Hi, has/does anyone have both the power steering pump and alternator mounted on the left hand side if the engine?
I removed the air con from my S2 2+2 and wanted to shift the alternator from the front to the side of the engine. But with the standard brackets it looks like a no go (clearance between the steering rack, alternator and indeed the frame). See photo below
Before I give up and revert to the standard setup, it would be good to know if modifications are possible.
Mainly the AC was bust and the mount at the front of the engine is not very aesthetic.
I definitely would consider a smaller alternator if there are suggestions - the new bracket seems to be the blocker, but if smaller alternator with a different mounting arrangement, that could work.
Good spot @Ahwahnee - i changed the fan after reading @Michael_Frank ‘s guides on switching the alternator round. I still have the old fan so can switch back if needed.
I think i can have another fettle around and see if i can get the clearance i need for the PS pump.
Some progress here so thought i should update the thread as this seems like an unusual mod.
Anyway i figured i could create a similar mounting arrangement to the original for the PS pump. I drilled a hole in the alternator mount with just enough clearance to the block to get a 5/16 bolt through. This allows me to secure the top of the PS pump mount with the bottom on the elongated bolt. Pics below…
Not finished yet i need to put a sleeve round the bolt to secure the mount properly. Also its still very tight between the belts for the alternator and PS pump - if its too tight i think can adjust the alternator position to run the PS Pump and alternator off the same belt.
