If I’m going to go to the trouble of dropping the IRS, I am going to want to clean it up and re-build everything that I can. The president of our local Jag club is a 50 year Jag owner and mechanic (has a business restoring and working on Jags) he has suggested a gear swap, so this might be the time to take car of that too. I’ll have to chat with him about that.
Some questions:
How much does the entire IRS weigh?
Other than disconnecting the hydraulic brake line, the hand brake line, and the drive shaft, how many bolts hold the IRS in place?
I’ve done the job twice, though the last time was 7 years ago. If I recall correctly, the springs need to be compressed about an inch and a half, maybe two, to clear the shock collets. That puts them under considerable potential energy. The shock body is close to the inside of the spring coils and the hooks of a standard threaded rod spring compressor can foul and cause the thing to pop off. It can still be done, but again with caution, while securing the shock in a bench vice.
Update: I forgot that I also used this compressor to load springs onto the front shocks of my BMW Z3 for a strut like setup. Frankly that was a ton easier that the 22" Jeep springs that needed to be compressed to 15" to get over some bump stop mounts on the coil base.
Those look like they’ll do the job. What I found as you torque down the compressors is a tendency for them to go off kilter. Torque them down evenly, keep them straight and parallel and no drama.
Oh I learned that the hard way!! The first time I used them on a tall Jeep spring, I had to compress the coil down considerably, so I thought I was being a smart guy by using my impact wrench to tighten them up. I managed to get one side down much further than the other and the spring was shaped like the letter C. It was so bad that I couldn’t even get a wrench on the one side it was pressed so tightly up against the coil.
In a panic, I drove to AutoZone and rented one of their sets that look like this -
I was then able to get the spring straight again and into place, but my heart skipped a few beats. After that experience, I only use a box wrench and tighten 1/2 turn on each side at a time. No further drama after that…
Bob, After you complete the carbs, brakes, interior and wiring, your best bet is to drive it to CJ TEAMWORKS down the road from you.
If its out , you do it once…Brakes, rotors, bearings , seals, coil overs, the list goes on…
Remember the exhaust has to come out, trailing arms. Its very involved.
Re shim the gears, mounts and all the rest including U joints.
Good luck
gtjoey1314
Ugh. The tasks for the IRS are last on my list of many things I want/need to do. I want to drive the car for a while before I tackle any of the IRS items. The carb needles are due in today, hopefully tomorrow I can install them and get this thing started again.
Bob;
You are considering putting new shocks on you car, the rear IRS, specifically. When I did this I found a J-L lister that had done this and posted about it. The spring compressor he used was safe and easy to put together. I have lost his name but I did post a photo series on it and I will add it here. Be safe.
Use your two rear brake rotors as the top and bottom of the ‘spring compressor’, insert threaded rod (I think 5/8"), bolt them to the bottom rotor. Put the shock and spring into the rotor and place the other rotor onto the top of the spring. Use two nuts on the threaded rod and turn them down a ways down alternating from side to side. once down a ways you will be able to remove the collet that holds the end of the shock to the spring.
Using the rotors the spring and shock are held tightly and you are safe, done properly nothing is going to fly apart.
as you release the tension make sure the collets are secure.
It worked well for me and you can reuse the rotors on the car if they are good, if replacing them save the old rotors for future use.
I would never discourage a job but
I’ve known you a long timev😀
Let’s first finish the rest of the fantasy dream
Then drive it, you might want a 307 rear out in Texas!
Just a thought
Gtjoey1314
Oh I agree. There are several tasks ahead of this one, but I’m fairly certain the shocks are original, the calipers look like they may be leaking, I want to replace the pads, and the handbrake appears to be inoperable. I plan on spending the winter taking care of all of those things, either in my garage or at my mechanics. I’m gathering info on the magnitude of the tasks to judge where to get them done. Yesterday I leaned towards paying someone, today I lean towards tempting fate and doing it here in the January timeframe, when I won’t be driving the Jag. Time will tell if I’m brave enough.
By the way, the reason I asked how heavy it was, I was thinking of taking the IRS to my buddy to have him do the gear swap. If I drive it to him, there is no telling how long it would sit in his shop, he is swamped.
Following along with this has motivated me to get off my tail and get back to work on my car. I’ve had all the parts to rebuild the brake system for at least six months, but I’ve let fear of tackling the rear brakes keep me from doing an. Last night I went out to the garage, got the rear up on jack stands, slid underneath and just laid on my back for a while, looking up and contemplating the project. I came to realize that it’s a fair amount of work, but nothing to be scared of.
I’ve got a bunch of use-or-lose leave at work, so planning to take the week of Thanksgiving off to work on the car. Like you, Bob, I’m ready to get driving it.
Bob and any one else wanting to work on their E Type:
It does not take 30 years previous experience as a mechanic to do most jobs on the car. A book (Bentley manual ), read it carefully, ask questions of those you trust, and get to work!
Now I will admit that I started my Jag as my third project in 2009 at the age of 68 after retiring. My first project was a MG TC (exu) and I will tell you that I thought I knew just about everything I needed to know to do a bang up job. I bought it in 1973 and started to take it apart in 1975. Imagine my surprise at finding decaying wood on the inside, I had not known there was wood in the first place, like a Model A did. Anyway it got done and I have driven it about 14,000 miles since 1985. Now back to the present.
Jack up the car and use good jack stands to support it, two in the back under the square tubes running the length of the body and two in front under the front lower ‘A’ arm support. Put a jack under the IRS, floor or transmission I don’t care, then go about disconnecting the brake hose from the body to the IRS, the drive shaft from the differential flange and undo the E brake connection to the IRS. Now you are ready for the bolts that fasten the IRS to the car. Some would suggest you remove the bolts from the top rear fitting that go into the support frame and the front fastener bolts from the IRS. I don’t really think it matters, just get them out. Now you have to disconnect the radius arm on each side ( some times not an easy job) and the rear stabilizer from each side. Now I think you can lower it down and pull it from under the car. Now the real work begins and enjoy your self. Take plenty of photos of your work. when you think you have taken enough, take some more.
The rear axle is intimidating, but it’s all bark, no bite. Not only is there no need for a lift, it would actually get in the way. It’s just a whole lotta bolts. The weight is nowhere near 400 lbs, I would guess more like 250 or maybe a bit more. I’ve done it with a 2 ton floor jack, but that transmission jack looks like the perfect tool. The hardest part for me was getting the trailing arms out the first time, as mine had rust bonded to the mount points. Make sure to give the cups a liberal coat of anti-sieze when you bolt it back. You’ll also have to practice your safety wiring. I confess that I’m at an age where my physical abilities are diminished, but the cost of a professional R&R is the surest cure I know for arthritis. There’s no rush here…you have all winter to get it done step by step.
