Does anyone know which pins (plus and minus) at the back of the clock console I should use to check the digital clock on the X300 without risking damaging anything. I would like to check the clock before I install it in the car.? Thank you!
Thank you !
Here’s the actual wire colors for the clock and illumination. The first color is primary.
White/red
Brown/orange
Red/green
Red/pink
BLACK
I use this plugin to test the clocks/bulbs after I rebuild the X300 clocks as a part-time business.
Hope this helps!
Richard Greene via Jag-lovers Forums skrev den 2024-04-17 05:10:
Many thanks Richard.
It would have been easier if I had a plug like you have, but I’ll have to figure it out!
Thank´s
Per
