I own a late 1990 4.0 sovereign. I don’t use it much, and some problems appeared to me after the car sat outside for 3 month at a workshop. I think the problems might be related
Radio won’t turn on, no light, no code asked
Aerial stays up
Blower fan not working except on “Max”
Heating not working
Boot button not working, only electrical release from the inside working. This might be a mechanical problem…
Jean, welcome to Jag-lovers. Given the car sat outside, and the problems are electrical in nature, I would suspect water ingress. Any sign of dampness in the right side front carpet / floorboard? There is an AC/radio relay (black base) beneath the dash / glove box (left hand drive vehicles). Unplug that relay and check for any signs of water damage.
If you suspect the battery is faulty or not fully charged you should rectify this before looking any further. If the battery was already old then standing unused for over three months has probably killed it completely. A poor battery on an XJ40 can cause a whole range of seemingly unconnected issues and without changing it for a known good one trying to trouble shoot electrical problems is a waste of time. Also clean all the earthing points you can find around the car, particularly those on the bulkhead because poor ground connections will also cause all kinds of electrical problems.
By the way, I did not comment on the fuse 5 and 6 failures in my previous post. Here is a link to some information about that supplied by our fellow Jag-lover Bryan N:
I concur with all responses regarding battery health. My '99 X308 (XJ-R) lives off its battery. If I let the car sit for even a couple of weeks certain circuits in the car will slowly drain the battery. You don’t give a location so worst case: South - battery life usually around 3-4 years. Northern USA, 4-5 years. A low performing battery, even if it tested OK, may cause many of the electronics woes. I’d start with replacing the battery if it’s over 4 years old. The type (open cell, sealed, etc.) is your option.
With a new battery installed power up the car and let it “adjust” for a few minutes before proceeding to crank, test components, etc. Hopefully, a new battery will be a quick fix!
Have you checked the footwell fuse boxes?
They are known failure points due to cracked (cold) solder joints. Search the site for more info and remedies.
