Hello all
Some may recall that I have been working on a friend’s 1988 XJ6 to revive it after a long term storage.
I had actually finished the car except for some sheet metal work on the floor of the trunk.
I returned the car with the instructions to drive it around for a couple of weeks and then I would work on the repair of the trunk floor.
Unfortunately the car survived less than a day before I got a call that it died and wouldn’t restart.
The car was towed back to my shop where I spent a LOT of time this week trying to diagnose the root cause of the no start issue.
Basically the car has no spark. The starter works and spins the engine over just fine. The battery is new and fully charged.
I am checking for spark by unplugging the coil wire from the center of the distributor cap and holding the end near a ground point on the engine.
I have done lots of things to try and figure out why it won’t start but so far I have been completely unsuccessful at trying to solve the issue.
The car acts like the crank sensor is bad but I have done lots of things to check that and I will detail all of the steps I have gone through so far.
I have tried swapping in two other crank sensors, checking the resistance readings from the crank sensor at the actual electrical connector at the front of the motor and at the pins on the engine management ECU plug.
I have checked at the electrical plug for the engine management ECU for the appropriate AC voltage signal when cranking the engine. I do get AC voltage at the appropriate ECU pins corresponding to the wires coming from the crank sensor.
All of this looks good. But still no spark at the plug and zero movement of the tachometer when cranking the engine.
Although I have no spark from the coil wire, I also checked the ignition rotor to see if it had electrical conductivity and it was fine.
I have power at the coil (checked with a test lamp on both the positive and negative side of the coil) with the ignition switch turned on.
I also have power at two of the wiring harness pins going to the ignition module that sits behind and under the coil.
Earlier this evening I also put a noid lamp on one of the injector plugs and got nothing when cranking the engine. No blinks of the noid lamp when plugged into the harness in place of an injector.
I am fortunate that I also have another car in the shop with the identical engine management system that runs fine. So today I tried swapping some parts so I could confirm working parts or not.
I have swapped the actual engine management ECU from the no start car to the running car and the running car starts and runs fine with the no start ECU. Put the no start ECU back on the no start car and it still would not start.
I also swapped the original crank sensor from the no start car to the running car and the running car starts and runs fine with the no start crank sensor.
Earlier in the week I removed the ignition control module from the the running car and temporarily plugged it into the no start car but that made zero difference. The no start car still would not start with the running car’s ignition control module.
I also took this same “good” ignition control module and put it BACK on the the the running car and it still runs fine with it’s original ignition control module.
I have checked the action of the fuel pump when the ignition switch is first turned on and I can hear the pump do it’s initial pulse so that tells me that the main and fuel pump relays are working as expected.
I also checked these relays using a test lamp and the ignition relay, the main relay, and the fuel pump relay all have power on pin 30 and pin 87 when I turn the ignition switch to the on position.
I also swapped other identical relays in for the main, ignition and fuel pump relays but that had no effect.
I am running out of things to check so I really hope someone here might have some suggestions.
PLEASE HELP!
