Hi, I bought a 1972 XJ6 in the fall and it came with these seats (attached). I know these are not factory seats, but are they Jaguar seats?
The front mounts line up perfectly with the factory seat holes. The rears, however, required an adapter.
It even has the little lumbar support hand-pump.
Might be a long shot, but it would be great if someone on this forum could identify which car these seats came out of! I do not believe they are aftermarket, but I could be wrong…
I honestly would have never guessed these were Mustang seats. They look like they belong in an XJS.
And they fit great! Front studs line up with the factory floor holes. The rears use an adapter bracket. It looks like an aftermarket bracket that had multiple bolt hole locations (not some home fabbed piece). I would assume this bracket is readily available for these Mustang seats to fit into any car.
I’m actually still trying to figure out the color myself! I’m not sure if the rear bench was dyed to match the Mustang seats, our vice versa. The interior is “supposed” to represent the factory Dark Blue
Here is a pic of the plate install. Pretty simple device, really:
This is the interior in its current state. correct seats. Everything has been properly dyed the factory Dark Blue to match. New door panels from John Skinner match perfectly.
