Not much in the book about radiator fan bearing replacement anyone have any parts or procedures on replacing that bearing for the fan
EAC3437 no longer available
Thanks.
Thanks.
Did you search eBay for “Jaguar EAC3437”? If not, you should, right now.
If no luck on the net, take the bearing out, measure it and get a new one from a bearing supplier. I bet it will not be that hard to find.
Aristides
Better yet, just take the bearing to the supplier and let them measure it.
On both of these bearings, you may find it easier to find a bearing with a double-ended shaft and cut one end off. Be sure not to let the shaft get hot while cutting lest you damage the seals in the bearings.
