Hello all 1997 x300 tried to start after sitting for 2 weeks no start no spark no tach while cranking tested CPS 1.35 ohms installed a new one .checked all the fuses swapped relays(mine are brown) ecu looks clean got continuity on the white wire from CPS to ecu. Battery is charged ran exterior jumper from battery to right side fuse panel. I’m stumped any ideas would be most appreciated
I did replace a CKPS and at first had the same symptoms as you, I removed it and cleaned the area fully when replaced and seated correctly all was well! Good luck.
Thanx for the reply Neil it did cross my mind but I have my doubts. I will certainly let you know
