrong type.
In any case, on their first two attempts, the current shop has
managed to get mismatched flywheel and starter combinations. They are
not planning to check with suppliers in Canada and England for the
correct starter to match the flywheel. They claim that neither of the
first two replacement starters matched the pitch of the ring gear, and
that they now expect that a non-US supplier will have the correct
starter. Is it really the case that the starter for a 1983 manual
transmission car is different from that for an automatic transmission
car, and that, if so, they differ in more than just the pinion gear?
I am going to go ahead and get a Series III parts book, but I would
appreciate any help in sorting this out. (I have the service manual,
but it is not much help in this area.)
From: Veronica Coats rccola@ctos.com (by way of Veronica Coats rccola@ctos.com)
Date: Tue, 15 Oct 1996 18:30:57 -0600
Subject: new message
This mail message has exceeded the maximum number of hops.
The requested destination was:
jag-lovers@sn.no
Hi Troops again!
Model of Jag is XJS V12 circa '89. 7 years old but in very good
condition. I may be paranoid because I am such a newcomer to this breed of
car. All other cars were “Take the kids to events”.cars at best. Jag is
Black on black convt. Not an H&E. Built in Covernty,Eng.
Date: 16 Oct 96 10:31:50
Subject: Re: Salesmen (Zero Jag content)
Another True Story from Life, for your delectation: Back in the early '60s,
when I was writing manuals for Volvo, I came across the procedure manual for
salesmen. This was back when they brought out a 2-door version of that chubby
little thing that rather resembled a smaller 1941 Ford. The book said “Start by
telling the prospect how comfortable the rear seat is, and get him to try it.
Then sit in the front seat, so he can’t get out”.
- -Jan
Date: 16 Oct 96 10:39:22 EDT
Subject: Re: Toe-in and Camber for 84 XJ6
Don’t know series 3, but if it’s any use, these are the numbers for series 2:
Camber, front: +0.25 to +0.75 deg
Camber, rear: -0.5 to -1 deg
Castor, carburetted: +2 to +2.5 deg
Castor, injected: +3.25 to +3.75 deg
Toe-in, carburetted: 1/16 to 1/8in (1.6 to 3.2 mm)
Toe-in, injected: 0 to 1/16 (0 to 1.6 mm)
My own '77 XJ12C currently runs
Camber, front: 0
Camber, rear: -1 deg
Castor: 2.5 deg (correct adjustment not available)
Toe-in: 0
The maximum “fun” cornering speed is up by about 5% - more at lower speed.
Date: Tue, 15 Oct 1996 20:31:39 ±800
Subject: those last few concours points
wish you luck with your series one 1 restoration Terry in Pa…but =
unless you were given the car and all the parts to restore it, it ain’t =
gonna happen. I’ve helped restore many cars over the years, many went =
on to win events. The 100 point car first time out is a dream. Those =
last few points are the toughest and not the cheapest…when i was in =
the business, many folks would come in and ask for the perfect =
restoration…i would always say…pull up a stool and watch me work. =
When you think it is perfect enough and you have spent enough =
money…that’s when I stop…good luck though…john shuck, beijing
Date: Tue, 15 Oct 1996 20:35:47 ±800
Subject: thrown rod in Fla.
you say oil and water under the car…did it make any noise. I haven’t =
heard many that just go BANG without any racket before the fatal =
event…I agree that you part it…if in fact it is that bad, but I =
think you need a second opinion.=20
Sorry…been there…john shuck…beijing
Date: 16 Oct 96 12:09:49
Subject: Re: Jack Stands & Ramps
John Himes : If your car has “pins” that the stock jack connects to ( on
a jack stand that has a flat surface, the car can slip off one or more stands
Quite true, but there’s a simple solution: flatten down the ears on the typical
“fork” at the top of the stand and drill a 1/2in (or whatever size the pin is)
hole in the centre. Guaranteed no slip…
- -Jan
Date: Tue, 15 Oct 1996 19:09:28 -0700
Subject: Jaguar Factory Sheepskin Covers
Hi all!,
I posted a message a few weeks ago to see if anyone had the “factory
sheepskin covers accessory” from the Jaguar dealer. Well, needless to say
no one replyed, so I bought the sheepskin covers anyway. And, since the
cold weather is here for much of us in the northeast U.S., I figured I’d
tell you about how “great!” they are.
Well, my car is a 89 XJ40 VDP and has a type of “doeskin (that’s what
the dealer told me)” coloured seats and they are the flat/fluted type and
elctrically heated. The seat heaters take to long to warm up in the
morning, and I’m frozen by then anyway because of the COLD leather.
I bought the absolute genuine Jaguar sheepskin seat covers in the
coordinating interior colour. They match so well, are extremely soft and
rich looking and fit PERFECTLY on the two front seats. The seats are ALWAYS
warm now, are protected from rough jeans (if that’s what I’m wearing), rain,
elements, and are never dirtied.
I was concerned that they would look cheap in contrast to the rich
leather and wood throughout the car. But, they really look great! The
headrest part is sewn in to the seat cover, all cutouts are there for lumbar
and headrest lamps, there are only three little hidden straps to hold down
the cover, because they are so perfectly tailored for the seat (don’t even
hide the picnic tables!), even the indentation for the center piping is
there to give it the custom look. And most important a little gold “leaper”
is sewn into the two headrests facing the windows so that outside lookers
know that you have bought the best (most expensive) covers for your seats.
Friends have told me that such covers probably cost me in excess of
$1000 U.S., especially from a “jaguar” dealer! Well, I don’t tell them, but
the dealer wanted around $700 for the two front seats. But, I bought them
for $195.00! No, they’re not defects, they’re brand new in their beautiful
box, all tags and full documentation for their cleaning and labeling for the
correct seat side.
If I haven’t bored you enough already :-), I bought them from Jaguar
Services in Illinois, U.S… They were listed in Hemmings for October and
here is there article:
JAGUAR sheepskin seat covers, factory accessory in
Mulberry (88-89 XJ6); sand (88-92 VDP); cream (93-94
XJ6); tan (1991 XJS); list $540, now $259 pair; Visa,
AmEx. 800-842-0912, 708-331-9151, IL.
Just thought I’d share this with others who were unware and looking for
something to keep their butt from freezing on 0 degree mornings on that cold
leather. IMHO I think there still worth the dealers price, even if Jag
Services is sold out, they’re really great quality and a great deal!
Any questions on them E-Mail me!
Eric
cobac@ix.netcom.com
89 VDP XJ40
Date: Tue, 15 Oct 96 22:13:40 EDT
Subject: [rpeng: XJ40 Wheel Bearings]
Sorry, I missed the original postings on this subject, but…
Funny the question of wheel bearings has come up. I have been complaining
to my husband that the front breaking has been pulsating and that the
steering has been “wobbly” while breaking. He took off the front wheels
this weekend and found the locking nuts loose on each side. Then found
both inner and one outer bearing were frozen (rusted) up.
A trip to the dealer and $67 later, we had new inner/outer bearings and
seals for the front. The cat is driving much better today for this
maintenance.
Number one reason for this problem we believe, is the cheap rubber seals
which Jaguar is using. We have yet to inspect the rear…
FYI, I have a list of service to be performed at various mileage and no where
does it say that the wheel bearings are checked.
Shelly
90’ XJ40 Sovereign (78,800 miles)
- ----- Forwarded message # 1:
Subject: XJ40 Wheel Bearings
Date: Sat, 12 Oct 96 10:08:06 PDT
Brian: My car is a 1989 Sovereign, but I believe that in important respects
it is similar to yours. My very strong advice is to have front and rear
wheel bearings repacked with grease, which involves dissembly and will take
a few hours. The XJ40 has no means, other than dissembly, of repacking the
bearings and there have been some catastrophic failures.
Jaguar would not believe that this could happen, but there were finally too
many failures for them to ignore so they now recommend the repacking at
about 50000 km intervals
Does anyone know if this is also applies to my `91 XJ40? Is re-packing
the wheel-bearings included in the dealer major service?
Roger Peng (408)765-7863
Intel Corporation
Design Technology, Physical CAD
- ----- End of forwarded messages
Date: 15 Oct 96 18:02:11 EDT
Subject: Re: Engine stop [was: Re[4]: …crossover pipe (XJS)]
Hi Mike C,
I though I answered your rod in the cylinder suggestion
in a polite manner, but on re-reading my reply I realize
It could be viewed as slightly on the patronizing side - not intended
as a personal insult - My excuses if it offended after my note on list
politeness. The first prize etc was meant in an amusing voice - forgot the
smiley…
Do you seriously think you can break a rod or rip a plug out of the head by
trying to turn the crank with a hand wrench?
Not break a rod, but damaging the spark plug thread or the cylinder wall
or the piston crown or as you point out fouling a valve, IU would definately
count
amongst the possibilities.
I didn’t know the ropetrick - seems best - if - if used on the compression
stroke
(valves closing)
Jeff
Date: Tue, 15 Oct 96 12:56:08 PDT
Subject: Re: thrown rod
You may have a broken engine, but I doubt that it’s actually a “thrown
rod”. Usually the problem has to do with the head or the valves due to
overheating. In any case, the repair will be quite expensive.
Intel Corporation
Date: Tue, 15 Oct 1996 18:08:45 -0400 (EDT)
Subject: Re: Cold starting '85 XJ-S
Aaron: You might need a new Temp sensor for the ECU, Located on the
left front water/ T/stat housing. The price should be around $15-20.
Chad Bolles Jaguar South 306 Valcour Rd Columbia SC 29212 USA 803 798 3044On
driving)4.) Engine RPM seems too low (about 1050) on cold start.
wrong with it.I really don’t know what to check for this one. Anyone have ideas?
Aaron
'85 XJ-S
Date: Tue, 15 Oct 1996 16:47:36 -0400 (EDT)
Subject: Vacation down under. (No jag content)
Group:
We are planning a vacation for January or February, and we are
thinking about a trip to either Australia or New Zealand. Our vacations
typically last at least two weeks, bring us to exotic destinations, and
involve a great deal of driving. Favorite things to do: driving on twisty
mountain passes, antique collecting, seeing zoos or unusual wild fauna,
visiting unusual cultural/archeological sites, and snorkeling. For example,
our last vacation began in Buenos Aries, Argentina took us to Santiago,
Chile by way of the Aconcagua pass over the Andes, and ended with a relaxing
stay on Easter Island.
Can any of the folks down under offer suggestions for sights to see/places
to visit? Is it possible to renat a Jag? Not to stir up a minor war, but is
NZ or AUS the better place for the first time visitor?
Any help would be appreciated.
Mike & Iris Frank
Date: 16 Oct 96 12:30:44
Subject: Re: Heated rear window XJ6 Series III
If you take off the trim on the side where the traces on the glass disappear,
you’ll reveal two spade connectors. This is a damp spot and the odds that your
connectors will be corroded are high. If not, you can now test whether power
arrives at the connectors and use an ohmmeter to check the traces on the glass.
- -Jan
Date: Tue, 15 Oct 1996 18:03:42 -0400 (EDT)
Subject: Re: FW: timing chain noise
Aaron: NO. But you can rebuild the engine and install all new parts
that will tighten the chain.
If you have a Haynes manual check out the section on installing a chain,
you might as well rebuild the engine.
Chad Bolles Jaguar South 306 Valcour RD Columbia SC 29212 USA 803 798 3044On
If so, how?
thanks,
Aaron
'85 XJ-S
Date: Wed, 16 Oct 1996 00:07:44 +0000
Subject: Re: Carb/engine tuning- status
Try richer needles : For the HIF7 carb there are no richer needles - VSE have
tried already
more than what I am prepared to go through - experience taken at face value :
Jim Isbell : update the XJ6 book !
There are around 160 different needles that will fit an HIF-7
carburettor. They use exactly the same needle-size as the HIF-6. Many
of these needles are richer than the BDY-needles that you have
fitted. You will find many of them in the haystack needle selection
programme (Available on the team.net FTP archives.)
Unfortunately this programme is not updated with the
latest versions of the spring loaded needles. A complete list of
needles with profiles are availiable from Burlen. I also think that a
pair of HIF-7 carburettors could supply a 4.2 litre engine around 200
hp, they were used on the Rolls-Royce Shadow in the 76-86 models and
thats a 6.2 litre engine. Just to give you a guess of a needle to try
you could get the BDJ needles from a Volvo dealer, this needle is a
lot richer than the BDY. Take this only as a hint, to be able to set
the carburettors correctly you really need a rolling road.
I hope this is of some assistance to you.
Regards
Gunnar Eriksson
gunnar@forgasarteknik.se
www.forgasarteknik.se
Date: Tue, 15 Oct 1996 22:32:01 EDT
Subject: Part needed and Introduction
I am in need of a rear hub for a 1985 XJ6. I have some jag parts I would
like to trade for the hub. If anyone has one of these laying around and
would like to trade or sell cheap I’m your man.
Also, I would like to take this time and Introduce ourselfs. My wife
Lori, and myself, Bill have owned two Jaguars, both 1985 XJ6’s. First
one being a european model and, the present one is an americian model.
We have done quite a bit of work on these cars so hopefully, we can be of
some service to other owners and likewise, other owners helping us.
Thanks.
Bill and Lori Kroeger
St Paul MN,
1985 Blk XJ6
E-Mail ( blkcat@juno.com )
Date: 16 Oct 96 13:24:40
Subject: Ventilated rear brake disks
A small general interest note: Having had a post-installation inspection of the
new ventilated rear brake disks on my XJC, I noted that the machined cast iron
surface on the edge has turned a nice purplish brown. This corresponds to 260
deg C (500 F) according to the table on annealing in my excellent 1956 Bosch
Kraftfahrtechnisches Taschenbuch (literally, Power Travel Technology Pocket
Book) - which contains, not everything, but anything (see Theodore Sturgeon’s
“Need”) and has remained my favourite engineering reference source since I was
given it in 1959. For example, its coil spring design formulas tell me why the
XJ12 front springs are doomed to sag…
Anyway, it’s interesting to know that the new disks don’t get all that hot even
with fairly enthusiastic use, since that’s what I wanted.
- -Jan
Date: Tue, 15 Oct 96 13:36:46 PDT
Subject: Series III beauty
Today I examined what must be the most beautiful Series III saloon.
On the local Jag dealer’s srvice lot, a gorgeous black car. it was absolutely immaculate in its original paint. Not one scratch, dent or ripple. The wheels were unmarked, the P5’s as new. The interior was spotless in Barley with coffee piping, in the original style of the Van den Plas not the “after 87” pleated style as in the xj6. This car is a 1992 12 cylinder Van den Plas, and the best part is that it bears a brass plaque on the console just ahead of the shifter, reading “Series III Jaguar Final Canadian Edition 1992 # 82 of 100” This car is obviously owned by someone who CARES. It has only 22,300 kilometres on it. The worst part is that it is not for sale! I am experiencing lust. Gregory Andrachuk, Victoria, Canada From: DisneyPors@aol.com Date: Tue, 15 Oct 1996 18:10:22 -0400 Subject: Funny car story (no Jaguar content) thought you guys might get a kick out of this (and this is the list that give the least SH*T when a post is made that doesnt include a reference to the marque) - Doug SUPPOSEDLY TRUE This year’s Darwin Award (the Darwins go to the people who do the gene pool a favor by killing themselves in an extraordinary and stupid way) goes to the mystery owner of a jet-propelled Chevy Impala. The Arizona Highway Patrol came upon a pile of smoldering metal embedded in the side of a cliff rising above the road at the crest of a curve. Wreckage resembled that of an airplane crash, but it was a car - make and model unidentifiable at the scene. A lab figured out the story. It seems the driver had somehow gotten hold of a JATO unit (Jet-Assisted Take Off - actually a solid fuel rocket) that’s used to give heavy military transport planes an extra “push” taking off from short fields. He drive his Chevy Impala out into the desert and found a long, straight stretch of road. Then he attached the JATO unit to his car, jumped in, got up some speed and fired off the jet device. The cops calculate that the driver of the car … * Hit JATO ignition at a distance of 3 miles from the crash site. Asphalt was scorched and melted there. * Reached maximum thrust within 5 seconds, causing the Chevy to reach speeds well in excess of 350 miles per hour and continuing at full power for an additional 20-25 seconds. The driver, soon to be pilot, most likely would have experienced g-forces usually reserved for dogfighting F-14 jocks under full afterburners, basically causing him to be insignificant for the rest of the event. * Remained on the highway for about 2.5 miles (15 - 20 seconds) before the driver applied and completely melted the brakes, blowing the tires and leaving thick rubber marks on the road surface. * Became airborne for an additional 1.4 miles, impacting the cliff face at a height of 125 feet and leaving a black crater three feet deep in the rock. Most of the driver’s remains were not recoverable; however, small fragments of bone, teeth, and hair were extracted from the crater and fingernail shards were removed from a piece of debris believed to be a portion of the steering wheel. End of jag-lovers-digest V2 #440 ******************************** Return-Path: @owner-jag-lovers-di1 Received: (from majordom@localhost) by ekeberg.sn.no (8.7.5/8.7.3/on4) id for jag-lovers-digest-out; Wed, 16 Oct 1996 06:52:08 +0200 (MET DST) Date: Wed, 16 Oct 1996 06:52:08 +0200 (MET DST) Message-Id: 199610160452.GAA22633@ekeberg.sn.no From: @owner-jag-lovers-di1 To: jag-lovers-digest@sn.no Subject: jag-lovers-digest V2 #441 Reply-To: jag-lovers@sn.no Errors-To: @owner-jag-lovers-di1 Precedence: bulk X-Newsgroups: mail.jag-lovers-digest jag-lovers-digest Wednesday, 16 October 1996 Volume 02 : Number 441 xjs conversions Re: concours confusion: Re: Concours Rules Re: JCNA Judging Re: Gearboxes Re: 71 E-Type Re: Serial Number strangeness Re: Jag Certificate Re: Maintaining the Woodwork 7" Euro headlamp conversion on XJ6 Jaguar Factory Sheepskin Covers From: "esvax::mrgate::a1::abbottsd"@esvax.dnet.dupont.com Date: Tue, 15 Oct 96 16:11:24 EDT Subject: xjs conversions From: NAME: Scot D. ABBOTT FUNC: ENGETL TEL: 695-3930 To: “JAG-LOVERS@SN.NO”@ESDS01@MRGATE INTEROFFICE MEMORANDUM Date: 15-Oct-1996 12:39pm From: Scot D. ABBOTT ABBOTTSD Dept: ENGETL Tel No: 695-3930 TO: Remote Addressee ( SMTP%“JAG-LOVERS@SN.NO” ) Subject: xjs conversions Subject: thrown rod and conversions In our area there is a shop that will convert a v12 to v8 chevy for about $ 4000 for a traditional small block aspirated unit, and about $ 6000 for a TPI motor. These are fresh crate motors. There is a lot of differences in opinion about the practice of changing out the V12 for a Chevy V8. In my experience a converted and stock xjs cars are a fair bit different, but the nice coachwork and Jag styling makes both quite O.K. cars for me. A significant amount of the reliability controversy centres about whether the car is really properly maintained and a good mechanic oversees the car from time to time. V12 engine death is common from overheating, often preventable by proper maintenance or detection by a mechanic of other things awry (e.g. timing gone wrong, ecu problems, etc.). The small block Chevy V8 is more tolerant and inexpensive to maintain, but less glamorous. Also, conversions will generally provide some small detail type problems typical of a non-stock applications. Some folks like to tinker with these details and consider it a challenge; others think it a hassle. V8 V12 better gas mileage smoother performance & idle more reliable, tolerant slightly heavier feel on road cheaper to maintain quieter operation From: Chip Weems weems@cs.umass.edu Date: Tue, 15 Oct 1996 14:30:58 -0500 Subject: Re: concours confusion: At 8:47 PM -0400 10/13/96, DavidZ333@aol.com wrote:
- I don’t have many details :
I am aware of an XK120 that when shown is a great public hit and a formally
judged prize winner. The facia is not one offered - as far as I know ? -
in a roadster. It had the wooden fascia as offered in other models, the
coupe for example. It did look good by the way.
You can still take first place in a coucours even with some major
non-authentic items. Your car just has to be better than the others
there. Frankly, a car has to be a real dog to not be able to qualify
for 1st through 3rd places (there are minimum scores, but they are
very low – really just enough to prevent some car from winning 1st
place by virtue being the only model present in its class, even
though a basket case).
The other aspect of a win like this is that the judges just plain
made a mistake and didn’t notice the discrepancy. It happens – we’re
all volunteers, and sometimes pressed into service to judge a class that
we’re not expert on. Even for a class that a judge knows well, he or
she has only 15 minutes to judge a car, and being mere humans rushing to
get through a line of cars, we sometimes blow it.
Chip
Date: Tue, 15 Oct 1996 14:21:09 -0500
Subject: Re: Concours Rules
At 4:02 PM -0400 10/13/96, Daniel Kagan wrote:
Perhaps Chip or anyone else knowledgable about Concours could tell me if, in
Concours, you lose points if you have an item which was not offered on
your car
in the year it was sold, but WAS offered in subsequent years? For example, if
you have 1986 tread plates on a 1985 car, and the design of the tread
plates was
changed at the end of the 1985 model year, are you penalized for that?Daniel Kagan
1985 Jaguar Sovereign HE
When it is something really nonauthentic (like having seats from a 4.2L
E-type in a 1962 3.8L model), then yes. Technically, deductions are
supposed to be made for anything that is from the wrong year. But Jaguar
made life interesting by introducing some parts early (before a change
in model year) and keeping some parts over from a previous year. Sometimes
they would introduce a new part, then run out, and grab some spares of
the old part so they could keep going. Thus, rather than argue about
authenticity of parts from one year being on the next or prior year’s
models, most judges just roll their eyes, shrug their shoulders and
move on. This fact of Jaguar life covers a multitude of minor sins in
restorations – but the bottom line in most cases is that nobody can
really say for sure just what “correct” is.
I should note that every non-authentic item has to be noted on the
judging sheet, and the owner must read the list of items and sign
the form (signing acknowledges that you have read the form, not that
you agree – and you can protest after the event if you really feel
it is worth it). When we judge a car, it is at that point that we
ask the owner if anything judged non-authentic is incorrect. If the
owner can document the authenicity, then we’ll correct the scoresheet
(we don’t know it all – and we often learn from owners who have
invested a lot of effort into researching their car).
Chip
Date: Tue, 15 Oct 1996 14:51:21 -0500
Subject: Re: JCNA Judging
At 2:37 AM -0500 10/12/96, Mike Cogswell wrote:
Mark: Thanks for the thoughtful reply, although I think I’m a bit more
puzzled then a was a while ago. I got another reply from Chip Weems that
differs, significantly I think, from yours. Hopefully, you will have read
and replied to each other. I’m just gonna sit quietly and see if more
judges join the discussion.MikeC
Subject: JCNA Judging
Author: “mark (m.d.) roberts” markdr@nortel.ca at Internet
Date: 10/10/1996 6:05 PMOkay, I’ll bite :-). I’m the Chief Judge for our local JCNA Jag club…
having said that I too struggle with the original vs over-restored car.I like to think that I instill in the other judges that we are looking for
“authenticity” not perfection. A 100.00 pt. car should be one that is as it
should have left the factory, with no defects that would have been noticed by
the those on the factory floor…if they had had the time to actually go
over
every car inch-by-inch (cm-by-cm). A car that has the heater box so shiny
you
can see yourself in it is, IMHO, a bit too far in the perfection
direction, but
it should not score anymore points than one which is original
Mike,
I don’t think Mark and I really disagree here. If I see a car that is
clean and free of oxidation/corrosion under the bonnet, I won’t deduct points
because it isn’t polished to a mirror finish. It won’t score any lower
than the car that is so polished. However, I can’t see penalizing people
for “over preparing” a Jaguar. After all, it is a high performance luxury
car whose owners are justifiably proud to show it off – it ain’t a Model A
Ford (even if the marque is now owned by the same company).
I’ve been to Model A shows, and to be honest, I can see why they do
deduct points for over preparation. There is something out of place
about a highly detailed engine compartment in a humble Model A body.
But a Jaguar engine can be so gorgeous in under the bonnet of an
equally gorgeous Jaguar body that the two seem to go together quite
well. I understand what makes people want to do this, even if it
doesn’t get them any more points in concours.
Chip
From: rrichardson%eurekanet.com@vm1.cc.nps.navy.mil (Robert J. Richardson)
Date: Fri, 11 Oct 1996 23:37:02 -0500
Subject: Re:
R Richardson asks a good question concerning the work required when install-
ing a new interior kit;
<I can understand the cleaning hours required, but I don’t quite understand
<what has to be painted in order to install the interior fabrics, etc. To
<cut down on the installation labor, I thought I would volunteer to strip
<the interior if the installer would quote me less installation hours than
<say the 100 hours you mentioned. Thanks for your reply.
The door sills and jambs will need cleaning, and possible/probable repaint-
ing. Same for the floors, BUT there will probably be surface (at least) rust
to deal with. The rust must be wire brushed harshly, vaccuumed, and treated
with rust inhibitor. Then a good coat of primer put down, and a good coat of
paint over it. Takes time to do it right.
All exposed wireing must be checked, and rubber and chrome strips can be rep
laced a the same time. The seat frames should be cleaned, degreased, repainted
, and slides re-greased and adjusted. That is why I estimated a hundred hours.
I don’t think your interior guy would do all that for you. Rust cannot just be
painted over because it will just come back.
Putting the new interior in is quick and easy.
But the most important thing I can tell you is this. The same guy who takes
out the old interior should put the new on in. This is because of all the lay-
ering and sequence of replacing must be done just right or it won’t look right.
There were probably a hundred pieces to my kit. And I saved each of the old,
until the new one was installed. I couldn’t have done it any other way.
Some times you have to study and lay the old piece back on to see how it should
fit around/over/through/next to the piece beside it.
LLoyd
Date: Wed, 16 Oct 1996 15:20:05 +1100
Subject: Gearboxes
To jag lovers everywhere,
Hi, my name is Stefan Bernard and I am ‘investigating’ buying an XJS. I sent
a question to you guys about 2 months ago, and got a good response, so I
want to try once more with a couple of questions that someone might be able
to help me with.
The first question is the issue of replacing the GM400 transmission with a
manual gearbox. People I have spoken to reckon the GM400 is fine, and power
through-put is satisfactory, and why don’t I like the GM400 anyway? Well, I
hate automatics, and the auto in the XJS is a negative feature to me. It may
not stop me buying one, but a manual XJS is simply so much more appealing.
Fortunately, I have heard about Getrag 5 and 6 speed gearboxes available as
retro-fits for XJS’s. My question is: does anyone out there have any
experience with these boxes, and are they a good thing?
In particular, I would like to know:
Are they quiet? I am not particularly interested in buying a whining gearbox.
What is the clutch like that (I presume) comes with it? Can anyone tell
me what types of clutch are available? -
Is either the 5 or 6 speed better than the other? Are the ratios ‘about
right’ for road use, or are these units really intended for the race track?
If anyone can help me with these matters, I would be very appreciative.
The second question I have is in relation to the XJR-S of the period
1989-1993 and the 6-Litre model that came out about 1995. Is the engine in
the XJR-S the same as that in the 6 Litre versions? As far as I know, they
were both 6 litre, but were there any changes between the two? In
particular, I want to find out about the squareness of the cylinders and the
fuel injection and control.
Once more, thanks to anyone who can help me on this matter.
Yours,
Stefan Bernard
Dr. E. Stefan Bernard
Lecturer, Civil Engineering
University Of Western Sydney, Nepean
P.O. Box 10 Kingswood NSW 2747 Australia
Telephone (+ 61) 47 360 198 Fax (+61) 47 360 129
e-mail: s.bernard@uws.edu.au
Yours in Concrete!
From: "Mark McChesney" <mmcchesn%ford.com@vm1.cc.nps.navy.mil>
Date: Sat, 12 Oct 1996 12:11:20 -0400
Subject: Re: 71 E-Type
Regarding the '71 "E" type strangeness, Mark is correct;
< A fellow stylist here at Ford has a 6 cyl. '71 S2 E-type fhc that has an S3
<grill and chrome bead around the "mouth". He thinks it is original (he is 3rd
<owner).
'71 was the switch from seriews II to series III. The series III had the
chrome mouth. The series II did not come from the factory with the chrome
mouth. The US dealers installed them (even though they don't fit well) to
make the American buyer (barf) think he has something newer.
I'm removing the chrome mouth from my '71 because it don't belong there.
LLoyd
From: M.Cogswell%zds.com@vm1.cc.nps.navy.mil (Mike Cogswell)
Date: Fri, 11 Oct 1996 23:32:22 -0500
Subject: Re: Serial Number strangeness
Mike C. makes some good points, and I think an error !?!
< the most complete E-Type reference I'm aware of the end of production was
< given (if I remember right) as 10/71. The anomaly is that in the appendix
I believe that should be 10/70 for the series II "E".
<Your other issue, regarding the cars year is a bit more complicated. In
<the US, Jaguar Cars seems to have tried to match the US concept of model
<year and tried to stick with the Fall to Fall cycle. I wonder if this was
Yes, my 8/70 "E" is registered as a '71.
<hip the last of the E-Types from the factory to dealers until sometime in
<75 (long after the last one was made) I guess I'm not surprised anymore by
<he occasional ad for a '75 E-Type, although I think most of us would tend
<o say there is no such thing.
I think this is the way the US government could get additional revenues
(note: I am speaking of revenue enhancers, NOT additional taxes) (smile)
LLoyd
Date: Wed, 16 Oct 1996 00:38:44 -0400
Subject: Re: Jag Certificate
For Jaguar Heritage certificates in USA, write to:
Ms. Karen Miller
Jaguar Cars Inc.
555 MacArthur Blvd
Mahwah, New Jersey 07430-2327
Include a copy of your certificate of title and any info you have on the car.
ie.:
model, year, engine#, VIN #, etc. I think you get a discount if you are a
member of a JCNA affiliate club (not positive on this-it doesn't hurt to put
your
member # on the letter). She will send you a request for the exact amount
which
you can mail later. Also give her your fax number if you have one. She faxed
replies to me which saved some mail delay time.
Good Luck! Hope you like the certificate.
Jim Scannell
'67 420 Valentine Beige
'89 XJ-40 BRG
Date: Tue, 15 Oct 1996 12:00:33 -0700
Subject: Re: Maintaining the Woodwork
I personally use Formby's American Walnut wiping stain followed by multiple
coats of Tung Oil. For "maintenance I use Formby's Lemmon Oil Furniture
"polish". The finish looks like lacquer but "survives" longer and doesn't
present problems like the Polyurethanes do when it comes time to
"refinish".
> In Larry Martz's excellent piece on these web pages, "Refinishing
> Early Jaguar Woodwork," he recommends the use of Watco Satin Wax Dark
> "beeswax polish and NOT household furniture polish. The reason is
> prevent any future re-lacquering from taking place (p.70)."
The ides is not to "build-up" the wax coating. Dirt and other airborne
polutants get embedded in the wax. Use a "neutral oil" to maintain the
finish. The wood absorbs what it needs and you wipe off the rest. No
build-up to remove at some future date. Lee
From: David J Shield <David_J_Shield@ccm.fm.intel.com>
Date: Tue, 15 Oct 96 12:19:00 PDT
Subject: 7" Euro headlamp conversion on XJ6
Bill,
I did this on my car and wrote about it a year ago. Others have
done the same. You can do this on SI and SII cars as well.
I contacted a spares vendor in the UK and had them kit up all the
parts I needed. But the only parts you *can't* get in the US are
the headlamp rims. The buckets and adjusters came in a bag with a
'British Leyland' sticker on it. The buckets themselves also had
BL stickers. This leads me to believe that you can go to your
local British parts dealer and get all the mechanical stuff there
(buckets, adjusters, screws). The headlamps themselves you can get
anywhere - from $10 each at Walmart to much more for realllly
bright Hellas. But get them in the US, not the UK.
For the chrome bezel, you need to contact a spares vendor or one of
your jag-lovers colleagues in a country that uses the 7" headlamps.
UK, Australia, Japan, etc. The part number is in my
parts-interchange guide (under development - adds/subtracts welcome
- send email to me) at
http://www.ns.net/~dshield
That's all you need. It was a small hassle to snake the wiring out
of the old buckets and into the new. I took the connector apart
first.
It's worth the trouble - looks much nicer.
'84XJ6 VDP
'70XKE 2+2
and a Volvo
>Subject: Euro Head lights
>I would like to know if anyone might have the parts I need to put
>the 7" out side headlights on my 1985 XJ6. I use to have a euro
>model 1985 XJ6 that was set up like this and like the look.
> Thank You
> Bill Kroeger
Date: Tue, 15 Oct 1996 12:16:17 -0700
Hi all!,
I posted a message a few weeks ago to see if anyone had the "factory
sheepskin covers accessory" from the Jaguar dealer. Well, needless to say
cold weather is here for much of us in the northeast U.S., I figured I'd
tell you about how "great!" they are.
Well, my car is a 89 XJ40 VDP and has a type of "doeskin (that's what
the dealer told me)" coloured seats and they are the flat/fluted type and
morning, and I'm frozen by then anyway because of the COLD leather.
warm now, are protected from rough jeans (if that's what I'm wearing), rain,
the cover, because they are so perfectly tailored for the seat (don't even
there to give it the custom look. And most important a little gold "leaper"
$1000 U.S., especially from a "jaguar" dealer! Well, I don't tell them, but
for $195.00! No, they're not defects, they're brand new in their beautiful
correct seat side.
If I haven't bored you enough already :-), I bought them from Jaguar
Services in Illinois, U.S.. They were listed in Hemmings for October and
Just thought I'd share this with others who were unware and looking for
Services is sold out, they're really great quality and a great deal!
Eric
cobac@ix.netcom.com
89 VDP XJ40
End of jag-lovers-digest V2 #441
id <OAA02984> for jag-lovers-digest-out; Wed, 16 Oct 1996 14:10:12 +0200 (MET DST)
Date: Wed, 16 Oct 1996 14:10:12 +0200 (MET DST)
Message-Id: <199610161210.OAA02984@ekeberg.sn.no>
Subject: jag-lovers-digest V2 #442
Precedence: bulk
jag-lovers-digest Wednesday, 16 October 1996 Volume 02 : Number 442
Need original (BMW owns jag) post
Black Saturday Relived
intro (New person)
Re: Vacation down under. (No jag content)
New Leather Seat Upholstery
Re: XJS Location and phone #'s resent
Re: XJ40: 'Entry/Exit Switch' in VDP's?
Re: S1 XKE modifications
Re: XJS Fuel Starvation
Grovelling for info on bits!
Cat's Got My Tape
XJ-S
XJ-S EFI Rebuild
SIII XJ12 First impressions
List
[General] The rec.autos.makers.jaguar newsgroup failed
Re: those last few concours points
Progress of accident repair for XJ-S
Date: Tue, 15 Oct 1996 12:06:02 -0400
Subject: Need original (BMW owns jag) post
I lost the original "BMW owns Jaguar" post. I want to send it on to a friend,
can someone send it to me...Thanks - Doug
Date: Wed, 16 Oct 1996 00:52:33 -0400
Subject: Black Saturday Relived
Don't know why but people always say when something is long so, this
is long. To many suggestions, To little facts on my part. This is
reference to a 1985 XJS which suposidly has a thrown rod. I was
excelerating hard in first from a standstill walking slowly away from a
mustang. anticipating that chirp from the back tires and that familiar
snap back into the seat that always accompanies second gear at full
throttle, but I felt something else, the car began to slow down ?? I
imediately took my foot off the gas and proceeded to slow to 30 mph.
Everythings fine now false alarm ? misfire, water in the gas, vaccum
line popped off?? Something silly I thought. The car ran fine for
another mile or so then for the first time ever the temp gauge crept
past N. Thats when I realized my girl was in trouble. I pulled into the
next station and shut the motor off. All hell broke lose in the
expansion tanks and it proceeded to overheat for the beter part of 5
minutes. I have a leaking holding tank and assumed a little to much
water escaped so I filled it up. Temp fine I went to work . At work the
car again overheated blowing steam into the drivers fender well, and
onto my feet ( ouch ! what a dumb place for a water drain) I checked the
oil at this point and it was fine. 8 hrs later I got in it started it up
and started home. I noticed a major lack of power in the car It
progressed to were it was floored only doing thirty. The car once agin
began to heat up I parked it.I had it towed since I knew it was a
serious problem. Also to back up I heard a belt slipping and a noticable
tug on the motor like a belt had momentarily seized. The next day I
satrted the car and it would not idle also took a good two minutes to
start. I held it a 1000 rpm then went to 1500 this is when the knocking
sound could faintly be heard. This sound grew louder as the car got
warmer. It was towed to junk yard and that brings us current.
Franks non-expert opinon (self formed)
1) the water pump gave up the ghost, seized and something internal broke
causing the rattle.
2) distributor advance siezed up ( from Mr. Palm's book symtoms seem
simular)
3) Ex employee sabotaged the motor when I wasn't looking :-(
4) the car was sent by the devil to finacialy ruin me and almost cost me
my marriage and the earth around it will soon open up swallowing it and
returning the car to firey depts from which it came until another
unsupecting broke sole purchases it with dreams of owning a jag with no
money. ( That was wifes input, thanks Molly :-) )
Feel free to call me at 407-574-6758 or if your broke call
1-800-484-8293 then put in the code 6758 (tell me your calling toll free
so I don't get so windy :-) )
I probally haven't contributed much to this list but I hope my humor
puts a smile on somebodys face somewhere. If I can ever do anything for
jag-lovers feel free to let me know. The information I've gotton has
saved my tail many times. P.S. I'm a star now, I'm Quoted in The XJS
help book, If you send me that page I will autograph it for you :-)
Frank Perrick Pizza Man.
Date: Tue, 15 Oct 1996 22:59:09 -0600
Subject: intro (New person)
Hi Troops!
After I decided to seek advice I thought you have no idea as to who I
am. I recently purchased a Jaguar XJS V12 circa 1989. It was built in
England Browns Lane Coventry. It is Black on Black with aprox. 49,000 miles
on it. Convertible 2 seater for a very good reason. I have always driven a
"take the kids everywhere" kind of car, but 6 months ago I lost my husband
to cancer. Feeling the need for a change (or mid-life crisis) I bought my
Jag. It was totally impractical. I live 100 miles from my nearest service
dept. on a farm in Northern Colorado U.S.A. With winter quickly approaching,
my "kitten" will spend a lot of time in it's "kitten house." This gives me
lots of time to prepare it for it's many adventures of summer. With my hair
blowin' in the breeze,and the top down I would look pretty silly broken down
on the side of the road. So to avoid this unfortunate mishap I need your
help with a few minor details.
I am the ticking noise person.It's not a V12 thing but I think it might
be a suspension thing. The noise is generated from the drivers side front
wheel area. I hear it mostly at low RPM's.I don't think it's in the steering
because it doesn't vary with a turn of the wheel. US Drivers side
Thanks for your patience
Veronica
Date: Wed, 16 Oct 1996 18:46:43 -0700
Subject: Re: Vacation down under. (No jag content)
Michael Frank wrote:
> Our vacations typically last at least two weeks, bring us to exotic > destinations, and involve a great deal of driving. Favorite things to > do: driving on twisty mountain passes, antique collecting, seeing zoos > or unusual wild fauna visiting unusual cultural/archeological sites, > and snorkeling.
Michael
Well to start the flame war :-) if you have got two weeks and enjoy the
above then it has to be the South Island of New Zealand. It is a truly
beautiful country.
Shane Gibson
Wellington, New Zealand
1968 Daimler V8 250 (EDMUND)
Date: Wed, 16 Oct 1996 19:10:22 -0700
Subject: New Leather Seat Upholstery
Gidday all
Well after two weeks off and on (more off than on) I have finally
stripped, de-rusted, rust proofed and painted the front seat frames from
the Daimler.
The Leather upholstery has arrived from Aldridge in the UK and after a
minor hitch (which they fixed no questions asked) they are now with the
upholsterer being fitted. They should be ready in a couple of weeks
when I am next up that way. (The car is about 3 hours drive away at my
partners fathers place being restored)
So to date I would highly recomend Aldridge Trimming as a fast and
courteous service well worth using. (And not too pricey to boot)
I will let you all know how the final product turned out later.
See Ya
Shane Gibson
1968 Daimler V8 250 (EDMUND - I finally decided!)
Date: Wed, 16 Oct 1996 01:07:40 -0400
Subject: Re: XJS Location and phone #'s resent
Frank Perrick wrote:
> no response resent 1:15 am est
> and Mr. Palms book. Alpine CD Stereo ( if it's still there) Suposidly
> Call me first at 1-800-484-8293 enter 6758 as code I'll give details and
> daytona.
> Please Please Please call me!! I've got to get out of this car I have
> about $10,000 lost in this thing and I have to get the pay off only i'm
Date: Wed, 16 Oct 1996 08:58:22 +0100
Subject: Re: XJ40: 'Entry/Exit Switch' in VDP's?
On Tue, 15 Oct 1996 11:50:37 -0700 cobac@ix.netcom.com wrote:
> I was just reading all the replys on the "mystery button" for the 1989
> XJ40-XJ6........... I don't have it on my 1989 Vanden Plas..........
> What, only the XJ6's got that "option"? Or was it something that real
> late model 89's / early 90's got in their car.
I have a "real late 89/90" Daimler 4.0 (I understand this equates to
the VDP sold in the US) and I DO have these switches - they do what has
been said and are in the middle(ish) of the side of the seat squab.
Mark
Mark Stiles - Academic Development Manager
IT Services
Staffordshire University
01785 353410
Date: Wed, 16 Oct 1996 01:21:59 EDT
Subject: Re: S1 XKE modifications
On Tue, 15 Oct 1996 14:24:04 -0400 "Mark McChesney" <mmcchesn@ford.com>
writes:
>What else have you done to your E-type to improve performance?
>Mark McChesney
>'65 E-type ots
Hi Mark,
I have owned the car since 1981 and have done a number of things over the
years. Aside from rebuilding the rear and engine during "restoration"
the original Moss box was exchanged for a 4.2 gearbox with a lightened
flywheel. Since then, the engine mods are limited to the cam kit,
Mallory electronic distributor, an MSD 6AL spark box with rev limiter and
a K&N air filter that fits the stock canister. I also replaced the
ignition wired loom that routes the spark plug wires with a setup up
copied from the C-type that spaces the wires out over the right side cam
cover. Never could understand the logic of jamming all those high
tension wires into a tiny space...besides the 8mm wire wouldn't fit
anyway. Planned for the future are Webers, headers and free flow
exhaust. As is, the engine never fails to start instantly, will rev past
where I'm willing to let it go and pulls very strong from lower RPM than
the stock cam permits.
Other mods to the car are suspension/brake related. The rear brakes are
stock S1 units with Ferodo pads (the best I have found to fit the
original calipers). The fronts have been replaced with Wilwood aluminum
4 piston calipers. These calipers require an adapter bracket to mount
them but work quite well. I am using carbon metallic racing pads in
these and they stop incredibly well...they make alot of dust and dirt but
are worth the effort. With this combination and a working booster I can
easily lock the wheels under hard braking...something I could never do
with the stock setup. All the rubber hoses have been tossed out of the
brake system and replaced with braided stainless steel.
The best money spent on the suspension was for SPAX adjustable shocks all
around.
Not cheap but the most dramatic single improvement to the car. Along
with this a thicker, adjustable, solid mounted (no rubber bushings) front
sway bar was fitted. The bar has plain ends with a sliding link to
adjust the "lever arm" length and spherical rod end links to join it to
the lower A arm. The rear bar is STOCK with polyurethane bushings to
mount it to the body. DO NOT attempt to put a stiffer rear bar in...it
will make the car oversteer drastically, not a good thing!!! The wheels
are aluminum minilite replicas with Goodyear 195-70 15 GT 4 tires. The
wheels alone add a stable feel to the car at speed-no shake or vibration
at all.
Other changes for safety and comfort include a smaller, thicker leather
wrapped steering wheel, TRW racing harnesses, a dead pedal (try a
serious slalom without harnesses and dead pedal!!) and fire extinguisher.
Every single one of these mods so far is "bolt on" and could be undone
by a purist but all enhance the pleasure of DRIVING the car. I have
stopped short of a roll bar however as I just cannot bring myself to do
it.
Have you made any mods to your 65??
Frank
62 E OTS
From: "Barry Cooper" <b.w.cooper@acslink.aone.net.au>
Date: Wed, 16 Oct 1996 19:52:18 +1000
Subject: Re: XJS Fuel Starvation
In response to requests I shall post the brief procedure from the
May 1996 Qld Jaguar Driver magazine contributed by John Smith and
covering a cure for fuel starvation on the XJS. I know nothing about the
XJS and the usual disclaimers apply.
I quote -
i. The Jaguar fuel pump is usually very reliable and least likely to be the
cause of fuel problems.
ii. The external filter is extremely fine and should be checked/replaced
every 12 months.
iii. The internal gauze filter should be removed from the surge tank and
cleaned every 2 years/50,000 kms in the XJS.
iv. The hose which allows fuel to flow from the main tank to the surge tank
has also been known to cause problems, mainly from partial blockages at the
main tank union.
To check the internal gauze filter the procedure is:
1. Remove spare wheel, battery cover, floor carpet and right hand trim
panel.
2. Remove the fuel pump relay which is one of two identical relays fitted
above and to the right of the battery. If you are unsure which is the pump
relay, then remove both.
3. Crank the starter for a couple of seconds to depressurise the fuel
system.
4. Disconnect the battery terminals and remove the battery.
5. Clamp the hose which joins the lowest connection on the main tank to the
surge tank.
6. Use a suitable container to catch any spilled fuel (an ice cream
container is ideal) and release the hose clip on the hose attached to the
angled metal tube emerging from the surge tank.
7. Remove the angled tube assembly from the surge tank by gently tapping
the circular clamping/locking ring in an anti clockwise direction. The
assembly will lift straight out. Collect the rubber sealing ring. The
gauze filter is attached at the end of this tube assembly.
8. Clean the gauze of any dirt, etc and replace by the reverse of this
procedure.
9. Before replacement, it is recommended that the surge tank be checked for
any sediment. A torch shone through the top opening will show any sediment
in the surge tank. By removing the rubber grommet in the floor close to
the surge tank and with a bit of care, sediment can be siphoned off with
plastic tubing out through the hole in the floor.
* Make sure that any spilled fuel is totally mopped up or washed away
before reconnecting the battery.
Barry Cooper
Mackay Qld
Australia
68 E Type FHC
67 TR4-A
Date: Wed, 16 Oct 1996 18:51:24 +0900
Subject: Grovelling for info on bits!
Hi there,
I'm new to this list and have been sitting around waiting for a message
relating to what I want, so I can sneak into the thread and pick your
brains. But it hasn't happened, so I'm just going to blurt it out!
I'm located in Osaka, Japan. I don't have a Jaguar, but my boss has just
bought one. Alas, there's a slight chance he bought it to impress me, since
I'm a Brit.He wants a "big" one but thought he'd try a "little" one first,
so he picked up a three-year-old very low mileage British Racing Green one
for 1,000,000yen (about $9000). He's already paid his subscription to this
elite group: his first service cost 270,000yen, or $2500. I suggested that
he pay the garage in kind by cutting the front quarter of the car off, but
he didn't find it funny.
Anway, here's the thing: I've hit every web site I can find, and sent email
to a couple of dealers who have apparently non-functioning email, or
there's some kind of hand-delivered step involved. From what I've learnt so
far (yes, I know this is obvious to you all), this XJ6 is what most people
would call an XJ40, made in 1993. It has twin round headlights, no
foglights and no leaper: there's just a tacky little badge.
My boss wants the foglights and a leaper. The leaper (see? I already learnt
the correct word) is *important* to him in a way I can only describe as
very porbably having an impact on my Christmas bonus if he doesn't get one.
Is the leaper available everywhere or nowhere? What does it cost? Is there
a part number for it? Does it attach fairly readily to the hood/bonnet if
we ask the garage to do it?
Japan is RHD like Britain, so the standard British lamps should be fine.
What fog lamps fit in the mouldings under the bumper? Are they readily
available? Is the wiring in place? I see the light relays are in a
composite block, so I'm guessing the connectors are just sat there
somewhere.
I'm in Boston for two days next week, then in Moscow for a week, then in
Britain for a week before returning to Japan. It would help me career
prospects if I have the bits with me ;-)
[Just to prove I'm not a complete heathen, I used to own a BMW 2002tii and
a TR6. Here, I take the subway. Sigh.]
Paul Hardy
Paul Hardy phardy@ixicorp.com IXI Corporation
Date: Tue, 15 Oct 1996 13:22:23 -0400
Subject: Cat's Got My Tape
Well, my '88 XJ-S likes the Joshua Tree tape so much, it won't let it go,
nor will it let me hear it (maybe it's the water from the heater core or
whereever). In short, the radio is kaput. Although I hate to do it, maybe
I should put an aftermarket radio in. Any suggestions? Any
suggestions on how to get a Jag radio at a reasonable price (please
stop laughing)? I'm going to try to fix the radio, but most likely I'll break it.
Thanks.
Steve@Emerald City, where "Some things ain't funny."
Date: Tue, 15 Oct 1996 17:25:41 +0000
Subject: XJ-S
I have just joined this mail list. I live in Northern Ireland and drive a Rover.
I am seriously considering buying an XJ-S as a second car. Have any of you
any tips/ potential pitfalls? What should I look out for?
Which XJ-S engine would you recommend V12 or V6. I have heard that the V12
can be very very expensive if it dies.
Is there an FAQ relating to this?
Many thanks
Date: Tue, 15 Oct 1996 09:04:48 -0700
Subject: XJ-S EFI Rebuild
Just one last e-mail before I get down to the morning's work.
Some months ago, I rewired the EFI harness for my XJ-S, replacing all
wiring from the fender well to the new injector connectors. The rebuild
was needed because the old wires had become so brittle and cracked that
when I replaced plug wires and rebuilt my distributor, I broke a couple.
It seemed clear that the route of the old harness (right along the top
of the aluminum block - along both sides of the "V") had a lot to do
with its failure. So I decided to re-route my new harness. Rather than
run the wires against the block, I snaked them along the fuel rail. By
doing so, not only did I significantly decrease the heat to which they
are exposed and hopefully delay their decomposition, But I also created
a harness that is easily removable should I need to do other top-end
work.
I am curious to hear what others think of this modification. Are there
inherent dangers I have failed to consider or is it a good idea?
Thanks,
Aaron
'85 XJ-S
From: brownd@filon.ml.com (Dave Brown - London Dev X1818)
Date: Wed, 16 Oct 96 12:12:31 BST
Subject: SIII XJ12 First impressions
As I've driven a few tankfulls in my "new" toy (it is to me :-)) I thought I'd
offer my initial thoughts:
1) This is one smooth car. Deceptively quick (I haven't been this worried about
my licence since I had my 1100cc Kawasaki!) and very easy to drive.
2) A bit soft on the suspension side. I might have that looked at next service.
3) Extremely frugal - NOT!! At least you can play "let's see the petrol guage
move" game.
4) Suprisingly easy to park. The PAS is very good.
5) Very quiet in terms of engine noise, but quite noisy at speed with wind noise
(at least at speeds in excess of .......)
4) Overall an extremely refined and impressive car. I love it.
And contrary to my pre-ownership thoughts it DOES actually fit in the garage!
But only just. It's so tight that I have to be careful when I put it into PARK
as the one or two inches it rolls forward is often enough to cause it to rest
against the shelving at the back of the garage - I often leave it in neutral
with the handbrake on to be on the safe side.
The dealer I bought it from is sorting out the one or two small problems I found
with it. The cold-start engine surge was traced to a problem with the ECU (I
haven't got the full details yet) and the front crankcase oil seal leak and the
cracked rear hub casing are being fixed as I write.
The only downer is having to sell my Daimler 250 V8 (see add on used parts
exchange WEB page).
I can now look forward to (hopefully) many months of luxury cruising!
David Brown,
'88 XJ12 Sovereign
brownd@ml.com
_______/\/\/\__________/\_____/\__________/\__/\/\/\/\/\____/\/\/\_________
_______/\____/\_______/\/\_____/\________/\_______/\________/\____/\_______
_______/\_____/\_____/\__/\_____/\______/\________/\________/\_____/\______
_______/\______/\___/\____/\_____/\____/\_________/\________/\______/\_____
_______/\_____/\___/\/\/\/\/\_____/\__/\__________/\________/\_____/\______
_______/\____/\___/\________/\_____/\/\___________/\________/\____/\_______
_______/\/\/\____/\__________/\_____/\________/\/\/\/\/\____/\/\/\_________
Date: Wed, 16 Oct 96 07:15:16 PDT
Subject: List
Firstname Tom Murray
Surname ****
Address 9102 Dunncroft Dr
City/Town Glen Allen
State/County VA
Zip/Postcode 23060
Country USA
Phone Nos etc
Home (804)747-9326
Office ****
Fax (804)270-5565
Email appraise@i2020.net
http:// ****
Car 1 Jaguar
Model1 XJ-S
Colour Black
Interior Black
Year 1986
Mileage 151,000
Condition Good
Likes/Dislikes like style/dislike gas mileage
Remarks **** I am a residential appraiser. I have
my own business. Two children Reed 2, Conner 5
months, lovely wife Julie.
Date: Wed, 16 Oct 1996 12:28:48 +0100 (MET)
Subject: [General] The rec.autos.makers.jaguar newsgroup failed
Folks,
I just read David C. Lawrence (Tale)'s message on news.announce.newgroups
regarding recent votings on newgroup proposals. (Message id
<nan.passed.961009@uunet.uu.net> @ 9 Oct 1996 23:32:23 -0000). Here are
the relevant bits:
> These groups failed their votes for creation or to have their
> moderation status changed as reported on the date given. The
> proponents listed might be able to provide more information on other
> forums for the topics of the intended groups, such as mailing lists or
> groups in alternative newsgroup hierarchies.
> GROUP STAT VOTE DATE INFO CONTACT
> rec.autos.makers.jaguar FAIL 70:24 1004 gspencer@stim.tec.tn.us
Some other auto newsgroups failed as well:
> rec.autos.makers.ford.misc FAIL 107:35 0930 scottya@computerpro.com
> rec.autos.makers.ford.trucks FAIL 106:29 0930 scottya@computerpro.com
> rec.autos.makers.triumph FAIL 33:27 1004 gspencer@stim.tec.tn.us
> rec.autos.makers.mg FAIL 39:23 1004 gspencer@stim.tec.tn.us
Gunnar
Gunnar Helliesen | Bergen IT Consult AS | NetBSD/VAX on a uVAX II
Systems Consultant | Bergen, Norway | '86 Jaguar XJ6 4.2 Sovereign
gunnar@bitcon.no | http://www.bitcon.no/ | Vicki who? What .sig virus?
Date: Wed, 16 Oct 1996 07:33:13 -0400
Subject: Re: those last few concours points
John,
Your absolutely right in your assumption. I have Terry Lippencott doing the
final
finish work on the car. Terry has done Roy Anderson's MkII which got 100
Pts.
in several shows and was national champ in his class as illustrated in
Jaguar
Journal. He also did Carl Esterly's 120 which was national champ and got
some
100 pointers. I feel that I still have to strive for the 100 Points and
the first show
will be the benchmark to see what will have to be done.
Terry Wagner
Date: Tue, 15 Oct 1996 08:51:01 -0700
Subject: Progress of accident repair for XJ-S
(The two topics listed in the subject header are totally unrelated.)
Thought I would take a moment to update regarding repair progress on my
'85 XJ-S which was "T-boned" about two months ago.
Body and paint work are completed with an impressive match of original
paint color (BRG). The new stereo is in (Alpine 7825 CD Player).
A new door was installed and three associated repairs remain:
1.) The original interior door panel was retained and now does not seat
properly around the speaker mount (bowed quite a bit).
2.) Cannot lock the doors from inside the vehicle on the driver's side
3.) Window goes up VERY slowly and often must be pushed the last 1/2
inch.
The body shop is responsible for all of these items and right now I'm
having a pretty hard time getting them to stand behind their work!
The headliner should be replaced this weekend (along with all other
fabric trim - at my expense).
Next comes the part that really kills me!
After the accident, there was some debate regarding whether the diff
cage had been damaged. It was agreed that a four-way alignment would be
undertaken as an initial step. The mechanic to whom I had taken my car
sent the car to an alignment shop. The alignment tech reported a
successful alignment and I picked up my car the next day.
Funny thing -- about 1 mile from home, I began to notice a thumping
noise from the driver's side rear wheel that kept time with wheel
rotation. When I got home, I removed the wheel to find that the
alignment shop left the bolts that hold the upper A-arm to the chassis
on the passengers side VERY LOOSE. I tightened, and I'm taking it back
to the shop for re-alignment.
Most of the past two months have been spent in an all-out fight with the
insurance company trying to get them to fix things properly. I never
have dealt with accident repairs, nor have I taken my car to a mechanic
for much of anything in the past. Both have been extremely frustrating
experiences. It appears that most of these folks take precious little
pride in their work and care little for quality. They simply want to
minimize cost and maximize profit (insurance company and mechanic
alike!).
I know that there are plenty of excellent mechanics out there (several
on this list), and I have the utmost respect for their ability and
integrity. But my recent experiences have left me more resolved than
ever to do everything I can to maintain my car myself. Ultimately, only
I can be expected to adhere to my own quality standards -- so it fitting
that I also do the work.
Aaron (mending "slowly but surely")
'85 XJ-S
End of jag-lovers-digest V2 #442
id <AAA22459> for jag-lovers-digest-out; Thu, 17 Oct 1996 00:21:46 +0200 (MET DST)
Date: Thu, 17 Oct 1996 00:21:46 +0200 (MET DST)
Message-Id: <199610162221.AAA22459@ekeberg.sn.no>
Subject: jag-lovers-digest V2 #443
Precedence: bulk
jag-lovers-digest Thursday, 17 October 1996 Volume 02 : Number 443
Re: Grovelling for info on bits!(leaper)
RE: [NON-JAG, but funny] The Chicken Gun
Re: FW: '88 XJ-S with No Flow h2o
Re: S1 XKE modifications/long
1994 Xj40
Re: Progress of accident repair
Re: [General] The rec.autos.makers.jaguar newsgroup failed
[none]
Vintage Gasoline......
Fuel tank sender unit SII XJ6
Trader Magazines
Re: Starter and flywheel for 1983 Series III XJ6?
[SIII XJ6] Oil pressure
E-Type brake mast. cyl.warning
Re: Funny car story (no Jaguar content)
From: Michael Powers/TEIR/Thomson <Michael_Powers@teir.com>
Date: 16 Oct 96 9:27:53
Subject: Re: Grovelling for info on bits!(leaper)
As far as leapers are concerned:
There are 3 available from any Jag dealer:
a small one - around $75 (US)
a big one - around $120
a big one that is spring loaded - around $275
These are dealer add-on accessories that they would be more than happy to
install for a small price, or
you can do it yourself.
IMHO, the small leaper is less ostentatious than the big leaper.
Rgds,
Mike
89 XJ6
phardy @ ixicorp.com ("Paul Hardy")
10/16/96 06:51 PM
To: jag-lovers @ sn.no @ Internet
cc:
Hi there,
somewhere.
Paul Hardy
Date: Wed, 16 Oct 1996 07:41:55 -0700
Subject: RE: [NON-JAG, but funny] The Chicken Gun
Apparently the firm that makes the Intercity 125 (High speed British
train) borrowed one of these "chicken guns" to test the windscreen on
their trains during development. The chicken went straight through the
windscreen and left a large dent in the cabin behind where the drivers
head would have been.
Apparently they didn't know that they should have defrosted the chicken
first.
>-----Original Message-----
>From: Lee Walden [SMTP:lwalden@ebmud.com]
>Sent: Tuesday, October 15, 1996 3:32 AM
>To: Gunnar Helliesen; Jag Lovers
>Subject: Re: [NON-JAG, but funny] The Chicken Gun
>Gunnar sent in a story about "testing windshields"
>The testing involves both "fresh" and "frozen" birds. They also "launch"
>them into the engines during development. PBS ran a six-part show on
>building the Boeing 777 and they showed the engine testing. Time-Life
>books also describes the windshield testing in their book on flight.
>There is also a DEPT of Energy "gun" which launches telephone poles into
>building walls. Has something to due with nuclear power plant designs.
>Lee
>> It seems the US Federal Aviation Administration has a unique
>> device for testing the strength of windshields on airplanes. The
>> device is a gun that launches a dead chicken at a plane's
>> windshield at approximately the speed the plane flies.
Date: Wed, 16 Oct 1996 13:32:14 GMT
Subject: Re: FW: '88 XJ-S with No Flow h2o
In message <c=US%a=_%p=ACD%l=ATLAS-961015151405Z-8555@atlas.server.claircom.com> Aaron Burnett writes:
> Every time
> it rains, my foot gets soaked. The water is spilling from the piece of
> under-dash trim that also covers the fuse panel.
Lift the grille that covers the windscreen wiper mechanics, in the well
below you'll find two tubes supposedly for drainage in the corners. They
are the large tapering rubber tubes. Unclog them and see what happens.
Stefan Schulz
jaguar@suaviter.demon.co.uk
Leapers, an additional one i noticed in JC Whitney magazine;
<As far as leapers are concerned:
<There are 3 available from any Jag dealer:
<a small one - around $75 (US)
<a big one - around $120
<a big one that is spring loaded - around $275
Whitney has one (big one I think) for US $29.95 plus shipping. Has anyone
tried one of these? Does anyone know if they are the same as the dealers?
LLoyd - I can just see one on my "E" type -
Just kidding...
Date: Wed, 16 Oct 1996 12:36:57 -0400
Subject: Re: S1 XKE modifications/long
Cool, someone else who understands that the E-type is a SPORTS CAR!
> exhaust.
I had thought of using Webers too, but I keep hearing that the SUs are better
than the Webers for the E-type. 3 Webers is massive overkill and you have to
jet them way down, also, divability is better w/ the SUs. The hottest 4.2s in
vintage racing use SUs (there is a guy on the West Coast that is very
successful running Webers, but his car does not make nearly the h.p. as some of
the East Coast and Mid-West E-types that are on SUs).
> 4 piston calipers.
Where did you buy them? Are you using vented rotors? I understand that matching
the caliper bore to the master cyl. bore is critical - as too much pressure
will cause the caliper to flex(w/ a resulting 'mushy' pedal). I heard that
Wilwood makes a billet caliper that is resistant to flexing(?). Sounds like you
have a good set up.
> around.
Yes, I have heard that SPAX are best, I wish I had not spent $650 on a set of
Konis, but I understand that they are OK.
> Along
> the lower A arm.
Again, where did you get this??? I want one :-). GTJ has a bar like this but it
cost $625.
> I have
> it.
Hear that the right bar/cage can add a lot of rigidity to the body. I am
suffering over doing this too. I may add some bracing and reinforcement if I
can figure out where it would help the most and look the least offensive.
Well, I am in mid-restoration and the motivating force behind me is the
Porsche Clubs' free day (once a year, and its not free) at Waterford Hills race
track. I have this very juvenile desire to whip a few 911s.
I want to make the car streetable but as fast a financially possible. Kirbert
has me a little worried that some of the suspension mods I am doing may make
for a less than happy street car. I am doing a diagonal link radius arm/solid
mounted rear subframe, and at the front, zero ackerman steering arms with
camber curve adjusted lowered upper a-arms and the type of sway bar that you
have. Also using .835" torsion bars. I am using a set of XJ12 front
uprights/axle stubs (stronger) and the vented XJ discs/calibers - Wilwoods when
I can afford them.
The motor is out and will be built by one of 4 possible shops, GTJ, Terrys,
Earl Gibbs, or Vicarage. The wife already knows that we are going to spend some
serious $ here. I have a GTJ header and will get big bore exhaust.
I have a set of factory racing wires- 15x5.5 that will be discarded in favor
of a set of 5-bolt alloys - either 15x7 Minilights or 15x7 Dunlop peg-drive
replicas (5-bolt also). Tires will be 225 or 215/50s. I have a 3.31 rear end,
so lower profile tires are a plus. A 5-speed would be nice but I have to draw
the line somewhere. :-(
With the exception of the wheels/tires and lower ride height the car will look
stock.
Mark McChesney
'65 Etype ots
Date: Wed, 16 Oct 1996 12:32:02, -0500
Subject: 1994 Xj40
94 xj40 front end
I have a 94 that was wrecked on the right front corner .
Some steering linkage was replaced by the body shop. They
said they could not do the alignment. I took it too a tire store that
did the alignment . 8k miles later I started filling a pop in the
searing wheel. I took the car back too the shop . They showed me
that 4 bolts in a bracket that holds the rack & pinion up were loose
allowing a small movement at this bracket. These bolts were only
finger tight. They would not tighten them as they said they had
no replacements if any were to break and that I should take this to
the dealer. I got them to tighten them slightly with a hand wrench .
He
told me that this might leave the steering wheel off center and
that
I should have the dealer replace these bolts, possibly the bracket,
and
do a front end alignment. on test drive the steering wheel is level
and
all felt great.
My questions are ,
1. is there a common problem with these 4 bolts? or did the body
shop
just not tighten them properly. Should they have replaced them?
2. should I replace and tighten them? foot lb.???
3. do I use locktight?
4. will the front end then need to be aligned ? It fills good as it
did before.
5. should I go to dealer and leave car for them to fix.
thanks Paul
Date: Wed, 16 Oct 1996 13:24:25 -0400
Subject: Re: Progress of accident repair
Aaron,
reading your posts on the list is like deja vu. For instance, I have:
1. 85 XJ-S (bought from Seattle Mo. Sports, I think they're out of business now)
2. green in color
3. wrecked in the Seattle area (Bainbridge Island)
If you're unhappy with your repair results, just read on. My car was
insured for liability only, Allstate wasn't going to help with this. I
spent $1500 just on frame and minor body work while the car was in
Washington. I then moved to PA and paid another $1500 to have the car
moved. From then I've paid at least another $6000 to date on paint, wheels,
body parts, etc. If I've had one argument with my wife about this car, I've
had a thousand...
Hope this can make you (and maybe even Frank Perrick) feel a little better.
Feeling better myself,
Clayton Betlyon
85 XJ-S H.E. (better than ever!)
Clayton Betlyon cbetlyon@lumcorp.com
Software Engineer (717) 543-4994
Luminous Corporation
Date: Wed, 16 Oct 1996 12:27:45 -0600 (MDT)
Subject: Re: [General] The rec.autos.makers.jaguar newsgroup failed
{> GROUP STAT VOTE DATE INFO CONTACT
{> rec.autos.makers.jaguar FAIL 70:24 1004 gspencer@stim.tec.tn.us
{> rec.autos.makers.triumph FAIL 33:27 1004 gspencer@stim.tec.tn.us
{> rec.autos.makers.mg FAIL 39:23 1004 gspencer@stim.tec.tn.us
Although rec.autos.makers.jaguar failed, I would like to thank everyone
in the Jag-lovers list who took the time to vote. Your support is
clearly reflected in the 70:24 Yes:No ratio.
There are two criteria for newsgroup creation:
1. There must be at least 2/3 Yes votes.
2. There must be 100 more Yes votes than No votes
Of the three british car groups, rec.autos.makers.jaguar was the only
one which passed the first test. Since it failed the second test, the
creation proposal fails. This indicates a lack of large-scale interest
in the creation of the newsgroup.
Since I feel that it is a worthwhile newsgroup, I plan on restarting the
creation process after the required six month waiting period. If the
proposal still fails after giving it more publicity than I did this time
around, I will drop the subject.
/\ Lawrence Buja http://www.cgd.ucar.edu/cms/southern/
\_][ southern@ncar.ucar.edu National Center for Atmospheric Research
\_________________________Boulder,_Colorado___80307-3000__________
From: "KEATING, SCOTT" <KEATING@ssb-facstaff.ssb.rochester.edu>
Date: Wed, 16 Oct 96 14:26:00 EST
Subject: [none]
I have an '85 XJ6 SIII VDP (sage green paint, light tan interior (don't
know official color name). The front seat backs do not have picnic tables
in the back for use by back seat passengers. I am wondering whether (a)
picnic tables were ever made for '85 XJ6 VDPs, (b) if they could be
installed in my car, (c) what is involved in installing them, (d) where to
get the parts, and (e) whether I am crazy to do it. If anyone has answers to
or opinions on these queries, please let me know.
Thanks.
Scott Keating
Rochester, NY
Date: Wed, 16 Oct 1996 13:10:50 -0700 (PDT)
Subject: Vintage Gasoline......
Last night I got around to draining the seven years old gasoline out of
the left tank of my SII XJ6. The stuff smelled like varnish. I'm sure
there was a little water in there as well. Now I'm curious. What happens
to gasoline as it ages? Does it break down into other hydrocarbons or
what? Any chemists out there who can elaborate?
As for getting rid of old gas, I usually burn it in small amounts in a
coffee can or mix it in small amounts with every tank of gas. Does
anybody have a better technique?
- -Pessimist: "This ship is sinking." -Optimist: "This ship is half full."
Curt Onstott - Windows/DOS/PC Specialist - Information Services - Oregon
State University. - (541) 737-1483 - Office: Kerr 217
Date: Wed, 16 Oct 1996 13:20:10 -0700 (PDT)
Subject: Fuel tank sender unit SII XJ6
Both of my fuel tank sender units appear to be inoperative. Is there an
easy way to get to them, or do I have to pull the tanks? (ICKKY!) Most
of my electrical problems so far, have been caused by corroded electrical
connectors, so I'd like to check these before I drain the tanks and order
new sending units.
Date: 16 Oct 96 16:57:39 EDT
Subject: Trader Magazines
For those in the market for a Jag, you might like to check out the Trader
Magazines site. No pictures like in the hard-copies sold at the 7-Eleven, but a
good search engine. The site lets you access both the "Autotrader" and "Old Car
Trader" databases (as well as "Aero Trader" and all the other publications in
the group).
Location is as follows:
http://vision.traderonline.com/publications/
Peter Bange
1952 XK120 FHC
86/87 XJ6 III (soon)
Date: Wed, 16 Oct 1996 16:17:12 -0600
Subject: Re: Starter and flywheel for 1983 Series III XJ6?
At 05:32 PM 10/15/96 -0700, William J. Earl wrote:
> I took my 1983 Series III XJ6 into a shop for a loose starter wire.
>While they were looking at that, they investigated and found that the
>starter and flywheel were mismatched, in terms of the angle of the pinion
>and ring gear teeth, and that the latter were much worn. My car a US model,
>originally a BW66 automatic, retrofitted by the PO with a European 5-speed
>manual transmission. Apparently, the shop which did the conversion replaced
>the flywheel, but not the starter, or else the starter was later replaced
>with the wrong type.
> In any case, on their first two attempts, the current shop has
>managed to get mismatched flywheel and starter combinations. They are
>not planning to check with suppliers in Canada and England for the
>correct starter to match the flywheel. They claim that neither of the
>first two replacement starters matched the pitch of the ring gear, and
>that they now expect that a non-US supplier will have the correct
>starter. Is it really the case that the starter for a 1983 manual
>transmission car is different from that for an automatic transmission
>car, and that, if so, they differ in more than just the pinion gear?
> I am going to go ahead and get a Series III parts book, but I would
>appreciate any help in sorting this out. (I have the service manual,
>but it is not much help in this area.)
The flywheels are different between the manual trans and the automatic.
However, I show know record of the starter being different for either
model..this is according to the OEM parts book and the Lucas starter book.
Best Regards,
Hal
Hal Rogers
H.D. Rogers & Sons
Import Auto Specialists
3418 Barksdale Blvd.
Bossier City LA 71112
(318) 742-3651 voice
(318) 742-5044 fax
Serving Auto Enthusiasts since 1959
Date: Wed, 16 Oct 1996 22:40:31 +0100 (MET)
Subject: [SIII XJ6] Oil pressure
Thanks to all who responded to my plea for a KPa to psi and/or Kg/cm2
conversion.
After I changed to 5W-50 Mobil 1 oil I've been keeping a close eye on the
oil pressure instrument on my '86 Series III XJ6 4.2 with over 180,000
kms (112,500 miles) on the clock.
Seems my previous readings were a bit off (or maybe the oil change has
made a difference?)
With a hot engine I now read 400 Kpa (58 psi / 4.1 Kg/cm2) @ 800 rpm idle
and 500 Kpa (72.5 psi / 5.1 Kg/cm2) @ 4000 rpm. The pressure doesn't rise
above 500 KPa even if I press the engine above 4000 rpm and only drops
below 400 KPa if the idle speed momentarily drops to 500 rpm (like when
the A/C kicks in) and then only drops to around 380 KPa (55 psi / 3.9
Kg/cm2).
BTW, the oil pressure idiot light comes on when I turn the ignition on
(so I know it works) but goes off as soon as the engine turns.
Should I just be happy and content with having such excellent oil
pressure or should I suspect that The Prince of Darkness is playing
tricks on me?
Gunnar
Date: Wed, 16 Oct 1996 17:51:26 -0500
This is a Mime message, which your current mail reader
may not understand. Parts of the message will appear as
text. To process the remainder, you will need to use a Mime
compatible mail reader. Contact your vendor for details.
- --IMA.Boundary.690305548
Content-Type: text/plain; charset=US-ASCII
Content-Transfer-Encoding: 7bit
Content-Description: cc:Mail note part
I'll make this brief to avoid taking a lot of bandwidth, but since a lot of
us seem to travel I'm copying the list. Anyone who wants more info, e-mail
me direct.
Mike:
My family and I went down under for our vacation late July / early August.
We spent a week in NZ and two in Oz. First I have to say that I kind of
had a mental image of NZ being a lot like Australia (practically a wholly
owned subsidiary.) Nothing could have been further from reality. The two
countries are very different in very many ways. We (wife, teenage daughter
and myself) had an absolutely wonderful vacation. But spending a mere week
in NZ is a joke. We did a fair job of hitting the high spots of the North
Island, but never even went to the South Island. Apparently, all residents
of NZ are members of the South Island Chamber of Commerce. No matter how
much fun we were having, we were constantly told we should go to the South
Island. (And this from North Islanders.) I wouldn't have missed the North
Island for anything, but I sure have the South Is. at the top of my list of
places to go.
Australia, while dramatically different was equally wonderful to visit. If
a week in NZ is a joke, two in Oz is totally ludicrous. You can see a
piece, but it's like coming to the US, visiting a few mid-Atlantic states
and thinking you've seen the country. We managed to pack a lot into two
weeks. We flew into Melbourne, went west into the gold rush country near
Ballarat, then inland. Waded through herds (packs, gaggles?) of 'roos in
wildlife preserves, were fascinated by warnings about wombats, 'roos and
koalas as roadside hazards instead of the usual deer/moose/whatever signs
we see. Visited a string of historic and otherwise interesting towns, went
to the capitol at Canberra (embassy row is worth a visit all by itself.)
Drove through the Snowy mountains (made popular in the US by movies),
crossed the Snowy river and headed NE. Hit the coast at Wollengong,
followed the shore to Botany Bay, went west to the Blue Mountains and
finally looped back to Sydney. Don't even thing of visiting NZ or eastern
Oz without a visit to Sidney. A wonderful cosmopolitan city you can walk
for days.
I could go on for hours. Bottom line, both are wonderful, spend more than
a measly two weeks, enjoy it. For more detain, e-mail direct.
MikeC
______________________________ Reply Separator _________________________________
Subject: Vacation down under. (No jag content)
Author: Michael Frank <mfrank@westnet.com> at Internet
Date: 10/15/1996 4:47 PM
<snip>
Not to stir up a minor war, but is NZ or AUS the better place for the first
time visitor?
Any help would be appreciated.
Mike & Iris Frank
- --IMA.Boundary.690305548--
From: rrichardson@eurekanet.com (Robert J. Richardson)
Date: Wed, 16 Oct 1996 18:17:48 -0500
Subject: E-Type brake mast. cyl.warning
Warning: The rubber seals for a 1964 E-Type Series I are specifically for
either a Girling brake master cylinder or a Dunlop unit. Mark Roberts had
tipped me off about this, but I neglected to tell Terry's Jaguar Parts that
I had the Dunlop unit. They sent part No. SP9016 which is the Girling
rebuild kit. The rubber seals appear identical to those for the Dunlop
unit, but they are slightly smaller and wouldn't seal the unit. You have to
disassemble the master cylinder to identify the unit. The Girling brake
master cylinder has an additional rubber seal in the middle of the piston
in addition to the cup seal and valve seal. I had to return the Girling
kit, but the good news for me is that the Dunlop kit is $17.00 versus
$37.50 for the Girling rebuild kit. So I ordered two kits and will also
rebuild the master cylinder for the rear brakes although those seals are
almost new in appearance. But why go to all the trouble of installing both
units and bleeding both systems only to possibly have to rebuild the rear
brake m.c. later on. The $17.00 price, by the way, is competitive with
prices charged for the kit in the UK-10 GBP per kit.
