I have a “check engine” light and found code of PP69 on my trip computer. I have found several sources and all seen to describe different problems and “fixes”. If anyone has a copy of the codes or where I can get a list of codes from PP11 thru PP99 please send them to me are answer this post. Thanks, billwhis1
It’s FF69 probably. If you’re in New England, I have a 90’s Jaguar PDU dealership computer at my shop.
Code
List:
https://www.jaguarforums.com/forum/xjs-x27-32/fault-codes-tables-130456/
John,
You are right it should be FF69 not PP69. I would like to correct my post but I do not know how to go about it. Sorry, however my understanding of code still exists and I am confused and don’t know how to correct the problem because I don’t know how. Thanks for your help.
Basically the code means your battery is getting old,
Hi William, there should be a small pencil icon on the bottom right of your original post, this is the edit function.
Motorman,
Thanks for you reply, it is the best information I have been able to get.
Billwhis1.
Thanks davidsxj6. I have received several replies already.
Billwhis1
