To All,
I had my mechanic check the EGR valve in order to clear a “Fuel/Fail #37”
VCM warning and to extinguish the “Check Engine” light that I was receiving.
The mechanic said that the EGR valve was fine and not at all occluded, so I
cleared the “Check Engine” light by pulling the instrument panel fuse. The
“Check Engine” light was extinguished for about two days before coming back
on again, and I also get the “Fuel/Fail #37” warning.
What should I check next?
Michael Weyenberg
91 VDP 73K
e-mail: @Mike_Weyenberg
Mike,
The 37 code is for the electrical part of the egr system.
You need to clean the connector on the vacuum solinoid that opens
the egr valve.
A plugged port would give a 39 code.
Brett
1990 XJ6
…Date: Thu, 26 Aug 1999 13:34:44 -0700
From: Mike Weyenberg mike.weyenberg@calldynamics.com
Subject: [modern] Fuel/Fail #37–Not an occluded EGR valve?
Sender: owner-modern@jag-lovers.org
To: “‘modern@jag-lovers.com’” modern@jag-lovers.com
To All,
Michael Weyenberg
91 VDP 73K
e-mail: mike.weyenberg@calldynamics.com