Date: Wed, 16 Oct 1996 18:24:34 -0500
Subject: Re: Funny car story (no Jaguar content)
>thought you guys might get a kick out of this (and this is the list that give
>the least SH*T when a post is made that doesnt include a reference to the
>marque) - Doug
>SUPPOSEDLY TRUE
>This year's Darwin Award (the Darwins go to the people who do the gene
>pool a favor by killing themselves in an extraordinary and stupid way)
>goes to the mystery owner of a jet-propelled Chevy Impala.
>The Arizona Highway Patrol came upon a pile of smoldering metal embedded
>in the side of a cliff rising above the road at the crest of a curve.
>Wreckage resembled that of an airplane crash, but it was a car - make
>and model unidentifiable at the scene. A lab figured out the story. It
>seems the driver had somehow gotten hold of a JATO unit (Jet-Assisted
>Take Off - actually a solid fuel rocket) that's used to give heavy
>military transport planes an extra "push" taking off from short fields.
>He drive his Chevy Impala out into the desert and found a long, straight
>stretch of road. Then he attached the JATO unit to his car, jumped in,
>got up some speed and fired off the jet device. The cops calculate that
>the driver of the car ...
>* Hit JATO ignition at a distance of 3 miles from the crash site.
> Asphalt was scorched and melted there.
>* Reached maximum thrust within 5 seconds, causing the Chevy to reach
> speeds well in excess of 350 miles per hour and continuing at full
> power for an additional 20-25 seconds. The driver, soon to be pilot,
> most likely would have experienced g-forces usually reserved for
> dogfighting F-14 jocks under full afterburners, basically causing him
> to be insignificant for the rest of the event.
>* Remained on the highway for about 2.5 miles (15 - 20 seconds) before
> the driver applied and completely melted the brakes, blowing the tires
> and leaving thick rubber marks on the road surface.
>* Became airborne for an additional 1.4 miles, impacting the cliff face
> at a height of 125 feet and leaving a black crater three feet deep in
> the rock.
>Most of the driver's remains were not recoverable; however, small
>fragments of bone, teeth, and hair were extracted from the crater and
>fingernail shards were removed from a piece of debris believed to be a
>portion of the steering wheel.
I'm sure I read this story in the Ampersand column in Road & Track last
month. Anyhow, I repeated it to my faculty buddies at Ohio U. and one
immediately jumped all over me and insisted I was repeating a so-called
Urban Legend. That got me to wondering...how did the lab immediately know
it was a JATO unit?
If the car was in bits and pieces, how did the lab identify it as a Chevy
Impala? Was it a man or woman driving the Impala? Too early for DNA testing
to come back, right? It's a great story and I hope it is true. If it isn't,
Road & Track shouldn't be the passers-on of Urban Legends.
End of jag-lovers-digest V2 #443
X-UIDL: 732afbfb00d7275f81dac780376b7229
Return-Path: @owner-jag-lovers-di1
Received: (from majordom@localhost) by ekeberg.sn.no (8.7.5/8.7.3/on4)
id <FAA27778> for jag-lovers-digest-out; Thu, 17 Oct 1996 05:19:18 +0200 (MET DST)
Date: Thu, 17 Oct 1996 05:19:18 +0200 (MET DST)
Message-Id: <199610170319.FAA27778@ekeberg.sn.no>
To: jag-lovers-digest@sn.no
Subject: jag-lovers-digest V2 #444
Reply-To: jag-lovers@sn.no
Errors-To: @owner-jag-lovers-di1
Precedence: bulk
Status: RO
X-Status:
X-Newsgroups: mail.jag-lovers-digest
jag-lovers-digest Thursday, 17 October 1996 Volume 02 : Number 444
Re: [SIII XJ6] Oil pressure
Re: XJ-S EFI Rebuild
V12 Cooling Circuit
Vintage XK's in competition
Re: V12 Cooling Circuit
Re: (leaper)
Brake fluid for XJ-S
start - stop
Thump
Water leaks
Throttle switch (Federal)- XJ6 Series III
Re: (leaper)
RE: Gearboxes
Seat Mounting Bolts -- XJ-S
Re: Progress of accident repair for XJ-S
xk brake servo
Re: start - stop
Date: Wed, 16 Oct 1996 18:57:33 -0400 (EDT)
Subject: Re: [SIII XJ6] Oil pressure
If you pour in a synthetic oil, and get oil leaks, and then change back to
a conventional oil, do the leaks go away?
John
Date: Thu, 17 Oct 1996 09:10:03 +1000
Subject: Re: XJ-S EFI Rebuild
<snip from Aaron Burnett <aaron.burnett@attws.com>>
Aaron,
Where is a posting when you need it, because I installed my newly rebuilt
EFI harness last night and read your posting this morning. I rebuilt my
harness because my 77 XJ-S was flooding itself to death and I suspected bad
connections and the old wires were very brittle because of heat and oil. I
thought of re-routing my harness but decided to stay with convention rather
than convenience because I used high temperature aircraft engine wire in the
rebuild. I haven't wrapped the wires yet (I'm waiting to prove if it works
first) so it's not to late for me to change if no one else thinks that
re-routing along the fuel rail is a problem.
Derek Hibbs
Canberra, Australia
77 XJ-S
Date: Wed, 16 Oct 1996 19:15:38 -0400 (EDT)
Subject: V12 Cooling Circuit
THe Jag V12 has a heater hose connection from the top rear of the engine
to the lower radiator hose.
Pretend that the hot water (heater) valve is open. Coolant flows from the
top of the engine to the lower hose (outlet) of the radiator. This means
that the car might warm up quicker (thermostats are closed, almost all
flow is through heater circuit), which is a good thing.
Once the car is hot, though, it would seem that the effectiveness of the
cooling of the radiator is reduced by the flow through this circuit
(assuming heater valve is still open), which might not be a good thing.
(You are essentially mixing hot water from the cylinder head with cool
water from the radiator outlet.)
Aha, you say, but if the heater valve is open then this is the winter time
and it doesn't matter, because the thermostats still regulate overall
temperature. I buy that.
But every heater valve I've come across -- Jag and non-Jag -- flow a
little even when closed. I can rationalize that the Jag valves are
designed this way to allow some hot water through the heater core (matrix)
as a signal for the climate control system to know that the car is warmed
up.
As the result of having my dash apart, I can directly access the heater
matrix and let me tell you that that sucker is HOT all the time, even with
the diminuous flow that 'leaks' past the heater valve.
Questions: Is this another thing that goes against you if your cooling
system is not perfectly up to snuff? In the midst of hot weather and
stop-and-go driving, are you diluting the cooler coolant out of the
radiator with hotter coolant? Is this extra hot water flow somehow
necessary (bleeds heat from the rear cylinder head area -- I don't believe
this, otherwise there'd be heater matrix feeds on both heads).
I have installed a positive shut-off on this circuit because I deep-sixed
the stock climate controls and because I see no reason at all to have hot
water inside the passenger compartment when the heater isn't needed. But
I am curious as to the intent of the design.
John
'82 XJ-S HE
Date: Wed, 16 Oct 1996 19:21:14 -0400 (EDT)
> Urban Legend.
Yes, this is an urban legend. Right up there with Coke bottles in the
door panels and 200 MPG (on water) carburetors.
John
'82 XJ-S HE
Date: Wed, 16 Oct 1996 19:21:14, -0500
Subject: Vintage XK's in competition
Hi Nick,
I've sent off notes before but to a different address thinking I was
using a proper one for the Jag-Lovers. Sorry. I picked this address out of
a recent note of yours to John Elmgreen. Hope this one does the trick!
I've built a series of web pages with pictures of our old Jags at various
race tracks and rallys from the United States, Mexico and the Bahamas.
There's also an article about a MK II that I'm restoring for street use at
this site. Hope all enjoy the pics, etc.
I can make the various small images available as *.BMP files. These make
great "wall paper" for those using Windows to "tile" their opening screen.
Presently I have lots of XK 140's being chased by 356 Porsches as my my
wall paper on my machine. These are relatively small files as *.BMP so
could be attached to an email note. Anyone interested can send me email
from the web pages. Please identify the miniature photo by number.
If you would like any of these images as *.gif or *.bmp files for your
own records, please let me know.
Best regards and thanks for the hard work,
Tom Veale (Piloto Loco)
Port Washington, Wisconsin, USA
Date: Wed, 16 Oct 1996 20:14:32 -0400
Subject: Re: V12 Cooling Circuit
In a message dated 96-10-16 19:16:48 EDT, jgn@li.net (John Napoli) writes:
<< I can directly access the heater
system is not perfectly up to snuff? >>
Surely, having more heat exchanger area open to the atmosphere is better than
less. therefore I would say that if you have marginal cooling capacity,
turning the heater on would help the engine to cool better (and roast the
driver in the process).
Julian Mullaney
Date: Wed, 16 Oct 1996 20:45:48 -0400
Subject: Re: (leaper)
re: leapers
Great to hear there are three sizes.
I have a small one on each wing and a medium
on the front of the bonnet.
I'm about to order a large for the boot,
but am confused...should it face forwards,
(into the wind) or rear-ward, so those following
would know it was a jag?
Charles Daly, Toronto, Canada
'62 E-Type, ots
Date: Wed, 16 Oct 1996 18:19:21 -0700
Subject: Brake fluid for XJ-S
Any such cautionary notes for an '85 XJ-S?
Aaron
>From: rrichardson@eurekanet.com[SMTP:rrichardson@eurekanet.com]
>Sent: Wednesday, October 16, 1996 4:17 PM
Date: 16 Oct 96 22:16:23 EDT
Subject: start - stop
To anyone with a series III Xj6 experiencing
the start- stop syndrome, after 2 months picking
at this problem and throwing money at it like it
was a whore the problem is solved.
Temp. sensor was shorting and causing the
car to run at full rich condition. After 2 min. the
car would shut down, fully loaded with fuel and
wouldn't start for 10- 15 min.
Hope this helps,
Jim Stapleton
Date: 16 Oct 96 22:16:20 EDT
Subject: Thump
My III xj6 has developed a loud thump or
clunk when the car is slowing down and
almost at full stop . The noise comes from the
rear end. I belive it's the ring and pinion, am I
correct and are there any other possibilities ?
More importantly, what is the cure?
Jim Stapleton
Date: 16 Oct 96 22:16:26 EDT
Subject: Water leaks
After a complete resto. on my 83 XJ6, inc. new front
and rear window rubbers, the dam things still takes
on water like a wooden boat. Where are the most
likely spots for water to enter. After the resto costs
I can't afford a bilge pump.
Help,
Jim Stapleton
Date: Wed, 16 Oct 1996 21:24:27 -0600 (CST)
Subject: Throttle switch (Federal)- XJ6 Series III
Minimal chicken content.
Gunnar wrote regarding XJ6 Series III's <snip>
>A friend familiar with the Bosch L-Jetronic EFI system told me I should
>have a look at the small microswitch on the butterfly valve (the main
>throttle body on the EFI system). This switch is normally closed (on) at
>idle and should open the instant you press the accellerator to tell the
>ECU that the engine is no longer idling. If this switch is set to open
>too late or too soon the ECU will think the engine is still idling when in
>fact you are trying to increase the revs or vice versa. The ECU will
>compensate and thus "fight" what you are trying to achieve.
Gunnar, I don't think this applies to fuel injected Series III's sold in the
States.
Page 19-4 of my manual (AKM 9006 Ed 5)) states: "Throttle switch (Federal
cars)....signals the position of the throttle to the ECU.... This contact is
fitted, but not used, on cars to the U.S.A. and certain other countries".
However, the contact for wide open throttle is still operative because Page
19-10 goes on to say: "The switch closes when the throttle nears the
wide-open position and provides information to the ECU of fuel quantity
required by the injector for maximum power output at full throttle".
Moreover, the next paragraph states: "Throttle switch (UK and Europe)-manual
gearbox only. A micro-switch....replaces the Federal switch".
Therefore, to summarize what all this seems to mean. Fuel injected Series
III's, with automatic transmissions, have a throttle switch which replaces
the micro switch used on manual transmissions and, for those sold in the
U.S., the switch is de-activated except at WOT.
This is not merely pedantry; I do have a question for the list. On my car,
86 XJ6, the "Federal (throttle) switch" is on the bottom of the throttle
spindle and has three pins in the socket but only two wires to the plug;
seemingly confirming the manual. However, I am curious as to how this
missing feature is compensated for, if indeed at all, and what is the effect
of replacing the wire (other than the possibility of a day in court). I have
been too chicken to try it so far.
Tony Gardner
XJ6 Series III 1986 (Actually 1985 MY - according to the wiring diagrams)
Date: Thu, 17 Oct 1996 11:32:30 +0900
How about one for the roof, always pointing North. Ah, an E-type I see. On
the hat, then! ;-)
From: "YOUNG, Neil (M06)" <Neil.Young@qed.qld.gov.au>
Date: Thu, 17 Oct 96 12:47:00 PDT
Subject: RE: Gearboxes
In response to Stefan Bernard's email on Gearboxes:
I haven't tried the Getrag gearboxes, but there is a conversion available in
Australia which utilizes the Toyota Supra 5- speed gearbox (! ...Toyotas are
common here - Getrag boxes are not).
This conversion is available for all XK style 6 cylinder engines as well as
the V-12s.
The Toyota 'box works well and seems to be able to take the power, torque
and weight of the car OK. After all, the Supra is a heavy car and has a very
powerful engine, particularly in turbo form.
There are a number of 'Supra' style gearboxes available and it is important
to obtain one with the most forward-mounted gear lever position that you can
find.
Bellhousings and flywheels are all manufactured here as well as all the
small fittings (Spigot bush, Speedo adaptor, Pivot ball and shaft, etc.)
necessary for the job.
The rarest parts you might have to locate yourself would be the manual
pedal box and clutch cylinder assemblies.
New clutches (of your choice - depending on your application) are readily
available.
I'm currently installing a conversion in my early Series One XJ6. I will,
however, be making sure that I can convert the car back to original when
required.
I can put you in touch with suppliers, as well as people in Brisbane who
have made the change, including V12 conversions.
People I've spoken with have been ecstatic about the Supra conversion -
including those who have swapped a Jaguar manual box for the Supra.
I really do love the old Jaguar 'boxes, though, they have a wonderful feel
and they should last forever. However, if you're converting an automatic, it
can be a very expensive exercise to use original Jaguar parts.
In response to your question on 5 speed vs 6 speed.. six speeds might be
useful for racing ... and Jags have so much torque they could probably
handle a second overdrive type 6th speed. I don't think you'd want 5th OR
6th gear to be 1:1, that is.
Six gears can be good, if you can get a nice low first gear and a very tall
sixth gear.
Sorry if I've strayed too far from your questions.
Contact me directly via Email for further details.
Neil Young
Email: neil.young@qed.qld.gov.au
To: jag-lovers
Subject: Gearboxes
Date: Wednesday, 16 October 1996 3:20PM
To jag lovers everywhere,
Hi, my name is Stefan Bernard and I am 'investigating' buying an XJS. I sent
a question to you guys about 2 months ago, and got a good response, so I
want to try once more with a couple of questions that someone might be able
to help me with.
The first question is the issue of replacing the GM400 transmission with a
manual gearbox. People I have spoken to reckon the GM400 is fine, and power
through-put is satisfactory, and why don't I like the GM400 anyway? Well, I
hate automatics, and the auto in the XJS is a negative feature to me. It may
not stop me buying one, but a manual XJS is simply so much more appealing.
Fortunately, I have heard about Getrag 5 and 6 speed gearboxes available as
retro-fits for XJS's. My question is: does anyone out there have any
experience with these boxes, and are they a good thing?
In particular, I would like to know:
1. Are they quiet? I am not particularly interested in buying a whining
gearbox.
2. What is the clutch like that (I presume) comes with it? Can anyone tell
me what types of clutch are available?
3. Is either the 5 or 6 speed better than the other? Are the ratios 'about
right' for road use, or are these units really intended for the race track?
If anyone can help me with these matters, I would be very appreciative.
The second question I have is in relation to the XJR-S of the period
1989-1993 and the 6-Litre model that came out about 1995. Is the engine in
the XJR-S the same as that in the 6 Litre versions? As far as I know, they
were both 6 litre, but were there any changes between the two? In
particular, I want to find out about the squareness of the cylinders and the
fuel injection and control.
Once more, thanks to anyone who can help me on this matter.
Yours,
Stefan Bernard
Dr. E. Stefan Bernard
Lecturer, Civil Engineering
University Of Western Sydney, Nepean
P.O. Box 10 Kingswood NSW 2747 Australia
Telephone (+ 61) 47 360 198 Fax (+61) 47 360 129
e-mail: s.bernard@uws.edu.au
Yours in Concrete!
Date: Wed, 16 Oct 1996 22:54:06 -0005
Subject: Seat Mounting Bolts -- XJ-S
I bought suitable clip nuts and Allen drive bolts for mounting the
seats in my XJ-S today. Learned a couple things:
First off, the clip nuts are described as an "extruded U nut, 5/16
Regular". The "regular" means that the clip part is 5/8" deep, there
is also a "long" with a much longer clip. The U nuts were bought at
Lowe's and made by Curtis Industries, Inc., Eastlake, OH 44095. The
Curtis part number is 838758. I also found the same type U nut sold
by auto body parts shops as a part number 4016, although they all
seemed to be out of stock when I got there.
The bolt to use with it is a "socket head cap screw, 5/16-18 x 1".
Curtis part number 835558, but this is a fairly common critter and
can be found most anywhere. This is driven by a 1/4" Allen wrench.
The reason this type screw is used is to fit within the tracks on
the seat without obstructing forward/backward travel.
Now, for an important revelation: The above combination can ONLY be
used on the FRONT TWO mounting bolts on each seat. The rear
mounting bolts are arranged slightly differently, preventing the use
of the U nuts. The rear bolt near the console goes into a fixed
boss in the floor; this boss is immovable, and therefore positions
the entire seat. The boss is also not easily replaceable, so
keeping the original screw -- or replacing it with a FINE THREAD
3/4" long socket head cap screw -- is the only way to go.
The rear bolt near the door goes into a "trapped" nut. This nut
cannot easily be removed, but can be moved around for alignment.
Since replacement is not a simple matter, the original screw should
be used here as well.
The U nuts will do a fine job for the two front screws, and greatly
ease the job of seat installation since the U nuts will hold
themselves in place.
-- Kirbert | If anything is to be accomplished,
| some rules must be broken.
| - Palm's Postulate
Subject: Re: Progress of accident repair for XJ-S
Aaron Burnett:
The only problem with this story is that the '85 XJ-S rear suspension
doesn't HAVE an upper A-arm.
| - Palm's Postulate
Date: Wed, 16 Oct 1996 22:57:08 -0400
Subject: xk brake servo
Does anyone know where I can get kits to rebuild the air valve and vacuum
chamber on the 150 brake servo? I managed to find one for the piston, but its
not much good without the other two. It sure would be nice to have the
original unit working again.
Ron Gaeta
59 xk150 dhc
Date: Wed, 16 Oct 1996 23:14:10 -0005
And this, my friends, is a sure sign that the heater valve needs
replacing. When closed, it is not supposed to leak, period.
| - Palm's Postulate
John Napoli:
Quicker compared to what? Not compared to the heater valve being
closed, in which case the coolant goes from the block through the
thermostat bypass, directly into the pump, and from there directly
back to the block. No cooling whatsoever, so the engine will warm up
as soon as possible. Having the heater valve open simply adds a
little cooling to the system, thereby slowing the warmup slightly.
The thermostats on the V-12 do NOT stop flow; they merely redirect
it. Heater valve open or shut will not have a significant effect on
the total flow through the block.
What you are doing is cooling some of the coolant in the heater core
and the rest in the radiator. Hence, having the heater on adds to
the cooling capacity, but probably not significantly.
Then you haven't come across one that WORKS. They are NOT supposed
to leak when closed, and if they do you should take them back.
> up.
Negative. If it's cold enough in the car for the A/C system to be
locked out, the heater valve should be OPEN. At any time the heater
valve is closed, the sensor on the heater core shouldn't be an issue.
It's definitely a strike against the A/C system. You really need to
get a good heater valve.
This would assume that the heater core, which is seeing cool interior
air, is vastly less efficient than the radiator, which is seeing the
hot outdoor air. I doubt it. The heater core is merely taking some
of the load from the radiator, allowing it to cool its proportion of
the flow better.
> necessary...
No, it should be shut off when not needed.
| - Palm's Postulate
Date: Wed, 16 Oct 1996 23:18:55 -0400
Subject: Re: start - stop
X-UIDL: c17542666bc21dd58b127d0a93633ef0
Status: RO
James Stapleton wrote, in part;
>was a whore
<IAA17383>; Thu, 17 Oct 1996 08:25:57 +0200 (MET DST)
X-UIDL: 388859713aabd2ea138af2126cb11fa9
Date: Thu, 17 Oct 1996 08:25:57 +0200 (MET DST)
Message-Id: <199610170625.IAA17383@ekeberg.sn.no>
To: jag-lovers-approval
Subject: UNSUBSCRIBE jag-lovers
Reply-To: Majordomo@sn.no
Status: RO
X-Status:
ittmjs@staffs.ac.uk has unsubscribed from jag-lovers.
No action is required on your part.
id <KAA11618> for jag-lovers-digest-out; Thu, 17 Oct 1996 10:54:47 +0200 (MET DST)
Date: Thu, 17 Oct 1996 10:54:47 +0200 (MET DST)
Message-Id: <199610170854.KAA11618@ekeberg.sn.no>
Subject: jag-lovers-digest V2 #445
Precedence: bulk
Status: O
X-Status:
jag-lovers-digest Thursday, 17 October 1996 Volume 02 : Number 445
85 XJ-S:need brake pads/rotors replacement advice
Marque shifting
RE: Throttle switch (Federal)- XJ6 Series III
RE: Thump
RE: (leaper)
Re: xk brake servo
U.S.E-Jag Series I census
Re: start - stop
FW: Progress of accident repair for XJ-S
re vacation down South
Targa Tasmania 97
Lumenition Ignition System
Wild XJ40
Re: Carb/engine tuning- status
Re: start - stop
Re: Cam Kit Details
Date: Mon, 14 Oct 1996 20:25:12 -0700
Subject: 85 XJ-S:need brake pads/rotors replacement advice
A while back many of you responded to my request for advice on how to
replace the shocks on my car. I am hoping that some of you will again take
the time to help me with my next challenge (by the way, I got all 6 shocks
installed with no problems, due to the helpfull advice I got from those that
responded)...
I'm planning to replace the pads and rotors on my 85 XJ-S. I have never
done disc brakes before and could use a little advice...My "Repair and
Operation Manual" provides some instructions and a diagram...most of which I
can follow and understand. However....
Regarding the brake pads the instructions for starting to re-assamble the
pads say:
...."8. Lever caliper pistons into cylinder bores using service tool 64932392.
9. Locate brake pads in caliper.
10. Reverse operations ...."
My questions are: 1.) I presume that the caliper pistons are the two/side
"tubes" that push against the brake pad (I'm going by the diagram), am I
right?; 2)what does "service tool 64932392" look like, how is it used, is
there a suitable substitute?; and, 3)any tips on how to expedite the whole
thing, avoid problems, or other things I should do while I'm messing around
the area?
Regarding the rotors the instructions for dis-assambleing say:
...."2. Remove front hub (with a reference to a different section which I
think I understand).
3. Remove locking wire from caliper mounting bolts.
4. Remove caliper mounting bolts, recover and note position of shims
located between steering arm and caliper."....
My questions are: 1) does the "locking wire" have to be replaced with same
or is there another substitute such as cotter pins?; 2) what and where are
the "shims" they sare refferring to?; 3) is it possible/adviseable to
replace the rotors without actually taking the whole brake caliper off the
wheel?; and, again, 4)any tips on how to expedite the whole thing, avoid
problems, or other things I should do while I'm messing around this area?
Many thanks in advance,
Rob W-M
85 XJ-S
Date: Wed, 16 Oct 1996 23:59:18 -0400
Subject: Marque shifting
Hi Gang. Long time no post.
I'm about to make a quantum shift in my automotive lifestyle. I have
good news, bad news and great news.
1) Good news: I am about to buy a Ferrari 308 GTB
2) Bad news: I have to sell my Mercedes 420 SEL to do it
3) Great news: I get to keep my '66 3.8 "S" Type
Sometimes I feel selfish and shallow for puting so much emotion into
iron and oil but why not! There are lots of worse things I could be
wasting money on. Are you convinced yet? I wish I was...
Anyway, the S-Type is back on the road. I replaced all the rubber in
the front end. The steering was still a bit too vague for me, as we
discussed before, but when repairing the turn signal switch I discovered
that not only is the upper steering column bushing GONE, the lower
bushing is gone too! Not worn mind you, gone! For a test, I wrapped
the upper and lower column with oiled felt to temporarily simulate the
bushing and the steering tightened up! I mean, it's not a new power
rack feel but it's good. Now I have to tear the entire column down to
replace the bushings properly. The fun just keeps on coming!
Rick (less-vague) Lindsay
Date: Thu, 17 Oct 1996 03:13:20 GMT
Do as you please. But the small difference in effort between someone
hunting up jag-lovers and actually subscribing to it, compared to just
clicking on a newsgroup with his Netscape, acts as a very good garbage
filter, believe me.
Egil
Email: egilk@sn.no Voice: +47 22523641, 92022780 Fax: +47 22525899
Snail: Egil Kvaleberg, Husebybakken 14A, 0379 Oslo, Norway
URL: http://home.sn.no/home/egilk/
Date: Wed, 16 Oct 1996 22:09:14 -0500
Subject: RE: Throttle switch (Federal)- XJ6 Series III
Even less chicken content.
On my '85 XJ6, also a Federal model with A/T, (originally sold in Calif) =
there is a throttle switch (actually two switches combined into one), as =
described by Gunnar, on the throttle plate. There are three wires and =
three switch terminals on mine. Two wires go to the two switches, with =
a third wire as a common ground. One switch detects the throttle plate =
opening, the other switch detects WOT. This seems to be different from =
Mr. Gardner's. My understanding is that the standard type of Throttle =
Position Sensor normally used on FI cars is not used on the XJ6, and the =
function(s) of the TPS are taken over by the air flow meter. The =
throttle switches are used to detect the terminal events not detectable =
by the AFM, being WOT and closed throttle.
Greg Price
'85 VdP
Sent: Wednesday, October 16, 1996 4:24 PM
>A friend familiar with the Bosch L-Jetronic EFI system told me I should =
>have a look at the small microswitch on the butterfly valve (the main=20
>throttle body on the EFI system). This switch is normally closed (on) =
at=20
>idle and should open the instant you press the accellerator to tell the =
>ECU that the engine is no longer idling. If this switch is set to open=20
>too late or too soon the ECU will think the engine is still idling when =
in=20
>fact you are trying to increase the revs or vice versa. The ECU will=20
Gunnar, I don't think this applies to fuel injected Series III's sold in =
the
States.
Page 19-4 of my manual (AKM 9006 Ed 5)) states: "Throttle switch =
(Federal
cars)....signals the position of the throttle to the ECU.... This =
contact is
fitted, but not used, on cars to the U.S.A. and certain other =
countries".
However, the contact for wide open throttle is still operative because =
Page
Moreover, the next paragraph states: "Throttle switch (UK and =
Europe)-manual
Therefore, to summarize what all this seems to mean. Fuel injected =
Series
III's, with automatic transmissions, have a throttle switch which =
replaces
This is not merely pedantry; I do have a question for the list. On my =
car,
missing feature is compensated for, if indeed at all, and what is the =
effect
of replacing the wire (other than the possibility of a day in court). I =
have
Tony Gardner
XJ6 Series III 1986 (Actually 1985 MY - according to the wiring =
diagrams)
Date: Wed, 16 Oct 1996 22:12:13 -0500
Subject: RE: Thump
Could be a worn (read - dangerous) universal joint popping when the =
transmission shifts down into first. I would think a worn or =
misadjusted ring & pinion would whine at speed as well as clunk =
occaisionally.
Greg Price
'85 VdP
From: James Stapleton[SMTP:73303.2013@CompuServe.COM]
Sent: Wednesday, October 16, 1996 9:16 PM
To: Unkown
Subject: Thump
My III xj6 has developed a loud thump or=20
almost at full stop . The noise comes from the=20
Jim Stapleton
Date: Wed, 16 Oct 1996 22:14:58 -0500
Subject: RE: (leaper)
You don't want to use two for the boot, and get them coming and going?
Greg
Sent: Wednesday, October 16, 1996 7:45 PM
re: leapers
'62 E-Type, ots
Date: Thu, 17 Oct 1996 00:28:09 -0500
Subject: Re: xk brake servo
>Ron Gaeta
>59 xk150 dhc
I'm almost sure my 1964 Series I E-Type uses the same servo unit as your
XK-150. In all the mail-order parts catalong I get regularly, it lists
rebuild kits for the servo as N.A. (not available). Should my servo finally
bite the dust, I'll probably have to change over to the unit and master
cylinder available for the 4.2 E-Type.
Date: Thu, 17 Oct 1996 00:36:29 -0500
Subject: U.S.E-Jag Series I census
Have any of you owners of the Series I E-Type ever noted 1) the number of
both the OTS and the FHC sold in the U.S. and 2) the number still titled
and running to this day. I know there were slightly more than 7,000
left-hand drive Fix Head Coupes exported from 1961 through the end of the
3.8 model in the fall of 1964. It would be interesting to know how many
have expired to metal crusher and how many have survived and are in running
condition. This would give one some indication of the rarity of say a 1963
OTS and how this might affect prices down the road a bit.
Date: Thu, 17 Oct 1996 00:33:51 -0400
> Just kidding...
I was going to post that I had the big cat on the hood of my XJS from
jc. whitney but I didn't want to get laughed at but since the car is
gone I don't care. The big leaper, as I call it, Is pretty cool in my
opinion. Mine was the 24k gold. It even has little teeth ,and on some
days I'd swear a little tongue sticking out at me. To answer your
question I think it's junk. Just the car cover being pulled over it has
worn the gold off the head and the whole thing is holow with jagged
points underneath from the molding process. looks good when passing by
at 90 or so :-)
Frank Perrick Blown XJS owner
Date: Thu, 17 Oct 1996 00:52:25 -0400
> >was a whore
> I can imagine Frank yelling;
> THAT'S THE WORD I WAS LOOKING FOR!!
> '62 E-Type, ots
Been there done that, Got the tee shirt. Frank P.
Date: Wed, 16 Oct 1996 22:23:20 -0700
Subject: FW: Progress of accident repair for XJ-S
Sorry about the non-sequitor Kirby points out in the graph below. I was
interupted while typing the e-mail and left out a couple of very
important facts.
1) The loud thumping I heard was caused by one of the protective cups
that covers the outbound u-joint on the driver's side stubaxle. The
alignment shop had left the C-clamp loose that held it in place and it
had moved toward the diff and was striking the hub.
2) The next day, when backing the car out of my driveway, I noted yet
another loud clunk, this time coming from the right front wheel. Back
up the drive and on the jacks again and this is when I discovered that
the alignment shop had left the A-arm bolts loose.
Thanks to Kirby for catching this so that I could redeem myself by
sending these additional details. Hope it all makes sense now.
Aaron
'85 XJ-S
>From: Kirbert[SMTP:palmk@gcn.scri.fsu.edu]
>Sent: Wednesday, October 16, 1996 3:59 PM
>Aaron Burnett:
> | - Palm's Postulate
From: "Peter Rebbechi (03) 9275 3374" <"REBBECHI PETER"@A1.MEOC02.SNO.mts.dec.com>
Date: Thu, 17 Oct 1996 04:04:00 +0000 (GMT)
Subject: re vacation down South
Well, If you can, spend some time in BOTH countries,
How is that for diplomatic.!
Australia and New Zealand are very similar, and to the new
traveller may seem the same except that NZ seems to be about
5 years behind.
Not that this is always a bad thing, because not everything
new is good.
The countries are different. NZ would be easy to tour from
end to end in 2 weeks (I have done this), but you would be
hard pressed to tour Australia from end to end in 2 weeks
without missing everything.
Why not do a web search on the tourist authorities, ie
Northern Territory Tourist Authority, Tourism Victoria,
Tourism New South Wales, and do some planning before coming
down?
With your interests at heart, you may be able to concentrate
on what you want to see, rather than what we want to show
you.
It also follows that if you visit Victoria, your fellow Jag
Lovers will be happy to provide chow etc and a helping hand.
The victorian lot are reasonably active, and do not mind
hosting others.
Have fun!!!
regards
Peter Rebbechi
88 XJ40 Sovereign
92 mitsubishi
96 Westfield SEiW
4 kids
Mortgage too big to care
Wife who tolerates me.
From: "Peter Rebbechi (03) 9275 3374" <"REBBECHI PETER"@a1.meoc02.sno.mts.dec.com>
Date: Thu, 17 Oct 1996 04:17:00 +0000 (GMT)
Subject: Targa Tasmania 97
Yesterday, I scored a drive (actually a co-drive) in the
1997 Targa Tasmania event. A friend of mine has been
rebuilding a Lotus Escort for the last 7 years, and his
entry has been accepted. He has nominated me as
co-driver/navigator. Quite a buzz, but now for 6 months of
pre event hard work! (for free!)
I look forward to providing the list with info on this HUGE
event.
It has a number of sites on the web, with hundreds of
pictures, and a 'Virtual dash' that combines video with
instrument simulations on selected portions of the event.
Worth a look. Start at
http://www.tourism.tas.gov.au/targa/
Just to ensure that there is some jag content, a number of
XK120, 150, MK2, XJS and even a XJ40 compete in this 5 day
targa event around Tasmania.
The XJ40 is called "the two ton pussy', and has a 4 litre
engine with turbocharging! A wild car!
Last year a Westfield won its class, against 2 PRB clubmans,
and a Caterham.
Quite a lot of exotic machinery takes part.
Some of the stages are hairy, in some proof, one unfortunate
was killed last year in atrocious conditions when the car
left the road and hit a pole sideways. Mostly it is just
good racing. Vehicles from 1912 onwards compete. In
reality, any car newer than 1985 has to compete at insane
speeds on country roads to win their class. Older cars have
more realistic times in keeping with the cars capabilities.
Any car can win on handicap. We will be racing a 1970 Lotus
Escort, so speeds will be lower for us, and hence more
achievable.
Date: 17 Oct 96 15:23:38 JST
Subject: Lumenition Ignition System
Have any one in this mailing list had the experience of
installing the Lumenition Ignition System on their classic
Jaguars? What's our impression of the System? Is it
a reasonable method to convert a point and rotor type
distributor into a pseudo electronic ignition system?
Regards
Makoto Honjo
Date: Thu, 17 Oct 1996 08:23:21 +0200
Subject: Wild XJ40
Peter Rebecchi wrote re an entry for the Targa Tasmania:
I think the wildest XJ40s and X300s must be the ones made by the
British company Paramount Performance (formerly Chasseur). The
new Tornado 450 is a 4-litre BiTurbo XJ putting out 450BHP. Some
info on their web-page at www.jagweb.com/paramount and it for
those of us lucky enough to get BBC's Top Gear it has just been
tested and will air soon. More details when I know more.
Nick
Date: 17 Oct 96 02:25:52 EDT
Subject: Re: Carb/engine tuning- status
Hi Kirby,
>> Try richer needles : For the HIF7 carb there are no richer needles - VSE have
>> tried already
> > more than what I am prepared to go through - experience taken at face value
>Hmmmm. Does all of this imply that taking the stock needles out and
>machining them thinner won't help?
I didn't say it wont help or that it will not be possible. I think there is a
possibility.
Only I dont have knowledge, skill or patience to go that route.. Would probably
take endless
number of needles and a good micro-lathe, and lots of understanding and
measuring equipment.
Rather try other carbs that are known to work....
Regards jeffrey Gram
Date: Thu, 17 Oct 1996 16:53:13 +1000
<snip>
To anyone with a series III Xj6 experiencing the start- stop syndrome,
after 2 months picking at this problem and throwing money at it like it was
a whore the problem is solved. Temp. sensor was shorting and causing the car
to run at full rich condition. After 2 min. the car would shut down, fully
loaded with fuel and wouldn't start for 10- 15 min.
James,
Sounds like my recent problem when my XJ-S was flooding itself to death. I
decided to go the whole hog and rewire my injector and sensor looms and
replace all connectors. (see earlier posting) Was the fault in the sensor or
the connectors. I haven't restarted the engine yet to find out if the
problem is fixed.
Derek Hibbs
Canberra, Australia
77 XJ-S
Date: Thu, 17 Oct 1996 01:48:21 EDT
Subject: Re: Cam Kit Details
On 16 Oct 1996 10:09:44 U "Peterson, Gerry" <gp@dlvd.mdc.com> writes: Hi Frank- Hi Gerry, The cam kit came from Terrys. I don't know who the grinder is but they are "reground" cams that provide about .040 inches of additional lift. There is a core charge if you do not return your old cams. The kit includes new ISKY springs, inner and outer, and the richer needles. You will also need all new shims probably somewhere in the .145-.165 inch thick range. Don't buy these until the head is assembled and clearances checked with the old or dummy shims. I also had to machine back the upper spring guides and the valve keepers to prevent them from striking the valve guides. If you are installing new guides they could be made about .050 inch shorter as an alternative. There was no mention that this might be required in the installation instructions. Terrys recommends valve clearance of .010 for both intake and exhaust. It is essential to make sure there is enough "stroke" in the assembled valves to accomodate the new cams. An easy way to do this is to install a light dummy spring and use a dial indicator to push the valve down the amount the cam would push it taking into account the valve clearance plus maybe an additional .010 for safety. Installation of the needles was very straightfoward and required very little fiddling to get the carbs readjusted. My recollection (I did this 2 years ago) is that the kit cost was around $300 and was delivered from stock...about a week to get. GiveTerrys a call for updated price and delivery. Good luck with your rebuild. Frank 62E OTS that you purchased a cam kit which included Isky springs and richer carb needles. Could you please provide additional information on the kit you purchased? Who is the cam manufacturer? Where did you buy it? Cost? Delivery time? Any installation problems or recommendations? Thanks in advance for you help and insight. Gerry Peterson From: Cosmo <simond@inflon.informix.com> Date: Thu, 17 Oct 1996 07:58:05 -0100 Subject: Re: [General] The rec.autos.makers.jaguar newsgroup failed Egil Kvaleberg wrote:
> filter, believe me.
I have to agree with this - the content of newsgroups has plummeted
since the introduction of easy access via Netscape etc. It is full
of spam and the same old questions time and time again. Years ago I
was on the high-end mailing list and it was a nice place to discus
a common interest in high quality Hi-Fi. It is a now a newsgroup
that has degenerated into endless flame wars and juvenile bickering.
I love my car and enjoy the exchange of ideas on this list. If you
want to see what would happen if it got turned into a noisegroup go
visit something like rec.autos.makers.ford.mustang and watch the flame
fest.
Cosmo
83 XJ6 4.2
65 Mustang 289
End of jag-lovers-digest V2 #445
id <RAA26998> for jag-lovers-digest-out; Thu, 17 Oct 1996 17:54:16 +0200 (MET DST)
Date: Thu, 17 Oct 1996 17:54:16 +0200 (MET DST)
Message-Id: <199610171554.RAA26998@ekeberg.sn.no>
Subject: jag-lovers-digest V2 #446
Precedence: bulk
jag-lovers-digest Thursday, 17 October 1996 Volume 02 : Number 446
Lurking
Re: Lumenition Ignition System
Fun with heater cores.
Re: Lurking
RE: Weber's f0r XKEs
re: FW: '88 XJ-S with No Flow h2o
V12 engine managment
Re: start - stop
XJ-40 Help Needed
Re: Lurking
Re: U.S.E-Jag Series I census
R406A has been approved!!!!
RE: XJ-40 Help Needed
XJS Output Shafts
Another E strangeness, Help!
Re: Lurking
Date: Thu, 17 Oct 1996 19:51:00 +0100
Subject: Lurking
Hello everyone...
My name's 'Ashley', and I live in London, England. I joined this list a
week or so back because I'm going to buy a 2nd-hand Jag in the next month
or so, and I wanted to read some background first.
I love Jaguars... Their sleek, elegant beauty is second to none. I want
one, because I want to sink into the upholstery and ride behind one of
the best balanced, nicest sounding engines in the world. In England,
2nd-hand Jaguars are VERY cheap - and maintenance is only 'reasonably'
expensive, because there are quite a few of them about.
I won't bore you all with newbie FAQ's, but I will ask you all about the
attitude I'll receive off other drivers. I'm only 25, and I get the
feeling that others might think I'm trying to be something I'm not if I
buy a Jag - when in fact I'm just getting one because I've always wanted
one.
Ash.
Date: Thu, 17 Oct 1996 14:02:00 PDT
Subject: Re: Lumenition Ignition System
Easy and brilliant. Fitted to my 85 XJ6 3.4 (yes, this came with points
as standard!!) last year. Took about an hour, as I was double
checking the instructions all the time. Once you'd done a few, I bet it
could be completed in less than 15 minutes. So far, fit and forget -
faultlessly reliable.
> Is it
My opinion is don't waste your money on a halfway system that still
relies on points for the timing spark. Replace completely - it's more
expensive, but far more reliable.
Cheers,
Dave Wood.
Date: Thu, 17 Oct 1996 08:57:55 -0400
Subject: Fun with heater cores.
It's the heater core. Everybody was right on target. Plus, it's getting
worse. I've been told it's probably the gaskets about the heater core
that are the problem. Anybody have any comment on this? Most
importantly, can anybody offer advice on how to pull off this repair?
The instructions in Kirby's book (go through the glovebox) are a
tantilizing start. Finally, anybody know where to get the needed
gaskets, or heater core?
P.S., with the increasing amount of water coming out, I feel pretty
certain the radio was fried b/c of this situation. I got the tape out, but
the radio still won't work.
It's an '88xj-s w/ delanair mk iii.
Thanks,
Steve
@the Dark Tower, where you "Speak your mind, but ride a fast horse."
Date: Thu, 17 Oct 1996 09:07:56 -0400 (EDT)
Thanks for the reality check. I had always thought so, too, but have been
finding these bettys to 'leak' -- even the last three new ones (not
original Jag various but various vacuum operated and mechanical
replacements found at an auto parts store). Maybe this is a common
quality problem?
I wonder if sprinkler system valves can take the heat (:]). Operated by
12 volts DC, positive on and off, and they can withstand any pressure
you'd see in a cooling system.
John
'82 XJ-S HE
Date: Thu, 17 Oct 1996 14:23:11 +0100 (MET)
No chicken but some furry animal content.
Eh, mine only has the one switch that senses when the throttle is opened
from idle.
Only two on mine.
Are there any switches on the throttle linkage for example by the
accellerator pedal? The reason I ask is that my car behaves quite
differently if I pull on the throttle valve arm or of I push the pedal.
If I push the pedal it behaves nicely with no stumbling etc. If I pull on
the throttle valve arm it stumbles and generally misbehaves. Why?
Furry animal content: I have a cat called Whisky who loves to ride in
the Jaguar.
Gunnar
Gunnar Helliesen | Bergen IT Consult AS | NetBSD/VAX on a uVAX II
Systems Consultant | Bergen, Norway | '86 Jaguar XJ6 4.2 Sovereign
gunnar@bitcon.no | http://www.bitcon.no/ | Vicki who? What .sig virus?
Date: Thu, 17 Oct 1996 15:30:00 +0100
Subject: Re: Lurking
Hi Ashley,
I wanted to have a Jag limousine ever since because they are so incredibily beautiful. First I was a student
and I hadn't had a car at all, then I was living in France where Jags are quite rare (in the 400.000 agglomeration of Grenoble, I saw 3 of them ...). Plus, I always thought that one should be at least 30 years old to have one.
Well, now I'm 32 and since last week I own a '84 XJ6 4.2. I collect alot of stupid regards if I park the cat in the underground car park of the school where most of the places are rented bye honorable professors (and I'm just a poor postdoc).
But in the end: Who the hell cares with what age you drive what car? It's alone your buisiness. If you long for a cat and if you have an idea about what you might encounter as problems - go for it. Life is rather short, and a postponed dream may soon become a lost dream.
BTW, when I visited London I had the impression that you have to try hard to be noticed as an excentric fellow ...
Ciao
Bert
Date: Thu, 17 Oct 1996 09:58:22 -0400
Subject: RE: Weber's f0r XKEs
>Mark McChesney wrote in part on Wed, 16 Oct 1996 12:36:57
>Re: S1 XKE modifications/long
>Cool, someone else who understands that the E-type is a SPORTS CAR!
>> anyway. Planned for the future are Webers, headers and free flow
>> exhaust.
>I had thought of using Webers too, but I keep hearing that the SUs are better
>than the Webers for the E-type. 3 Webers is massive overkill and you have to
>jet them way down, also, divability is better w/ the SUs. The hottest 4.2s in
>vintage racing use SUs (there is a guy on the West Coast that is very
>successful running Webers, but his car does not make nearly the h.p. as some of
>the East Coast and Mid-West E-types that are on SUs).
Mark, yes, you are right about SUs being better than Weber's for most
racing and street uses, and this applies to both 6 and 12 cylinder's.
According to Lou Fidanza at GTJ, apparently the Huffaker and Group 44 IMSA
V-12 E-types ran with SU's (because of the rules on homologation). However,
when GTJ actually measured the HP of a six twin barrel Weber set up over 4
SUs, they found that there was in fact "very little difference". The
recommendation to me was to stay with the Stromberg/SUs (rebuild with
appropriate needls etc), gas-flow the heads, reprofile the cams, lighten
the flywheel and clutch, and work in some suspension mods. This is good
enough (and reasonable cheap) to dispose of most Volkswagen-cousin
(Porsche) and braying-donkey (Ferrari) cars .... especially if you include
fake rust patches and simulated dings during your bodywork re-do, and sport
a Kramer-esque hairstyle and demeanor yourself (as "Oh @#$%, this guy is
CRAZEE, let's let him past!)
Have fun, be quick!
Peter
Date: Thu, 17 Oct 1996 06:48:01 -0700
Subject: re: FW: '88 XJ-S with No Flow h2o
>>>>> "Aaron" == Aaron Burnett <aaron.burnett@attws.com> writes:
Aaron> I too have a leak on the driver's side of my XJ-S. I have
Aaron> sealed the windshield, and still the leak persists. I live in
Aaron> Any suggestions for solution?
I had to replace my seal. British rubber has its reputation, you
know. But then, my Jag came from Phoenix AZ where the climate is hard
on rubber bits.
Michael Bain "When in Doubt, Gas It!!!" mbain@wolfenet.com
Date: Thu, 17 Oct 1996 15:49:11 +0200 (MET DST)
Subject: V12 engine managment
Our XJ-S V12 is often used for short trips (unfortunely gas is very
expensive here, so I have another dayly transport :-( ).
However, I'm looking to drop the fuel consumption during warmup and
would be interested if someone else has already done this. I've put
in a multiple-pin cable for the arm-rest console to the engine, so I can
connect a little home-made tester easily. I have the impression that the
engine is running very rich the first 15-20 minutes and then drop to a
normal level. My first try will be to fool the coolant temp sensor, so
when the engine is 40 I tell the ECU it's 60 etc.
However, yesterday I drove around about 4 miles and then checked the
temperature with my Fluke gauge (garage sale, $ 1.00 :-) ) and it
was 82.5 C at the thermostat. So I guess temperature is not all.
I think there is a 15 min limited ignition advance change when the coolant
temp was under 38 C when the engine was started. (This is a European
version 12.5:1 compression 5.3ltr)
Any ideas/hints would be appreciated. Yes, I intend to get the AJ6 fuel
injection book.
Kind regards
- - Matthias
Date: Thu, 17 Oct 1996 09:03:54 -0600
>Hope this helps,
>Jim Stapleton
This is a common problem. I have mentioned this in past threads for those
with FI problems. The part is cheap so change it almost automatically. Also,
be ready to change after an overheating episode. This tends to accellerate
the demise of the sensor.
Hal
Hal Rogers
H.D. Rogers & Sons
(318) 742-5044 fax
Date: Thu, 17 Oct 96 8:41:00 CDT
Subject: XJ-40 Help Needed
This is the second time I have posed this question to the list. Recieved no
ansers the first time, but this time I have more details. So Michel Neal or
someone with experience if you can help I would realy realy appreciate it.
The drivers side blower unit on my 1988 XJ-40 has stopped working at the two
slower speeds. It still works at high speed and the passwenger fan works OK.
I have not yet removed the blower, but have removed the knee panel below the
steering wheel. I can hear both the blower isolation relay and the high
speed relay click at the appropriate times, which is not too surprising as
the high speed works OK. The dash switch is working at every position as it
affects the voltage in some of the many wires leading from the magic computer
control for the ventalation system. So according to my logic it must be
either the central computer or the speed control and speed feedback circuits
which I think are located in each blower. My manual for this car shows a
logic for about 20 wires to the computer, but there is no way I can correlate
these with the 60 or so wires actually leading to the computer.
There is a total of 7 wires leading to the blower. The two large wires are
presumably the power supply and always show 12 V positive and negative with
the fan switched on. There are then 5 smaller wires, which are presumably
the logic to the computerized speed control. One of the wires gets a
positive voltage when the blower is switched to max..... presumably this goes
straight to the high speed relay. However, no change in voltage is observed
for any of the remaining wires when the switch is adjusted to either the low
or medium settings...... this may or may not be correct given the closed loop
control system with the computer.
So is the central computer blown or just confused because the blower is not
providing the correct feedback (i.e. blower gone wrong)? Are there any other
possibilities before I spend a bunch of money?
All help appreciated.
Paul Lacey, San Antonio TX
Date: Thu, 17 Oct 1996 10:17:41 -0400
Ashley,
Welcome to the list.
But if you buy a jag you *are* special.
You didn't mention the model, so let us know.
Good luck, have fun, sign autographs!
'62 E-Type, ots
Date: Thu, 17 Oct 1996 10:24:44 -0400
Subject: Re: U.S.E-Jag Series I census
>-- End of excerpt from Robert J. Richardson
Is there any way to find out? Call all 50 DMVs? My car is not licensed, would
it then come up as 'expired'?(oops, it is a '65 anyway) How many untitled or
unlicensed cars are in restoration or storage? Still, it would be interesting
to find out... How about including the 4.2 S1 cars???
Mark
Date: Thu, 17 Oct 1996 10:33:00 -0400 (EDT)
Subject: R406A has been approved!!!!
Group:
The following post from the mopar network may be of interest to those of
us in the USA with outdated air conditioning systems:
>Return-Path: owner-mopar@universal.fiber.net
>X-Fibernet-Tip: Don't quote more than you contribute!
>Date: Thu, 17 Oct 1996 00:52:39 -0600 (MDT)
>From: Whistling in the Dart <dastern@nilenet.com>
>To: mopar@universal.fiber.net
>Sender: owner-mopar@universal.fiber.net
>IMPORTANT!
>Carol Browner, USEPA, has signed her OK on R406A and GHG-X4.
>THIS MEANS:
>R406A and GHG-X4 will be LEGAL, repeat, 100 per cent LEGAL to use in your
>automobile air conditioner thirty days from today (Wednesday). Repeat,
>LEGAL. LEGAL. LEGAL. (sorry, can't help myself)
>The official conversion will require unique fittings be installed over
>your R12 fittings, and yes, you hafta have a license to buy it, but this
>means there IS NO LONGER AN EXCUSE for butchering-up your air conditioner
>and settling for substandard performance with an R134a retrofit.
>Daniel Stern "a 2.2T3, a 2.5, and 2 225s. Say it FAST!"
>http://ursula.uoregon.edu/~dastern <---All Things Daniel and Pizza
>'65 Canadian Valiant '91 Spirit R/T and the SL6 Resource Centre
>Illegitimis Non Carborundum
>Nihil tamquam temporis momentum ultimatum incitat.
>Cogito ergo vroom
Date: Thu, 17 Oct 1996 08:43:58 -0600 (MDT)
Cosmo adds...
{Egil Kvaleberg wrote:
{> On Wed, 16 Oct 1996, Lawrence Buja wrote:
{> > Since I feel that it is a worthwhile newsgroup, I plan on restarting the
{> > creation process after the required six month waiting period.
{> Do as you please. But the small difference in effort between someone
{> hunting up jag-lovers and actually subscribing to it, compared to just
{> clicking on a newsgroup with his Netscape, acts as a very good garbage
{> filter, believe me.
I agree with you 100%. This is a great mail-list. Alot of people have
invested a great deal of time and effort getting it to where it is now
and I wouldn't do anything to harm it.
All I'm attempting to do is to broaden the accessibility to Jaguar
information on the net to even those unsophisticated enough to not
know how to subscribe to our mail-list.
{I have to agree with this - the content of newsgroups has plummeted
{since the introduction of easy access via Netscape etc. It is full
{of spam and the same old questions time and time again. Years ago I
{was on the high-end mailing list and it was a nice place to discus
{a common interest in high quality Hi-Fi. It is a now a newsgroup
{that has degenerated into endless flame wars and juvenile bickering.
No, this is just plain wrong if you are talking about the
rec.audio.high-end newsgroup. I just looked at rec.audio.high-end and
it is anything but flame wars and juvenile bickering. It's appears
quasi-professional and enjoys a much higher signal to noise ratio than
Jag-lovers. Check it out.
{I love my car and enjoy the exchange of ideas on this list. If you
{want to see what would happen if it got turned into a noisegroup go
{visit something like rec.autos.makers.ford.mustang and watch the flame
{fest.
I did visit rec.autos.makers.ford.mustang. In fact I just went through
rec.autos.makers.*. There are three flame threads and hundreds of
other good threads. If the flame threads bother you, you can easily
filter them out by using the standard killfile logic which deletes all
articles posted to more than two newsgroups. The rest of it is solid
auto related discussion which ranges from the marginally interesting to
the very good. But, in any case, there's lots of good stuff there.
It's very easy to take potshots at newsgroups from the comfort of a
mail list. But it's all kind of moot until the proposal gets raised
again next spring. Let's drop the subject until then.
/\ Lawrence Buja http://www.cgd.ucar.edu/cms/southern/
\_][ southern@ncar.ucar.edu National Center for Atmospheric Research
\_________________________Boulder,_Colorado___80307-3000__________
Date: Thu, 17 Oct 1996 08:10:16 -0700
Subject: RE: XJ-40 Help Needed
If the blower motor has gone open circuit, then you would get the results
you describe - I believe the speed of the motor is controlled by it being
in series with a variable resistance, thus the voltage read will always be
~12v in this case.
Graham
- -----Original Message-----
Sent: Thursday, October 17, 1996 1:41 PM
To: Jag-LOVERS@sn.no
no
or
two
OK.
the
it
computer
circuits
correlate
goes
observed
low
loop
other
Date: Thu, 17 Oct 1996 17:39:04 -0200 (GMT)
Subject: XJS Output Shafts
Cri de Coeur from South Africa
I have an '86 XJSC which has managed to destroy the oil seal/bearing on the
output shaft from the differential on the passenger (left) side of the car.
The diff is a Dana unit and my friendly Jag shop phoned me to say that i)
they had the shaft removed and ii) it is not possible to replace the seal
and bearing as Jaguar will only sell a complete shaft (JLM313) for that
particular rear end. As the shaft is in excess of $1 200 in SA and there
ain't one in the country anyhow I was wondering....
i) has anyone had this problem and fixed it without buying the whole d*&^% thing
ii) does anyone have ref nos for replacement bearing, seal and retaining ring?
Yours in hope Brian Askew
'86 XJSC '64 3.8 MkII
Date: Thu, 17 Oct 96 08:38:48 PDT
Subject: Another E strangeness, Help!
I'm replacing my ID plate which sets under the heater box on my '71 "E".
The last two items on it are adjustments for intake and exhaust valves. I've
looked at a couple of '70 model cars and they say 004 and 006 in the boxes.
But, on my head it is marked that both intake and exhaust valves should be
adjusted to 012-014 inches.
What should I stamp on the plate?
LLoyd -would like to stamp on the body shop that threw the original out...-
Date: Thu, 17 Oct 1996 09:51:10 -0600 (MDT)
Bert writes...
{I collect alot of stupid regards if I park the cat in the underground
{car park of the school where most of the places are rented by honorable
{professors and I'm just a poor postdoc.
We all get comments, but the one's I've gotten have been supportive.
The principal of my kids school (who races BMW's) regularly tries to
give me good natured grief about owning a Jag, but I fling it right back
about her and her boxy beemers. At work, I've gotten a bunch of "Wow,
I've always wanted one of those", a couple "When do I get a ride?", one
"So what do you use for gasoline in that thing, rocket fuel?" and a
"When are you gonna race it against my Corvette?" And this is just with
a 14 year old XJ6 sedan (around these parts, Jags are uncommon enough
that people don't seem to know whether mine's 2 or 10 years old).
Since I'm one of the younger fellowss around here and atmospheric
researchers aren't known for making a lot of money, I have gotten a few
"You (or Your wife) must be doing very well to afford such a nice
car"'s. But it's easy to point out that it cost no more to buy than the
4 year old used Ford Taurus which they bought and that, if something
should break, I can fix anything on it myself with new or used parts
which are readily available and not all that more expensive than those
for US cars. It may be a little more work, it way be a little less
reliable, but it doesn't cost me much more than a boring appliance car
and it's a hell of alot more fun to own and drive.
Basically, I've never gotten anything but good remarks about it. I've
heard stories of Jag owners getting their cars "keyed" (someone running
the sharp end of a key down the paint) in Denver, but it's never
happened to me. And the two times that it did break down on the road,
the police were almost overhelpful to Anne, getting her pushed to safety
and personally driving her to her meetings. It's been my experience
that people in the US are more supportive than antagonistic towards
Jaguar owners (perhaps it merely sympathy).
But my sister in London pointed out something to me when I told her
about getting my Jag. She said that there's a big difference in how the
working class in the US and the UK view someone in a Jaguar. The US
working stiff thinks that everyone should be rich enough to afford one
of those and someday they might be able to get one while the UK bloke is
of the opinion that no one should be rich enough to have one and they'll
never have a chance to get one. So, in the US you are apt to get thrown
a wave while in the UK you might get thrown a brick. I've never been
to the UK, so I can't verify the truth of this.
End of jag-lovers-digest V2 #446
id <XAA14577> for jag-lovers-digest-out; Thu, 17 Oct 1996 23:51:21 +0200 (MET DST)
Date: Thu, 17 Oct 1996 23:51:21 +0200 (MET DST)
Message-Id: <199610172151.XAA14577@ekeberg.sn.no>
Subject: jag-lovers-digest V2 #447
Precedence: bulk
jag-lovers-digest Thursday, 17 October 1996 Volume 02 : Number 447
Re: Lurking
E series II dates
dead pedal for XJS
XJ6L Parts Car
XJ-S Brake job
FW: XJS Output Shafts
New Member / XJ6 Questions
USA 88 XJ40 Rear Suspension Conversion
Just Bought XJ40
Vintage Gasoline
Daimler to identify please
Re: Lurking
re:Lurking
Attitude
Lighthearted Question, MCC*
JAGUAR XK 120 140 purchase
Re: Vintage Gasoline......
Vintage Gasoline
Vipers.
Date: Thu, 17 Oct 1996 09:16:22 +0000
Ashley Rolfe wrote:
> Hello everyone...
> buy a Jag -
Hey.. thats why I bought MY jag!... sheeshe if we all have to pretend we are exactly
who we are, there will only be Camrys on the road.
relax, enjoy, let them eat cake!
Jim Goring
________________________________________________________________________
Frank, Goring & Straja Architects jgoring@FGS.com
1144 65th Street Voice: (510) 595 9000
Oakland, CA 94608 Fax: (510) 595 9209
Date: Thu, 17 Oct 96 09:01:15 PDT
Subject: E series II dates
Well, I guess I've put out some mis-information. A reference book I have
states the last series two was produced in 10/70, but Bob Bagramian has one
produced in 11/70. Anyone with later information? I'll mark my reference book w
hen I can locate the page number.
Also, someone was asking about production figures for the "E". Here's what
the book says;
yr engine ots fhc 2+2
'61-64 3.8 7,820 7,670 -
65-68 4.2 9,550 7,770 5,600
69-70 4.2 8,630 4,860 5,330
71-74 5.3 7,990 7,300 -
grand total 75,520
I thought all the series III coupes were 2+2's not fhc. Is the book wrong
here too? LLoyd
Date: Thu, 17 Oct 96 09:23:04 -0700
Subject: dead pedal for XJS
Does anyone know of any over the shelf dead pedals available for the XJS
with auto (no clutch). After having a number of cars with dead pedals, I
miss having a place to put my left foot. I've been told that one can
fabricate one, but I've never seen it. Any suggestions would be
appreciated.
'96 XJS convertible - the last of the breed.
David C. Engelbach E-mail - widi@artnet.net
Valley Village, CA 91601 Voice - 818.506.5441
USA Fax - 818.506.1011
Date: Thu, 17 Oct 1996 12:37:14 -0400 (EDT)
Subject: XJ6L Parts Car
Hello All,
I have a 75 XJ6L parts car for sale if anyone is interested. You can
e-mail me anytime. It was fun for a while to sit in it and listen to the
radio, but people were starting to talk.
Joe Reilly
Cambridge, Massachusetts, USA
Date: Thu, 17 Oct 1996 13:04:23 -0400
Subject: XJ-S Brake job
>Regarding the brake pads the instructions for starting to re-assemble the
>pads say:
>right?;
Correct
I don't know what it looks like but I was able to work the pistons back
fairly
easily
>the area?
I replaced the bearing & race, than repacked the hub.
I did not replace the lock wire on mine. I would have, if I had one.
It
resembles a twisted coat hanger more than a cotter pin.
If I remember correctly, they are between the caliper itself, and the
steering
arm. No shims fell out on my left side, but on the right side both
upper &
lower fell out. It is a good idea to note where they belong so that you
could
put them back in the correct place. As for my car, I will watch to see
if the
pads ware evenly. The pads are relatively inexpensive and easy to
replace.
But that is the purpose of the shims, is to ensure that the pad is
pressing evenly
against the rotor.
>wheel?;
I was able to slip the old rotors out, but was unable to slip the new
rotors in.
I than had to cut the locking wire to remove the bolts that secure the
rotor &
at this point the shims may fall out.
I hear from a mechanic that there is some special grease you could apply
to the
metal area of the pad, where the caliper rubs the pad. This may prevent
break
squeal.
Tom Murray
87 XJ-S
Date: Thu, 17 Oct 1996 10:58:52 -0700
Subject: FW: XJS Output Shafts
I just called Special Interest Car Parts (located on the eastern coast
of the United States) and they carry output shaft bearing and seal kits
(Part No. JLM290) for $64.13 US. Their phone number is 1-800-556-7496
and they generally will deliver anywhere.
Hope this helps.
Aaron
'85 XJ-S
>From: B. Askew[SMTP:askewb@global.co.za]
>Sent: Thursday, October 17, 1996 12:39 PM
>To: jag-lovers@sn.no
>thing
>ring?
Date: Thu, 17 Oct 1996 14:17:28 -0400
Subject: New Member / XJ6 Questions
I found your group on the net under Michael Neals Technical Advice for
Jaguar owners. Sounds great - I'd like to join and also have a couple of
questions.
Questions:
For a 1983 S3 XJ6
1) Time for new tires - I'd like to stay with the original size of 205-70 R
15, they look better on the car than the larger 215-75's, but the original
Pirelli P5's are out of print, so even if I can find NOS they could be
short(er) lived due to shelf aging, plus they seem overpriced for their
performance. What are good tires in this size? I've seen strong
recommendations for Dunlop D 60 but they don't come in that size.
2) Cold Idle Problem. The car starts fine but when it's cold, after about 5
seconds of smooth idle it changes to a rich mode and starts to run rough,
black smoke , the idle speed sometimes hunts up and down, even stall. When I
drive off the problem clears and it runs well, but returns to the problem as
soon as I stop and it returns to idling again. When the engine temperature
reaches about 60 the problem disappears. I've tried an exchange ECU, AFM,
and coolant temperature sensor, no effect. I've also checked fuel pressure,
start injector timing, vacuum leaks, and injector leaks - all seem OK.
I assume that I could bluff the ECU with a resistor switched in parallel
with the coolant temperature sensor, to fake that the engine is warmer than
it is and back off the mixture. But I'd sooner fix the problem at its source
if I can.
In Michael Neals Technical advice for S3 XJ6's I see a paragraph on internal
adjustment of the AFM. Is this adjustment the problem? Does the AFM in a
1982 have this adjustment, and how do I find it? Or is there another solution.
Thanks
Ian Grant
Date: Thu, 17 Oct 1996 14:19:58 -0400
Subject: USA 88 XJ40 Rear Suspension Conversion
No chicken content!!
Thought it was way past time to introduce myself as I have been "lurking the
Digest" for quite a while. I retired six years ago from a 30 year stint in
the U. S. Navy because Jaguar maintenance and repair requirements dictated
that I do so. My wife and I have four between us and she does not twirl a
wrench!.
Now to the subject at hand. Ordered and received from Special Interest Car
Parts JLM11698 rear suspension conversion kit that contains instructions and
all pieces to replace the self leveling "junk" that has been repaired twice
before in the car's 73K miles of travel. In fact, there are more pieces than
I know what to do with and less instruction than I would like. (Jag Tech.
Bulletin 64-14 "Rear Struts - Non-leveling Dampers - Repair Procedure). My
problem is figuring out what to do with the six hard black plastic
spacers/"packing pieces". Two of them are 1/8" and four are 1/4" thick and
they do not have part numbers. The very rough diagram shows what I think are
spacers (one) on the top and bottom of each spring. The "fitting
Instructions" for the springs that came with this kit indicate one CAC 9162/1
and one CAC9162 "Packer" for each spring assembly. The instructions do not
indicate whether these "Packers" are supposed to be on top or the bottom of
the springs.
I hope that I have been able to convey my confusion without creating more
confusion. If any of you have done this conversion your advice at your
earliest opportunity would be most appreciated.
e2plus2@aol.com (Rex Henderson) In Connecticut at the Rhode Island border
near the shoreline.
1994 XJS (Her Toy)
1988 XJ40 (My Schlepper)
1987 XJ6 (Her Schlepper)
1972 E-Type (My Toy)
From: Marshall Hollister-Jones <marshall@mentor.co.nz>
Date: Fri, 18 Oct 1996 07:26:31 +1300
Subject: Just Bought XJ40
Hi all. I've just bought an '87 XJ40 Sovereign in excellent order travelled
only 50,000 km. After much research I have found this mailing list which
looks great!
I have one little problem which I hope someone can help me with. My bulb
failure system is playing up. All bulbs are functioning but I still get a
constant report of a failure. This seems mostly when operating the left
indicators. I have checked the bulbs for loose connection etc but all looks
OK. Could it be a faulty sensor but how do you tell which one?
Tauranga
New Zealand
Date: Thu, 17 Oct 1996 15:07:09 -0700
Subject: Vintage Gasoline
Hello Curt,
I was told by several chemist-types that fuel goes 'stale'. That is, it looses its ability
to combust cleanly and uniformly. I don't know whether all fuels are like this, but I am
under the impression that high octane fuels begin to go stale after about 3 weeks, where
lower octanes take a little longer.
I do know from personal experience that very old fuel can cause havoc. My father has
several Corvettes one of which is a '61 that rarely leaves its nest in the barn. (Yeh,
it's a lump, but you can't beat the raw noises, rumbles and smells of a 283 with a fuely
cam and a Holley 760 double pumper...) Anyway, it had been sitting for about 6 years
without being touched. The last time it ran, it ran like the race car it was in '62. This
time however, it wouldn't start period. We tried everything: new plugs, carb teardown,
you name it. Finally I shot some starter fluid into the throats. It fired and idled
roughly for about 2 or 3 minutes. I brapped the throttle to see whether it had cleared out
whatever had nested in the cylinders and it backfired louder than a black powder musket -
leaving a hole the size of a golf ball in the back of the left glass pack. Then it died
and refused to start. We then drained the tank and started with new high octane fuel. One
hit of the key and it fired like it used to and ran perfectly - except for the slight
increase in exhaust tone.
Sure, the backfire could have been the glass packs loading up from all the start attempts,
but the fact that it wouldn't even fire was definitely due to the fuel. I have personally
stored my Jag and Triumph for upwards of a year with no major ill effects. Who knows.
If anyone knows more about this please add your knowledge.
Thanks.
>From: Curt Onstott <onstottc@ucs.orst.edu>
>Date: Wed, 16 Oct 1996 13:10:50 -0700 (PDT)
>Subject: Vintage Gasoline......
>Last night I got around to draining the seven years old gasoline out of
>the left tank of my SII XJ6. The stuff smelled like varnish. I'm sure
>there was a little water in there as well. Now I'm curious. What happens
>to gasoline as it ages? Does it break down into other hydrocarbons or
>what? Any chemists out there who can elaborate?
>As for getting rid of old gas, I usually burn it in small amounts in a
>coffee can or mix it in small amounts with every tank of gas. Does
>anybody have a better technique?
DAVE OXENREIDER
'73 XJ12 SWB
'75 TR6
Audio Visual Imagineering, Inc.
Orlando, FL
http://www.gate.net/~laser3d
daveox@av-imagineering.com
76764.274@compuserve.com
Date: Thu, 17 Oct 96 16:50:57 gmt
Subject: Daimler to identify please
I have been asked about a car in the Jaguar Daimler Hereitage Trust picture
http://www.jagweb.com/jdht/mus2.jpg
I wish to know whar the car behind the Dart is, and if anyone knows, what years
made, how many??
Alastair Lauener
Date: Thu, 17 Oct 1996 12:28:58 -0700 (PDT)
Yesterday evening I tried to fill my '62 E and go home. It took about 20
minutes *after* I finished gassing the car, to get out of the station. Every
guy who drove in was curious about it and wanted to look. Kinda fun!
Hunt
(That doesn't happen as often with my XJ-6, but it gets looks, too. I
haven't ever experienced anyone with a bad attitude about it.)
At 07:51 PM 10/17/96 +0100, Ashley Rolfe wrote:
>Hello everyone...
>one.
>Ash.
Date: Thu, 17 Oct 96 15:58:11 EST
Subject: re:Lurking
>Ashley Rolfe writes :
>Subject: Lurking
>Hello everyone...
>one.
>Ash.
Hey Ash !
I'm 40 years old and I get attitudes from other drivers,
and I have an '85 SIII XJ6. When I take it in for the mandatory safety
inspection, I hear comments from the grease monkeys like : "yeah, you got
to drop the whole rear end to replace the brake pads". Also, there's a guy
in my car pool (I drive the Jag to work maybe twice a year) who, whenever
he rides in it says, "Is this real wood ?, Wow, I've never ridden in a
Jagwire before", and this guy drives a new Ford Escort that cost more than
my Jag. (He always slams the door like he's trying to crush it too !)
I guess there's some jealousy involved, but I love my Jag, and I'm not
jealous of anyone (except maybe Bruce Willis).
Jim Legge
85 SIII XJ6
80 TR7 (the red-headed stepchild of Triumphs)
Date: Fri, 18 Oct 1996 09:24:24 +1300
Subject: Attitude
A good point Ashley, who wrote.....
<snip> but I will ask you all about the attitude I'll receive off other
drivers. I'm only 25, and I get the feeling that others might think I'm
trying to be something I'm not if I buy a Jag - when in fact I'm just
getting one because I've always wanted one.<snip>
I too wanted a Jag for ages; 2 months ago I achieved my dream with an
'88 XJS Coupe.
It's a good looker in silver birch and glistens in the sun and turns
heads.
It feels a bit awkward to be so noticable; but nice.
However about 3 weeks after getting it a pedestrian jaywalking across
one of our main
shopping streets in the centre of Auckland at midday (lots of other
shoppers around)
decided that the RH door would look much better with an imprint of his
foot.
He took a run at me while I was travelling at about 50 KpH and drop
kicked the door
then scarpered off up the road. I was absolutely stunned, stopped and
fortunately did
not get hold of him or I would probably be locked up now. I'm still
quite shaken up about
this totally unprovoked incident.
The damage is minimal after polishing scratches out with brasso; but
there is now a slight
ripple in the panel. Unnoticable by most but very obvious to me.
Have others experienced anything like this ?
Jaguar ownership is seen as "status" but in reality as you point out is
affordable and in my
case cheaper than many of the bread and butter Holdens and Fords that
the masses are
using as family cars. If you want it go get it and to heck with what
others think !! (they are
most probably wrong) Do you ever question any of their spending
priorities ?
Regards
john_setters@eagle.co.nz
JKS-XJS 1988
Date: Thu, 17 Oct 1996 16:52:42 -0400
Subject: Lighthearted Question, MCC*
I'm going to do some heater core disrepair this weekend, which
promises not to be over easy*, and thought why not destroy two parts
of the car at the same time. The problem is minimal, but annoying (like
my posts!). At night, the dash light brightly illuminates the four vertical
gauges, but provides little light to the speedometer (hence,* you can
barely read it), and less to the tachometer. Any words on this issue
and how to correct? I'm trying to stay abreast*, but find I often have to
wing* it unless you guys tell me eggxactly* what the correction is, so
thanks for the advice so far; I'll keep pecking* away. Hoping this
doesn't get me fried,* Steve.
'88 XJ-S Coop*
'89 XJ40 Van den Flock*
*=Marginal Chicken Content
Date: Thu, 17 Oct 1996 23:00:54 +0100 (GMT+0100)
Subject: JAGUAR XK 120 140 purchase
I purchase a JAGUAR XK 120 /140 to buy :
ROADSTER, complete, no rust,good base for restoration (total).
I live in french (MARSEILLE) and there is no problem for shipping it.
Please advise to e-mail : bottasso@lac.gulliver.fr
Thank you.
Chritophe.
Date: Thu, 17 Oct 1996 17:04:09 -0005
Subject: Re: V12 Cooling Circuit
John Napoli:
> quality problem?
As far as I can tell, the problem isn't quality so much as design.
The early (and expensive) Jaguar heater control valves (reportedly
based on a GM design) are a type of "ball valve" with a cylinder
instead of a ball. This design valve doesn't like particles in the
fluid, they tend to screw up the seals causing leaks.
The later GM valves are a type of butterfly valve. Much more
durable, but very difficult to get to totally shutoff even when new.
Forget the sprinkler valves. The valve of choice is definitely the
late-model Jaguar heater control valve, available anywhere for about
$10. Entirely plastic, poppet type valve, vastly superior design to
anything else I've seen from Jaguar or GM.
| - Palm's Postulate
Date: Thu, 17 Oct 1996 16:29:57 -0500 (CDT)
Subject: Re: Vintage Gasoline......
There should be a good market out there for old gas. I mean, how could
one really have a 100-point, as-it-came-off-the-line concours car without
authentic gas?
Larry "I got my plaque with new gas" Lee
Date: Thu, 17 Oct 1996 17:35:29 -0400
An untechnical observation, but I've found that gasoline after 2 years
storage in a sealed can has varnished badly and will cause you to hurt
yourself trying to start a lawnmower with it.
Our local garbage dump accepts old oil but not gasoline. I also use the
trick of mixing it in small amounts with fresh stuff, and burn it in a car.
Date: Thu, 17 Oct 1996 15:49:41 -0600 (MDT)
Subject: Vipers.
{> We're going to the Denver unveiling of the XK8 tonight.
{> Should be fun...
{Heh. Neat. I'd still rather have a Viper. :)
Funny you should mention Vipers. Last weekend was a fundraiser at the
new track at the old Denver airport. Pay the $50 and race your car as
fast as you can on huge expanses of nice concrete which go on forever if
you miss a turn and go spinning off the track. These events are fun
because you get a different group of cars than the regular vintage race
club crowd. I was helping Grossmans with the racing MkII and another
club member with a silver SII E-type coupe. Patty got tired of driving
in the afternoon and told me to suit up and take the MkII out for the
last medium speed heat.
So I got to spend a half hour racing a Jaguar MkII against a pack of
Ferraris, Porsches and Corvettes, as well as an nitrous'd NSX and a
beautiful matched pair of dark blue with white stripe Viper Coupes.
Of course, they were all way faster than the MkII on the long straights,
and overall they pretty much kicked my ass, but I am proud to say that I
was able to stay with one of the Vipers for the entire second half of
the race (I won't mention how terrible of a driver he was).
