Anybody familiar with this kit? The lenses look normal, not strange like the LED sets I’ve seen.
I like the fact that they fit right on this forum! Not clear if you have to use their lenses or not.
I’m working my way through 5 different headlamps, I doubt the bulb will fit inside the bucket.
I’m going to try to contact them tomorrow and get some dimensioned drawings of the assembled unit. I’ll share them with you when and if I get them.
No personal experience, but I’ve been tracking reviews of LED sealed-beam replacements for several years now.
I’m waiting for somebody to make a legal headlight with good light output at an affordable cost. They don’t exist yet.
I probably go through this about once a year scouring the reviews by actual users and people who actually measure light output, and the result is always the same - there are only two manufacturers who don’t make garbage.
TruckLites are the “good enough” LED headlights and they run $500/pair
JW Speaker are the only LED headlight without any significant deficiencies and they run $700/pair
I had looked at hundreds of listings to find an LED replacement that would fit and was cheap. I found one for a motorcycle that has been great but no longer available @ $15. ea. The one pictured looks too tall at base to fit as most are.
Glenn
John, I have been looking for a set of LED headlights for my SII “E”. the problem areas are …Is the reflector shape designed for this particular bulb…if not then the beam could be illegal ( which is why some adverts for LED headlights specify …Off Road use only ! ). Is there room for the bulb, given that you have a finned appendage designed to dissipate heat from the bulb .I think the only safe way forward is to find someone who has actually used them!! So your post to the forum may unearth some DIY info!
It’s their designed lens and housing and their bulb so if they did the engineering right that wouldn’t be a problem.
That’s exactly the potential problem I see and why I asked if anyone has experience with the setup.
IIRC most cars I’m familiar with that use the two headlight system had scads of space behind the housing compared to the E-type.
A friend of mine installed NoveStar GT6 bulbs in his S2 almost two years ago. At one point, we went out on a dark road, and put his car next to my S1 with modern Halogen bulbs. The difference was night and day - his were MUCH brighter, and threw a MUCH longer, whiter beam. Someday I’d like to do the same to mine. Zero problems with fit - they require no more room than the original sealed beams.
Bought from here: http://www.haloheadlights.co/
Ray L.
Interesting Ray. What headlight body/lens did he put them in?
John,
Don’t know, but they came from the same source. They were very helpful in picking something that would fit well, so I’d contact them and ask.
Ray L.
I’ve tried several of the latest offerings from the far east. None of the H4 bulbs I tried produced a dipped beam with a sharply defined cutoff. Some had a dipped beam that was as generously spread as the high beam, such that they would fail a UK MOT test. Sure they were bright, and made very white light that made the halogen look yellow by comparison. All that had cooling fans (ie the brightest) fouled the S1 headlamp bucket.
I’m still looking for a bulb suitable for a S1.
Ray
Finding a set of LED bulbs to fit the S1 is almost impossible because, unlike the S2, the bowls have the angled flat back to clear the tyres.
My solution was to fit relays in the bonnet with a high capacity feed from the battery/dynamo. This is what the re-worked lights look like on the road, before followed by after (count the 9 metre white lines and 3m gaps as a quick reference of performance):
Dip before:
Dip after:
Main before:
Main after:
Photos don’t capture the full glory but suffice it to say I just wanted to keep driving the car that night it was so good. Give it a go - you only need a couple of $2 relays, a fuse and some wire and the lights are now as good as my LED equipped Range Rover Sport. Simple science - light output drops dramatically with voltage and when you measure the voltage at the headlight (which has losses due to main switch, dip switch, fuse, wire run and bonnet plug) it is typically less than 12 volts which means bulb output is about 67% of what it would be if there were 13 volts at the terminals.
That’s an impressive difference for the cost well done that man.
Indeed, and when I linked to a company—and lighting expert—who asserted exactly that, I received pushback.
Science rulez!!
Indeed Paul, and Science also says it is pretty pointless trying to get LED headlights to work efficiently in the E-Type as the reflectors are not big enough. LED headlights are all about the volume and focus of light rather than the intensity which is why all modern cars have huge headlamp housings.
I can provide step by step instructions on adding headlamp relays to the E-Type if anyone is interested. Takes about two hours and everything is hidden away.
I do not think that is necessarily true: There are quite effective LED headlights, that I have seen, on a lot of OTR trucks, and a few cars, that are not significantly larger than a standard 7” headlight.
However, the eensie bucket of an E presents an issue.
