I have looked through the old posts on removing the wiper motor and they have been very helpful. Basically, I have managed to remove all bolts etc. holding motor BUT I am having a dickens of a time removing what most folks call the “Jesus” clip that connects the arm from the motor to the wiper mechanism. It is a little “omega” shaped clip. In my case, on of the end pieces seems to be missing which should make it easier to remove. However, I have not been able to “lift” or “pry” the clip off the ball. Almost like it is glued. Anyone have a suggestion? I probably will spray it with WD-40 if no other easy solution pops up.
Thanks
