Dana:
I’ll work on getting the write up for the ign. amp. test procedure and send
for your review and then we can post to the list for comment and then submit
for inclusion in the book. I just replaced brake rotor’s pads, wheel
bearings front and rear (did not do rear bearings). Had a real hard time
getting the bolts loose on the front brake caliper brackets. Calipers came
off just fine, but the bracket bolts would not budge. Tried heat, air
impact, soaking with WD-40, nothing worked. After a couple of days with no
results, I removed the front shocks, and antirollbar link and front air dam
assembly in order to get a three foot breaker bar on the bolts with the car
on jack stands. If one had a lift and the cat was in the air, one could
possibly get a breaker bar from the bottom to reach the bolts. On jack
stands the bar has to extend to the front of the car. With moderate
pressure, the bolts turned with relative ease. Since they had never been
removed, I suspect just enough corrosion locked them in place. I have’nt
experienced any problems with the accumulator yet. I’ll keep you informed
on my ign. amp. test and the write up. If anyone on the list has an extra
amp. to loan me as a final test, that would help speed things up. Maybe a
used one (around $100) might be just as expeditious.
Tom
'90 XJ40, '66 E-Type_________________________________________________________________
Chat with friends online, try MSN Messenger: http://messenger.msn.com
