I have seen the Asteriod wheels on the early Coupe and someone in an earlier post advised the wheels would not fit.
Now that I have the wheels they indeed do no fit over the hub. Any advice? Looks like I will need to machine out the center of the front wheels to clear the bearing carrier Must be some other way. As I have seen these wheels on several early coupes.
No other way i’m afraid , if there is enough metal to be machined a good wheel shop can do it easily. What size are the rims , you may have to roll the inner guard lips (especially the rear ) for clearance as with out they will scrub.
Paul , Depending on the offset , spacers i think would not be an option , they would push the wheel further toward the wheel arch , i would expect . could be wrong .
To all who have responded. These are 18 X 8 stock Jaguar XJR wheels called “Astrroids”. Spacers are our as it would need to be about 1/2” thick and would require removal of the hub to install longer studs and would push the wheel and tire out past the fender lip on the front. The rear wheels fit beautifully with 235/50/18 tires. Plenty of clearance all around even if I lower the car 30mm.
So, the Asteroid wheels are installed. What I had to do was machine out the center opening to 2.45" to allow the wheel to slip over the stub axle. I then used a set of fake knock offs and milled the adapters to fit the wheels.
No problems. I had to open the inside of the adapter to fit over the hub and use epoxy to mount in the front wheels since there was too little “meat” left to use the setscrews.
Are there any pics or part #s for the adapters? Picking up some asteroids for my series 2 tomorrow. Will I need anything other than the machine work to bolt them up?
I don’t have a photo of just the adapter. I have attached the photos I do have I bought the set on eBay and have included the ad. I think this might be the place I got them, but it is the same set for sure. I remember what I had to do was cut down the depth of the front adapters so they would not hit the bearing carrier in the front. That left nothing to for the set screws to bite into, so I JB Welded them in place. The spinners thread onto the adapter and secure with two set screws. All four tires are the same size, 245/50 18R(I think).
Hope this helps.
DAVID A. JUDD
3440 Pocahontas Drive
Lake Havasu City, AZ 86404
951-640-6188
If the guys from back then are still here, I would ask them something.
Is it the case that these rims fit in the back but not in the front?
The wheel hubs are all the same as far as I know.
The diameter of the hubs are 73.9-74.1mm (±1mm) and the rims also have this diameter - so 74mm.
And still something has to be done at the front, even though all hubs are the same?
I think you are mistaken on the hub size. As I recall the hubs are smaller and the fronts had to be enlarged the about 2.25”. I did that on mine when I mounted these Asteroids
Either way you are correct in saying the later wheels will fit on the rear hobs without modification but the centers of the fronts will have to be bored out to about 2.5”
if you say something needs to be drilled out, then it will
I just don’t know where or how to drill another 63mm (2.5 inches).
then I would already be in the holes of the wheel nuts
It may be because there is still this castle nut at the front, but you can also swap the normal rims from the back to the front.
I ask because I want to drive these rims legally and the TÜV (that’s what it’s called in Germany) has to give its ok
however, drilling on rims is strictly forbidden and that’s why i try to find out beforehand whether and which problems i will face
i’ll confirm the opposite as well, later rims are metric 70’s models are imperial, so lucky me here in Sydney AUS/ i scored 5 pepper pots for $AU150 form a guy who was trying to fit them on a 87 canadian import…people - people - people - always ask questions before you shoot ya money away…XxX, take rim to a wheel rim specialist & even better, take a hub you want it to fit on with you.
That’s exactly what I did
I have a sawn off hub here
I’m going to Austria with it now and testing it out
guys, what crazy hobbies we have, right?
but i wanted to make a short trip to austria anyway…
David, the dimensions of your tires are 235/50
I’m thinking of 225/45 for me.
