I bought my Mark IV in parts and I don’t know how to install a spare wheel seat.
Any photos / advice on how to attach the spare wheel seat/casing to the body?
I have an element like in the picture and I don’t know how to fit it.
Yes, that’s correct, two long 1/4-BSF bolts through the front cross member and two long bolts through the rear cross member. I used big flat washers on them inside the tray, lock washers below with the nuts.
Tank sits on four rubber pads and at each side a metal strap over the top of the tank is bolted to the pillars that the pads sit on. The straps are about the same width as the pads and are made of brass.
The tank straps are in 4 pieces - fixed over the tank towards each end, and each long and short section is joined by a fixing bolt once the strap is located over the tank (see above photo).
@goodoldgrandad, @Peter_Scott
Thank you very much for your prompt reaction and information and great photos! They are very helpful. I like your idea of using additional felt pads.
I am a relatively new user of our forum and am constantly impressed with the willingness to help I meet. THANK YOU!
