The lamp, or are there 2-3, used to work, but is now dark.
How do I access them? There are 2 screws holding a cover of some sort. Simple as that?
Yes there is one little lamp behind there.
Same as on my Xk140FHC auto.
Thank you Peter.
But where is the bulb???
And what is the small steel ball doing, at the bottom of the left side, on the second picture??
(The car has been converted to the T700 gearbox, but dont know if anything was changed up here, by the gear selector)
The is a lamp in the black thing just behind the white arrow.
I see now that I am missing that cover, my lamp is exposed.
That steel ball has to sit in a hole with a spring, for the idents of the gearbox selections
Thanks. The bulb was loose!
Dont see where the ball would go. Might not bevapplicable with my new gearbox
