2001 XKR,
Was running well when stored last fall.
Initial start proved battery was flat ( one year old AGM)
With new battery cranks well but no fuel to engine.
Checked all fuses and pump relay is energized.
What next?
How is the fuel cutoff switch checked or reset?
Someone suggested the crank position sensor. Is this reasonable?
Rodents are not a problem.
The up side is our spring weather so far crappy.
Thanks in advance.
