Specifically that there is power on blue wire from the light switch in ‘on’, Jochen…?
Frank
xj6 85 Sov Europe (K/NZ)
Frank
Of course, Frank! I swapped the relay and everything works fine - so there’s got to be power on the blue wire.
Somewhere between the 56 pin in and the 56a and 56b pins out the power gets lost. That’s why I wanted to remove the case once more, make up a test rig with 12V at 56 to check what’s (not) going on.
Still, this has got time as the spare works fine in the car.
Best
Jochen
75 XJ6L 4.2 auto (UK spec)
