Anyone have acces to or where to get the entire units or the guts for a MK IV marker light. Need 2.
Thanks,
Gust Nelson
Thanks,
Gust Nelson
It’s not something you can buy off the shelf. I use MG TC park lamp internals [ bulb holder] the MK IV lense is held by 2 copper spring clips at each side of the lens,9 o clock and 3 o’clock. I save these and make a flat plate that sits vertically at the bulb holder and hold the 2 copper clips on with small BA screws. Obviously the old park lapmp internals have been removed [ or rusted away and a new top part of the guard welded in to replace that arear. All oe needs to do is position the new holder at the right for and aft position that the lens rim clips into place firmly. You might slot the holes onto the guard a little to get adjustment wiggle room.
I should have kept pics , or maybe I did but it wa spre-computer days
Thanks Ed. Figured I would hear from you. In the last stages of reprinting, new harness and spiffing up the IV Saloon. After all these years she needed a bit of TLC.
Gust
