Am making good progress with the conversion to the EZ-EFI 2.
2.0 fuel injection. The S3 filler caps, new tanks and high pr
pressure lines are installed. The new Pollak six (6) port ch
changeover valve and it’s relay are in place.
Today I cut the two inch hole to run the wiring for the ECU
and hand held – it is all in place inside the car now. The fi
final place to bolt the ECU is still up in the air… I ne
need to be able to see the front for the LED lights and the wh
whole interior is out as I am going to get a bare metal pa
paint after the conversion is done.
The wiring loom under the hood is in place now and a lot of
it will fit behind the Optima battery. The throttle body,
coolant sensor and fuel pressure regulator is ready (need to bol
to bolt the fuel pressure regulator to the fire wall). The CD box
CD box for the spark is on the way now and should be here this w
this week… a little ordering screw up!
The new distributor is installed at TDC and it will be cont
controlled by the ECU for optimum performance. The heated 02 s
02 sensor is in place and the wires connected.
This afternoon I will run the wires for the fuel pressure se
sensor and inline fuel pump in the trunk. Then all the wi
wiring for the relays for the changeover valve and the rear tr
trunk portion will be done.
Soon after the CD box arrives and I get it installed — I
can start the car! It will be interesting to see how much
better it runs/starts and stops with the modern fuel
injection. I expect more fuel economy with the fuel
injection and 2-4 MPG is not unheard of in these co
conversion.
The tablet that controls the setup and gives real time
information is now ‘‘stuck’’ onto the glove box door!–
'71 XJ6 383/200R, 2015 Dodge Ram 1500 4X4 Eco Diesel
Glendora, CA, United States
//please trim quoted text to context only
