I am looking for a replacement antenna for my 1963 MK2. The original antenna was a hand crank operated antenna wityh the hand crank located under the dash. The antenna looked similar to a power antenna without the motor. The originl was damaged during the body restoitation.
I would appreciate a lead on where I could purchase a replacement antenna if you don’t have one in great shape.
I am located in Georgia, USA.
Let me get back to the car to see if I can mount an electric antenna. The current setup has the antenna doing a right turn (from vertical to horizonal) which seems like it would make the operation somewhat difficult.
The electric that I have seen are mounted vertically without any bends. I need to see if there is room to mount an electric antenna.
Roy,
We had a break in the storms so I took a chance and dug them out.
They are too big for USPS Priority Flat Rate so I’ll need to use regular post.
Steve
That is bad. I mailed it on Jan 25th. I dropped it inside the Post Office in Buckhead as opposed to leaving in my mailbox.
I also dropped off a couple of packages that were delivered on the 29th.
Not sure what happened.
If it doesn’t get there in the next couple of days, I will either send you a replacement check or do a paypal transfer if that works. For Paypal, I would need your email address.
Please email me on Wednesday and let me know if you get the check.
Again, I apologize but not sure how to get around Post Office issues.
Roy,
Another Jag Lover has inquired re the power antennas.
If you are interested in passing on one of them I can give you his particulars.
Steve
Just came across this email (from weeks ago). FWIW, the “person” who you decided to send the antennas to NEVER made ANY attempt to contact me. Not surprised! I was 99% sure he would keep both OR sell both OR sell one!
