1996 VDP, 8 zillion miles (VIN:779967)
My story:
Driving home in 85 deg. weather and the radiator light came on.
I pulled over and at idle, no fans.
Turned off the engine, oepned the water reservoir cap slowly and carefully, and it was boiling mad.
Waited for the fountain to stop and topped it up w/water I had on hand.
Limped home slowly w/heat on high and windows open.
Radiator light went off during he drive home.
So far I have:
YES - fuses are OK on continuity check w/VOM.
YES fans run when checked w/direct-supplied 12VDC from aonther battery.
NO 12VDC at the fans electrical connector thatâs right under the radiator (with ingition in âlights on all over the dashâ position, but engine not started)
So, I assume that itâs either the relay or the temp sensor or cabling fault (not likely) - am I correct?
YES my air dam thingy got torn off ages ago - so the relay is muddy.
Pulled the relay and it looks like a somewhat muddy relay! Huh! I have no idea how to check it out.
Well, thatâs not true, I have a VOM and extra battery, so I can go play and make it click and check continutiy here and there on the pins, but Iâd need to sit down and understand the full wiring diagram, which I have in PDF form.
Questions:
Where is the temp sendor for the fans?
Is it the one on top of the thermostat housing?
Should I just swap out the relay with a used one off Ebay ($50)?
Should I just swap out the temp sensor (wherever it is)?
They seem cheap, might be quick-n-easy.
Should I push the whole thing off a handy cliff because I hate working on electrical?
Nah - Iâve driven it for 10 years w/no major issues and, hey! itâs a Jag, so: come on!
Thanks!