The one thing I learned is that I need to get in some track time with an
experienced driver to guide me. The straights are easy: accellerate
until you hit the rev limiter and stay up there until you chicken out
and brake/set-up for the upcoming turn. It's the turns that are tricky.
There's a milllion different ways to enter, apex and exit the turns.
Sometimes I'd blow it, lose all my momentum, bog the engine down and
turn into a big british racing green colored rolling roadblock. But, a
few times I'd hit 'em just right and come out ahead of the pack.
It was grrrrreat!!!
End of jag-lovers-digest V2 #447
X-UIDL: 71b01c87fc7314ad496470dc67182f62
Return-Path: @owner-jag-lovers-di1
Received: (from majordom@localhost) by ekeberg.sn.no (8.7.5/8.7.3/on4)
id <FAA22244> for jag-lovers-digest-out; Fri, 18 Oct 1996 05:28:14 +0200 (MET DST)
Date: Fri, 18 Oct 1996 05:28:14 +0200 (MET DST)
Message-Id: <199610180328.FAA22244@ekeberg.sn.no>
To: jag-lovers-digest@sn.no
Subject: jag-lovers-digest V2 #448
Reply-To: jag-lovers@sn.no
Errors-To: @owner-jag-lovers-di1
Precedence: bulk
Status: RO
X-Status:
X-Newsgroups: mail.jag-lovers-digest
jag-lovers-digest Friday, 18 October 1996 Volume 02 : Number 448
Re: Funny car story (no Jaguar content)
Re-send, Vintage Jags in Competition
Grovelling for info on bits!
Re: Lurking (Thu Oct 17 19:51:00 1996)
Re: Lurking
Old Fuel
Re: XJS Output Shafts
Re: Lurking
Re: Lurking
Re: XJ-S EFI Rebuild
Re: XJ-S
Re: XJS Output Shafts-REPLY
Positive Ground to Negative Ground Conversion
Need Help for 89 XJ40
Leaper
Re: intro (New person) XJS
Re: Black Saturday Relived
Date: Thu, 17 Oct 1996 17:38:53 -0500
Subject: Re: Funny car story (no Jaguar content)
This story has been circulating for many years. I first saw it long
before I had internet access. In the years since then I've seen it a
great many more times on the net, including previous appearances here
on Jag-Lovers. Recently it was also in a car magazine. Just like the
story about the broken Rolls-Royce rear axle, this has become an
"urban legend." This particular one is wildly implausible and
probably began life as a simple joke. Unlike the Rolls legend, this
one does seem to remain in Arizona instead of having its locale move
around the world.
MikeC
Date: Thu, 17 Oct 1996 17:53:04, -0500
Subject: Re-send, Vintage Jags in Competition
Hi Nick,
Charles Dalyfrom Toronto reminded me that I forgot to list my web site
after writing the following note! Sorry, sometimes I forget to zip up my
pants, too!!!
http://pages.prodigy.com/aimhigh/lcats1.htm
Hi Nick,
I've sent off notes before but to a different address thinking I was
using a proper one for the Jag-Lovers. Sorry. I picked this address out of
a recent note of yours to John Elmgreen. Hope this one does the trick!
I've built a series of web pages with pictures of our old Jags at various
race tracks and rallys from the United States, Mexico and the Bahamas.
There's also an article about a MK II that I'm restoring for street use at
this site. Hope all enjoy the pics, etc.
I can make the various small images available as *.BMP files. These make
great "wall paper" for those using Windows to "tile" their opening screen.
Presently I have lots of XK 140's being chased by 356 Porsches as my my
wall paper on my machine. These are relatively small files as *.BMP so
could be attached to an email note. Anyone interested can send me email
from the web pages. Please identify the miniature photo by number.
If you would like any of these images as *.gif or *.bmp files for your
own records, please let me know.
Best regards and thanks for the hard work,
Tom Veale (Piloto Loco)
Port Washington, Wisconsin, USA
Date: Fri, 18 Oct 1996 07:38:24 +0900
Subject: Grovelling for info on bits!
Hi there,
>a Brit.He wants a "big" one but thought he'd try a "little" one
>first, so he picked up a three-year-old very low mileage British
>Racing Green one for 1,000,000yen (about $9000). He's already paid
>his subscription to this elite
He really bought cheap -- no wonder he had to pay his initiation fee.
Whenever you feel particularly cute about your boss, ask him if he
bought a jikosha (car with accident record).
>My boss wants the foglights and a leaper.
I'm not sure about the foglight, but the leaper is available from any
Jaguar Japan dealer, although no doubt at frightfully marked up
prices. Make sure your boss doesn't go ahead and buy one during your
absence.
By the way, in the latest issue of the Jaguar Enthusiast, there's an
article about an outfit in Norwich which facelifts an XJ40 into an X300
(that's the latest version, it's called the XJ6 here in Japan) look
alike. If these guys sell their conversion kits, and you could get
your boss to lay his fingers on 'em, well your brownie points are
surely made. The outfit's called Custom Cabrios (phone +44 1263 76
8824 or 76-1681).
>a TR6. Here, I take the subway. Sigh.]
Hey, taking public transportation is a noble act of environmental
conscious ness -- besides as an added benefit, it gives you a strong
(and with the crowded condition of the trains during the rush hours)
flexible back. But, I agree, it's nice to be on the wrong side of being
environmentally conscious.
Regards
Makoto Honjo
Phone/Fax +81-3-3473-1848
Date: Fri, 18 Oct 96 12:10:22 GMT
Subject: Re: Lurking (Thu Oct 17 19:51:00 1996)
> Hello everyone...
> one.
> Ash.
Ashely, I'm 24 and I purchased my XJ-S earlier this year. Apart from hassleswith insurance - (Best to join a car club, no-one wants to insure someone myage who drives a V12!) I've had nothing but positive comments from others, mostly along the lines of "How the hell could you afford that!" As others
have said, when you are stopped for gas or for whatever reason, it
invevitably takes you twice as long as you end up chatting to someone about
your car or Jaguars in general. (BTW, I'm off to the New Zealand premiere
of the XK8 on the 1st November, can't wait!)
At any rate you're buying the car for yourself and not anybody else, so what
does it matter what they think.
ENJOY!!!
Dave C
'77 XJ-S
Date: Fri, 18 Oct 1996 00:22:33 +0100 (MET)
There is wisdom in them thar words!
Gunnar
Date: Thu, 17 Oct 96 16:20:48 PDT
Subject: Old Fuel
I have stored my Jag with fuel in it for a year. There are two things to do
to make it safe and not damage anything.
First, pour in some stuff to help the fuel stay good. It can be purchased at
auto parts stores, and needs (it says) about 8 ounces per ten gallons of gas.
Bunk. One 8 oz. bottle works with a 20 gallon tank fine.
Second, fill the tank all the way to the top. This keeps air/condensation
out of the tank, so water won't accumulate at the bottom of the tank over time.
Run it for a few minutes to assure the chemicle gets all the way to the carbura
tors/fuel injectors.
Piece of cake.
LLoyd
Date: Fri, 18 Oct 1996 00:47:38 +0100 (MET)
Subject: Re: XJS Output Shafts
Not sure what that means but a big hello to you from Bergen on the west
coast of Norway! ;-)
> d*&^% thing
Nope, I don't even own an XJS, but: Even around here there are several
"machine shops" that stock just about any seal and bearing you could
think of. I would take the old parts to such a shop, let them measure
them carefully and see if they couldn't find a replacement. I'm willing
to bet that they'd have the parts in stock and that they'd even be quite
cheap.
Don't ever accept the opinion of an auto mechanic when it comes to the
reparation of complex machinery! They simply do not know what they're
talking about. Todays mechanics are not trained to _fix_ things, just to
replace them. If a part is not in their book they're helpless. Pathetic!
My advice: Get the old worn parts from the Jaguar garage, get your car
out of there as soon as possible and find yourself a mechanic who is at
least 50 years old (because they still remember how to _fix_ things and
some even put pride in their work).
Bearings and seals are used in so many applications (on so many different
types of machinery) that there's bound to be a shop in your area
specializing in them. Go, seek and thou shall find!
Good luck!
Gunnar
Date: Thu, 17 Oct 1996 20:01:11 -0400 (EDT)
Brian: Bull Shit, excuse my language, but that's how your message struck
me. Unless you destroyed the shaft, these are the part numbers you will
need taken right from Jaguar parts catalogue No. RTC9888CE dated Aug
1987 page number 1F 08R. "O" ring pn RTC 1340 RTC 1348 Collapsible
bearing(crush sleeve here in the USA) RTC 1347 bearings you need TWO (2)
of these. Total cost here in the states around $40. Wish I could get them
to you. By the way if you can find any Jag from around 80 up to 87 you
can get the output shaft from it and you would be in business.
Chad Bolles Jaguar South 306 Valcour Rd Columbia SC 29212 USA 803 798 3044On
Date: Thu, 17 Oct 1996 20:42:59 -0400
Ashly:
Go for it, I wanted a Jag when I was 16 years old. Finally got one at 43.
Worked like a dog for 25 years to get it, and still have to put up with some
moron coming up to me and telling me "must be nice". Don't do as I did and
waste the most fun years of your life wondering what the neighbors, or your
friends, or your creditors think. Enjoy your dream today because tomorrow
may, as the old saying goes, never come.
Rick Castonguay, 90 sovereign
Date: Thu, 17 Oct 1996 20:51:59 -0400 (EDT)
> Hello everyone...
> one.
You're 25 and driving a Jag around town. You're concerned that people
might think your parents gave it to you or buy expensive stuff for you.
I am 21, run my own internet business, which is profitable (but not
enough to warrant a new jag), and work 70 hours a week. People dont throw
bricks or kick cars. The cars are rare in our parts. One jag per couple
hundred mercedes or bmw's. People who have jags, mercedes, or a vet in
our area work hard. I've never been to England.
For less than the price of a ford excort (or any other practical budget
vehicle which is not compelling) , I got my 89xjs v-12 a few months ago.
(bright red) It rides nice, it feels nice inside, and turns a lot of
heads. Quite reason enough, even without the head turning.
- -Jason
Date: 18 Oct 96 10:52:19
Subject: Re: XJ-S EFI Rebuild
Great minds think alike, Aaron. I did the same modification three years ago on
my XJ12L, for the same reasons, and haven't looked back since. There's a
general rule about rewiring a Lucas system: if you put the wiring out where you
can easily work on it, _it_will_never_give_trouble_.
:3+)
- -Jan
Date: 18 Oct 96 10:57:16
Subject: Re: XJ-S
I strongly recommend the 12 if you do your own maintenance. If you don't, it
gives unscrupulous workshops an excuse to rip you off even worse than usual
because it's such an exotic-seeming thing. In reality, it's quite agricultural,
there are just twice as many bits jammed into the same space. But oh, that
smoothness and aah, that torque...
- -Jan
77 XJ12C
78 XJ12L
Date: Thu, 17 Oct 1996 20:22:56 -0600
Subject: Re: XJS Output Shafts-REPLY
(snip)
Chad,
Actually the bearings/seals are available but not as you mentioned...notice
Brian says DANA unit. Dana unit part numbers are JLM292 O Ring, JLM290
Bearing, or JLM313 assy..which is also available remanufactured now. I have
forwarded prices to Brian of the repair parts needed. If he can't get them
in SA, I can sure ship them to him. Refer to parts catalog RTC9888CE...1F 09L.
Hal
Hal Rogers
H.D. Rogers & Sons
Import Auto Specialists
3418 Barksdale Blvd.
Bossier City LA 71112
(318) 742-3651 voice
(318) 742-5044 fax
Serving Auto Enthusiasts since 1959
Date: Thu, 17 Oct 1996 20:30:33 -0600
>> d*&^% thing
Now isn't that just the plain truth...seems to be a worldwide problem!
Well I don't know about 50! (I'm only 32 myself) But I did grow up into the
business too!
Keep up the humor and the good advice!
Hal Rogers
Hal Rogers
H.D. Rogers & Sons
(318) 742-5044 fax
Date: 18 Oct 96 11:26:57
John Napoli <snip>: But I am curious as to the intent of the design.
Have you got an Ouija board...?
Frankly, I think the word "design" is not le mot juste!
:3+)
- -Jan
Date: Thu, 17 Oct 1996 21:04:59 +0000
Subject: Positive Ground to Negative Ground Conversion
Can anyone tell me what is involved in converting from positive ground
to negative ground on a MKII Jaguar(Daimler 2.5)? Is it worth it? The
only reason I want to convert is so I can put a radio in the car. The
previous owner said the radio he gave me which was out of the dash and
on the floor,was the original radio. That radio doesn't fit into the
opening for the radio below the dash and I had it tested out and find
out it's negative ground! The car is definetly positive ground. Either
I search for an originalAM/FM positive ground radio(lots of luck!) or
I convert to negative ground.
All help in either converting polarity or finding a positive ground
AM/FM radio would be appreciated.
Lenny Seidman
Elkins Park, Pennsylvania, USA
email: lseidman@erols.com
Date: Thu, 17 Oct 1996 22:12:57 -0400
Subject: Need Help for 89 XJ40
My name is Ray and I live near Dallas Texas , in the USA. I own a 1989
XJ40 Vanden Plas that I purchased in 1992, It now has about 65,000 miles on
it, but remains in excellent shape. As time goes by I get to learn more and
more about it. I learned through problems about rear struts, accumulators,
seat belt retractors, crank shaft sensors, temperature sensors, etc., etc. I
try to do as much of my own work on it as possible. I purchased a set of Jag
service manuals which usually are of little help.
I currently have several problems I am working on and need help.
1. My low brake pressure light stays on for about 15 to 20 seconds after I
start driving. A Jag mechanic ( originally from Scotland) said I should
turn the car off once the light has gone off and then turn the key to the on
position and press the brake whatever number of times it takes to get the low
pressure light to go on. If it goes on after the pedal is pushed down 4 or
fewer times a new accumulator is needed. My light goes on after I have
pressed the brake 4 or 5 times, which seems like a marginal situation. If
the current situation is not a hazard I can live with it. Last year I was
told by a Jag dealer that I needed a new hydraboost pump ($1200) to solve
the probblem, and I told them I wasn't interested. The accumulator was
replaced on the car about 3 years ago. Any recommendations?
2. My right front wheel has very slight movement in the vertical plane but
not in the horizontal plane. Adjusting the wheel bearing tightness didn't
help. A Jag mechanic said I might need a new wheel bearing assembly even
though I only had movement in one direction. I seemed to me it was some
other suspension problem, but I changed out the wheel bearings anyway. It
didn't help. I still have a little play. What's the next step?
3. After changing the wheel bearing my anti-lock system warning light now
goes on. It does't go on until the low speed test is run. I had difficulty
removing the bearing grease seal from the spindle and removed it by prying
off the disc shield. I am afraid that I may have somehow damaged the
anti-lock sensor on the wheel. Help!!!!
Date: Thu, 17 Oct 96 19:31 PDT
Subject: Leaper
Greetings All,
MI>Leapers, an additional one i noticed in JC Whitney magazine;
MI> Whitney has one (big one I think) for US $29.95 plus shipping. Has anyone
MI>tried one of these? Does anyone know if they are the same as the dealers?
I bought a large leaper from the JC Whitney catalogue; it is quite a
good reproduction.
With drill in hand I could not bring myself to drill the holes in the
hood of my Jag. I had my neighbour mount the leaper on a block of
mahoghany and it now makes a nice addition to the decor of my computer
room.
Dennis Smith
� OLX 2.2 � Amish Buggy Sticker: Caution: Do Not Step In Exhaust.
Date: 18 Oct 96 13:12:20
Subject: Re: intro (New person) XJS
Hi Veronica!
The sheer silence of the Jaguar makes you notice things that simply won't be
heard in ordinary vehicles. I was going crazy (-ier?) for a while last year
over a clear Click! that appeared after I turned the wheel about 1/4 turn
right, but not to the left. I suspected something minor with the steering
column, but found nothing - until I went to get a toll coin out of the ashtray
and noticed that a small self-tapping screw was lying next to the only coin.
After I took the coin out, the click appeared on both sides. Yes, it was the
tiny screw rolling up against the side of the ashtray...
If the clicking seems to track your speed regardless of gear (leave the T-bar
in "1" to check), it's probably something to do with the wheel. If so, and you
have steel rims, take the wheel off and put the spare on; see if the noise goes
away. If it does, the noise could be generated by a crack in the rim just
outside the lug nuts. I had this sort of regular clicking on a Saab many years
ago, but ignored it - until the wheel rolled away in front of me with a big
hole in the middle...
Another expensive possibility is a cracked roller in the wheel bearing. You can
check this by jacking up that corner and spinning the wheel by hand; a cracked
or broken roller would be heard/felt quite clearly.
Let's hope it's just something silly, like an incidental twig stuck in one of
the holes of the wheel and hitting the suspension! That's another thing you'll
find if you take the wheel off and have a good look.
- -Jan
Date: 18 Oct 96 13:25:35 EDT
Subject: Re: Black Saturday Relived
The first thing to do, Frank, is to take the car to another workshop. If you
had indeed had a "thrown rod" there would be a great hole in the side of the
crankcase, there would be a frighteningly loud hammering noise as soon as the
engine fires and it would be running on 11 cylinders or less.
The overheating and starting difficulty indicate that you have a blown
headgasket, which is still non-trivial but easily repairable. By an honest
workshop, that is... Taking it to a junkyard is ludicrous. A tapping noise that
gets louder as the engine warms up could be from a damaged valve seat, too.
The belt slipping noise and momentary slow-down does indicate a problem with
the water pump - although it wouldn't be something I've experienced; water pump
trouble tends to manifest itself first by simple leakage.
- -Jan
End of jag-lovers-digest V2 #448
id <RAA16442> for jag-lovers-digest-out; Fri, 18 Oct 1996 17:38:49 +0200 (MET DST)
Date: Fri, 18 Oct 1996 17:38:49 +0200 (MET DST)
Message-Id: <199610181538.RAA16442@ekeberg.sn.no>
Subject: jag-lovers-digest V2 #449
Precedence: bulk
jag-lovers-digest Friday, 18 October 1996 Volume 02 : Number 449
Re: Fuel tank sender unit SII XJ6
Re: Need Help for 89 XJ40
re:dead pedal for XJ-S
Re: Attitude
Re: Lurking
Re: XK150 colour
Message for David Shield
E-type saga continued -- disaster!
Coolant Inhibiter
Trip Down Under (no Jag content)
wired bolts
Re: Positive Ground to Negative Ground Conversion
Re: Another E strangeness, Help!
Re[2]: [General] The rec.autos.makers.jaguar newsgroup faile
Luminition Ignition
Re[2]: JCNA Judging
still leaking XJ-S/ BATHTUB
Date: 18 Oct 96 13:29:36
Subject: Re: Fuel tank sender unit SII XJ6
Curt, I think you have some wiring trouble between the switch and the gauge;
it's most unlikely that both sender units would fall over at the same time. It
could of course be a faulty switch or gauge, too, but my money is on a Lucas
connector that's losing its grip... As far as I know (haven't got the book with
me) you can replace a sender unit after draining most of the tank. They're
located behind a sheet metal cover inside each wheel well, above the mud flap.
- -Jan
Date: 18 Oct 96 13:42:09
Subject: Re: Need Help for 89 XJ40
Anonymous <snip>: 2. My right front wheel has very slight movement in the
vertical plane but
Sounds like an upper or lower ball joint. Close your hand around the joint
while somebody rocks the wheel; you'll easily feel any looseness.
If you can jack the car up with a garage jack under the lower A-arm on the
outside part of the cup the spring sits in, you'll unload the suspension
joints. You can now check the inner bearings on the upper A-arm as well as the
ball joints - same method as before.
The mechanic could also be right; the disk brake can easily mask wheel bearing
slack in the horizontal plane. The way to check this out is to take the wheel
off and use a screw driver to back the brake pads off slightly (not too much;
if your brake fluid container is full you could make it run over. Guess how I
learned this).
- -Jan
Date: Thu, 17 Oct 1996 23:49:00 -0400
Subject: re:dead pedal for XJ-S
In message "jag-lovers-digest V2 #447", David Engelbach writes:
Ditto for an '87 XJ12 VDP.
This gives me a chance to boast/rejoice in public: I bought a VDP. Took a year
of looking + lotsa homework + stone luck. Guess which of the three is most
important? 8->
FWIW: 1987 Vandenplas
88,900 km (when bought. 89300 reached in a week. Where DOES the time go?)
Grey with grey interior
Still needs: Front valance (tin worm)
Remove smile from left front fender beside the
valance (more tin worm)
Remove minor bubbles elswhere (tin worm eggs?)
Get the rear windows, sunroof and front passenger door
lock working (tin worm droppings no doubt)
Get the fuel coming from one tank at a time (Friday -
the car is needed for a Xmas present run to Syracuse)
Get the coolant temperature up. Yes, UP. Thing runs
at 65 C. That can't be right. Does disastrous things
to the idle (ever talked to a Customs agent while your
car sat and blipped the engine instead of idling? Not
a good idea. Especially at Cornwall ON) To be fixed
Friday.
PO was a little old lady in FL. True story: one of my neighbours
owns a barber-shop and one of his customers is the LOLs grandson.
Bunch of snow-birds if you ask me! What's neat (to me) is how small
this makes the world look. Doesn't hold a patch on Kirby's manual or
Buja's stories, but ya gotta start somewhere.
Best first day story: took my wife and one of her friends for a ride
the first night I had the car. Took the car out on a freeway to
show off. Pressed the pedal and waited (like in my '88 Lancer).
Hmm - wheels need balancing. Ohh - that traffic's going slowly.
Yike - I'm doing 145 kph in a 100 kph zone in about the time my
Lancer would get to 90. And no fuss, no muss, just smooooth going
(the wheels get done on Friday!)
Babbling - Albert Cohoe
1987 XJ12 (I finally know what it's like to say that!)
Voice: 393-3440 or 613-763-3440 Email: cohoe@nortel.ca
Date: Fri, 18 Oct 1996 01:00:55 -0005
Subject: Re: Attitude
john_setters@eagle.co.nz:
> one of our main
> shoppers around)
> foot.
> kicked the door
While my wife and I were getting something out of the trunk in a
parking lot, some guy driving by tossed a lit cigarette into the
trunk.
I have also had quite a few people in front of me on the road
suddenly jam on the brakes, apparently hoping I would rear-end them.
Fortunately, the XJ-S has excellent brakes!
-- Kirbert | If anything is to be accomplished,
| some rules must be broken.
| - Palm's Postulate
From: rrichardson@eurekanet.com (Robert J. Richardson)
Date: Fri, 18 Oct 1996 01:06:11 -0500
>Ashly:
>Regards,
I bought my first Jag less than a year after graduating from Ohio
University. I was in the Public Relations Dept. of Packard Electric, a
division of General Motors. I was making a grand total of $100 a week (this
was in 1956) and I spotted a 1953 XK-120M Drophead Coupe sitting in the
showroom of Warren's Jag dealer. I sold my 1955 Chevy within a week (at a
terrific loss) and had myself the car I'd longed for since its
introduction. I parked it in the staff parking lot at Packard and received
a note that evening from the general manager telling me to park it in the
hourly worker's parking lot. I took the hint and a couple of years later
went for a job with Esso in Aruba where the Jag was more than welcome. I
had to wait 12 years to get my next Jag, a 1964 E-Type FHC, that turned
more than a few heads in the college town of Athens, Ohio, where my next
job took me. I still have the E-Type and a few treasured photos of that
glorious XK-120M. Go for it!
Date: Sun, 13 Oct 1996 15:55:50 +1000
Subject: Re: XK150 colour
RKPUTTY@MAIL.EISA.NET.AU
I am nearly at the painting stage for an XK150 FHC and face the same
dilema. A lot of XKs here in Australia seem (rash generalisation but what
the heck) to be coming out in a maroon colour that looks terrific, with
biscuit interior. We are hovering around the idea of BRG and biscuit or
Navy Blue and biscuit, We (or should I say my colour expert,.... her
indoors) also liked the idea of the Ecurie Eccose metallic blue, again
with biscuit inside. Has anyone seen a 150 FHC in this scheme? Noting the
additional cost of a metalic paint we will probably go for a solid colour
to keep the rapidly rising (groan, but no doubt familiar) costs down.
Aside from all the obvious about increased horsepower etc, has anyone got
any other ideas about colours that work together for XK150s, given that
fashions come and go, like the grey that a lot of the cars seemed to have
when new.
Roger Puttman
1957 XK 150 834019
1955 MG ZA Magnette (Who knows what that is?!)
> I am open for arguments on this colour combination.
> Your Mate from New Zealand
> Alex Beacham
Date: Fri, 18 Oct 1996 05:30:49 EDT
Subject: Message for David Shield
Sorry about this but I could not get E-mail through to david with Address
he left me.
Thanks for the info, I will take any numbers you have for vendors in the
UK as well as the part numbers for the parts. My uncle happens to live
in england and maybe he can help me find these parts. One more thing, do
you happen to remember the prices that you paid for these parts.
Thanks Again Bill Kroeger
Bill and Lori Kroeger
St Paul MN,
1985 Blk XJ6
E-Mail ( blkcat@juno.com )
Date: Fri, 18 Oct 96 11:10:29 +0100
Subject: E-type saga continued -- disaster!
Dear All,
Well some of you may remember a couple of weeks ago I introduced
myself with a story about my saga with the purchase of an early
E-type. Boy, is this turning into a saga! I was supposed to be
going down to complete the transaction this weekend, as the owner
had apparently had the major problems fixed: replacing steering
rack, and tightening tensioner to timing chain to reduce play
in cam. He then had the car MOT'd (i.e. road worthiness test)
and tuned.
Anyhow, yesterday he took the afternoon off to go for one last
trip in it with his girlfriend and, you guessed it, a problem!
Apparently, whils't travelling about 60mph the car starting
jumping or runing rough, then it was followed by a rather loud
bang. He pulled over and stopped to have a look, but after
not finding anything obviously wrong (he pulled plugs -- that sort
of stuff) he started the car again, but the `terrible' (?)
noise the engine had been making was still there. He then
got a someone to trailer it back to his house so they could have
a look at it. His friend thought it might be something to do
with the cam. (Coincidentally (?) he noticed the speedo had stopped
working as well??)
Well, I am obviously sad and a little worried about these
developments, but I must say also rather relieved it didn't
happen after I'd handed over the money. My plea to those of you
who would be brave enough to venture an opinion, given the perhaps
rather subjective and potentially inaccurate description of events,
is: what could have gone wrong; how serious is it; any advice
for further action?
Oh dear :-(
David White
(Up to now a potential owner of '61 FHC E-type)
P.S. Lloyd I think you are correct. All Series III's were 2+2 FHC's.
There were no 2-seaters in Series III (except the OTS) so maybe they
just called them FHC's?
Date: Fri, 18 Oct 1996 19:46:54 +0930
Subject: Coolant Inhibiter
Any suggestions please on what is the best type of coolant inhibiter to put
in a XJS system as I have just had to replace the heads due to corrosion,
the car was running great no signs of a problem with corrosion only a loud
tappet noise that once the heads were removed revealed the problem.
John.
Date: Fri, 18 Oct 1996 06:53:44 -0400 (EDT)
Subject: Trip Down Under (no Jag content)
Thanks to all who replied to my previous post regarding travelling in the
Antipodes. We will be in touch again as our plans firm up. Iris has one more
question: she is interested in knitting, and wants to know if there are any
interesting stops related to sweaters, wool, or knitting events.
Mike & Iris Frank
Date: Fri, 18 Oct 1996 09:10:10 -0400
Subject: wired bolts
In a message dated 96-10-17 13:09:01 EDT, appraise@i2020.net (Tom Murray)
writes:
<< I did not replace the lock wire on mine. I would have, if I had one.
It >>
Just an anecdote for the list.
When rebuilt my rear end ('87 XJS) the only thing holding the bolts in the
diff was the locking wire. Without the wire the bolts would have jumped
ship. From then on I became a believer in lock wire. The wire is soft
stainless from the hardware store, the special pliers to twist it are
available from race shops or any aircraft mechanics supply. Also there is a
right way and wrong way to do it. My guess is the wire is there for a
reason. As it's expensive to do on a factory line, they must have had a good
reason to put it there in the first place.
Julian Mullaney
Date: Fri, 18 Oct 96 08:20:01 CST
Subject: Re: Positive Ground to Negative Ground Conversion
I've done it on an E and the only thing I had to do was reverse the
polarity of the amp gauge and, I think, a few other gauges. The
generator needs to be re-polorized by reversing the procedure in the
book before installation according to experts, but I didn't do this
(probably because I think its BS that a core group of wires won't
behave predictably once the voltage is applied to the field in either
direction). All of the electrical motors in the car will turn in the
right direction, as they are DC brush-type motors in which the field
and armature are polorized together.
Was it worth doing? Probably not. Devices to accomplish the same are
available from suppliers within Hemmings. Going to negative ground
really doesn't accomplish anything for the car itself.
Steve
______________________________ Reply Separator _________________________________
Author: lseidman@erols.com at smtplink-tellabs
Date: 10/17/96 10:25 PM
Lenny Seidman
Date: Fri, 18 Oct 96 08:26:52 CST
Subject: Re: Another E strangeness, Help!
.012 and .014 are for the newer cam profiles and .004 and .006 are for the
older cam profiles. It would make sense that the 1970 have the older cam
profile clearances, while yours has the newer.
You can verify this in the service manual. I would stamp the *correct*
numbers on the plate in any event.
Steve
Author: LLoyd <3030P@vm1.cc.nps.navy.mil> at smtplink-tellabs
Date: 10/17/96 8:38 AM
Date: Fri, 18 Oct 96 08:32:38 CST
Subject: Re[2]: [General] The rec.autos.makers.jaguar newsgroup faile
Having just returned to my office after five days, I would also support the
the idea of this being on a newsgroup. I'm sure my mail server didn't like
the fact that their were 425 messages on it. I can also filter through a
newsgroup faster in Netscape.
Unfortunately, I also agree that most newsgroups attract ALOT of garbage.
Antique.autos is a good case in point. They get spammed all the time.
How about a controlled newsgroup, like this mailing list?
Steve
Subject: Re: [General] The rec.autos.makers.jaguar newsgroup failed
Author: southern@sol.cgd.ucar.EDU (Lawrence Buja) at smtplink-tellabs
Date: 10/17/96 11:32 AM
Cosmo adds...
{fest.
Date: Fri, 18 Oct 1996 09:50:13, -0500
Subject: Luminition Ignition
While I have no personal experience with this brand, I have very
positive experiences with electronic ignition conversions. I
installed an Allison (CraneCams) Ignition conversion on my TR-6 five
years ago and it has performed perfectly ever since. No points to
adjust an it never goes out of tune. I believe that the Luminition
system is very similar to Crane's.
- -MF
Date: Fri, 18 Oct 96 09:37:10 CST
Subject: Re[2]: JCNA Judging
Chip,
I think we would agree here, in that points are neither deducted nor
preference given to the highly polished Jaguar.
Unfortunately, the over-polished Jaguar creates a techinical mistake for
those viewers who are trying to determine what a *real* copy looks like.
For example, not long ago I was coaxed by my judging peers into overlooking
the fact that the SU carb body's were highly polished, removing that
original casted look. Great, except now we've got everybody thinking that
this is okay, destroying their original finished SUs in the process.
Doesn't seem to be a good plan to me. Same goes for the brushed aluminium
finish of the coils that can be polished to look like chrome. Looks good,
but still not original.
Although I personally would rather view a non-restored original than an
over-restored or restored car, I can certainly understand that duplicating
the sloppiness of mass production is somewhat criminal in the act of
restoration.
At best it seems that we overlook attempts at over cleaning or polishing,
but deduct for incorrect finishes (chrome vs. cad) and leave it at that. If
we change the rules now, we will cause quite a stir (it probably wouldn't
pass the AGM). This way, the person that manages to get the cam covers to
that just-cast look doesn't fair any worse than the one who pays $100 to
over polish his or hers.
Steve
Subject: Re: JCNA Judging
Author: Chip Weems <weems@cs.umass.edu> at smtplink-tellabs
Date: 10/15/96 11:47 PM
At 2:37 AM -0500 10/12/96, Mike Cogswell wrote:
>Mark: Thanks for the thoughtful reply, although I think I'm a bit more
>puzzled then a was a while ago. I got another reply from Chip Weems that
>differs, significantly I think, from yours. Hopefully, you will have read
>and replied to each other. I'm just gonna sit quietly and see if more
>judges join the discussion.
>MikeC
>Subject: JCNA Judging
>Author: "mark (m.d.) roberts" <markdr@nortel.ca> at Internet
>Date: 10/10/1996 6:05 PM
>Okay, I'll bite :-). I'm the Chief Judge for our local JCNA Jag club.....
>having said that I too struggle with the original vs over-restored car.
>I like to think that I instill in the other judges that we are looking for
>"authenticity" not perfection. A 100.00 pt. car should be one that is as it
>should have left the factory, with no defects that would have been noticed by
>the those on the factory floor....if they had had the time to actually go
>over
>every car inch-by-inch (cm-by-cm). A car that has the heater box so shiny
>you
>can see yourself in it is, IMHO, a bit too far in the perfection
>direction, but
>it should not score anymore points than one which is original
><big snip>
Mike,
I don't think Mark and I really disagree here. If I see a car that is
clean and free of oxidation/corrosion under the bonnet, I won't deduct points
because it isn't polished to a mirror finish. It won't score any lower
than the car that is so polished. However, I can't see penalizing people
for "over preparing" a Jaguar. After all, it is a high performance luxury
car whose owners are justifiably proud to show it off -- it ain't a Model A
Ford (even if the marque is now owned by the same company).
I've been to Model A shows, and to be honest, I can see why they do
deduct points for over preparation. There is something out of place
about a highly detailed engine compartment in a humble Model A body.
But a Jaguar engine can be so gorgeous in under the bonnet of an
equally gorgeous Jaguar body that the two seem to go together quite
well. I understand what makes people want to do this, even if it
doesn't get them any more points in concours.
Chip
Date: Fri, 18 Oct 1996 08:42:06 -0700
Subject: still leaking XJ-S/ BATHTUB
This is the next part in a continuing series on my still leaking '85
XJ-S. I realize that "leaking" can describe many types of XJ-S problems
involving many different types of fluid, so please allow me to clarify:
I live in Seattle, Washington and, whenever it rains (which is very
often!), my car leaks rainwater onto the driver's (my) legs -- and I
don't mean just a little.
I have tried the following to fix the problem:
1) Used flowable silicon to re-seal the windshield seal were the rubber
meets the glass -- it all looks very watertight now.
2) Used flowable silicon between the windshield seal and door posts on
both driver's and passenger's sides (I removed the chrome door post
cover first).
3) Cleaned the drains leading from the cavity in which the wiper motor
is mounted to both front wheel wells.
4) Used silicon (both flowable and standard -- I'm living on the edge
here!) to seal the drainage channel that leads from the lower driver's
side corner of the windshield (below the seam between the front
quarter-panel and the rear hood area) and into the recessed channels in
which the hood mounts. I sealed this at both top (windshield side) and
bottom (hood side).
AND STILL, WATER BUCKS INTO MY CAR!
I have no other ideas and I've run totally out of silicon.
Please help!!
Aaron (how many gallons do you think that is?) Burnett
'85 XJ-S
End of jag-lovers-digest V2 #449
id <BAA13593> for jag-lovers-digest-out; Sat, 19 Oct 1996 01:39:47 +0200 (MET DST)
Date: Sat, 19 Oct 1996 01:39:47 +0200 (MET DST)
Message-Id: <199610182339.BAA13593@ekeberg.sn.no>
Subject: jag-lovers-digest V2 #450
Precedence: bulk
jag-lovers-digest Saturday, 19 October 1996 Volume 02 : Number 450
FW: still leaking XJ-S/ BATHTUB
Re[2]: Concours Judging
SIII beautification
Re: still leaking XJ-S/ BATHTUB
Re: Leaper
Re: E-type saga continued -- disaster!
Re: Attitude
Re: Lighthearted Question, MCC*
XK8 Road Test
front wheel brg
battery polarity
Re[2]: Funny car story (no Jaguar content)
Re: E series II dates
Date: Fri, 18 Oct 1996 08:53:06 -0700
Subject: FW: still leaking XJ-S/ BATHTUB
I should have added another detail to this account. My car was hit in
the driver's side about two months ago. The door was replaced and the
driver's side front quarter panel was pulled back into shape. All new
seals were installed. Perhaps there are seams I should be looking at?
Thanks again,
Aaron
'85 XJ-S
>From: Aaron Burnett
>Sent: Friday, October 18, 1996 8:42 AM
>To: 'jag-lovers@sn.no'
>This is the next part in a continuing series on my still leaking '85 XJ-S. I
>realize that "leaking" can describe many types of XJ-S problems involving
>I live in Seattle, Washington and, whenever it rains (which is very often!),
>my car leaks rainwater onto the driver's (my) legs -- and I don't mean just a
>little.
>2) Used flowable silicon between the windshield seal and door posts on both
>driver's and passenger's sides (I removed the chrome door post cover first).
>3) Cleaned the drains leading from the cavity in which the wiper motor is
>4) Used silicon (both flowable and standard -- I'm living on the edge here!)
>to seal the drainage channel that leads from the lower driver's side corner
>of the windshield (below the seam between the front quarter-panel and the
>rear hood area) and into the recessed channels in which the hood mounts. I
>sealed this at both top (windshield side) and bottom (hood side).
>Please help!!
>'85 XJ-S
Date: Fri, 18 Oct 96 10:30:47 CST
Subject: Re[2]: Concours Judging
There was apparently a change in rack pinion tooth design around the
time the C41 (SP41) was introduced in 1967/68. This was done to
accomodate the larger contact patch of a radial and improve steering
ease. Unfortunately, I have only seen this mentioned in Skilleter's
early E-Type book as a production change (sorry Paul, If I mispelled
your name).
I put steel belted Michs on my 1963 and didn't like the more difficult
steering or the feel of increased unsprung weight. Heavier torsion
bars could have improved the latter, but a change in rack gearing
would have been needed for the former.
Steve
Subject: Re: Concours Judging
Author: "Mark McChesney" <mmcchesn@ford.com> at smtplink-tellabs
Date: 10/12/96 1:16 PM
> Ryan Border <rborder@hpspls16.cup.hp.com> wrote:
> The S1 E-type presents an interesting transition period. Later E-types
> were definitely designed to take radials. The S1 wasn't but people
> seem undecided as to whether the front end is harmed by their use.
I know of NO changes in suspension from S1 to S2 E-types (yes,brakes were
changed). Does anyone else know of any? There was an anti-dive geometry and
track width change (ok and power steering) w/ the S3 but they still had the
same type bushes. Oddly, Gran Turismo says that the S3 had an inferior camber
curve to the S1/S2.
Mark McChesney
'65 Etype ots
Date: Fri, 18 Oct 96 09:02:00 PDT
Subject: SIII beautification
In the never ending quest to turn my car into the ultimate Series III
xj6 (within the limits of authentic "Jaguarness"), I am embarking on
anoth minor project. Last week I saw a Swiss market Sovereign with
a Biscuit interior, the same as mine, but the front kick panels were
carpeted, while mine are covered in Biscuit Vinyl. They looked much
better. So, having obtained some original xj6 carpeting from a
wrecker, I will now glue the carpet (minus the padded backing) directly
on the existing kick panel, leaving a bound edge at the floor, and
possibly up the door edge. If any one has a car with the carpeted panel,
would you be good enough to check whether the binding goes up the
edge (beside the furflex)? I know that it is supposed to run along the
bottom. Are there any precautions for removing the kickpanel? Any comments
or help, VERY welcome. Gregory Andrachuk, 82 xj6
Date: Fri, 18 Oct 1996 12:35:02 -0600 (MDT)
Subject: Re: still leaking XJ-S/ BATHTUB
{my still leaking '85 XJ-S. I
How about the the wiper shaft seals?
Something you could try is to induce the leak under controlled
conditions by having an assistent systematically run water from a hose
over various parts of exterior of the car while you remain inside
looking for any water coming into the cabin.
/\ Lawrence Buja http://www.cgd.ucar.edu/cms/southern/
\_][ southern@ncar.ucar.edu National Center for Atmospheric Research
\_________________________Boulder,_Colorado___80307-3000__________
Date: Fri, 18 Oct 1996 12:03:03 -0700
Subject: Re: Leaper
At 07:31 PM 10/17/96 PDT, you wrote:
>Greetings All,
>MI> Whitney has one (big one I think) for US $29.95 plus shipping. Has=
anyone
>MI>tried one of these? Does anyone know if they are the same as the=
dealers?
>good reproduction.
>room.
>Dennis Smith
> =FE OLX 2.2 =FE Amish Buggy Sticker: Caution: Do Not Step In Exhaust.
> =20
I bought the LARGE leaper from the Jaguar Dealer. It was so beautiful,
not to mention very heavy (solid metal), that I could not bare NOT to put it
on my bonnet. Also, the PO had a leaper installed which was removed and the
bonnet repainted. SO, I had the holes their already under the plastic work,
that it was easily mounted in the old holes.
That large leaper is very heavy (I thought the bonnet might dent
itself!), and its teeth are also very sharp, which is a nice touch. It
looks gorgeous on the car, however if someone is worried about it being
stolen I would buy the small leaper because it looks like it would do less
damage if ripped off the car. IMHO I think the factory leaper is very
nicely made and worth the $100 as a decorative piece.
Eric
cobac@ix.netcom.com
'89 XJ40-VDP
Date: Fri, 18 Oct 1996 17:17:18 -0500
Converting to negative ground is very easy, and alows you to run all sorts
of modern electronic equipment(alternator, electronic distributor, etc.) I
believe the only items on a MKII that are affected are:
1. coil - will work reversed, but not as well
2. ammeter - switch leads
3. water temp, oil, and fuel gauges - switch leads(not sure about fuel, I
think you need to switch)
4. clock - usually does not work anyway
5. fuel pump, depending on type of pump - I have an aftermarket fuel pump
that is positive ground, it's possible to switch the diodes in the old ones
around, but I don't know the details
I believe this is everything, if nothing goes drastically wrong it should
take less than an hour to do. It is actually possible to run a negative
ground radio in a positive ground car, I did it for 2 years. You need to
isolate the chassis of the radio from the body and run the ground wire to a
positive terminal and the power wires to ground. This is a bit dangerous,
since if the body of the radio is grounded, it will short. However, if
you're careful it will work. If you want more details of my installation,
let me know. Hope this helps,
Braman
Date: Fri, 18 Oct 1996 17:33:57 -0400
Subject: Re: E-type saga continued -- disaster!
My guess is the timing chain was too tight or otherwise affected by the
adjustment.
How about collecting the guesses and let's see how many people get it
close or correct. This could be a new source of entertainment for the
list readers. The unfortunate one explains the problem with all known
details and facts. then list readers get to guess. the problem gets
fixed and we all get to participate.
Ivan The meek shall inherit the earth
http://users.visi.net/~isk00/ The rest of us will head for the stars
Date: Fri, 18 Oct 1996 17:37:53 -0500
>> one of our main
>> shoppers around)
>> foot.
>> kicked the door
>trunk.
> | - Palm's Postulate
I had a shopping cart deliberately shoved into the right front fender of
my E-Type. A Big Bear employe saw the incident. It was no accident. The
repair cost me $275 and more than a little abit of aggravation. I've had at
least five "nose" jobs while being parallel parked. Only one driver fessed
up and gave me the name of his insurance company. He complained, "That darn
thing sits so low, I didn't see it when I backed in." I asked, "What if it
had been a lady pushing a baby carriage?"
Date: Fri, 18 Oct 1996 17:47:40 -0400 (EDT)
Subject: Re: Lighthearted Question, MCC*
Pull the instrument console -- it comes right out from the front, and you
don't have to pull the steering wheel. THere are several screws that hold
fascia in place around the instrument pod, then remove the little plastic
caps and you'll have access to the rest of the screws that hold it in.
Pull the two plugs and disconnect speedo cale and it's out.
Now take it all apart and clean off the accumulated dust. Replace any
burnt-out bulbs. I also removed the little green lenses and this
brightened things considerably. There is provision on the white plastic
casting for a second speedo bulb, bbut the respective spot on the side
with the tach has one of the plugs in that spot. So factory went with
symmetry and has only one bulb each for these two large gauges. You
should be able to add a second bulb to each with a little ingenuity.
John
Date: Fri, 18 Oct 1996 17:56:43 -0400 (EDT)
Yes, the designers too seem to take the long way around the block...
John
Date: Fri, 18 Oct 1996 18:22:03 -0400 (EDT)
Subject: XK8 Road Test
My local Jag dealer ran a 'Customer Appreciation Day' today. THis means
that you bring in your car, get a free inspection by 'official factory
representatives', a free wash, and a chance to hang out in the showroom.
I was hoping that the factory folks would be able to answer questions I
had about some odds and ends on my XJ-S. This was the one sour note --
these guys just basically walk around in their green lab coats with
v-e-r-y serious expressions on their faces. Oh, well.
THe inspection was conducted by a senior tech, who was training a young
'mechanic' who was as green as the factory guys coats. How green? He
had never opened the hood of an XJ-S. Oh, well.
THe inspection went ok. Some of it was pure BS (my battery passed because
it was clean) but they were thorough overall. THe good news is that they
didn't find anything I didn't already know about.
Anyway -- during my requisite time in the showroom, I started talking with
the salesman who had recently sold my friend a new Porsche (some German
car, I think). He spends some time showing off the XK8s, and asks if I
wanted to go for a drive.
Well, this fellow is about the best salesman I've ever come across! He
encouraged me to drive as hard as possible, even taking the car into a
parking lot for some donuts -- full lock, full throttle. Neat.
The XJ8s are great. A very different car than the XJ-S. Very good ride
and handling and feel. Excellent throttle response. Fantastic
transmission calibration (right up to the 7500 rpm redline). Great
brakes. This would be one sweet everyday high performance tourer.
THe motor looks good -- rather, the plastic covers over everything look
good. A splash of chrome on a dashpot, too.
THe one real downer for me was the terribly intrusive console. I am tall
and need to splay my legs outward, even with the seat all the way back.
Head room was ok but not great.
Overall -- a great ride.
John
Date: Sat, 19 Oct 1996 08:48:52 -0700
Subject: front wheel brg
This is a multi-part message in MIME format.
- --------------40CA2BE11608
Content-Type: text/html; charset=us-ascii
Content-Transfer-Encoding: 7bit
Content-Base: "http://www.campaspe.net.au/"
<BASE HREF="http://www.campaspe.net.au/">
<HTML><HEAD><TITLE>Campaspe Internet</TITLE></HEAD>
<BODY background="images/bg.gif" bgcolor="#ffffff" link="#C9211D" vlink="#C9211D">
<center><MAP NAME="ci_buttons"><AREA SHAPE="RECT" COORDS="38,9,115,38" HREF="/About">
<AREA SHAPE="RECT" COORDS="147,6,240,39" HREF="/links">
<AREA SHAPE="RECT" COORDS="264,2,359,40" HREF="/Userpages">
<AREA SHAPE="RECT" COORDS="387,0,530,40" HREF="/Business"></MAP>
<IMG SRC="images/campaspe.jpg" WIDTH=568 HEIGHT=166 border=0 alt="WELCOME TO CAMPASPE INTERNET"><p>
<img src="images/service.gif"><P><IMG SRC="images/Buttons.jpg" WIDTH=568 HEIGHT=41 USEMAP="#ci_buttons" border=0><P>
<a href="mailto://www@mail.campaspe.ne.au"><img src="images/contact.gif" border=0></a><br><p>
<img src="/cgi-bin/Count.cgi?dd=H|comma=T|pad=0|ft=0|tr=T|trgb=00ffff|df=rtc.dat"><br><img src="images/visits.gif">
</center><p><font face="Arial">Campaspe Intenet welcomes you to its NEW Internet
Pages. Our home page might have a few bugs (or undocumented features :) If
you have any problems please mail them to <A HREF="mailto:www@mail.campaspe.net.au">Web Master </A>
<p> If you require any information about this service or you wish to learn more about the Internet and how it operates goto our
<a HREF="/About">Info</a> pages. Campaspe Intenet does its best to bring you closer to the rest of the world wide web by doing a lot of the searching for the best sites for you. Go to our
<a HREF="/links">Links</a> pages to find the hotest sites on the web.
<br>Campaspe Internet beleive that every one should have a chance to say something on the Internet. Check out the Homepages of those that have already had their say from this area in our
<a HREF="/Userpages">Users</a> section. <a HREF="/Business">Business</a> also has an important place on our pages. We encourage business to exploit the world wide web as the altemate advertising medium.<br>
<a href="/About/Anouncements.html">Anouncements</a> on the lattest happenings from Campaspe Internet can be found here.<p>
Good luck and happy surfing</BODY></HTML>
Content-Type: text/plain; charset=us-ascii; name="JAGBRG.TXT"
Content-Disposition: inline; filename="JAGBRG.TXT"
Good day
Reguarding the advice to loctite the front wheel bearing
cone to the axle shaft, have the following points been considered
1 Loctite can have a shear strength of approx 3-5000 psi
so it could take approx 10 tons force to move the bearing.
Think of the problems if you have to replace the bearing or
just remove the bearing hub to service the brakes etc.
2 If the wear is great enough then the loctite will not fill the
gap and would be of little use.
3 Except for some early motor vehicle all bearings fitted to
the non rotating front axle were made, so that the bearing cone
slowly creeped around on the stationary axle, this allowed the life
of the bearing to be greatly increased as the wear and fatigue
is spread over the entire surface and not always in the same spot
Reguards john
- --------------40CA2BE11608--
Date: Sat, 19 Oct 1996 08:50:19 -0700
Subject: battery polarity
- --------------38D0124127B2
Content-Type: text/plain; charset=us-ascii; name="GENPOL.TXT"
Content-Disposition: inline; filename="GENPOL.TXT"
Good day
To change polarity to negative to earth, when a generator is fitted
1 Refit battery with only the earth fitted to the negative battery terminal
then with jumper lead ,for a instant connect the battery positive to
the generator field terminal, this changes the polarity
of the residual magnetism in the generator field
2 Swap the primary leads on the ignition coil, this causes the electrons
(spark) to emmit from the centre electrode. The need to do this
is because it takes about 2-5000 less volts and the engine may misfire
under some conditions if not changed.
3 Connect the power lead to the positive battery terminal
and the jobs done.
Reguards john
- --------------38D0124127B2--
Date: Fri, 18 Oct 1996 19:22:18 -0005
Both sides of the wiper shafts are outdoors. They have little seals
that apparently keep water out of the bearings themselves, but any
water that gets through ends up in the wiper motor compartment, which
is open to rain anyway.
| - Palm's Postulate
Date: Fri, 18 Oct 1996 19:23:39 -0500
Subject: Re[2]: Funny car story (no Jaguar content)
This is a Mime message, which your current mail reader
may not understand. Parts of the message will appear as
text. To process the remainder, you will need to use a Mime
compatible mail reader. Contact your vendor for details.
- --IMA.Boundary.345186548
Content-Type: text/plain; charset=US-ASCII
Content-Description: cc:Mail note part
They aren't *ALL* urban legends. Back when I worked as a mechanic for a
new car dealer we found all manner of things in cars. Three general
categories stood out:
1. Excess fasteners. We found many extra nuts, bolts, screws etc. in the
cars. Often in plain sight, but also under the trunk or floor mats. Every
mechanic in the place kept a box for this, since many were odd/unique trim
fasteners that are almost impossible to find on the open market and
frequently not kept on hand in the dealer parts department. It's been 20
years, but I still have plenty left!
2. Assembly left-overs. I have a very nice air-driven drill and an
air-driven screwdriver, both of which were found in brand new vehicles that
I was preparing for delivery. The screwdriver was inside the passenger
door and made a very large noise whenever I hit a bump as I road tested the
car. My only guess is that they must have been left at the end of a shift
and not noticed by the next worker. We often found various odds and ends
that were used as jigs or holding fixtures during the actual assembly
process. For example, most of these cars used a trunk latch that was
mounted on the inside face of the deck lid and engaged a loop (more like
three sides of a rectangle) that protruded from the bottom center of the
opening. We occasionally found triangular steel plates that had the same
bolt hole spacings as the latch mechanism, but simply had two spring steel
fingers. It was used on the line to hold the deck lid shut by the grip of
the two fingers, but allow the lid to be opened and closed without a key.
3. Trash and sabotage. Yes, we would sometimes find some trash (even the
proverbial coke bottle) closed up inside something like a door. In the
process of trying to resolve a complaint about a long standing, but only
occasional, heavy thud in the front of a top of the line luxury model I
finally found a large cast iron cylinder that had been put between the
inner and outer fenders before they were spot welded together. I gave it
to the factory rep, but none of us ever did figure out was it was.
The trash and sabotage category was very rarely encountered. Usually
around the time of some labor dispute. Tools were even less common.
Virtually every bit of loose, noise making, junk we found fit into the
excess fasteners category. I always assumed they were most likely the
result of someone grabbing a replacement instead of looking around for the
one they dropped.
MikeC
Author: John Napoli <jgn@li.net> at Internet
Date: 10/16/1996 7:21 PM
<snip>
Yes, this is an urban legend. Right up there with Coke bottles in the
door panels
<snip>
John
'82 XJ-S HE
- --IMA.Boundary.345186548--
Date: Fri, 18 Oct 1996 19:39:14 -0400 (EDT)
Subject: Re: E series II dates
Lloyd:
I have checked my entire library in an attempt to identify Series II
production dates and totals. I am giving up trying to make sense of this!
Here is a summary of what I found:
Accoring to Haddock:
RHD LHD RHD LHD RHD LHD
OTS OTS Coupe Coupe 2+2 2+2
Series I;1st 500 91 385 0 20 0 0
Series I,flat floor 357 1581 175 2616 0 0 (includes 1st 500)
Series I, all 3.8 942 6885 942 5871 0 0 (includes flt flr)
Series I, all 4.2 1182 8366 1957 5813 1378 422 (includes I 1/2)
Series II 775 7852 1070 3785 1040 4286
According to Whyte:
OTS FHC 2+2
total (UK) total (uk) total (UK)
1961-4 7820 (760) 7670 (1560) 0 (0)
1965-8 9550 (1050) 7770 (1700) 5600 (1220)
1969-70 8630 ( 690) 4860 ( 910) 5330 ( 870)
1971-5 7990 (1740) 0 (0) 7300 (1830)
33990 (4240) 20300 (4170) 18230 (3920)
Grand total 72520(12330 UK)
According to Jenkinson:
OTS Coupe 2+2
Series 1 3.8 7827 7669 0 3/61-10/64
Series 1 4.2 9548 7770 5598 10/64-9/68
Series II 8627 4855 5326 10/68-9/70
Sereies III 7990 0 7297 4/71-9/73
Grand total 72507
According to Porter:
UK UK UK xport xport xport
OTS Coupe 2+2 OTS Coupe 2+2
Series I (3.8)
1961 257 91 0 1368 297 0
1962 263 833 0 2486 2671 0
1963 111 301 0 1931 1778 0
1964 125 334 0 1274 1362 0
Series I (4.2)
1964 53 108 0 357 358 0
1965 338 895 1 1882 2146 0
1966 225 271 578 2089 1648 2015
1967 236 220 400 2274 1000 902
1968 202 203 246 1892 921 1457
Series II
1968 55 86 81 859 468 556
1969 350 383 490 3867 2011 2765
1970 286 438 299 3191 1454 1134
1971 1 1 0 19 16 0
Series III
1970 0 0 0 0 0 6
1971 169 0 799 144 0 2595
1972 410 0 539 1266 0 1752
1973 872 0 489 2256 0 1118
1974 280 0 0 2582 0 0
1975 4 0 0 2 0 0
******(delivery dates, NOT production dates)
For 1970/71, Porter lists the following production totals:
OTS FHC 2+2
Jan 495 225 225
Feb 554 244 245
Mar 360 174 193
Apr 370 182 204
May 370 182 204
Jun 256 228 66
Jul 560 206 298
Aug 120 58 61
Sep 202 123 58
Oct 180 135 0
Nov 39 81 0
Dec 3 40 87
Jan 71 1 0 272
Feb 71 4 0 403
Mar 71 0 0 262
Apr 71 0 0 264
May 71 0 0 267
Jun 71 18 0 464
Jul 71 3 0 207
Aug 71 64 0 304
Sep 71 56 0 221
Oct 71 63 0 278
Nov 71 39 0 95
Dec 71 92 0 369
Numbers suggest that Series II production continued until Feb 71, at least
for OTS.
Wood reports the following PRODUCTION figures:
UK Export
Ser I 3.8 759 1533 0 7059 6108 0
Ser I 4.2 1057 1698 1212 8494 6073 4374
Ser II
1968 125 147 146 859 468 556
1969 420 386 499 3867 2011 2765
1970 179 412 229 3191 1454 1134
1971 0 0 0 19 16 0
total SII 724 945 874 7936 3949 4455
Ser III
1970 0 0 81 0 0 6
1971 196 0 811 144 0 2595
1972 445 0 242 1266 0 1752
1973 909 0 403 2256 0 1118
1974 175 0 0 2584 0 0
total SIII 4265 0 1537 6250 0 5471
Grand total production 72233
At 09:01 AM 10/17/96 PDT, you wrote:
> Well, I guess I've put out some mis-information. A reference book I have
>states the last series two was produced in 10/70, but Bob Bagramian has one
>produced in 11/70. Anyone with later information? I'll mark my reference book w
>hen I can locate the page number.
> Also, someone was asking about production figures for the "E". Here's what
>the book says;
> yr engine ots fhc 2+2
> '61-64 3.8 7,820 7,670 -
> 65-68 4.2 9,550 7,770 5,600
> 69-70 4.2 8,630 4,860 5,330
> 71-74 5.3 7,990 7,300 -
> grand total 75,520
> I thought all the series III coupes were 2+2's not fhc. Is the book wrong
>here too? LLoyd
End of jag-lovers-digest V2 #450
id <VAA00232> for jag-lovers-digest-out; Sat, 19 Oct 1996 21:06:26 +0200 (MET DST)
Date: Sat, 19 Oct 1996 21:06:26 +0200 (MET DST)
Message-Id: <199610191906.VAA00232@ekeberg.sn.no>
Subject: jag-lovers-digest V2 #451
Precedence: bulk
jag-lovers-digest Saturday, 19 October 1996 Volume 02 : Number 451
Bleeder nipple wrench size
Ordering Jaguar Parts
fogging of inside windshield
S-type instruments clean-up
Re: fogging of inside windshield
RE: Lurking
RE: Just Bought XJ40
Coombs Spats
Re: Ordering Jaguar Parts
Re: Trip Down Under (no Jag content)
RADIO WANTED
Drove an XK8
Intstrument Pack on '89 XJ40
Re: XK8 Road Test
Re: Lurking
Re: '88 MY and on Heater Core Replacement
Vintage racer's 1st XK8 drive!
Re: Instrument Pack on '89 XJ40
Date: Fri, 18 Oct 1996 19:39:11 -0400 (EDT)
David:
I have in the past entertained the list with the sad story of how I
came to own my Jag. In a nutshell: PO made lots of mdifications, promised
the car was PERFECT, and it wasn't. For the 18 months I have owned it I have
been troubled over many problems, but especially a stumble that would occur
any time the engine was revved past 3500. It would backfire and burp and
buck, and be a general pain at speed.
Last week, I was running down the road, and the engine burped a bit at low
revs. Just a little AHEM, to get my attention. Within a few miles, it was
missing badly, and finally backfired loudly enough to signal Civil Defense,
and died by the roadside. I tried to start it, but it just flooded.
Since it was flooded, I assumed no fuel problem (ha!), and checked the spark
plug wires and distributor. I pulled each wire, checked for water or
corrosion or loose fit, and reset it. I then popped of the distributor cap,
checked the points for gunk and replaced it. I then turned the key, and
viola! It started.
Five minutes later, and not quite home yet, the entire incident was
repeated. Several stops later, the car is in my driveway, much to my relief.
Quickly substitute new wires, cap, etc. No change. Now I'm totally puzzled.
There is clearly good spark, the fuel bowl is full and clear, and a quick
test shows good fuel pressure. Nothing seems loose, carbs are carbing, pump
pumping, sparks sparking. But every once in a while, the engine stumbles and
dies.
I put the car away for the night, and gave the problem some thought.
Remembering that my last fuel stop had been at a very run down gas station
in a rural area, I guessed that there was water in the fuel. So I drained
the fuel sump. Sure enough, there was some water in the fuel, but this
wasn't the problem.
With the sump off, I took the opportunity to replace the filter screen,
which was shot. As I struggled with the compression fitting, there was a
rattle in the take up tube, and out falls....a blob of solder. This must
have been in the tank for a long, long time, judging by the way it was worn.
I guess it had been working it's way past the remnants of the strainer and
up the tube for a while. The harder the engine drew fuel, the more likely it
would lodge in the wrong place. Once the suction was reduced, it probably
would fall back into the sump. Anyway, with the water and obstructions
removed, the engine has never run better: dare I say perfect?
Mike Frank
1969 E-Type 2+2
>working as well??)
>W
Date: Fri, 18 Oct 1996 23:26:08 -0500
Subject: Bleeder nipple wrench size
Sears has the answer for accessing the rear brake bleed nipples on an E-Type.
It's an exceptionally long closed-end wrench about the thickness of a pencil.
I need to order one, but they have two sizes. Does anyone know the size
wrench that fits a bleed nipple? I think this special wrench would obviate
the removal of the forward shock-spring unit. Hope someone out there can
help. Thanks.
Date: Fri, 18 Oct 1996 23:48:39 -0400
Subject: Ordering Jaguar Parts
Hey All Good Jaggers:
Laurel: I ordered an SU fuel pump from Welsh Enterprises last week and =
received it this week. I'm impressed - speedy delivery, the best price =
(of the four suppliers I checked out), and the friendliest staff on the =
phone. I think I got Bill himself. Never dealt with Welsh before but =
after this experience I think I'll drive down to Steubenville Ohio to =
check out their museum and pub and stuff.
Dart: When I order parts from the U.S. (I'm in Canada) they have to =
clear customs at the border (in this case Windsor Ontario). Because the =
parts are for a vehicle 25 years or older there's no duty payable, just =
G.S.T. (7% tax). I can live with that - it was $5.63. But those f*ckers =
at UPS charged me $25.00 to "broker" it through customs! The pump is =
only worth $59.50 U.S.!
Quandary: So which of my compatriots out there have a better way? =
There's no way I'm gonna pay UPS to broker anything for me again. What =
are my alternatives?
Thanks in advance.
tommy@peterboro.net
Date: Sat, 19 Oct 1996 00:16:35 -0400
Subject: fogging of inside windshield
My 1985 XJ6 VDP has "fog spots" that develop on the inside of the windshield.
Sometimes it occurs when I have had the heater/air conditioner working, and
sometimes it occurs without the system having been turned on.
It is a bit of a bother, but no big deal. Is there something I can do to
fix this? What might be the problem(s)? Would a "recharge" of the system
help?
Also, the windshield does fog a bit when the system is first turned on.
Depsite being a 1985 car, it has only 16,500 miles. But, of course, the car
is 11 years old, and I have no idea how long the original heating/cooling
system is supposed to last.
Any answers/help would be much appreciated.
Thanks.
Date: Sat, 19 Oct 1996 00:21:43 -0400
Subject: S-type instruments clean-up
Hi Gang,
Today I finished the dash wood for the "S" Type. It really looks great.
I set the spedo back in place only to see how shabby it looked against
the new, glossy wood.
As many of you know, the front bezel screws off Smiths gauges. It turns
maybe 5 degrees and slips off making it quite easy to refinish the bezel.
Inside, the face of the instrument, as well as the movement itself, is very
fragile. I learned on a TR6 that the paint used on the faces of gauges is
VERY easily damaged. I don't clean them beyond blowing away paint
chips and dust.
The bezel can be sanded and painted. I use the paint designed for
automotive "black chrome" trim. It is a nice semi-gloss black much like
the original Smiths finish. When dry, make sure that the glass is quite
clean on the inside before reassembly. The refurbished instruments look
new. One simply has to be VERY CAREFUL with the instrument when it is
partially disassembled!
Now, if I just had the furflex I could reassemble the dash. The furflex
has
to go on first as it is next to impossible to fit it in after the dash wood
has been installed. More later on that.
A couple of days ago I posted a note about trying to buy a Ferrari.
Well,
I still intend to buy one but upon reading the note that I sent I got the
wrong message. What I wanted to say was that the 308 Ferrari's are
now affordable (just like many other classic and exotic cars) and I am going
to take advantage of that. A Dino 308 GTB is about $30,000 US now for
a nice driver. That puts it in the price range of a really good XJ-S --
not that they should be compared beyond that.
In my automotive life I'm working between two end-members. The end
member on the LEFT is: "...to own one of ever kind of exotic car throughout
one's lifetime". The end-menber on the RIGHT is: "...to own one of every
kind
of exotic car ALL AT THE SAME TIME!"
Rick Lindsay
Date: Fri, 18 Oct 1996 22:13:23 -0700
Subject: Re: fogging of inside windshield
>Hey!
I have the same problem in my 88 Soveriegn. It's a real pain to be
constantly defogging. It's much worse if there are bodies in the back seat.
Debbie
Date: Fri, 18 Oct 1996 22:02:52 -0700
Subject: RE: Lurking
Ashley,
Good for you! Age is, or shouldn't be a factor in Jag ownership. I am 38, and I bought my first Jag last year (used). My father is 65, and he still drives a minivan -- whilst eyeing my Jag with extreme envy.
Drive what you enjoy. By the way, used Jags are cheap in Canada too -- too bad the parts aren't. ;-)
Mike Everatt
1987 1/2 XJ40
Sent: Thursday, October 17, 1996 11:51 AM
Subject: Lurking
Hello everyone...
My name's 'Ashley', and I live in London, England. I joined this list a
week or so back because I'm going to buy a 2nd-hand Jag in the next month
or so, and I wanted to read some background first.
I love Jaguars... Their sleek, elegant beauty is second to none. I want
one, because I want to sink into the upholstery and ride behind one of
the best balanced, nicest sounding engines in the world. In England,
2nd-hand Jaguars are VERY cheap - and maintenance is only 'reasonably'
expensive, because there are quite a few of them about.
I won't bore you all with newbie FAQ's, but I will ask you all about the
attitude I'll receive off other drivers. I'm only 25, and I get the
feeling that others might think I'm trying to be something I'm not if I
buy a Jag - when in fact I'm just getting one because I've always wanted
one.
Date: Fri, 18 Oct 1996 22:11:37 -0700
Subject: RE: Just Bought XJ40
Make sure the bulbs are all original Jag -- not discount store types. Other than that, you probably have a bad sensor on the left side -- front or rear. Quite common. Expensive to replace. Easier to live with it...;-)
Mike Everatt
1987 1/2 XJ40
From: Marshall Hollister-Jones[SMTP:marshall@mentor.co.nz]
Sent: Thursday, October 17, 1996 11:26 AM
To: Jag-Lovers
Subject: Just Bought XJ40
Hi all. I've just bought an '87 XJ40 Sovereign in excellent order travelled
only 50,000 km. After much research I have found this mailing list which
looks great!
I have one little problem which I hope someone can help me with. My bulb
failure system is playing up. All bulbs are functioning but I still get a
constant report of a failure. This seems mostly when operating the left
indicators. I have checked the bulbs for loose connection etc but all looks
OK. Could it be a faulty sensor but how do you tell which one?
Tauranga
New Zealand
Date: Sat, 19 Oct 1996 16:43:49 +0900
Subject: Coombs Spats
This is a most elementary question, but pray enlighten me. This is
information that's probably on one of the Thorley books, but alas it
is still on the way here.
1. what are Coombs spats?
2. I understand that only a few Mark 2s got the real Coombs spats,
but quite a few have the knockoffs (or whatever) anyway. In
this event, how do you know your Mark 2 has the real/original
Coombs spats or not.
Regards
Makoto Honjo
Phone/Fax +81-3-3473-1848
Subject: Re: Ordering Jaguar Parts
> Dart: When I order parts from the U.S. (I'm in Canada) they have to clear
> customs at the border (in this case Windsor Ontario). Because the parts are for
> a vehicle 25 years or older there's no duty payable, just G.S.T. (7% tax). I can
> live with that - it was $5.63. But those f*ckers at UPS charged me $25.00 to
> "broker" it through customs! The pump is only worth $59.50 U.S.!
I've had the same experience with these door-to-door freight
forwarders (that includes UPS, Fedex, and the like). I've found
that, at least for services to Japan, the much derided postal
service offers very competitive custom clearance and fair duty
assessments. Maybe there's something to be said about government
business (or maybe that's why they're losing money).
By the way, do you have Welsh's e-mail address (assuming they have
one)?
Regards
Makoto Honjo
Date: Sat, 19 Oct 1996 20:52:51 +1300
Subject: Re: Trip Down Under (no Jag content)
> Mike & Iris FrankWith 73 million sheep I believe we have the winner for the Aust vs NZ holiday debate.
Stewart Martel
Auckland NZ
PS Mike go South Island
PPS My neighbour has a XJS with a Supercharged 454 - no bonnet, the top of the motor
is in line with the roof of the cabin.
Date: Sat, 19 Oct 1996 08:26:19 +0000
Subject: RADIO WANTED
Looking to buy AM/FM radios (preferably transistor and pushbutton)
that can be set to either positive or negative ground. A Blaupunkt
Hanover model radio is one that I know will fit my needs. Radios can
be with built-in or separate speakers.
Any help would be appreciated.
Thanks,
Lenny Seidman
Date: Sat, 19 Oct 1996 10:16:04 -0400
Subject: Drove an XK8
Greetings All -
I just got back from my visit to the Jaguar Engineering Center
at Whitley, Coventry, UK. While there for business, I did get
a little pleasure!
I was able to get behind the wheel of an a sapphire blue XK8
coupe. Suffice it to say that the car has tremendous acceleration
and a terrific sound quality while doing so. The powertrain
isolation at idle is excellent. The handling of the car is
awesome -- feels like it's on rails when cornering.
I agree with all previous comments made that the seating position
is somewhat compromised for tall people (I'm 6' 1"), but it's not
a too bad. The wood rimmed steering wheel has a great feel.
Steering efforts a tad light. Transmission shift calibration
excellent.
As a passenger, the best feature of the car is the huge slab of
veneer, into which I could see my Cheshire-cat grin in the
reflection of the veneer's finish.
We drove up some country lanes near Leamington for some great
photo-ops. Last, the car was RHD, and we were driving in
England. How awesome!
I did miss out on seeing Tez Fair at Brown's Lane and also the
JDHT museum. Sorry about that. Maybe I'll have more time
next time.
B.J. Kroppe - '82 XJ6
p.s. In the development workshops there was a Mark V dhc
undergoing restoration for the JDHT. I got to climb
up on the lift for a thorough inspection!
Date: Sat, 19 Oct 1996 10:22:41 -0400
Subject: Intstrument Pack on '89 XJ40
How can something so small be so expensive? Sometimes after driving
for a while, the odometer and trip computer distance counter stop
working. I took the car into the shop for diagnosis and was told I need a
new "instrument pack" for $1,000U.S. (before tax and not including
labor). Has anyone had this problem or have an idea as to how to fix it?
The speedometer works fine. Plus, even if a new "instrument pack" is
in order, the price seems high. Thanks for the advice, Steve.
Date: Sat, 19 Oct 1996 12:26:41 +0100
Subject: Re: XK8 Road Test
In message <Pine.SUN.3.95.961018180603.26635D-100000@linet01>, John
Napoli <jgn@li.net> writes
I dropped into my local dealer a few days ago to get the new Porter
XK8 book which I can recommend. They also had a great 1:18 model of
thew convertable for 20ukp which I could not resist.
While I was there I had a good look at the showroom convertable and
noticed a coupe outside waiting to be collected.
This morning I have just seen my next door neighbour disappear
in the same car! I was envious of his Bentley but now I have turned
a much deeper shade of green. Oh well I will have to stick with
the XJ40 for a while...
Chris
Chris Matthews BSc FRAS cm@bcs.org.uk
Object-Oriented Designer and Microsoft Consultant E.D.S Limited
- ---------------------- Beware of geeks bearing GIFs --------------------
Date: Sat, 19 Oct 1996 16:28:29 +0200
Subject: Re: Lurking
[ Ashley Rolfe <Ashley@viglen.co.uk> ]
| one.
I bought my first one when I went over to England to study with
my wife and kid when I was 23. Bought a 9 year old series 3 XJ6.
I was king, an unbelievable feeling :-)
Now I'm 28, 29 in 2 weeks, still have the s3 and bought The Beast
two years ago. I can tell the neighbours are giving me the evil
eye, but I couldn't care less.
Keep on truckin'
Nick
<<< Nick Johannessen | nick@sn.no | nickj on IRC >>>
<<< Jaguar XJ6 4.2 '70 MOD & '82 Auto >>>
>>> The JagWeb http://www.sn.no/~nick/jaguar.html <<<
Date: Sat, 19 Oct 1996 12:10:00 -0400
Subject: Re: '88 MY and on Heater Core Replacement
Steve:
Are you in luck ! I just replaced the heater core on our
'88 V12 VDP this summer. The job is really easy !
IF you only have leaky "gaskets", then the fix is about
the same, only VERY cheap, because the gaskets from
the inlet/outlet pies to the heater core are standard
run-of-the-mill o-rings, $0.10 each :-) However,
you still have to almost take the heater core out
to replace them, so you might as well take the heater
core out and make sure it is not leaking as well, only
adds about 5 minutes more to the job...no really, only
about 5 minutes. The Delenair III system is really
easy to work on, just very expensive electronics.
To get the heater core out/replace the o-rings:
1) Drain the coolant. Use either the main radiator drain, if
you have one, or remove the lower radiator hose.
2) Take the front side panels (on the transmission tunnel
with the vent in it, yes, the vent screws are what hold
it on) and underdash panels off from both sides of the
car, 2 screws each (8 total).
3) Remove the glove box, 6 screws.
4) Remove the A/C CPU. There are actually 4 screws on this
thing, but you only have to take out one. Losen the other
three. Be very careful that you do not give any of those input
pins a static shock, as you will wreck it, and new ones are
about $1000.00 US
5) From the left side remove the two cover plates that fit around
the heater core inlet and outlet tubes, 2 screws each (4 total).
