The following is a list of Parts, Part Numbers and Prices of all the pieces
that I used to convert my MKVII to Four Wheel Disc.
Left Front Caliper CarQuest # 18-4081 $28.08
Right Front Caliper CarQuest # 18-4082 $28.00
Front Brake Pads CarQuest # BD 52 $20.63
Front Caliper Bolt Set CarQuest # H5004 $12.08 X2 $24.16
Front Brake Hoses CarQuest # SP296 $22.25 X2 $44.50
Left Rear Caliper CarQuest # 18-4116 $93.61(has cable
emer. brake)
Right Rear Caliper CarQuest # 18-4117 $93.61(has cable
emer. brake)
Rear Brake Pads CarQuest # RD 122 $13.96
Rear Caliper Bolts CarQuest # H 5011 $6.82 X2
$13.64
Rear Brake Hoses CarQuest # SP 296 $22.25 X2 $44.50
Left Rear Parking Lever GM # 1800-3044 $ Lost Receipt
Right Rear Parking Lever GM # 1800-3045 $ Lost Receipt
11" Vented Disc Rotors CarQuest # 5512BDR $76.41 ea X4 $305.64
Body to R Axle Brake Hose CarQuest # SP 6293 $29.34
Next Three Parts Purchased From: Master Power Brakes (704) 664-8866
Mooresville, N.C.
www.mpbrakes.com
Remote Master Cylinder-GM Type-1" Bore-Dual Chamber # MC 1001 PZ $139.95
2# Residual Valves (needed between M/C and rear calipers) # VL 3702 $26.00
each
Hydralic Brake Light Switch #
HW 2003 $19.95
Other Related & Misc. Parts
Rear Axle Inner Seal CarQuest # 42763 $14.48 each
Rear Axle Outer Seal CarQuest # 440085 $ 8.27 each
Rear Axle Bearing CarQuest # 25877 $13.52 each
Rear Axle Race CarQuest # 25820 $ 8.42 each
Front Inner Race CarQuest # 14276 $ 5.09 each
Front Inner Bearing CarQuest # 14138A $15.10 each
Front Outer Race CarQuest # 09195 $ 4.58 each
Front Outer Bearing CarQuest # 09067 $ 9.78 each
This is by no means a simple conversion, it involves some machining and
some serious fabrication. The Caliper Mounts have to be made from scratch
from plate steel. A mount to bolt the GM Master Cylinder in place of the
original has to be fabricated and also a plunger pin. The Rotors have to be
machined somewhat,
the center hole has to be opened up to a 3.875" ID and the 5 stud holes have
to be counterbored from the rear 1/8" deep to a .625 ID.
I have patterns for the caliper mounts and am trying to get prints drawn.
The biggest problem I had was the fact that the calipers are rather bulky
and I had to machine some of the body away to have enough clearance to keep
them from rubbing the wheels. It’s not as big a deal as it might sound, it’s
just a matter of sanding some of the housing away which is quite thick. All
of the CarQuest Brake parts were original equipment on 1969 thru 1978
Cadillac Eldorado and Oldsmobile Toronado and also some Buicks of the same
era. There may well be another caliper that will work that is not so bulky.
There are several ways to approach this conversion and this is just what I
was able to get to work. I drove the car for a couple of thousand mile and
never had any problems, but I have since disassembled the car for a
“frame-up” rebuild. I can assure you that the car would “stand on it’s
nose” when you wanted it to.
As many of you know the original hydralic system is a single chamber
system. There is not a separate circuit for the front and rear brakes as on
more modern cars.
If you blow a seal or a line you lose all brakes. It may be possible to use
the rotors and calipers I have listed with the original system if the fluid
displacement of the original master cylinder is adequate but even though you
will have disc brakes, you
will still have a “single circuit” system.
I will be happy to try to help anyone that wants to attempt this
modification is you will contact me “direct”. I want it understood that
this is not something you can do
in your garage some Saturday with a few hand tools!!
I hope this information will be of use to some of my fellow Jag-Lovers.
Regards
Ken Nicks (tr302@aol.com)
[Commercial use of subscribers e-mail addresses prohibited.]==============================
