Included components are:
Teves IV Pedal Box with Pedal
Tevers IV Matching combo brake light and cruise control switch
Teves IV Vacuum Booster with vacuum grommet and combination vacuum line adapter and check valve.
Teves IV Tandem Master Cylinder With reservoir and integral working brake fluid level switch.
All parts are used, but cleaned and guaranteed to be working correctly. Master Cylinders have been flushed with Valvoline DOT 4 synthetic brake fluid and checked for proper function. The master cylinders are used in other applications as well, and available new ($$$$), or If you wish, you can use the supplied master cylinder as a core trade in for a rebuilt master cylinder. If you don’t need the Fluid Reservoir low level switch function (failed switch), you can deduct $40 for a good reservoir with a failed switch. In case you thought the Teves IV Brake Pedal will work with the T3 brake light / cruise control switch it will not - the T4 pedal is of a different shape and the actuator pin is located differently. Maybe some one who welds can move it around to make it work with the T3 brake / cruise control switch. If one wishes to try that, I will deduct $70 to not include the switch in the kit (it can be found online new for ~ $140 - $200). Brief easy instructions will be included, and additional tips and advice are available.
Price Complete $250.00 USD + shipping (est. $20 - $30). Shipping from Miami, Fl, to Domestic continental USA only. Contact me by PM or reply to add.
Lockheed