On our car, left hand drive, the top screw was a real pain to take off and put on, so be careful there. With these plates off, you should be able to see the 4 allen head set screws holding the pipes onto the heater core, or some foam....move the foam over. 6) From the right side, remove the tape from the similar cover of the heater matrix as on the left side. Look hard to find the edges. Be careful taking the tape off, as you can reuse it. If not, do not use electrical tape here, as it will not last, and the "goop" from the tape could gum up your CPU later....not my idea of a good job. There are 4 screws holding this cover on, just like the onther side, but not in two pieces. 7) From the left side, remove the 4 allen head screws from the inlet and outlet pipes. 8) From the right side, draw the heater core out of the A/C unit. Inspect the o-rings, and the heater core. The heater core is the same for all Jaguars from later '87 up to '94, including the XJ40's. The XJ-S's and XJ12's had the same inlet/outlet pipes, but the XJ40's had slightly different pipes. A new core should only be about $200.00 US, and are readily available. As for your radio, if you remove it and clean/inspect it, you should be able to get it working again. If not, I'll take it, as the FIRST time the heater core leaked, the PO replaced the radio. This last time the core leaked, (due to a very poor replacement core, and some really STUPID mechanic), I was able to fix the radio. There is a deflector shield that can be placed over the radio to keep it safe from coolant leaks. It is Jaguar part number CBC 9193, and it retails here for $21.70 CDN ($15 US). I'm serious about the radio. :-) Regards, Mark Roberts Phone: (613) 763-2924 Ottawa, Ontario, CANADA Fax: (613) 763-3970 1988 VDP - SIII V12 email: markdr@nortel.ca 1963 3.8L E-Type Coupe - 16 years into a 3 year project From: CJPN35A@prodigy.com (MR TOM M VEALE) Date: Sat, 19 Oct 1996 12:19:39, -0500 Subject: Vintage racer's 1st XK8 drive! A couple of weeks ago my good friend and fellow vintage racer, David Hinton, was contacted by Jaguar North America. They had invited all the major auto journalists to a few days of familiarization with the new XK8 in Florida (where our race cars spend this part of the year). The Auto Mag. folks were to pick up new XK8's in Miami and then make their way to Sebring by the next day. JNA invited our Leaping Cats group over to display our "old" cats along with other eras of competition Jags from their Pride. David bolted passenger seats in my green XK 120 roadster and his 120 coupe and took Jaguar officials, journalists and photographers for joy rides around the LOOOOONG Sebring track (3.8 miles, I believe). Then the Jaguar folks asked David to try out the XK8 and see what he thought of the newest of their cars. At first he couldn't get the car to perform well. As he would start to drift the car around a corner, the Automatic Traction Control would take power away and the car would sort of lug around the rest of the turn like it was starved for fuel. The Jag folks showed him how to disable the Traction Control and then he had a ball. Again he was asked to take the journalists around the track at Joy-Ride speeds in the new XK8! Lots of photos were taken of our old cats and their new ones with plenty of "action" shots of David driving. I'll let you all know when the magazines come out with articles on the event. You should see the XK8 on the covers of some of the more popular Auto magazines in about 1 to 3 months. So not only did David get free room and board for the day, but got to pet the new big kitty from Jaguar! David said he wasn't sure about the automatic transmission with the shift selector at first, but once he became accustomed to it, it was easy to select the proper gear for the corners. Acceleration and braking were excellent and handling, even on Sebring's Very Bumpy track, was very neutral with enough "tail wag" under throttle to keep enthusiasts happy. Too bad I was stuck here in Wisconsin, it sounded like a great time! At least my car got to go!! Best regards, Tom Veale in WI (Piloto Loco) Race photos at-> http://pages.prodigy.com/aimhigh/lcats1.htm From: Marshall Hollister-Jones <marshall@mentor.co.nz> Date: Sun, 20 Oct 1996 08:02:21 +1300 Subject: Re: Instrument Pack on '89 XJ40 That's probably about right. I have a friend who's car did this while it was still under warranty. He was told that the replacement part was NZ$5000 (=approx US$3000). Seven hours labour was required to fit it. The entire instrument panel and associated electronics were replaced. From: Steve Draper <s_draper@wcsr.com> To: jag-lovers@sn.no Subject: Intstrument Pack on '89 XJ40 Date: Sunday, 20 October 1996 03:22 How can something so small be so expensive? Sometimes after driving for a while, the odometer and trip computer distance counter stop working. I took the car into the shop for diagnosis and was told I need a new "instrument pack" for $1,000U.S. (before tax and not including labor). Has anyone had this problem or have an idea as to how to fix it? The speedometer works fine. Plus, even if a new "instrument pack" is in order, the price seems high. Thanks for the advice, Steve. End of jag-lovers-digest V2 #451 ******************************** X-UIDL: c6d95f5ece4a78f33488c92c1a1dbce2 Return-Path: @owner-jag-lovers-di1 Received: (from majordom@localhost) by ekeberg.sn.no (8.7.5/8.7.3/on4) id <DAA08109> for jag-lovers-digest-out; Mon, 21 Oct 1996 03:39:32 +0200 (MET DST) Date: Mon, 21 Oct 1996 03:39:32 +0200 (MET DST) Message-Id: <199610210139.DAA08109@ekeberg.sn.no> From: @owner-jag-lovers-di1 To: jag-lovers-digest@sn.no Subject: jag-lovers-digest V2 #452 Reply-To: jag-lovers@sn.no Errors-To: @owner-jag-lovers-di1 Precedence: bulk Status: RO X-Status: X-Newsgroups: mail.jag-lovers-digest jag-lovers-digest Monday, 21 October 1996 Volume 02 : Number 452 Re: Ordering Jaguar Parts New member Re: Ordering Jaguar Parts Re: Heater Core Replacement Bathtub effect Cruise control Re: Drove an XK8 Fogging on inside of windshield Status change: info seeker to card carrying member :-) Went to A Concours Today Re: fogging of inside windshield Re: Bathtub effect Brake Fluid: DOT 3 or DOT 4 F/UP XJ40 Bulb Failure Re: Brake Fluid: DOT 3 or DOT 4 Re: fogging of inside windshield '89 xj40 radio New member. Want advise on buying a Jag. Re: Brake Fluid: DOT 3 or DOT 4 Question: Fuel Indicator Problem on XJ-40 Re: Went to A Concours Today From: dlfreeman@ipa.net (Dave & Linda Freeman) Date: Sat, 19 Oct 1996 13:21:49 -0500 Subject: Re: Ordering Jaguar Parts Hey All Good Jaggers: Laurel: I ordered an SU fuel pump from Welsh Enterprises last week and received it this week. I'm impressed - speedy delivery, the best price (of the four suppliers I checked out), and the friendliest staff on the phone. I think I got Bill himself. Never dealt with Welsh before but after this experience I think I'll drive down to Steubenville Ohio to check out their museum and pub and stuff. Dart: When I order parts from the U.S. (I'm in Canada) they have to clear customs at the border (in this case Windsor Ontario). Because the parts are for a vehicle 25 years or older there's no duty payable, just G.S.T. (7% tax). I can live with that - it was $5.63. But those f*ckers at UPS charged me $25.00 to "broker" it through customs! The pump is only worth $59.50 U.S.! Quandary: So which of my compatriots out there have a better way? There's no way I'm gonna pay UPS to broker anything for me again. What are my alternatives? Thanks in advance. tommy@peterboro.net I don't know how it works in Canada but in the U.S. I have had parts sent from U.K. directly to my local post office and paid the duty, etc. when I picked them up. I suggest you check with your local Canadian postal authorities. My wife who used to be in the inport/export business says that fee is fairly common and does not depend on the value of the goods. Good luck at the post office. Dave and Linda Freeman <http://www.ipa.net/~dlfreeman> Living the Good Life From: Dogkip@aol.com Date: Sat, 19 Oct 1996 15:36:32 -0400 Subject: New member I am still trying to sort out how a mail list operates and what commands I might have. I was not able to find the database to input information. However this the message I sent out earlier before I was on the jag-lovers mailing list ( I thought I was on the list): I would like to subscribe to jag-lovers-digest. My name is Ray and I live near Dallas Texas , in the USA. I own a 1989 XJ40 Vanden Plas that I purchased in 1992, It now has about 65,000 miles on it, but remains in excellent shape. As time goes by I get to learn more and more about it. I learned through problems about rear struts, accumulators, seat belt retractors, crank shaft sensors, temperature sensors, etc., etc. I try to do as much of my own work on it as possible. I purchased a set of Jag service manuals which usually are of little help. I currently have several problems I am working on and need help. 1. My low brake pressure light stays on for about 15 to 20 seconds after I start driving. A Jag mechanic ( orgiinally from Scotland) said I should turn the car off once the light has gone off and then turn the key to the on position and press the brake whatever number of times it takes to get the low pressure light to go on. If it goes on after the pedal is pushed down 4 or fewer times a new accumulator is needed. My light goes on after I have pressed the brake 4 or 5 times, which seems like a marginal situation. If the current situation is not a hazard I can live with it. Last year I was told by a Jag dealer that I needed a new hydraboost pump ($1200) to solve the probblem, and I told them I wasn't interested. The accumulator was replaced on the car about 3 years ago. Any recommendations? 2. My right front wheel has very slight movement in the vertical plane but not in the horizontal plane. Adjusting the wheel bearing tightness didn't help. A Jag mechanic said I might need a new wheel bearing assembly even though I only had movement in one direction. I seemed to me it was some other suspension problem, but I changed out the wheel bearings anyway. It didn't help. I still have a little play. What's the next step? 3. After changing the wheel bearing my anti-lock system warning light now goes on. It does't go on until the low speed test is run. I had difficulty removing the bearing grease seal from the spindle and removed it by prying off the disc shield. I am afraid that I may have somehow damaged the anti-lock sensor on the wheel. Help!!!! From: rrichardson@eurekanet.com (Robert J. Richardson) Date: Sat, 19 Oct 1996 15:48:15 -0500 Subject: Re: Ordering Jaguar Parts Hey All Good Jaggers: Laurel: I ordered an SU fuel pump from Welsh Enterprises last week and received it this week. I'm impressed - speedy delivery, the best price (of the four suppliers I checked out), and the friendliest staff on the phone. I think I got Bill himself. Never dealt with Welsh before but after this experience I think I'll drive down to Steubenville Ohio to check out their museum and pub and stuff. Dart: When I order parts from the U.S. (I'm in Canada) they have to clear customs at the border (in this case Windsor Ontario). Because the parts are for a vehicle 25 years or older there's no duty payable, just G.S.T. (7% tax). I can live with that - it was $5.63. But those f*ckers at UPS charged me $25.00 to "broker" it through customs! The pump is only worth $59.50 U.S.! Quandary: So which of my compatriots out there have a better way? There's no way I'm gonna pay UPS to broker anything for me again. What are my alternatives? Thanks in advance. tommy@peterboro.net Can you get Parcel Post via U.S.Mail. I shouldn't think there would be any brokerage charge, but I may be wrong. I have an idea the UPS brokerage fee wouldn't apply to the value of the shipment, just the paperwork involved. I'd be interested in your Jag type and model. Those of us with older E-Types would know whether or not Welsh had fuel pumps for our cars. From: Juliansean@aol.com Date: Sat, 19 Oct 1996 16:17:17 -0400 Subject: Re: Heater Core Replacement A few extra comments to ad to Mark's: In a message dated 96-10-19 12:15:32 EDT, markdr@nortel.ca (mark (m.d.) roberts) writes: << Are you in luck ! I just replaced the heater core on our '88 V12 VDP this summer. The job is really easy ! ..........To get the heater core out/replace the o-rings:>> Jaguar issues a replacement gasket for this, instead of the original (lousy) O rings <<1) Drain the coolant. >> You shouldn't have to do this, I didn't <<A new core should only be about $200.00 US, and are readily available. >> Wow, that's cheap. I couldn't find one that cheap anywhere in the US. Paul Taylor in the UK has them for around 100 pounds (used , almost new). Julian Mullaney NC USA From: WEZA65A@prodigy.com (MR MICHAEL D FATSI) Date: Sat, 19 Oct 1996 16:17:36, -0500 Subject: Bathtub effect Regarding the bathtub problem: have you illiminated the possibility that water is coming in through the air vent. If the recent accident damaged the air vent water drain water could be backing up and finding its way to the ineterior through the air vent in the foot well. Pour water into the scuttle intake (the air intake between the hood (bonnet) and windshield, if water starts pouring into your car you have found the problem. Good Luck. MF From: suka@intergate.bc.ca (John Morgan) Date: Sat, 19 Oct 1996 14:34:09 -0700 (PDT) Subject: Cruise control I have a Ser.II XJC that I would like to retrofit cruise control too, any advice or tips would be useful, thanks, John Morgan From: "Lee Walden" <lwalden@ebmud.com> Date: Sat, 19 Oct 1996 16:11:59 -0700 Subject: Re: Drove an XK8 I also just got to sit in a Saphire Blue XK8 Convertible. I'm 6'4, and didn't find any difficulties in getting into or out of the car. I did have the electrically adjustable seat all the way down, and all the way back. The back seat is good for strapping groceries into place, but anything else but legless children would find it a rough go to "sit" there. The finish on the convertible top when up is very nice. It almost looks like a hard top from inside the car. Was suprised to find a "full" sized spare, the very large battery and the main fuse panel in the trunk,(boot). The dealer had the blue, a metallic red, two BRG coupes, and a black convertible. They were too busy to give any "test" drives. The head room in the coupe was also very good. NON XK8 Question..... What's a "good" (going) price USD for a 93 XJS convertible, 5-speed manual, only 13K miles? Lee I just got back from my visit to the Jaguar Engineering Center at Whitley, Coventry, UK. While there for business, I did get a little pleasure! I was able to get behind the wheel of an a sapphire blue XK8 coupe. From: JISBELLJR@mail.utexas.edu (James A. Isbell) Date: Fri, 18 Oct 1996 17:07:22 -0500 Subject: Fogging on inside of windshield This could mean that you have a leak in the Heater matrix. Does the fog on the windshield smell like antifreese? Do you have to add water to the radiator occasionaly? Also it could be that the A/C draind ase plugged and there is watter standing in the housing. Do you get wet carpets for no known reason? Does your passanger occasionaly get water on their feet? When you are using the A/C and you park the car, does water drip from around the transmission housing onto the pavement? Jim "Better an outlaw than not free." Nance O'Neil From: kdj@rambus.com (Kevin Jones) Date: Sat, 19 Oct 96 16:24:37 PDT Subject: Status change: info seeker to card carrying member :-) I received quite a bit of useful information from my query about Jaguar purchase. In particular, one little comment was very useful in making the decision: Bill Frenchu said: I was in the same position that you're in... I originally thought that I needed the XJ6, and that an S was just too impractical with two kids. I bought the S anyway, and have *never* regretted the decision! So despite being theoretically interested in an XJ6, I have just become the owner of a 1990 Solent Blue XJS with 35K miles on it. I hope I can echo Bill's statement for a long time to come :-). Anybody happen to know any *good* Jaguar service mechanics in the SF Bay area? Thanks, ******************************************************************** * Kevin D. Jones (kdj@ki-aikido.com) * * The Ki-Aikido Center of Northern California * * 5437 Central Avenue, #10, Newark CA 94560 (510) 796-6754 * * Homepage: http://www.ki-aikido.com * ******************************************************************** From: George Cohn <gwcohn@azstarnet.com> Date: Sat, 19 Oct 1996 19:42:50 -0700 Subject: Went to A Concours Today The local chapter of the JCNA was sponsoring a Concours today and since I had never been to one, I thought I'd check it out. Also the local Jaguar dealer was bringing an XK8 by to show. My first impression: Lots of beautiful E-types. Only 3 XJ's, and one XK150 but at least 8 E-types. My second impression: Some of the E-type owners must really be the anal retentive type! There were two 64 E-OTS "trailer queens" that were as close to 100 point cars as I'll ever see. Nether were licensed and you could shave off of the cam covers. I can't imagine owning such a sexy car without driving it once in a while. Most of the people there were very nice and I can't wait to get my car back together maybe just to show it in the driven class. Last impression: I was trying to keep an open mind about the XK8. After all of the build-up, I expected to really fall in love with it when I saw it in person. I'm sorry, it just doesn't stir anything in me. Maybe it isn't fair though to judge it so harshly as it was sitting amongst all those gorgeous E-types. The color was a fawn or silver brown color. The salesman said it was one of 3 that were already sold though. I must be the only one who wanted pictures of the cars as I was the only one to take a camera. I shot several rolls of 35mm film and if any of it is any good, I'll post them on my web page for all to see. From: ee84287@goodnet.com (Weiss-Malik) Date: Thu, 17 Oct 1996 20:07:59 -0700 Subject: Re: fogging of inside windshield Hi, Several people have posted questins regarding fogging of their windshields....In my opinion two possibles here...Leaking in the heater core creating residual fluid inside the core which then evaporates and condenses on the windshield, or, more likely, the drain tubes at the bottom of the heater box are clogged and are not allowing condensate to drain out. The traped condensate evaporates and condenses on the windshield.Quick check/fix: jack up the car, find the drain holes (actually tubes that come out just at the rear of the engine along the tranny) and poke a wire up into them. If you get some drippage you know you've got (had) clogged tubes. Hope this helps. Rob W-M 85 XJ-S From: ee84287@goodnet.com (Weiss-Malik) Date: Thu, 17 Oct 1996 20:24:45 -0700 Subject: Re: Bathtub effect HI, I too have a problem with water sometimes dripping from the driver side underscuttle...After keeping track of when it happens I've narrowed it down to a potential source.... The rain gutter on the outside of the car drins into the front pillars. If you open the door to the car and then from the outside and leaning over the roof look down into the gutter drain in the pillar you may be able to see daylight. Now, bend down and look at the area within the door frame just below where the pillar stops. In my car there is a short "channel" or "shelf" sticking out horizontally right below the pillar. Beyond this channel/shelf I can just barely make out a small opening that, based on its location, I believe opens directly into the area behind the dashboard (just about below the instrument panel level). I think that under the right amount of flow (high) the water draining down through the drain in the pillar overflows into this opening and from there onto the underscuttle, where it proceeds to "water" us unfortunate owners of this enlightened piece of brilliant british engineering. I haven't had a chance to fully explore this cause/effect possibiity and I am offering only my observations so far (I live in Arizona and rainfall is not a big motivator for exploring the quirks of England's finest in automotive engineering; plenty of other equally challenging quirks about the car keep me busy enough). I would be interested in getting feedback regarding your own observations/fixes of this condition. Good luck. Rob W-M 85 XJ-S From: cobac@ix.netcom.com Date: Sat, 19 Oct 1996 21:36:54 -0700 Subject: Brake Fluid: DOT 3 or DOT 4 Hi, I want to top up the brake fluid reservior in my 1989 XJ40, however I have DOT 3 type fluid available. The reservior and owners manual says use "DOT 4 or EQUIVALENT FLUID ONLY!" or possible damage may occur. Can someone help me and tell me if the DOT 3 is alright to be used in this system? I have no idea what the difference is, I just don't want to damage any of the delicate ($$$) components of the brake system. Thanks in advance for any help!, Eric cobac@ix.netcom.com From: Marshall Hollister-Jones <marshall@mentor.co.nz> Date: Sun, 20 Oct 1996 21:19:43 +1300 Subject: F/UP XJ40 Bulb Failure Thanks to everyone who offered advice on this problem. After replacing all the bulbs in the rear lights (both sides) because some looked a bit smoky I discovered the right fender indicator light fitting quite corroded - which I think must be the culprit as changing the bulbs didn't help. So, I think I can get a second hand fender light, but how do I change it? The plastic cover comes off easily enough but there are no screws to remove the base. Anyone know how to do remove this? From: TezFair@aol.com Date: Sun, 20 Oct 1996 09:31:44 -0400 Subject: Re: Brake Fluid: DOT 3 or DOT 4 In a message dated 20/10/96 05:40:34, you write: I want to top up the brake fluid reservior in my 1989 XJ40, however I have DOT 3 type fluid available. The reservior and owners manual says use "DOT 4 or EQUIVALENT FLUID ONLY!" or possible damage may occur. Can someone help me and tell me if the DOT 3 is alright to be used in this system? I have no idea what the difference is, I just don't want to damage any of the delicate ($$$) components of the brake system. Its all to do with the boiling point of the oil. Because a Jag is heavy, more force is applied to the brakes thus causing friction and a rise in temperature. If the DOT is to low the oil boils and air bubbles form in the brake line then leading on to spongy brakes. If there's enough air in the brake circuit then its possible that the brakes may fail altogether. So no don't use DOT 3 because its a little cheaper. Always use DOT 4 as recommended. It might save your life. Terry Fairbrother (4000 V8's fitted) http://members.aol.com/tezfair/ford.html http://members.aol.com/jaguarxk8/xk8.html From: Jeffrey Gram <101454.2570@CompuServe.COM> Date: 20 Oct 96 11:35:12 EDT Subject: Re: fogging of inside windshield Fogging on the inside of the windshield, usually concentrated just over the vents are due to cycling of the airco. It only ever happens after I start the engine up after having left it for some time. The fogging is watervapour from the airco heatexchanger which has cooled moist incoming air, usually almost freezing the waterwapour, which then deposits itself on the cool heat exchange elements. When you sop the car the elements warm up and the next time you start the first "blow" of air is a highly moist which blows on to the screen. If the fogging occurs while the airco is working i.e. driving, then there may be another problem - a leaking heater core, which will cause loss of coolant. There should be no influence of carrying passengers. If you never had the airco system replenished and a new filter in, you may want to have a thorough check of the cooling system, the and heater core. If all ok then get a new airco filter and a new charge. The Charge however will not influence the degree of "fogging", but at least the cooling is better ... I'm sure you will get other answers too. Regards Jeffrey Gram From: Steve Draper <s_draper@wcsr.com> Date: Sun, 20 Oct 1996 12:25:37 -0400 Subject: '89 xj40 radio Does anyone know whether the '89 xj40 comes prewired in the boot for CD addition? Also, if I have to put a new "instrument pack" in the car, does anybody want the old one? It sure seems that it could be fixed by someone with an electronics background. Steve @the Dark Tower, where "No matter where you ride to, that's where you are." '89 xj40 (bad instrument pack) '88 xj-s (bad heater core & radio) From: Dikran Hovagimian <dikran@eden.rutgers.edu> Date: Sun, 20 Oct 96 12:37:53 EDT Subject: New member. Want advise on buying a Jag. Hi, I am very pleased to join this group. I have always liked jags since I was a kid. Now, I may have the money to buy one. For the past few months I have been looking for an XJ6 (85' to 87'). I could not find a good one at a reasonable price. Anywyas, I like the XJ40's too. There is an XJ40 VDP '88 for sale near me. There is about 104 K Miles on it (Northeast U.S. car). The car looked beautiful. I took it for a ride, I did not hear anything out of normal. The only thing was a small ticking sound that I could here inside (it was not loud) but could not here it when I opened the hood. It might be normal, but then again this is a Jag. The paint is OK, but has tiny crack type cross-overs (I think from the sun). It is Black. The paint problem is not noticeable and with a good polish may disappear. The owner said the paint is original, is this normal? The interior is perfect. Tires are almost new. He said he replaced the rear shocks when I asked him(???), but otherwise he said that nothing else was wrong with the car. The owner is retired and had the car since 1990. So, at least the driving was not abusive!!! The oil guage seemed to be all over the place as I stopped and moved the car. The LCD on the radio did not display all the numbers really well, but sounded OK. The guy was Asking $7300, and seemed to need the money. I gave him $6000. And after a week he accepted. But, during this week, a Jag owner (XJ40 VDP 89') cautioned me from buying the car. He told me that the rear differential in his car was replaced twice. He gave up on the brake sensors. And the computer is giving him all sort of messages about a bulb being out and the brakes and so on. Oh yeh, this car Iwant to buy, the sensor on it says that a bulb is out and that the washer fluid is low. It also, had the brake sign on for few minutes when I started the car, but then disappeared. So, should I get it. Should I expect a lot of problems? I do work on my buick myself. I do all the small things from the oil to replacing a starter and so on. Should expect to be able to perforom the same tasks on the Jag? I appreciate everyone's help. Oh yeh, Is $6000 a good price for a Jag that's been through bad winters? What is a reasonable price? Again, thanks. Dikran Hovagimian. From: nbx@atom.ansto.gov.au (Ned Blagojevic) Date: Mon, 21 Oct 1996 11:11:05 +1000 (EST) Subject: Re: Brake Fluid: DOT 3 or DOT 4 In a message dated 20/10/96 05:40:34, you write: I want to top up the brake fluid reservior in my 1989 XJ40, however I have DOT 3 type fluid available. The reservior and owners manual says use.... Terry wrote:
Terry talks about brake fluid being an "oil". I thought that the fluid was
a high boiling point alcohol such as glycol or something like that. Could
someone clear up this for me.
Ned
'61 MK2
From: Walt Rybinski <walt.rybinski@worldnet.att.net>
Date: Sun, 20 Oct 1996 18:21:50 -0700
Subject: Question: Fuel Indicator Problem on XJ-40
Jag-Lovers,
Any hint to what may be causing my fuel indicator to not register a full =
tank after filling up. After filling up my indicator will oscillate =
around and settle about the 3 / 4 to 7/8 level. After driving awhile (7 =
to 8 gallons), I think it starts to read normally again, but I haven't =
really trusted since it started doing this.
My xj-40 is a '93 with 42k miles. Any thoughts as to what this maybe?
Thanks,
Walt Rybinski
San Diego
Date: Sun, 20 Oct 1996 21:39:07 -0400 (EDT)
Subject: Re: Went to A Concours Today
George:
Jaguar seems to be taking every opportunity to show the XK8 in the company
of E-Types. We went to a large Jag concours last weekend, which was attended
by lots of E-Types, XK's, and a fair number of XJ's. The XJ display was back
to back with the E-Type display. My wife looked over and asked "What do you
think that (Buick) Riviera is doing with those XJ's?" I said (very
authoratively), "Hmmmmm...Thats not a Riviera, that's an (Oldsmobile)
Aurora." Needless to say, we were enjoying the tail-view of an XK8! It may
be a terrific car, but the body design will need more definition before I
shell out $70,000!
Mike Frank
1969 E-Type 2+2
("What a beautiful car, it looks just like an XKE!")
("How can you drive such a valuable car?")
>though.
End of jag-lovers-digest V2 #452
id <RAA15569> for jag-lovers-digest-out; Mon, 21 Oct 1996 17:19:40 +0200 (MET DST)
Date: Mon, 21 Oct 1996 17:19:40 +0200 (MET DST)
Message-Id: <199610211519.RAA15569@ekeberg.sn.no>
Subject: jag-lovers-digest V2 #453
Precedence: bulk
jag-lovers-digest Monday, 21 October 1996 Volume 02 : Number 453
brake fluid hints
Misty/foggy windscreen
Fuel Consumption
Q: Auxillary Air Valve
Re: Question: Fuel Indicator Problem on XJ-40
Re: Q: Auxillary Air Valve
UPS brokerage
Re: Lurking
V12 alternator / XJ-S question
Re[2]: Drove an XK8
'93 XJ-S Telephone Install
Re: Positive Ground to Negative Ground Conversion
MkII - Voltage Regulator..
[XJ-S V12] Thermostats/Jiggle Pins
Re: UPS and Canadian Customs
Re: Attitude
V12 - opinions needed
Salesmen, XK8, and XJC's
Date: Mon, 21 Oct 1996 09:36:44 +-800
Subject: brake fluid hints
here are a few more 1. Ford makes an excellent dot4 fluid with a high boil.
2. buy small cans....don't store it..it absorbs air from the can... bandwidth is a terrible thing to waste...john shuck..beijing...
Date: Sun, 20 Oct 96 21:50:02 EDT
Subject: Misty/foggy windscreen
From: ** SHANE MANTOSZKO ** IBMA INVENTORY ANALYST **
*** SYDVM1(SHANEM) PH. (02) 354-4918 CUMBERLAND FOREST FE21
*** INTERNET - SHANEM@VNET.IBM.COM *** IBMMAIL - AUIBMSPM ****
To all those who are having problems with a mist build up on the
inside of their windscreen, I have a major solution.
My XJ6 series 2 has been suffering this problem in a small way for
quite some time. I have just had the whole engine bay re-done with
new hoses, accessories etc, and everything is tight as a drum.
When they tried to re-gas the air-con, they couldn't get enough
pressure in, as the metal connection in the firewall that the air-con
hoses clamp on to has a crack in it. This crack is letting gas escape,
and sure enough, it is misting up the windscreen.
To all of you with this problem, have your air-con checked, as this
may be the cause.
Can anybody confirm to me the best fix for my problem ? Should I
replace the unit with a reconditioned one, or can this crack be
welded up ? (I think it is aluminium). Can the casing itself be replaced
without having to replace the whole unit ?(The cam and gears all seem
to work ok, so I don't want to throw out the lot if I can help it..).pls
help me if anybody can....thanks.
REGARDS.......Shane
Date: Mon, 21 Oct 96 15:48:50 GMT
Subject: Fuel Consumption
Hi there!
A quick question - Any thoughts on what a 'normal' rate of fuel consumption
for an early XJ-S would be? At both city and highway speeds I guess.
Just wondering!
Dave C
'77 XJ-S
Date: Mon, 21 Oct 1996 15:13:27 +1000
Subject: Q: Auxillary Air Valve
G'Day,
Some questions about a inoperative Auxillary Air Valve on my 77 XJ-S. At
$600 AUS for a new one or $220 AUS for a reconditioned exchange, I want a
second (or third etc) opinion before I do anything other than note it for
later work.
1. Is the 'spring' I can just see actually a spiral shaped thermal tube that
closes the valve when the coolant heats up?
2. Is there any ill affect other than poor performance when cold if I don't
replace it?
Thanx
Derek Hibbs
Canberra, Australia
77 XJ-S
Date: Mon, 21 Oct 1996 08:36:27 +0200
Subject: Re: Question: Fuel Indicator Problem on XJ-40
Mine ('84 XJ6) does the same on both tanks. There has been a recent posting=
on this list that this problem is due to corrosion of the wire connectors=
to the instrument which causes an additional voltage drop.
Bert
>Jag-Lovers,
>Any hint to what may be causing my fuel indicator to not register a full=
tank after filling up. After filling up my indicator will oscillate around=
and settle about the 3 / 4 to 7/8 level. After driving awhile (7 to 8=
gallons), I think it starts to read normally again, but I haven't really=
>Thanks,
>Walt Rybinski
>San Diego
Bert Willing '84 XJ6
Laboratoire de Ceramique - Departement des Materiaux
Swiss Federal Institute of Technology (EPFL), MX-Ecublens, CH-1015 Lausanne
=46one : (+41 21) 693 29 44
Phax : 58 10
email: Bert.Willing@lc.dmx.epfl.ch
- ------------------------- Eudora 2.1.1 ------------------------------
Date: 21 Oct 96 17:14:47
Subject: Re: Q: Auxillary Air Valve
Derek Hibbs <snip>:
replace it?
1. The spring is just a spring. The valve is operated by a thermostat-type wax
bulb that pokes out the bottom od the unit and into the cooling water flow.
2. Depends where the valve is stuck. If it's stuck closed, you won't have much
trouble if you're kind to the engine while it warms up. If it's stuck open,
you'll have too fast idle with hot engine (should be 700 rpm with airco off).
I got sick of replacing the stupid things (it's a sliding valve, which is bound
to jam as the slider gets coated with glop) and when my third one stuck half
open, I simply blocked the cold idle bypass hole (letting it suck in a small
piece of rag soaked with gasket compound through the hole inside the left air
cleaner - on a string in case it didn't work out). I may need to help the
throttle with a gentle foot for the first 5 seconds on a cold morning,
otherwise I don't miss the cold idle assist one bit. The idle rises rapidly to
950 or 1000 rpm during the few minutes of cold enrichment from the ECU, then
settles to 700 as the engine reaches working temperature. Of course, it never
gets nearly as cold as Canberra where I live...
- -Jan
Date: Mon, 21 Oct 1996 07:13:55 -0700
Subject: UPS brokerage
I too am a Canadian and got ripped off by UPS for their "brokerage" so I
asked Welsh to ship by mail to bypass the brokerage. Check the size and
weight limits as you may be surprised at what you can send by mail. (A
person I know sent an outboard motor by mail). I had most of my parts for
rebuilding my XK140 engine sent by mail and suggested to welsh that they
should reccomend to Canadian customers to ship by insured mail. Canada
post and U.S. post are similar on their regulations.
Bill
Corbeil, Ont.
Date: Mon, 21 Oct 1996 12:15:15 +0100
>| one.
>Frpm Nick
I was 23 ( back in 1972 ) when I bought my first Jaguar, a 1963 3.4 MK2, for 150
pounds. I felt like a king as well. I kept expecting to stopped by the law,
because of my relatively youthful age, in fact I was never given a scond glance.
Roly
Roly Alcock, (Postmaster) Principal Systems Engineer
Redac Systems Ltd, Tel: 01684 294161 ext. 211
Zuken-Redac Group, Fax: 01684 298902
Green Lane,
Tewkesbury, E-mail: roly@redac.co.uk
Gloucestershire, GL20 8HE, UK Web: http://www.redac.co.uk
Date: Mon, 21 Oct 1996 13:47:09 +0200 (MET DST)
> later work.
> replace it?
When I was browsing through some fuel injection books during the week-end,
and I saw that a electrical heat operated aux air valve is very common with
Bosch systems. I've no idea what such a beast might cost, but since it seems
to be more widely used, it might be an option from the junk yard.
- - Matthias
Date: Mon, 21 Oct 1996 13:57:35 +0200 (MET DST)
Subject: V12 alternator / XJ-S question
When driving home yesterday night, the red "flash" symbol came on on our
XJ-S. I had this before, and it was a short diode in the alternator.
Removed (hot) alternator from (hot) engine took about 40 minutes. Sure
enough another diode was short. Last time I had swapped the complete
diode plate from an old alternator, so this time I needed to replace
a diode. One can press out a diode and press it back in a vice.
Attention, there are two different types. One does not need to remove
the big stator soldering, unsoldering the diodes and bending away the
connections does the work.
I'm now left with my last spare diode, does anyone know if these
type of diodes can be bought as a single piece ?
And when I remounted everything, I saw that my A/C belt amost touches
the pulley bracket of the ventilator. Could any of you XJ-S owners please
check if this is normal ? I've neem chasing some noise when my
A/C compressor comes on and I wonder if this is related to the belt.
- - Matthias
ps
YES, the alternator has a little mark saying LUCAS ...
Date: Mon, 21 Oct 96 08:00:47 EST
Subject: Re[2]: Drove an XK8
Lee
I just spent several months shopping for a late model XJ-S
convertible. I ended up buying a '93. I can give you some
insight on pricing.
N.A.D.A. retail for a 93 is about $31K - or it was before the
'97 cars came out - I don't know about now.
'Good' price for a real clean car is under that - I never seen
a good car for less than about $27K.
You would expect to pay a premium for a car with such low
mileage - so I would suggest that anything under $30K is a
pretty good deal - go for it.
All of this assumes that the rest of the car is perfect of
course.
Let us know what happens.
- mclaus
______________________________ Reply Separator _________________________________
Author: "Lee Walden" <lwalden@ebmud.com> at WG-RAL-SMTP
Date: 10/19/96 11:12 PM
only 13K miles?
Lee
> a little pleasure!
> coupe.
Date: Mon, 21 Oct 96 08:18:26 EST
Subject: '93 XJ-S Telephone Install
Hi guys.
I am getting ready to have a telephone installed in my XJ-S.
Have any of you done this? What should I look out for?
The local cellular folks offer to do the install for $55 -
which seems pretty cheap to me. I wonder if I should trust
them? Is this a difficult/tricky thing to do - and is it
significantly different on the Jag than on most other cars?
Also, the jaguar console cover with the cut-out for the phone
in it - have any of you purchased this? Does it work OK? My
local dealer wants $375 for it - anyone know where I can get
it cheaper?
Could really use your advise - I don't want to mess up the car
for the convenience of being able to work while I'm driving
it.
- mclaus
Date: Mon, 21 Oct 1996 06:17:25 -0700
Try changing all three bulbs (I assume you have a side repeater) for new
ones of the correct rating. If the bulbs are old, they can have too high
/ low a resistance, fooling the system into thinking it's broken.
G
>-----Original Message-----
>From: Marshall Hollister-Jones [SMTP:marshall@mentor.co.nz]
>Sent: Friday, October 18, 1996 7:27 AM
>To: Jag-Lovers
>looks great!
>Tauranga
>New Zealand
From: Michael Powers/TEIR/Thomson <Michael_Powers@teir.com>
Date: 21 Oct 96 9:35:46
If you local, friendly autoparts store doesn't carry it, try a motorcycle shop.
My bike also requires DOT4 and I have always bought it there.
Rgds,
Mike
cobac @ ix.netcom.com
10/19/96 09:36 PM
To: jag-lovers @ sn.no @ Internet
cc:
Eric
cobac@ix.netcom.com
Date: Mon, 21 Oct 1996 13:23:12 GMT
Subject: Re: Positive Ground to Negative Ground Conversion
On Fri, 18 Oct 1996, Braman Wing wrote:
> 3. water temp, oil, and fuel gauges - switch leads(not sure about fuel, I
> think you need to switch)
No need to do anything with any of these, they are not polarity sensitive!
> 4. clock - usually does not work anyway
And remember you have to "flash" the generator, i.e. apply battery
voltage of the "new" polarity so that it runs like a motor - one second is
enough.
> It is actually possible to run a negative
> ground radio in a positive ground car, I did it for 2 years.
Sounds pretty dangerous - what about the ground wire to the antenna?
Probably not much of a problem, wanting a new radio is usually one of the
main reasons people switch to negative ground anyway.
Egil
Email: egilk@sn.no Voice: +47 22523641, 92022780 Fax: +47 22525899
Snail: Egil Kvaleberg, Husebybakken 14A, 0379 Oslo, Norway
URL: http://home.sn.no/home/egilk/
Date: Mon, 21 Oct 96 06:43:37 PST
Subject: MkII - Voltage Regulator..
What does 'WL' stand for ? Wipers/Lights ?
TIA
Date: Mon, 21 Oct 1996 10:17:17 -0400
Hey Makoto and All Good Jaggers:
I will concur with you regarding the post office. I have since =
discovered that the post office charges $5.00 to broker a package =
through Customs. I will probably request that future orders be delivered =
through the post office.
Anyone else have alternative methods to suggest?
Sorry, I don't have an e-mail address for Welsh Enterprises. Their =
catalogue and invoice don't indicate such technology.
Sincerely,
tommy@peterboro.net
Date: 21 Oct 96 10:39:48 EDT
Subject: [XJ-S V12] Thermostats/Jiggle Pins
Hello fellow sufferers, the money pit is at it again.....
I am chasing an intermittant overheating problem, the car is fine around town,
but on a run above 80mph, the temp guage sometimes (more often than not) creeps
up to between N and H on the scale, it then starts to blow steam from the pipe
from the expansion tank, slow down/get into traffic, it all cools down, next
time I run the car, I get a low coolant warning, and, sure enough it needs a top
up.
Diagnosis so far, the RAD is externally clear, the pressure caps are OK (and
appear to be the correct ratings), both the fans work., distributor advance OK
(I think), this weekend I decided to check the thermostats, sire enough one of
them looks bad (small rubber seal at base split and it generally looked
"doggy"), so of to the local parts store, replacement thermostats fitted, test
drive, seems OK
BUT.... The new thermostats do not have the "jiggle pins" the originals had, the
manual (Jaguar Repair Manual), is very clear that you must have thermostats with
jiggle pins, otherwise the system cannot "purge" correctly and engine failure
can result...
Question: Has anyone ever used non jiggle stats, if so, any problems?, and, by
purge I guess it means air, if the system is correctly bled, then is this a
potential problem.
Opinions/horror stories?
Regards
Date: Mon, 21 Oct 1996 09:54:00 -0400
Subject: Re: UPS and Canadian Customs
Tommy, and all other Canadian Jag-lovers:
I too have felt the bite of the UPS "broker" charge,
and now will not get any parts shipped by them if
at all possible. The best way I have found so
far is via MAIL, yes good old snail mail.
When I order parts from British Auto/USA, they send
by mail, and I only pay the $5.00 Postal handling
fee, plus GST, and it takes about 1 week. In the past
it has taken UPS to deliver from British Auto about...
1.5 weeks !
Some parts places, such as SICP only ship via UPS....
I do not use them because of this. Even with their
cheaper prices, the additional UPS charge just makes
them too expensive. Most other places give you the
option of either Post, or UPS.
Hope this helps.
Date: Mon, 21 Oct 1996 09:01:27 MDT
Subject: Re: Attitude
Et. al wrote:
> >> He took a run at me while I was travelling at about 50 KpH and drop
> >> kicked the door
> >> then scarpered off up the road.
> >While my wife and I were getting something out of the trunk in a
> >parking lot, some guy driving by tossed a lit cigarette into the
> >trunk.
> >I have also had quite a few people in front of me on the road
> >suddenly jam on the brakes, apparently hoping I would rear-end them.
> least five "nose" jobs while being parallel parked. Only one driver fessed
Well, I can add my name to the list. I live in a small town and my
Jags have become the object of scorn for the "wealthy" (which I'm
certainly far from). I have had eggs thrown at it several times and
some kids even rolled it down the street in the middle of the night
last summer. I park and lock them inside without exception now. Its
really true that people seem to think that you are some rich sod if
you drive a jag. I won't be surprised if some day I get a visit from
our security clearance rep. to see where I got my money for those
"expensive jags". If only he knew.
Kind Regards,
Jim Cantrell
Date: Mon, 21 Oct 1996 11:05:08 -0400
Subject: V12 - opinions needed
I am considering replacing the valve cover gaskets and intake man. gaskets on
a 1991 V12 XJS.
Should I pay $450 for someone to do this, or go for it myself. I'm quite
mechanical etc. , it's just a question of it it worth the bother???
Opinions??
Thanks
Julian Mullaney
Date: Mon, 21 Oct 1996 09:17:41 MDT
Subject: Salesmen, XK8, and XJC's
Last week, while I was travelling in Los Angeles on business, I
decided to drop in and visit the Jag dealer in Pasadena. I was
looking for an XK8 to look at but was admiring the many convertible
XJS's. As I was admiring the 65,000$ price tag on the new XJ12's, a
voice behind me said "hello chap, top of the morning to ya". I
looked around and here is this long haired oriental guy with a fake
british accent. "looking to buy a new Jag-you-werrrrrre are you ?".
I said that I wanted to look at the XK8's and he took me to them. I
could not "touch or sit" but I could look (no fee required). My
impressions were that the car is more beautiful in person than in
photos. It is much lower than I expected. But still, it does
resemble the Taurus. I mentioned that to him and he replied "sir,
those who don't possess the means to buy such a fine machine use that
as an excuse". In asking him some questions concerning the car's
engine noise (how quiet/loud), he stated that until 3000 RPM's, the
engine is nearly silent but afterwards, Jaguar designed in a
"mechanical device that connects the car and the engine so that you
can feel the motor when you are dirving in a spirited fashion".
Sounded like pure unadulterated BS to me. He asked what kind of
Jag-u-werrrre I drove and I explained the XJ12C and XJ6C in my
garage and the E-type that I had a few years ago. He had no problem
recognizing the E-type, but he argued with me for 5 minutes that the
XJ12C and XJ6C were in fact an XJS since they "never made a 2-door
XJ12 or XJ6". Oh well, I left and conveniently lost his card
afterwards. Where do they get these guys anyway ? Fake accent and
all - they must have some sort of school to train them and give them
all of this BS. At least they don't have free hot dogs to entice
buyers to come and look.
Kind Regards,
Jim Cantrell
End of jag-lovers-digest V2 #453
id <XAA18903> for jag-lovers-digest-out; Mon, 21 Oct 1996 23:31:57 +0200 (MET DST)
Date: Mon, 21 Oct 1996 23:31:57 +0200 (MET DST)
Message-Id: <199610212131.XAA18903@ekeberg.sn.no>
Subject: jag-lovers-digest V2 #454
Precedence: bulk
jag-lovers-digest Monday, 21 October 1996 Volume 02 : Number 454
Re: Fuel Consumption
Re: '93 XJ-S Telephone Install
Attitude
Re: Lurking
Re: E series II dates
SIIIxj6 beautification
Re: [XJ-S V12] Thermostats/Jiggle Pins
SIIIbeautification
Spark plug wire testing
Attitudes
Re: FW: XJS Output Shafts
Re: Spark plug wire testing
'88 XJ-S Shock bushings
Re: Attitudes
SIII xj6 stalling
Re: V12 engine managment
Re: V12 - opinions needed
Re: V12 alternator diodes
Date: Mon, 21 Oct 1996 15:24:13 GMT
Actually, most of the older vibrator-type radios were
polarity-insensitive and could be used without modification in either
positive or negative ground cars. The exceptions were those with
synchronous vibrators and some of the signal-seeking radios that used
motors instead of spring/solenoid drivers.
The real problems arise when trying to use a radio with any
solid-state components in it. In many cases, however, a voltage
converter can be installed to allow positive ground operation of a
negative-ground radio. The main requirement is that the maximum
current draw requirements of the radio be relatively low (less than 3
amps).
Vince
- -- =20
Vince Chrzanowski radiowsh@mindport.net=20
"There is not a moment to be lost" - Jack Aubrey
- -------------------------------------------------- =20
Date: Mon, 21 Oct 1996 08:27:49 -0700
Walt wrote..
You might have a collapsed fuel tank or a blown slosh module. Make sure
the tank has the correct shape. Lee
Date: Mon, 21 Oct 1996 08:29:45 -0700
Subject: Re: Fuel Consumption
City 8-10, highway 10-14. More or less. Sorry.
consumption
> Just wondering!
> Dave C
> '77 XJ-S
Date: Mon, 21 Oct 1996 15:59:45 +0200 (MET DST)
Subject: Re: '93 XJ-S Telephone Install
> it cheaper?
> it.
I bought my XJ-A at an auction, and it had a phone installed. It was
an older analogue system which I removed from the car. During this
process I made few observations :
- -1) A first system had been install with the hand-set mounted on the
passengers side. Simply drill a few holes in the leather up-holstery ....
The one I got was installed the middle arm rest which is a
good idea I guess. At least here in France many phones are "hands-free",
so you really don't need the handset and having the phone hidden
might avoid thiefs.
- -2) I guess to install the antenna on the roof, you might need to remove
(parts ?) of the headliner. well, my leather has a few spots where some
glue made contact, and I guess this might be related.
- -3) Also the antenna is a little too tightened, so the roof makes a very
slight bend around it. Nothing serious, but it might be nice to get
it well done.
$ 55 sounds pretty cheap to me.
- - Matthias
Date: Mon, 21 Oct 1996 12:05:15 -0400
Subject: Attitude
My wife often complains on how she (85XJS) continuously gets cut-off in
traffic. I think the car does sit low and the BRGreen doesn't help, but there
is definitely an attitude.
Add this to the list of bewares to prospective Jag owners:
When driving a Jag, whether it be new, or an acquired "previously owned"
project, understand there aren't many out on the road. You will be noticed
and will be paid attention to. This may require some special skills. There
are a lot of "teachers" on the road who love to show us how to live in THEIR
world, and punish us for not being the same as THEM, (when you know
different).
Treat them as ignorant of the blood, sweat and skills it takes to buy one,
build one, or keep one running, much less understand how one works. They could
drive one too, if they wanted to. Trade-offs are time, money, education, some
blood, tears, and head scraa dirty and of course a dirty garage floor.
Russ Lehman
"nothing worthwhile is ever easy"
"pessimists are accurate; optimists live longer"
Internet: rlehman@npr.org
Date: Mon, 21 Oct 1996 17:01:30 +0100
> >| one.
Well I'm not so young (45), but I have observed certain patterns of
behaviour by other drivers towards me when driving my Daimler (as
opposed to my wife, Christine's, Euro-hatch).
Aggression - comes in a number of forms:
"I'm not letting that git in the Jag out of that sideroad" - this
happens in queues of traffic, and is normally someone driving a newish
modest car or a "small" BMW or Merc. (funnily enough drivers of big
Beamers or Mercs are usually fine, as are nearly all drivers of older
vehicles) (Oh I forgot - Volvo drivers never let anyone out - there's
no Jag prejudice there!)
"Look! I can overtake a Jag" - this is either a rep driving a 1.6 or
2.0 litre company car, a driver of a "hot" hatch or similar, or
something just plain silly like a mini. The fact that you are
actually just pootling along at 60 doesn't matter, they will do
anything that it takes to get by. A related phenomenon is the "I'll
beat this Jag from these lights" - affects the same people.
"Niceness"
Most other Jag drivers will treat you wonderfully - the only bad
behaviour I have experienced I put down to envy - a man with a
similar age Jag to mine moved heaven and earth to prevent me pulling
out - I put this down to the fact that he somehow resented my
Daimler(his was a base 2.9).
I must confess that most people treat me more nicely in the Daimler
than in Christine's Maestro!
One thing that really throws people in Stafford is how nice Bus drivers
are to me. This is a con really - I am a dedicated non-drinking
driver who likes his beer - therefore I catch a bus twice a night and
all the drivers recognise me during the day!
Police:
Keep your Jag clean and shiney - they will treat you *slightly* better
than others.
Mark
90 Daimler 4.0
Date: Mon, 21 Oct 1996 12:00:06 -0500
Subject: Re: E series II dates
You are correct, all Series 3 E-Types with tin roofs were 2+2, not FHC. The
Series 3 OTS also used the 2+2 pan, hence the longer wheelbase and doors.
MikeC
Subject: E series II dates
Author: LLoyd <3030P@vm1.cc.nps.navy.mil> at Internet
Date: 10/17/1996 9:01 AM
<snip>
I thought all the series III coupes were 2+2's not fhc. Is the book wrong
here too? LLoyd
Date: Mon, 21 Oct 96 10:08:52 PDT
Subject: SIIIxj6 beautification
Date: Mon, 21 Oct 1996 13:25:16 -0005
Subject: Re: [XJ-S V12] Thermostats/Jiggle Pins
Paul Peard <100025.1253@CompuServe.COM>:
> (I think),
I *think*? Haven't you been paying attention? If you haven't had
your distributor apart and therefore made SURE all the black gunk has
been removed, trust me, it is seized.
> "doggy")
There's a criteria! I don't suppose the boiling test was even
considered?
> drive, seems OK
> can result...
> potential problem.
We have now verified for certain that you have not yet read my XJ-S
help book!
-- Kirbert | If anything is to be accomplished,
| some rules must be broken.
| - Palm's Postulate
Date: Mon, 21 Oct 96 10:18:00 PDT
Subject: SIIIbeautification
Lawrence Buja asks that I tell what I have done to "beautify" the
already beautiful Series III xj. I have installed the proper 7 inch
halogen lamps, the most expensive part being the chrome ring. The conversion
itself is very easy. Canadian cars, Australian cars, and most others
(except US) came at some point in the productionwith the 7 in lamps. American l
egislation prohibited anything that good (!) so the American cars have a spacer
ring to hold the small lamps. The conversion consists of obtaining a 7 inch
bowl and body gasket, the chrome ring, and fitting the wiring to the new bowl.
(Throw away the spacer!). I have fitted the rear seat reading lamps as
on the Sovereign and Van den Plas models. The lamps are available from
SICP among others, but the plastic base and shield must be obtained
from a wrecker or from Jaguar (these are NOT expensive). Installation
involves carefully removing the Cpillar cover, and making a hole in it
for the single wire to pass through. I wired the lamps into the parking light c
ircuit in the trunk. Very simple, and it prevents accidental battery
drain since the lamps will light when moved to the ON position otherwise.
The lamps are grounded by one long screw into the body pillar (careful
in drilling. Do not go further than the inner panel or you will have
a nice hole on the outside!!) A great addition, but the position of the
lamp should be carefully made, using a VDP or Sovereign as a model.
I have also added rear seat headrests. I obtained the proper xj6 headrests
which were an option on European Jags. They are slightly narrower and
I believe a bit taller than the Sovereign and VDP headrests. By comparison,
the are a full pleat narrower (using the seat pleats as a reference) than
the Sov. or VDP rests. If your car was made in 1982 or later, it will have
the bracket for these optional rests already built into the seat back.
Installation is a snap, involving only poking a small hole in the top
of the seat (on the vinyl, not the leather). Again, it is an easy
modification for an upscale look, but it is expensive to get the new
headrests. By the way, I could not get these proper xj6 headrests in
BISCUIT, so I used CT600 from Garrard Coachworks in Washington USA
to colour them. They match my new Jaguar leather perfectly. Alternatively,
you can get VDP headrests from a wrecker as the mounting bracket is the
same. They will not be "authentic xj6" because they are lower and wider,
but who willknow? They may have to be coloured. I have also obtained the later
style jack pouch for my late 82. It is in the same material as the trunk
carpeting, while the original in that year was a black material (the same
as the matting for the 79 to 81 xj). It looks much better and is more durable.
These can be had from a wrecker. I have added the original style rectangular
driving lamps, wired easily into the lighting switch by the existing bullet
connection in the front fenders. The switch is converted by simply removing
the C clip that prevents its being depressed.
Finally, I have carpeted the front kickpanels using as new-carpet from a wrecke
r. This was the style of Sovereign and VDP models. A simple improvement,
which looks terrific. Removing the kick panels involves taking out three
screws! (two on the retaining bar at the bottom, one at the top, inner
firewall side) Be careful to cut the carpet so the nap of the pile is
running the same way on both. I removed, or really shredded off, the
padding from the back of the carpet, since it is bonded to it. Unless
you do this, the carpet is to thick to easily bed around the cardboard
form. I simply glued the carpet to the existing vinyl covered board, being
careful to allow extra carpet for the bending. I trimmed the carpet after
gluing, allowing a bit extra. I added the proper binding at the bottom
edge and the firewall edge by removing it from the wrecker-s carpet piece. and
sewing it on using the existing thread holes. I did this before gluing, of
course. Installation is a process of fit and trim, but by allowing
a bit of extra carpet at the top edge, I actually improved the fit over
the original. It is now installed and looks absolutely original, and
exactly as the panels on the Swiss market Sovereign I saw last week. (by
the way, under the kick panels you will find the relays for the ignition
and the doors and trunk). All the above modifications are strictly
"Jaguar"in that they replicate the use of items installed on the xj
at Brown-s Lane during its production.
Gregory Andrachuk, Victoria, Canada
Date: 21 Oct 96 14:05:43 EDT
Subject: Spark plug wire testing
There has been some discussion lately about trouble shooting non running or poor
running cats. I know you can easly test spark to a plug by holding the plug
with wire attached against the block or, with the plug installed, by holding the
wire a short distance from the plug. (In both cases using insulated pliers of
course.)
But how can you test the effectiveness of the plug wires? The old time method
of turning off the lights in the garage at night at looking for arcing will show
serious wire problems. Is there a method to detect problems before they get to
this point?
Thanks,
Ed
Date: Mon, 21 Oct 1996 11:29:38 -0700
Subject: Attitudes
All this talk about attitude has been kind of interesting. Here in
Northern CA, there are quite a few Jags around, and there's no shortage
of cars that make even a brand-new Jag look like a poor-man's car in
comparason.
Anyway, people often ask me about, or comment on the reactions I must get
when driving my Jag: a pretty nice looking, BRG '59 MK1. Being
right-hand drive, it's even more unusual for these parts.
Anyway, in my opinion, it's all a matter of perspective. People *IGNORE* me
in the Jag. But, it only seems this way because of my daily driver- my
currently broken, 21 foot long, 1960 Cadillac hearse with flames. If you're
having troubles picturing that, try loading:
http://www.best.com/~border/pages/hearse/60hearse2.jpg
I actually worry about drivers going by, staring at the hearse, and doing
something really stupid (running into something) because they're not watching
where they're going. I've never actually seen an accident, but I've seen
numerous close calls.
What's funny is that although "car people" know and appreciate the Jag more,
the hearse generates responses from people from all walks of life, old ladies
and little kids included. The other day an older couple in a new'ish big
Mercedes with blacked out windows rolled them down just to give me a big
"thumb's up". I got the feeling they hadn't done that for a really long time.
There was only one time I can think of when I was driving and wasn't getting
the most attention on the road... I was cruising along-side the Oscar-
Meyer-Weinermobile.
Like I said, compared to all that, people pretty much just ignore the Jag ;-)
===== __ ============================================================== |> ===
/\_\ Ryan Border o~_ o~_ __| *
/ / / Hewlett Packard Company, Inc. >/-.>/'_ /_o| *
/ / /_ _______ Software Design Engineer ( )\---\(*)-( )' *
/ / /__\/\______\ email: rborder@cup.hp.com or border@best.com *
/ / __ / / __ / 19111 Pruneridge Ave. mailstop 42LX, Cupertino, CA 95014 *
/ / / / / / /_\/ / (408) 447-2496 FAX: (408) 447-0641 *
\/_/\/_/ / _____/ http://www.best.com/~border/grimrides/grimrides.shtml *
\/_/
Date: Mon, 21 Oct 1996 14:09:24 -0500
Subject: Re: FW: XJS Output Shafts
This is a Mime message, which your current mail reader
may not understand. Parts of the message will appear as
text. To process the remainder, you will need to use a Mime
compatible mail reader. Contact your vendor for details.
- --IMA.Boundary.064229548
Content-Type: text/plain; charset=US-ASCII
Content-Transfer-Encoding: 7bit
Content-Description: cc:Mail note part
SICP's regular phone number is: 401-831-8850 in the US. (thanks to
Jennifer Joy's monthly list of suppliers.)
(non-North Americans cannot use US toll-free numbers, so it isn't
especially useful to send them. As far as I know, our Northern
neighbors have no problem with them.)
MikeC
Subject: FW: XJS Output Shafts
Author: Aaron Burnett <aaron.burnett@attws.com> at Internet
Date: 10/17/1996 10:58 AM
I just called Special Interest Car Parts
<snip>
Their phone number is 1-800-556-7496 and they generally will deliver
anywhere.
Hope this helps.
Aaron
'85 XJ-S
- --IMA.Boundary.064229548--
Date: Mon, 21 Oct 1996 13:36:01 MDT
Subject: Re: Spark plug wire testing
> this point?
You bet. Most shops use very expensive engine diagnostics scopes
that will give you the time/voltage history of the spark traces. If
you know what you are looking at and have the money to buy the scope,
you should be able to pinpoint shorted or open wires (even in partial
states). I reccomend replacing suspect wires instead. Its a lot
cheaper than even having someone look at it to see if they are bad.
Kind Regards,
Jim Cantrell
Date: Mon, 21 Oct 1996 16:08:50 -0400
Subject: '88 XJ-S Shock bushings
I need to replace the front shock bushings. Anybody with any tips
please feel free to comment. I particularly would like to know what a
reasonable amount for the bushings is and where to get them as well
as any installation comments. Thanks, Steve.
Date: Mon, 21 Oct 1996 13:20:47 -0700
Subject: Re: Attitudes
No Jag Content, but British Car Content....
I just saw this weekend my second MGC. The first one I ever saw was at the
science museum in Malmo Sweden. It was a convertible in BRG. At a local
Amateur Radio Convention here this weekend, there was a black MGC GT.
Unfortunately it wasn't it the best of shape. The windshied was busted and
there was a rather large dent in the rear bumper. Looks like the car
impacted a post. Still it was neat to see a "rare" one. Lee
_______________SNIP_______________________
Ryan wrote...
> comparason.
_______________Snip____________________-
Like watching the teenagers cruise down Main Street in Walnut Creek in
their MzB's, Ferrari's, and Jags.
When he was still around, it was fun to see Bing Crosby tooling down El
Camino Real in his Rolls.
Lee
Date: Mon, 21 Oct 96 13:25:30 PDT
Subject: SIII xj6 stalling
A couple of weeks ago I changed the coolant in my 4.2 litre xj6. I
reported that the first time I drove it after this it started and idled
normally, but during the warm-up period (below 70 degrees) it would stall
when the accelerator was pressed from idle (as at a traffic signal). I
theorized, and some of you supported) the idea that the coolant temperature
sender was malfunctioning, telling the ECU that the engine was warm, when it
was not. A couple of days later, I found that the coolant level was down
more than a litre (the original coolant change did not take the full
stated capacity!). The problem seems to have cured itself, since the car
no longer stalls, and runs perfectly. Conclusion: air lock in the system
did not allow the sensor to read properly. I was prepared to replace the sensor
(not very expensive, in any case), but I think the coincidence of coolant
change and the stalling problem lead to this conclusion. So, once again
the problem was not a serious one; in such cases it is usually better to
wait and see, rather than taking drastic action.
Gregory Andrachuk,
Date: 21 Oct 96 16:30:41 EDT
Subject: Re: V12 engine managment
Hi list.
There is a discussion ongoing offline,Matthias F started . It concern
DIY and professional issues around possibilities of changing / enhancing the V12
ECU
to run less than 12 cylinders on part load, and on the issue of changing the
warm up enrichment.
If you're interested to follow, send me a note.
We have so far discussed this offline as I presume most of you wouldn dare to
put a solder iron to you
injection computer, and to save some list bandwidth. I may be wrong in this
assumption .
Date: 21 Oct 96 16:59:29 EDT
Subject: Re: V12 - opinions needed
Hi Julian,
Funny question. You should be the best to judge what you want to
do with your money.
If there is an air leak this is seriously dangerous. If not it may not be worth
to bother
and in that case save the 450$ and why not get some experience ?.
If you do however also replace the injector o-rings- 2 sets of twelve rings
(mandatory! - they MUST be changed if
you taken it apart)
Also check and clean out the distributor, seized advance etc etc.
regards Jeffrey Gram
Date: Mon, 21 Oct 1996 21:57:22 GMT
Subject: Re: V12 alternator diodes
In message <199610211157.NAA01291@turquoise.cray.com> mfl@kheops.cray.com (Matthias FOUQUET-LAPAR) writes:
Places like RS Components or Farnell should do them. If you tell me
the looks / dimensions of the thing I'll look it up and see what they've
got.
Stefan Schulz
jaguar@suaviter.demon.co.uk
End of jag-lovers-digest V2 #454
X-UIDL: a1e38fcc61d82eab96bb7f411ba8330c
Return-Path: @owner-jag-lovers-di1
Received: (from majordom@localhost) by ekeberg.sn.no (8.7.5/8.7.3/on4)
id <FAA05650> for jag-lovers-digest-out; Tue, 22 Oct 1996 05:14:38 +0200 (MET DST)
Date: Tue, 22 Oct 1996 05:14:38 +0200 (MET DST)
Message-Id: <199610220314.FAA05650@ekeberg.sn.no>
To: jag-lovers-digest@sn.no
Subject: jag-lovers-digest V2 #455
Reply-To: jag-lovers@sn.no
Errors-To: @owner-jag-lovers-di1
Precedence: bulk
Status: RO
X-Status:
X-Newsgroups: mail.jag-lovers-digest
jag-lovers-digest Tuesday, 22 October 1996 Volume 02 : Number 455
Attitudes & Attitudes
[none]
Speedometer/Tach readings. & Fuel Tank Cap (XJ6)
Re: Attitudes & Attitudes
Re: '88 XJ-S Shock bushings
Re: Salesmen, XK8, and XJC's
Screeching Sound
Re: Spark plug wire testing - my method
Getting noticed (was attitude)
British DMV info
FW: still leaking XJ-S/ BATHTUB
88 VDP XJ40 purchase
Re: Lurking
Date: Tue, 22 Oct 1996 10:27:22 +1300
Subject: Attitudes & Attitudes
Hi all,
Looks like I started a thread out of the original Luking
message......thanks for your input.
I'm sure that all attitudes are not negative though.
Can we hear from the multitudes of positive reactions.
To start the ball rolling.
When I first started test driving Jags to find the one I wanted
I was impressed by the courtesy (was it ?) of other drivers. They seemed
to allow
me space that they never afforded me when driving the old Subaru or
Honda.
Was their reason my erratic driving of an unfamiliar vehicle ?
Such a piece of art was best admired from a distance ?
Making room for the sudden acceleration from a Jag ?
I'm still not sure but the presence of the Jag provides openings in the
traffic that wen't there before.
I like to have a car that stands out in the crowd.
Jaguars are always noticed.
I believe that the onlookers are just envious.
It's a pity that more do not feel the joys that Jaguar ownership
provides.
John_setters@eagle.co.nz
JKS-XJS CATMBL
Date: Mon, 21 Oct 1996 17:38:54 -0400
Subject: [none]
Hi. I'm a newbie here. I got my mk 2 (62) while I was living in British
Columbia. I found it in Coeur D'Alene, Idaho and dragged it back across the
border into Canada a few hours before all the local highways were closed
because Mt. St. Helen's erupted that day. The car is a 3.8 auto with wire
wheels and factory sunroof. It is now time to take the motor out and reseal
it and the transmission since I am getting embarassed about pools of
lubricants I leave everywhere. If anyone can help me out with a source for
the Borg Warner seals as well as engine seals for the 3.8 I would appreciate
it. I was talking to a mechanic who suggested that the rear crankshaft seal
may be replaceable with something more sophisticated than what he called
that "dog turd" type seal (the braided rope). Any ideas?
Date: Mon, 21 Oct 1996 18:02:30 -0400 (EDT)
>a 1991 V12 XJS.
>Opinions??
It is not a small job, but it is straight-forward. If you have
the tools and skills for the job, can afford the down-time, and
really want it done right, then do it yourself.
Thomas E. Alberts
Date: Mon, 21 Oct 1996 18:04:45 -0400 (EDT)
I've had mine closed completely for over a year. On the coldest winter
days (0 degrees F) the car fires right up and idles at 200 rpm (at least
that is what the tach reads). Oil pressure builds straight away. As the
motor heats up it regains its normal idle of about 550 rpm. I don't drive
it until then (corresponds to movement of the temp gauge, now that I have
a mechanical gauge in the loop about 120 degrees F).
John
'82 XJ-S HE
Date: Mon, 21 Oct 1996 18:10:30 -0400 (EDT)
Gee, installing a phone is just about the easiest thing to do. A hot wire
and a ground, an antenna and mount the components.
Installation prices are low because it is an easy job and even easier if
you are just slapping it in. Screws through the leather and all that. My
advice is to take some time, plan it out and do it yourself.
John
'82 XJ-S HE
Date: Mon, 21 Oct 1996 14:20:36 -0500
Subject: Speedometer/Tach readings. & Fuel Tank Cap (XJ6)
I took the first extended trip since the resurection of old #25 this week end.
I made carefull notes on how much fuel was used at different points on the
guage.
Following is a table of the readings I got using the computer to compare
(The computer is VERY acurate)
Left tank Right tank
Actual if guage is acurate
L R
11.2 gallons F 10.6 gallons
11.2 10.6
9.2 gallons 3/4 9.1 gallons
8.4 7.95
5.8 gallons 1/2 6.6 gallons
5,6 5.3
2.4 gallons 1/4 2.6 gallons
2.8 2.65
0.4 gallons E 0.6 gallons
0 0
It apears that they are more accurate than I had thought, but the question I
have is, "Is there a difference in the capacity of the left and right tanks
as this apears to indicate?
Secondaly, is there a way to calibrate them and set them "spot on".
For those who were recently asking about spedometer vs Tach readings:
RPM MPH
2850 74
2700 70
2350 60
2100 55
1800 45
1400 35
This is with a TH350 transmission, but I am told there is no difference in
the final drive ratio between the TH350 and the BW66 so it should hold for
all Series III XJ6s.
I got 21 MPG on a trip of 450 miles. The average speed was 62 MPH and the
cruise control was set at 70MPH / 2700RPM.
JIM I.
"Prefiero morir de pie que vivir de rodillas."
Gen. Emiliano Zapata
1879-1919
Date: Mon, 21 Oct 1996 21:59:19 GMT
In message <961021143947_100025.1253_JHB143-1@CompuServe.COM> Paul Peard writes:
> I am chasing an intermittant overheating problem [snip]
> (I think)
Double-check that. Overheating at speed is usually distributor advance.
I had a stuck stat last year, and my experience was that the engine only got
uncomfortably warm, but did not overheat, so the two-stat set-up of the
V12 does seem to provide some redundancy.
Did you put the suspect 'stat into a boiling kettle to verify your
diagnosis ?
Ah. Quinton Hazell stats, right ? Junk. The jiggle pins ARE necessary,
otherwise you'll end up with air locks in the system which are only purged
VERY slowly as the air dissolves in the water and is transported to the
expansion tank molecule by molecule ;-) Seriously, if you insist on risking
a GBP5000 engine by saving a few quid on non-OEM stats, at least drill a
2mm hole in each of the mounting flanges and mount the stats so that the
hole is highest. That'll emulate the effect the jiggle pins have, albeit
without the one-way valve effect.
(No prizes for guessing how I figured it out.)
Stefan Schulz
'88 XJ-S V12 (with Jaguar thermostats after throwing out the QH ones again)
Date: Mon, 21 Oct 1996 19:17:16 -0400 (EDT)
Paul : Your must use the t/stat with the pin in the 12 o'clock
position, this let air purge from the system, and as air will not
transfer heat, you do not want air in the system. I get my t/stats at
Autozone, and drill a hole in them then install the jiggle pin from the
old stat. Speaking of the RAD how old is it, when was the last time it
was cleaned and when was the last time you removed it and cleaned the
debris from the front of it??? What about the front of the AC cond??
Every little bit helps. I also, in my car like the 180 degree t/stat,
as I tend to drive a little fast.
Chad Bolles Jaguar South 306 Valcour Rd Columbia SC 29212 USA 803 798
> up.
> drive, seems OK
> can result...
> potential problem.
> Regards
> Paul
Date: Mon, 21 Oct 1996 16:18:47 -0700
Subject: Re: Attitudes & Attitudes
At 10:27 AM 10/22/96 +1300, you wrote:
<cut>
>to allow
>Honda.
<cut>
>Regards,
>JKS-XJS CATMBL
Wow!,
Amazing how other people extend you courtesy when driving a Jaguar!
When I drive my Jaguar, I will always get envious looks from others.
However, followed by their "look" I'm suddenly cut-off by their car. Or, I
am never given "a break" when trying to merge into traffic with the car.
It's funny when you drive a nice car like a Jaguar or Mercedes, and
people never seem to give you "a break". But, everytime I drive a Honda or
Taurus, such as a "ordinary" car, most people seem to give breaks when driving.
It's true about the enviousness, no one ever asks what kind of car it
is. They know its something special, desirable, and Expensive! I even had
one lady chase me down to a gas station and told me that it was such a
beautiful car, she would LOVE to own one one day.
Eric
1989 XJ40 Vanden Plas
Date: Mon, 21 Oct 1996 19:24:22 -0400 (EDT)
Julian: If you have never worked on this engine before, just plan on an
afternoon, lay out all your parts, take your time and you can do it.
JUST REMEMBER the cam covers are not held on with head bolts and only
require 8 ft lbs. I have found that a LITE< THIS MEANS LITE coating of
silicone on both sides if the gasket, then install the cam cover and
tighten the bolts by hand, finger tight, leave alone for 4 to 6
hours,giving the silicone time to set then torque,all I have ever done
that way have NEVER leaked.
Chad Bolles Jaguar South 306 Valcour Rd Columbia SC 29212 USA 803 798 3044On
> a 1991 V12 XJS.
> Opinions??
> Thanks
> Julian Mullaney
Date: Mon, 21 Oct 1996 19:32:18 -0400 (EDT)
Subject: Re: '88 XJ-S Shock bushings
Steve: Go to Autozone, Pep Boys, Advance, and just about any good parts
store look for their parts section marked HELP, in red packages look for
shock bushings with part no. ending in 18,(cannot remember the first two
no's) these will work great and only cost around $3.00 a pair. Then the
hard part is installing them, cause you have a gas shock and it is a job
to pull it down and remove the old parts and install the new. So if you
have a helper great.
Date: Mon, 21 Oct 1996 20:11:01 -0400 (EDT)
Subject: Re: Salesmen, XK8, and XJC's
Wow, the complete opposite of the salesman I was with last week. He was
knowledgeable and no BS and encouraged me to beat on the car. And, of
course, he had me inches away from signing on the dotted line, but that's
another story!!
I also find it somewhat annoying the way the XK8 is being marketed as
'XK-E: The Next Generation". The only thing the two have in common is two
thirds of their name (yes, and XK-E is not really the name, either). So
what is the XJ-S, chopped liver?? A twenty year run and 100K built must
mean something. But Jag is falling all over itself to forget them.
John
'82 XJ-S and keeping it
Date: Mon, 21 Oct 1996 20:17:03 -0700
Subject: Screeching Sound
When starting my 1982 XJ6 in neutral this evening, it made a screeching
sound and did not turn over. On several subsequent tries it was fine.
The starter is 4 weeks old (rebuilt) and firmly in place. The old
starter had a 1/16" by 1/16" "v" shaped groove in its gear. This is
just a quirky thing that will never happen again, right?
Any help is greatly appreciated.
Date: Tue, 22 Oct 1996 11:19:18 +1000 (EST)
Subject: Re: Spark plug wire testing - my method
My method of checking spark leads is as follows:
1. Take the leads off including the dist. cap.
2. measure resistance of each lead. It should be between 1000 and 3000 to
4000 ohms. This is common to all the new leads you can get from the auto
shop. Replace suspect leads. You don't need a whole set, you can get high
quality leads of individual length from any auto shop.
3. clean all leads with a cloth soaked with alcohol (metho) to remove dirt
and dust. Do the same with the dist. cap and plugs. Wet dirt conducts
current especially when 10,000 to 20,000 volts is applied.
4. reinstall carefully. make sure that you obey the firing order
remembering that the distributor revolves in a particulate direction.
5. Start the engine. I like the old time method by looking for arcing in
the dark.
6. Get someone to rev up the engine. If any problems exist like internal
arcing or there are high resistance joints, a corona like glow will develop
around the suspect joint, plug or the lead in question.
7. replace all suspect parts and repeat the above test (6).
I have a small supply of leads saved from sets replaced in that past. This
is usually a good source of spares for trouble shooting purposes.
Ned
'61 Mk2
poor
holding the
>course.)
show
>this point?
>Thanks,
>Ed
Date: Mon, 21 Oct 1996 21:29 EDT
Subject: Getting noticed (was attitude)
A young person in a plain 2 or 4 door jag may well get noticed, but picture
me: I am 20 and cruising the streets of Philadelphia in a Daimler 420 LIMO!
It adds to the fact that it is a RHD in the states. For those who don't know
what a 420 LIMO looks llike, here is where I found it:
http://www. voicenet.com/~ctiano/daimler
I got quite a lot of the info to restore it from the jag-web pages.
I think if they can afford it, any young person should go with a Jag.
They are truly one of the great cars of the world. Bill McDowell
Date: Mon, 21 Oct 1996 22:02 EDT
Subject: British DMV info
Hello all: for those owners who have jags and daimler that were originally
registered in the UK and them exported, there is a great service you
know about to find the history of your car. If you write to DVLA Swansea
SA99 1AJ England and enclose 5 pounds ($8 US) and the original
registration # (plate #) they will photocopy all the old title info
and send it to you. For my 70 daimler, they sent all the titles and
the early book type registrations. What a great thing to have.
The copies are from microfilm, so they aren't the greatest quality, but
they are readable. Be sure to ask for a Full History. Bill McDowell
Date: Mon, 21 Oct 1996 20:00:55 -0700
Subject: FW: still leaking XJ-S/ BATHTUB
Here's the latest in this continuing series. It looks as if the leak
is, in fact, coming from around the windshield seal (where the rubber
meets metal). I will have it sealed as quickly as possible. Also,
while investigating leaks, I found that "when it rains it pours". By
that I mean that the rear window seal also is leaking.
My questions are:
1) Should I be looking for some sort of specialist who frequently works
on Jags, or will a standard auto glass shop do the trick?
2) How much should I expect to pay for both front and rear re-seals?
Thanks in advance for all replies
Aaron
'85 XJ-S
>From: Aaron Burnett[SMTP:aaron.burnett@mccaw.com]
>Sent: Friday, October 18, 1996 8:53 AM
>To: 'jag-lovers@sn.no'
>I should have added another detail to this account. My car was hit in
>the driver's side about two months ago. The door was replaced and the
>driver's side front quarter panel was pulled back into shape. All new
>seals were installed. Perhaps there are seams I should be looking at?
>Thanks again,
>Aaron
>'85 XJ-S
>>From: Aaron Burnett
>>Sent: Friday, October 18, 1996 8:42 AM
>>Subject: still leaking XJ-S/ BATHTUB
>>This is the next part in a continuing series on my still leaking '85 XJ-S.
>>I
>>realize that "leaking" can describe many types of XJ-S problems involving
>>many different types of fluid, so please allow me to clarify:
>>I live in Seattle, Washington and, whenever it rains (which is very often!),
>>my car leaks rainwater onto the driver's (my) legs -- and I don't mean just
>>a
>>little.
>>I have tried the following to fix the problem:
>>1) Used flowable silicon to re-seal the windshield seal were the rubber
>>meets the glass -- it all looks very watertight now.
>>2) Used flowable silicon between the windshield seal and door posts on both
>>driver's and passenger's sides (I removed the chrome door post cover first).
>>3) Cleaned the drains leading from the cavity in which the wiper motor is
>>mounted to both front wheel wells.
>>4) Used silicon (both flowable and standard -- I'm living on the edge
>>here!)
>>to seal the drainage channel that leads from the lower driver's side corner
>>of the windshield (below the seam between the front quarter-panel and the
>>rear hood area) and into the recessed channels in which the hood mounts. I
>>sealed this at both top (windshield side) and bottom (hood side).
>>AND STILL, WATER BUCKS INTO MY CAR!
>>I have no other ideas and I've run totally out of silicon.
>>Please help!!
>>Aaron (how many gallons do you think that is?) Burnett
>>'85 XJ-S
Date: Mon, 21 Oct 96 23:10:38 EDT
Subject: 88 VDP XJ40 purchase
Thanks everyone for the help in telling me about the XJ40 88 I inquired
about. I still have not purchased it yet!!! One important Q. that I did not
get any answer to is what is the average life of a Jag engine/ Trans? I know
that it all depends on how the car was driven... This one has 104K Mi. on it
driven by an older man mostly Hi way.
I spent a very long part of my day today thinking about this car. It is so
beautiful, but I don't want to make a mistake.
The local Jag mechanic has been taking care of the car for a long time, so
I do not know if he will tell me the truth about the condition of the car!!!
Also, what is the difference between the engines of the XJ40 and the
XJ6?
Thanks again
Dikran
Date: Mon, 21 Oct 1996 21:12:37 -0600
Subject: Re: Lurking
>Date: Thu, 17 Oct 1996 21:01:11
>To: Ashley Rolfe <Ashley@viglen.co.uk>
>From: Veronica Coats <rccola@ctos.com>
>>I won't bore you all with newbie FAQ's, but I will ask you all about the
>>attitude I'll receive off other drivers. I'm only 25, and I get the
>>feeling that others might think I'm trying to be something I'm not if I
>>buy a Jag - when in fact I'm just getting one because I've always wanted
>>one.
