I was wondering
Does anyone know of a parts compatibility chart or program comparing the various jag models
indicating which parts are common and interchangeable.I know jag tried to use parts from other models and years to save money
It would be good to know at these flee market auctions etc
There used to be something like that on this site, before the change. Can’t remember much about it, except that it was useful.
It would be a great resource if it could be found and or resurrected.
Relay 6RA for instance was used across the board on many sedans as well as E Types.
I bet many electrical switches and motors were shared as well.
Suspension components too…
There are fifty or sixty types of 6RA. Three, four or five pins. Some with internal resistance. Some are simple switching relays, some are switchover relays. Some with sealed bases for extreme service. There are fast closing relays for things like horns, relays with low current coils for things like alternators, and the unique double contact relay used in later cars for the starter. ALL of them are 6RA’s, ALL of them have 20a contacts, and nobody has a reliable and complete list of PN’s and features. And most are NLA, anyway. So sometimes it works, and sometimes it doesn’t. The good news is that with the exception of relays which have internal resistors, any 6RA can be replaced with a 30a DIN (“Bosch”) switchover relay, or you can get simple DIN switching relays to replace three pin or four pin applications. I’ve even seen subminature DIN relays installed inside Lucas cases.
There is this on the old site:
The Jag-lovers Parts Interchange Guide
This link shows the site navigation for the old version of J-L
Like this? I think I got this off the old site.
I have it as an excel file, but looks like it doesn’t paste to the site correctly.
Mike
PARTS INTERCHANGE TABLE FOR E-TYPES
Part Years/Series Interchangable Part
A/C Fan Motor All Granger Motor Part number 2M197. Uses the same motor as the Heater. See Heater motor. Or Everco P/N M868.
A/C Expansion valves & orifice tubes Series III Everco P/N A8250
Alternator Series III Leece-Neville equivalent (Made in USA). Amps are slightly higher but better quality. Used on commercial vehicles. OR Quality Rebuilders P/N 14038 - 60amp.
Alternator 70+ 6 cyl Quality Rebuilders P/N 14010 - 60 amp.
Alternator 64-69 Quality Rebuilders P/N 14010 - 45 amp
Alternator 64-69 w/ A/C Quality Rebuilders P/N 14005 - 45 amp
Ball Joints (Lower) All Use the ones from a 1988 XJ40 Part Number CAC9937. Non-Shimed and Sealed. More durable and better. Needs different bolts. (Maybe 5/16"x3/4" fine 24TPI grade 5 bolts w/ split washers.
Battery (Main) All Exide Model 34 sku# 1189208. 675 CCA. 75 month warranty. $65 from Montgomery Wards. Slightly smaller than original. Affix Lucus stickers on it and no one will be the wiser.
Belt - Air conditioning 69 Gates Number 9520 Green Stripe Belt
Belt - Air conditioning 70 Gates Number 9350 Green Stripe Belt
Belt - Alternator w/ A/C 69 Gates Number 7250
Belt - Alternator w/out A/C 69 Gates Number 7330 33 1/8" Belt O.C.
Belt - Alternator w/out A/C 70 Gates Number 7340 34 1/8" Belt O.C.
Belt - Water Pump 69 Gates Number 9313 Green Stripe Belt
Belt - Water Pump 70 Gates Number 9309 Green Stripe Belt
Bolts - Intake Manifold and Carb Nuts I & II Use a standard Fine thread 5/16 zinc plated nut available from most Hardware stores and a 5/16" lock washer.
Bonnet Safety Latch Series I Part Number N226-522 (SPB34). A 3-1/4" Zinc plated Double Safety Hasp by National Mfg. Co. Carried by Moss Motors.
Brake Light Switch All Upgrade of NAPA/Echlin Part # SL147. Specified as a Stop Light switch. Costs approx. $13. Must recrimp wires with spades from bullets.
Brakes - Rear Series II Should be the same as a 1980 XJS
Clock in Dashboard All WestClock battery powered clock. Some adapting required. Article link.
