Will the rear seat from a series III or possible an XJ40 fit my 77
Series II? My rear seat springs are rusted beyond repair plus the
seat material is vinyl and I would like to find black leather.
Thanks
Eric–
T-Cat 77, 1977 XJ6 Lump 79’ Vette SB + 700R4
OKC, Ok, United States
In reply to a message from T-Cat77 sent Tue 4 Nov 2008:
Hi Eric -
Please check on this with someone else, but I believe that a
S3 rear seat is a direct fit. I also think the rear seat
from an XJ40 will fit without modification, but I’ll less
certain on this! Certainly there are members here who have
done these conversions: you may get more luck if you post
the questions in the general XJ6 forum.
Eric, I recall seeing some pics here of someone who put the series
III rear seat into the II. I don’t recall him making any comments
about the bottom portion but the back fit. I seem to recall he had
to snip off a short section of ‘frame’ then re-streach the
material. This caused a small wrinkle at the upper-outside corner
of the back. He mentioned it was easily covered by the seatbelt.
Maybe do a search or go back and check past posts.
No idea about the XJ-40 rear seats. I’ve seen pics of a
procedure here on how to put their front seats into a series II.
And I’ll be doing that. good luck–
Gary '75 sedan (350/350) 70-72-76 parts cars
southern california, United States
In reply to a message from Gary Boehm sent Fri 7 Nov 2008:
IFRC, the rear seats will fit, but the seatbelt mechanisms have to
be changed as well.
The Series 3 belt mechanism is on the rear parcel shelf, where the
S2 is on the side of the seat. So the S2 seats have an indentation
in them to allow for the seatbelt mechanism. The S3 seats don’t
have that indentation.
I think the same is true for the XJ40.
David Boger
www.EverydayXJ.com–
69 XJ6, 75 XJ12, 84 XJ6, Bunches of parts cars
Rockwell, NC, United States
In reply to a message from DavidBoger sent Wed 12 Nov 2008:
David is spot-on regarding the S3 seats. The XJ40 squab
will also fit (with the seatbelt change David indicates) but
the back is a bit wide at top–it can be taken in, though.
The S3 seat back needs no modification.
Both S3 and XJ40 seat squabs are a bit deeper–you lose a
little legroom. Check the XJ archives–this has been gone
over numerous times.–
