Hi folks,
Since my idle drops about 300 rpm as soon as I put the DG250
in gear, I was wondering if the little pressure switch that
sits on a manifold bracket between the carbs might not have
something to do with it.
Truth be told, I’d removed the switch along with the P/O’s
home-made butterfly choke (starting) system, thinking it was
part of it, but now that I’ve read a couple of threads
mentioning ‘‘kick-down’’ and ‘‘anti-creep’’ switches located in
that same area, I started having second thoughts.
I re-installed the switch as it was, but it doesn’t seem to
do anything towards keeping the idle from dropping radically
when shifting into drive or reverse.
On the other hand, the tranny kicks down just fine without it.
Can anybody tell me what this switch is actually intended to do?
Thanks,
Jacques–
Jacques B / 62 MK II 3.8 Auto
Saint Augustine, Florida, United States
