Yep! I got my valve yesterday (WED) but had a visitor here so no chance to install it yet …maybe this weekend
Give yours a suck and see if it closes and then re-opens fully when you let go the suck - mine does, but definitely not as snappy as the old jag valve, a bit lazy in fact.
In my 89 I got 3 valves from coventry, first one didn’t leak but was pressed to hard and wouldn’t close next two closed but leaked, finally got one from rock auto (plastic) and it works great! And that pic is spot on as to the valve location.
Installation of my cut-and-paste plumbing was much easier than with the factory valve, and just to be sure I didn’t get a leak at the olive end I used some teflon tape on the thread.
Routing of the vacuum line was straightforward, plenty of length with no tight bends.
The a/c is colder now than before but I don’t think it’s as cold as it should be. I tried the heater and the air coming out of the footwell is nice and hot (hotter than before) but I don’t get hot air out of the side vents. More like slightly warm. The bend flap actuator motors worked last time when I checked them.
The vacuum line is running right in front of the valve so it’s length wasn’t a problem. Actually, I cut off like a 1/2" (12-13mm) piece because the previous valve stretched it and the connection wasn’t snug.
Joe - That ‘non-intuitive’ slider control governs the temperature of the air coming from the side vents.
Not sure if up or down increases or decreases the heat up there …I guess it’s supposed to regulate the amount of cooler air to the side vents when you have the heat cranked up to stop you from falling asleep at the wheel or something …
My A/C is down to 39, (4 celsius) so not super cold either but way better than the 50 it’s been at for the last couple of years.
