Left rear caliper dragging on 1995 xjs
Welcome to the forums, sounds like you need to take both calipers off and clean them up, you will probably find the piston is seized/frozen in the bore. Always do both sides when working on suspension or brakes.
Bleed your brakes. X
If bleeding the brakes fixes a sticky caliper, I wouldn’t recommend driving the car until you identify and rectify the problem.
