James,
The Diff output shaft bearings are not hard to replace, but as you say,
pinpoint the cause of the noise as it could be the wheel bearings or
something else. I did mine a while ago. Getting the stub shaft out is
easy, somewhat harder is removing the retaining collar that holds the
bearing in place. The collar needs to be drilled and split with a chisel to
be removed. You then need to press on the new bearing and new retaining
collar. I used a friend’s 5 Ton press but it would have been much easier
with a bigger press as the retaining collar required quite some force to go
on. If you don’t have a press you need to take the stub shaft to a workshop
as recommended in the Haynes manual. You also need to replace the O ring
seal with a new one.
From memory the Haynes manual suggests detaching the output shaft from the
Hub carrier assembly, but this is not necessary. All you need to do is to
remove the 4 nuts on the flange and then pull the output shaft away from the
diff, allowing the hub carrier to carefully swing down and supporting it so
as to not damage the brake line. This allows you to access to the 5 bolts
on the diff housing and remove the stub shaft.
I had a bit of play in one of the rear wheels, which according to most info
I found in the archives is normally attributed to excessive play in the diff
o/p shaft bearings, but the cause turned out to be previously incorrect
shimming of the stub shaft and my bearings were fine. The JDHT CDROM
describes the whole procedure very well including the shimming required,
which removes excessive in/out play in the stub shaft and consequently the
wheel.
Serge
1990 Sov.------------------------------
Date: Tue, 16 Apr 2002 00:13:05 +0100
Subject: [modern] XJ40 rear Differential
Hello,
I am soon going to have to embark on a job I have been fearing since getting
my XJ40, the rear differential output shaft bearings.
My front wheel bearings have a lot of play, and are to be replaced very
shortly, but my rear end has also started to whine louder than normal, I
have changed the diff oil and experienced a minor improvment. I am aware
that quick wear diffs seem to be a common XJ40 failing.
I need to pinpoint what the problem is exactly before embarking on the
remedy. Basically, at 60 MPH I have a noise from the rear end that sounds
like I am being pursued by a plane, though not majorly loud, it is
noticeable. Is this fault easy to rectify or is it a ‘drop the A frame job’?
Thanks in advance.
James Copp-Taylor
1987 XJ40 3.6 (Uhura)
