As far as I can tell they are required to stop only one thing… My inspection sticker from expiring…
Yep: that is precisely one valve too loose.
Again, nothing to really worry about, but they all need to be checked to make sure none are too tight.
Tight can cause VERY expensive problems.
Hi Bill,
You do have a set of tappet bucket hold downs don’t you, that’s the only thing I can think of that would be ‘mission critical’.
Cheers,
LLynn
See? There is a technical name for PFM!
pure effing magic😎
All - to revive this topic I wanted to ask where the Carb ID Tags should sit in relation to washer numbers 30 & 31 in Nicks picture? If the ID Tags are in the wrong position could it cause back pressure in the float bowl? - I’m getting float bowl seepage after installing the Carb ID Tags between items 31 and 29 as shown. Fresh carb rebuild Fall 2019 - but the vented washer is not present either . . .
Thanks, Dave
Tag goes above washer 31. That washer seals the top of the banjo overflow fitting. Washer 30, which is a serrated fiber design is critical to proper functioning, and seals the lower face of the banjo fitting, while allowing the float bowl to breathe (through the overflow fitting) and the overflow to function.
Bill thanks! I did confirm I do have the correct serrated washer #30 and washer #31 per carb bowl. Will reassemble with washers in original orientation and snug up again. Engine is running nicely will recheck for float bowl seepage - I do not see any cracks in bowl lids and have been careful not to over-tighten the tube nuts . . .
Thanks, Dave
Maybe time for a rebuild?
One of my favorite threads on this forum explained that carburetor was french for “don’t touch me”…
Everything is running really well at the moment - including getting 17 mpg - so I’m very reluctant to touch anything…
Bp
Bill yes indeed! - an interesting post here suggesting the stacking of ‘two’ AUC1928 serrated washers per carb float bowl. Nothing to do with float bowl leaks however . . .
