whine in low gear that is only noticeable in sport mode. << This is
because sport mode holds the trans in low longer to allow the engine to
build revs …
planetary gear whine in automatics is very typical - some have more than
others - this is because of massed produced clearances, also if the trans
has been rebuilt, the planetarys usually are reused if the sun gear thrust
washer clearances are OK, making the noise continue into the next rebuild.
Then of course there is gear wear - which causes more noise - but does not
affect the integrity of the assembly ( planetarys are very tuff ) - its
kinda like tinnitis & ringing in your ears - we all have it, but it either
drives some crazy, others dont hear it, some hear it but ignore it, others
were just fine until you brought it to their attention - after which they
have learned to obsess about it. Gear whine ( and rear end noise, and the
thunka-thunka from the fuel injection etc… ) is a problem in expensive
luxury cars that are characteristically quiet - IE you can hear it )because
it is not masked by road or wind noise. I recall a person who obsessed about
planetary gear noise in a used Cadillac Eldorado - the stupid salesman
brought it to the attention of the test drive customer, where a deal was
made that he would buy the car if the dealer would fix the gear noise. Well
we took the damn trans out & put first a used gear set same problem - then a
new gear set, which made it a little quiet - but basically imperceptable to
the customer.
As far as shift correction kits go - some are good - others are better, some
are not so good, the one for the 4L80E is basically a mechanical fuse to
prevent an electronics failure from blowing (literally ) up the trans. You
cannot change the shift timing or firming up etc. - the electronics have
full control over the shift points & the pressure modulation .
Shift kits typically incorporate all the industry knowledge on a particular
unit - into the little instruction sheet - IE part numbers, new seal numbers
etc. They also usually fix problems that are characteristic to a particular
model of trans. For instance - the shift selector valve for the Chrysler
904 - 999 trans is incorrect in that it allows the torque converter to drain
back to the pan when parked - causing a “dry” converter at start up …-
TRANSGO has the correct vaslve in their shift kit. Some transmissions
absolutely will not live without a shift correction kit - and some
transmission shops will not warranty their rebuilds without your agreement
to the installation of one of these kits - that is how bad some of these
transmissions can be…
By the way - electronic transmissions work BETTER with synthetics trans
fluids BECAUSE of the shift solenoids - the stuff lubricates better… That
is why the new spec for DEXIII & MERCON V…
BIGGY----- Original Message -----
To: “Modern List” modern@jag-lovers.org
Sent: Friday, March 29, 2002 7:00 AM
Subject: Re: [modern] What Transimission on XJ12???
The low-gear whine is typical (and normal) planetary gear noise. This
characteristic is found in all Th400 transmissions right back to '64 and
carried on into it’s overdrive cousin, the 4L80E, which is the trans you
have.
I’d wager there are some “shift kits” or the like out there for this trans
to firm up the shifting.
Doug Dwyer
Longview, Washington USA
I just got my 94 XJ12 back from the body shop… Great job.
Now I remember some annoying properties with the tranny. First is a
whine in low gear that is only noticeable in sport mode. The second is
sloooww shifts. The VCM shows the tranny display when check out only.
It has new filter & fluid. I would like to upgrade the shifts to be
much
firmer. Does anyone have any experience with these trannies??