Another option - ISI quartz clock. 1 800 558 2674
Clutch-Bearing Assembly 61-64 3.8eng. P/N N3035 by CR Seals & Bearings
Distributor (remanf) 61-63 P/N 31-428 by Cardone
Distributor (remaf) 64-71 P/N 31-407 w/out vacuum by Cardone
P/N 31-406 w/ vacuum by Cardone
Distributor-Cap 64-71 P/N LU-423 by Standard Car Parts
Distributor-Cap 71-74 P/N LU-434 by Standard Car Parts
Distributor-Coil 64-71 P/N UF-3 by Standard Car Parts w/out ext. resistor.
P/N UF-2 by Standard Car Parts w/ ext. resistor
Distributor-Coil 74 P/N UF-2 by Standard Car Parts
Distributor-Condenser 61-71 P/N LU-206 by Standard Car Parts
Distributor-Pickup 71-74 P/N LX-563 by Standard Car Parts
Distributor-Points 64-71 P/N LU1617XP by Standard Car Parts
Distributor-Reluctor 71-74 P/N LX-561 by Standard Car Parts
Distributor-Rotor 61-71 (manual) P/N LU-302 by Standard Car Parts
Distributor-Rotor 71-74 P/N LU-323 by Standard car Parts
Engine Bearings/Main Set Series I&II Federal-Mogul P/N 6129M Std-10-20
Engine Bearings/Thrust Washer Set Series I&II Federal-Mogul P/N 65527BF. Position 4.
Engine Bearings/Rod Set Series I&II Federal-Mogul P/N 6-2295RA Std-10-20-30
Engine Gasket - Head set Series II Fel-Pro P/N HS 21140 S-1
Engine Gasket - Water Outlet Series II Fel-Pro P/N 25603
Engine Gasket - Exhaust Pipe Flange (2 req.) Seris II Fel-Pro P/N 23590
Engine-Timing Chain 64-72 4.2L Federal-Mogul P/N 222-175
Engine-Timing Cover Seal 63-71 P/N 19807 by CR Seals & Bearings
Engine-Piston Rings 69+ 4.2L Federal-Mogul P/N E-703KC Std only. 2-2.0mm, 1-4.75mm
Fuel Cap 61-70 Gates Number 31623 non locking. Gates Number 31691 locking
Fuel Cap 71-74 Gates Number 31738 non locking. Gates Number 31761 locking
Fuel Filter The Gas Filter and Glass bowl are available from Napa and Moss Motors.
1) Gas Filter Part Number GF-124…sells at Terry’s Jaguar Parts at $4.75 1-800-851-9438
2) Gas Filter Part Number 95039 from Big A auto parts.
Fuel Filter in gas Tank I&II FRAM P/N CH8PL
Fuel Pick-up screen in gast tank Graco Airless Sprayer P/U screen should be a useable replacement and should be replaced periodically. See Article.
Fuel Pump Series I Borg-Warner EP-10 at approx $39. Easy install. Very reliable. 4-6.5psi.
Heater Fan Granger 800-323-0620. Motor Part number 2M197. Approx. $24. Identical but for cutting a flat spot on the shaft and larger mounting bolts. Paint it black, and polarity is important. Puts out more far more air that original. Or Everco P/N M868.
Headlights Hella H4 Haologens
Hose - Fuel line from filter to carbs I&II Standard 5/16" Fuel hose from all Auto Parts Stores. About 3 feet of it.
Hose - Main Upper from Header/Overflow Tank to Intake Manifold Series I You can use Goodyear Part No gafs074 and cut to size. Has the right bend.
Hose - Coolant Upper - Motor to Pipe 74 Gates Part 26403 or 25250
Hose - Coolant Upper Pipe to Radiator 74 Two hoses 1 1/4" I.D. type Hot water Hoses
Ignition Wires 70 P/N 3601 for silicone core Universal wire by Standard Motor Products.
Knock-Off Hammer SI & II Recommend Lead Knockoff Hammer. Moss Motors P/N 386-020 88G329. Much nicer to knockoffs than copper.
Oil Filter Spin-On Conversion All 1) Basset’s Jaguar of Wyoming 3/8 extension
2) XK’s Unlimited.
3) Flexolite of England. 23 Highway, Yate, Bristol, England BS175AB. Tel/Fax +44(ENG) 454-311401 TSCHUSS.
4) Terry’s Jaguar 800-851-9438. Uses FRAM -PH8A or -PH16.
