Not all that long ago, I spent some time re-plumbing my aftermarket fuel pump (the original was no longer functional) anyway, when I went to restart my 1977 XJ-S it just wouldn’t kick. It seemed as though pressure just wasn’t building( Fuel pump tone wasn’t changing among other things)
Long story short, I checked the fuel pressure regulators that appeared to be original (with the Lucas stickers and all) and the regulator on bank A was rattling as I handled it. I went to apply pressure to check the reading and found it wasn’t producing pressure at all. The regulator was shot.
Then, upon checking the bank B regulator, It appears to be holding 25 PSI.
So, I went to buy some new regulators and found that the Bosch 0 280 160 001 is no longer available. I even tried buying the Porsche P/N which was a relabel of the same part.
After some trouble (and comparing application vehicles) I came across the Delphi FP10545 which is shown as a replacement part for pretty much every vehicle using D- Jetronic EXCEPT for the Jaguars.
The pressure listed for the Delphi module is 29 PSI as opposed to the 31 PSI noted for the Bosch as noted here: Replacement fuel pressure regulator
Considering it seems the best option, I’ve ordered some to replace my faulty Bosch regulators.
Considering that every other vehicle with D-Jetronic uses these regulators, I’m hoping it’ll do the job. I’ll adjust them to 31.9 PSI if possible, though that 3.9 PSI difference most likely won’t be enough to matter, Considering one bank was running at 25 PSI (dangerously low)
Anyone have experience with these Delphi Fuel Pressure Regulators?
An interesting note:
A LOT of other cars share fuel injection components with the Pre-HE XJS. I checked out a friend’s 1971 Volvo P1800 today and found he has the same Fuel pressure regulator (the Bosch one), Fuel Pump and I suspect Injectors as my 1977 XJ-S.
Here’s some more information I came across-
https://oldtimer.tips/index.php/en/d-jetronic/102-jaguar
