Like to find an original shift stick with knob and switch for an overdrive early XJ6. Before I start looking at Volvos or MGB’s that use a similar set-up, I thought i’d see if anyone knows someone that’s parting out an old trans. It’s really awkward to use the Pep Boys switch someone bolted to the steering column.
I have a shift knob you can have for a nominal amount. The switch is available as it is a consumable. The gearstick itself is going to be hard to find as it isn’t a service item. It is fatter than the standard item on account of it being hollow to accommodate the wiring for the switch.