>>Ash.
>>Hi Ash
> I am 40 and bought my Jag aprox 3 months ago. I live in the same
proximity of the U.S. as Lawrence does. (No. Colo.) I have had nothing but
good comments about my cat. I did have a problem up in Black Hawk (mountain
gaming town in Colo.) about a month ago. I left her in the parking lot for
about 4 hrs. and had 2 new scratches on the bonnet. To say the least I will
drive my daily driver when I go gambling from now on. It is a 1990 Chevy 3/4
ton pickup. My Kitten grabs a lot of attention mainly because there are not
many where I live. Used Jags are not expensive around here (I'ts all
relative you know) but maintenance will be because I live so far from my
service dept. I don't see many women driving them, but, I have always been
of the impression that an uninformed or misinformed female is vulnerable. I
also don't live by the rules very well. Buy one. Drive it and have fun. Who
cares what anyone else thinks. I bought mine because I love to drive.
> Veronica
>'89 XJ-S V12 convert.
End of jag-lovers-digest V2 #455
id <PAA02360> for jag-lovers-digest-out; Tue, 22 Oct 1996 15:18:48 +0200 (MET DST)
Date: Tue, 22 Oct 1996 15:18:48 +0200 (MET DST)
Message-Id: <199610221318.PAA02360@ekeberg.sn.no>
Subject: jag-lovers-digest V2 #456
Precedence: bulk
jag-lovers-digest Tuesday, 22 October 1996 Volume 02 : Number 456
Locating a loose tappet guide.
Old Gasoline (Followup)
Fuel tank capacities, oil pres, temp. (XJ6)
Re: Locating a loose tappet guide.
Re: JAGUARS AT BATHURST.
Stoneleigh 27th October
Re: Lurking
Attitude - old vs new (cars)
Re: Attitude
Re:Positive Ground to Negative Ground Conversion
One more on attitudes
XK8 impact upon XJ-S market?
XJ-S starting problem?
Attitudes
Re: Jaguar Fresh Air Vent Troubles...
Re: Screeching Sound
Sovereign pics
RE: Attitude
Lurking (attitudes towards Jag drivers)
Welcome to xk-lovers
Date: Mon, 21 Oct 1996 21:01:45 -0700
Subject: Locating a loose tappet guide.
I drove my XJ6 on a quick 120mi trip last week. When I got off of the
freeway and stopped at a service station, I heard the dreaded
clickety-clack associated with loose tappet guides. Several weeks ago I
fitted a stake-down kit to the exhaust side. (I had the engine apart
anyway.)
The noise is now pretty constant. I pulled the valve covers and cannot
locate any obvious damage. (I drove the vehicle 160 miles with the
clacking) I'm trying to determine whether this is just tappet guide
clatter or a more serious problem-- which I don't have a clue as to what
it is...
I've tried:
1)pulling spark plug wires while engine is running -- no change.
2)compression test (To see if it could be a loose valve seat) -- OK
3)Pulling cam covers -- no damage to cam lobes or guides.
4)checking timing chain tension (Fine)
I can't seem to pin-point the exact tappet guide that is making the
clatter. Should there be visable damage? It is pretty noisy...
What other probs would cause this type of clatter?
- -Pessimist: "This ship is sinking." -Optimist: "This ship is half full."
Curt Onstott - Windows/DOS/PC Specialist - Information Services -
Oregon
State University. - (541) 737-1483 - Office: Kerr 217
Date: Mon, 21 Oct 1996 21:22:35 -0700
Subject: Old Gasoline (Followup)
A few days ago I asked about how bad gasoline should be disposed of.
The two suggestions I got were to: mix small amounts with a fresh tank
of gas and burn it in your engine or to burn it in small amounts in a
coffee can.
It seems that the reason that gasoline tends to go bad is that it
oxidizes. This can be prevented by: 1)topping off your tank before
storing a vehicle for an extended period of time. 2)Adding a stabilizer
to the fuel. I found a really good faq on gasoline at this URL:
http://www.paranoia.com/~filipg/HTML/AUTO/F_Gasoline.html
Oregon
Date: Tue, 22 Oct 1996 00:49:17 -0005
Steve Draper <s_draper@wcsr.com>:
Get them at any auto parts store, a good price is a couple bucks
each.
| - Palm's Postulate
Date: Mon, 21 Oct 1996 23:02:10 -0500
Subject: Fuel tank capacities, oil pres, temp. (XJ6)
Sorry about the reformating caused by the mail server. Here is
the table that got messed up in my last post.
Measured capacity Actual capacity
(using computer) (if guage was perfect)
L R L R
11.2 gallons F 10.6 gallons 11.2 10.6
9.2 gallons 3/4 9.1 gallons 8.4 7.95
5.8 gallons 1/2 6.6 gallons 5.6 5.3
2.4 gallons 1/4 2.6 gallons 2.8 2.65
0.4 gallons E 0.6 gallons 0 0
as this apears to indicate?"
Secondly, is there a way to calibrate them and set them "spot on"?
Also, I might note that for all of you that are wondering how cool your car
*COULD* run and what the oil pressure should be when its running properly,
here is the information on an engine with 116,000 miles on the clock.
The outside temp during this trip varied from 75F to 90F. The AC was
running continualy during the trip. The engine temp never got above 85C
which is just three degrees above the thermostat temp. Yes, Virginia, a Jag
that is running properly will stay cool. Before the rebuild I had to add
about a quart of water every month or so. Now the radiator stays topped up
with no additional water needed. I think I had a leaking heater core since
I had fog spots on the windshield before the rebuild and the new body came
with a new heater core.
The oil pressure at 70 MPH was 55lbs and at idle it droped to 35lbs. I am
running a 20W-40 synthetic oil (Quaker State)and I have *NO* leaks. It used
to leak before I started running the synthetic oil.
Jim
"Better an outlaw than not free."
Nance O'Neil
Date: Tue, 22 Oct 1996 16:31:27 +1000 (EST)
Subject: Re: Locating a loose tappet guide.
This may be a low tech solution but it is an old trick that could help.
Take a large screwdriver and place the sharp end on the engine with the
thing running. Place you ear to the handle and listen to noises at
different spots. If you survey the engine you should be able to at least
locate the cylinder in question if not the guide that is causing the problem.
Hope this helps.
Ned
'61 Mk2
PS You can get a stethoscope specifically made for this purpose.
>Oregon
Ned Blagojevic
Environmental Science Division
Australian Nuclear Science Organisation
PMB 1 Menai, NSW 2234
Australia
email: nbx@ansto.gov.au
phone (w)int 61-2-717-3660
fax int 61-2-717-9260
Date: Tue, 22 Oct 1996 17:14:33 +1000 (EST)
Subject: Re: JAGUARS AT BATHURST.
Greetings from downunder,
Interest was expressed earlier this month by a number of subscribers in
obtaining a copy of a Video with the highlights of the 1985 Bathurst 1000
Touring Car Race, won that year by a Walkinshaw Jaguar XJS.
I have found out that the Commercial distributors of the Bathurst Race
Highlights videos in Australia is currently FESTIVAL RECORDS. They are
retailed through K-Mart (amongst others) out here and the serial number of
the 1985 Video is ** V82310. **
1. Currently there IS still stock (at Festival) of that one at $A29.95 each.
If you are not able to order it through your local retailers, let me know
and I can organise it at this end for you.
( N.B. 2. The video is only available here in the 'PAL' format and would
need to be converted if required for viewing on an 'NTSC' system, if
applicable.)
regards,
Jim Ellis.
(1963 Daimler 2.5 v8 Sedan)
Jim Ellis
Internal Auditor
University of New England,
N.S.W. 2351.
AUSTRALIA.
'phone: (067) 733497;
[national: +61 67 733497;]
fax: (067) 733314;
e-mail: jellis@metz.une.edu.au
Date: Tue, 22 Oct 1996 09:40:06 +0200
Subject: Stoneleigh 27th October
Note to all Jag-lovers meeting at Stoneleigh on Sunday 27th for
the Spares Day.
We have now composed an "official" badge to help in recognizing
fellow Jag-lovers. Please request it from me or Roly. It comes
as a GIF-file that must be printed out before wearing it (you
could try bringing it on a floppy, but it probably wouldn't be
as effective...). After printing the graphics you can staple it
to your forehead, duct tape it to your arm or, preferably, place
it in a nifty id-holder like you get at trade shows etc.
Nick
Date: Tue, 22 Oct 1996 08:46:54 +0100
I'm 47 and wifes car is a Fiat Tipo, was an Uno until very recently.
Perhaps people are kinder to Jaguars in the South Midlands, people will
stop and let my '83 XJ6 into a stream of traffic. No such luck for the
Fiat!
True, I just them get on with it, it is more comfortable than being tailgated!
>"Niceness"
I find it surprising how many others ignore as though one did not exist,
the worst offenders are the ones with same model as mine. They never
wave back.
>Police:
>than others.
Same for the MOT test...
Roly
Green Lane,
1983 XJ6 S3, Grosvenor Brown, 116K on the clock.
From: brownd@filon.ml.com (Dave Brown - London Dev X1818)
Date: Tue, 22 Oct 96 09:14:10 BST
Subject: Attitude - old vs new (cars)
I've noticed a marked difference in other road users attitude to my car in my
"new" (1988) XJ12 than when I drove the "old" (1967) Daimler 250. With the old
car people usually just gave admiring glances and made allowances at junctions,
etc. by letting you out if the traffic was busy. With the new car that just
doesn't happen. That doesn't mean to say other road users are now overly
aggressive to the newer Jag, just more normal (which for non-London list members
means quite aggressive anyway!! :-) )
I've not had any "bad" experiences yet in the new car but I've only been driving
it a month.........
BTW. I'm "only" 33 so could still be considered quite young for a Jag owner :-)
David Brown,
brownd@ml.com
_______/\/\/\__________/\_____/\__________/\__/\/\/\/\/\____/\/\/\_________
_______/\____/\_______/\/\_____/\________/\_______/\________/\____/\_______
_______/\_____/\_____/\__/\_____/\______/\________/\________/\_____/\______
_______/\______/\___/\____/\_____/\____/\_________/\________/\______/\_____
_______/\_____/\___/\/\/\/\/\_____/\__/\__________/\________/\_____/\______
_______/\____/\___/\________/\_____/\/\___________/\________/\____/\_______
_______/\/\/\____/\__________/\_____/\________/\/\/\/\/\____/\/\/\_________
Date: Tue, 22 Oct 96 10:06:28 BST
OK. I was in my rep-mobile ('87 2.0 Cavalier (Sunbird in the US?)) the other day
coming off a roundabout onto a piece of dual carriageway. I accelerated through
the gears from second up to about 95 mph before settling down to about 85. I was
hitting around 5000, 5500 rpm whilst accelerating so I wasn't exactly hanging
about. Anyway, there just happened to be a Jag (late '80s XJ6 I think) on the
dual carriageway that I overtook. It was driven by an oldish man. He must have
been going at around 70mph when I overtook him (probably can't afford the
petrol) but he must have been upset that an ageing Cavalier was able to overtake
his superior Jaguar so he sped up and ended up catching me up and overtaking at
about 90mph in a now 40mph limit only to then stop and turn right off the road
(in the UK this is). His wife must have been driving the Volvo that day (sorry
M).
Over here in the UK we really do have car snobbery. I often like to drive my Cav
because I know nobody's going to think I'm showing off (especially in the area
that I live in).
Just how does a 5.3 HE XJ-S compare to say a 130 bhp 2.0 hot-hatch in a 'burn
up' in a straight line?
Oh and another thing, you'll occasionally be very surprised by the performance
of some of the Minis out there.
Steve (in the UK)
Date: Tue, 22 Oct 96 09:11:35 gmt
Subject: Re:Positive Ground to Negative Ground Conversion
The very first thing I heard as I connected the battery to my S-Type after 10
years of work, was the tick-tick-tick of the (+ve earth) clock. Mind you, it
only works when the car is driving. When I turn off, the clock stops after a
few minutes :-)
* Alastair Lauener Work Phone +44 131 455 2458 *
* Chief Technician Fax +44 131 455 2267 *
* Department of Building & Surveying *
* Napier University, Edinburgh EH10 5DT a.lauener@napier.ac.uk *
* 1964 3.4 S-Type story at http://www.sn.no/home/nick/alas.html *
Date: Tue, 22 Oct 1996 07:14:11 -0400
Subject: One more on attitudes
When I'm driving the AH3000 around, I get lots of admiring looks and
comments. Driving the 66 E I get these "sideways" looks and the
"avoidance of eye contact" looks. Of all things, don't try pulling into
a merge lane with one----it sends a signal to the other guy that says
- --don't let him in- don't let him in!
Wish I knew why.
Tom
Date: Tue, 22 Oct 96 08:04:39 EST
Subject: XK8 impact upon XJ-S market?
All this talk has got me wondering how I might afford to buy
an XK8.
Not really - but it did start me wondering about how the used
XJ-S market might be impacted by the availability of the new
car.
One could argue that since there won't be any more XJ-S cars -
the supply is limited- that the prices might begin to rise.
On the other hand you could think that some potential buyers
are now going to buy XK8's - the demand is reduced - so the
prices might begin to fall.
Or maybe both are true, and the prices will stay right where
they are.
What do you think? Will I be able to retire on the revenues
from my XJ-S if I keep it real clean and sell in 20 years?
- mclaus ('93 XJ-S Convertible)
Date: Tue, 22 Oct 1996 08:22:49 -0400
Subject: XJ-S starting problem?
My '91 XJ-S (V12) has recently started exhibiting some odd behavior
when I start it for the first time in the morning. It seems to want
to immediately idle at about 2000 rpm in park. That *can't* be good
for it. :-)
I can work around the problem by putting the car in gear, and,
typically by the time I've reached the corner, the idle (in neutral)
is down to about 1500. In only a few minutes, it's idling normally
again. At all other times the car runs well.
Where should I start looking?
Bill Frenchu |"Back when *I* was a
wrf@pluto.njcc.com (609) 466-2604 | boy, we carved our
http://ourworld.compuserve.com/homepages/wrf | own IC's out of wood."
Date: Tue, 22 Oct 96 08:26:49 EST
Subject: Attitudes
My question is - how do you know it's the car that is getting
the looks?
When I am driving my Jag - I admit it gets a few looks.
But when I am driving the car with my wife - or another
attractive woman - I get a whole lot more looks! I'm not
convinced it's the car they are looking at :-)
Date: Tue, 22 Oct 1996 08:29:47 -0400 (EDT)
Subject: Re: Jaguar Fresh Air Vent Troubles...
To all those that can offer advice,
I own a 1985 Sovereign Series III Euro Model. A very nice car
except the fact that it leaks water through the fresh air vents in the
front cubby directly in front of the windsheild. Can anyone tell me if
these vents are supposed to stay closed after the car is turned off
because mine don't and if it rain hard water finds its way up there and
the mats are then soaked. The evaporator drains that get rid of the
water are clear of debris and seem to pass water well. Also with the
vents closed (Only when the car is running in my case) the vents don't
leak at all. Is there a solution to this problem and is this just a
fault in engineering or are the vents supposed to be closed after the
car is off.
I would appreciate any and all advice on the subject!
Thanks
Theo Bremner
tbremner@lynx.neu.edu
Date: Tue, 22 Oct 1996 08:41:59 -0400 (EDT)
Subject: Re: Screeching Sound
Dennis: Sounds like the solenoid did not engage the starter gear with
the flywheel, may not happen again,but who knows. Concerning the starter
gear on the old starter, I hope that you replaced the flywheel when you
did the job,cause the wear pattern on the flywheel is still there and
will wear the new starter gear.
Date: 22 Oct 96 14:02:55 GMT
Subject: Sovereign pics
Does any know of any XJ6 Series III screen savers?
Dieter Hachenberg
Date: Tue, 22 Oct 96 13:06:10 UT
Subject: RE: Attitude
If a straight line "burn up" is your criteria then perhaps you should limit
your
car interests to the little 2 litre hatches and leave the rest of us to
appreciate Jaguars.
p.s. perhaps the old man could afford the petrol?
From: owner-jag-lovers@sn.no on behalf of Steven_Adderson@sandwich.pfizer.com
Sent: Tuesday, 22 October 1996 22:06
day
through
was
have
overtake
at
M).
Cav
that I live in).
Steve (in the UK)
Date: Tue, 22 Oct 1996 22:11:00 +0100
Subject: Lurking (attitudes towards Jag drivers)
What a response! Thank you all very much for your comments and insight
into my inquiry. It seems that although I might have to prepare myself
for some negative feelings from other drivers - to hell with it! If I'm
sitting in the car I've wanted for 15 years, I shouldn't really care if
people try to race me and challenge me.. I'm 100% decided to get one.
Oh no, the next decision ... XJS or XJ6...
Date: 22 Oct 96 09:15:33 EDT
Subject: Welcome to xk-lovers
- ---------- Forwarded Message ----------
From: INTERNET:Majordomo@honcho.ColumbiaSC.NCR.COM, INTERNET:Majordomo@honcho.ColumbiaSC.NCR.COM
TO: John Elmgreen, 100353,1733
DATE: 22-10-96 12:52 AM
RE: Welcome to xk-lovers
Sender: owner-xk-lovers@honcho.columbiasc.ncr.com
Received: from honcho.columbiasc.ncr.com ([153.78.17.231]) by hil-img-6.compuserve.com (8.6.10/5.950515)
id AAA23494; Tue, 22 Oct 1996 00:35:37 -0400
Received: (from majordomo@localhost) by honcho.columbiasc.ncr.com (8.6.12/8.6.12) id EAA29364; Tue, 22 Oct 1996 04:35:35 GMT
Date: Tue, 22 Oct 1996 04:35:35 GMT
Message-Id: <199610220435.EAA29364@honcho.columbiasc.ncr.com>
To: 100353.1733@compuserve.com
Reply-To: Majordomo@honcho.ColumbiaSC.NCR.COM
Welcome to the xk-lovers mailing list!
If you ever want to remove yourself from this mailing list,
you can send mail to "Majordomo" with the following command
in the body of your email message:
unsubscribe xk-lovers 100353.1733@compuserve.com
Here's the general information for the list you've
subscribed to, in case you don't already have it:
[Last updated on: Tue Oct 22 2:35:25 1996]
Welcome! You are now a charter member of the XK-Lovers mail list.
Now, instead of copying everyone on the list just send your messages
to "XK-Lovers@listserv.columbiasc.ncr.com". Majordomo will send
it to all members. There is no need to subscribe; I have already done
that for you. Below is the introductory message that all new members
will receive when they subscribe. Please read it and send me your
suggestions. Corrections are easy. Why, just last week I had John
Elmgreen living in Melbourne and "poof" now he's back in Sydney.
If you need to change your e-mail address, simply unsubscribe with
your old address and subscribe with your new address. You may also
send me e-mail [dick.white@columbiasc.ncr.com] and I'll do it for you.
** Please save this file for later reference. **
What is the XK-Lovers Mail List?
- XK-Lovers is an international network of Jaguar XK model automotive
owners and enthusiasts dedicated to enjoying and maintaining the
breed. Jaguar XK models were in production from 1948 to 1961
and include the XK120, XK140, XK150, C-type, D-type, and XKSS.
- Linked globally in real-time via the Internet, a global electronic
mail (e-mail) network, we discuss various topics such as the daily
dramas of owning the things, car maintenance, restoration, racing
and such. Together, we provide an informal support system which
ranges from sharing technical information and locating spare parts
(or even whole cars) to swapping tales of adventure and daring-do.
- The scope of this group is simple; discussion is open to any subject
involving Jaguar XK automobiles. Currently approximately 65 folks
are on the list, not all of them owning Jaguars, some wanting to get
information before they make the plunge, others simply admirers of
the marque. This list formed as an offshoot of the 'jag-lovers'
mail
list, a much larger mailing list dedicated to owners and admirers of
all models of Jaguars. The XK-Lovers list was formed by members
who wished to focus discussion on the XK models. Of course many
members of the list own other models of Jaguars.
- XK-Lovers was formed initially by John Elmgreen in February, 1996
with 4 members. John managed the list manually from Sydney,
Australia until October, 1996. Membership grew rapidly to 65
members necessitating automated list management. The list is
now based out of Columbia, SC with Dick White as the administrator.
New members from any continent and nation are welcome.
The list's location does not make it a "USA" or "North American"
Jaguar XK mailing list..
How busy is this list?
- The XK-Lovers list currently averages less than 5 messages per day.
How do I join?
- Send e-mail to majordomo@listserv.ColumbiaSC.NCR.COM with
subscribe xk-lovers
in the body of the message.
If you have problems, send a message with just "help" in the body.
Majordomo will send you help.
- When you join the xk-lovers list, you are encouraged to introduce
yourself and tell us a bit more about yourself and your car(s). For
example, tell us about the Jaguar(s) you have (or want) and any
adventures that you've had finding, buying or owning it. Your
Jaguar-related tales of treasures found, repairs, racing, rallying
and any general misadventure are always welcome.
- As a new member you are encouraged to advise of the original
numbers of your car(s). . John Elmgreen is compiling a worldwide
XK Register and doing research on originality for a possible book.
Names, addresses and any known history are requested for this
project, You may find your name and car(s) iconified in John's
book some day.
How to post to the list:
- Send your message to xk-lovers@listserv.ColumbiaSC.NCR.COM
and from there it will be relayed to all the other list-members.
Are there any rules?
- There are no formal rules.
- Commercial abuse of the list is not allowed. (ok, there's one formal
rule)
- Often some of the postings to xk-lovers make great material for
local club newsletters. This practice is encouraged and helps
advertise the utility of the net. However, don't assume that you
have the author's permission to copy his or her material. The
informal
rule we go by is that if you want to include anything off the
xk-lovers list in a local club newsletter, first get the author's
permission and offer to send a copy of the issue in which the
article appears.
- Postings may be used for the XK section of the Jag-Lovers WWW site,
for general information of web browsers etc. and as publicity and
examples of the type of material to be found on XK-Lovers.
- Also, be assured that you are among friends here. It helps everyone
if you relate both where things went wrong as well as where things
go right when working on your Jaguar. We all learn from it.
Administrator of the list is Dick White (dick.white@ColumbiaSC.NCR.COM)
** Now, did you save this file? **
End of jag-lovers-digest V2 #456
id <XAA24012> for jag-lovers-digest-out; Tue, 22 Oct 1996 23:17:33 +0200 (MET DST)
Date: Tue, 22 Oct 1996 23:17:33 +0200 (MET DST)
Message-Id: <199610222117.XAA24012@ekeberg.sn.no>
Subject: jag-lovers-digest V2 #457
Precedence: bulk
jag-lovers-digest Tuesday, 22 October 1996 Volume 02 : Number 457
XK-Lovers: new mail list
Re: Attitudes
OK, I give up. on the Tank Capacities.
Re: Attitude
Re: More attitude & to pootle or not to pootle
XJ6/12 77-79 door panels
sunroof motor/gearbox SIII
XJ6 Screen savers
Re: Positive Ground, Jaguar attitudes
Re: voltage regulator
Re: Attitude
Re: Attitude
V-12 Valve cover gasket
What color is my interior?
H2O in Air vent
Re: Attitude
Re: XJ6 Screen savers
Tappet guide/stakedown kit.........
Attitudes
My new XJS-V12
Date: 22 Oct 96 09:15:58 EDT
Subject: XK-Lovers: new mail list
Well it has finally happened! After 8 months as an informal email group, XK
Lovers has gone majordomo - see attached message. It's an exciting development
for all of us, and a result of the growth of the group from 4 (Feb 96) to about
64 (Oct 96). All are welcome. There is not a heavy mailload at this stage,
maybe 3-5 per day (no digest yet available, but not needed). Regards, John
Elmgreen
Date: Tue, 22 Oct 1996 09:28:19 -0400
Hmmmm...
I never thought that it could be my car!
Mike said;
the looks?
Charles Daly, Toronto, Canada
'62 E-Type, ots
Date: Tue, 22 Oct 1996 09:29:48 -0500
Subject: OK, I give up. on the Tank Capacities.
Can anyone tell me why I cant get a table to format correctly when I post it
to this list?
It is either line wrapped or it is all squashed to the left with most of the
spaces removed.
I am not using any tabs, just spaces to format it yet it is always screwed
up when it shows in the list.
JIM I.
1879-1919
Date: Tue, 22 Oct 1996 23:40:28 +0900
> to allow
> Honda.
snip
Hereabouts up North from NZ, I had the experience in the mid '80s of
people giving way whenever I drove my then vehicle of choice, a
Mercedes 300D, around. Well, no wonder. Those days any Mercedes C
class and above were the vehicle of choice of the mob (the upscale
mobs have since moved up to the Rolls and Bentleys -- fortunately
somehow they've bypassed the Jags).
I do know that people give their way to Jags too. That however I think is the
function of the onerous costs to your insurance policy when you do
hit a (perceived) expensive car.
Makoto Honjo
Phone/Fax +81-3-3473-1848
Date: Tue, 22 Oct 1996 16:43:34 +0200 (MET DST)
Steve,
I'm not sure if all Jaguar lovers share this opinion. I have a XJ-S V12 myself
and must say that I really don't care too much which 2.0 litre can outperform
it. I like the car for being a Jaguar, I like to drive it and I'm not
looking to impress others with it. For me these cars are just master pieces.
Matthias (in France)
> Steve (in the UK)
Date: Tue, 22 Oct 96 15:39:34 BST
Subject: Re: More attitude & to pootle or not to pootle
Oh dear I seem to have upset somebody by actually suggesting that one
can use the 5.3 litres to go quickly. Owning a Jag doesn't mean one
*has* to pootle along does it?? I was wondering whether people found
that the HE XJ-S's were quick all the time or just quicker than, say a
two litre eurobox, at highish speeds. It seems to me that smaller
cars tend to be quick off the mark but also tend to loose out to
larger cars (with bigger engines) once they get going. The classic
Mini drivers' quote is "yeah, it's only a one litre but it'll beat
anything off the lights" - up to 10mph that is :) (ask me I know).
Minis weigh what, about 1500lbs? Does the 4000lbs significantly
hinder the XJ-S when wanting to get around town quickly? Also what is
the performance difference between the 12 and 6 cylinder cars?
If "a straight line 'burn up'" really was my criteria I wouldn't drive
a 30hp 0.85 litre Morris Mini now would I? Max speed about 80mph and
0-60 in...er...what day is it? I am thinking about getting an XJ-S,
in addition to my other cars, because, apart from the fact that I just
like them, I want the smoothness and quietness, I want the leather
upholstery, I want the air-con and other gadgets, but I also want it
to be quick!
The other point I was merely wishing to make is that it's not just
some non-flashy car drivers who want to "out do" some flashy car
drivers but also that some people get upset when an, in their opinion,
inferior car overtakes them. This Jag driver seemed quite happy
driving along at 70. Nothing wrong with that - it is the legal limit
after all. Trouble was, when I went passed, something made him *have*
to overtake me even if it meant doing it at 90mph in a 40mph limit in
the last 200 metres of an upcoming lane closure.
From reading this list it seems that people are generally friendly and
nice and I wasn't intending to offend anyone. I don't usually like to
get into exchanges about who's right and who's wrong but I thought I'd
reply so that fewer people would take my last message the wrong way.
Steve
______________________________ Reply Separator _________________________________
Author: "Stephen Stewart" <SAPLSTEWART@msn.com> at CR_SAND_SMTP
Date: 22/10/96 13:06
your
appreciate Jaguars.
Date: 22 Oct 96 10:13:20 EDT
Subject: XJ6/12 77-79 door panels
A new in-the-box set of leather door panels for a '77-'79 XJ6/12 (no
weld line, no kick carpets) have come into my possession. These panels
sell for around $400 for the set. As I own an XJ-S I have no use for
these panels; however, some member on this list may have a use for them
so I am offering them for sale to the highest bidder.
The proceeds of any sale will be happily spent on Fritz the Jag who
having expended many of his nine lives is rapidly making a comeback.
If you are interested you may contact me at rwoodlin@indiana.edu.
Robert Woodling
'84 XJ-S
Date: Tue, 22 Oct 96 18:24:00 PDT
Subject: sunroof motor/gearbox SIII
Hello!
Does anyone know if the drive wheel in the sunroof-gearbox comes as a
single spare part. It is white and made of some plastic material. Mine
has lost several cogs which is why the sunroof got stuck 10 cm open.
Are Lorentsen
Narvik, Norway
82XJ6
Date: Tue, 22 Oct 1996 11:25:27 -0500
Subject: XJ6 Screen savers
<snip>
>Dieter Hachenberg
Windows95 and others will let you set up a neat screen saver without using
up all the space required for a seperate program. When you are on the WEB
and see the picture of the XJ6 that you want. Save the image, usually a
.gif file. There are many, many programs around that will allow you to
convert it to a .bmp file. Once converted put it in your c:\windows
subdirectory. Next go to "Control Panel" select Desktop or Display
Properties, depending on release of Windows, and set up your screen saver.
You can have it tile or not so you will have multiple images or just one.
Result your own unique screen saver.
Date: Tue, 22 Oct 1996 12:44:58 -0500
Subject: Re: Positive Ground, Jaguar attitudes
>> It is actually possible to run a negative
>> ground radio in a positive ground car, I did it for 2 years.
>Sounds pretty dangerous - what about the ground wire to the antenna?
>Probably not much of a problem, wanting a new radio is usually one of the
>main reasons people switch to negative ground anyway.
>Egil
I had to remove the shielding from a portion of the antenna cable to
prevent it from grounding, this affected reception but not too badly. It
did have the benefit of allowing the ignition system to be heard clearly on
AM, it turned out to be useful for tracking down a misfire I once had. This
definitely wasn't an ideal situation, but at that point I had no idea how
easy it was to switch the battery polarity, so I lived with it for a while
and it worked quite well.
On another note, I bought my mk2 when I was 15, it was a complete wreck. I
worked on it 40-50 hours a week after school(I was fortunate that my dad
had the expertise and many of the parts I needed), and it was more or less
driveable by the time I got my learner's permit at 16. Since then I've done
a rolling restoration, and it has been my daily driver for the last 4
years(in the summer).
I do get a lot of dirty looks from drivers who seem to think that I
don't deserve to be driving a jag at 20, but I really don't care. I am
content in the knowledge that I am driving a car that can compete in
performance and comfort with new cars that cost 10 times what I have in my
mk2(not counting 2000+hours of labor) On the whole, I get mostly positive
reactions, many waves and thumbs-ups. I certainly haven't been cut-off or
had anyone actually do anything malicious. I have been to a few shows, and
with one or two noteable exceptions, people seem to be happy to see a
younger person actively involved. I'll get off my soapbox now, but this is
an issue that I feel very strongly about. If you're willing to treat your
car well, there's no reason that age should keep you from driving a jag. (I
do get a bit upset by some of the people around here whose parents but them
a 40k+ brand new car for college when they don't even know how to drive,
but that's another story)
regards,
Braman
1963 mk2 Coombs replica
1966 Land Rover 88"
Date: Tue, 22 Oct 1996 12:45:02 -0500
Subject: Re: voltage regulator
Ahhh, the evil Lucas voltage regulator! I believe the WL stands for Warning
Light. I believe the best thing to do with these units is remove them from
the car, carefully remove the cover, clean the contacts with fine emory
paper, and then smash them into bits with as large a hammer as you can
wield.
Braman
Date: Tue, 22 Oct 1996 09:56:08 -0700 (PDT)
>To: owner-jag-lovers@sn.no
>From: ola@community.net (Steven and Ola Peters)
>I have to agree with my fellow jag-lover from California. I live in
Northern California and Jaguars are pretty common. I do get an occasional
glance from a passerby, and this glance is usually associated with a
friendly smile. When a stranger talks to me about my car, a compliment on
how good the car looks is always included.
>Perhaps some areas of the world view Jaguar owners as snobs; these people
are entitled to their thoughts and opinions. Nobody has the right to harm a
person's body or damage their property. Could there be a need for better
law enforcement or even a little self defense in a strong form?
>Ola Peters
>84 XJ6 VP
Date: Tue, 22 Oct 1996 18:10:20 +0100
On Tue, 22 Oct 1996 16:43:34 +0200 (MET DST) Matthias FOUQUET-LAPAR <mfl@kheops.cray.com> wrote:
> Steve,
Quite right Matthias,
the point I was trying to make was that it matters to THEM (the
other, non-jag people) not to the average Jag driver. I am
constantly amused by the fact that although all I am doing is
cruising along (at whatever speed) others (particularly drivers of
hot-hatches and rep-mobiles) seem to find it a matter of pride to
overtake. (The fact that some of them may well be able to out
accelerate me in various conditions is neither here nor there).
Mark
Mark Stiles
90 Daimler 4.0
Date: Tue, 22 Oct 1996 10:24:38 -0700
Curt, get a long screwdriver to use as a stethoscope. Place the handle
against your ear and rest the blade end against NON MOVING parts of the
engine to locate the source of the noise. Lee
- ------------------SNIP -------------
> From: Curt Onstott <onstottc@ucs.orst.edu>
> it is...
Date: Tue, 22 Oct 1996 13:41:34, -0500
Subject: V-12 Valve cover gasket
$450 sounds like a lot of money to replace valve cover gaskets. You
should be able to do it yourself anyway. Either that or find a more
reasonable mechanic.
Date: Tue, 22 Oct 96 13:58:12 EST
Subject: What color is my interior?
Hi list.
Here is a silly sounding question - but I'll ask anyway.
My car's interior color I would call 'tan'. But apparently
Jaguar has made several colors which I would call tan. The
car's trim code is 'AFW'. Does anybody know the name of this
color. Is it what is sometimes called 'biscuit'?.
Does anybody have a list of trim codes with the corresponding
names?
Thanks in advance
- mclaus ('93 XJ-S)
Date: Tue, 22 Oct 1996 13:39:29, -0500
Subject: H2O in Air vent
You should NOT have water cming out of your airvent. It sound like
you have a seriously plgged water drain, which should be repaired
ASAP.
Date: Tue, 22 Oct 1996 15:11:18 -0400
'burn
performance
My Mini Cooper makes me laugh my a-- off when I drive it. It is the MOST fun to
be had on 4 wheels (and occasionally on 2 wheels!). So why am I selling it to
pay for the motor rebuild on my E-type ???
Mark McChesney
love conquers all - even Minis
Date: Tue, 22 Oct 96 14:18:36 CST
Subject: Re: XJ6 Screen savers
For those of you that don't mind a little hacking...
Lots of times just saving the file won't result in a usable GIF. Your
browser is often reading a hypertext document that contains an
embedded reference to another document that holds only the GIF. The
embedded GIF is usually referenced using a different http:// address
(see the menu bar of your browser to see what address it is pointing
to for the document you are reading). You need to point your browser
at the specific address for the GIF to capture and save the GIF alone.
To learn what the GIF's address is, chose "View", then "Document
Source" from your browser (assuming Netscape here, Explorer likely
uses different terminology). This will allow you to see the actual
hypertext markup document itself. Nose around until you see the word
"FRAME src=" or "IMG src=" in the approximate location of the text
where you saw the picture you wanted. The address is generally what
"src=" equals. Simply append a slash (/) and the address provided
within the quotes after "src=" to the address that your browser used
for the original document. This will force your browser to look at the
picture itself, not the HTML document.
NOTE: This process should not be used in any way that violates
copyright laws.
Author: "David Tordoff" <dtordoff@flash.net> at smtplink-tellabs
Date: 10/22/96 1:29 PM
<snip>
>Dieter Hachenberg
From: Mario James <brackett@minotaur.uwimona.edu.jm>
Date: Tue, 22 Oct 1996 14:50:06 -0400
Subject: Tappet guide/stakedown kit.........
Dear List,
Can someone tell me how to properly stop the annoying and
potentially very expensive noise of a t'guide moving in its registers?
I heard that the stake down kits are not to be trusted, and that what
really is needed is some arrangement of screws around the t'guide.
Actually, I would prefer the screw method, as I am short of cash at the
moment, and $300 US is rather steep. Diagrams, advice, anyone?
Mario James
1972 Lucas Petrol injected 2.8 XJ6
1966 Mustang coupe 5.0 with Jag front and rear clip
I'ma going racing next month........
From: "Martin Fooks" <Martin.Fooks@centurasoft.com>
Date: Tue, 22 Oct 96 17:46:37 PST
Subject: Attitudes
I find that the responses I get with my modified XJS here in Europe,
from most people are very favourable, although the key scratches down
both sides and on the bonnet (sorry HOOD) of my toy when I bought it
as a standard XJS mean that I may have just been lucky so far.
On it's first major run after the restoration we went on the Entente
Cordial of 1995 (200+ Jaguars cruising through France during a
beautiful bank-holiday weekend....sigh!) and thanks to a rushed
last-minute engine swap by the garage causing oil to flow down into
the alternator from the loose rocker cover, I was left stranded in the
middle of some French town with a large crowd of onlookers. I sunk as
low as possible into the drivers seat and prepared for the laughter,
but none came. The Director of the local bank reopened his bank, which
had already shut for the weekend and helped me phone my breakdown
company.
Soon a middle aged Frenchman arrived with a large trailer attached to
the back of his huge Citroen and very soon we were on our way to meet
up with the rest of the Jags and more importantly the spares truck.
The only downside to owning a Jaguar on that trip was the fact that we
visited 2 different garages on our way to the rendezvous, just so that
the French mechanic who was driving could show off his cargo to his
friends.
Garages here as in the USA seem to be the most prejudicial people in
general... "Exotic car, V12 engine, leather, etc.. .... (think of a
repair cost, double it, double it again)".
Sigh!
Martin Fooks
Nitrous Injected XJS
HTTP://www.internetdesign.com/mrfooks
Date: 22 Oct 96 17:07:44 EDT
Subject: My new XJS-V12
Yes, I finally did it - after years of wanting one, I have finally bought an 86
XJS-V12 and it is super. As for 'attitude', I have not found it a problem at
all yet - perhaps it is our perception that people act up because we expect them
too - ever try a nice smile at them?
I do however have a few problems that I am hoping some jag experts could comment
on - please bear in mind that I don't know one end of a torc wrench from the
other so try and make it simple. Just telling me whether I should cry or not
should do fine...
1) My power steering goes dead when my foot is holding the car still with the
footbrake. When driving, everything seems OK and the brakes are very effective.
I have noticed a groaning noise when turning the wheel when first starting up
and for the first couple of miles, and I am pretty sure my bushes/shocks need
replacing; I don't get the smoothest of rides.
2) The engine seems to run cold most of the time, it never reaches the middle
of the dial - from what I have heard of their habbit of overheating this scares
me - has a previous owner done something to make the gauge misread. When I
leave the car I can hear it ticking as it cools, this OK or not?
3) For the first two/three minutes after starting, my water lever warning
indicator is on and then it goes off. At first I used to top up but it doesn't
seem to matter how long I leave it between topping up as it always takes about a
pint and is full again.
4) There are several other things wrong, but why put all my fun into one
message. When I find out how to pop the bonnet:-), I'll move onto them.
Cheers,
Tony
London, UK
End of jag-lovers-digest V2 #457
id <GAA20555> for jag-lovers-digest-out; Wed, 23 Oct 1996 06:28:06 +0200 (MET DST)
Date: Wed, 23 Oct 1996 06:28:06 +0200 (MET DST)
Message-Id: <199610230428.GAA20555@ekeberg.sn.no>
Subject: jag-lovers-digest V2 #458
Precedence: bulk
Status: O
X-Status:
jag-lovers-digest Wednesday, 23 October 1996 Volume 02 : Number 458
ECU Vacuum sensor -(No attitude content)
North American toll-free numbers
In search of a SS100
Re: Attitudes
Re: sunroof motor/gearbox SIII
Re: In search of a SS100
Re: Attitude
XJ6 Series III trip computer: broken or operator error
Update on XJ6 series III heated window problem
The screwdriver/stethascope trick
loosetappet guide
E-Type cold starting
Re: My new XJS V12
Re: OK, I give up. on the Tank Capacities.
Master Cylinder leak
RE: '88 XJ-S Shock bushings
Dealer and service centre listing
RE: E-Type cold starting
Re: Update on XJ6 series III heated window problem
Repair/Rebuild Jag Alternator Myself?
Date: Tue, 22 Oct 96 16:28:24 -0500
Subject: ECU Vacuum sensor -(No attitude content)
I have been doing battle with a loosing power on
acceleration problem for some time now. Replaced
the fuel pump, filters, etc. I'm now thinking that
the problem may be in the ECU, specifically with
the vacuum sensor. This sensor is a part #GS-47
manufactured by Gulton Industries of Costa Mesa,
CA, who advised me that they haven't made it in
years and are not aware of any substitute. Does
anyone know of a part that can be used to replace
this sensor? Any suggestions will be greatly
appreciated.
Date: Tue, 22 Oct 1996 20:11:22 GMT
Subject: North American toll-free numbers
In message <26bc09c0@ccmail.mi04.zds.com> M.Cogswell@zds.com (Mike Cogswell) writes:
> (non-North Americans cannot use US toll-free numbers
That's the _first_ time I've seen an American who is aware of that :-)
Anyway, if a list.member is desperate enough to order parts for a British
car from the US for shipment to Britain or so (yes, I've come close at
least once), here's the good news.
>From the UK, using BT, it IS possible to dial US 1-800 numbers. Before the
connection is made, there is an announcement, saying that you'll be charged
at intercontinental rates for the call and if you don't like that, to hang
up. But at least you do get through. This does not work with other UK
long distance carriers.
>From other countries in Europe it's not so straightforward. But it can be
done, using an AT&T or MCI telephone charge card. Yes. they're available
to Europeans and can be billed to a normal VISA card. Yes, their charges
are ridiculously high. But if you only need them once in a while, the
costs are insignificant compared to what it takes to keep a V12 on the road.
Stefan Schulz
jaguar@suaviter.demon.co.uk
Date: Tue, 22 Oct 1996 22:41:15 +0200
Subject: In search of a SS100
Dear fellow Jag lovers
A friend of mine without www-connection (but for the present more $ than
me), asked me after he heard about the jag-lovers-list if I could help
him locating a SS-100 for sale somewhere in the western world.
Does anyone have any suggestions, hints or advice. What about future
auction sales ?
What would be the best place to go ?
Thanks for any input you can offer!
Per O. Asperud
Oslo, Norway
XJ6 Ser I
Date: Tue, 22 Oct 1996 17:47:37 -0400 (EDT)
> the looks?
Maybe you need to wash the jag, and/or wax it.
Date: Tue, 22 Oct 1996 18:08:53 -0400 (EDT)
Subject: Re: sunroof motor/gearbox SIII
Are: Yes part no. AEU3020, depending where you buy it sell for around
$18-25 here in the USA>
Tue, 22 Oct 1996, Are Lorentsen wrote:
> Hello!
> Are Lorentsen
> Narvik, Norway
> 82XJ6
Date: Tue, 22 Oct 1996 16:31:54 MDT
Subject: Re: In search of a SS100
> auction sales ?
I know of two at Aagard Foreign Motor in Salt Lake City. They are
1938 models. One is restored and one is needing restoration. Give
them a call at 1.801.272.9979 or fax at 1.801.273.1742. I know
several people who have worked there and they are a reputable Jaguar
restoration shop that's been around for a while.
Kind Regards,
Jim Cantrell
Date: Tue, 22 Oct 1996 19:48:14 -0005
> in a 'burn up' in a straight line?
5.3 H.E. XJ-S with stock GM400 tranny vs. man on foot: Man on foot
will be clear winner for about 30 yards.
Now, if you wanna talk about MY car with the 5-speed, well, that's
another story. Synopsis: the problem with the XJ-S H.E. getting
outta the hole isn't the engine, it's the transmission.
-- Kirbert | If anything is to be accomplished,
| some rules must be broken.
| - Palm's Postulate
Date: Tue, 22 Oct 1996 19:50:23 -0400
Subject: XJ6 Series III trip computer: broken or operator error
Finally the speedo is working correctly. Seems the drive unit in the trans
was loose. So the speedo would work only part of the time. Like right
after going over a rather large bump. Anyway since this has been a problem
since I purchased the car, I have not had a means of testing either the
cruise control or the trip computer.
The cruise control works great. However, the trip computer doesn't appear
to function correctly. Mind you I have no documentation on how this thing
works. So here goes. I can set the clock and it works. There is power to
the unit and when I press one of the other functions, data appears on the
LCD panel. The problem comes when I try to reset the system. It seems
that pressing the reset button does nothing, either by itself or in
combination with another function.
Any ideas, Is this operator error or something wrong with the unit itself?
Thanks for any help the group can give. Ideas of where to obtain
documentation for the computer.
Date: Tue, 22 Oct 1996 19:55:22 -0400
Subject: Update on XJ6 series III heated window problem
A few days ago I posted a message about the rear window defroster not
functioning on my Cat. Power is getting to the switch as the light in the
tac comes on. I have traced the problem to the actual window grid as power
and ground are present at the window. Has anyone repaired a grid? What
options do I have? Replace the rear screen? Help!! Winter is soon to come
to Maine in a big way.
Date: Tue, 22 Oct 1996 19:07:05 -0700
Subject: The screwdriver/stethascope trick
I've found that pushing the handle of the screwdriver into a length of
heater hose makes life easier. You can listen at the other end of the hose
and hear much better and without the inconvenience of getting your nose
caught in a fan blade.
Dave
Date: Tue, 22 Oct 1996 20:09:17 -0700
Subject: loosetappet guide
Curt:
Perhaps your noise could be a valve keeper touching the inside of the
tappet. Did you grind the valves when you had the engine apart? If you
ground too much off the valve stem to get adjustment the shim will sit
too low and the keeper will hit the inside of the tappet.
Been there---done that....
Bill
Corbeil, Ont.
Date: Tue, 22 Oct 1996 19:28:24 -0500
I have two 1987 XJ6's and both do the same thing in about one out of
every 100 starts (a pure guess--it doesn't happen often but often enough
to remind me that it happens). I have no idea why it
happens--undoubtedly the starter teeth fail to engage the flywheel.
Both always start fine on the second try. I've been intrigued as to why
this occurs on both my cars--it doesn't seem serious enough at this
point to do anything about it.
Steve Coleman, Gadsden, AL
1987 XJ6 x2
Date: Wed, 23 Oct 96 00:41:40 UT
Subject: E-Type cold starting
Hello,
My name is David. I have a '69 2+2 auto transmission E-Type with triple SUs.
It is a daily driver that runs great but has trouble starting when the
temperature is below 60 F. The carbs are rebuilt, the coil is a high
performance aftermarket, and overall engine condition - plugs, compression...
OK. Spraying Spray Start into the carbs causes it to start immediately;
otherwise it has to turn over 8 or 10 times.
Any suggestions? Pointless ignition? Choke adjustment?
I drive year round in New England weather and use up lots of batteries with
these slow starts!
Thanks, David R.
Date: 23 Oct 96 10:33:45
Subject: Re: V12 - opinions needed
Those gaskets are a simple job; you just need to be thorough when cleaning the
old gaskets and sealants off. Also, the little rubber half-moons at the rear
end of the cam covers need to be taken out and sealed with RTV Blue
high-temperature silicon. They harden with age, but don't replace them - the
old, hard ones with silicon make a better and more permanent seal than the new,
soft ones (which start leaking when they harden...).
The smart way to handle the fuel rails is to unbolt the injectors from the
manifold and leave the hoses between fuel rail and injectors undisturbed; you
can lift off the whole thing with all injectors. While you're at it, renew the
little rubber seals around the injector necks where they seat in the manifold.
I have a simple attitude to Jaguar maintenance: why should I pay somebody else
to play with my toys?
:3+)
- -Jan
Date: Tue, 22 Oct 1996 18:10:43 -0700
Subject: Re: My new XJS V12
Congratulations Tony. I have an 87 XJS V12 and they are great looking
machines. I hate to say it but I've had nothing but trouble from mine
but I'm keeping her anyway. You'll find lots of help on this page. You
should also try http://home.sn.no/home/nick/jaguar.html It's full of
info and links. Good Luck
Jana
Date: 23 Oct 96 11:47:11
Ed, the simplest is to check the HT leads with an ohmmeter. If the resistance
runs into more than 100k ohms, replace the lead (it should ideally be 1k, but
there's plenty of tolerance).
Another way is to use a strobe timing light with an inductive pickup. With the
engine idling, apply the pickup to the sparkplug end (as near as you can get)
of lead after lead and check for regular, even firing with no "missing flashes".
- -Jan
Date: 23 Oct 96 12:07:27
I haven't had any courtesy problems from fellow motorists - maybe because I'm
pretty aggressive myself, and it shows - but I remember without fondness that
on the two occasions when I was standing by the side of a major highway with
the bonnet open (overheating before I found out about blocked radiators), the
tattooed beer bellies in two passing hoonmobiles made rude gestures and
stretched their intellects to the limit with clever aphorisms (such as
"yaaa-boo sucks").
Comments in conversation is another matter; here's an excerpt from a recent
article ("Bargain Supercar"):
So far, so wonderful - so what,s the downside? The thing that annoys me the
most about this car is the stupid, ignorant comments I get, such as &you,re
obviously too well paid8 and &yeah, but what do you drive when you have to
get somewhere, ha ha?8
I know a landscaper who can,t drive his Jaguar to quote on a job, because he
gets accused of overcharging - the fact that the car is 12 years old and worth
less than a socially acceptable two-year-old Commodore doesn,t register. Of
course, this just shows what a great marketing job Jaguar has done over the
years - surprising, really, considering that it always has been priced far
below its competitors. So I guess I,ll just have to learn to live with the
unwanted prestige(
Date: 23 Oct 96 12:34:33
Subject: Re: OK, I give up. on the Tank Capacities.
There's nothing wrong with your tables, Jim. I think you'll find that your own
E-mail package displays messages in a proportional font, as mine (Lotus Notes)
does. I cut-and-pasted the table from your last message into Notepad, which
always displays in a non-proportional font (easier to do than changing the
display font in a received Notes message) and it came out just fine.
I'm not surprised to see that your tanks are different sizes; after all,
they're "handed", thus different, and maybe your car was "dinged" before you
got it. Differences at intermediate levels could be due to tank shape
differences but also to differences in the primitive wire-wound potentiometer
forming the active part of the senders.
- -Jan
Date: Tue, 22 Oct 1996 19:29:42 -0700
Subject: Master Cylinder leak
Hey folks,
My XJ40 decided to take the next few days off, and sprang a leak at the master brake cylinder. The leak appears to come from where the plastic reservoir mates to the Girling cyinder -- it looks like there are some washers or gaskets there. Anyone had this problem? Is it easy to fix, or is this a big-buck full master cylinder overhaul? I'd appreciate any advice.
Car is a 1987 1/2 XJ40, 150,000 KM (about 90k miles)
Mike Everatt
1987 1/2 XJ40
Keeping warm in the garage (not me -- just the car!)
Date: Tue, 22 Oct 1996 19:38:24 -0700
Subject: RE: '88 XJ-S Shock bushings
Chad,
Will those same bushings fit XJ40?
Mike Everatt
1987 1/2 XJ40
Sent: Monday, October 21, 1996 12:32 PM
To: Steve Draper
Cc: jag-lovers@sn.no
Subject: Re: '88 XJ-S Shock bushings
Steve: Go to Autozone, Pep Boys, Advance, and just about any good parts
store look for their parts section marked HELP, in red packages look for
shock bushings with part no. ending in 18,(cannot remember the first two
no's) these will work great and only cost around $3.00 a pair. Then the
hard part is installing them, cause you have a gas shock and it is a job
to pull it down and remove the old parts and install the new. So if you
have a helper great.
Chad Bolles Jaguar South 306 Valcour Rd Columbia SC 29212 USA 803 798 3044On
Mon, 21 Oct 1996, Steve Draper wrote:
> I need to replace the front shock bushings. Anybody with any tips
> please feel free to comment. I particularly would like to know what a
> reasonable amount for the bushings is and where to get them as well
> as any installation comments. Thanks, Steve.
Date: Tue, 22 Oct 1996 23:20:46 EDT
Subject: Dealer and service centre listing
Hi all,
You may remember a fortnight ago I offered to start a web page listing
Jag mechanics and comments from jag-lovers regarding their experiences
with these mechanics. It was one of Kirby's suggestions I believe.
As part of the discussions offline Reg Heber (heber@qwkslvr.com)
mentioned he was already in the process of putting together a listing
of North American Jag dealers and that he was prepared to take over this
part as well, as he is the web master of that domain he has the resources
and experience to do a better job then I am likely to be able to so I've
handed it to him. I believe The North American and Canadian listing will
be up in text only form this week and he'll probably be looking for your
input after that.
Regards
John
Level 1, 29-57 Christie St.
St Leonards NSW 2065
Ph: +61-2-9937-8063 Fax: +61-2-9937-8100
Mobile +61-419-617-619
Date: Wed, 23 Oct 96 03:17:00 UT
Subject: RE: E-Type cold starting
On our '67 420G with the triple carb setup there is a separate "starting carburetor" next to the front most SU which provides extra fuel and air when the engine is cold as sensed by a thermistor type device in the water jacket. Does/should your car have such a device? I wonder if it may have been removed at some time in the past. Of course my car is not the same as yours, but I *think* it's the same engine. From: owner-jag-lovers@sn.no on behalf of David Rardin Sent: Tuesday, October 22, 1996 5:41 PM To: jag-lovers@sn.no Subject: E-Type cold starting Hello, My name is David. I have a '69 2+2 auto transmission E-Type with triple SUs. It is a daily driver that runs great but has trouble starting when the temperature is below 60 F. The carbs are rebuilt, the coil is a high performance aftermarket, and overall engine condition - plugs, compression... OK. Spraying Spray Start into the carbs causes it to start immediately; otherwise it has to turn over 8 or 10 times. Any suggestions? Pointless ignition? Choke adjustment? I drive year round in New England weather and use up lots of batteries with these slow starts! Thanks, David R. From: Curt Onstott <onstottc@ucs.orst.edu> Date: Tue, 22 Oct 1996 20:35:13 -0700 Subject: Re: Update on XJ6 series III heated window problem I've seen repair kits for this. Assuming that there are minor breaks in the rear window defrost elements, you can get a kit consisting of a paint on electrical conductor. Locate the short and bridge them with the stuff and everything should be hunky-dory. Bruce Sawyer wrote:
Oregon
Date: Wed, 23 Oct 96 04:09:22 UT
Subject: Repair/Rebuild Jag Alternator Myself?
Hello All,
Is there any good reason a DIY with good mechanical and electronic skills
shouldn't attempt to repair and refurbish the Lucas Alternator on a '67 420G
in the home shop?
I have a good digital VOM and the Jag service manual.
The procedures look pretty straightforward and I can't bring myself to shell
out $150 plus shipping for a rebuilt unit (Welsh Jaguar's quote - most others
quoted me around $250) when in all likelihood all I need is to renew the
brushes and perhaps some diodes.
Any words of wisdom or advice before I tackle this would be appreciated.
Also, I'm planning to generally re-furb the Lucas distributor since I managed
to break the vac advance unit (a long and embarrassing story :( ). Any words
of advice in that regard? I have it apart waiting for the vac. unit and it
seems to be a very simple distributor. Rather crude in manufacturing quality
compared to the Bosch units I'm used to working on from my other cars.
TIA, John Horner
End of jag-lovers-digest V2 #458
Return-Path: @owner-jag-lovers-di1
Received: (from majordom@localhost) by ekeberg.sn.no (8.7.5/8.7.3/on4)
id <RAA12347> for jag-lovers-digest-out; Wed, 23 Oct 1996 17:55:31 +0200 (MET DST)
Date: Wed, 23 Oct 1996 17:55:31 +0200 (MET DST)
Message-Id: <199610231555.RAA12347@ekeberg.sn.no>
To: jag-lovers-digest@sn.no
Subject: jag-lovers-digest V2 #459
Reply-To: jag-lovers@sn.no
Errors-To: @owner-jag-lovers-di1
Precedence: bulk
X-Newsgroups: mail.jag-lovers-digest
jag-lovers-digest Wednesday, 23 October 1996 Volume 02 : Number 459
Wood Problems
[Fwd: Re: Spark plug wire testing]
spar varnish
Re: My new XJS-V12
Re: Repair/Rebuild Jag Alternator Myself?
XJ40 Sovereign Headlamps
Re: I can't take this!!
Re: Tappet guide/stakedown kit.........
Ashton Preston Jaguar UK dealer
Re: The sound of a V12 (Zilch Jag-content)
Water in air Vents Continued...
UK, SW London, Mechanic
Re: spar varnish
Electrical
Re: XK8 impact upon XJ-S market?
Thanks/Timing chain noise
Re: rear window grid
Jaguar kit car
Date: Wed, 23 Oct 1996 00:05:10, -0500
Subject: Wood Problems
The wood on my '86 SeriesIII is starting to show signs of cracking on
glove box. What can I do (if anything) to slow down this process.
Also large cracks have formed on wood around gear shift. What do I
need to do to remove this wood so that I can repair it? Do I need to
remove gear shift housing etc.?
Date: Wed, 23 Oct 1996 00:41:07 -0400
Subject: [Fwd: Re: Spark plug wire testing]
Message-ID: <326DA1CB.6366@mscnet.net>
Date: Wed, 23 Oct 1996 00:40:43 -0400
Reply-To: frankp@mscnet.net
Organization: chc
X-Mailer: Mozilla 3.01b1 (Win95; I)
MIME-Version: 1.0
To: Ed Scripps <73200.2362@CompuServe.COM>
Subject: Re: Spark plug wire testing
References: <961021180543_73200.2362_FHJ65-1@CompuServe.COM>
Content-Type: text/plain; charset=us-ascii
Content-Transfer-Encoding: 7bit
Ed Scripps wrote:
> There has been some discussion lately about trouble shooting non running or poor
> running cats. I know you can easly test spark to a plug by holding the plug
> with wire attached against the block or, with the plug installed, by holding the
> wire a short distance from the plug. (In both cases using insulated pliers of
> course.)
> But how can you test the effectiveness of the plug wires? The old time method
> of turning off the lights in the garage at night at looking for arcing will show
> serious wire problems. Is there a method to detect problems before they get to
> this point?
> Thanks,
> Ed
Hi, I bought a little gizmo that consist of a ground wire and a neon
light bulg the end is curved to fit over plug wires. This light glows
when on a operating plug wire and goes off if you hit a break or put it
on a fouled plug. around $9.00 at any auto store . Frank Perrick 1980
honda civic
Date: Wed, 23 Oct 1996 15:20:41 UTC+1000 (ES
Subject: spar varnish
Hello All,
Ihave stripped my woodwork back to bare veneer and I am
not to sure what to use as a coating .
I Have been told that polyurethane has no give and will
crack within a short time.The other suggestion was spar varnish as it
has uv inhibiters (we have lots of sun out here)and is
flexible.I looked at it in our local hardware store and it is quite
yellow I am not sure how this would affect the finish .Would it give
that wood under glass look that I have seen in the newer Jaguars if I
spray enough coats on?
Thanks in advance.
Richard
Date: 23 Oct 96 16:03:13
Subject: Re: My new XJS-V12
Tony Buckley <snip>:
It shouldn't reach the middle of the dial, but check your thermostats just in
case - if they don't close properly, the engine won't raech normal running
temperature. You should be unable to blow through a thermostat when it's cold
(apart from the bleed hole) and it should open fully at 90 deg C if it's a
standard one. The ticking is normal; that's mainly contraction as the exhaust
manifolds cool.
I hope you bleed the radiator when you fill the cooling system. If you fill it
right up when it's cold, heat expansion will push some water out the relief
hose - I haven't measured it, but a pint could be right; this is a very large
system - and you need to leave some expansion space. So if it's a pint down,
don't top up.
- -Jan
From: Volker Nadenau <nadenau@ipers1.e-technik.uni-stuttgart.de>
Date: Wed, 23 Oct 1996 08:14:31 +0100 (MET)
Subject: Re: Repair/Rebuild Jag Alternator Myself?
I just finished the repair of the alternator of my XJ12S3. It was easy to
get a new regulator ,rectifier and brushes. It took about an hour to
replace the parts; all you need to do is to solder 3 wires and turn a few
screws. In my case there was an overvoltage protection diode, which was
shorted. I realized that very late and therefore it took much longer than
expexted until the alternator was working properly again. Threfore check
this diode if present in your alternator.
Good luck
Volker
> Hello All, >
> in the home shop?
Volker Nadenau
University of Stuttgart Fax : ++49 711 685 7143
Institute for Physical Electronics Internet: nadenau@ipers1.e-technik.uni-stuttgart.de
Pfaffenwaldring 47
70569 Stuttgart
Germany
From: "Mark A. Salmon & Company" <Mark@masassoc.demon.co.uk>
Date: Wed, 23 Oct 1996 09:05:50 +0100
Subject: XJ40 Sovereign Headlamps
Hear is what sounds like simple problem.
I have an '89 Sovereign 3.6 with square headlamps, the bulb for the main
beam needed replacing, no problem there, the problem arose when trying
to refit the spring clip to hold the bulb in place, it seems impossible
to get it back in. I hope that there is a simple trick that I am missing
as it has up to now got me baffled.
Any help or advice will be much appreciated.
Mark Salmon
'89 XJ40 Sovereign 3.6
'83 XJS H.E. V12
Date: Wed, 23 Oct 1996 10:42:21 -0700
Subject: Re: I can't take this!!
Hi gang,
I just had to comment on Gunnar's October 15th. posting (I'm a bit behind with
my mail after my visit to Finland a couple of weeks ago.)
Gunnar:
>Anywho, you should have seen the reaction of people we met along the road.
>Instant whiplash! (There are only three Countachs in all of Norway, the
>other two are in Oslo).....
He's probably right about the total number of Countaches, but one of them is
currently residing in Haugesund!
Gunnar:
>....... And nothing beats the sound of a V12!
Well, this summer we had a short stop in Arendal in the far south of Norway,
just as they put to sea and warmed up some of the contenders boats for the
Offshore Boat Race that was to take place the following day. The Italian team
(three boats) was powered by twin Lamborghini V12s, unmuffled :-) Now, there's a
sound that gives you a belly full!
Rroaaarrr!
Bard
______ _ ! Baard Th Hesvik, Telesoft AS
/ _ / _ _ _ / / ! Longhammarvn 7, N-5500 Haugesund
/ /_/ / /_/ /_ / / -/- -/- ! T: +47 52735000 F: +47 52717040
/ /_ / /_ _/ /_/ / /_ ! E-mail: baard@telesoft.no
Date: Wed, 23 Oct 96 11:03:57 BST
Subject: Re: Tappet guide/stakedown kit.........
Mario writes:-
> Dear List,
I have just modified the head of my '85 Series III XJ6 Sovereign to fasten
the tappet guides down.
I decided to make my own "stakedown-kit", partly because I enjoy doing that
sort of thing, and partly because I don't like the idea of using self-tapping
screws (which I believe the normal kit uses). I have visions of a screw
coming loose and getting jammed between those whirling cams and something
solid. I made up some aluminium plates (each one spanning two tappet guides)
just like in the kit. However, instead of using self-tappers or cutting a thread
with a tap, I drilled holes right through into oil tunnel below and used M5
screws with lock-nuts and washers on the other side. It's a slight fiddle
but there's just enough access through the tappet guide hole and large oval
oil-drains to get the nuts on and held while you tighten the screws.
I drilled the holes close to the tappet guide itself so that the screw head
(& a washer) were overlapping the lip of the guide somewhat, with the plate
extending a little further still. The casting is quite thick here (about 20 or
25mm) forming a "boss" that the tappet guide hole is bored into, and I used
screws about 35mm long.
All this was done with the cylinder head off the car so it was easy to clean out
all the swarf.
None of my tappet guides was actually loose but one exhaust guide was "raised"
a few mm although it couldn't be moved by hand. I drove it back down flush
with the head with a suitably sized socket and soft hammer before I started.
I'm sure you'll get a few more replies on other possible solutions to this
problem.
regards,
Dan.
From: "Barry Cooper" <b.w.cooper@acslink.aone.net.au>
Date: Wed, 23 Oct 1996 12:23:19 +1000
Subject: Ashton Preston Jaguar UK dealer
Do any Jaguar Lovers in the UK know whether the dealer Ashton Preston is
still in existence? If so a contact address would be appreciated.
My E-Type Heritage certificate shows first delivery as being to them. I
would dearly like to trace the history but I realise that it is unlikely
that I will be able to do so. The posting "British DMV info" by Bill
McDowell suggested that the British registration number is required before
seeking info from DMV.
Barry Cooper
Mackay Qld
Australia
68 E FHC
67 TR4-A
Date: Wed, 23 Oct 1996 13:50:16 -0700
Subject: Re: The sound of a V12 (Zilch Jag-content)
Hi gang,
Gunnar:
Gunnar:
Rroaaarrr!
Bard
Date: Wed, 23 Oct 1996 08:09:15 -0400 (EDT)
Subject: Water in air Vents Continued...
The water doesn't actually go in the air vent it follows a small lip of
metal just before the air vent and then enters the car coming out on the
floor boards. The two drains for the cubby are open except for those
boots that are put on the ends by the factory. The vents only stay
closed when there is vacuum from the motor and after the motor is shut
off they open and leak when they are open because the drains can't keep
up with the water that is coming in......
Theo
'85 Sovereign SeriesIII
Date: Wed, 23 Oct 1996 09:24:58 -0400
For those who answered to my post, thanx a lot, Jeffrey, thanx for the
info on British Car Specialists, I hope the stakedown kit works. Going
to try and order one today....by the way, anyone knows how the
transmission mount goes together? Changed my u-joints over the weekend,
built my jig, but can't align my driveshaft properly. Any advice,
diagrams, etc will be appreciated....
Mario James,
1972 2.8 lucas injected XJ6
1966 "Jagified" Mustang 302
From: "Buckley, Tony" <BUCKLEYT@oldstreet.agw.bt.co.uk>
Date: Wed, 23 Oct 96 12:58:00 GMT
Subject: UK, SW London, Mechanic
Anyone recommend a garage or mechanic in SW London that knows about the XS-S
and that won't charge me Jag prices and that are GOOD at what they do. Yeh
- I know I want everything, but I can ask :-)
Tony
Date: Wed, 23 Oct 1996 15:17:00 +0100
Here is what sounds like simple problem.
Mark Salmon
'83 XJS H.E. V12
Date: Wed, 23 Oct 1996 07:46:00 -0700
You have to hold the reset button in for about 6 to 10 seconds.
Tracy A. Ferrell tracy@brooktree.com in Sunny San Diego, CA, USA
Date: Wed, 23 Oct 1996 07:55:50 -0700
My '84 XJ6 did this about 1 in every 10 times I started it. I tried a new
starter motor, but it didn't help. I finally bought a new flex plate and had
it installed when I had my transmission worked on. The old flex plate had
two areas on it where the teeth were worn away. I couldn't see the wear from
the vent/inspection openings on the bell housing. It seems like a fairly
common problem. Are all flex plates made of soft material or has Jaguar
cornered the market?
Date: Wed, 23 Oct 1996 07:55:40 -0700
Subject: Re: spar varnish
Richard,
Use a good TUNG OIL or Danish Oil finish. DO NOT USE any of the "poly's"
as they make it next to impossible to ever "refinish" the wood. Lee
> From: Richard Moore <richard@ee.uts.edu.au>
> Date: Wednesday, October 23, 1996 8:20 AM
> Hello All,
> Thanks in advance.
> Richard
Date: Wed, 23 Oct 1996 10:06:58 -0500 (CDT)
Subject: Electrical
Morning folks,
Does anyone have procedures for tracing a short. A brand new battery was
virtually immediately run down. Using jump cables the beast starts first time.
I realise this will be a process of elimination but I wondered if there was
a step by step process.
Thanks in advance.
Gavin, 83 XJ6
Date: Wed, 23 Oct 1996 15:11:28 GMT
Subject: Re: XK8 impact upon XJ-S market?
On Tue, 22 Oct 96 08:04:39 EST, you wrote:
> All this talk has got me wondering how I might afford to buy=20
> an XK8.
> =20
> Not really - but it did start me wondering about how the used=20
> XJ-S market might be impacted by the availability of the new=20
> car.
> =20
> One could argue that since there won't be any more XJ-S cars -=20
> =20
> On the other hand you could think that some potential buyers=20
> are now going to buy XK8's - the demand is reduced - so the=20
> =20
> Or maybe both are true, and the prices will stay right where=20
> they are.
> =20
> What do you think? Will I be able to retire on the revenues=20
> =20
An interesting dilema. I wouild propose that there will be an
immediate drop in the value of late model XJ-S's. IMHO this will
probably last for about two years until the propoganda campaign dies
down.
While the XK8 is certainly a well engineered car with great bells and
whistles, I find that there is a certain purity in the XJ-S. Nobody
has ever mistaken my XJ-S for a Riviera, Aurora, or for that matter
anything other than it actually is. The XK8 unfortunately has
sacrificed the unique stying which has always denoted a Jag, in order
to exist in the "every car looks the same" world of Ford.
Don't get me wrong. I'm glad that Ford has invested so much to once
again bring Jag back to a fiscally viable position. And there is no
question that Ford's committment to quality production has had a
wonderful influence on the reliability of Jag products. It's too bad
that the price to be paid might be the loss of the innovative styling
which makes me love the damn cars so much!!! :-).
Date: Wed, 23 Oct 1996 17:50:32 +0100
Subject: Thanks/Timing chain noise
Thanks to everybody for all the hints about the noise of my SIII XJ6 engine. I had it checked/fixed by a non-dealer jag-mechanic (yes, I am a chicken but I have this car since 2 weeks and I wanted to be sure and to have somebody evaluate the car). It was a mixture of loose timing chain and a slacken nut on the alternator.
According to the mechanic, the car is ok so far, with a compression of 9:1 +/- 5% on all 6 and no special noise anymore. The only things to replace up to now are rear brake pads (done), speedo transducer (I open that thing just to know more - maybe it will work again ...), trackrod ends, hazard flasher button and the drive gear of the antenna motor.
Ciao
Bert
Date: Wed, 23 Oct 1996 11:48:46 -0400
Subject: Re: rear window grid
bsawyer@mint.net (Bruce Sawyer) asked if anyone had repaired
a rear window defroster grid.
Bruce- if you can located the break in the grid, clean that spot with steel
wool, then solder. If there's a large gap, a piece of wire can be soldered
between the two ends.
Cheers,
Brian Sherwood
'85 XJ6, '84 XJS
Date: Wed, 23 Oct 96 16:50:18 BST
Subject: Jaguar kit car
In "The Times" last week there was an article about a rather fast Jag
kit car that closely resembles a Ferrari. The story started something
like "Yeah, well, we had this Jaguar V12 engine sitting in the garage
and decided to build a car around it..."
Apparently it's actually quicker than the Ferrari it looks like. I
wonder if they'll add nitrous?
Steve
End of jag-lovers-digest V2 #459
id <VAA26227> for jag-lovers-digest-out; Wed, 23 Oct 1996 21:06:05 +0200 (MET DST)
Date: Wed, 23 Oct 1996 21:06:05 +0200 (MET DST)
Message-Id: <199610231906.VAA26227@ekeberg.sn.no>
Subject: jag-lovers-digest V2 #460
Precedence: bulk
jag-lovers-digest Wednesday, 23 October 1996 Volume 02 : Number 460
Re: Electrical
Tachometer upgrade
Re: Starter and flywheel for 1983 Series III XJ6?
RE: Electrical
Re: XJ6 Series III trip computer: broken or operator error
Re: Electrical
Re: Attitudes & Attitudes
Re: Locating Loose Tappet Guides
Electrical
Jag Drivers Problems with Drivers of Lesser Breeds
xk8 Body Panels wanted
Re: Electrical
Engine Click When Cold...
gas smell/headlights
Re: Electrical
Dayton Wires
Re: Electrical
Date: Wed, 23 Oct 1996 09:01:02 -0700
Subject: Re: Electrical
Gavin,
Brute Force method.
Disconnect battery and re-charge it.
Pull all the fuses from all blocks.
Connect ammeter in line with positive lead.
Watch current rise with each fuse you plug in.
If you get a "sharp" increase in current flow for a "circuit" which is
suppose to be off, you've found the culprit and can then proceed to tracing
out the wires to look for the short. Lee
> From: Gavin Murphy <gmurphy@telalink.net>
> Subject: Electrical
> Date: Wednesday, October 23, 1996 8:06 AM
> Morning folks,
time.
was
> Thanks in advance.
> Gavin, 83 XJ6
Date: Wed, 23 Oct 1996 12:18:04 -0400
Looks like operator error is to blame here instead of the Prince of
Darkness. Thanks for the tips on holding the reset button for more than 5
seconds. Works like a charm and seems to be correct.
Date: Wed, 23 Oct 1996 12:18:50 -0400
Subject: Tachometer upgrade
Hi gang,
I have been on the quest of building an interface that allows me to use my
stock, Jaguar tachometer (the kind that runs from an alternator on the cam
shaft) with a modern feed from the points. I have learned the following:
1) The system is an AC alternator driving a full wave selenium rectifier and
with a large wire-wound resistor/inductor in series.
2) The galvenometer (instrument meter movement) reads full scale (or 5500
RPM) with a 1.5 volt DC current applied and draws about 20 mA. I make that
about a 75 ohm resistance through the coil.
3) To avoid undue engineering, and the time it takes to do it, I have chosen
to
buy a $29 (US) tachometer from the local parts supplier. I will use the
circuitry in this unit to drive the original instrument. Thanks for the
suggestion
by a jag-lovers menber whose name I have misplaced. Sorry.
4) For quazi-calibration, I plan to use a simple resistor divider and an NPN
transistor to drive the original gauge.
If any of you have non-Jaguar engines or later model Jag engines in your
older cars and want details of the process, I will e-mail or FAX the details
to you.
Rick Lindsay
Date: Wed, 23 Oct 1996 12:18:05 -0400 (EDT)
Subject: Re: Screeching Sound
On Mon, 21 Oct 1996, Dennis Beisswanger wrote:
> When starting my 1982 XJ6 in neutral this evening, it made a screeching
> sound and did not turn over. On several subsequent tries it was fine.
Maybe it was a cat stepping across the starter solenoid terminal and
ground.
John
Date: Wed, 23 Oct 1996 09:32:46 -0700
Subject: Re: Starter and flywheel for 1983 Series III XJ6?
Hal Rogers writes:
> At 05:32 PM 10/15/96 -0700, William J. Earl wrote:
> > I took my 1983 Series III XJ6 into a shop for a loose starter wire.
> >While they were looking at that, they investigated and found that the
> >starter and flywheel were mismatched, in terms of the angle of the pinion
> >and ring gear teeth, and that the latter were much worn. My car a US model,
> >originally a BW66 automatic, retrofitted by the PO with a European 5-speed
> >manual transmission. Apparently, the shop which did the conversion replaced
> >the flywheel, but not the starter, or else the starter was later replaced
> >with the wrong type.
> > I am going to go ahead and get a Series III parts book, but I would
> >appreciate any help in sorting this out. (I have the service manual,
> >but it is not much help in this area.)
> The flywheels are different between the manual trans and the automatic.
> However, I show know record of the starter being different for either
> model..this is according to the OEM parts book and the Lucas starter book.
Thanks for your note.
I have now obtained a parts book, and also got more information.
It turns out that the parts book, as you say, shows only one starter
and only one manual transmission flywheel. Unfortunately, the parts
microfiches from the XJ6 period show three starter/flywheel
combinations (two of which are of course not in the paper parts book).
I turn out to have a later flywheel and an earlier (incorrect)
starter. The only important major difference in the starter is the
size and cut of the starter drive gear (which engages the flywheel). I have
now encountered three types. One has too large a diameter, so it binds
as it engages the flywheel, to the point where it cannot turn the flywheel.
This one looks like the one in the parts book. Another, which is the
type in my car, has the right diameter, but it only cut halfway back from
the end of the gear to the shoulder, and the uncut portion wears against
the starter side of the ring gear teeth, causing excess noise and wear.
The third kind, which is on order, looks like the one in the parts book,
but has a small enough diameter to not bind on the flywheel.
There are at least two kinds of flywheel. The first find is in the
parts book, and is thicker than mine. Also, the center of my flywheel has
a large hole, not a small hole, and thus looks more like the automatic
transmission flywheel. The ring gear diameter is the same as that
of the flywheel in the parts book. (I compared the two, side by side.)
Once I get to the end of this treasure hunt, I will post the results
to the list. I have been quite happy with the manual transmission, but it
is clear that one needs a parts supplier with access to the microfiches to
get a compatible set of components.