Oil Filter Original 61-62 Fram Oil Filter CH801BPL with service gasket SP135367
Oil Filter Original 65-68 Fram Oil Filter CH801BPL with service gasket SP135367
Oil Pressure Switch 74 P/N PS-15X by Standard Motor Products
Pinion - Bearing (Front) 61-74 P/N M88043/M88010 by CR Seals & Bearings
Pinion - Bearing (Rear) 61-74 P/N HM90446/HM89410 by CR Seals & Bearings
Pinion - Seal 61-74 P/N 18679 by CR Seals & Bearings
Radiator Cap 61-71 4 lb system - Gates Number 31505 w/ safety release
7 lb system - Gates Number 31508 w/ safety release
Radiator Cap 72-75 14 lb system - Gates Number 31527 spinlok
Radiator/Cooling Fan Volvo Turbine Fan from 96 Volvo replacement for Hayden fan.
Regulator Series III Leece-Neville equivalent (Made in USA). Amps are slightly higher but better quality. Used on commercial vehicles
Starter-Brush Set 70-71 P/N LU-278 by Standard Motor Products
Starter - Refurb. 72-75 Quality Rebuilders P/N 16175
Starter - Refurb 65-71 Quality Rebuilders P/N 16138
Starter - Refurb 61-64 Quality Rebuilders P/N 16139
Steering Racks (Power) 71-74 P/N 26-1911 by Cardone
Stop Light Switch Series I & II P/N SLS-34 by Standard Motor Products
Thermostat 61-69 160 degree - Gates 33006 and Gates Gasket 33635
180 degree - Gates 33008 and Gates Gasket 33635
Thermostat 69-74 160 degree - Gates 33006 and Gates Gasket 33635
192-195 degree - Gates 33009 and same Gasket
Thermostat 75 (V12s) 180 degree - Gates 33188 and Gates Gasket 33635
192-195 degree - Gates 33189 and same Gasket
Transmission Filter 61-71 Fram Filter FT1040 for 6 cylinders
Transmission- Automatic Rear Seal 60-74 P/N 15620 by CR Seals & Bearings
Transmission-Manual Rear Seal 60-74 P/N 17484 by CR Seals & Bearings
U-Joints - Rear Half Shafts Series I P/N UJ 330 by CR Industries" UJ 330. Approx $15.97 each.
Wheel-Front Inner Bearing 65-75 P/N BR6 by CR Seals & Bearings
Wheel-Front Outer Bearing 65-75 P/N BR2 by CR Seals & Bearings
Wheel-Rear Inner Bearing 61-75 P/N BR18590/BR18520 by CR Seals & Bearings
Wheel-Rear Outer Bearing 61-75 P/N BR18690/BR18620 by CR Seals & Bearings
Thks Mike I added it to my files I was hoping there would be something more jag specific between models such as say rotors or distributors used on various models Cheers
@Jagjim1 - I post this knowing I may teaching you how to suck an egg
BUT
by using SNG Barratt’s website, you can find some cross-fertilizing info.
I used your example of a distributor and focused down the cap
Barratt’s lists this as a genuine replacement
Distributor Cap
Genuine
Brand:Jaguar
Product Code:JLM9523
$49.30
“Page Down” for a screen (at least on my lap top) and you come to a tab called
Suitable For
and Barratt’s says that distributor cap also fits:
Classic Saloons
420 Saloon
Daimler Sovereign
Mk II / Mk 2 2.4 & 240
Mk II / Mk 2 3.4, 3.8 & 340
Mk X / Mk 10 3.8
Mk X / Mk 10 4.2
S-Type 3.4, 3.8
XJ Models
Daimler Sovereign S1
XJ6 S1
XKE / E-Type
E-Type S1 3.8 DHC
E-Type S1 3.8 FHC
E-Type S1 4.2 2+2
E-Type S1 4.2 DHC
E-Type S1 4.2 FHC
E-Type S1.5 2+2
E-Type S1.5 DHC
E-Type S1.5 FHC
E-Type S2 2+2
E-Type S2 DHC
E-Type S2 FHC
Admittedly this is a simplistic example but this resource may work for other items
Thks Craig I figured that was one way but I’ve not used SNG I’ve also got several old paper catalogs to cross reference but it’s a slow process was hoping for something more real time. The SNG site is probably as good as it will get
