Hi folks, I wonder if you could help please? The under dash top map light assembly is missing on my 1965 S1. I now have a replacement assembly but wondered if you could share a description or some photos showing how it is actually fixed in position and what with? Thanks in advance, Jon.
That’s perfect Angus, many thanks indeed! Jon.
Hey Angus,
If you took a whole series of refurbishing your dash top, I would like to have the picks via e mail.
Bill B
Here you go. Mine was shot from the get go. I use Weldwood Landau Top and Trim. Just clips on the windshield edge. Heat gun allows you to stretch the vinyl as you glue it down.
thanks. is that a replacement pad with foam and vinyl attached or did you recover with vinyl stock
It was a replacement pad with foam and vinyl attached.