Date: Wed, 23 Oct 1996 09:58:33 -0700
Subject: RE: Electrical
Why not start by using a voltmeter at the fuse panels to determine which
circuit contains the short. Put one lead on each side of each fuse and
look for the circuit on which current flow is indicated.
It's a good start anyway
>From: gmurphy@telalink.net[SMTP:gmurphy@telalink.net]
>Sent: Wednesday, October 23, 1996 8:06 AM
>Subject: Electrical
>Morning folks,
>time.
>Thanks in advance.
>Gavin, 83 XJ6
Date: Wed, 23 Oct 96 16:52:34 GMT
Subject: Re: XJ6 Series III trip computer: broken or operator error
Hold the reset button down for 2 seconds.
Allan Lysse
alysse@primenet.com
- -----------------------------Reply Separator---------------------------------
On 10/22/96 4:50PM, in message <199610222349.TAA22769@mint.mint.net>, Bruce Sawyer <bsawyer@mint.net> wrote:
Date: Wed, 23 Oct 1996 13:13:33 -0400
Gavin Murphy wrote:
> Morning folks,
> Thanks in advance.
> Gavin, 83 XJ6
I would get an amp meter (usually part of a volt meter), and put it in
series with the Plus(red) line. Specifically, remove the cable from the
plus connection of the battery, connect the plus lead of the meter to
the battery, and touch the negative lead of the meter to the battery
cable you just removed. BEWARE! If you are running a battery down that
fast, it may be a very significant drain current. Most household
voltmeters will only handle up to 10 amps. You would most likely blow a
fuse in the meter if it's a lot higher.
I'd go to the plus side, because the short is most likely to ground
(worn wire insulation, etc).
Do not try to start the car with the meter in series. You can draw up
to 350 amps momentarily.
Date: Wed, 23 Oct 96 10:07:20 -0700
Subject: Re: Attitudes & Attitudes
While first test driving an XJS I was trying to merge onto a crowded
Southern California Freeway and to my surprise, a trucker flashed his
lights and motioned for me to merge in front of him. This never happened
to me in my Honda, or even in my Turbo 300ZX. Having now acquired an XJS
convertible, I have observed that most people seem to be more courteous
to me than I remember. I've had parking attendants offer me better
spots, and even had security guards at film studios try to find me more
secure or more convenient parking spaces.
And this in a town where a Mercedes or a Porsche goes unnoticed. Maybe
it's something about the Jag mystique, or perhaps I've become a happier,
more pleasant driver behind the wheel of my XJS.
'96 XJS - The last of the breed
_______________________________________________________
David C. Engelbach E-mail - widi@artnet.net
Valley Village, CA 91601 Voice - 818.506.5441
USA Fax - 818.506.1011
Date: Wed, 23 Oct 1996 10:04:00 -0700
Subject: Re: Locating Loose Tappet Guides
I went and bought a mechanic's stethescope and tracked the noise to
cylinder four on the exhaust side. Just for kicks, I pulled the plug
wire for this cylinder. There was absolutely no change in engine RPMs.
Pulling the wires for the other cylinders in turn, resulted in a drop in
idle speed.
Fearing a bent valve, dropped valve seat, or other problem I did a
compression test. Compression is the same on all six cylinders. Next,
I tried a different wire on cylinder 4. It made no difference pulling
this wire while the engine was idling.
I pulled the distributor cap and found that the rotor that I put in a
week ago was the wrong size and had been rubbing against the distributor
cap and also ground away the carbon brush. So now, I'm wondering if the
clanking noise I was hearing could be cylinder 4 firing at the wrong
time? Once I get a new cap, rotor and set of wires put on I'll see...
Does this sound plausable?
Curt Onstott wrote:
> I drove my XJ6 on a quick 120mi trip last week. When I got off of the
> freeway and stopped at a service station, I heard the dreaded
> clickety-clack associated with loose tappet guides. Several weeks ago I
> fitted a stake-down kit to the exhaust side. (I had the engine apart
> anyway.)
> The noise is now pretty constant. I pulled the valve covers and cannot
> locate any obvious damage. (I drove the vehicle 160 miles with the
> clacking) I'm trying to determine whether this is just tappet guide
> clatter or a more serious problem-- which I don't have a clue as to what
> it is...
> I've tried:
> 1)pulling spark plug wires while engine is running -- no change.
> 2)compression test (To see if it could be a loose valve seat) -- OK
> 3)Pulling cam covers -- no damage to cam lobes or guides.
> 4)checking timing chain tension (Fine)
> I can't seem to pin-point the exact tappet guide that is making the
> clatter. Should there be visable damage? It is pretty noisy...
> What other probs would cause this type of clatter?
- -Pessimist: "This ship is sinking." -Optimist: "This ship is half full."
Curt Onstott - Windows/DOS/PC Specialist - Information Services -
Oregon
State University. - (541) 737-1483 - Office: Kerr 217
Date: Wed, 23 Oct 96 10:22:44 -0700
The dealer where I bought my new 96 XJS had previously worked for a
Mercedes dealer. When MB introduced the remodeled SL series it pushed up
the prices for the previous series cars. That doesn't mean the same will
happen with the XJS, but the very good press being generated by the XK8
will help to mitigate some of the bad reputation Jag has acquired. That
should equate to better resale for good condition, later model XJS.
Maybe.
Date: Wed, 23 Oct 1996 13:26:34 -0400 (EDT)
Subject: Electrical
Tracing a short can be very fun but most likely it isn't a direct short
you have b/c if you did it would burn something up not just kill your
battery. Depending on how long it takes to kill the battery, tells you
if you have a short or you may have a piece of insulation that is frayed
that is not shorting but is giving little resistance to ground causing a
constant draw on the battery. The best thing to do at first would be to
measure with an ammeter the amount of constant draw on the battery.
Then the next step will be to monitor this draw while removing fuses
from the fuse box and this will tell you where the constant draw is
coming (What part or accessory in the car.) from and then you can track
individual wires as needed.
good luck and be careful!
Theo
85 Sovereign Series III
Date: Wed, 23 Oct 1996 13:09:52 -0700
Subject: Jag Drivers Problems with Drivers of Lesser Breeds
I have driven Jags since 1959 when I was 20 (add it up). One of the first
coments was "Does your father know fast you drove his car." My reply, "I
don't drive his car this Jag is mine."
I have had a cigarette butt thrown into the rear seat of my mark 7,
leaving a hole in the leather upholstery.
I have been told I have no business driving a Jag.
I have been shot at with an air gun, it put a bad mark in the aluminum
door of my XK140.
I have been tailgated by idiots and have had the same mental midgits jam
on their brakes in front of me for no reason other than to test my
reflexes.
I have been stopped by police in a 60MPH zone when I was going 60MPH and
was told that if I went 1MPH faster he would get me.
I can drive my Olds station wagon at 75 and nobody tries to pass me but
at 80 MPH in my XK140 they all try to pass. (Possibly we should all chip
in to hire a shrink who can tell us how to deal with these idiots).
Bill
Ontario,Canada
Date: Wed, 23 Oct 1996 13:55:54 -0400
Subject: xk8 Body Panels wanted
am looking for composite xk8 body panels to fit to SCCA super production tube
frame chassis. Any Ideas???
Date: Wed, 23 Oct 1996 10:55:40 -0700 (PDT)
Gavin-
1) Attach an ammeter in line with one of the battery cables.
1a) If there isn't appreciable drain (say, >10mA), then you probably have a
charging problem.
2) Remove one fuse at a time and note the change in current drain. There
will be slight drain for the clock/computer.
Charging problem: with the engine running, the voltmeter on your dash should
indicate about 13 volts. 12 or under, you probably have a bad alternator
(mine just required replacement).
Good luck!
Hunt
At 10:06 AM 10/23/96 -0500, you wrote:
>Morning folks,
>Thanks in advance.
>Gavin, 83 XJ6
Date: Wed, 23 Oct 1996 14:13:12 -0400 (EDT)
Subject: Engine Click When Cold...
Hello,
Sovereign Series Three 6 cylinder motor clicks taps or whatever you want
to call it when it is cold but once warm it is ok. Valve adjustment or
more serious?
Appreciate any input!
Thanks
Theo
Date: Wed, 23 Oct 1996 13:40:46 -0500
Subject: gas smell/headlights
Dear felow jag-lovers
1. I have noticed that ever so familiar gas smell in my 86 VDP, most
frequently after refueling. Any thoughts on if i should check the
cannister first or should I attempt to purge the vent lines?
2. Last night i drve my car to a store. When I returned to my car and
turned the headlights on the left came on for 5 seconds,then
spontaneously shut off. It now refuses to come back on. When I use the
highbeams, however, all four lights do illuminate. Are these lights
single or dual fillaments. Any suggestions as to where to start?
Many thanks
Stacy
Houma, La
1986 Vanden Plas
From: Marshall Hollister-Jones <marshall@mentor.co.nz>
Date: Thu, 24 Oct 1996 07:47:41 +1300
Is the battery just running down with using the car or if it is standing
for a day or so? If it is the former the problem may be the voltage
regulator or alternator - the car runs off the battery without any charge
going back into it.
> > Subject: Electrical
> > Morning folks,
was
first
> time.
> was
> > Thanks in advance.
> > Gavin, 83 XJ6
Date: Thu, 24 Oct 1996 07:50:13 +1300
steel
soldered
Beware, soldering tends to lift the element off the glass - the repair kit
may be better.
Date: Wed, 23 Oct 1996 12:01:56 -0700
Subject: Dayton Wires
Hello everyone,
A consumer alert: I've been having troubles with 7 spokes on my
Dayton wires bought this spring. Basically, they wouldn't hold a shine,
and when washed would get a thin coat of corrosion on them... requiring
a hand-polish to restore the shine (kind of a pain).
Anyway, when I brought this to the attention of my retailler, they
had me test the spokes with a magnet, and sure enough the magnet pulled
stronger to the 7 spokes in question.
Apparently, Dayton had a little mishap earlier this year, and got
some plain steel spokes mixed up with the stainless ones. They all
went through the polisher, and when new are virtually indistinguishable
from one another (a magnet will pull to the plain steel spokes stronger
than to the stainless ones). The place I bought mine have been quite good
about it, offering to either replace the spokes, or just replace the wheels
at no charge- and seemed well aware of the problem.
Just a heads up- if you've got new Dayton wires and are encountering similar
problems, try the magnet test-
Ryan.
Date: Wed, 23 Oct 1996 19:04:30 GMT
>fuse in the meter if it's a lot higher.=20
How about this instead:
Put a 12-volt lamp in series with the battery. Measure across the
lamp with a voltmeter set to the 12 volt scale to get a relative idea
of the current draw. The worst that can happen with a dead short is
that the lamp will glow brightly. Your meter will be safe.
Vince
- -- =20
Vince Chrzanowski radiowsh@mindport.net=20
"There is not a moment to be lost" - Jack Aubrey
- -------------------------------------------------- =20
End of jag-lovers-digest V2 #460
X-UIDL: b735486cf27d7e68d48c31d4b30aa2b0
id <GAA17048> for jag-lovers-digest-out; Thu, 24 Oct 1996 06:08:12 +0200 (MET DST)
Date: Thu, 24 Oct 1996 06:08:12 +0200 (MET DST)
Message-Id: <199610240408.GAA17048@ekeberg.sn.no>
Subject: jag-lovers-digest V2 #461
Precedence: bulk
Status: RO
X-Status:
jag-lovers-digest Thursday, 24 October 1996 Volume 02 : Number 461
Re: Thanks/Timing chain noise
Re: gas smell/headlights
JAGUAR XK 120 OR XK 140 WANTED !!!!
83 XJ6 Air Con Leak
Is there a lawyer in the house ??
XJ-S Bodies
E-Type cross member specs.
Re: Master Cylinder leak
FW: E-Type cold starting
Jaguar Starting Problem
Re: 83 XJ6 Air Con Leak
XJRS 6.0 cuts out
Attitudes/ Rear Brake Removal
car for sale
XJS, I have parts left over
Re: North American toll-free numbers
Re: spar varnish
Re: E-Type cold starting
Date: Wed, 23 Oct 1996 16:00:46 -0005
Subject: Re: Thanks/Timing chain noise
Bert Willing:
> XJ6 engine. I had it checked/fixed by a non-dealer jag-mechanic. It
> alternator.
Translation: the mechanic had already gone through the time and
effort to adjust the timing chain before he found the problem, which
was the nut on the alternator. Charged customer for both.
| - Palm's Postulate
Date: Wed, 23 Oct 1996 13:03:47 -0700
>I have an 88 Soveriegn. The highlight of an evening at the Westin Bayshore
in Vancouver was the valet not parking my jag, but leaving it at the
entrance, under cover, for all the world to see it parked there. Made for
very handy acces and the valet even took the trouble to point out where
storm clouds were forming on the horrizon so the jag wouldn't get a sprinkle.
The lowest was when I parked it at the bank and came out to a dent and the
paint was scraped right down to the undercoat. No-one saw a thing.
In respect to the crumby attitudes of some out there...SMILE, you're driving
the most beautiful car in the world, and you deserve it!
Debbie
Date: Wed, 23 Oct 1996 15:29:30 -0600
Subject: Re: gas smell/headlights
>Many thanks
>Stacy
>Houma, La
>1986 Vanden Plas
Hi Stacy,
If all the lights are out then it is not likely to be bad headlamp
bulbs..more likely another electrical problem..like a headlamp relay or fuse
or even switch perhaps. Headlamp relay is a fairly common failure. Good luck.
Hal
Hal Rogers
H.D. Rogers & Sons
Import Auto Specialists
3418 Barksdale Blvd.
Bossier City LA 71112
(318) 742-3651 voice
(318) 742-5044 fax
Serving Auto Enthusiasts since 1959
Date: Wed, 23 Oct 1996 22:49:43 +0100 (GMT+0100)
Subject: JAGUAR XK 120 OR XK 140 WANTED !!!!
> I can read that no one understand my message then :
> I want to buy a XK 140 or XK 120 Jaguar.
> I want to find one not on top (completetely rebuid).
> If engine don't run, paint to do, interior in poor state no problem.
> I want to buy a car around 10.000 $ (change --> 1$= 5.5 FF)
> Thank you for yours answers.
>CHRISTOPHE.
Date: Tue, 22 Oct 1996 08:17:19 -0400
Subject: 83 XJ6 Air Con Leak
I have very slow leak in the air con that seems to take
about three weeks before the charge is depleted enough that
there is no cold air. Everything under the hood has been
checked or replaced and it seems that the leak is on the
cabin side of the firewall. My question is what is the best
way to proceed to find the leak and how do I get to the
evaporater if in fact I have to replace it? Any suggestions
on where to start looking without tearing the whole dash
out. Thanks for any help.
Alex Lynch
83 XJ6
62 TR3
Date: Wed, 23 Oct 1996 17:49:36 -0400
Subject: Is there a lawyer in the house ??
Hi all,
Long stuff here bear with me. Recap to date: My 1985 XJS experienced
severe malfunctions resulting in turning it back into the junk yard from
which it came. I still owe around $2,100 on the car and turned it back
in hoping for a voluntary repo type of thing. Instead I was told by the
owner that I would be personally responsible for selling the car. Since
the car has been there the radio a $300 dollar alpine was stolen out of
the vehicle. I have put up e-mail for any one interested to call me to
arrange going to look at it.Yesterday I recieved a call from an
interested party from the jag lovers group ( HI, Jim ) so I gave the
location of the car. Also just for kicks I asked him not to tell the
owner he knew me. When he went to look at the car. He asked about the
radio ,he was offerd the original jaguar radio ( I gave him both radios)
for $200.00 and was told that it worked fine. That radio never even lit
up much less worked. Also he asked about the price of the car he was
told $4000.00. This car according to the owner of the junk yard and his
greese monkeys, has a thrown rod however my jag-lover friend was told it
runs and drives fine !! Has a slight tick I belive was the phrase. This
infuriates me !! This must be illeagal to mis represent a vehicle like
this. Also doesn't he have to sell the car at auction and subtract the
proceeds from the bill or pay me anything over $2,100 dollars ( payoff)
I have a standard loan contract with him. I received nothing from him
when I turned the car in. I really don't need this trouble right now. I
figured I'm 2 1/2 months behind on payments so I would have to pay
$500.00 to pull it out of the junk yard and bring it back home. It was
suggested that i part it out my self. I don't have this kind of money to
spend on that car right now. Any ideas ?? Also my Jag- lover friend has
a beutiful XJS if any one out there wants to float the note it would be
apreciated. Just started second job so payments wouldn't be a problem.
Just have to make up something for the wife , I won it or something..
Seriously I would apreciate any suggestions on handling this fine mess
I've gotton my self into. I'm the king of handling stress( I have to
be) But this is a little much. Plus it makes me look dishonest by
sending people out to this guy and I am certianly not dishonest (even if
I can't spell or punctuate well) . Thank you Frank Perrick
Date: Wed, 23 Oct 1996 18:32:40 -0400 (EDT)
Subject: XJ-S Bodies
I have seen something like this on the net before, so here is my version.
Part No. JLM 1444 is the part no. for an XJ-S coupe body (body in white).
The cost ia around $1900. delivered to the dock in Charleston SC.
I am not sure if the body is still available, but I have a contact at
Jaguar, he is going to check for me tomorrow, 24 Oct 1996. If they are
still available, is anyone interested, as the more I order the cheaper
they are, as about 1/2 the cost is shipping, and we could ship 2,3,or 4
for about the same price as shipping 1 or 2.
I need to know ASAP.
From: rrichardson@eurekanet.com (Robert J. Richardson)
Date: Wed, 23 Oct 1996 18:43:51 -0500
Subject: E-Type cross member specs.
I need the measurements for the hardwood piece that one needs to insert
under the front frame cross member before placing the floor jack there in
order to raise the front of the car. The service manual advises to do this
to keep from distorting the cross member. The Jag, a 1964 Series 1, is
raised at the rear via ramps and I am unable to get under the front to
obtain measurements for the hardwood piece. I have to order all the wood
jacking and jackstand hardwood blocks precut at the local lumber dealer and
would appreciate the requested measurements from someone who currently has
this hardwood attached to the front subframe cross member.
Date: Wed, 23 Oct 1996 19:03:16 -0500
Subject: Re: Master Cylinder leak
>Hey folks,
>advice.
>Mike Everatt
>1987 1/2 XJ40
I'm in the process of rebuilding both my master cylinders (front and rear
brakes) on my Series 1 E-Type. The rubber seals have deteriorated, possibly
because someone topped up the reservoir with brake fluid other than
Girling-Catrol. Figure on about an hour's labor to disassemble the master
cylinder and installing new rubber seals. The entire brake system will have
to be bled afterwards. On an E-Type Jag (Series 1) there can be either
Girling or Dunlop master cylinders as original equipment. I have Dunlops
and had to return Girling rebuild kits, because the rubber seals are not
interchangable. Your mechanic will know which kit to install.
From: "YOUNG, Neil (M06)" <Neil.Young@qed.qld.gov.au>
Date: Thu, 24 Oct 96 09:26:00 PDT
Subject: FW: E-Type cold starting
In response to John Horner:
Mark 10 and 420G models use SU HD8 carbs along with the Auxuiliary Starting
Carburettor - as you've described - making virtually four carbs in total.
E-Types still use HD8 carbs, but with a manual enrichment device (not a
choke) which lowers/raises the diaphragm/jet assy on all three carbs at
once. This arrangement is also used on the Rover 3-Litre (although single
carb) which can be a cheap source of parts for this assembly.
I converted my triple setup to SU HS8 carbs (but with .125 inch jets/needles
as per the original HD8) as they don't use the flexible diaphragm
arrangement of the HD8, don't smell and leak and therefore require less
maintenance.
Three nice SU's on a polished manifold look so good, don't they ?
Then, of course, towards the end of the run they put twin Strombergs on
E-Types for the USA. (!) Pity about that manifold arrangement also.
For David Rardin:
I can suggest checking the following if you haven't already:
Are your carb linkages working/connected to all three carbs ? (If you have
triples)
Are you confident that the carbs are rebuilt/setup as they should be ?
Is your fuel pressure up to scratch ?
Do you have fuel filter blockages ?
Is the ignition system clean ?
Is the compression pressure really as good as you believe it to be ?
Is the battery grounded well ?
Is the earth strap from the chassis to motor in place ?
After all, an XK/XJ engine in good condition should (ALWAYS) start at the
touch of the starter.
Neil Young.
To: jag-lovers; David Rardin
Date: Wednesday, 23 October 1996 3:17AM
jacket.
engine.
Hello,
triple SUs.
compression...
these slow starts!
Thanks, David R.
Date: Wed, 23 Oct 1996 19:29:23 -0400 (EDT)
Subject: Jaguar Starting Problem
I found the cause of my water leak and fixed that problem but now the
car only starts and won't stay running it was rainning quite hard as I
was finishing up with the bonnet open and I had to remove the battery
but nor really play with any wires. Is there something that might have
gotten wet to cause the car to stall right after it starts? Where do I
look first? Are there any wires that may be bad over on the battery
side that could cause such a symptom? I don't mind tackling the problem
but I do like to have some kind of method.
Thanks for any input,
Theo
1985 Sovereign Series III Euro Model.
Date: Wed, 23 Oct 1996 16:35:52 -0700
Subject: Re: 83 XJ6 Air Con Leak
Alex,
There are fluorescent dyes on the market which you can use to "find" leaks
in the A/C system. You charge the system like normal, but use the tracer
dye. Run the system for awhile and then check all of the hoses and the
receiver/dryer, condensor, evaporator, compressor, hoses, couplings, etc.
The dye will show up under a black light. (ultra violet).
> From: BD1Y0CA@NJMKTNG.BELL-ATL.COM
> To: jag-lovers(a)sn.no <jag-lovers@sn.no>
> Date: Tuesday, October 22, 1996 5:17 AM
> Alex Lynch
> 83 XJ6
> 62 TR3
Date: 23 Oct 96 21:05:42 EDT
Subject: XJRS 6.0 cuts out
I'm new to jag -lovers, but have owned and maintained V12 XJS's for many years.
I have recently purchased another one, 1989 XJRS 6.0 in A1 condition FSH and
low mileage (35,000). BUT it has one of those nightmare intermittent
electrical faults !
Occasionally when warm / hot the engine just stops, this happens at Idle or
when moving slow. It will usually restart after a few goes or if left for a
couple of mins. But seems to be getting more frequent and harder to restart. It
shuts of clean no spluttering, and when it restarts again runs normally.
The fuel pump runs for the usual 5 - 8 secs., when the ignition is turned on,
and fuel can be heard returning to the tank. The pump relays were replaced and
fuel filter changed, so assume these items are functioning correctly. I have
examined all connections to the ignition power amplifier, distributor and coil
which seem OK. I suspect one of these items, the coil, which is different from
my other '88 XJS 5.3 which is the common cylindrical shape, this one is smaller
and sort of a "lumpy cube" shape, or maybe the power amplifier ??.
This is driving me nuts, it runs fine whenever I try to get someone to look at
it, can't swop bits from the other car because a lot of the injection stuff is
different !!!
Anyone had similar experience, or offer sugestions ??
1990 XJRS 6.0 mileage 35,0000
John
Date: Wed, 23 Oct 1996 21:14:34 -0400
Subject: Attitudes/ Rear Brake Removal
I've read the comments about other driver's attitudes with great interest.
After a year of driving our '93 Silver XJ-40, I can say that we've had no
adverse reactions at all from other drivers. I put it down to the fact that
we're crawling (or should I say "Prowling) with Jags here in my suburb of
Seattle. But, an old friend, on seeing the car for the first time, did
comment: "That's a show-off car isn't it!"
Now, the real reason for writing - How does one remove the rear brake
disk/drum unit from the hub? I wanted to check the parking brake shoes and
lubricate the actuating mechanism. I have the breakdown illustration, and
understand how they fit together, but the drums will not budge. A local Jag
mech agrees that this is common. His advice is to beat them off with a
rubber hammer. What's the "real" answer? Thanks in advance.
This is a puzzle to me because the car has always been garaged, and there is
no rust on it. Maybe I should just pull the hub and drum as a unit and
repack the wheel bearings while I'm at it. Comments?
Ron Miller '93 XJ-40
Date: Wed, 23 Oct 1996 21:56:20 -0400 (EDT)
Alex: Get ready to remove the dash, if it is the core leaking, that is
the only way.
> Alex Lynch
> 83 XJ6
> 62 TR3
Date: Wed, 23 Oct 1996 22:35:32 -0400
Subject: car for sale
Just wondering if anyones interested in a 77 xj6c $5000 cdn.
Thanks Tony Moon.
Date: Wed, 23 Oct 1996 20:45:05 -0500
Subject: XJS, I have parts left over
Now I have done it. I have the cooling system back together, but I hace a
hose left over, complete with clamps on both ends!!!
I know, fill it with water and put the hose where the water comes out.
Realy, I need help since I cant find anyplace for this hose.
It is 7/8" or maybe 1" hose shaped like this:
________
| ______ \
| | \ \____
|_| \_____|
It obviously connects two pipes that are at right angles to each other and
the hose goes around something. Where does it go? I cant see anything left
open. It is probably in a region where it cant be reached without removing
the engine.
Also on the subject of the XJS. You may remember that I have a wire I
cannot identify. I traced it back to a vacume device of some sort on the
right side air cleaner box. This device also has a hose that goes from it
to the underside of the intake manifold. It appears to be an electricaly
operated valve that alows air into the manifold when 12 volts is
applied????? Maybe????
Anyway, the wire I was trying to identify is hooked in parallel to this
device and runs in front of the engine and dead ends near the left side
thermostat with nothing to connect to.
Does this help identify the wire?
Jim
"Better an outlaw than not free."
Nance O'Neil
Date: Wed, 23 Oct 1996 23:21:36 -0400
Subject: Re: North American toll-free numbers
Have you ever tried the AT&T direct numbers? I've used these in the past and
then used a Mastercard or Visa instead of a calling card, Don't know if it
will still work but the numbers from the UK are 0800-89-0011 or 0500-89-0011.
This will get you an AT&T operator in the US. Give it a try, it should be
cheaper and easier then using BT.
Date: Wed, 23 Oct 1996 20:39:56 -0700
Lee,
I've never had a problem successfully removing any of the polyurethanes
I tested from the veneer without damaging the veneer.
I've refinished two sets of interior wood (one from an 'S' type saloon,
the other from a MK X) in the last year. My experience is that the
durability of the finish is influenced by not only the formulation of
the polyurethane but also how it was applied.
I've determine from a series of 2 level factor experiments that the most
durable, and to my eye, the most aesthetically pleasing finish was had
from first staining the veneer with a Danish oil stain, then overcoating
this with a particularbrand of exterior grade polyurethane so that the
final thickness of the polyurethane is between 0.5 and 1.0 mm. My
experiments also revealed that waxing the polyurethane with carnuba
increase by 40 percent the time it took to get detectable polymer
degradation. (I attempted to do accelerated testing in a test chamber
where I could control the UV flux and spectrum along with the
temperature and humidity that my test strips were exposed to. )
BTW, the least durable finish was just Danish oil stain alone because
under 60% humidity and 40 C the veneer lifted when it was only stained.
( I did not try staining and waxing. The wax might prevent the swelling
of the glue. I do not like the look of stain alone. It simply does NOT
look like the finish on the wood in MK II's and MK X that I saw in the
showroom of B.M.C. of San Francisco in the mid '60's. )
My 'S' Type's wood has been in the car with the new finish since
December 1995. I wax it about every four weeks and drive the car about
500 miles a month. Looks good so far. I expect (O.K., I'm hoping) it
will last at least 10 years.
Robert Paulson
1966 3.8 'S' Type
1965 MK II
Lee Walden wrote:
> Richard,
> > Hello All,
> > Thanks in advance.
> > Richard
Date: Thu, 24 Oct 1996 00:07:53 -0400 (EDT)
Subject: Re: E-Type cold starting
David:
Carburetor adjustment would be my guess. There are three adjustments on each
SU: idle, mixture, and fast idle.
The idle adjustment is the large screw on the top of each throttle body.
This adjusts the idle speed.
The mixture adjustment is the small screw near the bottom of the fuel bowl.
It is used to adjust the gas/air ratio.
The fast idle adjustment is the small screw which interacts with the
accelerator linkage. It both enriches the cold mixture, and speeds up the
idle (by 'pushing down' the accelerator linkage when the choke is pulled
out).This is where the problem probably lies.
Adjusting idle speed or mixture is a tricky process, requiring a unisyn or
similar tool to adjust and balance the carbs. But fast idle is fairly
insensitive to error: adjusting any of the three fast idle screws adjusts
the fast idle on all three carbs, and even if you make a gross error, all is
forgiven when you push the choke in.
The way I adjust this is as follows: with the engine running, and the choke
in normal positition, I tighten one of the fast idle screws until the engine
starts to speed up. Then I back the screw off until the engine drops back to
normal idle. I then adjust the other two screws in exactly the same way.
This gives the greatest possible range to the choke control. Test this by
pulling out the choke. The engine should idle at at least 1200-1500 RPM.
This should fix the problem.
There is one other possibility. I have a Plymouth which never starts cold.
It is due to the fuel in the bowl boiling out when the engine is shut down.
Dry carb=cranky start, until fuel reaches the carb from the tank. If you
turn the ignition switch to the 'on' position for 15 seconds, refraining
from cranking, the electric pump will fill the carbs and you should start
no problem. If this is the case check for leaks, or a faulty pump. If this
doesn't turn up a problem, try replacing the carb to manifold insulators.
I can tell you that my E starts like a jack rabbit in all weather, so there
is hope!
Mike Frank
1969 E-Type 2+2 (with triple SU's)
At 12:41 AM 10/23/96 UT, you wrote:
>Hello,
>these slow starts!
>Thanks, David R.
End of jag-lovers-digest V2 #461
id <PAA17392> for jag-lovers-digest-out; Thu, 24 Oct 1996 15:44:33 +0200 (MET DST)
Date: Thu, 24 Oct 1996 15:44:33 +0200 (MET DST)
Message-Id: <199610241344.PAA17392@ekeberg.sn.no>
Subject: jag-lovers-digest V2 #462
Precedence: bulk
jag-lovers-digest Thursday, 24 October 1996 Volume 02 : Number 462
GM400 Mods
XJ6 Trip Computer Reset
Heater Control Valve
Re: XJS, I have parts left over
How to afford an XK8
Cruise control 1987 XJ40
Re: JAGUARS AT BATHURST - The Plot Thickens.
Re: FW: still leaking XJ-S/ BATHTUB
Re: Electrical
Re: XJRS 6.0 cuts out
Re: Electrical
Could I have The last "Attitude"Comment?
RE: Attitudes
Re: Heater Control Valve
Re: GM400 Mods
Alternator diodes - XKE
Refinishing Wood
Date: Thu, 24 Oct 1996 00:57:39 -0005
Subject: GM400 Mods
My XJ-S help book is definitely a little vague in the area of
modifying/improving the GM400 transmission. D'you suppose this might
be related to the fact that my GM400 is sitting under a tarp? Maybe.
I'd like to solicit a little more input in this area, but rather than
just opening it up to "what all can be done to this tranny" (which
would probably add another 100 pages to the book), I'd like to begin
with a more specific question:
If an XJ-S owner is largely uninterested in performance (wouldn't
mind a little less sluggishness off the line, but doesn't wanna burn
rubber; wouldn't mind firmer shifts, but doesn't wanna be jolted)
and finds himself having the GM400 pulled outta the car for an
overhaul, what recommendations should he be given for doing a simple
rebuild for improved durability?
And, please, whereever possible, include any available specifics.
If a different torque convertor should be fitted, exactly what
torque convertor should he ask for? If different sprags are in
order, where to get them? Are there two sets of sprags? Should
both be upgraded, or only one? If a "shift kit" is appropriate for
such a customer, is there a specific kit to ask for?
As always, thanks.
-- Kirbert | If anything is to be accomplished,
| some rules must be broken.
| - Palm's Postulate
Date: Thu, 24 Oct 1996 00:19:54 -0500
Subject: XJ6 Trip Computer Reset
The trick with reseting the trip computer is to hold the reset button
down at least 15, maybe 20 seconds. Interestingly, both previous owners
of my Jags had this problem, and thought the units defective. There is a
referece to this procedure in the owner's pack, but I saw in your
posting you did not have documentation.
Art in Baton Rouge, La, USA
Date: Thu, 24 Oct 1996 01:29:16 -0400
Subject: Heater Control Valve
The recent thread regarding the heater control valves, and whether they
should close all the way, was timely. I am just having to replace my valve
again, which has become stuck open due to corrosion.
Kirby suggested an all-plastic valve "available anywhere" which is used on
late-model Jaguars. Kirby, you wouldn't happen to have a part number or more
specific year/model? For my car, the control valve wants to be closed until
vacuum is supplied.
Also, while on the subject of corrosion in the coolant circuit, including
radiators, expansion tanks, water pumps, et al. An old-time mechanic once
told me he didn't use commercial anti-freeze, just distilled water plus a
bottle of mineral oil was sufficient to extend the freezing/boiling
tempratures and provide anti-corrosive properties. Any thoughts on the
soundness of this idea??
Thanks for all the good discussions and tips shared on this list; I have been
enjoying it!
- --David Quintana
1971 SI XJ
Date: Thu, 24 Oct 1996 02:10:40 -0400 (EDT)
Subject: Re: XJS, I have parts left over
> ________
> | ______ \
> | | \ \____
> |_| \_____|
I would first guess the heater return tube to lower radiator hose neck. the
lower rad neck is a tee afair. Main lower hose connection pointing straight
back, and the heater return pointing up. The tube runs along the left frame
rail.
If not that, then check right head to heater valve, valve to core, and core
to return tube.
This is most likely the wiring left over after doing one of the evap.
emissions updates/recalls. It's been a while since I've done one, so
I'm a bit foggy. I'll try to remember to check tomorrow.
> Jim
Randy K. Wilson
randy@taylor.infi.net
Date: Thu, 24 Oct 1996 16:47:00 +1100
Subject: How to afford an XK8
You blokes in the USA have got it made! One of my industry journals
recently outlined the case of one of your countrymen entering a fun run.
He strapped a refrigerator onto his back, ran some way, the straps
broke, the fridge hurt him and he SUCCESSFULLY sued for $420,000. Of
course then you'll have to find an orthopedic drivers' seat in Connolly
leather...
Regards Peter Smith
Date: Thu, 24 Oct 96 01:59:20 -0700
Subject: Cruise control 1987 XJ40
I have started to experience a problem with the cruise control on my XJ40. After
I have set the speed I wish to travel at it will work fine then some time, later
it will loose the seting and the car will loose speed. If I reset the speed it
will work for a while and then loose speed and basically cut out so that it
needs resetting again.
Does anyone have any ideas as to the problem?
Derek <dparnell@shlci.ca>
Date: Thu, 24 Oct 1996 19:25:20 +1000 (EST)
Subject: Re: JAGUARS AT BATHURST - The Plot Thickens.
Are you all sitting comfortably?
I have since my last message, heard from an organisation based in
Perth, W.A. known as "THE PITSTOP BOOKSHOP" who specialise in Automotive
Books, Magazines, Manuals & Videos ("little boys' stuff?). Anyway, their
current catalogue actually lists the crucial 1985 Bathurst Video, and:
(i) it is only $A25.10 there;
(ii) they will accept an 'international' mail/phone/fax order, claim
that they will charge only the actual post & packing cost; and
(iii) accept payment by Mastercard or Visa!
So, you are able to order direct from them, by phone, fax or post.
They are open 7 days a week (Sundays, afternoon only.)
POSTAL ADDRESS: THE PITSTOP BOOKSHOP,
48, King Street,
PERTH.
W.A. 6000.
AUSTRALIA.
TELEPHONE: 61 9 322 5544.
FACSIMILE: 61 9 322 5535.
N.B. For AUSTRALIAN Orders only, they have the following convenience contacts:
'phone: 1800 622 422;
OR post: Reply Paid 393,
48, King Street,
PERTH.
W.A. 6000.
Jim Ellis.
(1963 Daimler 2.5 v8 Sedan)
Jim Ellis
Internal Auditor
University of New England,
N.S.W. 2351.
AUSTRALIA.
'phone: (067) 733497;
[national: +61 67 733497;]
fax: (067) 733314;
e-mail: jellis@metz.une.edu.au
Date: Thu, 24 Oct 1996 11:02:51 +0100
Subject: Re: FW: still leaking XJ-S/ BATHTUB
Have you tried dusting chalk (or talcum powder) on the seals, then hosing
water at the (closed) doors? You could also try a pressure washer.
This will often show where the bad fit is, if anywhere.
Ian
On Oct 18, 1996 08:53:06, 'Aaron Burnett <aaron.burnett@attws.com>' wrote:
>I should have added another detail to this account. My car was hit in
>the driver's side about two months ago. The door was replaced and the
>driver's side front quarter panel was pulled back into shape. All new
>seals were installed. Perhaps there are seams I should be looking at?
>Thanks again,
>Aaron
>'85 XJ-S
Date: 24 Oct 96 06:42:06 EDT
Gavin,
If a battery goes flat overnight, its something that you thought was off is
still on, take a few minutes to think of what it could be, I came up with, light
in the boot (trunk) staying on, electric aerial motor still trying very hard to
wind down the mast, central locking still trying, electric windows, or a
personal favourite, door lock or mirror heating element stuck on, pull those
fuses first and see if you can see a difference on the meter.
Hope this helps
Date: Wed, 23 Oct 1996 18:02:57 -0500
Well, I guess it's time for my tuppence.
Pros: In my 22 continuous years of Jag ownership, I have never been the
recipient of a direct negative comment. On the contrary, a surprising
number of complete strangers take the time to offer compliments. Most are
of the simple "nice car" category, some tinged with a perhaps a bit of
envy. The E-Type generates significantly more positive reactions than my
XJ-S, no doubt due to the large number of XJ-S's on the road in this area.
Back in '88, when an XJ-S convertible was a rarity, it got almost as many
comments as the E-Type. When either is parked, people will often stop to
look at them. At gas stations I often get questions and requests to look
at the V-12.
Cons: Although I have not gotten any negative comments, other driver's
nonverbal reactions vary. For the most part it's not unusual for someone
to adjust their speed to look over one of the Jags, especially the E-Type.
On the other hand, it also isn't unusual for someone who I am overtaking to
speed up suddenly as if to say "you're not going to get ahead of me." This
seems especially likely if the person is a young male who is driving a
Camaro, Firebird or VW and I am driving the XJ-S. It's as though being
overtaken by a red luxury convertible was a direct insult or challenge.
(Oddly enough, this also happens if I overtake someone while driving the
Chevy Suburban. Being passed by a truck also seems to provoke them.
Nobody ever cares when I go by in the Honda, no matter how fast I'm
traveling.)
Most other traffic "salutes" and other incidents are most likely
attributable to the normal hazards of driving in fairly congested areas. I
do get cut off and otherwise irritated, but no more so in the Jags than the
other family vehicles.
Oh yeah, I almost forgot. When the XJ-S was brand new I got a traffic
ticket for doing absolutely nothing. I think I was actually found guilty
of driving around in a new Jag with the top down on a perfect Spring
Saturday when the cop was in a bad mood. I don't worry too much about it,
I just reflect on all the times I have broken the traffic laws and didn't
get a ticket. I'm still way ahead.
MikeC
'74 E-Type (Series 3 OTS)
'88 XJ-S (H&E Convertible)
'88 Honda Accord (over 340,000 miles - takes a lickin' and keeps on tickin')
'91 Chevy Suburban (I too have a lump, only mine is where it belongs)
'96 Honda Accord (the first was so damned reliable we bought another)
Date: Wed, 23 Oct 1996 18:35:19 -0500
If your trip computer is like the one in my XJ-S, you need to press
"reset" and hold it for several seconds. Just a momentary press does
nothing.
MikeC
Date: Thu, 24 Oct 1996 13:23:54 +0200 (MET DST)
Subject: Re: XJRS 6.0 cuts out
Just some ordinary electrical/electrnic trouble-shoorting might help :
keep the engine running and use a medium-seized screwdriver and know gently
with the handle on suspect parts and connectors. I've diagnosed a few
bad electronical connectors using this method (no LUCAS parts :-) )
Also, if you have, check the connections of your car alarm. I had this
problem on my XJ-S, e.g. bad contact in ignitition disable circuit.
- - Matthias
Date: Thu, 24 Oct 1996 13:30:49 +0200 (MET DST)
Something else very easy available and usefull to chase these kinds of
problems is a light bulb. Start with a low power, say 5W wired IN SERIE
with the "-" pole, e.g. instead having the "-" battery wire going
directly to the
car ground, route it through the bulb. Always use the negative pole
for security reasons. Don't try to do this when the engine is running, e.g.
the alternator is charging. This might destroy a lot of electronics.
If everything is
off, I guess it should not light even a little bit. You can then start
troubleshooting. The problem with a amp meter is when by accident you use
some big power, it might blow. The bulb will simply light up.
Date: Thu, 24 Oct 1996 07:46:35 -0400
Subject: Could I have The last "Attitude"Comment?
Just had to make one more comment Re: attitude. Got my first E in 1966.
Wife and I were driving around Waco, Texas. This gentleman pulls
alongside at a stop light and sits staring at us. We finally had to
look over. His comment--"You'r eaten up with a complex, arn't you?"
Light changed we move on, laughing, leaving him in the dust! Now
there's a complex for you!
Tom
PS---What should the gap width at the rear of the bonnet be in order to
accomodate the safety catch? I have a nice close fit, but the latch
won't latch with it so close. I don't like a wide gap at this location.
Date: Thu, 24 Oct 1996 11:00:14 -0700
Subject: RE: Attitudes
There is a fundamental problem in the UK with regard luxury cars,
especially Jags, and that is to take whatever action is necessary to
pass them. We Jag owners know from day one that we will be targets of
the green eyed monsters driving, I use the term driving loosely, the
hot hatch/rep-mobile/all round naff motor. I have on several occasions
been the victim of mob rule on the motorway, being boxed in by these
people who have no respect for other road users and should be ignored.
There is nothing better than a p***ed off road hog who has no idea whats
going on around them and looses it at the last minute.
Well with that off my chest I don't think any of us really put drag
strip
performance as a serious criteria for buying a Jag. I prefer to cruise
in the 45 - 65 MPH band and so long as there is a free lane to my right
for the faster drivers I don't care. None of my driving bears any
relation to the cost because there is nothing in the rules about Jags
and cost. As for age, who cares, if you can afford the car drive it.
When buying a Jag We put engineering, style and all round beauty before
anything else. If you need to ask how quick the Jag of your choice is
then you haven't spent enough time looking at your dream. A Jag is a Jag
and that is all that matters, difficult to understand but that's how it
is.
Barrie Dawson
Chatham, Kent England
1985 Series III Sovereign
Date: Thu, 24 Oct 1996 08:52:40 -0400 (EDT)
Jim: The hose looks like the heater hose connected to the right rear
cylinder head and comes from the heater control valve.
Wire went to the 45 sec air valve that is open on start up for 45 seconds
to help the cat light off.
Chad Bolles Jaguar South 306 Valcour RD Columbia SC 29212 USA 803 798 3044On
> ________
> | ______ \
> | | \ \____
> |_| \_____|
> the engine.
> Jim
> Nance O'Neil
Date: Thu, 24 Oct 1996 08:56:20 -0400 (EDT)
Subject: Re: Heater Control Valve
David: Go to Autozone, PepBoys, Advance Auto, etc, ask for a heater
control valve for a Olds Cutless year try 1983. If the valve is correct
you will be able to blow thru it holding it in your hand. The Jag valve
is a normal open valve, and so is the Olds.
Chad Bolles Jaguar South 306 Valcour Rd Columbia SC 29212 USA 803 798 3044On
> vacuum is supplied.
> enjoying it!
> --David Quintana
> 1971 SI XJ
Date: Thu, 24 Oct 1996 09:09:38 -0400 (EDT)
Subject: Re: GM400 Mods
Kirby: Keep in mind that the Turbo 400 is nothing but a GM unit with a
different bellhousing. Any mod that can be made to a Chev 400 can be
made to the Jag unit. B&M makes a kit called a TRANSPAK around $50 from
ASAP, JEGS, SUMMET and people like that. They also make racing overhaul
kits around $50 also. Different valve bodies are also available. TCI also
makes just about anything you want including a lower 1st gear set around
$500. Everybody makes converters, but the Jag unit uses a HI-Stall
converter now, it is the same converter used in the 427 L-88 and LS6 and
LS7 Chev, flash stalls around 2600-2800rpm, the diffence being the Jaguar
converter has 6 lugs on it where the Chev has 3. Remember that the higher
the stall the more heat the trans makes,meaning the more cooling you
will need.
And you are right this could go on for another 2 or 3 pages.
> As always, thanks.
> | - Palm's Postulate
Date: Thu, 24 Oct 1996 09:12 -0500 (EST)
Subject: Alternator diodes - XKE
I am also interested in rebuilding my alternator. Where can one find
replacement diodes? This alternator is the original Lucas and is 30
years old. I'm tired of getting laughed at when I ask someone at a
parts house for any of parts (although I do luck out once in a while).
BTW, excellent responses on the electrical short troubleshooting
everyone.
Robert Abascal - '63 XKE OTS & '66 XKE Coupe
Date: Thu, 24 Oct 1996 09:43:19 -0700
Subject: Refinishing Wood
I haven't refinished any interior wood in Jags but
I refinish over 30 wood canoes in my shop each year.
Urethane varnishes don't work on wood that moves with
humidity changes. They will eventially crack, how long
will depend on the formulation of the varnish. Urethanes
are hard and scratch resistant and work well on hardwood
floors where they aren't exposed to sharp temperature
and humidity changes. They tend to be used in production
work because of their fast drying and low cost.
Spar varnishes have the ability to flex with wood
but are slow to build up to a high gloss finish.
We use 4 or more coats to get the best finishes on both
hard and soft woods. Sanding between each coat to level
out the previous coat and create a tooth for the next
coat. The varnish we use in our shop is a marine spar
varnish with UV filtration made by Pettit Paint Products
#2353 (Bak V).
1..Remove ALL previous varnish
2..Sand up to 400 grit
3..clean
Apply varnish. If you want to make the varnish dry quicker
use a drop or two of Japan Dryer. Don't use solvents to
thin the varnish, just warm it to reduce viscosity.
Be careful about "no load" sandpapers. They have a
silicone lubricant and can cause flow problems with
the varnish. If anyone has any questions please don't
hesitate to contact me at canoe@online.net
Bill
Ontario, Canada
End of jag-lovers-digest V2 #462
Return-Path: @owner-jag-lovers-di1
Received: (from majordom@localhost) by ekeberg.sn.no (8.7.5/8.7.3/on4)
id <AAA08240> for jag-lovers-digest-out; Fri, 25 Oct 1996 00:05:22 +0200 (MET DST)
Date: Fri, 25 Oct 1996 00:05:22 +0200 (MET DST)
Message-Id: <199610242205.AAA08240@ekeberg.sn.no>
To: jag-lovers-digest@sn.no
Subject: jag-lovers-digest V2 #463
Reply-To: jag-lovers@sn.no
Errors-To: @owner-jag-lovers-di1
Precedence: bulk
X-Newsgroups: mail.jag-lovers-digest
jag-lovers-digest Friday, 25 October 1996 Volume 02 : Number 463
Hood opens at one side
Re: 83 XJ6 Air Con Leak ( Alex: )
Vaccuum advance problem
Attitude
E type All-sychro conversion
Mouse died - seatbelts '90 XJ-40 (US spec)
V-12 vs. AJ-V8
XJ-S ground effects kits
Re: Mouse died - seatbelts '90 XJ-40 (US spec)
1939 Jaguar
Attitude
Re: Vaccuum advance problem
Re: Cruise control 1987 XJ40
Re: Alternator diodes - XKE
E-type For Sale
Buying a Jag...
SIII xj beautification
"A New Breed of Jaguar"
Re: Hood opens at one side
Date: Thu, 24 Oct 1996 15:59:58 +0000
Subject: Hood opens at one side
Maybe I should introduce myself before I ask for help again...
My name is Roger Hartonen and I have a Daimler Vanden Plas from -85.
We, me and my whife, bought it 2 years ago with a few known faults...
It's imported from England to Sweden and rebuilt from RHD to LHD. Maybe
not the best thing to do, but that's how it is. The car is now running
as our everyday car in the south of Norway. (Moved with my work.)
I have had some troubles with the steering, oil leaking etc. and the
latest thing was a scratching sound from somewhere around the brakes. I
got some help from Chad Bolles indicating that it could have been
something with the shielding around the u-joint making contact with the
exhaust pipes. This was not the problem!
The previous owner had the handbrake fixed, and the guides to keep the
breakpads in correct position were not put in correct position.
After fixing that, the noise disapeared!
Now to another small thing.
My hood keeps opening on the right hand side. When hitting a bump the
righthand side pops up. I have tried to adjust the bolts with the
springs going down into the chassie, but no success.
Anyone had this problem before?
Thanks for any help!
Roger
Date: Thu, 24 Oct 1996 10:46:55 -0400
Subject: Re: 83 XJ6 Air Con Leak ( Alex: )
Alex-
suggest you find someone with an electronic freon sniffer- they can
check all joints and hoses in engine compartment quickly, and also
check the air outlets in the cabin. Leaking evaporator core will show at
air outlets. Of course the system has to have >some< freon in it to
check for leaks. :)
If core is leaking, dash has to come completely apart (major job).
Cheers,
Brian Sherwood
84 XJ-S, 85 XJ6
Date: Thu, 24 Oct 1996 11:29:35 -0400
re;
>Camaro, Firebird
Hi Mike and all,
Just as a non-vanity plate is, to me, the ultimate
cool, so is being passed 'on purpose' by a ...
whatever.
If I'm in a racing mood, of course I will perhaps
speed shift to 3rd and say au revoir, but usually
my playful version of cool is to not increase speed
and as they blast by, I know they are probably
thinking, *damn, I wish I had *all* that money,
and *all* that time!" (Makes them feel very
unimportant -to me)
Little do they know that if I got ahead of them all
that leaking oil would put them, James Bond-like
into the guard rail!
Charles Daly, Toronto, Canada
'62 E-Type, ots
Date: Thu, 24 Oct 96 08:27:13 PDT
Subject: Vaccuum advance problem
Help. I need a sanity check here.
'71 4.2 liter, standard ignition. I just replaced the vaccuum advance. If
I remove the vaccuum line to it, the car does not change idle speed.
At idle, the vaccuum retards the spark, removing the line should speed up the
idle speed, right? Also, the timing does not change.
I believe this to be true of all distributers, right?
The advance is not the original number, it is the same size/shape, but the
diaphram may require more 'suck' to retard the spark. The dual carb 4.2 may
not 'suck' hard enough for it. The advance mech moves freely in the distributer
and the mechanical advance works fine.
I may have to get an original number advance, which is big bucks and made of
unobtanium.
LLoyd
Date: Thu, 24 Oct 1996 11:43:38 -0400
Subject: Attitude
The only rude comment I ever remember getting about my cars are, "Jags are
unreliable." That was true of almost every car at one time or another.
Those people all wish they had a Jaguar anyway. They're trying to
rationalize their situation. When I drive my XKE 2+2 people respond with
the reverence the car deserves. On the other hand, when I drive the XJS
conv. in the city a lot of favorable comments and questions are offered at
stop lights. On the interstate cars hover near by and then an inevitable
race begins. They all think they have to prove themselves by passing a
Jaguar. Driving Jaguars is one of the most rewarding experiences in my
life. Jaguar has more character than attitude.
Jack Bednarski
71 XKE 2+2 V12
90 XJS VDP
95 XJS Conv V12
Date: Thu, 24 Oct 1996 08:51:04 -0400
Subject: E type All-sychro conversion
I have a 61 and 63 E type that I'm slowly restoring, and have reached a
point where I now am looking at the transmissions. These will be driver
cars for me - and everyone tells me to use all-sychro boxes as I will hate
the moss box.
Is the conversion simply re-machining the original and existing bell
housing for the all-sychro box, and using the original and existing starter
and clutch ?
Was is the going price for a used all-synchro box?
Any experiences out there ?
Thanks in advance.
- -Tom SF, California.
_____________________________ _____________________
Tom Canning E-mail: tomc@ncd.com
District Sales Manager Voice: 415.921.3819
Network Computing Devices Inc. Fax: 415.694.4541
350 North Bernardo Avenue http://www.ncd.com
Mountain View, CA 94043 ftp://ftp.ncd.com
Date: Thu, 24 Oct 1996 12:05:51 -0400
Subject: Mouse died - seatbelts '90 XJ-40 (US spec)
Driver's side seatbelt mouse suddenly quit yesterday ending an amazing 6 year
repair free streak on my XJ-40.
Is this a know problem? Where do I start ? Is safety equipment like this
covered under any longer warranty than the rest of the car in US???
Thanx... John ex: 150FHC, 3.8mkII, Xj6C
Date: Thu, 24 Oct 1996 12:43:53 -0005
Subject: V-12 vs. AJ-V8
An observation, just to stir up discussion:
I was told before that racing teams used to use Nikasil liners in
the Jaguar V-12, but gave them up; the weight saved was not worth
the reduction in reliability. Reportedly the Nikasil would start to
get "picked up" by the rings, and the effect was cumulative and
exponential with the whole engine going to hell very quickly once it
started. Using iron liners, the Jaguar V-12 established itself as
one of the most reliable engines in endurance racing.
I also happen to know a guy that builds racing Porsches, and the
cylinders (aluminum stock, I presume Nikasil or some similar idea)
ALWAYS have an iron sleeve installed.
Now, Jaguar introduces the XK8 with its new AJ-V8 engine -- with
Nikasil cylinders.
I can only draw two possible conclusions from this:
1) Technology has advanced, we now know how to make Nikasil work
long term.
2) Regardless of durability, Nikasil is a lot cheaper way to build
engines than iron liners.
Guess which one I'm betting on?
One possibly related item: Sometimes you hear about engines that are
made SMALLER when set up for racing. Usually the obvious conclusion
is that the stock engine exceeds class limits and the displacement
must be reduced to make the engine legal. However, maybe there's
another reason/benefit: if the engine is cast aluminum with Nikasil
cylinders and the casting is too thin to machine out and install
full-size iron sleeves, perhaps the answer is to install iron sleeves
with a smaller bore. Result: durable engine, but smaller
displacement than stock.
| - Palm's Postulate
Date: Thu, 24 Oct 1996 10:18:00 -0700 (MST)
Subject: XJ-S ground effects kits
I have an Arden ground effects kit installed on my XJ-S. The car has been
rear-ended and the
rear bumper cover destroyed. It is my understanding that the Arden kit is
manufactured in Germany, but I have not been able to find an address for the
company. I have contacted several US suppliers for a replacement panel. They
all have indicated that they no longer stock the Arden kits. I think a TWR
rear panel would work, if I could find one. Can anyone on the Jag-Lovers
list help me?
Michael
Date: Thu, 24 Oct 1996 10:23:51 -0700 (MST)
rear-ended and the
list help me?
Michael
P.S. I have just been informed by majordomo that there will be a delay,
while waiting for on my subscription request for jag-lovers. Please e-mail
any suggestions to me at armsco@primenet.com
Thanks
Date: Thu, 24 Oct 1996 11:02:10 -0700
Subject: Re: Mouse died - seatbelts '90 XJ-40 (US spec)
Hi John,
You might want to check with your dealer. My 91 Sovereign had a seat
belt retractor problem and I discovered that it was covered for the
life of the car....something to do with a "safety recall" I think
Good luck,
don
Donald R. Farr
Paradise Valley, AZ 85253
(602) 948-7499 - fax
91 Sovereign
d.farr@phx.cox.com - e-mail
http://people.phx.cox.com/dfarr/dfarr.htm - Don's Homepage
http://people.phx.cox.com/dfarr/jetta1.htm - Jetta Notebook Computers
http://people.phx.cox.com/dfarr/march10.htm - Wireless products
http://people.phx.cox.com/dfarr/ncs1.htm - National Consulting Services
Date: Thu, 24 Oct 1996 11:03:38 -0700
No Jag Content...
I was tooling along the Autobahn between Kasierlautern and Mainz one
weekend. I was in the second lane in my 85 Saab Turbo doing about 110 KPH
(70 MPH+-). These Army guys come up on me in a 5.0 Ltr SHO Mustang and
pull over to pass. I never knew what the 5.0 Ltr SHO could do, but I knew
what the Saab could. Since they slowed down to take a look as they went
past, I pulled in behind them and accellerated. They slowly pulled away.
I moved up quickly and they slowly pulled away again. I kept doing this
until they didn't pull away, they just pulled over, and I blew past them at
127 MPH. So much for "big Detroit Iron".
On another trip, my brother took a picture of the dash as we were driving
the 'bahn up to the Alps outside of Munich. The picture shows the speedo
at 135 MPH, and I had to slow down because the Mercedes in the fast lane
wouldn't yield. Calculated Top Speed was 142MPH, and I believe it could do
it with the intercooled turbo. Alas, someone stole the car from my
apartment complex in 1990. Probably in Mexico being driven by a Federale.
Now all I have for "fun" is a '94 Capri XR2 and my Mark X. I keep looking
at the 93 XJS though. Lee
> From: charles daly <cdaly@passport.ca>
> Cc: Mike Cogswell <M.Cogswell@zds.com>
> Date: Thursday, October 24, 1996 8:29 AM
> re;
> >On the other hand, it also isn't unusual for someone who I am overtaking to speed up suddenly as if to say "you're not going to get ahead of me." This seems especially likely if the person is a young male who is driving a Camaro, Firebird Hi Mike and all, Just as a non-vanity plate is, to me, the ultimate cool, so is being passed 'on purpose' by a ... whatever. If I'm in a racing mood, of course I will perhaps speed shift to 3rd and say au revoir, but usually my playful version of cool is to not increase speed and as they blast by, I know they are probably thinking, *damn, I wish I had *all* that money, and *all* that time!" (Makes them feel very unimportant -to me) Little do they know that if I got ahead of them all that leaking oil would put them, James Bond-like into the guard rail! :>) Charles Daly, Toronto, Canada '62 E-Type, ots From: "Donald R. Farr" <d.farr@phx.cox.com> Date: Thu, 24 Oct 1996 11:07:00 -0700 Subject: 1939 Jaguar Good morning everyone, A couple of days ago I was made aware of a 1939 Jaguar for sale here in Arizona, and I offered to put a picture on my server for the world to see. If you have an interest it's at http://people.phx.cox.com/dfarr/39jag.htm Donald R. Farr 91 Sovereign Paradise Valley, AZ http://people.phx.cox.com/dfarr/dfarr.htm - Don's Homepage http://people.phx.cox.com/dfarr/jetta1.htm - Jetta Notebook Computers http://people.phx.cox.com/dfarr/march10.htm - Wireless products http://people.phx.cox.com/dfarr/ncs1.htm - National Consulting Services From: Juliansean@aol.com Date: Thu, 24 Oct 1996 14:09:40 -0400 Subject: Attitude I have had several complimentary comments on my (now deceased) convertible XJS, but the most humorous antics concerning this car are from my friends and officemates. In particular my co-workers choose to highlight the negative aspects of Jaguar ownership (but always in a friendly way). However, I know that this is only a product of their inner envy at not being able to afford one. For example, I have had many people poke their head in my office to tell me how they saw a such&such type of Jag broken down and of course they immediately thought of me and laughed etc. etc. etc. Secretly, they want this to happen to me and are dissapointed that due to preventive maintenance I have defied the law of Jaguar ownership (i.e. inevitable breakdowns). The best one was the office joke about a "Jag-o-copter" which would fly around to spot broken Jaguars from the air and rescue the occupants. They humorously suggested that the Jaguar Car Co. was so ill-managed that they would do that rather than simply make the cars more reliable. They had a lot of fun with that one. Julian Mullaney From: Michael Frank <mfrank@westnet.com> Date: Thu, 24 Oct 1996 14:15:33 -0400 (EDT) Subject: Re: Vaccuum advance problem Lloyd: You have the idea right, but the action is the reverse of what you describe. The advance is connected to the carb venturii, where vacuum increases with engine speed. Beyond idle speed, the incremental vacuum will pull in the advance mechanism, a_d_v_a_n_c_i_n_g the spark. So removing the line at idle speed should have little or no effect. If you apply vacuum to the line, you will observe the engine speed increasing, and the timing advance. Mike Frank 1969 E-Type 2+2 At 08:27 AM 10/24/96 PDT, you wrote:
>unobtanium.
> LLoyd
Date: Thu, 24 Oct 1996 13:18:29 -0500
Subject: Re: Cruise control 1987 XJ40
Derek wrote:
<snip>
After
later
speed it
it
Had a similar problem once. Turned out that the brake cutout switch was
mis-aligned.
Date: Thu, 24 Oct 1996 13:45:05 -0600
Subject: Re: Alternator diodes - XKE
> everyone.
Called heatsinks..the part nos are Lucas- 54218133 and 54219249
I have one 54219249 at $44.50.
Hal
Hal Rogers
H.D. Rogers & Sons
(318) 742-5044 fax
Date: 24 Oct 96 14:38:59 EDT
Subject: E-type For Sale
For those interested, I am selling my 1971 E type FHC. This is NOT a 2+2 car. It
is a manual transmission car with factory air. It has 91,000 miles on it. I
rebuilt the motor about 1,000 miles ago. Good driver.
E-mail if you are interested. 102073.3171@compuserve.com
Thanks;
Sean
Date: Thu, 24 Oct 1996 22:15:04 +0100
Subject: Buying a Jag...
Hi!
I've finally decided to have a closer look at buying myself one
of these fine vehicles. The other contestants in this class, like
Mercedes or BMW, don't quite offer this mix of class and refinement...
but enough of the fine words.
I'd like a car that's fast, luxurious and relatively hassle-free. I
think that a 82-83 XJ12 or a 85-86 XJ6 would suite my needs, but
this is where I need your help:
- - first of all, I'd like manual transmission. Is this possible with
the V12 engine?
- - if I wan't a lot of equipment, which "model" should I be looking for,
and how do I know which is which?
- - as for the latter, I'm considering importing a Jag from Germany: is
there anything I should be aware of concerning this?
Thanx very much in advance,
Mr. Jan-Aage Bruvoll
Date: Thu, 24 Oct 96 13:04:48 PDT
Subject: SIII xj beautification
Most Series III xj cars have a problem with the front windshield and
backlight seals shrinking, especially the glass to metal (inner) seal.
If this is not properly seated, water will sit in the channel. The result
can be leaks, or the almost inevitable bubbles of rust just below the
outer seal. The inner seal is easily refitted. I did mine last night, thus:
I removed the inner seal starting at the bottom, but I left the top part
intact since this is not where the problems are. The problem area is
almost always the curves, top and bottom. On some cars the seal simply
pulls out, with no visible sealing action. On mine, there was a good quantity
of silicone sealant. I cleaned that from the seal, and any loose bits from
the channel, vacuuming the entire channel to remove any dirt or loose
sealant. If your seal has been loose, then you may have a lot of sandy
dirt. DO NOT USE WATER. water and Jaguars=rust. Vacuum the channel thoroughly.
I then squeezed a generous amount of black silicone sealant into the channel
and began to refit the seal. THIS IS THE IMPORTANT PART. You must refit the
seal pushing AGAINST, or TOWARDS the part already fitted, otherwise you risk
pulling or stretching the seal, and the same problem will eventually occur.
The curves are particularly important, so there should be no pulling at
that point. If there are any spots where the stainless steel finisher
does not sit tightly againstthe seal, some sealant should be used to make
sure that there is no ingress of water. At the bottom, in the centre
of the windshield there was a gap owing to shrinkage of the seal. Because I
had a new length of seal (put aside for the eventual $$$$$$$$$$ concurs
paintjob), I simply cut a small piece to insert. The result is perfect,
and because my seal has been preshrunk (years of use), I don't expect
any more movement of the seal. The same procedure can be used on the
real window, although mine does not need it. For the small patch at the
bottom of the windshield, a piece from a wrecker would be fine (remember
that they just pull out). The outer seal (stainless steel to body) also
shrinks, but as it does so, it pulls IN (i.e.gets tighter, not looser).
There is still the matter of the gap at the bottom, and I believe that this
is fitted under the stainless steel, so it is more difficult. Any ideas?
Gregory Andrachuk, late 82 xj6
Victoria, Canada
Date: Thu, 24 Oct 1996 17:21:53 -0005
Subject: "A New Breed of Jaguar"
I received my FREE video tape from Jaguar today, "A New Breed of
Jaguar", introducing the XK8. My review of the video: At least they
knew what it was worth! It's less than 10 minutes long, and it's a
complete waste of those 10 minutes. Just a bunch of old fogeys at
the factory talking about how new everything is.
You gotta wonder who's in charge down there at Jaguar these days.
They go to the effort and expense of shipping a free video, and they
don't put anything in it you couldn't get from a 1-minute ad on TV!
Seriously boneheaded. The only way in hell you could talk me into
shipping tapes by s-mail would be if they included all the details
you CAN'T put on TV -- about an hour showing all the mechanical
innovations, the assembly line at work, road tests of the car, etc.
| - Palm's Postulate
Date: Thu, 24 Oct 1996 17:02:11 -0500 (CDT)
Subject: Re: Hood opens at one side
Roger,
Welcome to our humble list. There are a couple of fairly recent comments
on this topic in the list archives that might be of help.
Larry Lee
End of jag-lovers-digest V2 #463
id <OAA22170> for jag-lovers-digest-out; Fri, 25 Oct 1996 14:25:31 +0200 (MET DST)
Date: Fri, 25 Oct 1996 14:25:31 +0200 (MET DST)
Message-Id: <199610251225.OAA22170@ekeberg.sn.no>
Subject: jag-lovers-digest V2 #464
Precedence: bulk
jag-lovers-digest Friday, 25 October 1996 Volume 02 : Number 464
Seat Mounting Bolts -- XJ-S
Re: Attitudes & Attitudes
Re: V-12 vs. AJ-V8
Re: E-Type cross member specs.
RE: V-12 vs. AJ-V8
Information on E-Type Wheels
RE: XJS, I have parts left over
Re: jag-lovers-digest V2 #461
Re: V12 - opinions needed
Re: "A New Breed of Jaguar"
Re: E type All-sychro conversion
RE: Jag Drivers Problems with Drivers of
Re: Buying a Jag...
Date: Thu, 24 Oct 1996 18:35:01 -0005
Subject: Seat Mounting Bolts -- XJ-S
This thread has already gone on far too long, but I need to report
one more development.
To recap: If you don't like the grief involved trying to hold the
nuts in place while bolting the seat to the floor, you can replace
the nuts on the FRONT TWO bolts with "extruded U nuts", while
replacing the two bolts with Allen drive "cap screws" in order to
mate with the coarse threads of the U nuts.
Now, for one further stipulation: The U nuts come in "regular" or
"long", referring to the distance the bolt can be located from the
edge the U nut is clipped over. For this application, you may need a
mixture! On my car, the bolts near the console require the long U
nut. However, the regular length is the item of choice for the bolts
nearest the doors, since the long clip would stick out and catch
passengers on the ankle -- causing runs in hose!
One of the nicest benefits (IMHO) is the use of an Allen wrench to
install. My car came with large Phillips screws, which really suck.
I'll probably look around for fine thread Allen cap screws to replace
the rear two bolts! I understand newer cars come with Torx screws,
which would be much better than the Phillips.
| - Palm's Postulate
Date: Thu, 24 Oct 1996 18:35:02 -0005
> LLoyd:
> advance. If I remove the vaccuum line to it, the car does not
> change idle speed. At idle, the vaccuum retards the spark, removing
> the line should speed up the idle speed, right? Also, the timing
> does not change. I believe this to be true of all distributers,
> right?
> Mike Frank: You have the idea right, but the action is the reverse
> advance.
Here I am, jumping in where I have no business (don't own a 6-cyl).
If Mike's description is correct, it will be the first and only
vacuum advance I've ever heard of that works this way. Worse yet, if
the car has SU or Zenith Stromberg carbs, it won't do anything, since
these are "constant depression" carburetors and the vacuum at the
venturi is constant.
On every car I have ever seen, Lloyd's description is much closer; the vacuum advance is connected to the intake manifold, so maximum vacuum is applied at idle and advances the spark. The intention is to provide more advance at part throttle conditions, optimizing fuel economy. However, on many American cars, the vacuum advance is "ported", meaning that it is connected to a tiny orifice right at the edge of the butterfly. If the butterfly is open, this orifice is essentially downstream of it and therefore sees manifold vacuum. As the butterfly moves toward idle, the edge of the butterfly itself passes over the orifice, so the orifice ends up on the air filter side of the butterfly -- and sensing outdoor air pressure. With this type of setup, the vacuum advance goes away when the throttle is at idle. There are several implications to this. First, supposedly this helps emissions, since it's difficult to meter fuel properly at idle; since the retarded timing kills the efficiency and requires that the throttle be opened up to maintain idle, the mixture can be more precisely controlled. Second, this lower efficiency adds to the heat rejection at the same conditions where the water pump is barely effective, so it adds to overheating problems at idle. Third, since there is no vacuum at idle, you don't have to disconnect the vacuum line when adjusting the timing at idle. Fourth, if you are dealing with a typical American auto mechanic with s__t for brains and you DON'T have ported vacuum, he will assume it works the same as his Chevy and leave your vacuum line connected while adjusting the timing and REALLY f__k it up! Trying to explain it to him will do no good, you can just plan ahead to redo the timing yourself as soon as you get home. Kirbert | If anything is to be accomplished, | some rules must be broken. | - Palm's Postulate From: Kyle Chatman <kchatman@mail.coin.missouri.edu> Date: Thu, 24 Oct 1996 17:32:38 -0500 Subject: Re: Attitudes & Attitudes Going from the University System administration building where I work to = one of the campuses for a meeting, I entered a parking garage where 1/2 = the available spaces were roped off with a guard posted. I was in a = hurry and asked the guard if I could park on the empty side. He asked if = I was a Curator. I said, no but that I worked for them. (Technically = true if misleading.) The Curators were meeting in a building near the = parking garage. I was waved in. Anyway, this nice man thought that I was = a state university curator (governing board member) because I was = driving a Jag -- a 14 year old Jag that I bought for $5000. Name another = $5000 car that people assume is being driven by a wealthy and powerful = state figure. Actually that's rhetorical. I don't really want to know. 1983 XJ6 From: JISBELLJR@mail.utexas.edu (Jim Isbell) Date: Thu, 24 Oct 1996 17:53:51 -0500 Subject: Re: 83 XJ6 Air Con Leak ( Alex: ) The electronic sniffer can be had from JCWhitney very cheap. If you sniff freon at the center vent in the dash but not under the hood you have a leaking evaporator. The cost with labor and all is about $1200 to $1500. Its not cheap, but you dont want to do it yourself its a bitch of a job. JIM I. "Prefiero morir de pie que vivir de rodillas." Gen. Emiliano Zapata 1879-1919 From: "Jim Cantrell" <jimc@sysdiv.sdl.USU.edu> Date: Thu, 24 Oct 1996 17:05:52 MDT Subject: Re: V-12 vs. AJ-V8 Kirby wrote:
> started.
Yep, you can't fool the laws of nature. It is bitch hard to get good
bonding between nickel plating and aluminum that can withstand
thermal and mechanical fatigue. As any oldtime plating specialist
knows, plating is good when you can "encase" the material in the
plating material and thus making a "shell" of the plated material
over the object. I cna't tell you how much grief I have encountered
from pulling gold and nickel plating off of various spacecraft parts
by being anything but extremely careful. I can well imagine that
Nickasil, whatever concoction it may be, is not a very durable
material for a cylinder liner. This whole experience reminds me of
Chevrolet's sad experience during the 70's with a similar design that
was done to save a few pennies per car and ended up costing them big
bucks in warranty and worse, market share.
Once again, a well proven technique that has been used over and over.
Someting's ringing in my head about not fixing something that's not broke.
> Nikasil cylinders.
Well, Jag has always been known for reliability problems - deserved
or not. Sometimes you have to feel compelled to carry the torch.
> long term.
I am very skeptical about this since no major new types of Nickel
alloys that can be plated have been recently developed to my
knowledge. In my mind, the problem is still of how to bond
dissimilar metals in a durable way without creating a plating
"shell". My gut feel is no new technology here but that the
controlled test conditions (ie good maintenance, no abuse etc) has
shown this to be viable when combined with very good quality control
techniques. Only time will tell the real story.
No doubt. One has to ask, why use it ? Is it more durable (doubt
it) ?. Does it give reduced emissions ? (not likely). Does it
improve performance ? (why would it?). Nice for sales brochures ? (a
slightly extreme conspiricy theory). The bean counters upstairs ?
Why do the lights come on in my head with this answer ?
They want to emulate Chevrolet of the 70's ??
This is a good question Kirby. I myself am highly skeptical of this
design as it seems designed to save a few bucks with possibly
disasterous results. It reminds me of the kinds of design mistakes
that the young guys make around where I work. "Hey its a new
technology that's real neat and saves us some money - proimotions to
follow via peter principle".
Kind Regards,
Jim Cantrell
Date: Thu, 24 Oct 1996 19:13:35 -0500
Subject: Re: E-Type cross member specs.
> 17" Long x 1and 3/8" Wide x 3/4" Thick
>(at least thats what is on my '63 Etype (878974)
>Good lifting.
Thanks a million. I had a piece fitted there for seveal years, but it was
taped on instead of wired. Apparently, I hit one bump too many and away it
went. I'll post this again on the list in case someone misses your reply.
Date: Thu, 24 Oct 96 20:20:18 EDT
From: ** SHANE MANTOSZKO ** IBMA INVENTORY ANALYST **
*** Resending note of 10/25/96 00:34
*** SYDVM1(SHANEM) PH. (02) 354-4918 CUMBERLAND FOREST FE21
*** INTERNET - SHANEM@VNET.IBM.COM *** IBMMAIL - AUIBMSPM ****
Roger, this is common as hell. There are a number of contributing
factors that can cause it. Address them all and you shouldn't have a
problem. They worked for me and are :-
1) Spring has gone slack in the locking mechanism.
Pull it all apart, and fit a new, thicker spring to the assembly. The
thicker one will hold tighter and get you through those bumps
2) Pin is not coming down in right place
The pins may be at the wrong angle, and so are not sitting right in
the catch assembly. This will mean that the half-moon catch may only
be holding a bit of the pin head, and so a bump causes it to release.
Use a soft rubber mallet and carefully tap the pins straight.
3) The half-moon catch plate that the spring holds is worn
This can be adjusted to close the gap. It should be covering just under
half the hole that the pin goes down into. If it isn't, try adjusting
it. If it cannot be adjusted any further, you will have to drill new
holes for it's screws and move the whole plate closer.
4) Bonnet not adjusted down tight enough
Close your bonnet, and then put your hands on the outside above the
lock assembly, and push a few times gently. There should be little if
no play on the bonnet. It should be a nice snug fit. If the bonnet
rattles up and down, then you need to adjust the pin length a bit at a
time until it closes fine, and holds snug.
5) Worn pin
Here in Sydney, maybe elsewhere, you can buy pins with slightly over
size heads that can last longer, and will make up for some of the
wear in the half-moon latch plate.
6) Bonnet not fitted correctly
Look along the edges of your bonnet and make sure it is properly
aligned. If not, it will twist a bit and will put pressure on the
latch mechanism, which may cause it to release with a slight bump.
Tackle all of these, and you should definitely fix the problem. Make
sure you clean and re-lubricate the assembly when putting back together.
Date: Fri, 25 Oct 96 01:42:42 UT
Subject: RE: V-12 vs. AJ-V8
One article I read stated that the main reason for using Nikasil instead of
iron was to reduce the weight of the engine. Engine power to weight ratio was
supposedly one of the driving factors in the AJ-V8 development.
Besides other issues, we must remember that the Jaguar engineers have to come
up with some bragging rights for their engine to justify the development and
manufacture of an engine other than a member of Ford's Duratec modular engine
family. Had the bean counters really had their way, the XK8 would be powered
by some version of Ford's global engine family rather than a complete new and
different design (although they are using Ford of England factory space to
build the motor).
Only time will tell how durable the new motor is, but we should all realize
the incredible pressure's Jaguar's engineering group must have been under to
do something out of the ordinary with this engine design in order to justify
the effort. On paper they have succeeded in building a smother, more
efficient engine than the off the shelf Ford motors. Hopefully it will have
sufficient reliability to be a long term success.
