Since my system is likely(!?) compromised using Window7, I don’t really know how the new set-up is meant to work. In the older set-up I got the ‘quote’ window at the lower screen - allowing to read the original post at the upper half.
Later, I got the reply text on the left half of the screen - and a b… repeat of what I wrote on the right side. Still with original post of top - fair enough, but an incomprehensible misuse of screen space.
Now, using ‘quote’, the original post is invisible - and and repeat ‘quotes’ impossible. And half the screen is still just used for a repeat of what I write! There may of course be something ‘useful’ or even ‘necessary’, or whatever, for other parts of the Jag-lovers site forcing the change - but it escapes me…
To Kevin and others with the same issues; I have ‘solved’ the repeat ‘quote’ while keeping the original post. I use ‘reply’, then use ‘O’ (quote entire post), extreme left on the bar. then I write my replies in succession - and delete the parts of the original message not relevant. And hit ‘send’…
For all I know; this is what the geeks intend - but using half the screen as a default to repeat what I write is completely incomprehensible. Though, of course - you can set full screen by selection…
As an aside; being a procrastinator here as with my cars; this issue finally pushed me to buy a lap-top with Windows 11. I use Windows 7 as I have valued programs that cannot be transferred to later Windows or other systems - hence the procrastination as 7 still (mostly) works satisfactorily.
And during set-up the damned thing froze halfway through the set-up. And knowing nothing about lap-tops; I don’t know how to unfreeze it. On my desktop, as a last desperate resort, I could just unplug it - but you cannot easily ‘unpower’ a lap-top to bring it to its senses - an expert is called in…
( Advice on lap-tops not unwelcomed - though the forum is hardly the place)
Frank
xj6 85 Sov Europe (UK/NZ)