Since when would that be the case? Sure an led lights less bright on a larger area so different reflectors make sense. But I have yet to see a modern car with 20“ reflectors. Cooling is important with LEDs, and they need less power so they don’t need wires as good as halogen.
I prefer warmish light. If LED, it should match or be close to the color. Hotter halogens last longer than when dimmed, by the way, so the rewiring might have additional benefits!
Morning David (afternoon where your at I’m sure),
I’ve been thinking of doing this so would appreciate your instructions when you have a chance/time.
Cheers, and thanks in advance,
LLynn
Several people have asked me for more explicit instructions on how to do this modification so here you go.
You will need from an Auto electrician shop:
Parts
3 metres PVC 28/.30 17 Amp cable blue/green
1 m PVC 28/.30 17 Amp cable black
1 m PVC 14/.30 8.75 Amp cable black
1 m PVC 14/.30 8.75 Amp cable blue/red
1 m PVC 14/.30 8.75 Amp cable blue/white
1 m PVC 14/.30 8.75 Amp cable red *
1 m PVC 14/.30 8.75 Amp cable red/green *
1 m PVC 14/.30 8.75 Amp cable red/white *
2 x 20 Amp In Line Waterproof Fuseholder (one fuse per headlight for safety)
4 x Standard Blade fuse with built in LED 20 amp (two for spares)
A selection of bullets, sleeve connectors and spades.
2 double contact 12V 30amp SPST Relay
NB: The cables with a * are optional but do allow you to extend the wiring for the indicators/side lights to make a neater job.
The Relay’s:
or:
Pins 85 & 86 - relay coil; switches relay when fed 12v (your existing headlamp power feeds are used to operate these)
Pins 87 & 87A - common contacts, one per headlamp (your existing wiring to the headlamps go here)
Pin 30 - connects 12v direct from battery to 87 & 87A when relay operated - the headlamp circuit (new wire goes here)
Alternatively you could use a pair of fused relay’s to simplify the installation:
Wiring diagram:
Procedure:
- Disconnect the battery earth
- Remove headlamp cover and sugar scoop from nearside (L/H) of bonnet.
- Attach the two relays to the headlamp diaphragm. You can use at least one existing bolt but you may need to drill a hole for the second relay. Label the relays ‘Main’ and ‘Dip’ for easy identification later.
- Disconnect the following headlamp harness wires from the 10 way connector located on the headlamp diaphragm - blue/white x2, blue/red x2, black x2 and set aside. These are the bundled harnesses which run to the headlights, not the ones from the multi plug/socket - leave the latter connected to the the 10 way.
- Make up two 12" jumper wires each with a bullet on one end and a spade on the other using blue/white and blue/red 8.75amp cable
- Connect the blue/red wire spade to pin 86 on the ‘Dip’ relay
- Connect the blue/white wire spade to pin 86 on the ‘Main’ relay
- Connect the bullet of the blue/white wire to the blue/white on the 10 pin connector
- Connect the bullet of the blue/red wire to the blue/red on the 10 pin connector
- Make up two 12" jumper wires each with a bullet on one end and a spade on the other, both black 8.75amp cable
- Connect a black wire to pin 85 on the ‘Dip’ relay. Connect a black wire to pin 85 on the ‘Main’ relay
- Connect the bullet connector of each black wire to spare earth connectors on the 10 way
- Reconnect battery and test relays. You should hear them click with the headlight switch on and operating the main/dip switch.
- Disconnect battery
- Cut off the bullet connectors on the two blue/white and two blue/red headlamp wires you set aside earlier. Replace with spade connectors
- Connect both blue/white spades to pins 87 and 87a of the ‘Main’ relay
- Connect both blue/red spades to pin 87 and 87a of the ‘Dip’ relay
- On each waterproof fuse holder attached a spade connector to one end and a bullet connector to the other
- Connect the spade end of one fuse holder to pin 30 of the ‘Main’ relay and do the same for pin 30 of the ‘Dip’ relay. It does not matter which goes where as they are going to a common supply
- Connect the bullet end of each fuse-holder to the red/yellow on the 10 way. This is the unused ‘Fog-lamp’ wire and nothing else should be connected to it. Check to make sure the red/yellow goes back to pin 6 on the bulkhead multi socket - someone could have messed with the wiring!
- Make up a 12" jumper wire using black 17amp cable with a bullet on one end and an eyelet on the other
- Remove a bolt from the bonnet area, make sure it is clean and attach the black wire eyelet. Use petroleum jelly or similar to ensure there will be a good stable earth connection. Make sure the bolt is tight.
