Looking to add an oil pressure gauge as a back up to the one in the Cockpit.
I had removed the oil pressure switch because it leaked and just plugged the hole.
Can I install an oil pressure gauge there. I assume the pressure would be the same?
Assuming you have a V12, there are three ports for oil pressure. Right side is for warning light. Middle is oil pressure gauge. Left is capped. I replaced middle one for the OEM gauge, and installed my own aftermarket one in the left side.