John
Date: Thu, 24 Oct 1996 22:02:08 -0400
Subject: Information on E-Type Wheels
Hi There:
I would appreciate some technical information on E-type rear suspension
-best type of shocks & setup
- springs
-explanation of the function of radius arms and their refurbishment
-advice on tires -I would like to install the widest tires possible
I have a '69 roadster that I restored last summer. It's a 4.2 E-type.
Thanks for your trouble. I look forward to hearing from you.
John
Date: Thu, 24 Oct 1996 19:23:50 -0700
Subject: RE: XJS, I have parts left over
If this is a 3.6L XJ-S, it looks like the heater hose that goes from the rear of the head into the firewall. The outlet from the head is under the intake manifold -- real difficult to see.
Mike Everatt
1987 1/2 XJ40
From: James A. Isbell[SMTP:JISBELLJR@mail.utexas.edu]
Sent: Wednesday, October 23, 1996 6:45 PM
Cc: Kirbert
________
| ______ \
| | \ \____
|_| \_____|
the engine.
Jim
Nance O'Neil
Date: Thu, 24 Oct 1996 23:04:32 -0400 (EDT)
Subject: Re: jag-lovers-digest V2 #461
> From: John Goodman <101547.1141@CompuServe.COM>
> different !!!
> John
Yes, I've had the same problem with my 89 X-JS. It turned out to be the
crankshaft sensor connector. Engine would cutout at any speed. I could
jiggle the crank-sensor and car would start again. If you have the
Marelli digital ignition system you will have a crankshaft sensor and a
flywheel sensor, engine will not run if the signal is interupted from
either. Look for a two wire connector on the left front top of the
engine, wires should be in a hard plastic wire protector running down
the front of the engine to the back side of the crankshaft pully.
I found the contacts in this connector to be green and nasty. Cleaning
with spray-on relay and contact cleaner cured the problem. Run the
engine and wiggle this connector and see if it stops. Also check the
flywheel sensor connector, its on the rear top left of the engine, looks
like the crank sensor connector and, hard to get to.
greg
Date: Thu, 24 Oct 1996 20:12:13 -0700
There is a lifetime warranty on the "mouse on a string" passive restraints
for the XJ40. Call your dealer, make an appointment and have them make sure
the part is in stock. Be nice to them and get your car serviced at the
same time.
Date: Thu, 24 Oct 1996 20:44:52 -0700
Subject: Re: V12 - opinions needed
If you are going to replace the cam cover gaskets get the good ones from
the dealer. They are a piece of stamped shim stock and are sandwiched by a
new type of material, for Jaguar<g>. Do not use any kind of sealer on them.
At 07:24 PM 10/21/96 -0400, Chad Bolles wrote:
>Julian: If you have never worked on this engine before, just plan on an
>afternoon, lay out all your parts, take your time and you can do it.
>JUST REMEMBER the cam covers are not held on with head bolts and only
>require 8 ft lbs. I have found that a LITE< THIS MEANS LITE coating of
>silicone on both sides if the gasket, then install the cam cover and
>tighten the bolts by hand, finger tight, leave alone for 4 to 6
>hours,giving the silicone time to set then torque,all I have ever done
>that way have NEVER leaked.
>Mon, 21 Oct 1996 Juliansean@aol.com wrote:
>> I am considering replacing the valve cover gaskets and intake man.
gaskets on
>> a 1991 V12 XJS.
>> Should I pay $450 for someone to do this, or go for it myself. I'm quite
>> mechanical etc. , it's just a question of it it worth the bother???
>> Opinions??
>> Thanks
>> Julian Mullaney
Date: Fri, 25 Oct 1996 09:17:28 +0100
Subject: Re: "A New Breed of Jaguar"
Same goes for a approx 30 pages brochure ("Sovereign") about the
XK8 which I picked up at the dealer in Grenoble, France. Just telling
stories about those people they gave this car for a try - nothing down to
the fact AT ALL. If this is how they want to sell this car, they'll never
ever sell even a wheel to me.
Having seen the XK8 in nature (haven't sit in nor driven), I think it looks very
much like a very fine sportscar. On a second glance from the front, you could
imagine it to be a Jaguar.. On the rear, they fortunately put a Jaguar sticker ...
id <CAA24031> for jag-lovers-digest-out; Sat, 26 Oct 1996 02:57:35 +0200 (MET DST)
Date: Sat, 26 Oct 1996 02:57:35 +0200 (MET DST)
Message-Id: <199610260057.CAA24031@ekeberg.sn.no>
Subject: jag-lovers-digest V2 #465
Precedence: bulk
jag-lovers-digest Saturday, 26 October 1996 Volume 02 : Number 465
Spare parts antenna
Re: V-12 vs. AJ-V8
RE: V-12 vs. AJ-V8
Re: V-12 vs. AJ-V8
Attitude & E-type Frames - (Long?)
Re: Buying a Jag...
Re: Screeching Sound
New Jag
re: XK8 vs. V12, Nicosil
RE: jag-lovers-digest V2 #461
Re: Attitude & E-type Frames - (Long?)
XJ40: Intermittent Starting Problem
XJ40: Tool Case in Boot?
engine click
For Sale
E Type All Synchro
'70 E-type air cleaner box finish - what to use?
Date: Fri, 25 Oct 1996 14:35:51 +0100
Subject: Spare parts antenna
Hi everybody,
I've got the drive gear of the antenna motor completely worn out - Jag dealer told me to change the whole set for CHF 500 (that's $400). Does anybody have an adress where to order these things (XJ6 '84)? The rest of the assembly work perfectly, so I don't see a reason to change everything.
BTW, I had an intermittently working speedo. I took off the transducer to order a new one, but then I thought I might have a look as it was already broken. I had to open the case (carefully as it is a disposable design ...) and to spoil the sealed cable feedthrough - there had been a wire broken in this feedthrough. The interior is full of electronics, gee ...
I've got it sealed again with epoxy, closed the case - works perfectly now. The drawback is that I now will get a precise idea of fuel consumption on high mountain roads. Anyhow, each drop is well spent.
Regards
Bert
Date: Fri, 25 Oct 1996 09:58:40 -0400
In 15 or 20 years, when the price of a used XK8 has come down to a
level I can afford, maybe I'll buy one with a worn out engine, and
transplant
a V12! The engine from my '84 will probably just be "broken in" by then. :)
Brian Sherwood
Date: Fri, 25 Oct 1996 09:16:10 MDT
Kirby wrote about the vaccuum advance on an XJ6:
> vacuum advance I've ever heard of that works this way (retards when
> vacuum applied)
Well, actually, I used to work as a Ford mechanic while putting
myself through college. During that time, it was common for Fords
of the late 70's and early 80's to have two ports on the distributor
"vacuum module". One port acted as a traditional venturi based
advance and the other was a distributer timing "retard" port. This
port was connected to a maze of emissions hoses. The purpose of this
"retard" port was to retard the timing under certain temperature
conditions in order to reduce cold running emissions. It was common,
however, for the "do it yourselfer" to get these ports mixed up and
the results were very interesting. Not that this has anything to do
with a Jaguar, but when I read the original post, I imagined that this could be
possible but not likely since I don't know about the model in
question. However, I have seen distributors whose shaft bushings are
worn have this effect since the force of the vacuum advance shifts
the gap on the points thus altering the dwell thus retarding the
timing. I always check the play in the distributor shaft bushings
when I have the cap off since these bushings wear more than one would
imagine.
> economy.
> get home.
> | - Palm's Postulate
Kind Regards,
Jim Cantrell
Date: Fri, 25 Oct 1996 11:51:50 -0005
John Horner:
Of course. That was the reason for its trial in the racing V-12's
too. Lessons apparently were not learned.
> build the motor).
While I'm sure that there is a lot of pride going around these days
regarding this all-new all-Jaguar engine, I personally am quite sure
that not using the Ford Modular was a BIG mistake! The Ford Modular
is an excellent engine, and you can get parts for it anywhere! It
would have been a relatively simple matter for Jaguar engineers to
have based their design on this engine, perhaps creating a
high-performance version or some such. As it is, it won't be long
before somebody will be yanking that Nikosil-cylindered
hard-to-find-parts-for British motor for a Chevy lump.
> the effort.
I wonder what pressure they see. If it were ME applying the
pressure, that car would have come out a LOT differently than it did!
| - Palm's Postulate
Date: Fri, 25 Oct 1996 13:41:36 -0400 (EDT)
> long term.
Maybe both? I believe that Ferarri has been using Nikasil cylinders since
the 308 series. Many other cars use 'em, too. My hi-po boat engine has
them. Maybe the state of the art has gotten them to the point where the
original service life is acceptable? However, the COST TO REBUILD is much
higher and this is an issue for those who keep their cars longer or buy
used vehicles.
It is ironic that Chevy has gone to Nikasil liners for their third
generation lump V8. Jag is right in lock-step with GM! :)
I have no doubt that a Nikasil engine is cheaper to
manufacture that one with separate liners.
John
'82 XJ-S with an easily rebuildable V12
This is an interesting observation. I always thought this was done to get
into a better class. Any racers out there?
Date: Fri, 25 Oct 1996 13:45:44 -0400
Subject: Attitude & E-type Frames - (Long?)
Hi Everyone,
Great reading all the stories about attitudes. I have no bad ones to =
offer, only great hand turning looks, stares, questions, =
can-I-sit-in-it, how's the maintenance, is it fast, a 12 or the 6, etc., =
and whenever someones puts the car down because it's always in a repair =
shop, and they had a lift home in it afterwards, they'd always leave by =
saying "Can't wait to tell insert name here that I drove in a JAG!" I =
loved the fact people automatically assumed I had a great salary, or =
lot's of money. Their car was always more expensive than my Jag, and I'd =
tell them! but still it meant nothing. Sometimes this attention was =
good, other times when I had to hide the car to not give this impression =
to people was a bad side. I have sold this XJ6 I'm talking about, to =
spend time with my E-type, and everyone how's heard about me selling it, =
claims I was crazy! Ya, and where were you when I owned it! On the side =
of the I-made-a-bad-move-to-buying-into-trouble-side?!=20
I remember a drunk fellow walking with his buddy along the sidewalk. I =
was sitting in my car waiting for my son to come out his friends house =
for his lift home. The drunk fell over his feet and down beside my car =
about 3 feet away. I had my sunroof open, so I heard what his friend =
would say. He said "Man, you almost fell and damaged a $50,000 car!! I =
had to smile, because I paid little, the car was rusted, and it would =
never start, but the *impression* is/was always there over this car. =
(Ok, he WAS drunk....but you know what I mean) lol=20
As far as driving goes, I would always get into the fast lane and run =
with the big boys. A had a great 2 hour drive with a BMW driving to =
Ontario. I was always between 145-165 kph, (don't know the conversion to =
mph) and he ran with me exchanging leads. No one wanted to run with us. =
When I slowed for my exit, we waved to each other....he in his 45 grand? =
car, me in my 6 grand XJ6. I never had anyone throwing anything, saying =
anything, or kicking anything over my Jag. I am an ex-steel worker, 220 =
pounds, neck like a bull, 6 feet, so I'd not take this crap from =
strangers - only the fun provoking from friends. I would even wear my =
worker blues to drive to work in the Jag, and why not! Welding was =
paying the bills! I wouldn't get cut off or actually let myself get cut =
off or wedged out. If I'm in the fast lane and they won't move over, I'd =
pull on the inside, then scare the heck out of they by pushing them =
towards the wall as I take over the fast lane and give then the shaking =
head tisk-tisk. I could be diplomatic when I need be, but my patience is =
short for idiots.....like me! lol My wife bitches as she should, but the =
heck with them. They usually back off, seldom want to "play" CAT and =
mouse. If a car comes up behind me, I don't stay, I move for them, so I =
have no attitude problem...... I guess?=20
To my other topic, I just bought an E-type front rail (A Martin Robey) =
unit from John Farrell. I saw his ad in Hemmings. XK's wanted $1100, and =
$1400 for SICP I think, but this John Farrell wanted $685! It wasn't a =
copy, but a real Robey unit, and I purchased it. I must say, at 50% less =
than other places, it should be considered. He has only 2 drivers side =
units left I believe. I thought someone might want this info and act =
fast. E-mail me and I will give his number. I don't have it with me as =
I'm typing this...
Mark Budd
1970 E-Type OTS
1986 XJ6 (1995-1996)
Date: Fri, 25 Oct 1996 20:08:08 +0100
Subject: Re: Buying a Jag...
Hi.
>Daimler I guess
Aren't there different models of the Jaguars? (I'm thinking of the
Sovereign, etc.)
>Importing to which country ? There might be BIG issues with emissions etc.
>There has been a recent thread of importing cars to the US and I think
>someone provided a very complete list of about 2 pages full of requirements ...
Sorry, I forgot to state which country I live in. Actually I was hoping
that Nick Johannesen would reply on this one, as I too live in Norway.
Thanx for your comments anyway.
- - Jan-Aage
Date: Fri, 25 Oct 1996 13:56:58, -0500
Subject: Re: Screeching Sound
- -- [ From: David V. Kerner * EMC.Ver #2.5.1 ] --
The starter engages the flywheel in only one of three places. If the
flywheel is worn in one of those places it will occasionally not engage.
The engagement of the starter flywheel is some what random, but will
always be one of the three.
Bud
Date: Fri, 25 Oct 1996 14:38:10 -0400
Subject: New Jag
I'm off to pick up my new XJS Convertible (new to me that is). It's a 1991
white with black canvas, barley interior in absolutely ultra-mint condition.
Only 32,000 miles, one owner.
I got it for an excellent price too, so right now in hindsight the tree
falling on my '87 seems like a blessing in disguise.
Julian Mullaney
"Preferio to drive jaguars even if it takes all my dollars"
Date: Fri, 25 Oct 1996 14:48:59 -0400
Subject: re: XK8 vs. V12, Nicosil
transplant a V12! The engine from my '84 will probably just be
Brian Sherwood
Date: 25 Oct 96 14:59:00 EDT
Subject: RE: jag-lovers-digest V2 #461
>greg
I will have a good look at these connectors on Sunday, I didn't know of these
sensors before.
Makes me wonder how many more I haven't realized !!
John
Date: Fri, 25 Oct 1996 12:59:59 -0700
Huh? It's called a ring gear for a purpose. If the starter pinion "only
engaged" the gear in one of "three" places, how would it turn the engine
through one or more complete revolutions necessary to start the car?
> From: MR DAVID V KERNER <bizmodel@prodigy.com>; WWRJ84A@prodigy.com
> To: jag-lovers@sn.no; jag-lovers@sn.no
> Date: Friday, October 25, 1996 11:56 AM
> Bud
Date: Fri, 25 Oct 96 15:28:23 CST
Subject: Re: Attitude & E-type Frames - (Long?)
All,
From my 15 years experience, I will tell you that John is a good guy and
generally tries real hard to offer better value. He is often the first to
produce small, hard to find parts that the others manage to carry (probably
via John) many months later.
I've got nothing but praise for John and hope he enjoys many good years in
business. Unfortunately, the best deals don't last forever (see below) or
come around often and I resorted to used frame rails due to availability at
the time.
Steve K.
______________________________ Reply Separator _________________________________
Author: Mark Budd <mbudd@inforoute.net> at smtplink-tellabs
Date: 10/25/96 3:10 PM
Hi Everyone,
<super large snip>
I'm typing this...
Mark Budd
1970 E-Type OTS
Date: Fri, 25 Oct 1996 13:39:33 -0700
Subject: XJ40: Intermittent Starting Problem
I have slight problem with my 1989 XJ40. Actually, it's embarrassing to
me rather then a "problem". When ever I start the car it USUALLY starts on
the first try with barely a full effort from the starter. However, for some
reason when people are admiring the car, it may take two or three turns of
the key to start!
It really urks me that it happens when people look at the car and then
this happens (Now, the phrase about Jaguar problems is usually emitted!),
but when I MYSELF drive it, all is fine! It is usually when the car has
been used frequently and is still warm. No problems when COLD.
I just changed the fuel non-return valve, and that made A LOT of
difference, and now starts great except for the "once in a blue moon" hard
starting.
So, what next? Any idea if the temperature sensor could be faulty, and
not adjusting the fuel flow accordingly to temperature? If anyone even
knows of the current, voltage, etc. that the sensor should be at, and I
could measure with my multimeter that would be great!
Any comments on similar experiences or help greatly appreciated!
Thanks,
Eric (1989 XJ40)
Date: Fri, 25 Oct 1996 13:52:34 -0700
Subject: XJ40: Tool Case in Boot?
Does anyone know if their is supposed to be some type of tool case
mounted above the spare tire in the boot of an XJ40('89)? I've heard there
may be something there, but never saw anything in my car.
Due to a, now fixed, boot water leak, the floor rug and tire cover were
removed and disappeared. Now, I think some type of tool case is missing in
the boot too! I have the lug-nut wrench, jack and jack wrench hidden behind
the tire, but no other tools. It seemed curious as to why their is no
screwdriver to pop the wheel covers off with, that's why I think their
should be more tools, but they were removed by the PO.
Can anyone help, and describe what they have for tools in their boot?
Sorry for the ridiculus question,
Thanks in advance!
Eric
1989 XJ40-VDP
Date: Fri, 25 Oct 1996 16:19:55 -0600
Subject: engine click
Hello all, I'm new to your group. I have about three things to ask, but in
case there is an ettiquete thing,
I'll limit it to one question today.
I have a SIII 85 Sovereign that is making a clicking sound from the engine.
(I could swear it's getting louder as I get more worried). Bad valve, valve
guide? What might I be looking at? Will I harm the engine by continuing to
drive.
Appreciate your input.
Thanks,
Dan
Calgary
Date: Fri, 25 Oct 1996 17:43:14 -0700
Subject: For Sale
This is my first time to this group. I sold my XKE and XJ6 and have the
following parts which I found in my attic.
New Boot cover for 1970 XKE $200
air filter new XKE
rear u joints XJ6 $20 New
New brake part for XJ6 flat looks like it goes against brake drum???
Other parts
EMail Gene356@ix.netcom.com
Date: Fri, 25 Oct 1996 19:13:19 -0700
Subject: E Type All Synchro
Welsh Jaguar have 2 4.2 used transmissions at $850.00 ea. in their
latest flyer. Phone 1 800 875 5247.
In the early 60's I remember a person who fitted a Warner T
10 gearset inside of a Moss transmission case, he would sell
an information kit and parts. For this change it required
some machining of the case. Anyone remember this?
The Moss transmission is very strong and reliable. A lot of
drivers are accustomed to very forgiving All Synchro and have
a hard time managing a Moss transmission. If you have driven a
mid 30'struck with a sliding gear transmission like the one I
learned on (double clutch or don't shift). Compaired to it the
Moss is very smooth and good shifting.
Bill
Ontario, Canada
Date: Fri, 25 Oct 1996 18:25:40 -0600
>Brian Sherwood
I doubt that you will be able to do this. I would be amazed if Jaguar put
enough room under the hood for a V-12 when they are seem to be trying to
phase out that engine.
Phil Bates
58 MGA
67 MGB
75 Jaguar XJ12C
52 MG TD replicar (VW)
From: David J Shield <David_J_Shield@ccm.fm.intel.com>
Date: Fri, 25 Oct 96 17:50:00 PDT
Subject: '70 E-type air cleaner box finish - what to use?
Hi All,
My '70 XKE 2+2 is now a kit. The background is that this car was
little-used by the original owner, and the auto trans leaked badly.
*Much* too leaky to park it anywhere near a friend's house. I took
the car to my mechanic, whereupon the engine+tranny were promptly
yanked (money will follow the same path soon). So, since I'm on
vacation and the car is apart, I've spent a couple of days at his
shop doing the detailing that the engine compartment needs (that
I'm unwilling to pay for). It's kind of fun to hang around his
shop anyway.
Current status: All parts except for the pedal box and suspension
components are removed. I'll give the frame and bulkhead a good
scrub and scuff, then paint the frame (currently Willow Green) the
same color as the body (a not-unpleasant metallic bronze), unless I
decide to paint it yet another color. Now's the time to do that,
right?. Dunno how crazy I want to get on this particular car....
I've got all the brackets, widgets, etc. off and neatly stacked in
a pile, ready to be stripped and repainted. But here's the
question: The air cleaner box (the rectangular one for the
dual-Stromberg car, not the Hammertone round one for the triple SUs
that I wish I had) is a metal finish, not a painted finish. It's
straight and everything, but rusty and dull. What is the best
finish to put on this piece? Who's done this before? Is this
Cadmium plated?
As a side note, this car is very close to original, including the
placement of wire ties, hoses, etc. I've taken photos and lots of
notes, in order to put it back correctly with no extra parts. If
anyone has an originality question I'll do my best with it.
Bye!
'70 XKE 2+2
'84 XJ6 VDP
End of jag-lovers-digest V2 #465
id <SAA18672> for jag-lovers-digest-out; Sat, 26 Oct 1996 18:48:25 +0200 (MET DST)
Date: Sat, 26 Oct 1996 18:48:25 +0200 (MET DST)
Message-Id: <199610261648.SAA18672@ekeberg.sn.no>
Subject: jag-lovers-digest V2 #466
Precedence: bulk
jag-lovers-digest Saturday, 26 October 1996 Volume 02 : Number 466
clarification on my '70 E-type (now in partial kit form)
'84 XJ6 antenna
removal of vent pipes, carbon canister etc.
Electrical - has Gavin found the short yet?
Re: removal of vent pipes, carbon canister etc.
XKE Windshield
Re: XKE Windshield
RE: Electrical - has Gavin found the short yet?
Re: XKE Windshield
Re: E Type All Synchro
Date: Fri, 25 Oct 1996 21:57:04 -0400 (EDT)
At 06:35 PM 10/24/96 -0005, you wrote:
>Worse yet, if
Yes, you are correct about this: the advance is not connected to the
constant-depression venturii, as this would have almost no effect- my error.
The advance, in fact, is connected to a passage which leads to the piston
housing, and therefore is exposed to M_O_R_E vacuum as the engine load
increases.
I have been doing this stuff since I was 16 (43 now). I have NEVER seen an
advance which works that way. My experience includes most American cars,
Toyota, and Opel, so I am a relative newcomer to Britmobiles, but from what
I can see the British do it just like everyone else.
One exception comes to mind: Ford used to make distributors with a
dual-action diaphragm, as I recall. Under certain circumstances, vacuum
would be applied to the back side of the unit to cause the timing to retard.
It was used in the early-mid 70's emission control applications, and was
usually defeated by frustrated shade tree mechanics. This is the only case I
can remember of a 'retard diaphragm'.
That's true. An that is exactly what happens on my 4.2 Jag. If I place a
vacuum guage on the carb advance nipple, I observe that vacuum increases in
direct proportion to engine speed. At idle, the vacuum reading is ZERO.
Vacuum builds to around 15 Inches at 2000 RPM. According to Bentley, the
advance curve is:
In of HG Degress Adv
20 7-9
13 6-8.5
9 2.5-5.5
7.5 0-3
6 0-.5
0-4.5 0
So vacuum advance increases with engine speed.
This makes no sense to me. Retarded static timing will improve CO and HC
readings because the combustion temperature INCREASES. This is true whether
the diapraghm works by pushing or pulling. If the diaphragm retards timing
at idle, then releases at load, it is EXACTLY the same effect as the
diaprhagm doing nothing at idle, then advancing timing at load.
If the goal is to open the throttle to improve fuel metering, then why would
they not just open the throttle to improve fuel metering? There doesn't
seem to be a need to choke the engine to death just to make an excuse to
open the butterfly.
>get home.
Guess what? It does work just like his Chevy. In fact, the SU HD8's close up
tighter than any American carb I have seen, which always seem to leak a
little vacuum.
Yup: the 6's are the ones with the BIG pistons. And stop feeding me
straight lines ;-)!
Mike Frank
1969 E-Type 2+2
Date: Fri, 25 Oct 1996 21:09:43 EDT
I can second Steve Kemps comments. John stands behind what he sells and
will do whatever is necessary to make your purchase the right one at the
right price. I have been doing business with him since 1981 for both
both new and used parts.
Frank Filangeri
62 E OTS
On Fri, 25 Oct 96 15:28:23 CST Steve_Kemp_at_NBD@pcmail.tellabs.com
writes:
> All,
>guy and
>first to
>(probably
>years in
>below) or
>availability at
> the time.
> Steve K.
> Hi Everyone,
><super large snip>
>Robey) =
>and =
>less =
>I'm typing this...
> Mark Budd
> 1970 E-Type OTS
Date: Fri, 25 Oct 96 21:45:00 PDT
Subject: clarification on my '70 E-type (now in partial kit form)
Just a clarification - I said that all parts except the pedal box
and suspension components are stripped. I mean all parts from the
bulkhead forward. From there back, I don't need to do much. :)
So, it's a partial kit. I hope it's running in a month.
Date: Fri, 25 Oct 96 22:17:00 PDT
Subject: '84 XJ6 antenna
Bert,
Welsh Enterprises in Ohio (614.282.8649) sells the entire antenna,
new, for something between $120 and $150 USD (somewhere in that
range). When my antenna became balky, I tried a few times to take
it apart and make it work. The whole thing was tired, so I chucked
it and replaced it with a used one. For what I paid and what Welsh
charges, I should have bought the new one from them instead of the
used one elsewhere. But if you're up to rebuilding yours, you may
be able to get a non-functional one real cheap from the used-parts
places, with the part you need still intact. Otherwise, I dunno
where you can find *the* drive gear from the OEM.
I'd offer you my old antenna for free, but I tossed it a long time
ago. Does someone have a dead unit they can offer to Bert?
'70 E 2+2
'84 XJ6 VDP (the antenna usually stops an inch from the bottom)
http://www.ns.net/~dshield
Bert Writes:
Date: Fri, 25 Oct 1996 23:30:16 -0600
Subject: removal of vent pipes, carbon canister etc.
I have a 75 XJ12C. I noticed that in the parts book, the vent pipes are
listed for Canada and the US only. The carbon canister is listed for
Australia, Canada, Japan, and the US only. Having heard all the comments
about gasoline fumes in the passenger area of these cars, I was wondering
what would have to be done to remove these systems. I have the interior
out, and now would be an ideal time for me to take this stuff off, and
pinch/plug lines as required. I realize this may violate some environmental
regulations, but am not that concerned with such things right now.
Something tells me that closing and sealing off the lines is safer than
running 20 miles of pipe around the car, going through a carbon filter, and
returning back to the tanks again. If I could run the pipes only to the
carbon filter, and from there to the air cleaner or vacuum system, and get
rid of the additional pipes that go up the rear pillar (I think it is called
a C post), that would be enough for me.
Thanks,
Phil Bates
58 MGA
67 MGB
75 Jaguar XJ12C
Date: Sat, 26 Oct 1996 02:49:05 -0005
Michael Frank:
> increases.
I wouldn't have expected this either, since that vacuum changes only
slightly. Also, since what you want is less advance as engine load
increases, you're gonna have to have a vacuum module that works the
opposite way from most of them. Can't imagine why Jaguar would have
gone this way.
I'd invite you to inspect my parents' 1969 Volvo, which was
constantly being misadjusted by the idiots at the Volvo dealer when
they'd take it in for scheduled maintenance. Had full advance at
idle, you HAD to disconnect and plug the vacuum line when setting
the timing, they never did, it always came back retarded by about 15
degrees. By the way, it had dual SU carbs, too.
If you're running the engine unloaded (as that 15 inches of vacuum
indicates), 2000 RPM is just off idle -- you're just getting the
butterfly past the port. To see what the vacuum advance does, you
gotta monitor the vacuum under load.
> advance curve is:
> 20 7-9
> 13 6-8.5
> 9 2.5-5.5
> 7.5 0-3
> 6 0-.5
> 0-4.5 0
Exactly. Therefore, as the engine load increases and the vacuum
decreases, the advance also decreases. That's the way it works.
One wonders where this conclusion comes from. Vacuum advance is
unrelated to engine speed, it's related to vacuum (Duh!) which is
related to engine load.
Not if there's no enough oxygen available for burning that CO or HC.
The problem has to do with metering fuel within tolerances on an
assembly line putting out cars every 30 seconds. You have to have
the F/A mixture within limits, or combustion temperature won't do
anything. By increasing the F/A flow, it becomes easier to maintain
correct F/A mixture in production.
> This is true whether the diapraghm works by pushing or pulling.
> If the diaphragm retards timing at idle, then releases at load...
The diaphram does nothing at idle, little at load, a LOT at low
throttle.
> it is EXACTLY the same effect as the diaprhagm doing nothing at
That would be true, if (for some reason) you would want to advance
timing at load. But you don't, so what's the point?
> why would they not just open the throttle to improve fuel metering?
Well, for one thing, the engine would hit 2500 RPM at idle. For
another, all those cars with automatic transmissions would haul ass
as soon as you took your foot off the brake.
-- Kirbert | If anything is to be accomplished,
| - Palm's Postulate
Date: Fri, 25 Oct 96 23:45:00 PDT
Subject: Electrical - has Gavin found the short yet?
Gavin,
Have you found the reason for your battery running down yet? If not,
here's *my* advice. Get a 12V test lamp (they sell 'em at every car
parts place, and even drugstores) for a couple of bucks. With
everything off, remove one fuse at a time. Connect the test lamp across
that (empty) fuse holder position. The circuit that draws the current
will light the lamp, unless it's a real weak current draw (in which case
the battery will take many days to run down). This assumes, of course,
that the leakage is in a fused circuit (but it probably is). Then, you
can figure out which of the things connected to that fuse is the
culprit.
My '84 XJ6 VDP baffled me recently. Whenever it sat for a week (often),
the battery would be dead, though it's a good battery and tests good.
The glove box light was staying on. I removed the gove box lamp, end of
problem. Had I performed the above test, I would have found it sooner.
Gavin, if you've found the leak - what was it???
owner of a couple of jags
Date: Sat, 26 Oct 1996 02:56:41 -0005
Subject: Re: removal of vent pipes, carbon canister etc.
Whatever is telling you this is WRONG. The item in the pillar is a
vapor separator, does nothing but good. In fact, the whole SYSTEM
does nothing but good. We could go on all day about the pros and
cons of removing or disabling it, but in the end you don't wanna.
| - Palm's Postulate
Date: Sat, 26 Oct 1996 03:25:38 -0400 (EDT)
>increases.
In your case, the vacuum should rise as engine speed goes up, under no
load. As soon as you put it under a load, i.e. open the throttle, the
vacuum should drop away again. As described earlier.
Ported advance, manifold advance, manifold retard, venturi retard... they
all exist. and over the years Toyota has used all of them. In fact, they've
been known to use up to three at once... two different advances and a
retard in the same can (early 80's 4AC, among others).
The list of makers that used retards for exactly the reason Kirby described
is a long one.
Sorry, combustion temp will go down. Thermal efficiency goes down. Less
energy into moving the piston, more soaking into the cylinder walls and
going out the tail pipe. This is why an engine with retarded timing
can overheat.
The idea is to have the throttle open far enough to keep the air and fuel
flow up in a controlable range, then get the engine down to idle speed
by killing it via retarded timing.
Another stratagy used to get the same result was to put an undersized
carb on the engine. This improved the low speed efficiency, but killed
top end power.
>Mike Frank
>1969 E-Type 2+2
Randy K. Wilson
randy@taylor.infi.net
Date: Sat, 26 Oct 1996 05:54:20 -0400
Subject: XKE Windshield
Has anyone replaced their own windshield ? The local place wants $ 100. I
ordered one in and am considering doing it myself.
Doug
Date: Sat, 26 Oct 1996 12:37:15 GMT
Subject: Re: XKE Windshield
On Sat, 26 Oct 1996 05:54:20 -0400, DHarr13177@aol.com wrote:
>Has anyone replaced their own windshield ? The local place wants $ 100.=
I
>Doug=20
I replaced the windshield in my '68 E-Type roadster about 10 years
ago. I'd never done a windshield before, and found that, by taking my
time and by going _very_ slowly, I was able to do the job unassisted.
As I recollect it, the hardest part of the whole job was inserting
that *&$%# chrome finisher into the rubber moulding.
Vince
- -- =20
Vince Chrzanowski radiowsh@mindport.net=20
"There is not a moment to be lost" - Jack Aubrey
- -------------------------------------------------- =20
Date: Sat, 26 Oct 1996 10:21:13 -0500
Subject: RE: Electrical - has Gavin found the short yet?
Thanks David.
I tried to respond to everyone individually but if I missed anyone THANKS.
I am about to start pulling fuses now.
Gavin.
From: David J Shield[SMTP:David_J_Shield@ccm.fm.intel.com]
Sent: Saturday, October 26, 1996 1:45 AM
Gavin,
culprit.
Date: Sat, 26 Oct 1996 10:04:27 -0600
> -- Kirbert
I am interested in the going on all day about it if need be. Telling me I'm
wrong is simply not enough information. I want to know exactly what the
system does. Exactly why they are a benefit. And if they are such a
benefit why don't all Jaguar's sent to all countries have them fitted?
To me it is logic, if they are only on certain cars that Jaguar made, then
they are not necessary. If they are not necessary, then they are just one
more thing that can fail. I have enough other things on the car that can
fail, I'd rather take this system off while I have the opportunity.
I've got Kirby's comment, can anyone else give me sound logical advice here.
Phil Bates
58 MGA
67 MGB
75 Jaguar XJ12C
Date: Sat, 26 Oct 1996 12:39:38 -0400
> Frank Filangeri
> 62 E OTS
DITTO
I got all my Robey panels from John when I rebuilt my E-type body in 1989. Best
prices, good attitude and very helpful. He knows a lot about E-types.
Mark McChesney
'65 E-type ots
Date: Sat, 26 Oct 1996 12:43:58 -0400
Buy the tool for this, makes it way easier!
Date: Sat, 26 Oct 1996 12:45:25 -0400
Subject: Re: E Type All Synchro
Yep!
I have a 1963 magz. article from Car and Driver(or what ever it was called
then) that tells of an E-type racer in Florida that did this conversion, the
Moss case was used to get the T10 by tech inspection. Also in the article are
more tricks to make the early S1 E-types go faster and handle better - all from
a 'period' 1963 perspective. This racer also owned a P-51 Mustang. Can't
remember his name... I'll dig it out if anyone is interested.
Mark McChesney
'65 E-type ots
End of jag-lovers-digest V2 #466
Return-Path: @owner-jag-lovers-di1
Received: (from majordom@localhost) by ekeberg.sn.no (8.7.5/8.7.3/on4)
id <GAA05709> for jag-lovers-digest-out; Sun, 27 Oct 1996 06:39:00 +0100 (MET)
Date: Sun, 27 Oct 1996 06:39:00 +0100 (MET)
Message-Id: <199610270539.GAA05709@ekeberg.sn.no>
To: jag-lovers-digest@sn.no
Subject: jag-lovers-digest V2 #467
Reply-To: jag-lovers@sn.no
Errors-To: @owner-jag-lovers-di1
Precedence: bulk
X-Newsgroups: mail.jag-lovers-digest
jag-lovers-digest Sunday, 27 October 1996 Volume 02 : Number 467
83 XJ6 S3 Volt Meter - Buy Used or New
Final drive ratio
Oil Treatment and more
Re: Final drive ratio
Introduction to list
[none]
Parts For Sale
Re: V12 vs. AJ-V8 vs. Ford Romeo V8
Re: 83 XJ6 S3 Volt Meter - Buy Used or New
Re: Oil Treatment and more
SS100
Re: Parts For Sale
XJ-S No Start
Series III XJ6 Stalling
tracing an old friend
Date: Sat, 26 Oct 1996 11:59:04 -0500
Subject: 83 XJ6 S3 Volt Meter - Buy Used or New
The problem with my volt meter is that the needle has bowed to the point =
that the tip is hitting the face and resisting movement. If I tap the =
back of the meter, the needle will move to a correct position. It does =
return to zero but in stages. Should I replace with a new gauge or a =
used gauge? In other words, is this a common problem? Recommended prices =
and sources welcomed.
Also, I am having some trouble reinstalling the tach. It doesn't seem to =
want to turn clockwise (LHD). Maybe my fingers are just too tired? =
Anyway, is it only about a 3 degree turn or more like a 60 degree turn. =
I turned it about 60 degrees removing it but I wonder if I didn't go =
past the first set of notches. Thanks.
From: rrichardson@eurekanet.com (Robert J. Richardson)
Date: Sat, 26 Oct 1996 13:22:54 -0500
Subject: Final drive ratio
I need to estimate my mph using the rev counter until I replace the
speedometer's flex shaft. Do all left-hand-drive Series 1 E-Types have the
same final drive ratio? Somehow the ratio of 3.54:1 keeps popping up in my
head. If I know the final drive ratio I can then establish the rpm's for
city and highway limits and avoid those costly speeding tickets.
Date: Sat, 26 Oct 1996 13:26:48 -0500
>I'm typing this...
> Mark Budd
> 1970 E-Type OTS
I'm curious as to what constitutes a front rail. I can't seem to find this
terminology in my service manual. I have a '64 Series 1 E-Type so possibly
a front rail doesn't apply to my Jag.
Date: Sat, 26 Oct 1996 10:45:37 -0700 (MST)
Subject: Oil Treatment and more
First a response to Bert regarding his power antenna. Welsh (they have a web
site) offers a replacement electric antenna for around $120.
Big question: I recently watched a rather long TV commercial for Prolong
engine treatment. Among other "tests" they added Prolong to the engine oil,
then drained the oil, and ran the engine, without oil, at 4,000 rpm for 500
hours to demonstrate how well the Prolong treatment would protect an engine.
Next they cut the radiator hose to drain the coolant, and dumped buckets of
sand into the rocker arm assembly and continued to run the engine. Again the
engine seemed run without any problems.
According to the ad this product has been around for years and is the only
additive that really works. It seems to good to be true! Has anyone had any
experience with this product?
My interest/concern with this product is related to Brian's comment about
putting a V-12 into the new XK8. My '84 V-12 is well broken in at 170,000
miles. It still runs strong without excessive oil consumption. Prolong
sounds great, but I do not want to ruin a good thing.
A final comment concerning the XK8. Even if you could shoe horn a V-12 into
it, why bother? The styling is Japanese generic. Certainly not the
distinctive styling one would expect from Jaguar.
Former E-Type owner
Present XJ-S owner
Michael
Date: Sat, 26 Oct 1996 17:04:33 -0500
Subject: Re: Final drive ratio
>Most Series 1 E-types that were sold in the US are 3.54, however,
>3.07 and (I think) 3.77 or 4.11 were options. UK and Australian
>cars were more typically 3.07 for the higher top end.
>Generally only the race cars had the 3.77/4.11 ratios.
>The best bet is to go to a speedo shop where they can run the car
>on a machine to measure the actual speed at the wheels. I did this
>when I put a diff out of an automatic into my 5 speed Fiat then
>the speedo shop made a corrector gear for the speedo cable for
>me.
>Ken
>'62 flatfloor E-type Roadster
Thanks. I'm almost certain I too have the 3.54:1 final drive. Until I can
replace the flex cable, I'm going to do a graphic of the Jag speedometer
face (exact size) and, based on my final drive ratio, show rpm's opposite
significant speeds such as 25mph, 35mph, 55mph, 65mph and an even 100mph.
I'll tape this over the speedometer face and at a glance I can tell my
speed based on rpm's.
Date: Sat, 26 Oct 1996 11:39:41 -1000 (HST)
Subject: Introduction to list
I've had my '55 XK-140 FHC for one year and have so many questions about
how to improve it, I could have my own mailing list. I have solved each
problem as it has presented itself taking only slight liberties on the
orginality issue. Lately, I've gotten a variety of opinions on the correct
type of needle for the HD6 carbs.The engine is not a C-type.The LB1's it
had when I got it seem to be a mystery to everyone.It ran fine until it
seemed to all of a sudden quit every time I went uphill. After replacing
all the ignition components, including the installation of an electronic
ignition system, and changing the needles to WO2's, it runs great again but
the milage fell off to only 11mpg. Before, it was getting in the high
teens. Anyone have an idea what milage I should be getting and what kind of
needle it should really have? The radiator was leaking very bad and making
a mess of the engine compartment, not to mention the high operating
temperatures. I replaced it with a modern core that has made an incredible
difference in the normal running temp; at least 10 to 15 degrees cooler on
the guage. It hasn't done a thing for the mileage though.
Hope I hear from lots of other owners on my questions and any you might
have. I've managed to assemble a pretty good library. Aloha from Hawaii,
Rob Caveney
Date: Sat, 26 Oct 1996 17:43:43 -0500
Subject: [none]
According to my information, Chevy's new small-block LS1 (the LT1's =
replacement), is a Y-block aluminum with iron sleeves. It is also still =
a push-rod with only two valves per cylinder but produces both =
horsepower and torque at about 350. Compared to the AJ-V8, it is only =
slightly heavier. For 20 pounds you get about 60 horses? Is this the new =
Chevy lump to use when the more complicated and expensive AJ-V8 with =
Nikasil-plated cylinders goes?=20
I'm no expert on these things. My sources are Jaguar World 8(6) and Hot =
Rod 49(9) and it is possible that I misunderstood something. I certainly =
hope so.
Date: Sat, 26 Oct 1996 18:41:30 -0700
Subject: Parts For Sale
I am new to the list and would like to sell the following parts:
XKE 1970: Boot cover from Welsh Jag. New top of line #19-14195 $200,
Filter, New Crosland C2 GFE 101 F Marked Item 11-14801 offer,wheel
bearings new BK92 60% of new, Seat rake ajuster new for Series III
BD37768/9 $100, Clock,Smith 10-0012 used but works, $75. Chrome Ibrow
used BD35668,used $25
XJ6 1984 Brake pads new 06-2244 $12 a set, 2 new thin size of rotor
brake parts? 60% of new, rear universal joints new (4) $20.ea. 2 rotors,
used but good $25 ea. shipping extra
512 346-8855
Gene356@ix.netcom.com Austin, Tx.
Date: Sat, 26 Oct 1996 20:03:46 -0400
Subject: Re: V12 vs. AJ-V8 vs. Ford Romeo V8
Greetings All -
Regarding the installation of the V12 in an XK8, it won't fit
because the motor is too tall (bonnet too low), and the
motor is too long to fit in the short XK8 engine bay.
(Maybe this opens up an industry for "long nose" XK8s,
like the long-nose D-types of old..................!)
Also on the subject of choosing the Ford Modular V8, the Romeo
V8 is a package-inefficient engine (poor power-to-size ratio).
If anyone has taken a look at the cylinder heads of this
engine, you will be astounded at their size -- mainly in
the width dimension. This is only on the two valve per
cylinder variant. When you go to four valves per cylinder
and dual overhead cams, the cylinder head width grows again.
This is due to the roller-finger-follower (RFF) cam drive
system, where the cam follower is a roller, which
actuates the valve via a rocker arm.
The proper cylinder head for a high performance, compact
luxury engine is a direct acting mechanical bucket
(DAMB) system, which the XK8 uses. The XK inline 6 that
we are all familiar with uses DAMB. This is where the
cam rides on a tappet (bucket) which sits directly in
mechanical contact with the valve stem. Very much
more compact.
The DAMB cam drive, plus Nikasil bores are two very
effective size- and weight- reducing design features.
Also with DAMB, the valve actuation system is lighter,
but there is an increase in system friction due to the
sliding DAMB cam-to-cam follower interface vs.
the rolling RFF interface.
DAMB could be adapted to the Romeo V8. I do not
know why the decision was made not to do this. Also
keep in mind there is a very strong need for product
differentiation, which we all agree is top priority
to avoid dilution of the Jaguar lineage.
B.J. Kroppe - '82 XJ6
Date: Sat, 26 Oct 1996 20:02:23 -0400 (EDT)
Phil: One thing the system does is keep gas vapors out of the car(when
it works right). Check at each filler, or if an S car check the rubber
lines connected to the fill tube. These lines go bad and allow vapors to
seep into the car, then you blame the charcoal cannister, when that is
not the real problem. I know that it would be alot easier to just remove
the system, but when you did you would still have gas vapor at the rear
of the car and what would you do with it then?? Remember that the tank
has to vent somewhere or your fuel pump would create such a vacuum that
the tank would collapse, ( I have seen this happen).
Chad Bolles Jaguar South 306 Valcour Rd Columbia SC 29212 USA 803 798 3044
Date: Sat, 26 Oct 1996 20:07:40 -0400 (EDT)
Subject: Re: 83 XJ6 S3 Volt Meter - Buy Used or New
Kyle: You went tooooo far, you only have to move the tach about a 1/4
turn, just look in the dash you will see the tits(for lack of a better word)
that the tach will catch on. Look at the tach, you will see the notches
in the case, just line them up. As to removing the tach, I find that if
you remove the panel in the middle, the one with all the red lites in it,
then I can get to things better.
Date: Sat, 26 Oct 1996 20:16:24 -0400 (EDT)
Subject: Re: Oil Treatment and more
Michael: Go ahead and use the oil treatment. I build and sell engines
and need many more customers. I find that if I change the oil in my
engines every 3000 miles, I get lots of miles from them.
Please keep in mind that most of the ads like you see are SNAKE OIL. Now
I know that someone will come back at me for this, but if I used that
stuff in my engine,the way I run mineI would be building a new engine.
I tell you what lets get those people to let me test their product on TV,
lets see how long my engine would last at say 5-8000 rpm. You notice
they never show a hi performance engine being use at its max.
Date: Sat, 26 Oct 1996 20:18:49 -0400 (EDT)
Robert: Why not just jack up the car read the tag attached(if still
there) to the diff, that tell you the ratio.
Date: Sat, 26 Oct 1996 19:00:52 -0600
I agree with you that a vacuum release is important, my '67 MGB has a
non-vented tank, and I have had to release the vacuum after drives in excess
of 1/2 hour or so. This, however, does not answer the basic question. If
this system is essential, why is it that cars to the UK, France, Italy, and
other countries don't need it?? It would be real simple to remove the
system, and add one check valve on the upper vent pipe, this should relieve
vacuum, and not let fumes out. This is a lot less equipment, and piping
that has the possibility of failing.
Phil Bates
58 MGA
67 MGB
75 Jaguar XJ12C
Date: 26 Oct 96 22:08:53 EDT
Subject: SS100
There is a real SS100 for sale in Sydney, Aus circa AUD 180,000, known history,
and a pretty good replica built from SS and other parts at circa $100k.
Regards, John Elmgreen
Date: Sat, 26 Oct 1996 21:26:01 -0700
Subject: Re: Parts For Sale
> 512 346-8855
Date: Sat, 26 Oct 1996 21:35:57 -0700
Phil:
HELP, how do you send email to the members of this club. I have tried
and tried but they all come back??? Where do you live? I have a 60 MGA
that needs restoring for $2,500
> Phil Bates
> 58 MGA
> 67 MGB
> 75 Jaguar XJ12C
Date: Sat, 26 Oct 1996 22:52:19 -0400 (EDT)
Subject: XJ-S No Start
I recently made the aquaintance of a fellow XJ-S owner. His car is an '85
HE that he just repainted (did a pretty nice job of it, too).
Since completing the repaint, the car won't start!! He and others have
spent some time trying to get it to go; he and I have had a go of it as
well. I would like to present a summary of the car's known
idiosyncracies, what has been looked at, and what has not been done in
order to elicit suggestions on what to do next from you all:
Symptoms:
The car cranks but won't fire. Initial attempts at starting produce a few
kicks as if the motor wants to start but it doesn't
The car was running fine. Then it got repainted. It started once, ran,
had trouble restarting, then died completely.
Known/Historical Problems:
1. The fuel pump relay is normally grounded thru pin 15 of the ECU. For
some reason, no ground was available and so the fuel pump would not run.
The owner fixed this by adding a ground wire to the fuel pump relay and
the 'interface unit' for the trip computer. This let the pump run. This
fix was made some time ago and the car ran OK.
2. When the ignition is switched on, the fuel pump does not shut off in
two seconds as pressure builds. It keeps running and running.
Opinions Thus Far:
I suspect a flooding problem. THere is a strong smell of gas when
attempting to start the car. Plus, the motor just behaves like its
flooded. Owner suspects an electrical problem.
Diagnostics To Date:
Air cleaners not plugged. Good gas in tank. Fuel pump builds pressure.
Good flow from fuel pump. Injectors are pulsing. Spark is good. All
electrical connections and grounds have been checked and are good.
Battery properly charged (cranking speed adequate, etc.). Main coolant
sensor recently replaced (car ran with the one now in the car -- and car
still would not start with the connector to the temp sensor shunted). FI
ballast resistors ok. ECU ok (swapped in the one from my car). All
vacuum hoses intact. Reportedly no changes to ignition timing ever made.
When engine cranks it 'sounds' normal in terms of compression so no
expectation of incorrect cam timing (can this happen to this motor,
anyway?). ECU is grounded. All chassis grounds are good. It makes no
difference in starting the car if the throttle rods are disconnected and
either the butterflys opened or the throttle pot opened while attempting
to start the car. Neutral safety switch/inhibit relay working properly.
One spark plug pulled and slightly sooty but not enough to keep car from
starting (famous last words??). Very slight smell of gas when sniffing
dipstick. No sign of water in gas.
What Has Not Been Checked:
All plugs not pulled. Timing. O2 sensors (shouldn't matter to get car
started?). Compression (but sounds OK). Valve timing. Reason for fuel
pump not shutting down when key switched on but no crank. Fuel filter
(but plenty of flow from pump). Investigation if the previous 'lost
ground' from pin 15 of the ECU has any other implications, including the
possibility that some other critical circuit also has lost ground (what
would this circuit be?).
Summary/Conclusion:
Owner not thrilled about thought of yanking the plugs and expects to find
an electrical problem in the trunk based on his previous experiences.
Does this car suffer from an accumulation of three problems:
Why did an auxiliary ground need to be added to get the fuel pump to run?
Why won't the pump shut off (is gas dribbling thru the injectors)?
Is the poor thing hopelessly flooded and plugs need to come out?
What do you folks think? What would you do next?
Thank you very much for your help. The poor fellow wants to get out and
show off his amazing paint job!
John
Date: Sat, 26 Oct 1996 23:28:25 -0400 (EDT)
Subject: Series III XJ6 Stalling
More on our 86, 4.2L XJ6, and its stalling problem. In prior
messages i reported that the car wouldn't idle once the system
slowed the RPM down below the intial 1,000. It would always
restart, but would not remain running on its own. Today I
replaced the fule filter and the temp sensor. And, I toped up the
antifreeze. It started great and ran fine until the temp gauge
moved up off cold, and the RPM began to drop. Once it got to 500
RPM it gradually stumbled and died. Same thing after several
restarts.
So I said the heck wioth it and took it out on the road. Ran
great -- got an expressway and went all the way to 80 without a
whimper. Coming home, though, as I stopped a light, the same
thing -- stumble, stumble die. Immediate restart and all is ok
so long as I keep my foot on the gas and maintain 1000 RPM
I guess I can raise the idle speed (cant find the allen wrench
hole yet -- and which way do you trun to raise the speed?) But
why should that be neccesary now? Is there something more
important going on? Book suggests looking at the throttle
linkage? Any ideas as to what i should be looking for?
Any advice will be helpful.
Bob Sack
86 XJ6
50 XK 150 DHC
Robert J. Sack
phone 804 924 4814
fax 804 924 4859
Date: Sun, 27 Oct 1996 04:39:06 +0000 (GMT)
Subject: tracing an old friend
just on the offchance that someone on this list now owns an old friend of mine.
i once many years ago lived in boston and owned a xk-140 coupe-white. this car
took me many miles including a trip from boston to acapulco and back-including
a new camshaft and an engine rebuild in kingsville texas. because of all these
misadventures and lack of cash i had to trade it in for a mustang [i must have
been insane].i am curious if this car has survived and found a good home.robin
Date: Sun, 27 Oct 1996 01:38:29 -0500
>Hi Robert,
>You mean you're an E-Type owner and you don't
>know what a front rail is???
>hahahahahahah
>I've been lurking here for about a week now, waiting
>for someone to tell someone!!!!
>(haven't a clue!)
>Charles Daly, Toronto, Canada
>'62 E-Type, ots
On page N.8.7 of the Jaguar Serivice Manualthe unit is called the Front Frame Assembly. The individual parts are called side members, cross members, etc. and not one mention of the word "rail." So there. End of jag-lovers-digest V2 #467 ******************************** Return-Path: @owner-jag-lovers-di1 Received: (from majordom@localhost) by ekeberg.sn.no (8.7.5/8.7.3/on4) id <TAA05130> for jag-lovers-digest-out; Sun, 27 Oct 1996 19:44:55 +0100 (MET) Date: Sun, 27 Oct 1996 19:44:55 +0100 (MET) Message-Id: <199610271844.TAA05130@ekeberg.sn.no> From: @owner-jag-lovers-di1 To: jag-lovers-digest@sn.no Subject: jag-lovers-digest V2 #468 Reply-To: jag-lovers@sn.no Errors-To: @owner-jag-lovers-di1 Precedence: bulk X-Newsgroups: mail.jag-lovers-digest jag-lovers-digest Sunday, 27 October 1996 Volume 02 : Number 468 Re: Final drive ratio Re: Vacuum Advance re: Message for David Shield For LLoyd - cam clearances (was: E-Type Strangeness) re: Series III XJ6 Stalling Re: Buying a Jag.. Re: Parts For Sale RE: Attitudes Re: XK8 impact upon XJ-S market? Re: XK8 vs. V12, Nicosil RE:Re: XK8 vs. V12, Nicosil Re: removal of vent pipes, carbon canister etc. SU carbs Re: tracing an old friend winter storage Re: removal of vent pipes, carbon canister etc. Re: Vaccuum advance problem XJ6 stumbling and dying. Re: Screeching Sound From: Michael Frank <mfrank@westnet.com> Date: Sun, 27 Oct 1996 02:21:47 -0500 (EST) Subject: Re: Final drive ratio Robert: There should be an aluminum tag on the diff that will identify the ratio. the 3.54 will be tagged 46/13. Mike Frank 1969 E-Type 2+2 At 05:04 PM 10/26/96 -0500, you wrote:
Date: Sun, 27 Oct 1996 02:21:52 -0500 (EST)
Subject: Re: Vacuum Advance
OK. I've done my homework. Let's see if we can document this thing in a
way that everyone will be happy with.
1. Vacuum advance. Ignoring emission control factors, this quote from Robert
Bentley's Automotive Reference Center reflects my understanding of what it
is and how it works:
"Mechanism that automatically varies the instant at which the spark occurs
as a function of intake manifold vacuum. Vacuum advance provides the
additional advance needed when the engine is operating at part throttle,
when less air-fuel mixture gets into the cylinders and takes longer to burn
after it is ignited. Without additional ignition advance, the piston would
be past top dead center and moving down before the mixture had a chance to
burn and produce full power."
"The typical vacuum advance mechanism consists of a flexible, spring-loaded
diaphragm connected by a linkage to the breaker plate on which the points
are mounted. The diaphragm's sealed side is connected by a tube to the
carburetor. The throttle valve is below the vacuum passage in the carburetor
air horn, so there is no vacuum advance when the engine is idling because
the throttle is closed. However, when the throttle is partly open, intake
manifold vacuum pulls the diaphragm in, causing the breaker plate to rotate
a few degrees and advance the timing. At wide-open throttle there is very
little vacuum in the intake manifold, so there will be little or no vacuum
advance."
By empirical experiment, I know that all of the old cars I work on operate
just this way: including my 4.2 Jaguar E-Type. Kirby indicates that a Volvo
with which he is acquainted works differently:
"I'd invite you to inspect my parents' 1969 Volvo, which was constantly
being misadjusted by the idiots at the Volvo dealer when they'd take it in
for scheduled maintenance. Had full advance at idle, you HAD to disconnect
and plug the vacuum line when setting the timing, they never did, it always
came back retarded by about 15 degrees. By the way, it had dual SU carbs, too."
As a SAAB owner, I would never characterize Swedish engineering as
conventional. I guess the Volvo folks think outside the box, even when
designing a box on wheels! Kidding aside, It seems irrelevant whether the
mechanism is a vacuum operated advance or a vacuum operated retard. The goal
is the same: a little extra advance when the throttle is partly open.
2. Static advance. 70's vintage cars tend to use a leaner and later approach
to polution control. This was typically accomplished by the throttle plate
being opened and the ignition static timing retarded. The open throttle
plate did, indeed, allow better metering, and thereby allowed a leaner
mixture. Retarding the timing brought down idle speed to an acceptable
level. But more importantly, it increased cylinder and exhaust system
temperatures, allowing more complete combustion of HC and reduced CO.
Increased temperature does not imply impoved thermal efficiency, which in
fact drops. This all has little or nothing to do with vacuum advance (at
least in principle), and has changed radically with the introduction of
advanced electronics and catalytic converters.
3. Other emission control strategies. Over the years, various manufacturers
(Ford is still the one that comes to mind) have used vacuum controls to
advance/retard timing under specific conditions. The overall idea has
remained the same, however, with timing normally vacuum advanced during part
throttle conditions. Happily, the 4.2 E-Type was retired before this
nonsense got underway...so no relevance to the original question.
Allow me to restate my original description: In the 4.2 E-Type, there will
be no vacuum advance at idle. As the throttle opens, vacuum at the advance
port will increase, drawing in the diaphragm, and advancing the timing. As
the throttle continues to open, vacuum falls, and at full throttle there is
no advance. I still believe that this is typical of most cars built prior to
the 70's.
If this satisfies everyone, let's put this one to bed.
Mike Frank
1969 E-Type 2+2
Date: Sun, 27 Oct 96 00:26:00 PDT
Subject: re: Message for David Shield
Bill Kroeger,
I'm on vacation and am not checking my e-mail regularly. I've been
catching up on 1.5 weeks of jag-lovers digests and found your
'Message to David Shield' just now. This was about the headlamp
conversion, right? (sorry, but I'm so deeply into vacation mode
I'm forgetting things....)
If it's about the XJ6 headlamps, have your uncle in the UK get the
headlamp rims from any Jaguar spares dealer. Buy it from whoever's
got it.
The Jaguar part number for the chrome finshers is posted in my
'Parts Interchange Guide' (due for an update tomorrow) on my web
page (soon to be included in Nick's 'Outbound Links' listing):
This finisher fits the SIII and SII XJ6, and probably the SI. I
did the SIII car and my friend did the SII. I don't have part #s
for the headlamp buckets, but those are standard British Leyland
parts which should be obtainable from any British parts dealer in
the US. Several other jag-lovers have done this conversion - has
anyone identified the BL bucket part #s?
We paid $200 for two entire kits including shipping.
Best regards,
David Shield
>Sorry about this but I could not get E-mail through to david with
>Address he left me.
>Thanks for the info, I will take any numbers you have for vendors
>in the UK as well as the part numbers for the parts. My uncle
>happens to live in england and maybe he can help me find these
>parts. One more thing, do you happen to remember the prices that
>you paid for these parts. Thanks Again Bill Kroeger
Date: Sun, 27 Oct 96 00:36:00 PDT
Subject: For LLoyd - cam clearances (was: E-Type Strangeness)
LLoyd,
My '70 E-type 2+2 was manufactured in Feb. '70. The ID plate says
.012 and .014 on it. (9:1 head.)
--from LLoyd--
> I'm replacing my ID plate which sets under the heater box on my
>'71 "E". The last two items on it are adjustments for intake and
>exhaust valves. I've looked at a couple of '70 model cars and they
>say 004 and 006 in the boxes.
> But, on my head it is marked that both intake and exhaust valves
>should be adjusted to 012-014 inches. What should I stamp on the
>plate?
> LLoyd
Date: Sun, 27 Oct 96 00:59:00 PDT
Subject: re: Series III XJ6 Stalling
Bob,
Make sure the throttle switch is working correctly. It should
click just before the butterfly is closed at idle. If not, it may
be mis-adjusted, loose, or disconnected, tricking the ECU into
thinking that you're never at idle position. Thus the idle speed
control circuit would never wake up and do its job.
'84XJ6
'70XKE 2+2
Bob Sack writes:
>snip<
>restarts.
Date: Sun, 27 Oct 1996 04:23:34 EST
Jan-Aage,
You asked for details on the top of the range jags and wanted to know the
difference between the models, obviously it depends on which model you're
talking about but in general the following holds from the Series 1 (1968
I think) to the current range.
XJ6 is the base level saloon, for the Series 1,2 and 3, it will have a 6
cylinder motor of 3.4l or 4.2l(XK6) for the XJ40 I think the options were
2.8, 3.4 and 4.0l (correct me here anyone) the current X220 series also
uses the AJ6 motor common to the XJ40.
The Sovereign model is a fully optioned XJ6, on my series 3 that means
A/Con, trip computer,leather seats (not velour), sunroof, rear seat head
rests and probably a heap of things I haven't thought - pretty much every
thing available as an option. Here in Australia most Series 3's I seeare
Sovereigns.
The model above the Sovereign is the Vanden Plaas. The VDPhad everything
the Sovereign had plus a couple of extras, the rear seats were twin
buckets with an arm rest rather than a bench seat. The headlights had
wipers (?!!?) I never could figure that one. I believe the front seats
were slightly different on the XJ40 but I dont think they were different
on the Series 3 VDP. Theabove is correct for S3 and XJ40, don't know
about S1 and 2. There may well have been other diff's I haven't listed.
Daimler: The top of the range, I've often read that only the VDP was
exported and not the Daimler, yet I've seen a few Daimlers here in Aust.
perhaps they didn't make any LHD Daimlers so none were sent to the US,
but were sent to Aust as we share RHD with the UK,NZ and Jap.(?). Don't
know for sure..... but I'd be interested if anyone cares to fill me in...
This model has a distinctive "serrated" (is there a better word ?) tail
piece and front grille edge. I believe they all have the central chrome
stripe up the centre of the bonnet. I believe quite rare from my memory
of the production figures someone posted a month or 2 ago.
I hope that helps you distinguish between the main saloon models. I also
hope that you are looking at saloons otherwise I've wasted a huge amount
of bandwidth.......
If I've made any errors (highly likely when making sweeping statements
across 5 model sets and 30 years) please correct me anyone.
Contact me offline if you want further info - can't guarantee I'll know
the answer though !!! :-)
Good Luck finding your new car.
John
Level 1, 29-57 Christie St.
St Leonards NSW 2065
Ph: +61-2-9937-8063 Fax: +61-2-9937-8100
Mobile +61-419-617-619
Date: Sun, 27 Oct 1996 07:41:46 -0800
> > 512 346-8855
Date: Sun, 27 Oct 1996 06:08:52 -0800 (PST)
Subject: RE: Attitudes
At 11:00 AM 10/24/96, Barrie Dawson wrote:
> <snip> I prefer to cruise
>in the 45 - 65 MPH band...
I also like to cruise in the 45 - 65 MPH band. Unfortunately, my driveway
is a bit too short to do any more than that and the gravel makes me a bit
nervous too, as does the hairpin turn at the end that one has to negotiate
in order to pull the car in to the garage... ;-)
-Steve A.
'67 E Type Coupe
'76 XJ6C
'91 XJ40
Date: Sun, 27 Oct 1996 06:10:07 -0800 (PST)
Subject: Re: XK8 impact upon XJ-S market?
At 3:11 PM 10/23/96, Jonathon Shevelew wrote:
>While the XK8 is certainly a well engineered car with great bells and
>whistles, I find that there is a certain purity in the XJ-S. Nobody
>has ever mistaken my XJ-S for a Riviera, Aurora, or for that matter
>anything other than it actually is.
Purity? If it's a coupe, it looks like a 1975 Chevrolet Camaro with the
rear window bashed in. If it's a pre-HE, even the instrument panel looks
like the Camaro. Even the car magazines couldn't avoid THAT comparison
when the XJ-S first came out. It just outlasted two style changes of the
Camaro during its production. Gee, maybe that's why Jaguar eventually
started using a GM tranny in the car - to make it MORE like a Camaro! Nice
headlights though...
The XK8 will do the same thing to the used XJS market that the XJ-6 did to
the used Mk X market and the same thing that the E Type did to the XK
market. It'll make the XJS "affordable." Maybe the V12 versions will
eventually do well, but even V12 Lincolns eventually did OK after a LONG
drop. In the meantime, you're stuck with a big, heavy, complicated,
thirsty car that can't carry anything and that's missing a gear or two.
-Steve A.
'67 E Type Coupe (Jaguar's best looking production car ever - including the OTS)
'76 XJ6C (a beauty that behaves like a beast - ign switch just died!)
'91 XJ40 (at least it isn't any uglier than an XJS)
Date: 27 Oct 96 09:28:32 EST
Subject: Re: XK8 vs. V12, Nicosil
After the XK8 public launch here in the UK, several of the daily newspapers
carried a few column inches regarding Jag and future plans. Some talked of
supercharged XK8's, others talked about Aston Martin trying out a tuned V12 6
litre in the DB7, and some mentioned a V12 variant of the XK8 (should that be
XK12?).
Probably complete rubbish but who knows.
Regards
Date: Sun, 27 Oct 1996 09:42:53 -0500
Subject: RE:Re: XK8 vs. V12, Nicosil
In a message dated 27/10/96 14:37:18, you write:
6
be
>XK12?).
1. There are Supercharged XK8's already being tested around the plant. Will
be available sometime late '97.
2. The DB7 uses a modified XK8 shell so a V12 won't fit.
3. There's no way that after spening #M's on developing a new engine that
they would put an old lump back in, even if it fitted.
Tez
Date: Sun, 27 Oct 1996 09:44:10 -0500 (EST)
Phil: Where would the gas vapors go??? Into the air that we breathe???
When the engine is running the vapors are sucked into the intake and
burned, but when the engine of off where would they go then, now that you
have remove all the system.
I would just about bet that all the newer cars made in Europe have a
system like this, as those countries have come to realize how important
clean air is.
Date: Sun, 27 Oct 1996 10:49:42 -0800
Subject: SU carbs
Rob Caveney.
If you have HD6 you don't have the original carbs.
The original carbs are H6. Check the diaphragm, it
may be leaking. I chased a similar problem on a
3 ltr. Rover at one time. Check your carb floats.
I have seen them with gas inside which screws up the
gas level in the float chamber. Check the float needles
for wear. Your pump pressure should be 2-3 lbs. Too high
and it will force gas past the needles. Also check your
start carb. My XK140 averages around 20 MPG (Imperial gal.)
Bill
Ontario, Canada
Date: Sun, 27 Oct 96 10:43:17 EST
Subject: Re: tracing an old friend
I have seen a white 140 parked on Memorial Drive near the MIT
med-grad-residence near Kendall Square a few times in the last
couple of years. Kind of like "Oh, I know someone from Canada..."
but... the other thing is I can make an enquiry of the local
Jaguar Owners Clubs - I'm a member of the Empire club, and the
Boston chapter is quite cooperative. Send me the particulars if
you have them - vin, reg, who you sold it to, and I can ask.
John R. Lupien
lupienj@wal.hp.com
Date: Sun, 27 Oct 1996 12:30:46 -0500
Subject: winter storage
I'm paying a big price in both dollars and time for neglecting my E-Type
winter after winter. I'm convinced that just letting it set there in an
unheated garage led to the failure of one of my master cylinders. From the
jaglovers list I plan to do the following: 1) replace the brake fluid and
bleed the brakes 2) install a device to keep the clutch pedal depressed to
prevent the clutch plate from rusting and sieizing against the flywheel 3)
topping the fuel tank to prevent condensation within the tank thus leading
to water in the fuel 4) changing the oil and filter 5) lubing all grease
fittings front and rear.
For several years I never even tried to start my Jag all winter long. This
cost me at least one battery plus I couldn't engage either first gear or
reverse. If the latter occurs to you, put the car in reverse, keep the
clutch pedal depressed and then start the engine (have some quick start on
hand). You should then be able to release the clutch and break the apparent
rust bonding of the clutch plate and flywheel. Like I said, if I had just
started the car up every few weeks and gone around the block a time or two,
I probably would have avoided several expensive fixes when spring rolled
around.
Date: Sun, 27 Oct 1996 13:41:54 -0005
Phil Bates:
Y'know, you're right -- this might actually be a good topic for this
group to discuss in detail.
The system vents the fuel tank, preventing pollutants and odors from
escaping to the atmosphere (and into your car) and preventing
excessive pressures or vacuums within the tank. Obviously, it must
allow air to enter the tank as the tank is emptied by the consumption
of fuel by the engine. It also must allow air in and out due to
temperature changes.
The system vents THROUGH the carbon canister. The activated charcoal
absorbs any hydrocarbons in the escaping air, preventing them from
polluting or reaching your nose.
When the car is running, fresh air is drawn THROUGH the carbon
canister and into the engine in order to purge all the hydrocarbons
back out of the charcoal.
Because the system costs MONEY. Why pay for it if you don't have to?
On the other hand, since YOU have already paid for it, why not leave
it in place?
Will the car run without it? Certainly. But the car will also run
without a lot of other things -- is it your policy to remove ANYTHING
and EVERYTHING that isn't necessary for the car to run?
I should point out that it is absolutely necessary for the tank to be
vented. If this system is yanked, some other vent must be provided,
even if it's merely drilling a hole in the gas cap. Which will
result in more odors? Which will cause more danger of fire?
Ordinarily, I would disagree strongly -- the carbon canister fuel
tank ventilation system has no moving parts and NEVER fails; if
you're not concerned with pollution, you can simply leave the
original carbon canister in there forever and the car will run fine.
Ordinarily. Jaguar, on the other hand, does have the propensity to
make even the most simple and mundane system subject to failure. The
carbon canister is vented into the bodywork rather than out under the
car. The vapor separator develops pinholes from tinworms. The hoses
themselves are made of British materials, and may decide to leak at
any time. And, most ridiculous of all, Jaguar apparently made some
design errors with the XJ-S that resulted in a recall to prevent fuel
tank failures from excessive pressure cycles.
All of these problems, however, are easier to deal with than removing
the system -- and will have better results. The concept that "I
don't know what it is, it must be a smog device, I should just yank
it out" is NOT a good idea for ANY system -- you should always
understand what a system does before you attempt to modify or
eliminate it.
| some rules must be broken.
| - Palm's Postulate
Subject: Re: Vaccuum advance problem
Randy K. Wilson:
> is a long one.
I need to take this opportunity to clarify: at no time did I ever
even mention the vacuum retard systems. All I talked about was the
ported vacuum that merely kills the vacuum advance at idle.
| - Palm's Postulate
Date: Fri, 18 Oct 1996 11:43:37 -0500
Subject: XJ6 stumbling and dying.
I dont know if you have other problems, but the idle speed IS too low. It
should be AT LEAST 600 to 650.
Jim
"Better an outlaw than not free."
Nance O'Neil
Date: Sun, 27 Oct 1996 13:09:05, -0500
Subject: Re: Screeching Sound
- -- [ From: David V. Kerner * EMC.Ver #2.5.1 ] --
- -------- REPLY, Original message follows --------
> Date: Friday, 25-Oct-96 04:01 PM
> From: Lee Walden \ Internet: (lwalden@ebmud.com)
> To: Mr David V Kerner \ Internet: (bizmodel@prodigy.com)
> To: Jaguar list \ Internet: (jag-lovers@sn.no)
> To: WWRJ84A@prodigy.com (Unlisted Name) \ Internet:
(wwrj84a@prodigy.com)
"only
engine
I was referring to the initial contact of starter pinion to ring gear.
That contact is made in one of three places. Once the contact is made
the starter motor turns the engine over.
End of jag-lovers-digest V2 #468
id <FAA22971> for jag-lovers-digest-out; Mon, 28 Oct 1996 05:22:46 +0100 (MET)
Date: Mon, 28 Oct 1996 05:22:46 +0100 (MET)
Message-Id: <199610280422.FAA22971@ekeberg.sn.no>
Subject: jag-lovers-digest V2 #469
Precedence: bulk
jag-lovers-digest Monday, 28 October 1996 Volume 02 : Number 469
Oil treatment
Re: Oil Treatment and more (No Jag Specific Content)
SU carbs
Chevy Lumps in XK8's
RE: Attitude & E-type Frames - (Long?)
engine click
Seat Heaters XJ40 1987
XJ40 Mystery strap
Re: Heater Control Valve
Re: V-12 vs. AJ-V8
420G/XJ6 updates, want DS420 limo
XKE windshield - failed
Re: '85 XJ-S no start
62 E, oil pressure problem (long)
Am I crazy?
Faulty Wiper
Date: Sun, 27 Oct 1996 13:16:08 -0700 (MST)
Subject: Oil treatment
Chad, thanks for your imput. I have driven high performance cars for over 20
years and never considered running any of that SNAKE OIL in them, for
exactly the reason you stated. Prolong's TV infomercial has me taking a
second look.
Part of this same infomercial did show a hi performance engine in that Al
Unser drove a Viper for several hours, with no oil in the engine, It was
somewhere with track tempertures up to 150 degrees. Al indicated his top
speed on this test was around 90 mph. I wonder if Al is an invester with
Prolong?
As part of this promotion Prolong has issued a $1 million challege to any
other oil additive company to match their test results.
Seems to me that if their product is as good as they claim, they may
consider extending that challenge to profession engine rebuilders such as
you. With your permission I would like to forward your answer to my post to
Prolong. Let's see if they have any stones.
Former E-Type owner
Current XJ-S owner
Michael
From: Kyle Chatman <kchatman@mail.coin.missouri.edu>
Date: Sun, 27 Oct 1996 14:17:32 -0600
Subject: Re: Oil Treatment and more (No Jag Specific Content)
I too have been wondering about these demonstrations. Then, I happened=20
to see part of a demolition derby on ESPN. The announcers were =
explaining
modifications made to these junker cars for the derbies and said that =
one
of the modifications was to alter the timing so that the cars could run =
30
minutes or more without oil. I think that the bottom line probably is =
that an
engine will run a surprising long time without oil and that any =
synthetic oil or treatment (even heavier weight oil) will extend the =
period before failure. Anyone volunteer to drain their Jaguar and drive =
till it drops?
Date: Sun, 27 Oct 1996 16:47:05 -0800
Subject: SU carbs
Rob Caveney.
I am trying to send this again as the first time it was returned.
Bill
Ontario, Canada
Date: Sun, 27 Oct 1996 14:41:52 -0800
Thanks for that piece of info. You may have just saved me a few thousand
dollars. I'll keep the XJ6 for another year and wait for the supercharged
version of the XK8.
Date: Sun, 27 Oct 1996 14:44:40 -0800
I think the XK8 would look better with a longer nose. It would certainly
look a little more like an E-type with one.
Date: Sun, 27 Oct 1996 18:09:31 -0005
Subject: Chevy Lumps in XK8's
> LT1's replacement), is a Y-block aluminum with iron sleeves. It is
> also still a push-rod with only two valves per cylinder but
> produces both horsepower and torque at about 350. Compared to the
> AJ-V8, it is only slightly heavier. For 20 pounds you get about 60
> horses? Is this the new Chevy lump to use when the more complicated
> and expensive AJ-V8 with Nikasil-plated cylinders goes? I'm no
You have. Keep in mind that NEITHER of these engines is anywhere
near its HP capacity in street tune; the only reason that the Chevy
can claim its HP figures is because they choose to tune the engine
higher. Of course, why Jaguar didn't decide to tune the AJ-V8 higher
would be a good question; as I mentioned before, if _I_ had been in
charge, the V-12 would have been a 7+ litre 450+ HP powerplant by the
mid-80's at the latest, why Jaguar chooses to keep excellent
powerplants in such lame configurations I cannot explain.
But when it comes to determining which engine is REALLY superior,
one excellent indicator is who is doing well in the GT class at the
endurance events -- LeMans, Daytona 24-hour, Sebring 12-hour. For
example, the Viper in stock form appears to be a real beast, but the
comparitively docile Aurora kicked its ass repeatedly. This is
because the Aurora engine is truly excellent, while the Viper is
just an overgrown Chrysler lump.
I'd be hopeful for the XK8 in 1997 events, except that the
competition is keen these days. Also, I have no idea what kind of
XK8 effort will be mounted. Knowing how utterly disconnected Jaguar
is from their market these days (see their lame video, etc.) it's
entirely possible they have decided not to bother fielding a factory
team.
| - Palm's Postulate
Date: Sun, 27 Oct 1996 17:27:47 -0500
Subject: RE: Attitude & E-type Frames - (Long?)
Just thought I'd say, I myself was wondering what type of E-type owner =
you could be, if you couldn't figure out what my version of a front =
frame rail explanation was. I mean, I would of thought it was a natural. =
When I read Charles reply, I laughed too, (as I usually do for Charles) =
because that would seem so obvious! If you had to have a proper =
explanation from the bible service manual, then were you ready and =
informed enough to really know what your E-type and it's history was =
about when you bought it??
