My car was missing these lamps when I bought it and I am having no success finding them at the usuals. I believe the P/N is C16898. A lookup on the PN at SNG produces a hit but it has wires coming from it instead of a single connector. This doesn’t match my harness which has a series of spade connectors that go across the instrument panel serving all the lamps in the left dash.
I’m guessing the proper tach lamps look like the speedo lamps (although I think the speedo might have a different P/N C16897). The speedo one looks like this:
If anyone has their dash apart it would help if I knew whether the tach and speedo have the same lamps and if not a picture of the proper tach lamp would be great. Of course if anyone has a source for the correct lamp that would earn many brownie points.
John - check out this thread, and in particular the post I linked. It looks like you’re after a C612M from British Wiring. It looks like they may be out of stock currently though.
John
If you want more confirmations I’m sure they are right
I’ll look at mine tomorrow if I can get to it … dash is off
Skied in 3 feet of powder today went over the front 3 times ……might be sore
Actually, Rob, I think that’s a C611M and that seems to be stock. I ordered a couple, will see how they work.
By the way, Richard Liggitt, as you can tell by now I was looking for the socket. But let me say that your book on the S2 is my goto resource when I can’t find precise details that I need, such as part numbers. I did find the ones quoted here in your S2 book, even though I am working on an S1. The book was expensive but I I relied on other people when they said it was well worth it. Now I wouldn’t be without it. Thanks for all the work you did,
