Very low volt gauge readings prompted me to upgrade the alternator to a 130A unit from a Land Rover Discovery 2 V8. Its NOT the amps that prompted me to use that alternator but rather its FORM FACTOR which made it rather easy to install. However, after the upgrade the volt meter still presented very low readings despite my Fluke multimeter telling me otherwise.
Without boring you with electronic detail, I found that
- the Volt meter was taking its reading from an inappropriate point - from an electronic engineering point of view; (old wires, corroded contacts, excessive number of contacts, worn ignition contacts all contributed to false readings)
- the amps drawn by the gauges themselves also influences the reading downwards.
I have now modified the point where the volt meter takes its reading from as follows:
- I installed a relay which is energised by the light green wire that previously went to the volt gauge;
- The two switch contacts of the relay is connected to a: the volt gauge and b: the permanent 12V “input” 3rd terminal cluster from the top, left side. The wiring diagram shows this as a brown wire but on the car it seems more white than brown. This wire comes directly from the double ended terminal close to the battery +. Please note this point is still not the most optimal point from an electronic engineering perspective. The MOST optimal point would be a dedicated wire coming straight from the alternator B+ terminal.
I also modified the earthing of the volt gauge so that it now has its own fresh, dedicated earthing point.
Now the readings correspond to my Fluke - without having had to re-calibrate the meter.
