Listers,
I am seeking some specific advice please. I am setting up to
replace the Burman P/S box from my Mark IX with a Saginaw box
from a 70’s Chevrolet. All else will be original in this
complete ground up restoration, but the Burman box leaks and I
have had it out and back in six times and it still leaks with
only gravity feeding the fluid.
Before you scoff, I have re-manufactured shims (anyone want
some) and used fresh fittings including helicoiling the top
plate to allow tightening the top banjo fitting and fitting a
brand new OEM top gasket (hell of a find). The engineering
advice was that once worn, I would never achieve success
without a hard re-chrome finish on the shaft and then
regrinding it to spec.
So, Steve Kennedy suggested the possibility of the Saginaw box.
What I want to learn is the pressure generated by the Jaguar
P/S pump so I can determine if the Saginaw box will be
adequately pressurized to operate properly.
Can anyone tell me the pressure generated by the Jag pump?
Hoping for answers.
ILOB–
Iain Buxton, Reno, NV 66 3.8 S-Type 61 Mark IX 2000 S-Type