- Connect an ohm meter between the bullet of the black wire and the battery earth terminal. You should have a reading of no more than 0.4ohms. If it is higher you need to select a better earthing point or remove paint from under the bolt
- Connect the bullet end of the black wire to a double sleeve connector.
- Connect both black wires from the headlamp harness you set aside earlier to the double sleeve connector
That is it for the headlamp bonnet area but leave open for the moment until you are sure everything works. Next the main heavy duty headlamp feed.
- Check the battery earth is still disconnected
- Release the bonnet plug and remove any cable ties to allow you to extend the harness as far as possible outside the engine compartment
- Remove the rubber cover and/or release the socket from its housing.
- Unsolder the red/yellow cable from pin 6 and cut back
- Thread the blue/green 17amp cable down the plastic sleeving of the harness and solder to pin 6
- Reassemble the plug and re-attach to bonnet. Use petroleum jelly on the contacts to ensure low resistance
- Run the blue/green cable alongside the existing harness attached to the near side frame to exit behind the battery adjacent to the live battery terminal.
- Cut the blue/green cable to length and terminate with a suitable size eyelet.
- Connect eyelet to live side battery post. Use petroleum jelly to ensure good contact. Tighten well
- Re-connect battery earth and test o/s headlight (the nearside will not yet be connected) for correct main/dip function. Make sure the nearside headlamp connectors you insulated earlier are not touching anything!
- Test the headlamp wiring by using a voltmeter between black and blue/red (dip); black and blue/white (main). You should see 12v on each when switched.
At this point you can go ahead and replace the sugar scoop, bowl and headlamp although you may now want to consider if the re-wire has left anything under any strain and everything is tidy. This is where those wires I highlighted with a * (above) come in handy - they allow you to extend the side/indicators with jump wires and sleeve connectors. You also want to make sure you can reach the fuses from the bonnet mouth in case they ever blow. Use cable ties to support the wiring and sleeve connectors.
This was my final wiring:
Dedicated earth on right hand side; red, green/red, green/white bundle in centre is the side/indicator extension loom I made up to allow more room; standard 10 way connector on left; I replaced the red/yellow ‘fog lamp’ wire with the blue/green 17amp wire but it is not necessary to do so given the very short length; not shown on this picture but I also added a jump wire between the loom earth on the 10 way and my dedicated earth point; I used ‘piggy back’ connectors on the relay earth’s to reduce wire clutter.
With the L/H headlamp back in place check the operation and beam alignment before replacing the cowl (on an S1). This upgrade will work on both +ve and -ve earth vehicles and applies to all series E-Type’s. Go out and test at night where you will find the dip beams are now as good as the previous main beams and the main beams are as good as a modern vehicle. Total time spent - about 4 hours.
Notes:
a) You can use any colour of wiring you have lying around but it may make fault diagnosis difficult and really confuse a garage or the next owner. For the cost of the cable it is worth sticking to standard colours.
b) Dismantle the 10 way connector (just remove one screw and loosen the other to swing the cover out of the way) if you have the time. The spring connectors can then be removed individually and cleaned to ensure a good contact. Reassemble with lots of petroleum jelly.
c) I chose blue/green for the 17 amp feed because that colour combination in not used anywhere else on the E-Type.
d) If your headlamps are looking a bit dull try washing them in Fairy liquid inside and out. Rinse well in warm water and leave then to dry thoroughly before reinstalling.
e) Only headlamps that will fit the S1 are the Wipacs or Lucas units. For the S2/3 you have the choice of Cibie’s or the Crystal polycarbonate headlamps for even better light
f) For even more light fit a pair of Osram Night Breaker Plus or Philips X-treme Vision + 100% H4 65/55w bulbs. They cost about $30/pair but are very good.
g) I found it was easier to connect up the relays if you left the securing bolts slack to allow access. Don’t forget to tighten them afterwards!
h) Apart from the blue/green wire going to the battery post there is no evidence of the modification. You could tidy that up on the 4.2 cars by connecting the blue/green to the bulkhead terminal post instead.
i) Check the alignment of both headlights - you will be amazed how much better your forward vision will be if this is done correctly:
The instructions may seem daunting but I decided to document each step so anyone can follow the procedure without head scratching. The instructions and wiring apply to both +ve and - ve earth cars. Angus Moss was my instruction guinea pig and he has now done several cars by following the steps, all without problems.
Any questions, just ask.
