The subject has been partially dealt with on this Forum, but still some questions remained unanswered. I dug a bit deeper and found more information. It’s not enough for an article in one of the magazines, so I put it here for “those interested”.
Mutocel over Gearbox Cover.
Jaguar XK 120 SPC J.11 (1958) refers to Mutocel BD.3864 with suffix 6 to 12, as the five pieces of Mutocel required for the insulation of the early Gearbox Cover BD.3168. Only two pieces of Mutocel BD.4596/7 are required for the later Gearbox Cover BD.4078. The latter pieces of Mutocel measure 32” x 30” (81 x 76 cm) each, according SPC J.11 (FHC) and J.13 (DHC). .
Urs Schmid shows the (later) Gearbox Cover BD.4078 with the original Mutocel pieces. One is placed on the outside and one on the inner side of the Cover: cuts have been made to obtain the right shape. Bifurcated rivets are used as an extra measure to keep them in place.
Underfelt is placed over the Mutocel.
Although not mentioned in the SPC’s, Mutocel was also used on the inside of (later?) doors: a longer strip of about 16” long and 6” wide was used along the top of the door (partly behind the horizontal section). In addition, at the inside of the door panel a piece of underfelt of about 6” x 12” was glued in the centre.
Mutocel was a “sound deadening” material manufactured by the Ruberoid Company, originally from the USA but with activities in the UK as well. Mutocel was developed in the 1930s and used by a number of British car manufacturers. Mutocel is described as “consisting of several layers of felt, bonded together with bitumen”. See example as presented by Wolseley for their 1937 model “12”.
Note that (unlike modern similar materials) Mutocel didn’t have a self-adhesive back, but was glued to the panels to be covered.
In Europe similar materials (with the same “diamond” pattern) are supplied by various companies like 3M (08840), Terodem/Teroson (by Henkel), Dinitrol (by Dinol/Würth) and many others.
Underfelt for XK 120 OTS
Three pieces of underfelt are used (according the SPC) for the XK 120 OTS (see photo below).
The piece in the middle (coded BD.4596/6), fits over the gearbox tunnel and measures 32” x 30” (81 x 76 cm). The other pieces are for the toe boards: BD.4589 for the RH side and BD.4590 on the LH side, the latter having a cut out for the dipper switch. All part numbers related to LHD cars. Unlike the FHC and DHC, the OTS had no underfelt underneath the floor carpets.
We already mentioned the piece of underfelt used on the inside of the door.
The “Panel for Lubrication of the Propellor Shaft” (as used from December 1952 onward), bolted to the side of the Gearbox Cover BD.4078, had a piece of underfelt cut to the correct shape (see very first photo).
