Trying to carefully remove old and extremely hard / brittle rubber plug. I’ve tried every different shaped pick I’ve got. But the rubber is SO hard that every time I apply force to remove, pieces just explode outward.
I’ve pretty much run out of options and am about to lose the rest inside the engine. I know everybody says I shouldn’t worry, but most people just seem to lose the inner ears, I’m going to drop most of the plug!
i had similar issue - I poked a hole in middle thinner area, and inserted pick/hook tool so I could hook around the back of it and pull. Worked pretty well.
That old plug was hard as Bakelite and there was no way I could poke a hole through. At least until I heated up my pick red hot with the torch. Then I was able to slide/burn a hole through with a straight pick and then ‘thread’ a curved pick in behind.
Still only came out in bits and pieces, but at least they mostly all came out. At least one piece fell in, as I could see it in a picture. Had it skewered with a straight pick but ultimately while trying to wrangle it out, it fell in.
