Would someone mind sending me a photo of the bell-crank throttle linkage setup on their Mk10? Mine binds and I have not yet found a diagram to explain. I think there may be some mis-assembly, but it’s not clear to me exactly what. This is what I have:
Ok, thanks. I did finally get it sorted. You are right, it’s a fiddly bit. The problems were the carb throttle shafts set too far out, so that there wasn’t enough bellcrank travel, some binding, and the need for a little more bend in the cross shaft.
