Hey, this is going to be a long read, as its 1 year story with my jag, so sorry for that, but to avoid most common suggestions, i need to write everything down
Car: Jaguar XJS 1992, 5.3
In short: Car overheats, after warm up looses any power after 3k RPM (not always, one rev it goes higher, next one, doesnt want to, popping sound from exhaust sometimes) , slight vibration when seating inside. Not sure if those problems connected, moreover loss of power came somewhere in between and was not present at the beginning of that saga.
Also, note that car overheats more when driving fast, at idle it doesnt, at least for the first 30 mins, then it cant get back to close thermostats even with efans on, they stay on forever, but when you driving it, no matter of speed it climbs up.
I bought the car more then a year ago and from day one it was overheating between N-H.
No big deal, i thought. So i got into forums, found sticky document explaining how to deal with overheating and started complete overhaul, bellow is the list of things done so far withing a year
all hoses
new thermostats (checked in boiling water for proper length)
all new seals and gaskets including rail pipes
radiator recored (twice)
new water pump
new banjo bolt from ebay (modified)
tried 2 fan clutches, then moved to efan controlled by separate thermoswitch
all air gaps closed
bottom spoiler in place
installed glass coolant filters, now i can see that flow is good and equal on both sides
both tanks (metal and plastic) cleaned
tried to fill the coolant in 5 different ways, front up, down, left, right, all possible ways i could find
all spark plugs and wires
injectors removed resealed and cleaned
bottom of V cleaned,
ALL vacuum hoses replaced
fuel lines replaced
fuel rail cleaned,
valve cover gaskets replaced
moon seal metallic one
both new crank speed sensors
new CTS
injector harness rebuilt, rest of harness checked
MAP vaccum line fixed(was leaking)
new fuel filter
both new coils
all injectors checked with test light
check for exhaust fumes in cooling system using special liquid - nothing
TPS voltage adjusted
throttle bodies adjusted
new dist cap
every sensor checked, resistance, resistance at ECU.
vacuum - 16 at idle
compression within normal range on all cylinders with less then 10% difference between each other
Also, it feels like B bank is hotter a bit. That slight vibration no idea where is coming from.
Now, last thing to check is clogged cats, BUT i dont hear any noise, exhaust flow feels steady and strong and no smell.
Other then that, i have no idea what it could be
P.S maybe it doesnt overheat, gauge not working properly? i dont think so!
here is my logic
oem small fan turns on somewhere at 92, it does
my new thermoswitch for efan goes on at 95 and switches off at 85 (dont remember exactly, but it doesnt matter)
When interior gauge shows a hair past N, both fans turning on, when it goes towards mid to H, both fans are on and not switching off even driving hghway. But at idle they both goes off when gauge drops bellow N
Honestly, now i wish it would be blown head gaskets, at least i would know for sure the reason and deal with it accordingly. One year of work, testing, checking, cleaning, praying is devastating
BTW! Problems i found and fixed and hoped THIS IS IT
- B bank thermostat was incorrect, shorter, no hole at the top
- MAP vacuum line was leaking badly
- Old radiator was completely gone
- TPS was out of range
- old plastic fan was cracked
- spark plug wires was eaten by rat
and after fixing and replacing half of the car its even worse then it was.
