D.K.Graafland
(1978 XJ-S Lynx Spider, located Gouda (Netherlands))
1
The bleed valve on the top left of my radiator is leaking. I found out from Kirby’s book that the size should be 1/8" BSPP, but the original valve is difficult to come by (part number C45587).
My question is if anyone knows which conversion to a normal European size bolt would be possible? I’ve tried to decipher conversion charts but I’m getting nowhere. Or does anyone know where to find an original bleed valve? I have no preference for a normal bolt or the orginal bleed valve, as long as it stops leaking. I’ve contacted local used part retailers here in Holland but no-one seems to sell them!
If leak due to bad VALVE, go to proper Plumbing/ hardware store and buy brass PLUG, as newer cars had. Bring in your valve and or specify thread. Alternate- fill valve with epoxy (or braze shut) , and treat as plug.
In USA- it is a very odd pet-cock, as we are UNP, straight-odd, or Taper- common. . You know thread, and have sample. That is why PLUG is advice for quick solution, cheap.
So I’m a bit confused, are the pre HE different than my HE?
Mine looks like a simple bolt. No tapered threads. Getting it snug with a new copper washer makes it leak free for me. I change washer every time i need to bleed.
Greg. I don’t know about the pre HE.
I do know that my 95 v12 had straight threads and copper washer. Had to replace the radiator and the new aftermarket had tapered thread plug.
I eventually replaced that one with an aluminum radiator from Wizard Cooling
Greg, that photo was of the “simple bolt” top radiator/cooling system bleed bolt in my 83 HE V12. The photo was just showing that, size and thread pitch, it very nicely fits in the M10-1.00 threaded hole.
It may be some “special” British size/thread as it was not UNF … close, but as Groucho Marx said “close, but no cigar”.
Be careful if your solution sticks up a bit. I have a pimple bump in the bonnet from using a taller banjo bolt/spacer setup on the RH side. Oops. Clearance is pretty tight above the radiator.
D.K.Graafland
14
Thanks for all the suggestions everyone! Appreciate it. I’ll get to work on it soon!
