The 1990 to 1997 3.58:1 HU15 will all fit. The only difference are a few bolts or studs that can be swapped or replaced.
The X300 sedan has different bolts to hold the pinion ‘snout’ plate and the output shafts have different fastener heads but all can be swapped back and forth.
If you have the earlier diff with the 'U’Joint flange, then that is a different story.
Mine has bad pinion bearing. Noise is from diff at decelation(throttle off). It it not too bad though. Most people can’t recognise the noise if not told.
The chance is a just Loosen Pinion Bearing Preload. is there easy way to just fix this?
It is really hard to locate any parts of xj40 here in South Korea…
I may just need to rebuild the diff when the time comes…
I hope it lasts longer as out of budge for rebuilding at the moment.
I had, I believe, the same problem on my '89 XJ40. Differential sounded fine until around 50 mph when I let off the gas I heard a soft whining sound, after a while it drove me crazy. I was all ready to buy a rebuilt diff when I stumbled onto a detailed article on line by a gentleman with the same problem he had with his XJ-S and how he solved it.
I won’t go into all the details but it essential involve removing the driveshaft and tightening the bolt going into the differential 1/8th of a turn. Since I was ready to replace the differential I said “what’s to lose”… I did it and it worked perfectly. this was about 6 or 7 years ago and still quite as a mouse.
If you’re interested let me know an I’ll try to track down the article. This gent really did his homework and must have been an engineer because of all the pictures and diagrams he included.
Alright, it a took while but I found the article. As you can see this guy really did his homework. It was so long ago I don’t remember all the details but I do remember that bolt is SERIOUSLY tight. You really need to get the car on a lift so you have the room to use a long cheater bar to get any movement on it.
I remember having someone on the forum tell me expertly how this wouldn’t work …but it did and stopped the noise and it’s been absolutely fine after many years. I’m sure I posted something about it so let me see if I can find that.
There’s a crush sleeve at the pinion bearing that’s also called differential shaft bearing retainer. It’s installed when they assembled the differential. As the nut gets tightened this crush sleeve start to collapse a little bit. Over time the bearing wears out and it get looser a bit. That’s when you hear a whine. So by tightening the nut a little bit more the crush sleeve collapse more, keeping the bearing tight enough so no more whine. There’s a certain torque the pinion bearing needs and the crush sleeve’s jot to achieve it and hold it.
1/8" is indeed a little over 3mm not 6. As many times as I read this article before I tightened my pinon bolt I didn’t pick up on that, but then I’m not a metric kind of guy.
It’s even more surprising because this fellow is obviously very meticulous and did his homework.
Swallow_che … If you decide to try this I can’t stress enough just how tight this bolt is. You definitely need to have the car on a lift to give you enough room to use a long cheater bar. Something like this …