Mark Budd
1970 E-type=20
From: Robert J. Richardson[SMTP:rrichardson@eurekanet.com]
Sent: Sunday, October 27, 1996 1:38 AM
Subject: Re: Attitude & E-type Frames - (Long?)
>Hi Robert,
>hahahahahahah
>(haven't a clue!)
>'62 E-Type, ots
Date: Sun, 27 Oct 96 17:40:19 EST
Subject: engine click
From: ** SHANE MANTOSZKO ** IBMA INVENTORY ANALYST **
*** Resending note of 10/26/96 10:11
*** SYDVM1(SHANEM) PH. (02) 354-4918 CUMBERLAND FOREST FE21
*** INTERNET - SHANEM@VNET.IBM.COM *** IBMMAIL - AUIBMSPM ****
>I have a SIII 85 Sovereign that is making a clicking sound from the engine.
>(I could swear it's getting louder as I get more worried). Bad valve, valve
>guide? What might I be looking at? Will I harm the engine by continuing to
>drive.
>Thanks,
>Dan
>Calgary
Dan, are they continuous little clicks, sort of like noisy lifters
in a V8 but only quieter ? If so, it's probably just your injectors
going tappety-tap, which is normal. If it's a louder, less repetitive
clicking, then it could be anything. You need to try and pinpoint the
area where it's coming from....the reverse screwdriver in the ear bit
should help find it....welcome aboard, and heres hoping it's nothing
more than the injectors....cheers.
Date: Sun, 27 Oct 96 16:54:45 -0700
Subject: Seat Heaters XJ40 1987
Does anyone know if it is possible to either repair or replace the seat heater
elements in my XJ40. I have checked the driver side and they show open ciruits
on both the seat base and seat back elements. The passenger seat shows an open
ciruit on the base only. My Jaguar wiring diagrams show a thermostat on the
drivers seat base, when I took my seat base off I found this to be a pressure
sensitive switch. Any comments!!!!!!
Thanking you in advance
Derek
Date: Sun, 27 Oct 1996 18:41:57 -0500
Subject: XJ40 Mystery strap
I took my 1990 Majestic to Bergen Jaguar for thier Customer Appreciation
Days, and got a free 1-hour inspection of my car and a chance to see the XK8.
Four were there and all had been sold, so I was limited in the poke-and-prod
department. I also got a free breakfast and car wash in the bargain.
Well, they found nine things about the car which need attention (about
US$2,283 worth of attention). Some, like the leaking ABS hoses and the wheel
bearings, are going to bring them some business. Others, like the cracked
lenses on my fog lamps (they insist on replacing the entire lamps at $160
each) are going to wait unitl I feel vain enough. I got a chance to talk to
BJ's mechanic, but no factory people were in evidence.
Anyway, the to point of this missive. Today I went shopping and on returning
to my car saw something hanging off the rear bumper. On inspection I found a
nylon strap, very much like a seat belt, drooping down from deep between the
bumper and body on the right side of the car. It seems attached to the car
at both ends, but I could not see well enough to determine how. I tucked it
up out of sight and went home. Any ideas? Is this standard equipment, or
something strange I've picked up?
Robert MacLeay (rmac@aol.com)
1990 XJ40 VdP Majestic
Date: 28 Oct 96 8:57:35
Subject: Re: Heater Control Valve
David Quintana <snip>: An old-time mechanic once
told me he didn't use commercial anti-freeze, just distilled water plus a
bottle of mineral oil was sufficient to extend the freezing/boiling
tempratures and provide anti-corrosive properties.
I can't comment on freezing/boiling properties although I'd suspect nil effect,
but I do recall that back when I was writing Volvo truck manuals (early
sixties) the recommendation was to add 2% emulsifiable oil (the type used in
machining) to protect against corrosion.
- -Jan
Date: 28 Oct 96 9:38:21
Subject: Re: V-12 vs. AJ-V8
Brian Sherwood <snip>: In 15 or 20 years, when the price of a used XK8 has come
down to a
level I can afford, maybe I'll buy one with a worn out engine, and transplant
a V12!
Excellent plan, Brian - just one snag: the silly so-and-so's made the XK8
engine bay too short for anything but a V8 (or, shock horror, a 4...). BTW,
under the existing numbering system, the top speed of this car is 8 mph...
- -Jan
Date: Sun, 27 Oct 96 20:14:57 EST
Subject: 420G/XJ6 updates, want DS420 limo
Thought I'd give an update on my two cats. One for the purists, and
one for those who are lump tolerant. (those who aren't lump tolerant
can tune out after the first section.....;-)
420G - Raquel
The old girl has had her damaged guard repaired, and is getting her
new spray job over the next month or so. She will be old english
white. She has now basically had everything rejuvenated over the last
10 years or so. The interior is basically brand new. When you open
the trunk/boot, you think it's a brand new car your looking into...not
a mark on the new lining, and man, what a boot it is !! I think I
could almost squeeze a double bed in there !!!
I'd say around February, she will be perfect, and will commence her new
life parading Brides and grooms around on saturday afternoons. The one
thing I have to do after the bodywork is get a top air-con shop to
install an A1 air-con system to help the wedding parties cope with the
Sydney heat. I've talked to a shop called Hahn automotive who seem great.
They can make it discreet, and efficient, and ensure it doesn't detract
from the cars beautiful leather and walnut authentic trim.
Can any jag-lovers in Britain give me an idea on how much a used
Daimler limo can be purchased for ? I'd love to give Raquel a partner
so that I can fit the whole bridal party in. Can anybody tell me what
the availability is like, and a ballpark cost for the various year
models ? If they are reasonably affordable, I'll make my next
holiday a British one, and will bring one back with me...can't wait !
XJ6 Series 2 - Corvette lump is now in !
Anti-lumpsters can now tune out. Those interested can stay.
My jag-ette is now on the road, and man does she purrrr...:-)
I have had a 1986 model TPI engine installed, and it's performance
is just breathtaking. I can't understand how this engine can be called
a lump when compared to an XK engine. It looks good, is lighter,
is definitely more powerful, and is just as smooth.It's got much better
fuel economy from what I've seen. I love the XK engine in my 420G,
but find it hard when comparing the two to call the V8 the 'lump'. If
having overhead cam is so much superior to push-rods, where is the
proof of the pudding ? After belonging to this group for a few years, I
can see that XK engines are lucky to run well once they have reached
the 100,000 mile mark, and then cost a fortune to rebuild. They have
poor fuel economy, need alot of maintenance (compared to the V8), have
less power to weight than the V8, and have less options available to the
owner to increase performance. If this is superior engineering when
compared to the old pushrod, then I'm missing something. Maybe someone
can put forward an unemotional, strictly fact based comparison of the
two, with pro's-con's for each engine listed. Personally, the change
to 'lump' on this car is an improvement. The series 2 XJ6 is one of the
most maligned of the models. Even purists shouldn't frown on keeping
these cars running with new lump transplants....at least they are still
jags on the outside......(sorry to re-ignite the debate, but remember,
I asked the anti-lump guys to tune out at the beginning of this section).
When standing at the back of my car now, you can be excused for thinking
it sounds like a vacuum cleaner. It is so smooth and quiet.
The old Holden carbie powered 5 litre 308 ci just doesn't compare to
what I now have. The new T700 4 speed auto is also a dream compared to
the old 3 speed trimatic that the car had.
Heres a summary of the main things we did to convert the car :-
* Corvette 'suitcase' which contains the radiator,condenser and thermo
fan fit beautifully in the front of the jag. Looks great too..
We found a small toyota coolant bottle which bolted nicely to the
top right of the suitcase. Unless you knew what the original jag
setup looked like, you'd never know that it was non-standard.
* Engine and tranny also sit great, with plenty of room around it to
work on. The power steering reservior now sits next to the wiper
washer bottle. The fan-belt, and all auxillaries like alternator,
smog pump, compressor etc are all right in front of you and a snap
to replace.
* All new air-con hoses have been put in, and the guy went to great
efforts to make it extremely neat. This applies to all the wiring
and hoses which are tucked away, or hidden beneath the engine where
possible/practical.
* Fuel system now the same as series 3 XJ6. Main difference is that the
return lines from the injection go through the same round plates
that fuel is drawn from. (it had the in-tank fuel pumps which are
located in the back wheel well.) This saved us having to pull the
tanks and weld in new return connections, or alternatively put in
series 3 tanks which cost a bundle. The fuel pump and
valve set up is the same as the series 3, and the tank breathers
and charcoal cannister set-up is as it was with the series 2. The last
thing I have to do is change the seals on the fuel filler caps to non
vented, and put restrictors in them so that the leaded nozzle cannot
fit in and blow out my cat converters by mistake.
* The transmission is basically brand new inside, as are basically all of
the parts apart from the short motor. Had to do some serious mods to
the tailshaft, which added another few hundred bucks to the exercise.
* We fitted a computer and harness from a holden 5.7 litre performance
V8 instead of the original corvette one. It is state of the art, and
eliminated the need for the air-flow meter. You guys in the US may
be able to replace a Corvette computer and air flow meter cheaply,
but over here, to replace the two in the future I would have been up
for around US$1,000. The Holden computer and air sensor will only cost
me US$300 if they ever break down. We were able to keep the Chev
distributer and ignition module, just had to adjust it to suit the
holden computer and engine management system.
It now has a nice small K&N air filter that comes out from the front
of the intake manifold, and looks great.
Overall, the exercise was not cheap, but the car now basically has a
whole new engine, new transmission, new tailshaft and uni joints,new
cooling system right through, new air conditioning right through the
engine bay, new fuel system, new engine management system. Add this
to the rebuilt suspension, diff, steering rack, leather trim,
glorious paint job, ss exhaust and all the miscellaneous electric
bits that have been done, and I have a fully reco'd Jag-ette that will
run the family around for the next 10 years comfortably and cheaply.
When compared to the cost of a new basic family ford or Holden, my
car was cheap, and leaves them for dead....long live the lump...cheers.
REGARDS.......Shane
Date: Sun, 27 Oct 1996 21:01:43 -0500
Subject: XKE windshield - failed
Getting the old windshield out eas easy.
Putting in the new one was more than I could manage. I considered using soapy
water to lubricate everything but didn't because I was concerned about
sealing it and didn't want to use something incompatible . Tomorrow I call "
Speedy windshield "
Doug
Date: Sun, 27 Oct 1996 21:25:07 -0500
Subject: Re: '85 XJ-S no start
John Napoli asked for suggestions for a friend's XJ-S which won't start-
John- you didn't mention checking the air temperature sensor, on the LH air
cleaner- was this checked to make sure it's not open circuit? Should be
some resistance there.
Also, might be helpful to put a fuel pressure guage to the injector manifold,
to read actual pressure to the injectors- should be 36-38 psi, I think; much
higher or lower would surely affect starting. (I installed a tee in the
rubber
tube to the RH-forward injector of my car, for a convenient place to
attach a pressure gage)
BTW, the PO of my car also had added a ground to the fuel pump relay,
so the pump runs whenever key is on; I haven't fixed that yet, I just don't
leave the key >on<. It could be hazardous, in an accident, if the pump
didn't
shut off. I will fix it some day.
Good luck, and keep us posted- sounds like you've been pretty thorough,
already.
Brian Sherwood
'84 XJ-S, '86 XJ-6
John Napoli <jgn@li.net>
Date: Sun, 27 Oct 96 19:50 MST
Subject: 62 E, oil pressure problem (long)
Hi everyone,
A while back I wrote in with a oil pressure problem on my E-type. Thanks to
everyone who replied! The problem turns out to be more serious than I
originally thought, and I still have a mystery on my hands.
To recap, one day I noticed that my oil pressure gauge was pegged solid at
60 psi+ all of the time. I originally thought it was an instrument problem.
After checking the wiring, and replacing the sender, the problem still
persisted. The common thought from members of the group was that I had a
blocked regulator valve. I pulled the assembly apart, cleaned it, saw no
problem and put it all back together with fresh oil and filter. I installed
a 100 psi mechanical gauge and started the engine. The gauge went past the
100 mark, and solidly pegged on the far side of the zero peg!!! At this
point I started getting really nervous.
I had the car towed into my mechanic. He put a 300 psi gauge on the engine.
At a cold idle (20-50 oil) the car has 200 psi of oil pressure! After
warming up it goes to 65 psi at idle and about 150 psi as soon as you rev
the engine.
We pulled of the regulator assembly again. Still looks good. Tried a
different filter, and a weaker spring on the valve. No difference.
So they pulled off the sump. Everything inside looks OK. Looks like oil is
circulating. All of the oil passages that can be accessed from the bottom
of the engine appear to be clear.
It turns out that the oil pump clearances are well below minimum. The pump
is so tight that the coupler to the distributor shaft was twisted from the
torque required to turn it. A new oil pump is on order, but I still have a
feeling something else has got to be wrong. How could a pump with tight
clearances "suddenly" cause high oil pressures. My pressure was usually
30-40 psi until suddenly changing one day.
I'm told that racing mechanics would kill for this kind of pressure, and I
can't get rid of it. Oil now seems to be seeping out of every possible area
of the engine, and I don't have any sudden valve train noise, so I believe
that the engine is getting oil. Is there a location where a blockage could
cause high pressure without depriving the engine of lubrication? I don't
have any good drawings of how the oil circulates in these engines.
By the way XK's Unlimited says that their source of oil pumps has not made
any in some time. Maybe next year. SICP claims any day now they will be
getting some. Anyone know where I can actually get an oil pump now?
Thanks for the help and sorry about the long message. My mechanic and I are
really puzzled over this one. Any suggestions are welcome!
John Gardner
http://rainbow.rmi.net/~jgardner/top.htm
'62 E-type OTS
'84 Audi 4000 Quattro
Date: Sun, 27 Oct 1996 19:28:07 -0800
Subject: Am I crazy?
Well, after spending some time reading all of those fascinating threads
in Jag Lovers Digest, I've finally gone and done it. I just towed home a
'65 3.8 "S" that has been in the process of restoration for at least 10
years and two owners already. I'm hoping I will have the stamina and
patience (read madness) to complete the job. Thanks to Steve Marrio for
giving me some advice during the decision process.
My name's John Toyofuku. It's been many years since I've done a
restoration (the last one was an '53 MG TD when I was still in school)
so I'm hoping for some advice and am looking forward to offering any
insights I may discover along the way.
The engine has been rebuilt and seems to run ok though it still needs to
be tuned; the suspension has been rebuilt but the PO aligned it himself
and though it drives steadily enough, I think I'll have to make some
adjustments there.
The first major projects I'll be tackling are the interior and the paint
job. So the questions I have are:
1. Paint: I'd like to restore it to original so I'd like to match the
original paint colors. I don't know what the original color of this car
was but I like the tan/gold color I believe was an option. Does anyone
know how I can get a chip of that original color to match or where I
might be able to buy this paint?
2. Wood: I've been reading the threads on this subject but I'm still not
sure. I'll pretty much stay away from Urethane but I'm not sure about
oils vs varnish. Does anyone know what was used by the manfacturer? And
if that finish would be available? I'm leaning toward varnish because I
would like a high gloss finish and don't want to be waxing it every
month. Any advice would be helpful here.
One more thing; I noticed there are very few "S" type owners out there.
Wondered if this is because there aren't many around or is the model
overshadowed by the more popular MK2, etc...
Keep up the great advice. Thanks in advance. I know I'll have lots of
questions so please bear with.
John
Recent owner '65 3.8 "S" type.
Date: Sun, 27 Oct 1996 19:41:15 -0800
Subject: Faulty Wiper
Hello everyone,
The wiper on my 89 XJ40 works fine with the 1 and 2-speed, but it refuses to work
with the D-speed. When I turn to D-speed the wiper turns about 45 degrees and
stucks in the middle of the windshield. Moreover, when turning it off during any
speed the wiper stucks and does not return back to the park location.
Does this sound like the relay is not working right? I opened up the wiper motor
and everything seems to be okay. Any suggestions?
Thanks,
- -Quang (jaguar@gaianet.net)
Black 89 XJ6
End of jag-lovers-digest V2 #469
id <QAA07009> for jag-lovers-digest-out; Mon, 28 Oct 1996 16:10:23 +0100 (MET)
Date: Mon, 28 Oct 1996 16:10:23 +0100 (MET)
Message-Id: <199610281510.QAA07009@ekeberg.sn.no>
Subject: jag-lovers-digest V2 #470
Precedence: bulk
jag-lovers-digest Monday, 28 October 1996 Volume 02 : Number 470
XJ40 Brakes
XK8 ownership
XJS Beauty
Re: Faulty Wiper
Re: 62 E, oil pressure problem (long)
Engine cuts out
EFI V12 Problems
Re: XK8 ownership
XK8 & Nikasil
Re: Oil treatment
Faulty Wiper
RE: E-type Frames
85 XJS ignition switch and power steering
Buying a 1993/94 SJX: What Does One Look For; Good Price
Date: Sun, 27 Oct 1996 20:16:43 -0800
Subject: XJ40 Brakes
Howdy,
Not long ago I replaced the accumulator on my 89 XJ40 since there
was "Low Brake Pressure" warning. The brakes work fine ever since.
But the warning only shows up after a few hours of parking. When the
warning shows up the brakes don't work too well. However, after driving
about a few blocks the warning disappears and the brakes work fine.
Does it sound like I need to bleed my brakes? When I replaced the
accumulator I did step on the brakes about 60 times or so as instructed
by a jag-lover. I need some advice... This warning really looks bad. It
gets on my nerve....really. ;(
I have done brake bleeding on a Mazda and a Honda. I'm sure it's
different on a Jaguar. Are there any instructions on bleeding brakes
on an XJ40 floating on the net that I can get a hand to?
Happy riding,
Black Cat - 89 XJ40
Date: Sun, 27 Oct 1996 20:53:10 -0800
Subject: XK8 ownership
Just wondering, with all the opinions on the list about this car (XK8),
does anyone on this list actually own one? If so, could we please have
your initial opinions/experience with the car? I was told the car can
be leased for $10,000.00 down and $1,250.00 per month. Can any actual
owner give a reason or two for paying this much cash each month for
this car? My guess is that there is not a single owner on the list.
If there are, why haven't they defended their expensive investment?
Just curious
Gerald Foster
From: rrichardson@eurekanet.com (Robert J. Richardson)
Date: Mon, 28 Oct 1996 00:15:08 -0500
> Hi,
>owner you could be, if you couldn't figure out what my version of a front
>informed enough to really know what your E-type and it's history was about
> Mark Budd
> 1970 E-type
O.K., O.K. Enough already. Remember, you initially referred to the front
frame assembly as a front rail. Rail? Tubes, yes. Frame would have given us
a clue.
I just go by the book. It helps when securing parts. I had a '53 XK-120M
for several years so I bought my E-Type because I've always been a Jag
lover. Up to now, I had experienced mechanics in Naples, Fla., so
unfortunately I didn't know how to tune three SUs let alone have to replace
any of the tubes in the Front Frame Assembly. Now that I'm back in hill
country (Ohio) I'm faced with learning E-Type maintenance from scratch. And
that's why I think all of you with experience are the main reason why this
list is so valuable. I don't mind a good kidding, but I sure would be lost
without this list and that good old Jag Bible.
Date: Sun, 27 Oct 1996 21:31:32 -0800
Subject: XJS Beauty
After reading the on-going debate about the outdated styling of the
XJS, etc. I badly need to vent on this subject.
1. I think some people on this list are suffering the effects of too
much solo sex.
2. I'd rather push my XJS than drive some other peoples cars. (and I
have!)
3. For the puny price most of us pay for a used XJS, you can still get
big time access to women who would not normally give you the time
of day otherwise. (See #1 above)
4. There are no ugly Jaguars.
5. A Jaguar is a prestige possession. It says: I have this expensive
brand of auto, I can afford to put money into it, and it still
does not always run, and I still love it.
Now let the flaming begin!
A satisfied XJS man
Gerald Foster
89 XJ40
86 XJS
Date: Mon, 28 Oct 1996 00:55:48 -0500 (EST)
Subject: Re: Faulty Wiper
The self-parking system is down for the count. The two common causes are a
blown park fuse (behind the right side lower dash piece) and a failed park
micro-switch inside of the motor.
Randy K. Wilson
randy@taylor.infi.net
Date: Mon, 28 Oct 1996 00:51:13 -0500 (EST)
Subject: Re: 62 E, oil pressure problem (long)
>the engine.
There pretty much has to be a blockage going in to, or out of, the relief
valve. Or... it's possible that something has gotten screwy such that
the valve is getting a hydraulic lock... same high pressure on both sides.
Not really. We strive to get the by with the minimum oil pressure. It saps
a lot of power making that high pressure, as is evident from your twisted
drve shaft.
I may have one sitting on the shelf. Tis noted to check tomorrow am.
>John Gardner
Randy K. Wilson
Date: Sun, 27 Oct 1996 22:13:23 -0800
Subject: Engine cuts out
I bought a 1984 XJ6 "Vanden Plas" a few months ago and up until now has ran
great. It has the 4.2 EFI motor. If anyone can help me figure this out I
would be most greatful.
The problem first appeared on a short (5 mi.) run. At cruising speed, the
motor just stopped...no sputter, falter or anything. It was as though
someone had just shut off the key. I put the car in neutral and it fired
right up. This happened several times over the next few days (with new gas
in the tank). At first I thought it was fuel delivery. I replaced the fuel
filter (original?) checked the fuel pump, (fine), but would still do it.
Electrical? I replaced the plugs, distributor cap and rotor, and air
filter. The car was running GREAT....but still intermittent cut outs.
Didn't matter if cold or warm. Then one day it wouldn't start. Checked for
spark - good. Fuel to the fuel rail - yes (I could here it pressurize when
I manually operated the air flow flap with the ignition on). I finally got
it started by spraying that awful starting fluid into the throttle body.
Does this sound like a loose or bad electrical connection? Where do I
start?
Date: 28 Oct 96 15:16:52
John Gardner <snip>: ...oil pump clearances too tight...
Just a couple of stray thoughts on this:
1. If the clearances in the oil pump are too tight, I don't see a need for a
new oil pump - shims should set the clearances just right, along with maybe a
little stoning on the gear tips.
2. It's not the oil pump that sets the pressure, it's the relief valve - as you
know. However, the reason why the relief valve doesn't work may be found in its
outlet. I don't know how the six is plumbed; on the V12, the relief valve
outlet is plumbed through the oil cooler, and if the cooler is blocked, the
symptoms would be exactly the same as yours.
- -Jan
77 XJ12C
78XJ12L
Date: Mon, 28 Oct 1996 18:44:10 +1100
Subject: EFI V12 Problems
My thanks to all who publicly and privately replied to my recent message
about my aux air valve problem. I have decided to leave it there because it
remains closed and will only affect my cold idle.
I have been chasing a stranger problem for the last five weeks.
Symptoms:
1. Runs rich and then stops with a strong smell of fuel (flooded I think)
2. Restarts after 45 minutes but blows soot when reved and driven
3. No power when trying to accelerate
4. Stops again
Have Done:
1. Rewired my injector harness (wires perished),
2. Tested temperature sensors (no shorts, correct resistance at temperature),
3. Adjusted linkages and butterfly valves,
4. Tested (and disabled) cold start system,
5. Serviced injectors, and
6. New coil, plugs, fuel and air filters.
I am currently overhauling the distributer (ref: Kirby Palm - old grease had
varnished and siezed advance)
Next in line is the pressure sensor and throttle switch. Do these fail often?
Any thoughts?
Derek Hibbs
Canberra, Australia
77 XJ-S (no go)
Date: Mon, 28 Oct 1996 00:57:32 -0700
Subject: Re: removal of vent pipes, carbon canister etc.
>> And if they are such a
>> benefit why don't all Jaguar's sent to all countries have them fitted?
>it in place?
>> To me it is logic, if they are only on certain cars that Jaguar made, then
>> they are not necessary.
>> If they are not necessary, then they are just one
>> more thing that can fail.
>eliminate it.
> -- Kirbert | If anything is to be accomplished,
> | - Palm's Postulate
OK, Although I am not, lets play that I've been convinced I need a vent
system. As I said, my MGs do not have a vent, and this is rarely a problem:
I have had to release a vacuum every now and then, but I have never seen my
tank collapse or explode. Then again, the MGs do not get 9 mpg and use a
high pressure recirculating fool infection, oops I mean fuel injection system.
So, why is this system so complex? It seems to me that one vent at the top
of each tank that went to one carbon canister per tank would be more than
sufficient, and cheaper. Further, it would not put pipes and things (I
don't know what you call the things in the pillar, they are probably put up
high to act as condensors of some sort) where they could fail and let vapors
in the car. You could put it say behind the tanks, but in front of the rear
bumper (not exposed). It would be less piping, fewer vents (currently there
are two per tank, and looks like one is fairly low, therefore usually full
of liquid fuel) and thus lower cost, but yes, it would not introduce the
vapors into the intake manifold. Do I really need to do that, for the
miniscule amount of vapor that will be going in there. Seems that most of
the time, the tanks would pull in air to prevent a vacuum, and only on
extremely hot days, the fuel would expand enough to expell vapors when the
cars are sitting.
Phil Bates
58 MGA
67 MGB
75 Jaguar XJ12C
52 MG TD replicar (VW)
From: "Mark A. Salmon & Company" <Mark@masassoc.demon.co.uk>
Date: Mon, 28 Oct 1996 08:52:37 +0000
Subject: Re: XK8 ownership
I drove the XK8 both fixed head and convertable last tuesday, for a few
hours, It is INCREDIBLE.
It is a far better car than the XJ-S V12, which I have owned for over
three years.
It would be well worth the investment.
Regards
Mark Salmon
In message <199610280453.UAA02160@dfw-ix7.ix.netcom.com>, Gerald M
Foster <sky182@ix.netcom.com> writes
> Just curious
> Gerald Foster
Date: Mon, 28 Oct 1996 21:59:47 +1000
Subject: XK8 & Nikasil
I'm reading Phillip Porter's book on the XK8 and brief mention is made
of the Nikasil process. The plating is 3thou, saves 15lb weight & the
only other volume manufacturer using it is BMW. The aluminium block is
low-pressure cast to ensure low porosity prior to plating. "Clearly the
quality of the aluminium bore finish has a direct relationship on the
final finish of the plated bores." I assume that 3thou of plating is
goodbye to rebores. So the stuff had better work,eh?
Regards Peter Smith
Date: Mon, 28 Oct 1996 08:11:21 -0500 (EST)
Subject: Re: Oil treatment
Michael: Keep in mind that in top gear the Viper at 90 would only be
turning around 1600 rpm. The Viper has a double overdrive, the two top
gears are OD gears as they are in the Vette and Camero.
I would like to see them run an engine at say 6000-8000 for an hour.
Chad Bolles Jaguar South 306 Valcour Rd Columbia SC 29212 USA 803 798 3044
Date: Mon, 28 Oct 1996 08:16:10 -0500
> >Most Series 1 E-types that were sold in the US are 3.54, however,
> >3.07 and (I think) 3.77 or 4.11 were options. UK and Australian
> >cars were more typically 3.07 for the higher top end.
> >Generally only the race cars had the 3.77/4.11 ratios.
> Thanks. I'm almost certain I too have the 3.54:1 final drive. Until I can
> replace the flex cable, I'm going to do a graphic of the Jag speedometer
> face (exact size) and, based on my final drive ratio, show rpm's opposite
> significant speeds such as 25mph, 35mph, 55mph, 65mph and an even 100mph.
> I'll tape this over the speedometer face and at a glance I can tell my
> speed based on rpm's.
>-- End of excerpt from Robert J. Richardson
Missed one, mine is a 3.31 also common in Canada/UK AND on early 3.8 US
cars(!). The way to know for sure is by the little silver tag on the diff. Look
carefully, you will find it wired to one of the bolts (if the diff hasn't been
messed with). There are two numbers on the tag, divide the top number into the
bottom number(or was it the other way around?) and presto, that's your axle
ratio.
Mark McChesney
'65 Etype ots
Date: Mon, 28 Oct 1996 08:35:36 -0500
Genlemen, start your engines;
Choose your weapons!
We're tilting from frames to attitudes now!
Shut off you engines,
Ctl, alt, del.
Start over.
'62 E-Type, ots
Date: Mon, 28 Oct 1996 15:08:38 +0100 (MET)
Forwarded to: SMTP[Jag-LOVERS@SN.NO]
cc:
Comments by: PLacey@Petrol@SwRI08
Comments:
Quang
I had a similar problem with my 88 XJ-40. The real problem is that the
wipers dont park. Try changing the 5 amp fuse at the passanger side of the
dash inside the car. To get at the fuse (on my car at least) remove the
pannel below the dash in front of the passangers knees (US cars). It is an
in line fuse are is easily visible once this pannel is removed.
Let me know if it works,
Paul Lacey, Texas
-------------------------- [Original Message] -------------------------
Hello everyone,
Thanks,
Black 89 XJ6
Date: Mon, 28 Oct 1996 09:13:30 -0500
Subject: RE: E-type Frames
Hi Robert,
Point taken and noted. I have bought myself all the E-type books I =
could get my hands on, to learn how to restore most of my car myself. I =
have found that even when I go to my Jag mechanic to reassemble the =
parts I've restored, *he* doesn't know the "book" terms for the part =
names. He'll go by the names he was taught from his garage upbringing. =
So you see, this happens often not only with rail, frames, whatever, but =
even suspension parts. Now that I think about it Robert, when I had an =
estimate done on my 1970 E-type, the restoration company said mine was a =
Series 3 car! I had to tell them it was a 6 cyl.! (They were a year off) =
Tisk. I would like to be an owner who really *knows* his E-type, so when =
and if I'm ever asked about it, I could go into details that a person =
who only bought the car couldn't. Maybe this attitude of mine will help =
me from getting ripped off from a garage restorer, or even help a =
prospective E buyer to understand his or her car... My Jag books are =
gold to me as well!
Good luck with your E-type, keep us/me updated with whatever you're =
working on? I am presently rebuilding my rear diff. Just getting all the =
parts purchased before I send it out for reassembly. My front suspension =
is just completed a week ago.
Mark Budd
1970 E-type OTS 6 cyl! lol
=09
> Hi,
> Just thought I'd say, I myself was wondering what type of =
E-type
>owner you could be, if you couldn't figure out what my version of a =
front
>frame rail explanation was. I mean, I would of thought it was a =
natural.
about
> Mark Budd
> 1970 E-type
frame assembly as a front rail. Rail? Tubes, yes. Frame would have given =
us
a clue.
unfortunately I didn't know how to tune three SUs let alone have to =
replace
country (Ohio) I'm faced with learning E-Type maintenance from scratch. =
And
that's why I think all of you with experience are the main reason why =
this
list is so valuable. I don't mind a good kidding, but I sure would be =
lost
From: tom fisher <fisher-tommy@blue.weeg.uiowa.edu>
Date: Mon, 28 Oct 1996 08:51:59 -0600
Subject: 85 XJS ignition switch and power steering
HELP!!!!
My baby is broke. First of all this is the second most beautiful car I own
(the first being my 61 1/2 E-type) and now I have a problem.
Last week the power steering lost some fluid, broken hose I hope.
Question....any recomendations on proper fluid??
Second, the following day I noticed that the inition indicator dash lights
were staying lit. I have been having a little problem with this switch with
it being intermitant in working sometimes.
Question....how do I get the switch out, and do you think that this is
co-incidental, or, did somthing get wet under the bonnet (gulp). Help
please as I need this car for a trip from Iowa City to Champaign ILL to
see my Hawkeye football team embarass the Fighting Illini this Saturday.
please replky either by e-mail direct or to an alternat e-mail address of
tommy-fisher@uiowa.edu
HELP!!!!!!!!
Date: Mon, 28 Oct 1996 10:06:00 -0500
Subject: Buying a 1993/94 SJX: What Does One Look For; Good Price
A friend is very seriously interested in a 1993/94 SJX coupe. I'd
appreciate any advice on what to look for--especially if there are
mechanical differences that make one model year greater. Or if there
is a functional area (for example, climate control) advantage.
Naturally, what's a good price range for the 1993/94 SJX coupe in the
U.S./East Coast today? I look forward to hearing your opinions.
Thanks.
Steven Huff
End of jag-lovers-digest V2 #470
id <TAA28594> for jag-lovers-digest-out; Mon, 28 Oct 1996 19:49:03 +0100 (MET)
Date: Mon, 28 Oct 1996 19:49:03 +0100 (MET)
Message-Id: <199610281849.TAA28594@ekeberg.sn.no>
Subject: jag-lovers-digest V2 #471
Precedence: bulk
jag-lovers-digest Monday, 28 October 1996 Volume 02 : Number 471
Re: Introduction to list
Re: Series Three Door lock problems
engine click2
Re[2]: E-type Frames
mailing-list
Snake oils
Re[2]: 83 XJ6 Air Con Leak ( Alex: )
Re: Series III Door Lock Problems...
Re: XK8 & Nikasil
Re: Engine cuts out
Mark IX trim
Re: I have the Clicking Engine Too!
Re: XJ40 Mystery strap
Nikasil being used by others
Re: Snake oils
Re: XK8 & Nikasil
Date: Mon, 28 Oct 1996 17:11:59 -0200 (GMT)
Subject: Re: Introduction to list
Dear Robert
At 11:39 26/10/96 -1000, you wrote:
. Lately, I've gotten a variety of opinions on the correct
>type of needle for the HD6 carbs
. Anyone have an idea what milage I should be getting and what kind of
>needle it should really have?
The Burlen book says for an XK140 FHC 1955 for CR of 7:1 or 8:1 manual (LHD/RHD)
that you should have SJ needles, The WO2 are for the 140C which I believe
had the C-type head.
Hope this helps
Regards......Brian
64 3.8 MkII 86 XJSC
Date: Mon, 28 Oct 1996 10:19:55 -0500 (EST)
Subject: Re: Series Three Door lock problems
1985 xj6 series III electric door locks don't operate correctly. I can
unlock them but when I return the key to the vertical position to take
it out they lock back up sometimes is there and adjustment for this or
is new locks the only answer.
Thanks in advance
Theo
tbremner@lynx.neu.edu
Date: Mon, 28 Oct 1996 08:47:49 -0700
Subject: engine click2
Good morning folks.
On Friday I posted a message regarding engine click on from my 85 Sovereign.
It may or may not be
important but the click only manifests itself when the engine is warm. any
ideas?
Dan
85 SIII Sovereign
Calgary, Canada
Date: Mon, 28 Oct 96 11:05:22 CST
Subject: Re[2]: E-type Frames
I'm sorry, I can't resist. I was chuckling too much sitting on the
sidelines.
Have any of you called one of the suppliers asking for either a RH or
LH rear diaphram for the bonnet? They will insist they are called
mudshields, when in the fact that parts book is specific about what a
mudshield *and* a diaphram is.
SK
______________________________ Reply Separator _________________________________
Author: Mark Budd <mbudd@inforoute.net> at smtplink-tellabs
Date: 10/28/96 10:58 AM
Hi Robert,
gold to me as well!
Mark Budd
=09
> Hi,
E-type
front
natural.
about
> Mark Budd
> 1970 E-type
us
a clue.
replace
And
this
lost
Date: Mon, 28 Oct 1996 11:36:43 -0800
Subject: mailing-list
My name is Michael Graziotti and I'm interresed in joining your mailing list. Several
months ago I bought a 1985 Jaguar XJ6 SIII. I love it! the car has 68000 original miles
and looks and runs like new. It is black with a red inteior that is perfect. I had never
owned a Jag, but I,m hooked. I have been reading books and searching the web to learn as
much as I can about these great cars.
I,m very impressed with the size of your mailing-list and the number of Jaguar experts
that partisapate. My car does have one persistent problem that I hope your members
can help me with. It does not start easily when it is cold. Since it�s currently summer
in Florida, �cold� translates to 90 degrees F. I had the car serviced by the local
Jaguar dealer, who installed new plugs, cap, rotor and replaced one of the water
temperature sensors. The mechanic could not find any other electrical or mechanical
problems with the engine. It starts right up if the car is at operating temperature, but
has to be turned over 5 or 6 times when it�s cold. I have put my multi-meter on the Cold
Start Fuel Injector and I�m getting voltage at start-up. Are there any other circuits
that possibly control cold starts.
I look forward to joining your mailing-list and any help your members can give me..thank
you
Date: Mon, 28 Oct 1996 11:35:36 -0500
Subject: Snake oils
Another add demo:
The other day I was in a typical auto parts store (not a retail store). On
the counter they had, Lucas oil stabilizer additive. The little gears you
spin showed that the oil sticks to the gears, better than regular oil does.
Do we care if oil is attracted to parts if it is continuously pumped through
the engine?
With all these oil additives and secret chemicals, is there a change in
evolution in oil coming? Are they beginning to design engines diffferently
due to this apparent/alleged improvement in lubricants (like the DOT
2,3,4... brake fluid)? Is there a PROBLEM with lubricants now; isn't
friction now close to nil when the engine is at temp and running???
Russ Lehman
"nothing worthwhile is ever easy"
"pessimists are accurate; optimists live longer"
Internet: rlehman@npr.org
From: "Richard.Mansell" <Richard.Mansell@psemail.ps.net>
Date: Mon, 28 Oct 1996 16:47:00 +0000
Subject: Re[2]: 83 XJ6 Air Con Leak ( Alex: )
- ------ =_0_MIME_Boundary_18197.3274e2db.im4dr6d0.eurh021.eur.ps.net
- ---------------------------- Forwarded with Changes ---------------------------
Date: 10/24/96 6:19PM
To: owner-jag-lovers@sn.no%ussmtp at ccx400uk
Content-Type: text/plain; charset=iso-8859-1
Content-Transfer-Encoding: quoted-printable
Brian=2c and others said=3a-
=3eIf core is leaking=2c dash has to come completely apart =28major jo=
b=29=2e =
My first XJ-S had a leaking core=2c the air-con man waved his freon =
detector around the vents in the car and it made the usual =
big-freon-leak noises=2e
He then said =22you can either pull the core=2c big job=2c or for =a33=
0 I can =
put some of this new leak sealer in =28holds up Agent X=29=2e There ar=
e no =
guarantees but I have seen it work before=2e=22
Having nothing to lose other than =a330 I told him to try it=2e After =
a =
few minutes he waved his magic wand again=2c this time no =
The charge in the system lasted for another couple of years till I =
junked the car=2e
Thats the good news=2c the bad news is I have no idea what it was=2c n=
o =
one I have spoken to has ever heard of this stuff but it appeared to =
work for me=2e
Richard Mansell
'89 XJ-S
- ------ =_0_MIME_Boundary_18197.3274e2db.im4dr6d0.eurh021.eur.ps.net--
Date: Mon, 28 Oct 1996 11:50:52 -0500 (EST)
Subject: Re: Series III Door Lock Problems...
I have a 1985 Sovereign Series II that the door locks don't operate
properly. I took the door panel off and found that the E clip holding
the lock in was missing and I replaced that feeling that the job was
done but when I tried the lock it unlocks but when you return the key to
the upright position to remove it the locks lock again it seems that the
lock and unlock aren't spacved far enpough based on the little amount of
key movement to lock and unlock them. Is there an adjustment to be made
to correct this or do I need new lock????
Thanks
Theo
Date: Mon, 28 Oct 96 09:53 MST
Thanks for the comments on my little mystery. Just one point I didn't
mention before...
I'm pretty certain that the relief valve is working. After cleaning and
reassembling the housing for the relief valve, I forgot to put the hose on
that goes between the relief valve output and the sump. After starting the
engine , I was running at normal oil pressure for several seconds before I
noticed that I was dumping oil on the floor. The relief valve was defiantly
opening and dumping oil. After cleaning up the mess, replacing the hose
and topping off the oil (I lost three quarts), the pressure maxed out my
gauge.
I'm not too clear on how the oil circulates in this engine. The output of
the relief valve goes directly into the sump via a hose. There is a pickup
tube that goes down into the sump. Everything accessible with just the sump
off is clear. Anyone have any ideas about where a blockage might be?
BTW, Randy mentioned that, in racing engines that high pressure is
considered undesirable because of the power loss. One former racing
mechanic I've talked to said that he always tried to get high pressure so
that he could run tighter clearances on bearings. Anyone else have any
experience with this? Just curious.
John Gardner
Date: Mon, 28 Oct 1996 11:55:10 -0500
(This message was bounced back, so I'm resending it)
rubber tube to the RH-forward injector of my car, for a convenient place
to attach a pressure gage).
didn't shut off. I will fix it some day.
already.
Brian Sherwood
'84 XJ-S, '86 XJ-6
Date: Mon, 28 Oct 1996 12:01:23 -0005
Phil Bates:
As far as I know, there has never been an XJ-S tank collapse or
explode either. The problem that caused the recall was that the
pressure/vacuum cycles were too large, causing the tank to "oilcan"
back and forth, and this would eventually cause cracks in the metal.
A design hack to be sure, but perhaps a more understandable hack when
talking about a 25 gallon tank vs. a 12 gallon.
As far as I'm concerned, it's not all that complex -- at least, it
wasn't before the recall. The recall added these vacuum-operated
valves and did increase the complexity considerably, I'll admit.
It would be, if the tank had a convenient "top". However, the XJ-S
tank is broad with a flat top, so the "top" can be at either end,
depending on slight road camber. Connecting the vapor separator to
several places on the tank -- as well as right up at the filler cap
- -- makes sure you have it vented wherever the top is at any given
moment. This is the type of thing necessary when you try to make a
low, sleek car rather than a pickup truck, and the tank must be
shaped to fit rather than just any old shape.
> in the car.
If you're that concerned with failure (and I have NO idea why you
are), then do this: Take the vapor separator out, coat it internally
with the same stuff we've discussed earlier for sealing the inside of
fuel tanks, and paint the outside with zinc chromate primer and/or a
nice coating of Rustoleum or some other favored rust preventor.
Then, while installing, replace ALL of the hoses to it with generic
fuel hose purchased at a local parts shop, making sure it is not made
in the UK. That done, you won't have anything to worry about any
more than you would on any other car.
> ...but yes, it would not introduce the
> cars are sitting.
We're not talking about the fuel BOILING, it doesn't take a hot day.
The fuel will always be vaporizing enough to provide a good amount of
vapor within the tank. And if the tank is essentially open to
atmosphere, a pretty good amount is gonna escape -- although,
clearly, not enough to significantly add to your fuel bill. And if
your area gets a little cooler at night and warmer in the afternoons,
these cycles are gonna "pump" this vapor out, even if we're talking
35F at night and 55F in the afternoons.
The better question would be "why?" The stock system is not really a
problem, and providing any sort of replacement system is not gonna
improve anything.
| - Palm's Postulate
Subject: Re: XK8 & Nikasil
Peter Smith:
> of the Nikasil process. The plating is 3thou...
Hmmm. So, once there is .003" of wear on the cylinder, it breaks
through the plating and starts yanking off gobs of aluminum? How
much is .003" on a cylinder bore?
> ...saves 15lb weight...
Save 15lb compared to what? NOT plating? Cast iron block?
> ...& the only other volume manufacturer using it is BMW.
OK, somebody please fill me in on what the Porsche 928 is using, as
well as all the other non-linered aluminum blocks out there. And,
for that matter, what those liners were that were reportedly used in
racing V-12's and then dropped due to reliability problems.
> I assume that 3thou of plating is goodbye to rebores.
Why? It would seem to me a simple matter to grind the old plating
off and replate -- although I strongly suspect most people going to
this effort would prefer to insert iron liners, if possible.
| - Palm's Postulate
Date: Mon, 28 Oct 1996 10:04:01 -0700 (PPET)
Subject: Re: Engine cuts out
>start?
>___________________________Reply Separator__________________________________
Steven and I had the very same problem... what a PITA it was! We replaced
the ignition power relay, (you know, those three relays mounted together at
the back wall of the frame, it is one of those), and the car has run like a
champ since. Hope this helps you with your troubles!
Steven and Ola Peters
84 XJ6 Vanden Plas
Date: Mon, 28 Oct 1996 17:49:50 GMT
Subject: Mark IX trim
I'm in the process of re-installing the chrome trim over the fresh
paint on my Mark IX. When the trim was removed a few years ago I
noticed a putty-like substance between the trim and the paint. I
assume this was used to seal the interface.
Any ideas about what I should use as a sealant? I'm considering
something like plumbers putty which supposedly never hardens, but I
don't know how it will react with the paint.
Any ideas are welcome.
Vince
- -- =20
Vince Chrzanowski radiowsh@mindport.net=20
"There is not a moment to be lost" - Jack Aubrey
- -------------------------------------------------- =20
Date: Mon, 28 Oct 1996 13:06:55 -0500 (EST)
Subject: Re: I have the Clicking Engine Too!
My 1985 Sovereign also clicks taps or whatever but only when it is cold
after it warms it seems to be ok and the click is not all that
noticeable unless the hood is open is this normal or does something need
adjustment?
Thanks
Theo
Date: Mon, 28 Oct 1996 13:28:06 -0500
Subject: Re: XJ40 Mystery strap
In a message dated 27/10/96 23:49:31, you write:
returning
a
Its just a transit strap, fitted at the factory for the car to be secured to
the transporter during delivery. Its ok to cut it off.
Tez.
From: <miflook@banmail.ml.com> (mflook@banmail.ml.com)
Date: Mon, 28 Oct 96 13:30:07 EST
Subject: Nikasil being used by others
<< Peter Smith <pjsmith@gil.com.au> notes:
only other volume manufacturer using it is BMW. The aluminium block is>>
FWIW - I'm a Jag list lurker (and hopefull soon to be XJS owner), but currently drive BMW's. I believe the the BMW engine to which you refer is the V8 used in the 540. Interestingly enough, this engine is involved in a "good-will" campaign to be resleaved(sp?) apparently as a result of the high sulfer content in US fuels - most notably in the southern region - breaking down the Nikasil liner. In addition, the warranty is being extended to 100,000 miles for this particular engine.
There was quite a thread over on the BMW Digest over this matter this past summer, with questions being raised regarding owner notification (there has been no official recall notice sent to owners to my knowledge), as well as resale complications.
Just a point about others using the same technology. As my father used to say, "Sometimes the majority simply means all of the fools are on the same side".
Michael J. Flook
Pennsylvania USA
sorry, no jag yet.
Date: Mon, 28 Oct 1996 11:33:02 MDT
Subject: Re: Snake oils
Oh god, the electrical parts weren't enough, now we have to reduce
the relaibility of simple oil too !
> the engine?
As far as the bearings go, no. They are lubricated hydrodynamically
which means that the bearings mostly do not touch
each other when under pressure. As far as the cylinders go, this
might have an effect but I can't imagine that this is any different
than a simply higher viscosity oil.
Really a million dollar question (or multi-million!). There are
endless opinions and FAQs on this issue. Personally, I like my
standard 30W oil with no additives. Keep it clean and full and there
really is no reason for it to not serve its purpose. In my opinion,
improvements in manufacturing techniques, better tolerance control,
and higher quality control in the materials the engine components are
made of has done more to improve engine life than "snake oils".
Many people swear by synthetic oils and that's just
fine. There probobly is a difference for the better in most of the
more reputable lubricant additives, its just a question of value. I
would rather spend my money on a good brew (or whiskey for those who
prefer that) or replacing injectors in my XJ12C.
Kind Regards,
Jim Cantrell
Date: Mon, 28 Oct 1996 11:48:21 MDT
On a hard wear surface, that's likely to be adequate - for a minimal
number of miles. However, this discounts the effect of the strength
with thickness. Having spent nearly three years (very long I might
add) studying the wear characteristics of plated surfaces, I can
safely say that the effect that you describe will occur and that it
will happen when the wear is closer to half the shell thickness. The
plating shell will usually fail at these thin layers since there is
often imperfections in the plating process itself that have a finite
depth and the material gets weaker as it thins out.
I would bet money that the likely reason the plating in the XK8 is so
thin is that the plating quality control is very difficult to obtain
with thicker plating thicknesses. The result would be, I imagine,
weaker plating shells, higher porosity, and less tolerance control.
I imagine that theu have tested this and found some optimum point.
Seems to me to be a lot less bother for the driver to go on a diet
and lose the equivalent weight - or to shave 0.001" off of the body
panels. Sounds like a sales gimmick to me.
I don't know exactly what the 928 uses, but I do know that Porsche
put a version of GM's disaster engineering in their cars in the mid
80's. Thise used a process of casting the aluminum block,
impregnating the bores with a higher silicon content, machining the
bore, and then chemically etching the aluminum back from the silicon
grains. The supposed result was a "hard" bore surface. It was great
until contaminants got introduced (such as a leaky head gasket) and
this ruined the motor. Steel sleeves rendered the motor useful. I
haven't heard any ill reports of the Porsche experience but then
again, would they admit to it if they had ?
Liners are more likely to be more economical than Nickasil. I
imagine that the plating process is rather involved and involves some
very specialized tooling. This is likely to be an economical method
for mass production, but small plating shops probobly couldn't afford
the capital for such a small return. On the other hand, everybody
knows how to do sleeves, even some bubbas.
Kind Regards,
Jim Cantrell
End of jag-lovers-digest V2 #471
Return-Path: @owner-jag-lovers-di1
Received: (from majordom@localhost) by ekeberg.sn.no (8.7.5/8.7.3/on4)
id <WAA08916> for jag-lovers-digest-out; Mon, 28 Oct 1996 22:29:58 +0100 (MET)
Date: Mon, 28 Oct 1996 22:29:58 +0100 (MET)
Message-Id: <199610282129.WAA08916@ekeberg.sn.no>
To: jag-lovers-digest@sn.no
Subject: jag-lovers-digest V2 #472
Reply-To: jag-lovers@sn.no
Errors-To: @owner-jag-lovers-di1
Precedence: bulk
X-Newsgroups: mail.jag-lovers-digest
jag-lovers-digest Monday, 28 October 1996 Volume 02 : Number 472
Must be near Halloween / XJ-S Beauty
XJ-S Power steering hoses
Vapor Lock
Dead Cylinder/ Clicking Noise.
Jags
XJS power steering
E-type frames
XKE engine/trans
Carbon canister etc.
Re: Nickasil bores ..
Re: Chevy Lumps in XK8's
XJ-S beauty v.s. XK8 performance
Oil Pressure overage in E Type
Snake Oil is too cheap to not use.
Re: XJS Beauty
Restoration Process
Date: Mon, 28 Oct 96 12:19:00 PST
Subject: Must be near Halloween / XJ-S Beauty
STEVEN.HUFF inquired:
Steve must have been looking in a mirror to see if he still has a
reflection. :-)
Just kidding. Although I am fairly new to Jags, a SJX ???
Amen to Gerald Fosters XJS Beauty posting. On just about any Jag line, if
you placed the first year next to the last year & told someone who knows
nothing about them, that they are the same, just different years, they would
most likely agree.
Try that with a Mustang, Camero, Taurus ...
John Himes
88 XJ-S 98K Miles
72 Mustang Convertible 115K miles, I think ?
Date: Mon, 28 Oct 96 13:06:00 PST
Subject: XJ-S Power steering hoses
In reply to a message by Tommy Fisher ( I tried to reply directly to
"fisher-tommy@blue.weeg.uiowa.edu", that was returned. I deleted the
original message so I do not have the other id's mentioned in his post )
On my 88 XJ-S I have been using off the shelf power steering fluid with
no problems.
If one of your hoses are leaking, this can be a pain to correct, but
should only take a few hours. This is something I did last year.
My return hose was leaking. ( The one that goes from the rack to the middle
of the pump and is attached via a hose clamp. The one that has a fitting in
the bottom
of the pump is the supply line )
I wanted to go ahead & replace both hoses. I was able to get a new
supply hose, but not a new return hose. The return hose was leaking
where the hose & the metal fitting come together. I purchases about 2
feed of bulk hose, cut off the fitting, used 2 hose clamps on the side
that attaches to the rack, & ran the other end of the hose up to the pump.
I have not
had any problems for over a year with it.
If you can not get at the fittings for the hoses on the rack, you can
drop the rack by disconnecting the 3 bolts that hold the rack in place.
Do not detach the connecting rods to the wheels. This will lower the
rack a little. You may also want to remove the oil filter. If you
still need the rack to be lowered even more, disconnect the steering wheel
connection. You do need to remove the screw, not just loosen it as it
engages into
a flat spot in the teeth. If you remove it, you will know what I mean.
Have fun & a good trip.
John Himes
88 XJ-S 98K Miles
Date: Mon, 28 Oct 1996 12:13:50 -0800
Subject: Vapor Lock
OK, a silly question:
What exactly *is* "vapor lock"? What causes it? Does getting it indicate
something needs attention? What steps can be taken to prevent it from
happening?
Actually, I'm wondering if my fuel problems about a month back might have
just been "vapor lock". (It was about 100degrees outside, during a long
highway run and my motor just sputtered and lost power). Acted very much
like it was fuel starving. Letting things cool, adding STP, filling my
tank, and cleaning out the fuel filter made the problem go away.
Thanks-
Ryan
Date: Mon, 28 Oct 1996 12:11:26 -0800
Subject: Dead Cylinder/ Clicking Noise.
I've got a problem with my series II XJ6. The problem started as a
clattering somewhere in the cylinder head. With a mechanics
stethescope, I traced the noise to the exhaust side of cylinder 4. Now
for the scary part: removing the spark plug wire for cylinder four
causes no change in slow or fast idling. Disconnecting any other wire
makes a significant difference. So, this cylinder is not firing.
Cylinder 4 checks out fine for compression (all cylinders are at 150.)
It is getting a spark-- I also replaced the cap, rotor, wires and points
and tried another plug on this cylinder. So now I'm wondering what I
should do next. In trying to rule causes out, I'm assuming that: a
dropped valve seat or stuck open valve would cause a loss of
compression and a tappet giude problem would not affect valve timing?
(I've had the cam cover off and have not found anything abnormal.) I'm
stumped here.
- -Pessimist: "This ship is sinking." -Optimist: "This ship is half full."
Curt Onstott - Windows/DOS/PC Specialist - Information Services -
Oregon
State University. - (541) 737-1483 - Office: Kerr 217
Date: Mon, 28 Oct 1996 15:13:35 -0500
Subject: Jags
Looking for information on these cats - contemplating buying one myself. Got
this address from TJWal@concentric.com, a buddy of mine.
Help!!
Steve Stephenson "FlyinSteve@AOL.com"
Date: Mon, 28 Oct 1996 15:14:16 -0500
> Regards,
> John Gardner
>-- End of excerpt from John Gardner
Gran Turismo sells a high pressure oil pump (120psi) for the 6cyl engines.
They say that it is good for aggressive street driving/racing where cornering
inertia pulls oil away from bearings etc. Problem is that some of the racers
say that it does indeed suck up a lot of h.p. - like 25-35 h.p. or more. Also,
Donovan Racing had problems with the unit sucking the occasional shot of air -
w/bad effect... Earl Gibbs said that they had similar problems but found a fix
for that problem (he is not saying how). He says that for even a very serious
street car the stock pump is sufficient.
The Ford guys here say that lower pressure/higher volume is a better than
high pressure/lower volume. Take that any way you want...
Mark McChesney
...yes, I love you just the way you are, now put this wig on.
Date: Mon, 28 Oct 1996 15:15:23 -0500
Subject: XJS power steering
My 1991 XJS exhibits the following strangeness:
At low speeds (especially parking lots) the power steering seems to
occasionally lose a bit of power. It feels as if all of a sudden, just for
an instant, the power is reduced in half.
This effect is particularly observed when you are turning the wheel one way
and just begin to turn it the opposite way. Almost as if a valve of some
sort sticks just for an instant.
There is adequate power steering fluid.
There are no squeels from a slipping belt.
But, there is a small power steering fluid leak from the rack itself.
Any ideas??
Thanks
Julian Mullaney
Date: Mon, 28 Oct 1996 13:25:01 -0700
Subject: E-type frames
Mark, I'm beginning to think that every E-type owner on this list has a
70-OTS! It would be interesting to take a survey and see how many
owners on this list have 70's. That's what mine is, too. Right now
it's stripped to a rolling chassis, getting ready to have some dings
taken out a a fresh coat of paint.
You're right about having to learn everything you can about the car (and
what to call it). I've talked to salepeople at all of the major Jag
parts suppliers that didn't have the foggiest idea what I needed. Then
there are others that you can describe the part to, and they know
exactly what it is.
The first thing that I did when I got mine was to purchase reprints of
the original service and parts manuals. They are worth their weight in
gold! Good luck on your car! GWC
Date: Mon, 28 Oct 1996 16:20:32 EST
Subject: XKE engine/trans
COMPLETELY rebuilt, unused, stored warm for 15 years,
a JAG 3.8 litre triple SU carb, 1967 engine-clutch-transmission!!
New parts, seals, clutch, etc
The block is marked U4 15-1-62 3
The trans is marked EB
8320
JS
The cylinder head says R 5683-9
with K35 on the top rear cylinder head
If interested(!) reply here (gaid@sunynassau.edu) or call
Charles in New York at 516-549-0356
Price negotiable, will take responsible,
resonable offers only.
Date: Mon, 28 Oct 1996 11:56:54 -0600
Subject: Carbon canister etc.
Woah!!! Something is wrong here. 9MPG is terrible. No jag I ever owned
did that bad. You have other problems that should be taking your time. My
XJS gets better that 12-18 MPG and the XJ6 gets 18-24MPG and the older jags
got even better milage.
Anyway, burning those excess fumes, which is what the canister is designed
to do for you, would increase your fuel milage, though I doubt that you
could measure the difference.
JIM I.
"Prefiero morir de pie que vivir de rodillas."
Gen. Emiliano Zapata
1879-1919
Date: Mon, 28 Oct 1996 13:32:14 MDT
Subject: Re: Nickasil bores ..
>engine. There was quite a thread over on the BMW Digest over this
>notification
Aha ! As I suspected, this new technology is not all its cracked up
to be ! Some folks never learn from others mistakes. As I said
before, its probably very vulnerable to real world contamination just
like EVERY OTHER bore technology. I caught some flack for saying it
the first time, so I'll say it again. Sounds like a product of over
eager engineers with too much experience in the books and not enough
hard knocks and experience in the reality of the machines. I too am
an engineer but I am a constant critic of this type of "laboratory"
engineering mentality. To be sure, these types of technologies have their place
but should never be tried on production vehicles before they are well
proven on the race track. The financial risks are way too high
otherwise. And as Kirby says "I I were running the place" .... oh
well.
Kind Regards,
Jim Cantrell
Date: Mon, 28 Oct 96 15:35:19 EST
Subject: Re: Chevy Lumps in XK8's
Subject: Chevy Lumps in XK8's
Author: palmk@gcn.scri.fsu.edu at WG-RAL-SMTP
Date: 10/27/96 7:23 PM
> Knowing how utterly disconnected Jaguar is from their market these
> days (see their lame video, etc.) it's entirely possible they have
> decided not to bother fielding a factory team.
I kind of agree with this too, but then again I think that we (the
folks on this list) arn't really Jaguar's market at all - Jaguar's
market is folks who are willing to drop $70K US for a new Jaguar -
not many of us did that. I'm not sure that I know what kind of mind
set those folks have - maybe the video is just what they are looking
for, So far XK8 sales have been pretty brisk according tothe local
dealer here - of course there was some pent-up demand - it will be
interesting to see how the car performs from a financial point of
view.
- - mclaus
Date: Mon, 28 Oct 1996 13:48:12 -0700
>Phil Bates:
Not complex?? Each tank has two vent pipes that go up the car into a pillar
to a thing that has three pipes, one of which goes to the other side, from
the back of the car to the front of the car, to a carbon canister out to
atmosphere under the front fender or to the intake manifold. And this is
not complex? The piping alone must weigh 5-10 lbs.
AH HA!!! Here is the deal, I have an XJ12C, not an XJ-S or XJ-SC. It is a
virtual pick-up truck, two tons, two tanks, etc., but a lot more sporty.
The top of my tanks does have one of the vent pipes, and there is a distinct
top of the tank.
>> in the car.
>> cars are sitting.
>improve anything.
Here is the real reason why. Someday (in my dreams) I would like to have
this car professionally turned into a convertible. With a convertible top,
those pipes can't fit there. So, while I have some interior out, I thought,
if that is going to go, it should go NOW. I decided to look into their
functionality, and see if I really need them. When I realized that only
emmission controlled cars have the pipes, I said no, I don't really need
them, my air pump is already gone, my egr valves are gone, and I can't get
new ones, and I don't have catalytic converters. Why should I keep this?
... just one more silly system to fail. But if there is a really good
reason to keep them, I would.
Phil Bates
58 MGA
67 MGB
75 Jaguar XJ12C
Date: Mon, 28 Oct 96 16:09:16 EST
Subject: XJ-S beauty v.s. XK8 performance
Someone recently wrote about how great they felt the XK8 was after the test
drive.
I spent almost an hour driving an XK8 convertible on Saturday. It was a
fantastic day with perfect weather and I got to drive pretty much as hard as I
wanted. The top was down, and we received a lot of envious looks. I enjoyed
myself immensely. And I have to agree, the car's performance is FANTASTIC.
It accelerates better than my XJ-S
It handles better than the XJ-S
It is more fuel efficient than the XJ-S
It can go faster than the XJ-S
It can stop much more quickly than the XJ-S
It is safer than the XJ-S
The list probably goes on and on...
But I gotta say - I just like the XJ-S better. I admit to some prejudice -
after all I own one, but I guess performance is only part of the reason we love
Jags. If you can't love the way a car looks and feels, then performance may not
count for so much - and if you do love the way it looks and feels maybe you can
overlook a lot of performance shortcomings.
Just one opinion from a misty eyed XJ-S romantic....
- - mclaus ('93 XJ-S Convertible)
Date: Mon, 28 Oct 1996 15:18:52 -0600
Subject: Oil Pressure overage in E Type
I dont think the oil pressure would have to be higher to use tighter bearing
clearances in fact I could be lower since there would be less cross section
for the oil to flow through. The bearings ride on a molecular film of oil
and the pressure does not make any difference. The main thing is flow to
remove any wear products. If you reduce the cross sectional area of the
flow by decreasing the clearances, theoreticaly you could use lower pressure
to maintain the flow!
I think the guy was having success but didnt know why.
JIM I.
1879-1919
Date: Mon, 28 Oct 1996 15:18:26 -0600
Subject: Snake Oil is too cheap to not use.
Ok, I dont know from shit when it comes to oil and lubricant chemistry, but
I have 48 years experience since buying my first car at the age of 12.
I have used the Teflon additives ever since they appeared on the market.
Lubrilon was the first one then Metalon and then a dearth of competitors.
Maybe its because I take better care of my cars than most people, but maybe
its the additives. I dont know the full answer, but my cars usualy run
200-300K before the head has to be removed (I have never had to remove the
head, so I dont know the exact milage). I use a Teflon additive every
40,000 miles. At 16$ a treatment that comes out to about 25 miles to the
penny. I spent 160 pennys for the gas used in that same 25 miles. To me,
thats cheap insurance and I am afraid to test any theory that it doesnt work
when I get 180,000 miles on an Escort 4 banger (sold the car still running
fine, who knows how far it has gone now and those sidewinders are supposed
to be disposable engines), 250,000 on a Mercedes 220D (changing the oil
only every 15,000 miles!!! Sold it still in top running condition), 230,000
on a Mustang 200ci six (the daughter threw a rod after driving 45 miles with
the chank case empty at highway speeds). My current XJ6 has 118,000 miles
on it (and they say the 4.2 is only good for 90,000) and I still race the
thing at up to 120MPH.
So, snake oil or not, I will use it, its awfully cheap. I spend much more
on gas or oil or even antifreeze over the 40,000 mile period that each quart
of snake oil covers. Ill bet I spend more on wax to polish the car in
40,000 miles than I spend on Metalon and I know the Metalon does more for
the car than the wax does.
I think if you will look at your average cents per mile cost of operation
which is about 10 to 20 cents and look at the cost of a quart of Teflon
aditive at .04 cents per mile you can see that it does not add substantialy
to your cost and it sure cant hurt to have something slippery in your crankcase.
JIM I.
1879-1919
Date: Mon, 28 Oct 1996 22:18:25 GMT
Subject: Re: XJS Beauty
On Sun, 27 Oct 1996 21:31:32 -0800, you wrote:
>After reading the on-going debate about the outdated styling of the=20
> =20
>1. I think some people on this list are suffering the effects of too =20
> much solo sex.
>2. I'd rather push my XJS than drive some other peoples cars. (and I =20
> have!)
>3. For the puny price most of us pay for a used XJS, you can still get=20
> big time access to women who would not normally give you the time =20
>4. There are no ugly Jaguars. =20
>5. A Jaguar is a prestige possession. It says: I have this expensive =20
> brand of auto, I can afford to put money into it, and it still =20
> A satisfied XJS man
> Gerald Foster
>89 XJ40
>86 XJS
No flaming from here Gerald. I'm not sure I agree with all your
reasons, but the conclusion is undisputable. My XJS allows me to
enjoy all the simplicity I miss in today's "high tech" automobiles and
still have the luxury of enjoying the benefits of a new car warranty.
The XJS's lines have been and remain absolutely distinctive in a world
of lets share sheetmetal look alikes being produced by the majority of
todays automotive manufacturers.
Jonathon Shevelew
'95 XJ-S 4.0L Convertible
'93 VDP
'96 Explorer (something for the kids to dirty up)
jonathon@protech.com
Date: Mon, 28 Oct 1996 15:27:23 -0600
Subject: Restoration Process
I'm getting ready to begin the restoration of my 70 E-type. I wanted to run
my general plan by everyone.
Condition:
*Body
- --Needs new paint. Old blistered by DPO covering car with black plastic in
California summers. I plan to change to XK8 dark blue.
- --No visible rust except floors and inside trunk near roof attachment point.
Oh, and the battery tray.
- --Some dings. RF fender crushed a bit by latching mechanism due to poor
bonnet alignment.
*Interior
- --Needs new dash cover
- --Seat leather good but seats need rebuilt (reclining weird). I want to
change them to tan anyways.
- --Door panels need replaced
- --Carpets need replaced
- --Top needs replaced
- --Steering wheel needs refurbished
*Engine
- --Leaks oil like a sieve
- --Good compression. Head rebuilt a couple hundred miles ago
- --Some leakage evident (filled with orange permatex) around one of the
inboard head studs. Not sure what it is or why it manifests itself there.
- --Needs new distributor (planning on Mallory dual-point).
- --Needs new clutch
Brakes and suspension recently professionally rebuilt
THE PLAN
I figured pull the engine/tranny and get all that done professionally. I
don't have time, experience or inclination to get inside motor. Will consult
with local KC Jag club for recommendations.
While drivetrain out pull interior.
Have body stripped, repaired (with metal) and painted.
Have chrome redone.
Install drivetrain
Install interior
I'm planning on carefully cataloging all wire connections in the computer
and using both still and video photography to record connections and such
with corresponding computer logs of the picture frames and video timestamps.
Anything I'm forgetting? Are there any good books on the PROCESS of
restoration? I have a nice book that I got from Hal showing what the E-types
are supposed to look like but I'd like a book on how to do the restoration.
Thanks,
jvr
End of jag-lovers-digest V2 #472
id <DAA04396> for jag-lovers-digest-out; Tue, 29 Oct 1996 03:45:58 +0100 (MET)
Date: Tue, 29 Oct 1996 03:45:58 +0100 (MET)
Message-Id: <199610290245.DAA04396@ekeberg.sn.no>
Subject: jag-lovers-digest V2 #473
Precedence: bulk
jag-lovers-digest Tuesday, 29 October 1996 Volume 02 : Number 473
Re: Seat Heaters XJ40 1987
'84 XJ-S U-Joints, Wheel Bearings, rear brakes
Re[3]: XK8 vs. V12
Corrections to Monthly List
Re: Vapor Lock
Re[2]: V-12 vs. AJ-V8
Replacing chrome head nuts for appearance only - '66 E-Type
[none]
Re: Vapor Lock
Lost issue
Re: 85 XJS ignition switch and power steering
Halloween ? SJX
Re: Jags
7" headlights for XJ6
Re: E-type frames
Re: oil pressure problem
Re: Re[2]: V-12 vs. AJ-V8
Re: Oil Treatment and more (No Jag Specific Content)
Oxygen Sensor
Re: Engine cuts out
Date: Mon, 28 Oct 1996 11:37:12 -0600
Subject: Re: Seat Heaters XJ40 1987
This is a Mime message, which your current mail reader
may not understand. Parts of the message will appear as
text. To process the remainder, you will need to use a Mime
compatible mail reader. Contact your vendor for details.
- --IMA.Boundary.767835648
Content-Type: text/plain; charset=US-ASCII
Content-Transfer-Encoding: 7bit
Content-Description: cc:Mail note part
And a jolly effective thermostat, too! Once the seat temperature reaches
the passenger pain threshold (pph), the passenger immediately removes
his/her seat from the car's seat. This breaks the circuit, causing the
seat to cool until the passenger can resume their seat, thereby making the
circuit and restarting the cycle.
Another triumph of modern British electrical design as interpreted by the
Prince of Darkness.
MikeC
Subject: Seat Heaters XJ40 1987
Author: dparnell@shlci.ca at Internet
Date: 10/27/1996 4:54 PM
<snip>
My Jaguar wiring diagrams show a thermostat on the drivers seat base, when I
took my seat base off I found this to be a pressure sensitive switch. Any
comments!!!!!!
Thanking you in advance
Derek
- --IMA.Boundary.767835648--
Date: 28 Oct 96 16:43:49 CDT
Subject: '84 XJ-S U-Joints, Wheel Bearings, rear brakes
After replacing the shocks on my '84 XJ-S I noticed a good deal of play
when I grabbed the right rear tire and applied vertical pressure. I
also heard a distinct clicking coming from the propeller shaft/tranny
area upon rotating the wheel. I sense that I have a combination of
rear wheel bearing and propeller shaft u-joint failure. I intend to
replace the wheel bearings, drive shaft u-joints, and propeller shaft
u-joints this weekend. While I am in there I will also rebuild the
rear calipers and replace the badly worn brake discs.
After dutifully reading Kirby's help book and the Jaguar shop manuals
(in that order) I have the following questions.
1. Is there a viable alternative to using the jaguar hub puller?
2. The diagram in the Jag shop manual shows a length of L-channel
being used to support the rear of a 4.2 engine accross the engine bay -
Will the same arrangement work for the 5.3?
3. What type of problems can I expect to encounter? The help book is
amazingly quiet with respect to these repairs.
4. Should I plan on replacing all the seals, etc. in the wishbones?
5. What have people used to drift out the bearing races?
6. Anyone in the vicinity of Bloomington, IN want some hands on
experience? I always enjoy company...
Thanks in advance for suggestions,
Robert Woodling
'84 XJ-S (no really...I bought it because I enjoy working on fine
machinery! ;-} )
Date: Mon, 28 Oct 1996 11:53:55 -0600
Subject: Re[3]: XK8 vs. V12
Actually, isn't it more accurate to say that they both are based on the
XJ-S? The XK-8 to a much smaller degree than the DB-7. The DB-7 is really
the old F-Type XJ-S derivative that was in development for quite a long
time, canceled by Ford and now restyled with gills and an A-M grill.
Since the A-M is much closer to its XJ-S origins than the XK-8, it may be
possible to stuff a V-12 into it. The DB-7 still has the basic XJ-S
bulkhead, engine location and front suspension.
The XK-8, on the other hand, has the basic XJ-S pan, but is significantly
different from the bulkhead forward. Amongst other things, it has a
completely new front crossmember. It is also a good bit shorter up front
than the DB-7. One of the obstacles to putting a V-12 in the XK-8 would be
the greater length. I wonder if the XK-8 can even take an AJ-6? (The
DB-7, of course, has a modified AJ-6 already.)
The new V8 is very compact. If the XK-8 was designed around it, as appears
to be the case, it may be difficult to fit a lot of other possible engine
choices. I wonder it there is an AJ-V6 in the future?
Subject: RE:Re: XK8 vs. V12, Nicosil
Author: TezFair@aol.com at Internet
Date: 10/27/1996 9:42 AM
<snip>
2. The DB7 uses a modified XK8 shell so a V12 won't fit.
<snip>
Tez
Date: Mon, 28 Oct 1996 16:22:47 -0600
HELP!!!!
HELP!!!!!!!!
Date: Mon, 28 Oct 1996 17:26:51 -0500 (EST)
Subject: Corrections to Monthly List
Jennifer:
New business number for John Farrel:
John Farrel, 4315 Murray St., Flushing, NY 11355 1-718-762-9071(Home)
NOS XK parts 1-516-454-7977(Work)
Mike
Date: Mon, 28 Oct 1996 15:50:06 MDT
Subject: Re: Vapor Lock
> happening?
Gasoline, like all liquids and solids, has a vapor pressure. What
this means is that if you evacuated a container and filled it with
gas and allowed it to come to its natural equilibrium pressure, this
would be known as its vapor pressure. This is caused by molecules of
the liquid freeing themselves and forming a gas. For gasoline at
least, the higher the temperature of the fluid, the higher the vapor
pressure since more molecules are being driven off of the fluid/gas
interface. So what the hell does this mean ? When gas lines are
heated, sometimes the vapor pressure is high enough to prevent fuel
flow. This is more common on the suction side of a pump than on the
pressure side. The "hot fuel line" can also be compounded by fuel lines
that experience a large elevation change within the vehicle since the
garvity head on the fluid can easily put the suction side of the pump
at or near the vapor pressure of the gasoline. Grades of gasoline
also have an effect since, at least in this part of the US where it
is cold, winter gas stocks are more volitile for easier cold weather
starting. I have found the majority of my vapor lock problems have
occurred during the spring warm weather when the winter fuel stocks
are still being sold. Vapor lock is a hard problem to fix since its
hard to see and understand. You simply have to be careful of
exposing fuel lines to hot exhaust and underhood heat. My XJ12C even
has a fuel cooler that runs the recirculating fuel through an
airconditioner line heat exchanger. I have heard that its imperitive
to keep the aircon system working properly to avoid vapor lock
problems. If you have this problem, I suggest looking for possible
hot spots on the fuel lines (like near the exhaust) or even a weak
pump. Good luck !
the upper portion of the fuel line experiences a
> Thanks-
> Ryan
Kind Regards,
Jim Cantrell
Date: Mon, 28 Oct 1996 18:45:29 -0600
Subject: Re[2]: V-12 vs. AJ-V8
Hmmm . . .
So, I guess that makes the top speed of an XK-E to be about 2.718282
mph.
MikeC
Subject: Re: V-12 vs. AJ-V8
Author: Jan Wikstroem <Jan_Wikstroem@acp.com.au> at Internet
Date: 10/28/1996 9:38 AM
<snip>
BTW, under the existing numbering system, the top speed of this car <the
XK8> is 8 mph...
- -Jan
Date: Mon, 28 Oct 1996 17:20:07 -0600
Subject: Replacing chrome head nuts for appearance only - '66 E-Type
I just bought an E-Type with corroded chrome head nuts, and would like =
to replace them with new. I have rebuilt a couple Jag engines, so I am =
somewhat familier with the problems I may encounter, such as cylinder =
head leakage, if not done properly. The local Jag dealership suggests I =
replace one nut at a time, using the factory tightening sequence, and =
torquing the full 70 ft/lbs at one pull, then re-torquing after the =
engine is up to operating temperature. A long time Jag mechanic =
suggested using the torque sequence to replace one at a time, but =
tighten each new nut to about 35-40 lbs. After all nuts are replaced, =
then tighten to 50-55 in sequence, then to 70 ft/lbs. Any suggestions =
from those with more experience in the area.?? The nuts are =
really rough looking, for an otherwise nice engine and car.
Date: Mon, 28 Oct 1996 23:39:24 +0000
Subject: [none]
Hi there people.
Talking about door locks on the series III XJ6. Does anyone know where the
relay for the lock mechanism is located?
Johann from Iceland.
Date: Mon, 28 Oct 1996 15:33:47 -0800
Ryan,
Vapor lock occurs when the fuel in the line "boils" and forms air bubbles.
Kind of like if you inject air into a vein, you'll get "vapor lock" which
can kill you. It prevents the gas from flowing. On some cars the fuel
lines are insulated or run where air can flow around them to keep them
cool. Years ago, GM ran into a problem with one of their models. It seems
a customer complained that every time she went to buy ice cream at the
local shoppe, if she bought pistachio, the car refused to start. GM sent
some engineering types to investigate, and they were able to determine that
it took longer for the shoppe to get the pistachio ice cream, and that
extra time allowed the fuel in the lines to boil, causing vaporlock. The
dealer re-routed the fuel lines, added some insulation, and her problem
went away. Lee
> From: Ryan Border <rborder@hpspls16.cup.hp.com>
> Subject: Vapor Lock
> Date: Monday, October 28, 1996 12:13 PM
indicate
> happening?
